  4. Test Adapter Solarlog v2.x.x latest
solarlog
76 Beiträge 12 Kommentatoren 12.7k Aufrufe 10 Beobachtet
  • S schmuh
    @forelleblau
    Hi Marcel,
    hoffe es ist alle gut bei dir. Der Adapter bringt beim Start noch diese "kosmetischen" Meldungen:
    2022-02-11 03:04:00.897	warn	This object will not be created in future versions. Please report this to the developer.
    solarlog.0
    2022-02-11 03:04:00.897	warn	Object solarlog.0.status.consyieldtotal is invalid: Default value has to be type "number" but received type "boolean"
    solarlog.0
    2022-02-11 03:04:00.888	warn	This object will not be created in future versions. Please report this to the developer.
    solarlog.0
    2022-02-11 03:04:00.887	warn	Object solarlog.0.status.consyieldyear is invalid: Default value has to be type "number" but received type "boolean"
    solarlog.0
    2022-02-11 03:04:00.885	warn	This object will not be created in future versions. Please report this to the developer.
    solarlog.0
    2022-02-11 03:04:00.885	warn	Object solarlog.0.status.consyieldmonth is invalid: Default value has to be type "number" but received type "boolean"
    solarlog.0
    2022-02-11 03:04:00.871	warn	This object will not be created in future versions. Please report this to the developer.
    solarlog.0
    2022-02-11 03:04:00.870	warn	Object solarlog.0.status.consyieldyesterday is invalid: Default value has to be type "number" but received type "boolean"
    solarlog.0
    2022-02-11 03:04:00.864	warn	This object will not be created in future versions. Please report this to the developer.
    solarlog.0
    2022-02-11 03:04:00.864	warn	Object solarlog.0.status.consyieldday is invalid: Default value has to be type "number" but received type "boolean"
    solarlog.0
    2022-02-11 03:04:00.862	warn	This object will not be created in future versions. Please report this to the developer.
    solarlog.0
    2022-02-11 03:04:00.862	warn	Object solarlog.0.status.yieldtotal is invalid: Default value has to be type "number" but received type "boolean"
    solarlog.0
    2022-02-11 03:04:00.860	warn	This object will not be created in future versions. Please report this to the developer.
    solarlog.0
    2022-02-11 03:04:00.859	warn	Object solarlog.0.status.yieldyear is invalid: Default value has to be type "number" but received type "boolean"
    solarlog.0
    2022-02-11 03:04:00.853	warn	This object will not be created in future versions. Please report this to the developer.
    solarlog.0
    2022-02-11 03:04:00.853	warn	Object solarlog.0.status.yieldmonth is invalid: Default value has to be type "number" but received type "boolean"
    solarlog.0
    2022-02-11 03:04:00.845	warn	This object will not be created in future versions. Please report this to the developer.
    solarlog.0
    2022-02-11 03:04:00.845	warn	Object solarlog.0.status.yieldyesterday is invalid: Default value has to be type "number" but received type "boolean"
    solarlog.0
    2022-02-11 03:04:00.843	warn	This object will not be created in future versions. Please report this to the developer.
    solarlog.0
    2022-02-11 03:04:00.842	warn	Object solarlog.0.status.yieldday is invalid: Default value has to be type "number" but received type "boolean"
    solarlog.0
    2022-02-11 03:04:00.840	warn	This object will not be created in future versions. Please report this to the developer.
    solarlog.0
    2022-02-11 03:04:00.840	warn	Object solarlog.0.status.conspac is invalid: Default value has to be type "number" but received type "boolean"
    solarlog.0
    2022-02-11 03:04:00.833	warn	This object will not be created in future versions. Please report this to the developer.
    solarlog.0
    2022-02-11 03:04:00.832	warn	Object solarlog.0.status.udc is invalid: Default value has to be type "number" but received type "boolean"
    solarlog.0
    2022-02-11 03:04:00.828	warn	This object will not be created in future versions. Please report this to the developer.
    solarlog.0
    2022-02-11 03:04:00.828	warn	Object solarlog.0.status.uac is invalid: Default value has to be type "number" but received type "boolean"
    solarlog.0
    2022-02-11 03:04:00.808	warn	This object will not be created in future versions. Please report this to the developer.
    solarlog.0
    2022-02-11 03:04:00.807	warn	Object solarlog.0.info.totalPower is invalid: Default value has to be type "number" but received type "boolean"
    Controller 4.x
    Beste Grüße
    Werner
    forelleblau
    @schmuh sagte in Test Adapter Solarlog v2.x.x latest:
    Hallo Werner
    Danke für den Hinweis. Erklären kann ich mir das aber nicht wirklich. Da bräuchte ich ein Debug-Log.
