  4. Kann vis/edit.html nicht finden
    6.3k
80 Beiträge 10 Kommentatoren 9.4k Aufrufe 7 Beobachtet
  • B Beowolf
    @djmarc75
    pi@raspberrypi:~ $ iobroker list instances
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
    + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
      system.adapter.luftdaten.0              : luftdaten             : raspberrypi                              - disabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : ioBroker-Slave-1                         -  enabled, port: 1887, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 192.168.49.38, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
    + system.adapter.wiffi-wz.0               : wiffi-wz              : raspberrypi                              -  enabled
    + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
    + instance is alive
    pi@raspberrypi:~ $ ^C
    crunchipC Abwesend
    crunchipC Abwesend
    @beowolf deine vis instanz läuft nicht
      Beowolf
      @crunchip
      und was mache ich dagegen? Habe den pi schon neu gestartet.
      • B Beowolf
        @crunchip
        @beowolf
        Mich macht aber stutzig, dass vis nicht auch beim
        iobroker update -i
        aufgeführt ist. Das sollte eigentlich da auch erscheinen.
          @beowolf
          iobroker update -i
          Beowolf
          + instance is alive
          pi@raspberrypi:~ $
          Thomas BraunT B 2 Antworten Letzte Antwort
          • B Beowolf
            + instance is alive
            pi@raspberrypi:~ $
            @beowolf
            iobroker start vis
            • B Beowolf
              + instance is alive
              pi@raspberrypi:~ $
              Beowolf
              pi@raspberrypi:~ $ iobroker update -i
              Used repository: stable
              Adapter    "admin"        : 5.3.8    , installed 5.3.8
              Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
              Adapter    "alias-manager": 1.2.4    , installed 1.2.4
              Adapter    "backitup"     : 2.4.6    , installed 2.4.6
              Adapter    "discovery"    : 3.0.3    , installed 3.0.3
              Adapter    "email"        : 1.0.10   , installed 1.0.10
              Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
              Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
              Adapter    "ical"         : 1.12.1   , installed 1.12.1
              Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
              Adapter    "info"         : 1.9.19   , installed 1.9.19
              Adapter    "iot"          : 1.11.4   , installed 1.11.4
              Adapter    "iqontrol"     : 2.0.0    , installed 2.0.1
              Adapter    "javascript"   : 5.7.0    , installed 5.7.0
              Controller "js-controller": 4.0.23   , installed 4.0.23
              Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
              Adapter    "mqtt"         : 3.0.6    , installed 3.0.6
              Adapter    "pushover"     : 2.1.0    , installed 2.1.0
              Adapter    "simple-api"   : 2.6.5    , installed 2.6.5
              Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
              Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
              Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
              Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
              Adapter    "wled"         : 0.6.3    , installed 0.6.3
              pi@raspberrypi:~ $
                @beowolf
                iobroker start vis
                Beowolf
                @thomas-braun sagte in Kann vis/edit.html nicht finden:
                @beowolf
                iobroker start vis
                keine Änderung
                • B Beowolf
                  @beowolf
                  iobroker start vis
                  keine Änderung
                  @beowolf
                  Was steht denn im Log File, wenn die vis gestartet wird?
                  iobroker logs --watch
                  anschauen, vis starten und neue Ausgaben beobachten.
                    @beowolf
                    Beowolf
                    Wenn ich den VIA Adapter versuche neu zu starten kommt das 😳
                    2022-06-01 10:08:58.634  - silly: mqtt.0 (1415) Objects system redis pmessage system.adapter.*/cfg.o.system.adapter.vis.0:{"_id":"system.adapter.vis.0","type":"instance","common":{"name":"vis","version":"1.4.15","title":"Visualisation","titleLang":{"en":"Visualisation","de":"Visualisierung","ru":"Визуализация","pt":"Visualização","nl":"Visualisatie","fr":"Visualisation","it":"Visualizzazione","es":"Visualización","pl":"Wizualizacja","zh-cn":"可视化"},"news":{"1.1.4":{"en":"Fixing the saving of project\nFixing the background selector\nFixing the null pointer problem\nFixing the selection helper\nUpdate translations","de":"Die Projektspeicherung ist korrigiert\nHintergrundselektors ist korrigiert\nReparieren des Null-Zeiger-Problems\nAuswahlhelfer korrigiert\nÜbersetzungen","ru":"исправлено сохранение проекта\nисправлен переключатель фона\nУстранение проблемы с нулевым указателем\nисправлен выбор виджетов\nпереводы","pt":"Reparando a poupança do projeto\nCorrigindo o seletor de fundo\nCorrigindo o problema do ponteiro nulo\nReparando o auxiliar de seleção\nAtualizar traduções","nl":"Het opslaan van het project bevestigen\nDe achtergrondkiezer bevestigen\nVaststelling van het probleem met de null-wijzer\nDe selectiehulp bevestigen\nUpdate vertalingen","fr":"Fixer la sauvegarde du projet\nFixer le sélecteur d'arrière-plan\nCorrection du problème du pointeur nul\nCorrection de l'assistant de sélection\nMise à jour","it":"Risolvendo il salvataggio del progetto\nRisolto il problema con il selettore dello sfondo\nRisolvere il problema con il puntatore nullo\nRiparare l'helper di selezione\nAggiorna traduzioni","es":"Corregir el guardado del proyecto\nReparar el selector de fondo\nCorregir el problema del puntero nulo\nReparar el asistente de selección\nActualizar traducciones","pl":"Naprawienie zapisu projektu\nNaprawianie wybieraka tła\nNaprawiono problem z pustym wskaźnikiem\nNaprawianie pomocnika wyboru\nZaktualizuj tłumaczenia"},"1.1.2":{"en":"Fixing the saving of project\nFixing the background selector\nFixing the null pointer problem\nFixing the selection helper\nUpdate translations","de":"Die Projektspeicherung ist korrigiert\nHintergrundselektors ist korrigiert\nReparieren des Null-Zeiger-Problems\nAuswahlhelfer korrigiert\nÜbersetzungen","ru":"исправлено сохранение проекта\nисправлен переключатель фона\nУстранение проблемы с нулевым указателем\nисправлен выбор виджетов\nпереводы","pt":"Reparando a poupança do projeto\nCorrigindo o seletor de fundo\nCorrigindo o problema do ponteiro nulo\nReparando o auxiliar de seleção\nAtualizar traduções","nl":"Het opslaan van het project bevestigen\nDe achtergrondkiezer bevestigen\nVaststelling van het probleem met de null-wijzer\nDe selectiehulp bevestigen\nUpdate vertalingen","fr":"Fixer la sauvegarde du projet\nFixer le sélecteur d'arrière-plan\nCorrection du problème du pointeur nul\nCorrection de l'assistant de sélection\nMise à jour","it":"Risolvendo il salvataggio del progetto\nRisolto il problema con il selettore dello sfondo\nRisolvere il problema con il puntatore nullo\nRiparare l'helper di selezione\nAggiorna traduzioni","es":"Corregir el guardado del proyecto\nReparar el selector de fondo\nCorregir el problema del puntero nulo\nReparar el asistente de selección\nActualizar traducciones","pl":"Naprawienie zapisu projektu\nNaprawianie wybieraka tła\nNaprawiono problem z pustym wskaźnikiem\nNaprawianie pomocnika wyboru\nZaktualizuj tłumaczenia"},"1.1.1":{"en":"The problem with view change on the touch devices fixed","de":"Das Problem mit der Ansicht Änderung auf den Touch-Geräten behoben","ru":"Проблема с изменением вида на сенсорных устройствах исправлена","pt":"O problema com a mudança de exibição nos dispositivos de toque fixos","nl":"Het probleem met de wijziging van weergave op de aanraakapparaten is opgelost","fr":"Le problème avec le changement de vue sur les appareils tactiles fixés","it":"Risolto il problema con il cambio di vista sui dispositivi touch","es":"El problema con el cambio de vista en los dispositivos táctiles solucionó","pl":"Naprawiono problem z zmianą widoku na urządzeniach dotykowych"},"1.0.5":{"en":"show number of datapoints in every project","de":"Zeige die Anzahl von Datenpunkten in jedem Projekt","ru":"Показывет количество используемых данных в каждом проекте"},"1.0.4":{"en":"Add autocomplete for view CSS options\nchange edit of view CSS background options","de":"Automatische Vervollständigung für View-CSS-Optionen hinzufügen\nÄndern der CSS-Hintergrundoptionen für View","ru":"Добавлено автозаполнение для CSS опций страницы\nИзменение редактирования background CSS страницы"},"1.0.3":{"en":"Release candidate\nFix parse of invalid bindings\nadd moment.js","de":"Release candidate\nKorrigiere die Aufbau von falschen Bindings\nmoment.js hinzugefügt","ru":"Release candidate\nПоправлен рендеринг неправильных bindings\nДобавлен moment.js"},"0.15.6":{"en":"Added array operator to bindings","de":"Array Operator zu bindings hinzugefügt"},"0.15.5":{"en":"Fix widgets upload","de":"Korrigiere Widgets uplaod","ru":"Исправлено обновление виджетов"},"0.15.4":{"en":"Add swipe","de":"Swipe hunzugefügt","ru":"Добавлен swipe"},"0.15.3":{"en":"Add full screen widget\nFix timestamp widget","de":"Full Screen Widget hunzugefügt\nKorrigiere timestamp