  4. iobroker Admin hat mit Restart Probleme
    5.9k
3 Beiträge 2 Kommentatoren 236 Aufrufe 1 Beobachtet
  • ? Offline
    Guten Morgen zusammen,
    ich habe ein kleines aber nerviges Problem. Wenn ich meinen Pi4 reboote, dann startet die Adminoberfläche nicht mit.
    Im Log steht dann immer:
    2022-05-17 08:00:50.231  - ^[[32minfo^[[39m: host.Raspbroker instance system.adapter.admin.0 started with pid 979
    2022-05-17 08:00:53.628  - ^[[32minfo^[[39m: admin.0 (979) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.12, js-controller: 4.0.23
    2022-05-17 08:00:53.821  - ^[[32minfo^[[39m: admin.0 (979) requesting all states
    2022-05-17 08:00:53.822  - ^[[32minfo^[[39m: admin.0 (979) requesting all objects
    2022-05-17 08:00:53.942  - ^[[33mwarn^[[39m: admin.0 (979) Cannot update news: getaddrinfo EAI_AGAIN iobroker.live
    2022-05-17 08:00:54.256  - ^[[32minfo^[[39m: host.Raspbroker instance system.adapter.javascript.0 started with pid 1181
    2022-05-17 08:00:54.580  - ^[[33mwarn^[[39m: admin.0 (979) Cannot update rating: getaddrinfo EAI_AGAIN rating.iobroker.net
    2022-05-17 08:00:55.526  - ^[[32minfo^[[39m: admin.0 (979) received all objects
    2022-05-17 08:00:56.126  - ^[[32minfo^[[39m: admin.0 (979) Request actual repository...
    2022-05-17 08:00:56.196  - ^[[32minfo^[[39m: admin.0 (979) http server listening on port 8081
    2022-05-17 08:00:56.199  - ^[[32minfo^[[39m: admin.0 (979) Use link "http://localhost:8081" to configure.
    2022-05-17 08:00:56.306  - ^[[31merror^[[39m: admin.0 (979) Cannot start server on 192.168.1.202:8081: Error: listen EADDRNOTAVAIL: address not available 192.168.1.202:8081
    2022-05-17 08:00:56.309  - ^[[32minfo^[[39m: admin.0 (979) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-05-17 08:00:56.311  - ^[[31merror^[[39m: admin.0 (979) Error: "error"
    2022-05-17 08:00:57.304  - ^[[33mwarn^[[39m: admin.0 (979) Could not perform strict object check of state admin.0.info.connection: DB closed
    2022-05-17 08:00:57.306  - ^[[33mwarn^[[39m: admin.0 (979) get state error: Connection is closed.
    2022-05-17 08:00:57.436  - ^[[32minfo^[[39m: admin.0 (979) terminating http server on port 8081
    2022-05-17 08:00:57.816  - ^[[31merror^[[39m: host.Raspbroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2022-05-17 08:00:57.818  - ^[[32minfo^[[39m: host.Raspbroker Do not restart adapter system.adapter.admin.0 because desired by instance
    Wie es da steht, muss ich den dann immer händisch einmal rebooten.
    Weiß einer von euch, wie ich das wieder "automatisch" ans Laufen bekommen kann nach einen Reboot?
    Vielen Dank euch :)
    LG Elirion
      Vielen Dank euch :)
      LG Elirion
      crunchipC Offline
      crunchipC Offline
      @elirion sagte in iobroker Admin hat mit Restart Probleme:
      da steht, die IP ist nicht erreichbar
      ist dein Admin auf 0.0.0.0 eingestellt?
        @crunchip ohhhh nee die war direkt auf die 192.168.1.202 eingestellt. Habe das mal angepasst. Dank dir :)