    Möglich Erklärung: die Fehler tauch kurz nach dem Solarlog-Neustart morgens um 03.00 auf. Ev gibt da die offene JSON-Schnittstelle lauter Nullen zurück die dann als boolsches false gedeutet werden.
    Kannst du mir ein debug-log aus dem Fehler-zeitraum zur Verfügung stellen?
    Grüsse forelleblau
    • F forelleblau
      Hallo Werner
      Grüsse forelleblau
      schmuh
      @forelleblau sagte in Test Adapter Solarlog v2.x.x latest:
      Hallo Marcel,
      anbei das Debug Log. Es hat nichts mit der Uhrzeit zu tun, die Meldungen kommen bei jedem Neustart des Adapters! Ich hoffe als Datei ist das Log ok, sonst packe ich es nochmal in Codetags.
      SL-Debug.txt
      Beste Grüße und ein schönes Wochenende
      Werner
      F 1 Antwort Letzte Antwort
      • S schmuh
        Hallo Marcel,
        SL-Debug.txt
        Werner
        forelleblau
        @schmuh
        Danke vielmal für das Log Werner. Hab den Fehler gefunden - jedenfalls eine Möglichkeit.
        Hab die Korrektur auf Github hochgeladen. Wenn du von da installierst, sollte es ohne Warnungen laufen.
        Würdest du das für mich testen bitte?
        Herzliche Grüsse
        Forelleblau
        • F forelleblau
          @schmuh
          Herzliche Grüsse
          Forelleblau
          schmuh
          @forelleblau
          Moin Marcel,
          klasse, es kommen keine Warnungen mehr. Danke für die, wie immer, schnelle Korrektur und den super Adapter.
          Schönes Wochenende
          Werner
          • S schmuh
            @forelleblau
            Moin Marcel,
            Schönes Wochenende
            Werner
            forelleblau
            @schmuh
            Danke. Hab jetzt js-controller 4.x auch drauf.
            V2.2.2 vom solarlog-adapter ist nun publiziert (latest)
            Grüsse Forelleblau
              Stoni
              @forelleblau
              Hi, ich nutze seit längerem den Solarlog Adapter erfolgreich. Vielen Dank dafür an dieser Stelle. Seit kurzem wird mir der aktuelle Leistungswert der PV Anlage nicht mehr angezeigt.
              Folgende Warnung wird angezeigt:
              solarlog.0
              2022-03-28 08:20:56.327	warn	State "solarlog.0.SwitchGroup.undefined.state" has no existing object, this might lead to an error in future versions
              Die erzeugten KWh werden aber weiterhin angezeigt. In den Objekten steht Connection auf false, ich kann aber ganz normal auf den Solarlog zugreifen. Da werden auch alle Werte korrekt angezeigt.
              Kannst Du oder jemand anderes mir helfen?
              Grüße Stoni
              • S Stoni
                @forelleblau
                solarlog.0
                Grüße Stoni
                forelleblau
                @stoni Hallo Stoni
                Das sind mehrere Fehler aufs mal, wenn ich das richtig verstehe.
                Hast du die neueste Version 2.2.2 installiert?
                Wenn ja, dann lösche einmal das Objekt, das den geposteten Fehler erzeugt und starte den Adapter neu. So wird das Objekt neu angelegt.
                Ebenso bitte prüfen, ob die die Benutzer/Passwort - Einstellungen im Solarlog und im Adapter noch identisch sind.
                Für das übrige bräuchte ich ein debug-log von einem gesamte Adapter - Start mit allen Abfragen.
                Herzliche Grüsse
                forelleblau
                • F forelleblau
                  @stoni Hallo Stoni
                  Herzliche Grüsse
                  forelleblau
                  Stoni
                  @stoni Hallo Stoni
                  Herzliche Grüsse
                  forelleblau
                  Hi, ja hab die 2.2.2 installiert. Ich hatte den Adapter Mal gestoppt und eben gerade wieder gestartet. Komischerweise werden jetzt alle Daten korrekt angezeigt.