widget","ru":"Добавлен виджет full screen\nИсправлен виджет timestamp"},"0.15.2":{"en":"Fix binding if it has \"-\" in the OID","de":"Korrigiere den fehler mit Binding und \"-\" in OID","ru":"Исправлены bindings, если содержат минус в имени"},"0.15.1":{"en":"Fix error with context menu\nAllow add class to view","de":"Korrigiere den fehler mit dem Kontext-Menu\nErlaube Klasse zur Seite hinzufügen","ru":"Исправлено контекстное меню\nМожно добавлять классы к страницам"},"1.1.7":{"en":"view8 corrected","de":"view8 korrigiert","ru":"view8 исправлено","pt":"view8 corrigido","nl":"view8 gecorrigeerd","fr":"view8 corrigé","it":"view8 corretta","es":"view8 corregido","pl":"view8 poprawiony"},"1.1.6":{"en":"New special bindings are supported\nError with fast view changes is fixed\nfix (jqui - ctrl - IconState / val - Icon Bool)","de":"Neue spezielle Bindungen werden unterstützt\nFehler bei schnellen Ansichtsänderungen ist behoben\nfix (jqui - Strg - IconState / val - Icon Bool)","ru":"Поддерживаются новые специальные привязки\nИсправлена ​​ошибка с быстрым изменением вида\nfix (jqui - ctrl - IconState / val - Icon Bool)","pt":"Novas ligações especiais são suportadas\nErro com alterações de visualização rápida corrigidas\ncorrigir (jqui - ctrl - IconState / val - Bool de ícone)","nl":"Nieuwe speciale bindingen worden ondersteund\nFout bij snelle wijzigingen in weergave is opgelost\nfix (jqui - ctrl - IconState / val - Icon Bool)","fr":"Les nouvelles liaisons spéciales sont prises en charge\nErreur avec les changements d'affichage rapide est fixée\ncorriger (jqui - ctrl - IconState / val - Icône Bool)","it":"Sono supportati nuovi binding speciali\nL'errore con le modifiche veloci alla vista è stato risolto\ncorreggere (jqui - ctrl - IconState / val - Icon Bool)","es":"Se admiten nuevos enlaces especiales\nSe corrigió el error con los cambios de vista rápida\ncorregir (jqui - ctrl - IconState / val - Icon Bool)","pl":"Nowe powiązania specjalne są obsługiwane\nNaprawiono błąd związany z szybkimi zmianami widoku\nnapraw (jqui - ctrl - IconState / val - Icon Bool)"},"1.1.10":{"en":"Add Chinese support","de":"Chinesische Unterstützung hinzufügen","ru":"Добавить поддержку китайцев","pt":"Adicionar suporte chinês","nl":"Voeg Chinese ondersteuning toe","fr":"Ajouter un support chinois","it":"Aggiungi supporto cinese","es":"Añadir soporte chino","pl":"Dodaj chińskie wsparcie","zh-cn":"添加中文支持"},"1.1.8":{"en":"File dialog was corrected","de":"Dateidialog wurde korrigiert","ru":"Исправлено диалоговое окно файла","pt":"A caixa de diálogo do arquivo foi corrigida","nl":"Bestandsdialoog is gecorrigeerd","fr":"Le dialogue de fichier a été corrigé","it":"La finestra di dialogo del file è stata corretta","es":"Se corrigió el diálogo del archivo","pl":"Okno dialogowe pliku zostało poprawione"},"1.2.2":{"en":"Preparations for js-controller 2.0","de":"Vorbereitungen für js-controller 2.0","ru":"Подготовка к js-controller 2.0","pt":"Preparativos para js-controller 2.0","nl":"Voorbereidingen voor js-controller 2.0","fr":"Préparations pour js-controller 2.0","it":"Preparativi per js-controller 2.0","es":"Preparativos para js-controller 2.0","pl":"Przygotowania do js-kontrolera 2.0","zh-cn":"js-controller 2.0的准备"},"1.2.1":{"en":"fixed upload of files","de":"Fehler beim Hochladen von Dateien behoben","ru":"исправлена загрузка файлов","pt":"upload fixo de arquivos","nl":"vaste upload van bestanden","fr":"téléchargement fixe de fichiers","it":"caricamento fisso di file","es":"carga fija de archivos","pl":"naprawione przesyłanie plików","zh-cn":"修复了文件上传"},"1.2.0":{"en":"Translations were added","de":"Übersetzungen wurden hinzugefügt","ru":"Добавлены переводы","pt":"Traduções foram adicionadas","nl":"Vertalingen zijn toegevoegd","fr":"Les traductions ont été ajoutées","it":"Sono state aggiunte traduzioni","es":"Se agregaron traducciones","pl":"Dodano tłumaczenia","zh-cn":"翻译增加了"},"1.1.11":{"en":"Bool HTML was Improved ","de":"Bool HTML wurde verbessert","ru":"Bool HTML был улучшен","pt":"Bool HTML foi melhorado","nl":"Bool HTML is verbeterd","fr":"Bool HTML a été amélioré","it":"Bool HTML è stato migliorato","es":"Bool HTML fue mejorado","pl":"Bool HTML został ulepszony","zh-cn":"“Bool HTML”得到了改进"},"1.2.3":{"en":"Small changes in license handling were made","de":"Kleine Änderungen in der Lizenzverwaltung wurden vorgenommen","ru":"Небольшие изменения в обработке лицензий","pt":"Pequenas mudanças no manuseio de licenças foram feitas","nl":"Er zijn kleine wijzigingen aangebracht in de licentiebehandeling","fr":"De petits changements dans la gestion des licences ont été effectués","it":"Sono state apportate piccole modifiche alla gestione delle licenze","es":"Se hicieron pequeños cambios en el manejo de la licencia.","pl":"Wprowadzono niewielkie zmiany w obsłudze
                    • B Beowolf
                      Beowolf
                      hier geht es weiter
                      licencji","zh-cn":"许可证处理方面进行了一些小的更改"},"1.2.4":{"en":"Table widget was extended with the selected object ID.","de":"Das Tabellenwidget wurde um die ausgewählte Objekt-ID erweitert.","ru":"Табличный виджет был расширен с выбранным идентификатором объекта.","pt":"O widget de tabela foi estendido com o ID do objeto selecionado.","nl":"Tabelwidget is uitgebreid met de geselecteerde object-ID.","fr":"Le widget de table a été étendu avec l'ID d'objet sélectionné.","it":"Il widget della tabella è stato esteso con l'ID oggetto selezionato.","es":"El widget de tabla se amplió con el ID de objeto seleccionado.","pl":"Widżet tabeli został rozszerzony o wybrany identyfikator obiektu.","zh-cn":"表窗口小部件已扩展为具有选定的对象ID。"},"1.2.11":{"en":"The error message about the non-found chart view was fixed.","de":"Die Fehlermeldung zur nicht gefundenen Diagrammansicht wurde behoben.","ru":"Исправлено сообщение об ошибке о ненайденном просмотре диаграммы.","pt":"A mensagem de erro sobre a exibição do gráfico não encontrado foi corrigida.","nl":"Het foutbericht over de niet-gevonden kaartweergave is opgelost.","fr":"Le message d'erreur concernant la vue graphique non trouvée a été corrigé.","it":"Il messaggio di errore relativo alla visualizzazione del grafico non trovata è stato corretto.","es":"Se solucionó el mensaje de error sobre la vista de gráfico no encontrado.","pl":"Komunikat o błędzie dotyczący nieodnalezionego widoku wykresu został naprawiony.","zh-cn":"有关未找到的图表视图的错误消息已修复。"},"1.2.10":{"en":"JSON strings will be parsed in VIS bindings","de":"JSON-Zeichenfolgen werden in VIS-Bindungen analysiert","ru":"Строки JSON будут анализироваться в привязках VIS","pt":"Strings JSON serão analisadas em associações VIS","nl":"JSON-strings worden geparseerd in VIS-bindingen","fr":"Les chaînes JSON seront analysées dans les liaisons VIS","it":"Le stringhe JSON verranno analizzate nelle associazioni VIS","es":"Las cadenas JSON se analizarán en enlaces VIS","pl":"Ciągi JSON będą analizowane w powiązaniach VIS","zh-cn":"JSON字符串将在VIS绑定中解析"},"1.2.9":{"en":"Charts are now supported","de":"Diagramme werden jetzt unterstützt","ru":"Графики теперь поддерживаются","pt":"Gráficos agora são suportados","nl":"Grafieken worden nu ondersteund","fr":"Les graphiques sont désormais pris en charge","it":"I grafici sono ora supportati","es":"Los gráficos ahora son compatibles","pl":"Wykresy są teraz obsługiwane","zh-cn":"现在支持图表"},"1.2.6":{"en":"Added the better error message if license could not be parsed","de":"Die bessere Fehlermeldung wurde hinzugefügt, wenn die Lizenz nicht analysiert werden konnte","ru":"Добавлено лучшее сообщение об ошибке, если лицензия не может быть проанализирована","pt":"Adicionada a melhor mensagem de erro se a licença não puder ser analisada","nl":"Het betere foutbericht toegevoegd als de licentie niet kon worden geparseerd","fr":"Ajout du meilleur message d'erreur si la licence n'a pas pu être analysée","it":"Aggiunto il messaggio di errore migliore se non è stato possibile analizzare la licenza","es":"Se agregó el mejor mensaje de error si no se pudo analizar la licencia","pl":"Dodano lepszy komunikat o błędzie, jeśli nie można przeanalizować licencji","zh-cn":"如果无法解析许可证,则添加了更好的错误消息"},"1.2.12":{"en":"only parse arrays and json objects, not booleans, normal strings etc","de":"Analysieren Sie nur Arrays und JSON-Objekte, keine Booleschen Werte, normale Zeichenfolgen usw.","ru":"анализировать только массивы и объекты json, а не логические значения, обычные строки и т. д.","pt":"analisa apenas matrizes e objetos json, não booleanos, strings normais, etc.","nl":"alleen arrays en json-objecten ontleden, geen booleans, normale strings enz","fr":"analyser uniquement les tableaux et les objets json, pas les booléens, les chaînes normales, etc.","it":"analizza solo array e oggetti json, non booleani, stringhe normali ecc","es":"solo analizar matrices y objetos json, no booleanos, cadenas normales, etc.","pl":"analizuje tylko tablice i obiekty json, a nie wartości logiczne, zwykłe ciągi znaków itp","zh-cn":"仅解析数组和json对象,不解析布尔值,普通字符串等"},"1.3.4":{"en":"Corrected the error on older devices","de":"Der Fehler auf älteren Geräten wurde behoben","ru":"Исправлена ошибка на старых устройствах","pt":"Corrigido o erro em dispositivos mais antigos","nl":"De fout op oudere apparaten gecorrigeerd","fr":"Correction de l'erreur sur les appareils plus anciens","it":"Corretto l'errore sui dispositivi meno recenti","es":"Corregido el error en dispositivos más antiguos.","pl":"Poprawiono błąd na starszych urządzeniach","zh-cn":"更正了旧设备上的错误"},"1.3.3":{"en":"Return