  4. Node.Js wird nicht gefunden
    6.3k
26 Beiträge 3 Kommentatoren 1.3k Aufrufe 2 Beobachtet
    @zlorsh
    Die Zeile nur node12 in der influxdb.list würde ich löschen.
    Die ist a) falsch bei dir (falsches Release) und b) ist node12 abgekündigt
    Z Offline
    Z Offline
    Zlorsh
    @thomas-braun ok werde ich raus löschen, leider hat der versuch auch nicht geklappt :(
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    > iobroker.js-controller@4.0.23 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.17
    > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram
    > node-gyp rebuild
    make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
    In file included from ../../nan/nan.h:60,
                     from ../src/unix_dgram.cc:5:
    /home/iobroker/.cache/node-gyp/14.19.3/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/14.19.3/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
      SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
      COPY Release/unix_dgram.node
    make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
    > iobroker.js-controller@4.0.23 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    Successfully migrated 2083 objects to Redis Sets
    object _design/system updated
    host.raspberrypi install adapter backitup
    These apt-get packages were already installed: cifs-utils, nfs-common
    upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
    upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
    upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
    upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    host.raspberrypi Invalid version of "admin". Installed "4.2.1", required ">=5.2.0"
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 32
    npm ERR! iobroker.js-controller@4.0.23 install: `node iobroker.js setup first`
    npm ERR! Exit status 32
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@4.0.23 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2022-06-01T20_20_36_990Z-debug.log
    pi@raspberrypi:/opt/iobroker $ iobroker status
    internal/modules/cjs/loader.js:905
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
        at Function.Module._load (internal/modules/cjs/loader.js:746:27)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
        at internal/main/run_main_module.js:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    • Z Zlorsh
      > node-gyp rebuild
      npm ERR! errno 32
      npm ERR!
        throw err;
        requireStack: []
      @zlorsh sagte in Node.Js wird nicht gefunden:
      wie lange hast du keine updates mehr gemacht?
      Z 1 Antwort Letzte Antwort
        Z Offline
        Z Offline
        Zlorsh
        schrieb am zuletzt editiert von Zlorsh
        @homoran Leider sehr lange :(
        Ich hatte es so verstanden dass ich erst das nodejs update machen muss und dann den admin
        • Z Zlorsh
          ist auch richtig.
          und du hast wirlich ubuntu auf einen Pi2?
            ist auch richtig.
            Z Offline
            Z Offline
            Zlorsh
            @homoran sehr gute frage, das hab ich vor Ewigkeiten installiert das Teil. Wenn ich so drüber nach denke ist es wohl eher ein Raspberian oder so?!
            Kurz geprüft....
            pi@raspberrypi:/opt/iobroker $ cat /etc/*release
            PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
            NAME="Raspbian GNU/Linux"
            VERSION_ID="10"
            VERSION="10 (buster)"
            VERSION_CODENAME=buster
            ID=raspbian
            ID_LIKE=debian
            HOME_URL="http://www.raspbian.org/"
            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
            • Z Zlorsh
              > node-gyp rebuild
              npm ERR! errno 32
              npm ERR!
                throw err;
                requireStack: []
              @zlorsh
              Da ist Chaos drin...
              iobroker update -i
              funktioniert noch?
                @zlorsh
                iobroker update -i
                funktioniert noch?
                Z Offline
                Z Offline
                Zlorsh
                @thomas-braun leider nein
                pi@raspberrypi:/opt/iobroker $ iobroker update -i
                  throw err;
                  requireStack: []
                • Z Zlorsh
                  Kurz geprüft....
                  VERSION_ID="10"
                  ID=raspbian
                  ID_LIKE=debian
                  langsam gefällt mir deine Idee
                  Ich glaube ich mach einfach ein ganz cleanen reinstall von allem
                    Z Offline
                    Z Offline
                    Zlorsh
                    @homoran Ja ist vermutlich das einfachste...
                    Genau aus dem Grund hab ich nie Updates gemacht, never change a running system :)
                    • Z Zlorsh
                      Das war jetzt der falscheste Satz an der ungünstigsten Stelle!
                      Deine Probleme hast du weil du so gehandelt hast.
                        Z Offline
                        Z Offline
                        Zlorsh
                        @homoran Ja, da könnte was dran sein, shame on me 😨🙊
                        • Z Zlorsh
                          Ich weiß nicht ob @Thomas-Braun noch Lust hat das tote Pferd wiederzubeleben. Könnte eine Herausforderung für ihn sein.
                          Sonst mach am besten alles neu, angefangen vom aktuellen Raspberry Pi OS lite.
                          und erzähl uns wenn du wieder in local installiert hast, wie du das gemacht hast. Interessiert uns brennend!
                          • Z Zlorsh
                            So lange, bis dir das tolle running system komplett versumpft.
                            Ist dir hier passiert.
                              @homoran sagte in Node.Js wird nicht gefunden:
                              Ehrlich gesagt nicht. Wobei das Grundsystem ja jetzt wohl auf Stand ist.
                              Ist 'nur' noch der ioBroker in der Update-Falle versunken.
                                Z Offline
                                Z Offline
                                Zlorsh
                                Ich habe nun ganz neu installiert, trotzdem vielen Dank für eure Versuche mein Problem zu lösen.
                                Von mir aus kann der Thread gerne geschlossen werden.