                  Danke für Deine Unterstützung.
                  • F forelleblau
                    Hallo Andreas
                    Einen eigentlichen Workaround gibt es nicht. Was du tun kannst, ist in den 'Erweiterten Einstellungen' das 'Importieren von Wechselrichter- und Gerätedaten' aktivieren. Damit solltest du die Daten der einzelnen Wechselrichter oder Metern erhalten. Hast du das schon gemacht?
                    Ich kann mal prüfen, welche der betroffenen 'Access denied' Daten ich allenfalls über andere Abfragen zur Verfügung stellen könnte.
                    Ich hab mir mal ein Issue dazu angelegt.
                    Grüsse
                    Marcel
                    treffganix
                    Hallo @forelleblau,
                    sorry dass ich das hier nochmal aufgreifen muss. Ich habe seit ein paar Tagen den Solar-Log 50 neu und habe von der Möglichkeit gelesen den in meinen iobroker zu integrieren. Egal was ich versuche, ich bekomme die "ACCESS DENIED" Meldungen aber nicht weg und kann auch keine ausgelesenen Werte erkennen. Ich habs schon mit aktiviertem Benutzerkennwort probiert, das brachte keine Besserung. Den Punkt "Erweiterte Einstellungen" -> Importieren von Wechselrichter- und Gerätedaten finde ich gar nicht in meinem Solar-Log.... Oder habe ich da doch irgendwie ein anderes Gerät was nicht funktioniert. Vielleicht hast du ja noch eine Idee. Würde mich freuen.
                    Liebe Grüße
                    Patrick
                    • T treffganix
                      Hallo @forelleblau,
                      Liebe Grüße
                      Patrick
                      forelleblau
                      @treffganix Hallo Patrick
                      Für das 'Access Denied' - Problem beim Solarlog 50 hab ich leider noch keine schlaue Lösung.
                      Den Teil 'Importieren von Wechselrichter- und Gerätedaten' musst du nicht im solarlog suchen, sondern im ioBroker in den Einstellungen zur solarlog-Instanz. Dort wo du die IP etc zu deinem Solarlog eingibst (=Grundeinstellungen) hat es ein zweites Tab (oben) 'Erweiterte Einstellungen' wo du die entsprechenden Haken setzen kannst etc.
                      Wenn du dann runterscrollst, kannst du auch den Abruf der historischen Daten und den Forcast konfigurieren.
                      Grüsse Forelleblau
                      • F forelleblau
                        Grüsse Forelleblau
                        treffganix
                        @forelleblau Oh wie doof von mir, jetzt habe ich es gefunden und es läuft auch auf Anhieb. Danke dir, ich schau mal was ich damit anstellen kann.
                        • F forelleblau
                          Aktuelle Test Version 2.2.x
                          Veröffentlichungsdatum 25.2.2023
                          Github Link https://github.com/iobroker-community-adapters/ioBroker.solarlog
                          NEU: 'forecast - Fehler behoben
                          V2.2.6 - github/latest
                          'forecast' Fehler behoben.
                          V2.2.5
                          Keine zusätzlichen Funktionen. Anpassungen im Wesentlichen in der Programmierung. Verschiedene Fehler (z.B. falsche Objektformate). Ready für js-controller > 4
                          V2.2.1
                          Da 'request' nicht mehr weiter unterstützt/ausgebaut wird, setzt der Adapter neu auf 'got' für die http-requests beim Solarlog. node.js wurde auf >=12 angehoben.
                          V2.1.2
                          JS-Controller 3.3.x - Kompatibilität sichergestellt.
                          V2.1.1
                          Neu werden alle Werte aus der Grafik im Cockpit und die Anzeige einiger Icons und Fehlermeldungen (resp. ob OK steht) importiert.
                          V2.0.2
                          Neu werden die Smart-Energy Schaltgruppen mit Name, verknüpfter Hardware (inkl. Untereinheit wo vorhanden), Schaltereinstellung (on/off/auto) und Schaltzustand im Adapter abgebildet. Voraussetzung ist der Import der 'Wechselrichter und Gerätedaten' in den erweiterten Einstellungen.
                          V2.0.1
                          Da beim ersten Start des Adapters immer mehr Daten aus dem Solarlog geholt werden, sind Fälle aufgetreten, in denen das Timing zwischen Datenbeschaffung und Objekte anlegen im Adapter nicht mehr passend war. Dies wurde korrigiert.