de-bounce settings back\nCorrected error with {username} binding","de":"Geben Sie die De-Bounce-Einstellungen zurück\nFehler mit Bindung {Benutzername} behoben","ru":"Вернуть настройки де-дребезга назад\nИсправлена ошибка с привязкой {username}","pt":"Retorne as configurações de de-bounce de volta\nErro corrigido com ligação de {nome de usuário}","nl":"Zet de instellingen voor terugveren terug\nFout gecorrigeerd met binding van {gebruikersnaam}","fr":"Rétablir les paramètres d'anti-rebond\nErreur corrigée avec la liaison {username}","it":"Ripristina le impostazioni di antirimbalzo\nErrore corretto con l'associazione {nomeutente}","es":"Devolver la configuración de rebote\nError corregido con la vinculación de {username}","pl":"Przywróć ustawienia odbijania\nPoprawiony błąd z wiązaniem {nazwa użytkownika}","zh-cn":"返回反跳设置\n已更正{username}绑定的错误"},"1.3.1":{"en":"Added the auto-focus option to the input widgets","de":"Die Autofokus-Option wurde zu den Eingabe-Widgets hinzugefügt","ru":"Добавлена опция автофокуса для виджетов ввода","pt":"Adicionada a opção de foco automático aos widgets de entrada","nl":"De auto-focus-optie toegevoegd aan de invoerwidgets","fr":"Ajout de l'option de mise au point automatique aux widgets d'entrée","it":"Aggiunta l'opzione di messa a fuoco automatica ai widget di input","es":"Se agregó la opción de enfoque automático a los widgets de entrada.","pl":"Dodano opcję automatycznego ustawiania ostrości do widżetów wejściowych","zh-cn":"在输入小部件中添加了自动对焦选项"},"1.3.0":{"en":"On pending getStates, try again instead of drop\nFixed the file manager typos\nAdded momentDate for the bindings","de":"Versuchen Sie es bei ausstehenden getStates erneut, anstatt es zu löschen\nDie Tippfehler im Dateimanager wurden behoben\nMomentDate für die Bindungen hinzugefügt","ru":"В ожидании getStates попробуйте снова вместо того, чтобы отбрасывать\nИсправлены опечатки в файловом менеджере\nДобавлен моментDate для привязок","pt":"Em getStates pendentes, tente novamente em vez de descartar\nCorrigidos erros de digitação do gerenciador de arquivos\nAdicionado momentDate para as ligações","nl":"Probeer het op getStates in afwachting opnieuw in plaats van te laten vallen\nTypefouten in bestandsbeheer opgelost\nMomentDate toegevoegd voor de bindingen","fr":"Sur getStates en attente, réessayez au lieu de supprimer\nCorrection des fautes de frappe du gestionnaire de fichiers\nMomentDate ajouté pour les fixations","it":"In attesa di getStates, riprova invece di rilasciare\nRisolti gli errori di battitura del file manager\nMomentDate aggiunto per le associazioni","es":"En getStates pendientes, inténtelo de nuevo en lugar de soltar\nSe corrigieron los errores tipográficos del administrador de archivos\nMomento añadido Fecha para las fijaciones","pl":"W oczekiwaniu na getStates spróbuj ponownie zamiast upuszczać\nNaprawiono literówki w menedżerze plików\nDodano momentDate dla wiązań","zh-cn":"在待处理的getStates上,重试而不是drop\n修复了文件管理器输入错误\n为绑定添加了momentDate"},"1.3.8":{"en":"fix play sounds on iOS Safari an android\nvisEditInspect: format dimension added\nReplace travis and appveyor by the github actions\nAllow resources to be loaded as blob\n(Excodibur ) Allow resources to be loaded as blob","de":"Fix Play Sounds auf iOS Safari und Android\nvisEditInspect: Formatdimension hinzugefügt\nErsetzen Sie Travis und Appveyor durch die Github-Aktionen\nZulassen, dass Ressourcen als Blob geladen werden\n(Excodibur) Ermöglicht das Laden von Ressourcen als Blob","ru":"исправить звуки воспроизведения на iOS Safari и Android\nvisEditInspect: добавлено измерение формата\nЗамените travis и appveyor действиями github\nРазрешить загрузку ресурсов как blob\n(Excodibur) Разрешить загрузку ресурсов как blob","pt":"corrigir sons de reprodução no iOS Safari e Android\nvisEditInspect: dimensão do formato adicionada\nSubstitua travis e appveyor pelas ações do github\nPermitir que recursos sejam carregados como blob\n(Excodibur) Permite que os recursos sejam carregados como blob","nl":"repareer afspeelgeluiden op iOS Safari en Android\nvisEditInspect: formaatdimensie toegevoegd\nVervang travis en appveyor door de github-acties\nToestaan dat resources als blob worden geladen\n(Excodibur) Toestaan dat bronnen als blob worden geladen","fr":"réparer les sons de lecture sur iOS Safari et Android\nvisEditInspect: dimension de format ajoutée\nRemplacez travis et appveyor par les actions github\nAutoriser le chargement des ressources en tant qu'objet blob\n(Excodibur) Autoriser le chargement des ressources en tant que blob","it":"correggere i suoni di riproduzione su iOS Safari e Android\nvisEditInspect: dimensione del formato aggiunta\nSostituisci travis e appveyor con le azioni github\nConsenti il caricamento delle risorse come BLOB\n(Excodibur) Consenti il caricamento delle risorse come BLOB","es":"arreglar sonidos de reproducción en iOS Safari y Android\nvisEditInspect: dimensión de formato agregada\nReemplaza travis y appveyor por las acciones de github\nPermitir que los recursos se carguen como blob\n(Excodibur) Permitir que los recursos se carguen como blob","pl":"naprawianie odtwarzania dźwięków w iOS Safari i Androidzie\nvisEditInspect: dodano wymiar formatu\nZastąp travis i appveyor akcjami github\nZezwalaj na ładowanie zasobów jako obiektu blob\n(Excodibur) Zezwalaj na ładowanie zasobów jako obiektu blob","zh-cn":"修复iOS Safari和Android上的播放声音\nvisEditInspect:添加了格式尺寸\n用github操作替换travis和appveyor\n允许将资源加载为Blob\n(Excodibur)允许将资源加载为Blob"},"1.3.7":{"en":"Bug Fixed - Binding in JSON string","de":"Fehler behoben - Bindung in JSON-Zeichenfolge","ru":"Исправлена ошибка - привязка в строке JSON","pt":"Bug corrigido - vinculação em string JSON","nl":"Bug opgelost - Binding in JSON-string","fr":"Bug corrigé - Liaison dans la chaîne JSON","it":"Bug risolto: binding nella stringa JSON","es":"Error solucionado: enlace en cadena JSON","pl":"Naprawiono błąd - wiązanie w ciągu JSON","zh-cn":"错误修复-JSON字符串绑定"},"1.3.6":{"en":"Corrected: old browser issue\nCorrected: play sounds on iOS Safari\nAdded the optional arguments to support Material Design Widgets\n","de":"Behoben: altes Browserproblem\nKorrigiert: Spielen Sie Sounds auf iOS Safari ab\nDie optionalen Argumente zur Unterstützung von Material Design Widgets wurden hinzugefügt\n","ru":"Исправлено: старая проблема с браузером.\nИсправлено: воспроизведение звуков в iOS Safari.\nДобавлены необязательные аргументы для поддержки виджетов Material Design.\n","pt":"Corrigido: problema do navegador antigo\nCorrigido: reproduzir sons no iOS Safari\nAdicionados os argumentos opcionais para oferecer suporte a Widgets de Material Design\n","nl":"Opgelost: oud browserprobleem\nGecorrigeerd: speel geluiden af op iOS Safari\nDe optionele argumenten toegevoegd om Material Design Widgets te ondersteunen\n","fr":"Corrigé: ancien problème de navigateur\nCorrigé: jouer des sons sur iOS Safari\nAjout des arguments facultatifs pour prendre en charge les widgets de conception de matériaux\n","it":"Corretto: vecchio problema del browser\nCorretto: riproduci suoni su iOS Safari\nAggiunti gli argomenti opzionali per supportare i widget di Material Design\n","es":"Corregido: problema del navegador antiguo\nCorregido: reproducir sonidos en iOS Safari\nSe agregaron los argumentos opcionales para admitir widgets de diseño de materiales.\n","pl":"Poprawione: stary problem z przeglądarką\nPoprawiono: odtwarzaj dźwięki w iOS Safari\nDodano opcjonalne argumenty do obsługi widżetów Material Design\n","zh-cn":"更正的:旧的浏览器问题\n纠正:在iOS Safari上播放声音\n添加了可选参数以支持Material Design Widgets\n"},"1.3.9":{"en":"Added support of local browser variables\nBug fix for null & NaN values in width and height\nAdded support for admin5","de":"Unterstützung für lokale Browservariablen hinzugefügt\nFehlerbehebung für Null- und NaN-Werte in Breite und Höhe\nUnterstützung für admin5 hinzugefügt","ru":"Добавлена поддержка локальных переменных браузера.\nИсправлена ошибка для значений NULL и NaN по ширине и высоте\nДобавлена поддержка admin5","pt":"Adicionado suporte para variáveis locais do navegador\nCorreção de bug para valores nulos e NaN em largura e altura\nAdicionado suporte para admin5","nl":"Ondersteuning toegevoegd voor lokale browservariabelen\nBugfix voor null & NaN-waarden in breedte en hoogte\nOndersteuning toegevoegd voor admin5","fr":"Ajout de la prise en charge des variables de navigateur locales\nCorrection de bogue pour les valeurs null et NaN en largeur et en hauteur\nAjout du support pour admin5","it":"Aggiunto il supporto delle variabili del browser locale\nCorrezione di bug per valori null e NaN in larghezza e altezza\nAggiunto supporto per admin5","es":"Se agregó soporte para las variables del navegador local.