                          Danke den Meldern.
                          V2.0.x
                          Die neue Version bringt eine ganz neue Struktur der Kommunikation mit dem Solarlog. Die Anzahl Anfragen an den Solarlog kann damit massiv reduziert werden. Es wird gebündelter und gezielter abgefragt. Beide Systeme werden so weniger belastet.
                          Zudem werden neu ein paar technische / Systemdaten abgerufen und im .info - channel bereitgestelt und es werden aus den im Solarlog eingetragenen Daten eine Tages-, Monats(laufender und alle)-, und Jahressollwert berechnet und zur Verfügung gestellt. Die Werte sind im .forecast-channel zu finden und sind mit 'setpoint' bezeichnet um sie von 'forecast' - Werten, die optional von forecast.solar abgerufen werden können abzugrenzen (mit besten Grüssen an @hmanfred ). Die Sollwerte funktionieren auf jeden Fall bei Einzelanlagen. Besteht eine Anlage aus mehreren Anlagegruppen, stimmen die Werte möglicherweise nicht. Sollte dies der Fall sein. bitte ich um Feedback hier oder im Issue zum Thema auf github.
                          V.1.3.x
                          Mit der neuen Version 1.3.x kann nun im Solarlog das Benutzerpasswort aktiviert / gesetzt werden. Gleichzeitig muss in den Adaptereinstellungen das Häkchen dafür gesetzt und das Benutzerpasswort vom Solarlog angegeben werden.
                          Will man auf die Solarlog - UI (per solarlog-ip im Browser) zugreifen, sollte der Adapter aber gestoppt werden, da sonst Authentifizierungsprobleme entstehen. Ebenso sollte nicht von mehreren Instanzen gleichzeitig auf den Solarlog zugegriffen werden. Für den 'Mehrfachzugriff' empfiehlt sich nur die Variante mit deaktiviertem Benutzerpasswort.
                          Danke fürs Testen und für Feedback an dieser Stelle, freue mich auch über positives.
                          forelleblau
                          W Offline
                          W Offline
                          WillyIobrok
                          #66
                          @forelleblau
                          Hallo, nach dem update des solarlog adapters von V2.2.1 auf 2.2.5 ist mir aufgefallen, daß die Protokollierung der Energiedaten über den history - Adapter jede Nacht um 03:00 stoppt. Wenn ich am nächsten Tag den Solarlog Adapter dann wieder starte läuft's wieder bis 03:00Uhr in der nächsten Nacht.
                          Hat jemand anders das auch beobachtet?
                          Ist das ein Bug, oder eine Inkompatibilität, d.h. gibt es ein neue Einstellung, an der ich etwas eintragen muß ?
                          Viele Grüße
                          WillyIobrok
                          • P Offline
                            PEPITO82
                            #67
                            Ich habe regelmäßig diesen Syntax Error im Log:
                            solarlog.0
                            2023-02-20 07:25:00.178 warn Getforecastdata - Error: SyntaxError: Unexpected token T in JSON at position 0
                            Zwecks Vorhersage habe ich folgende Parameter festgelegt:
                            Ist da ein Fehler bei meinen Einstellungen oder ist das ein bekannter "Fehler"?
                            • P PEPITO82
                              solarlog.0
                              forelleblau
                              schrieb am zuletzt editiert von forelleblau
                              #68
                              @pepito82 Danke für den Hinweis, jetzt ist es ein bekannter Fehler. Es hat sich ein '/' zuviel eingeschlichen. Ich werde in den nächsten Tagen eine neue Version publizieren, die (hoffentlich) die Unsauberkeiten von 2.2.5 bereinigt.
                              Grüsse forelleblau
                              EDIT: auf Github steht der korrigierte Code bereits zur Verfügung (noch nicht neu versioniert).
                              P 1 Antwort Letzte Antwort
                              • F forelleblau
                                Grüsse forelleblau
                                PEPITO82
                                #69
                                @forelleblau Super, vielen Dank! :)
                                  tomasog
                                  #70
                                  in meinem ioBroker 6.3.5 habe ich den Solarlog-Adapter V2.2.6 installiert und möchte auf einen Solarlog 200 PM zugreifen.
                                  Unter Instanzwn wird mir angezeigt, dass er mit dem Host verbunden ist und auch ein Lebenszeichen hat (alles grün).
                                  Dennoch werden keine Werte geliefert.
                                  Im Log sehe ich immer wieder einen Fehler 404.
                                  Kann mir bitte jemand mitteilen, worin das Problem liegt?
                                  solarlog.0
                                  	2023-09-20 18:23:03.945	info	Fehler beim Logcheck: Statuscode:AxiosError: Request failed with status code 404. Führe Logcheck bei nächster Gelegenheit erneut aus.
                                  solarlog.0
                                  	2023-09-20 18:23:03.945	info	Logcheck - axios - Error: AxiosError: Request failed with status code 404
                                  solarlog.0
                                  	2023-09-20 18:23:03.395	info	Fehler beim Login: Statuscode:AxiosError: Request failed with status code 404. Führe Login bei nächster Gelegenheit erneut aus.
                                  solarlog.0
                                  	2023-09-20 18:23:03.395	info	Login - axios - Error: AxiosError: Request failed with status code 404
                                  solarlog.0
                                  	2023-09-20 18:23:03.309	info	Forecast - Datenabruf: true
                                  solarlog.0
                                  	2023-09-20 18:23:03.309	info	Rufe historische Daten um 24:0 ab
                                  solarlog.0
                                  	2023-09-20 18:23:03.308	info	Unterzähler - Import: true
                                  solarlog.0
                                  	2023-09-20 18:23:03.282	info	[START] Starting solarlog adapter
                                  solarlog.0
                                  	2023-09-20 18:23:03.187	info	starting. Version 2.2.6 in /opt/iobroker/node_modules/iobroker.solarlog, node: v18.16.1, js-controller: 4.0.24
                                  solarlog.0
                                  	2023-09-20 18:23:00.053	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                  solarlog.0
                                  	2023-09-20 18:23:00.051	info	terminating
                                  solarlog.0
                                  	2023-09-20 18:23:00.038	info	[END] Stopping solarlog adapter...
                                  solarlog.0
                                  	2023-09-20 18:23:00.034	info	Scheduled restart.
                                  solarlog.0
                                  	2023-09-20 18:22:53.090	info	Fehler beim Logcheck: Statuscode:AxiosError: Request failed with status code 404. Führe Logcheck bei nächster Gelegenheit erneut aus.
                                  solarlog.0
                                  	2023-09-20 18:22:53.089	info	Logcheck - axios - Error: AxiosError: Request failed with status code 404
                                  • T tomasog
                                    solarlog.0
                                    solarlog.0
                                    solarlog.0
                                    solarlog.0
                                    solarlog.0
                                    solarlog.0
                                    solarlog.0
                                    solarlog.0
                                    solarlog.0
                                    solarlog.0
                                    solarlog.0
                                    solarlog.0
                                    solarlog.0
                                    solarlog.0
                                    solarlog.0
                                    forelleblau
                                    #71
                                    @tomasog Hallo tomasog. Prüf doch mal, ob deine IP und deine Einstellungen zum Benutzerpasswort mit dem solarlog, den du erreichen willst, übereinstimmen. Am besten deaktivierst du mal das Benutzerpasswort im Solarlog und im Adapter.
                                    Wenn das nicht hilft, stell mir bitte in debug-log zur verfügung.
                                    Am Typ Solarlog sollte es nicht liegen, der Adapter läuft jedenfalls schon mit anderen 200 PM+.
                                    Grüsse
                                    forelleblau
                                      tomasog
                                      schrieb am zuletzt editiert von tomasog
                                      #72
                                      Hey @forelleblau,
                                      vielen Dank für Deine Nachricht.
                                      Das Benutzerpassword habe ich deaktiviert.
                                      Anschließend nochmals alles gecheckt und neu gestartet, bekomme es aber trotzdem nicht hin.
                                      Hier schicke ich Dir nochmals mein Protokoll:
                                      solarlog.0
                                      	2545	2023-09-27 15:20:04.479	info	Fehler beim Logcheck: Statuscode:AxiosError: Request failed with status code 404. Führe Logcheck bei nächster Gelegenheit erneut aus.