\nCorrección de errores para valores nulos y NaN en ancho y alto\nSoporte agregado para admin5","pl":"Dodano obsługę zmiennych lokalnych przeglądarki\nNaprawiono błąd wartości null i NaN w szerokości i wysokości\nDodano wsparcie dla admin5","zh-cn":"增加了对本地浏览器变量的支持\n错误修复宽度和高度的null和NaN值\n添加了对admin5的支持"},"1.3.10":{"en":"Fixed the support of admin5","de":"Die Unterstützung von admin5 wurde behoben","ru":"Исправлена поддержка admin5","pt":"Corrigido o suporte de admin5","nl":"Ondersteuning van admin5 opgelost","fr":"Correction du support d'admin5","it":"Risolto il problema con il supporto di admin5","es":"Se corrigió el soporte de admin5.","pl":"Naprawiono wsparcie dla admin5","zh-cn":"修复了对admin5的支持"},"1.4.3":{"en":"Added possibility to check license offline (only special once)","de":"Möglichkeit zur Offline-Lizenzprüfung hinzugefügt (nur einmalig)","ru":"Добавлена возможность проверить лицензию в автономном режиме (только один раз)","pt":"Adicionada a possibilidade de verificar a licença offline (especial apenas uma vez)","nl":"Mogelijkheid toegevoegd om licentie offline te controleren (slechts één keer speciaal)","fr":"Ajout de la possibilité de vérifier la licence hors ligne (une seule fois spéciale)","it":"Aggiunta la possibilità di controllare la licenza offline (speciale solo una volta)","es":"Se agregó la posibilidad de verificar la licencia fuera de línea (solo especial una vez)","pl":"Dodano możliwość sprawdzenia licencji offline (tylko raz)","zh-cn":"添加了离线检查许可证的可能性(仅特殊一次)"},"1.4.2":{"en":"Added possibility to check license offline (only special once)","de":"Möglichkeit zur Offline-Lizenzprüfung hinzugefügt (nur einmalig)","ru":"Добавлена возможность проверить лицензию в автономном режиме (только один раз)","pt":"Adicionada a possibilidade de verificar a licença offline (especial apenas uma vez)","nl":"Mogelijkheid toegevoegd om licentie offline te controleren (slechts één keer speciaal)","fr":"Ajout de la possibilité de vérifier la licence hors ligne (une seule fois spéciale)","it":"Aggiunta la possibilità di controllare la licenza offline (speciale solo una volta)","es":"Se agregó la posibilidad de verificar la licencia fuera de línea (solo especial una vez)","pl":"Dodano możliwość sprawdzenia licencji offline (tylko raz)","zh-cn":"添加了离线检查许可证的可能性(仅特殊一次)"},"1.4.0":{"en":"Changed path for check of certificates \nfixes for issues found by adapter-checker","de":"Geänderter Pfad zur Prüfung von Zertifikaten\nFixes für Probleme, die vom Adapter-Checker gefunden wurden","ru":"Изменен путь проверки сертификатов\nисправления проблем, обнаруженных при проверке адаптера","pt":"Caminho alterado para verificação de certificados\ncorreções para problemas encontrados pelo verificador de adaptador","nl":"Pad gewijzigd voor controle van certificaten\noplossingen voor problemen gevonden door adapter-checker","fr":"Chemin modifié pour la vérification des certificats\ncorrectifs pour les problèmes trouvés par adapter-checker","it":"Percorso modificato per il controllo dei certificati\ncorrezioni per problemi rilevati da adapter-checker","es":"Ruta cambiada para la verificación de certificados\narreglos para problemas encontrados por el verificador de adaptadores","pl":"Zmieniona ścieżka do sprawdzenia certyfikatów\npoprawki problemów znalezionych przez adapter-checker","zh-cn":"更改了检查证书的路径\n修复适配器检查器发现的问题"},"1.4.4":{"en":"Allowed to have \":\" in the binding object IDs","de":"Darf \":\" in den Bindungsobjekt-IDs enthalten","ru":"Допускается наличие \":\" в идентификаторах объектов привязки.","pt":"É permitido ter \":\" nos IDs de objeto de ligação","nl":"Toegestaan om \":\" in de bindende object-ID's te hebben","fr":"Autorisé à avoir \":\" dans les ID d'objet de liaison","it":"Consentito di avere \":\" negli ID oggetto di associazione","es":"Se permite tener \":\" en los ID de objeto de vinculación","pl":"Dozwolone mieć \":\" w powiązanych identyfikatorach obiektów","zh-cn":"允许在绑定对象 ID 中包含“:”"},"1.4.5":{"en":"Added frame-src spec to content-security-policy header fixing frame related content blocking issues (e.g. using KioskPro iOS app).\nShowed the extended error messages by license check\nPatch visibility oid binding","de":"Frame-src-Spezifikation zum Content-Security-Policy-Header hinzugefügt, um Probleme beim Blockieren von Frame-bezogenen Inhalten zu beheben (z. B. bei Verwendung der KioskPro iOS-App).\nZeigte die erweiterten Fehlermeldungen bei der Lizenzprüfung an\nPatch-Sichtbarkeit ohne Bindung","ru":"Добавлена спецификация frame-src в заголовок content-security-policy, исправляющая проблемы блокировки содержимого, связанные с кадрами (например, с помощью приложения KioskPro для iOS).\nПоказал расширенные сообщения об ошибках при проверке лицензии\nОбвязка oid видимости исправлений","pt":"Adicionada especificação frame-src ao cabeçalho da política de segurança de conteúdo, corrigindo problemas de bloqueio de conteúdo relacionados a frame (por exemplo, usando o aplicativo KioskPro iOS).\nMostrou as mensagens de erro estendidas por verificação de licença\nVisibilidade do remendo oid vinculativo","nl":"Frame-src-specificatie toegevoegd aan content-security-policy header om frame-gerelateerde contentblokkeringsproblemen op te lossen (bijv. bij gebruik van de KioskPro iOS-app).\nToonde de uitgebreide foutmeldingen door licentiecontrole\nPatch zichtbaarheid oid binding","fr":"Ajout de la spécification frame-src à l'en-tête content-security-policy fixant les problèmes de blocage de contenu liés au cadre (par exemple, en utilisant l'application KioskPro iOS).\nAffichage des messages d'erreur étendus par vérification de licence\nLiaison oid de visibilité des correctifs","it":"Aggiunte le specifiche frame-src all'intestazione content-security-policy che risolve i problemi di blocco dei contenuti relativi ai frame (ad esempio utilizzando l'app KioskPro iOS).\nHa mostrato i messaggi di errore estesi dal controllo della licenza\nRilegatura oid visibilità patch","es":"Se agregó la especificación frame-src al encabezado content-security-policy que corrige problemas de bloqueo de contenido relacionados con el marco (por ejemplo, usando la aplicación KioskPro para iOS).\nMostró los mensajes de error extendidos por verificación de licencia\nParche visibilidad oid vinculante","pl":"Dodano specyfikację frame-src do nagłówka content-security-policy naprawiającego problemy z blokowaniem treści związane z ramkami (np. przy użyciu aplikacji KioskPro na iOS).\nPokazano rozszerzone komunikaty o błędach przy sprawdzaniu licencji\nWiązanie poprawki widoczności oid","zh-cn":"向 content-security-policy 标头添加了 frame-src 规范,修复了与框架相关的内容阻塞问题(例如,使用 KioskPro iOS 应用程序)。\n通过许可证检查显示扩展错误消息\n补丁可见性 oid 绑定"}},"desc":{"en":"Graphical user interface for iobroker","de":"Grafische Benutzeroberfläche für iobroker","ru":"Графический пользовательский интерфейс для iobroker","pt":"Interface gráfica do usuário para iobroker","nl":"Grafische gebruikersinterface voor iobroker","fr":"Interface utilisateur graphique pour iobroker","it":"Interfaccia utente grafica per iobroker","es":"Interfaz gráfica de usuario para iobroker","pl":"Graficzny interfejs użytkownika dla iobroker","zh-cn":"iobroker的图形化用户界面"},"platform":"Javascript/Node.js","loglevel":"info","icon":"vis.png","enabled":true,"mode":"once","extIcon":"https://raw.githubusercontent.com/iobroker/iobroker.vis/master/admin/vis.png","keywords":["DashUI","GUI","graphical","scada"],"readme":"https://github.com/iobroker/iobroker.vis/blob/master/README.md","authors":["bluefox <dogafox@gmail.com>"],"localLink":"%web_protocol%://%ip%:%web_port%/vis/edit.html","license":"CC-BY-NC-4.0","restartAdapters":["vis"],"serviceStates":"lib/states.js","singleton":true,"type":"visualization","highlight":true,"noConfig":false,"materialize":true,"welcomeScreen":{"link":"vis/index.html","name":"vis runtime","img":"vis/img/favicon.png","color":"#ffe9c8","order":0},"welcomeScreenPro":{"link":"vis/edit.html","name":"vis editor","img":"vis/img/faviconEdit.png","color":"#c8ffe1","order":1},"installedVersion":"1.4.15","host":"raspberrypi","dependencies":[{"web":">=3.0.12"},{"js-controller":">=2.0.0"}],"installedFrom":"iobroker.vis@1.4.15","localLinks":{"_default":"%web_protocol%://%ip%:%web_port%/vis/edit.html"},"adminUI":{"config":"materialize"},"connectionType":"local","dataSource":"push","tier":3,"compact":true},"native":{"defaultFileMode":1604,"license":"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJuYW1lIjoiaW9icm9rZXIudmlzIiwidHlwZSI6InByaXZhdGUiLCJsdHlwZSI6InN3IiwiZW1haWwiOiJtZ2xhbmVtYW5uQHQtb25saW5lLmRlIiwiaW52b2ljZSI6ImZyZWUiLCJjb21tZW50IjoiIiwiZXhwaXJlcyI6MjQ3MDc0OTU1NSwidmVyc2lvbiI6IjwyIiwiaWQiOiJiMGI4YzI1MC00MjUyLTExZTgtOGQ5Yi1mNTJiY2QzNGE3MjUiLCJpYXQiOjE1MjM5NzgzNTV9.ZY1aJFk5Ioue9OvvlTGCgHovK9xeBUjUq6hIc7CYf1K-j_eohwukDMrTqjmKrD-qhylPJ6ccdpm7qBM8gyQ6JbBsG8LiIeVz_ifYxAb5MSJF-OpDVqmTMab59f6niwnqnHh68aYTnvKg15RbzCHK5l7V1XAjel86yORm4KYyyt3bpOXzOp5ebcM5P-HdgTAnjG2tu48Ytka93mIS1zB79lqZ2Fbki4MyH349GHZ91y1whNoAYGJ8mQRB6QmOoJ--pZi3XEbg2NX7QDio6yOOi2ELG0DH6F6CF6uLJVRZZ_5uQWBc7Vb1eF2Vs7o3E8366XP0bewHzq_-ZdGz8JNoBA","useLicenseManager":0},"from":"system.adapter.admin.0","ts":1654070938550,"acl":{"object":1636,"ownerGroup":"system.group.administrator"},"user":"system.user.admin","protectedNative":[],"encryptedNative":[],"instanceObjects":[{"_id":"","type":"meta","common":{"name":"user files and images for vis","type":"meta.user"},"native":{}},{"_id":"control","type":"channel","common":{"name":"Control vis"},"native":{}},{"_id":"control.instance","type":"state","common":{"name":"Control vis","type":"string","desc":"Write here browser instance ID to control or 'FFFFFFFF' to control all instances"},"native":{}},{"_id":"control.command","type":"state","common":{"name":"Command for vis","type":"string","desc":"Writing this variable act as the trigger. Instance and data must be preset before 'command' will be written. 'changedView' will be signalled too","states":{"alert":"alert","changeView":"changeView","refresh":"refresh","reload":"reload","dialog":"dialog","popup":"popup","playSound":"playSound","changedView":"changedView","tts":"tts"}},"native":{}},{"_id":"control.data","type":"state","common":{"name":"Data for control vis","type":"string","desc":"Used for: alert, changeView, dialog, popup, playSound, changedView"},"native":{}}],"objects":[],"notifications":[]}