                                      solarlog.0
                                      	2545	2023-09-27 15:20:04.478	info	Logcheck - axios - Error: AxiosError: Request failed with status code 404
                                      solarlog.0
                                      	2545	2023-09-27 15:20:04.429	debug	Starte LogCheck
                                      solarlog.0
                                      	2545	2023-09-27 15:20:04.428	debug	Options: {"method":"post","headers":{"Accept":"*/*","Accept-Encoding":"gzip, deflate","Connection":"keep-alive","Content-Type":"application/x-www-form-urlencoded; charset=UTF-8","Referer":"http://192.168.178.90//","Accept-Origin":"http://192.168.178.90//","User-Agent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.149 Safari/537.36","X-Requested-With":"XMLHttpRequest","Cookie":"banner_hidden=false; SolarLog="}}
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.927	debug	WR Importieren
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.927	debug	uzimp: true
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.927	info	Fehler beim Login: Statuscode:AxiosError: Request failed with status code 404. Führe Login bei nächster Gelegenheit erneut aus.
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.926	info	Login - axios - Error: AxiosError: Request failed with status code 404
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.825	debug	starte LOGIN
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.825	debug	Options: {"method":"post","headers":{"Cookie":"banner_hidden=false"}}
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.824	debug	[START] Started Adapter with: http://192.168.178.90/
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.823	debug	[INFO] Configured polling interval averages&other: 300000
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.822	debug	[INFO] Configured polling interval consumption/production: 30000
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.822	info	Forecast - Datenabruf: true
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.822	info	Rufe historische Daten um 24:0 ab
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.822	debug	uzimp: true
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.821	info	Unterzähler - Import: true
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.821	debug	LOVE - Ich liebe euch!
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.820	debug	Host? true : http://192.168.178.90/
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.786	info	[START] Starting solarlog adapter
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.688	debug	Schedule restart: * * * * *
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.650	info	starting. Version 2.2.6 in /opt/iobroker/node_modules/iobroker.solarlog, node: v18.16.1, js-controller: 4.0.24
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.204	debug	States connected to redis: 127.0.0.1:9000
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.183	debug	States create User PubSub Client
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.181	debug	States create System PubSub Client
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.172	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.154	debug	Objects connected to redis: 127.0.0.1:9001
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.147	debug	Objects client initialize lua scripts
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.121	debug	Objects create User PubSub Client
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.120	debug	Objects create System PubSub Client
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.074	debug	Objects client ready ... initialize now
                                      solarlog.0
                                      	2545	2023-09-27 15:20:03.032	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      solarlog.0
                                      	2474	2023-09-27 15:20:00.045	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                      solarlog.0
                                      	2474	2023-09-27 15:20:00.044	info	terminating
                                      solarlog.0
                                      	2474	2023-09-27 15:20:00.027	info	[END] Stopping solarlog adapter...
                                      solarlog.0
                                      	2474	2023-09-27 15:20:00.019	info	Scheduled restart.
                                      solarlog.0
                                      	2474	2023-09-27 15:19:15.089	info	Fehler beim Logcheck: Statuscode:AxiosError: Request failed with status code 404. Führe Logcheck bei nächster Gelegenheit erneut aus.
                                      solarlog.0
                                      	2474	2023-09-27 15:19:15.088	info	Logcheck - axios - Error: AxiosError: Request failed with status code 404
                                      solarlog.0
                                      	2474	2023-09-27 15:19:15.041	debug	Starte LogCheck
                                      solarlog.0
                                      	2474	2023-09-27 15:19:15.040	debug	Options: {"method":"post","headers":{"Accept":"*/*","Accept-Encoding":"gzip, deflate","Connection":"keep-alive","Content-Type":"application/x-www-form-urlencoded; charset=UTF-8","Referer":"http://192.168.178.90//","Accept-Origin":"http://192.168.178.90//","User-Agent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.149 Safari/537.36","X-Requested-With":"XMLHttpRequest","Cookie":"banner_hidden=false; SolarLog="}}
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.539	debug	WR Importieren
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.539	debug	uzimp: true
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.539	info	Fehler beim Login: Statuscode:AxiosError: Request failed with status code 404. Führe Login bei nächster Gelegenheit erneut aus.
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.538	info	Login - axios - Error: AxiosError: Request failed with status code 404
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.429	debug	starte LOGIN
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.428	debug	Options: {"method":"post","headers":{"Cookie":"banner_hidden=false"}}
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.428	debug	[START] Started Adapter with: http://192.168.178.90/
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.427	debug	[INFO] Configured polling interval averages&other: 300000
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.427	debug	[INFO] Configured polling interval consumption/production: 30000
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.426	info	Forecast - Datenabruf: true
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.426	info	Rufe historische Daten um 24:0 ab
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.426	debug	uzimp: true
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.424	info	Unterzähler - Import: true
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.424	debug	LOVE - Ich liebe euch!