                      • B Beowolf
                        hier geht es weiter
                        Beowolf
                        und das noch
                        2022-06-01 10:08:58.876  - error: host.raspberrypi Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                        2022-06-01 10:08:58.634  - silly: mqtt.0 (1415) Objects system redis pmessage system.adapter.*/cfg.o.system.adapter.vis.0:{"_id":"system.adapter.vis.0","type":"instance","common":{"name":"vis","version":"1.4.15","title":"Visualisation","titleLang":{"en":"Visualisation","de":"Visualisierung","ru":"Визуализация","pt":"Visualização","nl":"Visualisatie","fr":"Visualisation","it":"Visualizzazione","es":"Visualización","pl":"Wizualizacja","zh-cn":"可视化"},"news":{"1.1.4":{"en":"Fixing the saving of project\nFixing the background selector\nFixing the null pointer problem\nFixing the selection helper\nUpdate translations","de":"Die Projektspeicherung ist korrigiert\nHintergrundselektors ist korrigiert\nReparieren des Null-Zeiger-Problems\nAuswahlhelfer korrigiert\nÜbersetzungen","ru":"исправлено сохранение проекта\nисправлен переключатель фона\nУстранение проблемы с нулевым указателем\nисправлен выбор виджетов\nпереводы","pt":"Reparando a poupança do projeto\nCorrigindo o seletor de fundo\nCorrigindo o problema do ponteiro nulo\nReparando o auxiliar de seleção\nAtualizar traduções","nl":"Het opslaan van het project bevestigen\nDe achtergrondkiezer bevestigen\nVaststelling van het probleem met de null-wijzer\nDe selectiehulp bevestigen\nUpdate vertalingen","fr":"Fixer la sauvegarde du projet\nFixer le sélecteur d'arrière-plan\nCorrection du problème du pointeur nul\nCorrection de l'assistant de sélection\nMise à jour","it":"Risolvendo il salvataggio del progetto\nRisolto il problema con il selettore dello sfondo\nRisolvere il problema con il puntatore nullo\nRiparare l'helper di selezione\nAggiorna traduzioni","es":"Corregir el guardado del proyecto\nReparar el selector de fondo\nCorregir el problema del puntero nulo\nReparar el asistente de selección\nActualizar traducciones","pl":"Naprawienie zapisu projektu\nNaprawianie wybieraka tła\nNaprawiono problem z pustym wskaźnikiem\nNaprawianie pomocnika wyboru\nZaktualizuj tłumaczenia"},"1.1.2":{"en":"Fixing the saving of project\nFixing the background selector\nFixing the null pointer problem\nFixing the selection helper\nUpdate translations","de":"Die Projektspeicherung ist korrigiert\nHintergrundselektors ist korrigiert\nReparieren des Null-Zeiger-Problems\nAuswahlhelfer korrigiert\nÜbersetzungen","ru":"исправлено сохранение проекта\nисправлен переключатель фона\nУстранение проблемы с нулевым указателем\nисправлен выбор виджетов\nпереводы","pt":"Reparando a poupança do projeto\nCorrigindo o seletor de fundo\nCorrigindo o problema do ponteiro nulo\nReparando o auxiliar de seleção\nAtualizar traduções","nl":"Het opslaan van het project bevestigen\nDe achtergrondkiezer bevestigen\nVaststelling van het probleem met de null-wijzer\nDe selectiehulp bevestigen\nUpdate vertalingen","fr":"Fixer la sauvegarde du projet\nFixer le sélecteur d'arrière-plan\nCorrection du problème du pointeur nul\nCorrection de l'assistant de sélection\nMise à jour","it":"Risolvendo il salvataggio del progetto\nRisolto il problema con il selettore dello sfondo\nRisolvere il problema con il puntatore nullo\nRiparare l'helper di selezione\nAggiorna traduzioni","es":"Corregir el guardado del proyecto\nReparar el selector de fondo\nCorregir el problema del puntero nulo\nReparar el asistente de selección\nActualizar traducciones","pl":"Naprawienie zapisu projektu\nNaprawianie wybieraka tła\nNaprawiono problem z pustym wskaźnikiem\nNaprawianie pomocnika wyboru\nZaktualizuj tłumaczenia"},"1.1.1":{"en":"The problem with view change on the touch devices fixed","de":"Das Problem mit der Ansicht Änderung auf den Touch-Geräten behoben","ru":"Проблема с изменением вида на сенсорных устройствах исправлена","pt":"O problema com a mudança de exibição nos dispositivos de toque fixos","nl":"Het probleem met de wijziging van weergave op de aanraakapparaten is opgelost","fr":"Le problème avec le changement de vue sur les appareils tactiles fixés","it":"Risolto il problema con il cambio di vista sui dispositivi touch","es":"El problema con el cambio de vista en los dispositivos táctiles solucionó","pl":"Naprawiono problem z zmianą widoku na urządzeniach dotykowych"},"1.0.5":{"en":"show number of datapoints in every project","de":"Zeige die Anzahl von Datenpunkten in jedem Projekt","ru":"Показывет количество используемых данных в каждом проекте"},"1.0.4":{"en":"Add autocomplete for view CSS options\nchange edit of view CSS background options","de":"Automatische Vervollständigung für View-CSS-Optionen hinzufügen\nÄndern der CSS-Hintergrundoptionen für View","ru":"Добавлено автозаполнение для CSS опций страницы\nИзменение редактирования background CSS страницы"},"1.0.3":{"en":"Release candidate\nFix parse of invalid bindings\nadd moment.js","de":"Release candidate\nKorrigiere die Aufbau von falschen Bindings\nmoment.js hinzugefügt","ru":"Release candidate\nПоправлен рендеринг неправильных bindings\nДобавлен moment.js"},"0.15.6":{"en":"Added array operator to bindings","de":"Array Operator zu bindings hinzugefügt"},"0.15.5":{"en":"Fix widgets upload","de":"Korrigiere Widgets uplaod","ru":"Исправлено обновление виджетов"},"0.15.4":{"en":"Add swipe","de":"Swipe hunzugefügt","ru":"Добавлен swipe"},"0.15.3":{"en":"Add full screen widget\nFix timestamp widget","de":"Full Screen Widget hunzugefügt\nKorrigiere timestamp widget","ru":"Добавлен виджет full screen\nИсправлен виджет timestamp"},"0.15.2":{"en":"Fix binding if it has \"-\" in the OID","de":"Korrigiere den fehler mit Binding und \"-\" in OID","ru":"Исправлены bindings, если содержат минус в имени"},"0.15.1":{"en":"Fix error with context menu\nAllow add class to view","de":"Korrigiere den fehler mit dem Kontext-Menu\nErlaube Klasse zur Seite hinzufügen","ru":"Исправлено контекстное меню\nМожно добавлять классы к страницам"},"1.1.7":{"en":"view8 corrected","de":"view8 korrigiert","ru":"view8 исправлено","pt":"view8 corrigido","nl":"view8 gecorrigeerd","fr":"view8 corrigé","it":"view8 corretta","es":"view8 corregido","pl":"view8 poprawiony"},"1.1.6":{"en":"New special bindings are supported\nError with fast view changes is fixed\nfix (jqui - ctrl - IconState / val - Icon Bool)","de":"Neue spezielle Bindungen werden unterstützt\nFehler bei schnellen Ansichtsänderungen ist behoben\nfix (jqui - Strg - IconState / val - Icon Bool)","ru":"Поддерживаются новые специальные привязки\nИсправлена ​​ошибка с быстрым изменением вида\nfix (jqui - ctrl - IconState / val - Icon Bool)","pt":"Novas ligações especiais são suportadas\nErro com alterações de visualização rápida corrigidas\ncorrigir (jqui - ctrl - IconState / val - Bool de ícone)","nl":"Nieuwe speciale bindingen worden ondersteund\nFout bij snelle wijzigingen in weergave is opgelost\nfix (jqui - ctrl - IconState / val - Icon Bool)","fr":"Les nouvelles liaisons spéciales sont prises en charge\nErreur avec les changements d'affichage rapide est fixée\ncorriger (jqui - ctrl - IconState / val - Icône Bool)","it":"Sono supportati nuovi binding speciali\nL'errore con le modifiche veloci alla vista è stato risolto\ncorreggere (jqui - ctrl - IconState / val - Icon Bool)","es":"Se admiten nuevos enlaces especiales\nSe corrigió el error con los cambios de vista rápida\ncorregir (jqui - ctrl - IconState / val - Icon Bool)","pl":"Nowe powiązania specjalne są obsługiwane\nNaprawiono błąd związany z szybkimi zmianami widoku\nnapraw (jqui - ctrl - IconState / val - Icon Bool)"},"1.1.10":{"en":"Add Chinese support","de":"Chinesische Unterstützung hinzufügen","ru":"Добавить поддержку китайцев","pt":"Adicionar suporte chinês","nl":"Voeg Chinese ondersteuning toe","fr":"Ajouter un support chinois","it":"Aggiungi supporto cinese","es":"Añadir soporte chino","pl":"Dodaj chińskie wsparcie","zh-cn":"添加中文支持"},"1.1.8":{"en":"File dialog was corrected","de":"Dateidialog wurde korrigiert","ru":"Исправлено диалоговое окно файла","pt":"A caixa de diálogo do arquivo foi corrigida","nl":"Bestandsdialoog is gecorrigeerd","fr":"Le dialogue de fichier a été corrigé","it":"La finestra di dialogo del file è stata corretta","es":"Se corrigió el diálogo del archivo","pl":"Okno dialogowe pliku zostało poprawione"},"1.2.2":{"en":"Preparations for js-controller 2.0","de":"Vorbereitungen für js-controller 2.0","ru":"Подготовка к js-controller 2.0","pt":"Preparativos para js-controller 2.0","nl":"Voorbereidingen voor js-controller 2.0","fr":"Préparations pour js-controller 2.0","it":"Preparativi per js-controller 2.0","es":"Preparativos para js-controller 2.0","pl":"Przygotowania do js-kontrolera 2.0","zh-cn":"js-controller 2.0的准备"},"1.2.1":{"en":"fixed upload of files","de":"Fehler beim Hochladen von Dateien behoben","ru":"исправлена загрузка файлов","pt":"upload fixo de arquivos","nl":"vaste upload van bestanden","fr":"téléchargement fixe de fichiers","it":"caricamento fisso di file","es":"carga fija de archivos","pl":"naprawione przesyłanie plików","zh-cn":"修复了文件上传"},"1.2.0":{"en":"Translations were added","de":"Übersetzungen wurden hinzugefügt","ru":"Добавлены переводы","pt":"Traduções foram adicionadas","nl":"Vertalingen zijn toegevoegd","fr":"Les traductions ont été ajoutées","it":"Sono state aggiunte traduzioni","es":"Se agregaron traducciones","pl":"Dodano tłumaczenia","zh-cn":"翻译增加了"},"1.1.11":{"en":"Bool HTML was Improved ","de":"Bool HTML wurde verbessert","ru":"Bool HTML был улучшен","pt":"Bool HTML foi melhorado","nl":"Bool HTML is verbeterd","fr":"Bool HTML a été amélioré","it":"Bool HTML è stato migliorato","es":"Bool HTML fue mejorado","pl":"Bool HTML został ulepszony","zh-cn":"“Bool HTML”得到了改进"},"1.2.3":{"en":"Small changes in license handling were made","de":"Kleine Änderungen in der Lizenzverwaltung wurden vorgenommen","ru":"Небольшие изменения в обработке лицензий","pt":"Pequenas mudanças no manuseio de licenças foram feitas","nl":"Er zijn kleine wijzigingen aangebracht in de licentiebehandeling","fr":"De petits changements dans la gestion des licences ont été effectués","it":"Sono state apportate piccole modifiche alla gestione delle licenze","es":"Se hicieron pequeños cambios en el manejo de la licencia.","pl":"Wprowadzono niewielkie zmiany w obsłudze licencji","zh-cn":"许可证处理方面进行了一些小的更改"},"1.2.4":{"en":"Table widget was extended with the selected object ID.","de":"Das Tabellenwidget wurde um die ausgewählte Objekt-ID erweitert.","ru":"Табличный виджет был расширен с выбранным идентификатором объекта.","pt":"O widget de tabela foi estendido com o ID do objeto selecionado.","nl":"Tabelwidget is uitgebreid met de geselecteerde object-ID.","fr":"Le widget de table a été étendu avec l'ID d'objet sélectionné.","it":"Il widget della tabella è stato esteso con l'ID oggetto selezionato.","es":"El widget de tabla se amplió con el ID de objeto seleccionado.","pl":"Widżet tabeli został rozszerzony o wybrany identyfikator obiektu.","zh-cn":"表窗口小部件已扩展为具有选定的对象ID。"},"1.2.11":{"en":"The error message about the non-found chart view was fixed.","de":"Die Fehlermeldung zur nicht gefundenen Diagrammansicht wurde behoben.","ru":"Исправлено сообщение об ошибке о ненайденном просмотре диаграммы.","pt":"A mensagem de erro sobre a exibição do gráfico não encontrado foi corrigida.","nl":"Het foutbericht over de niet-gevonden kaartweergave is opgelost.","fr":"Le message d'erreur concernant la vue graphique non trouvée a été corrigé.","it":"Il messaggio di errore relativo alla visualizzazione del grafico non trovata è stato corretto.","es":"Se solucionó el mensaje de error sobre la vista de gráfico no encontrado.","pl":"Komunikat o błędzie dotyczący nieodnalezionego widoku wykresu został naprawiony.","zh-cn":"有关未找到的图表视图的错误消息已修复。"},"1.2.10":{"en":"JSON strings will be parsed in VIS bindings","de":"JSON-Zeichenfolgen werden in VIS-Bindungen analysiert","ru":"Строки JSON будут анализироваться в привязках VIS","pt":"Strings JSON serão analisadas em associações VIS","nl":"JSON-strings worden geparseerd in VIS-bindingen","fr":"Les chaînes JSON seront analysées dans les liaisons VIS","it":"Le stringhe JSON verranno analizzate nelle associazioni VIS","es":"Las cadenas JSON se analizarán en enlaces VIS","pl":"Ciągi JSON będą analizowane w powiązaniach VIS","zh-cn":"JSON字符串将在VIS绑定中解析"},"1.2.9":{"en":"Charts are now supported","de":"Diagramme werden jetzt unterstützt","ru":"Графики теперь поддерживаются","pt":"Gráficos agora são suportados","nl":"Grafieken worden nu ondersteund","fr":"Les graphiques sont désormais pris en charge","it":"I grafici sono ora supportati","es":"Los gráficos ahora son compatibles","pl":"Wykresy są teraz obsługiwane","zh-cn":"现在支持图表"},"1.2.6":{"en":"Added the better error message if license could not be parsed","de":"Die bessere Fehlermeldung wurde hinzugefügt, wenn die Lizenz nicht analysiert werden konnte","ru":"Добавлено лучшее сообщение об ошибке, если лицензия не может быть проанализирована","pt":"Adicionada a melhor mensagem de erro se a licença não puder ser analisada","nl":"Het betere foutbericht toegevoegd als de licentie niet kon worden geparseerd","fr":"Ajout du meilleur message d'erreur si la licence n'a pas pu être analysée","it":"Aggiunto il messaggio di errore migliore se non è stato possibile analizzare la licenza","es":"Se agregó el mejor mensaje de error si no se pudo analizar la licencia","pl":"Dodano lepszy komunikat o błędzie, jeśli nie można przeanalizować licencji","zh-cn":"如果无法解析许可证,则添加了更好的错误消息"},"1.2.12":{"en":"only parse arrays and json objects, not booleans, normal strings etc","de":"Analysieren Sie nur Arrays und JSON-Objekte, keine Booleschen Werte, normale Zeichenfolgen usw.","ru":"анализировать только массивы и объекты json, а не логические значения, обычные строки и т. д.","pt":"analisa apenas matrizes e objetos json, não booleanos, strings normais, etc.","nl":"alleen arrays en json-objecten ontleden, geen booleans, normale strings enz","fr":"analyser uniquement les tableaux et les objets json, pas les booléens, les chaînes normales, etc.","it":"analizza solo array e oggetti json, non booleani, stringhe normali ecc","es":"solo analizar matrices y objetos json, no booleanos, cadenas normales, etc.","pl":"analizuje tylko tablice i obiekty json, a nie wartości logiczne, zwykłe ciągi znaków itp","zh-cn":"仅解析数组和json对象,不解析布尔值,普通字符串等"},"1.3.4":{"en":"Corrected the error on older devices","de":"Der Fehler auf älteren Geräten wurde behoben","ru":"Исправлена ошибка на старых устройствах","pt":"Corrigido o erro em dispositivos mais antigos","nl":"De fout op oudere apparaten gecorrigeerd","fr":"Correction de l'erreur sur les appareils plus anciens","it":"Corretto l'errore sui dispositivi meno recenti","es":"Corregido el error en dispositivos más antiguos.","pl":"Poprawiono błąd na starszych urządzeniach","zh-cn":"更正了旧设备上的错误"},"1.3.3":{"en":"Return de-bounce settings back\nCorrected error with {username} binding","de":"Geben Sie die De-Bounce-Einstellungen zurück\nFehler mit Bindung {Benutzername} behoben","ru":"Вернуть настройки де-дребезга назад\nИсправлена ошибка с привязкой {username}","pt":"Retorne as configurações de de-bounce de volta\nErro corrigido com ligação de {nome de usuário}","nl":"Zet de instellingen voor terugveren terug\nFout gecorrigeerd met binding van {gebruikersnaam}","fr":"Rétablir les paramètres d'anti-rebond\nErreur corrigée avec la liaison {username}","it":"Ripristina le impostazioni di antirimbalzo\nErrore corretto con l'associazione {nomeutente}","es":"Devolver la configuración de rebote\nError corregido con la vinculación de {username}","pl":"Przywróć ustawienia odbijania\nPoprawiony błąd z wiązaniem {nazwa użytkownika}","zh-cn":"返回反跳设置\n已更正{username}绑定的错误"},"1.3.1":{"en":"Added the auto-focus option to the input widgets","de":"Die Autofokus-Option wurde zu den Eingabe-Widgets hinzugefügt","ru":"Добавлена опция автофокуса для виджетов ввода","pt":"Adicionada a opção de foco automático aos widgets de entrada","nl":"De auto-focus-optie toegevoegd aan de invoerwidgets","fr":"Ajout de l'option de mise au point automatique aux widgets d'entrée","it":"Aggiunta l'opzione di messa a fuoco automatica ai widget di input","es":"Se agregó la opción de enfoque automático a los widgets de entrada.","pl":"Dodano opcję automatycznego ustawiania ostrości do widżetów wejściowych","zh-cn":"在输入小部件中添加了自动对焦选项"},"1.3.0":{"en":"On pending getStates, try again instead of drop\nFixed the file manager typos\nAdded momentDate for the bindings","de":"Versuchen Sie es bei ausstehenden getStates erneut, anstatt es zu löschen\nDie Tippfehler im Dateimanager wurden behoben\nMomentDate für die Bindungen hinzugefügt","ru":"В ожидании getStates попробуйте снова вместо того, чтобы отбрасывать\nИсправлены опечатки в файловом менеджере\nДобавлен моментDate для привязок","pt":"Em getStates pendentes, tente novamente em vez de descartar\nCorrigidos erros de digitação do gerenciador de arquivos\nAdicionado momentDate para as ligações","nl":"Probeer het op getStates in afwachting opnieuw in plaats van te laten vallen\nTypefouten in bestandsbeheer opgelost\nMomentDate toegevoegd voor de bindingen","fr":"Sur getStates en attente, réessayez au lieu de supprimer\nCorrection des fautes de frappe du gestionnaire de fichiers\nMomentDate ajouté pour les fixations","it":"In attesa di getStates, riprova invece di rilasciare\nRisolti gli errori di battitura del file manager\nMomentDate aggiunto per le associazioni","es":"En getStates pendientes, inténtelo de nuevo en lugar de soltar\nSe corrigieron los errores tipográficos del administrador de archivos\nMomento añadido Fecha para las fijaciones","pl":"W oczekiwaniu na getStates spróbuj ponownie zamiast upuszczać\nNaprawiono literówki w menedżerze plików\nDodano momentDate dla wiązań","zh-cn":"在待处理的getStates上,重试而不是drop\n修复了文件管理器输入错误\n为绑定添加了momentDate"},"1.3.8":{"en":"fix play sounds on iOS Safari an android\nvisEditInspect: format dimension added\nReplace travis and appveyor by the github actions\nAllow resources to be loaded as blob\n(Excodibur ) Allow resources to be loaded as blob","de":"Fix Play Sounds auf iOS Safari und Android\nvisEditInspect: Formatdimension hinzugefügt\nErsetzen Sie Travis und Appveyor durch die Github-Aktionen\nZulassen, dass Ressourcen als Blob geladen werden\n(Excodibur) Ermöglicht das Laden von Ressourcen als Blob","ru":"исправить звуки воспроизведения на iOS Safari и Android\nvisEditInspect: добавлено измерение формата\nЗамените travis и appveyor действиями github\nРазрешить загрузку ресурсов как blob\n(Excodibur) Разрешить загрузку ресурсов как blob","pt":"corrigir sons de reprodução no iOS Safari e Android\nvisEditInspect: dimensão do formato adicionada\nSubstitua travis e appveyor pelas ações do github\nPermitir que recursos sejam carregados como blob\n(Excodibur) Permite que os recursos sejam carregados como blob","nl":"repareer afspeelgeluiden