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.422	debug	Host? true : http://192.168.178.90/
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.381	info	[START] Starting solarlog adapter
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.321	debug	Schedule restart: * * * * *
                                      solarlog.0
                                      	2474	2023-09-27 15:19:14.286	info	starting. Version 2.2.6 in /opt/iobroker/node_modules/iobroker.solarlog, node: v18.16.1, js-controller: 4.0.24
                                      solarlog.0
                                      	2474	2023-09-27 15:19:13.907	debug	States connected to redis: 127.0.0.1:9000
                                      solarlog.0
                                      	2474	2023-09-27 15:19:13.889	debug	States create User PubSub Client
                                      solarlog.0
                                      	2474	2023-09-27 15:19:13.888	debug	States create System PubSub Client
                                      solarlog.0
                                      	2474	2023-09-27 15:19:13.879	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                      solarlog.0
                                      	2474	2023-09-27 15:19:13.859	debug	Objects connected to redis: 127.0.0.1:9001
                                      solarlog.0
                                      	2474	2023-09-27 15:19:13.850	debug	Objects client initialize lua scripts
                                      solarlog.0
                                      	2474	2023-09-27 15:19:13.821	debug	Objects create User PubSub Client
                                      solarlog.0
                                      	2474	2023-09-27 15:19:13.819	debug	Objects create System PubSub Client
                                      solarlog.0
                                      	2474	2023-09-27 15:19:13.817	debug	Objects client ready ... initialize now
                                      solarlog.0
                                      	2474	2023-09-27 15:19:13.775	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      solarlog.0
                                      	2450	2023-09-27 15:19:09.469	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      solarlog.0
                                      	2450	2023-09-27 15:19:09.468	info	terminating
                                      solarlog.0
                                      	2450	2023-09-27 15:19:09.467	info	[END] Stopping solarlog adapter...
                                      solarlog.0
                                      	2450	2023-09-27 15:19:09.465	info	Got terminate signal TERMINATE_YOURSELF
                                      solarlog.0
                                      	2450	2023-09-27 15:19:04.653	info	Fehler beim Logcheck: Statuscode:AxiosError: Request failed with status code 404. Führe Logcheck bei nächster Gelegenheit erneut aus.
                                      solarlog.0
                                      	2450	2023-09-27 15:19:04.652	info	Logcheck - axios - Error: AxiosError: Request failed with status code 404
                                      solarlog.0
                                      	2450	2023-09-27 15:19:04.103	info	Fehler beim Login: Statuscode:AxiosError: Request failed with status code 404. Führe Login bei nächster Gelegenheit erneut aus.
                                      solarlog.0
                                      	2450	2023-09-27 15:19:04.102	info	Login - axios - Error: AxiosError: Request failed with status code 404
                                      solarlog.0
                                      	2450	2023-09-27 15:19:03.976	info	Forecast - Datenabruf: true
                                      solarlog.0
                                      	2450	2023-09-27 15:19:03.976	info	Rufe historische Daten um 24:0 ab
                                      solarlog.0
                                      	2450	2023-09-27 15:19:03.974	info	Unterzähler - Import: true
                                      solarlog.0
                                      	2450	2023-09-27 15:19:03.930	info	[START] Starting solarlog adapter
                                      solarlog.0
                                      	2450	2023-09-27 15:19:03.795	info	starting. Version 2.2.6 in /opt/iobroker/node_modules/iobroker.solarlog, node: v18.16.1, js-controller: 4.0.24
                                      solarlog.0
                                      	2076	2023-09-27 15:19:00.043	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                      solarlog.0
                                      	2076	2023-09-27 15:19:00.042	info	terminating
                                      solarlog.0
                                      	2076	2023-09-27 15:19:00.030	info	[END] Stopping solarlog adapter...
                                      solarlog.0
                                      	2076	2023-09-27 15:19:00.029	info	Scheduled restart.
                                      solarlog.0
                                      	2076	2023-09-27 15:18:53.199	info	Fehler beim Logcheck: Statuscode:AxiosError: Request failed with status code 404. Führe Logcheck bei nächster Gelegenheit erneut aus.