op iOS Safari en Android\nvisEditInspect: formaatdimensie toegevoegd\nVervang travis en appveyor door de github-acties\nToestaan dat resources als blob worden geladen\n(Excodibur) Toestaan dat bronnen als blob worden geladen","fr":"réparer les sons de lecture sur iOS Safari et Android\nvisEditInspect: dimension de format ajoutée\nRemplacez travis et appveyor par les actions github\nAutoriser le chargement des ressources en tant qu'objet blob\n(Excodibur) Autoriser le chargement des ressources en tant que blob","it":"correggere i suoni di riproduzione su iOS Safari e Android\nvisEditInspect: dimensione del formato aggiunta\nSostituisci travis e appveyor con le azioni github\nConsenti il caricamento delle risorse come BLOB\n(Excodibur) Consenti il caricamento delle risorse come BLOB","es":"arreglar sonidos de reproducción en iOS Safari y Android\nvisEditInspect: dimensión de formato agregada\nReemplaza travis y appveyor por las acciones de github\nPermitir que los recursos se carguen como blob\n(Excodibur) Permitir que los recursos se carguen como blob","pl":"naprawianie odtwarzania dźwięków w iOS Safari i Androidzie\nvisEditInspect: dodano wymiar formatu\nZastąp travis i appveyor akcjami github\nZezwalaj na ładowanie zasobów jako obiektu blob\n(Excodibur) Zezwalaj na ładowanie zasobów jako obiektu blob","zh-cn":"修复iOS Safari和Android上的播放声音\nvisEditInspect:添加了格式尺寸\n用github操作替换travis和appveyor\n允许将资源加载为Blob\n(Excodibur)允许将资源加载为Blob"},"1.3.7":{"en":"Bug Fixed - Binding in JSON string","de":"Fehler behoben - Bindung in JSON-Zeichenfolge","ru":"Исправлена ошибка - привязка в строке JSON","pt":"Bug corrigido - vinculação em string JSON","nl":"Bug opgelost - Binding in JSON-string","fr":"Bug corrigé - Liaison dans la chaîne JSON","it":"Bug risolto: binding nella stringa JSON","es":"Error solucionado: enlace en cadena JSON","pl":"Naprawiono błąd - wiązanie w ciągu JSON","zh-cn":"错误修复-JSON字符串绑定"},"1.3.6":{"en":"Corrected: old browser issue\nCorrected: play sounds on iOS Safari\nAdded the optional arguments to support Material Design Widgets\n","de":"Behoben: altes Browserproblem\nKorrigiert: Spielen Sie Sounds auf iOS Safari ab\nDie optionalen Argumente zur Unterstützung von Material Design Widgets wurden hinzugefügt\n","ru":"Исправлено: старая проблема с браузером.\nИсправлено: воспроизведение звуков в iOS Safari.\nДобавлены необязательные аргументы для поддержки виджетов Material Design.\n","pt":"Corrigido: problema do navegador antigo\nCorrigido: reproduzir sons no iOS Safari\nAdicionados os argumentos opcionais para oferecer suporte a Widgets de Material Design\n","nl":"Opgelost: oud browserprobleem\nGecorrigeerd: speel geluiden af op iOS Safari\nDe optionele argumenten toegevoegd om Material Design Widgets te ondersteunen\n","fr":"Corrigé: ancien problème de navigateur\nCorrigé: jouer des sons sur iOS Safari\nAjout des arguments facultatifs pour prendre en charge les widgets de conception de matériaux\n","it":"Corretto: vecchio problema del browser\nCorretto: riproduci suoni su iOS Safari\nAggiunti gli argomenti opzionali per supportare i widget di Material Design\n","es":"Corregido: problema del navegador antiguo\nCorregido: reproducir sonidos en iOS Safari\nSe agregaron los argumentos opcionales para admitir widgets de diseño de materiales.\n","pl":"Poprawione: stary problem z przeglądarką\nPoprawiono: odtwarzaj dźwięki w iOS Safari\nDodano opcjonalne argumenty do obsługi widżetów Material Design\n","zh-cn":"更正的:旧的浏览器问题\n纠正:在iOS Safari上播放声音\n添加了可选参数以支持Material Design Widgets\n"},"1.3.9":{"en":"Added support of local browser variables\nBug fix for null & NaN values in width and height\nAdded support for admin5","de":"Unterstützung für lokale Browservariablen hinzugefügt\nFehlerbehebung für Null- und NaN-Werte in Breite und Höhe\nUnterstützung für admin5 hinzugefügt","ru":"Добавлена поддержка локальных переменных браузера.\nИсправлена ошибка для значений NULL и NaN по ширине и высоте\nДобавлена поддержка admin5","pt":"Adicionado suporte para variáveis locais do navegador\nCorreção de bug para valores nulos e NaN em largura e altura\nAdicionado suporte para admin5","nl":"Ondersteuning toegevoegd voor lokale browservariabelen\nBugfix voor null & NaN-waarden in breedte en hoogte\nOndersteuning toegevoegd voor admin5","fr":"Ajout de la prise en charge des variables de navigateur locales\nCorrection de bogue pour les valeurs null et NaN en largeur et en hauteur\nAjout du support pour admin5","it":"Aggiunto il supporto delle variabili del browser locale\nCorrezione di bug per valori null e NaN in larghezza e altezza\nAggiunto supporto per admin5","es":"Se agregó soporte para las variables del navegador local.\nCorrección de errores para valores nulos y NaN en ancho y alto\nSoporte agregado para admin5","pl":"Dodano obsługę zmiennych lokalnych przeglądarki\nNaprawiono błąd wartości null i NaN w szerokości i wysokości\nDodano wsparcie dla admin5","zh-cn":"增加了对本地浏览器变量的支持\n错误修复宽度和高度的null和NaN值\n添加了对admin5的支持"},"1.3.10":{"en":"Fixed the support of admin5","de":"Die Unterstützung von admin5 wurde behoben","ru":"Исправлена поддержка admin5","pt":"Corrigido o suporte de admin5","nl":"Ondersteuning van admin5 opgelost","fr":"Correction du support d'admin5","it":"Risolto il problema con il supporto di admin5","es":"Se corrigió el soporte de admin5.","pl":"Naprawiono wsparcie dla admin5","zh-cn":"修复了对admin5的支持"},"1.4.3":{"en":"Added possibility to check license offline (only special once)","de":"Möglichkeit zur Offline-Lizenzprüfung hinzugefügt (nur einmalig)","ru":"Добавлена возможность проверить лицензию в автономном режиме (только один раз)","pt":"Adicionada a possibilidade de verificar a licença offline (especial apenas uma vez)","nl":"Mogelijkheid toegevoegd om licentie offline te controleren (slechts één keer speciaal)","fr":"Ajout de la possibilité de vérifier la licence hors ligne (une seule fois spéciale)","it":"Aggiunta la possibilità di controllare la licenza offline (speciale solo una volta)","es":"Se agregó la posibilidad de verificar la licencia fuera de línea (solo especial una vez)","pl":"Dodano możliwość sprawdzenia licencji offline (tylko raz)","zh-cn":"添加了离线检查许可证的可能性(仅特殊一次)"},"1.4.2":{"en":"Added possibility to check license offline (only special once)","de":"Möglichkeit zur Offline-Lizenzprüfung hinzugefügt (nur einmalig)","ru":"Добавлена возможность проверить лицензию в автономном режиме (только один раз)","pt":"Adicionada a possibilidade de verificar a licença offline (especial apenas uma vez)","nl":"Mogelijkheid toegevoegd om licentie offline te controleren (slechts één keer speciaal)","fr":"Ajout de la possibilité de vérifier la licence hors ligne (une seule fois spéciale)","it":"Aggiunta la possibilità di controllare la licenza offline (speciale solo una volta)","es":"Se agregó la posibilidad de verificar la licencia fuera de línea (solo especial una vez)","pl":"Dodano możliwość sprawdzenia licencji offline (tylko raz)","zh-cn":"添加了离线检查许可证的可能性(仅特殊一次)"},"1.4.0":{"en":"Changed path for check of certificates \nfixes for issues found by adapter-checker","de":"Geänderter Pfad zur Prüfung von Zertifikaten\nFixes für Probleme, die vom Adapter-Checker gefunden wurden","ru":"Изменен путь проверки сертификатов\nисправления проблем, обнаруженных при проверке адаптера","pt":"Caminho alterado para verificação de certificados\ncorreções para problemas encontrados pelo verificador de adaptador","nl":"Pad gewijzigd voor controle van certificaten\noplossingen voor problemen gevonden door adapter-checker","fr":"Chemin modifié pour la vérification des certificats\ncorrectifs pour les problèmes trouvés par adapter-checker","it":"Percorso modificato per il controllo dei certificati\ncorrezioni per problemi rilevati da adapter-checker","es":"Ruta cambiada para la verificación de certificados\narreglos para problemas encontrados por el verificador de adaptadores","pl":"Zmieniona ścieżka do sprawdzenia certyfikatów\npoprawki problemów znalezionych przez adapter-checker","zh-cn":"更改了检查证书的路径\n修复适配器检查器发现的问题"},"1.4.4":{"en":"Allowed to have \":\" in the binding object IDs","de":"Darf \":\" in den Bindungsobjekt-IDs enthalten","ru":"Допускается наличие \":\" в идентификаторах объектов привязки.","pt":"É permitido ter \":\" nos IDs de objeto de ligação","nl":"Toegestaan om \":\" in de bindende object-ID's te hebben","fr":"Autorisé à avoir \":\" dans les ID d'objet de liaison","it":"Consentito di avere \":\" negli ID oggetto di associazione","es":"Se permite tener \":\" en los ID de objeto de vinculación","pl":"Dozwolone mieć \":\" w powiązanych identyfikatorach obiektów","zh-cn":"允许在绑定对象 ID 中包含“:”"},"1.4.5":{"en":"Added frame-src spec to content-security-policy header fixing frame related content blocking issues (e.g. using KioskPro iOS app).\nShowed the extended error messages by license check\nPatch visibility oid binding","de":"Frame-src-Spezifikation zum Content-Security-Policy-Header hinzugefügt, um Probleme beim Blockieren von Frame-bezogenen Inhalten zu beheben (z. B. bei Verwendung der KioskPro iOS-App).\nZeigte die erweiterten Fehlermeldungen bei der Lizenzprüfung an\nPatch-Sichtbarkeit ohne Bindung","ru":"Добавлена спецификация frame-src в заголовок content-security-policy, исправляющая проблемы блокировки содержимого, связанные с кадрами (например, с помощью приложения KioskPro для iOS).\nПоказал расширенные сообщения об ошибках при проверке лицензии\nОбвязка oid видимости исправлений","pt":"Adicionada especificação frame-src ao cabeçalho da política de segurança de conteúdo, corrigindo problemas de bloqueio de conteúdo relacionados a frame (por exemplo, usando o aplicativo KioskPro iOS).