                                      solarlog.0
                                      	2076	2023-09-27 15:18:53.198	info	Logcheck - axios - Error: AxiosError: Request failed with status code 404
                                      solarlog.0
                                      	2076	2023-09-27 15:18:03.698	info	Fehler beim Logcheck: Statuscode:AxiosError: Request failed with status code 404. Führe Logcheck bei nächster Gelegenheit erneut aus.
                                      solarlog.0
                                      	2076	2023-09-27 15:18:03.697	info	Logcheck - axios - Error: AxiosError: Request failed with status code 404
                                      solarlog.0
                                      	2076	2023-09-27 15:18:03.146	info	Fehler beim Login: Statuscode:AxiosError: Request failed with status code 404. Führe Login bei nächster Gelegenheit erneut aus.
                                      solarlog.0
                                      	2076	2023-09-27 15:18:03.145	info	Login - axios - Error: AxiosError: Request failed with status code 404
                                      solarlog.0
                                      	2076	2023-09-27 15:18:03.045	info	Forecast - Datenabruf: true
                                      solarlog.0
                                      	2076	2023-09-27 15:18:03.044	info	Rufe historische Daten um 24:0 ab
                                      solarlog.0
                                      	2076	2023-09-27 15:18:03.043	info	Unterzähler - Import: true
                                      solarlog.0
                                      	2076	2023-09-27 15:18:03.021	info	[START] Starting solarlog adapter
                                      solarlog.0
                                      	2076	2023-09-27 15:18:02.942	info	starting. Version 2.2.6 in /opt/iobroker/node_modules/iobroker.solarlog, node: v18.16.1, js-controller: 4.0.24
                                      solarlog.0
                                      	2020	2023-09-27 15:18:00.019	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                      solarlog.0
                                      	2020	2023-09-27 15:18:00.018	info	terminating
                                      solarlog.0
                                      	2020	2023-09-27 15:18:00.013	info	[END] Stopping solarlog adapter...
                                      solarlog.0
                                      	2020	2023-09-27 15:18:00.011	info	Scheduled restart.
                                      solarlog.0
                                      	2020	2023-09-27 15:17:46.746	info	Fehler beim Logcheck: Statuscode:AxiosError: Request failed with status code 404. Führe Logcheck bei nächster Gelegenheit erneut aus.
                                      solarlog.0
                                      	2020	2023-09-27 15:17:46.745	info	Logcheck - axios - Error: AxiosError: Request failed with status code 404
                                      solarlog.0
                                      	2020	2023-09-27 15:17:46.199	info	Fehler beim Login: Statuscode:AxiosError: Request failed with status code 404. Führe Login bei nächster Gelegenheit erneut aus.
                                      solarlog.0
                                      	2020	2023-09-27 15:17:46.198	info	Login - axios - Error: AxiosError: Request failed with status code 404
                                      solarlog.0
                                      	2020	2023-09-27 15:17:46.106	info	Forecast - Datenabruf: true
                                      solarlog.0
                                      	2020	2023-09-27 15:17:46.106	info	Rufe historische Daten um 24:0 ab
                                      solarlog.0
                                      	2020	2023-09-27 15:17:46.105	info	Unterzähler - Import: true
                                      solarlog.0
                                      	2020	2023-09-27 15:17:46.022	info	[START] Starting solarlog adapter
                                      solarlog.0
                                      	2020	2023-09-27 15:17:45.957	info	starting. Version 2.2.6 in /opt/iobroker/node_modules/iobroker.solarlog, node: v18.16.1, js-controller: 4.0.24
                                      • F Offline
                                        forelleblau
                                        #73
                                        Hallo @tomasog.
                                        Kleines Detail: Wahrscheinlich hast du in den Adapter - Einstellungen die IP-Adresse mit einem / am Schluss eingegeben.
                                        Gib sie mal wie ein der Anleitung beschrieben ohne, alse nur 192.168.178.XX ein, vorne nicht und hinten nichts.
                                        Dann sollte es eigenlich klappen (wenn die IP stimmt.....)
                                        Grüsse Forelleblau
                                        • F forelleblau
                                          Hallo @tomasog.
                                          Grüsse Forelleblau
                                          tomasog
                                          #74
                                          Hallo @forelleblau,
                                          super, vielen Dank für die Unterstützung, es funktioniert tatsächlich! Ich freue mich sehr!
                                          Tomasog