\nMostrou as mensagens de erro estendidas por verificação de licença\nVisibilidade do remendo oid vinculativo","nl":"Frame-src-specificatie toegevoegd aan content-security-policy header om frame-gerelateerde contentblokkeringsproblemen op te lossen (bijv. bij gebruik van de KioskPro iOS-app).\nToonde de uitgebreide foutmeldingen door licentiecontrole\nPatch zichtbaarheid oid binding","fr":"Ajout de la spécification frame-src à l'en-tête content-security-policy fixant les problèmes de blocage de contenu liés au cadre (par exemple, en utilisant l'application KioskPro iOS).\nAffichage des messages d'erreur étendus par vérification de licence\nLiaison oid de visibilité des correctifs","it":"Aggiunte le specifiche frame-src all'intestazione content-security-policy che risolve i problemi di blocco dei contenuti relativi ai frame (ad esempio utilizzando l'app KioskPro iOS).\nHa mostrato i messaggi di errore estesi dal controllo della licenza\nRilegatura oid visibilità patch","es":"Se agregó la especificación frame-src al encabezado content-security-policy que corrige problemas de bloqueo de contenido relacionados con el marco (por ejemplo, usando la aplicación KioskPro para iOS).\nMostró los mensajes de error extendidos por verificación de licencia\nParche visibilidad oid vinculante","pl":"Dodano specyfikację frame-src do nagłówka content-security-policy naprawiającego problemy z blokowaniem treści związane z ramkami (np. przy użyciu aplikacji KioskPro na iOS).\nPokazano rozszerzone komunikaty o błędach przy sprawdzaniu licencji\nWiązanie poprawki widoczności oid","zh-cn":"向 content-security-policy 标头添加了 frame-src 规范,修复了与框架相关的内容阻塞问题(例如,使用 KioskPro iOS 应用程序)。\n通过许可证检查显示扩展错误消息\n补丁可见性 oid 绑定"}},"desc":{"en":"Graphical user interface for iobroker","de":"Grafische Benutzeroberfläche für iobroker","ru":"Графический пользовательский интерфейс для iobroker","pt":"Interface gráfica do usuário para iobroker","nl":"Grafische gebruikersinterface voor iobroker","fr":"Interface utilisateur graphique pour iobroker","it":"Interfaccia utente grafica per iobroker","es":"Interfaz gráfica de usuario para iobroker","pl":"Graficzny interfejs użytkownika dla iobroker","zh-cn":"iobroker的图形化用户界面"},"platform":"Javascript/Node.js","loglevel":"info","icon":"vis.png","enabled":true,"mode":"once","extIcon":"https://raw.githubusercontent.com/iobroker/iobroker.vis/master/admin/vis.png","keywords":["DashUI","GUI","graphical","scada"],"readme":"https://github.com/iobroker/iobroker.vis/blob/master/README.md","authors":["bluefox <dogafox@gmail.com>"],"localLink":"%web_protocol%://%ip%:%web_port%/vis/edit.html","license":"CC-BY-NC-4.0","restartAdapters":["vis"],"serviceStates":"lib/states.js","singleton":true,"type":"visualization","highlight":true,"noConfig":false,"materialize":true,"welcomeScreen":{"link":"vis/index.html","name":"vis runtime","img":"vis/img/favicon.png","color":"#ffe9c8","order":0},"welcomeScreenPro":{"link":"vis/edit.html","name":"vis editor","img":"vis/img/faviconEdit.png","color":"#c8ffe1","order":1},"installedVersion":"1.4.15","host":"raspberrypi","dependencies":[{"web":">=3.0.12"},{"js-controller":">=2.0.0"}],"installedFrom":"iobroker.vis@1.4.15","localLinks":{"_default":"%web_protocol%://%ip%:%web_port%/vis/edit.html"},"adminUI":{"config":"materialize"},"connectionType":"local","dataSource":"push","tier":3,"compact":true},"native":{"defaultFileMode":1604,"license":"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJuYW1lIjoiaW9icm9rZXIudmlzIiwidHlwZSI6InByaXZhdGUiLCJsdHlwZSI6InN3IiwiZW1haWwiOiJtZ2xhbmVtYW5uQHQtb25saW5lLmRlIiwiaW52b2ljZSI6ImZyZWUiLCJjb21tZW50IjoiIiwiZXhwaXJlcyI6MjQ3MDc0OTU1NSwidmVyc2lvbiI6IjwyIiwiaWQiOiJiMGI4YzI1MC00MjUyLTExZTgtOGQ5Yi1mNTJiY2QzNGE3MjUiLCJpYXQiOjE1MjM5NzgzNTV9.ZY1aJFk5Ioue9OvvlTGCgHovK9xeBUjUq6hIc7CYf1K-j_eohwukDMrTqjmKrD-qhylPJ6ccdpm7qBM8gyQ6JbBsG8LiIeVz_ifYxAb5MSJF-OpDVqmTMab59f6niwnqnHh68aYTnvKg15RbzCHK5l7V1XAjel86yORm4KYyyt3bpOXzOp5ebcM5P-HdgTAnjG2tu48Ytka93mIS1zB79lqZ2Fbki4MyH349GHZ91y1whNoAYGJ8mQRB6QmOoJ--pZi3XEbg2NX7QDio6yOOi2ELG0DH6F6CF6uLJVRZZ_5uQWBc7Vb1eF2Vs7o3E8366XP0bewHzq_-ZdGz8JNoBA","useLicenseManager":0},"from":"system.adapter.admin.0","ts":1654070938550,"acl":{"object":1636,"ownerGroup":"system.group.administrator"},"user":"system.user.admin","protectedNative":[],"encryptedNative":[],"instanceObjects":[{"_id":"","type":"meta","common":{"name":"user files and images for vis","type":"meta.user"},"native":{}},{"_id":"control","type":"channel","common":{"name":"Control vis"},"native":{}},{"_id":"control.instance","type":"state","common":{"name":"Control vis","type":"string","desc":"Write here browser instance ID to control or 'FFFFFFFF' to control all instances"},"native":{}},{"_id":"control.command","type":"state","common":{"name":"Command for vis","type":"string","desc":"Writing this variable act as the trigger. Instance and data must be preset before 'command' will be written. 'changedView' will be signalled too","states":{"alert":"alert","changeView":"changeView","refresh":"refresh","reload":"reload","dialog":"dialog","popup":"popup","playSound":"playSound","changedView":"changedView","tts":"tts"}},"native":{}},{"_id":"control.data","type":"state","common":{"name":"Data for control vis","type":"string","desc":"Used for: alert, changeView, dialog, popup, playSound, changedView"},"native":{}}],"objects":[],"notifications":[]}
                        2022-06-01 10:09:00.158  - debug: mqtt.0 (1415) Client [ESPClient_2C:F4:32:20:4B:4F]  pingreq
                        ^X^C
                        pi@raspberrypi:~ $
                        • B Beowolf
                          und das noch
                          ^X^C
                          pi@raspberrypi:~ $
                          @beowolf
                          Bitte nicht auf silly! Da kommt ja alles ums Eck!
                          Info reicht erstmal. Vielleicht später noch debug.
                            @beowolf
                            Beowolf
                            Was meinst du mit silly?
                            Das ist das was gekommen ist. War das nicht richtig?
                            • B Beowolf
                              @beowolf
                              Stell mal den mqtt-Adaper auf Info. Sonst quakt der jeden Mist in das Log rein.
                              • B Beowolf
                                @beowolf
                                Das hast du schon durch?
                                iobroker add vis
                                bringt?
                                  @beowolf
                                  iobroker add vis
                                  bringt?
                                  Beowolf
                                  Das
                                  pi@raspberrypi:~ $ iobroker add vis
                                  NPM version: 6.14.17
                                  Installing iobroker.vis@1.4.15... (System call)
                                  > iobroker.vis@1.4.15 install /opt/iobroker/node_modules/iobroker.vis
                                  > node main.js --install
                                  host.raspberrypi Cannot install iobroker.vis@1.4.15: 6
                                  pi@raspberrypi:~ $
                                  • B Beowolf
                                    Das
                                    pi@raspberrypi:~ $
                                    @beowolf
                                    Ich vermute da ist der npm tree nicht sauber.
                                    cd /opt/iobroker
                                    sudo -H -u iobroker npm install iobroker.vis --loglevel error --prefix "/opt/iobroker"
                                      @beowolf
                                      cd /opt/iobroker
                                      Beowolf
                                      @thomas-braun sagte in Kann vis/edit.html nicht finden:
                                      Kommt das
                                      pi@raspberrypi:~ $ cd /opt/iobroker
                                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.vis --loglevel error --prefix "/opt/iobroker"
                                      npm ERR! code ELIFECYCLE
                                      npm ERR! errno 6
                                      npm ERR! iobroker.vis@1.4.15 install: `node main.js --install`
                                      npm ERR! Exit status 6
                                      npm ERR!
                                      npm ERR! Failed at the iobroker.vis@1.4.15 install script.
                                      npm ERR!     /home/iobroker/.npm/_logs/2022-06-01T08_51_46_521Z-debug.log
                                      • B Beowolf
                                        Kommt das
                                        npm ERR! errno 6
                                        npm ERR!
                                        @beowolf sagte in Kann vis/edit.html nicht finden:
                                        npm ERR! errno 6
                                        Da fallen mir nur noch ekelige Dinge mit Dateien löschen ein. Ich weiß aber nicht was dann passiert.
                                          npm ERR! errno 6
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          @thomas-braun oder mal eine ältere Version probieren
