  4. Probleme von 4.0.21 auf 4.0.23
91 Beiträge 7 Kommentatoren 15.3k Aufrufe 5 Beobachtet
  • SMSS Offline
    SMSS Offline
    SMS
    pi@homee:/ $ npm cache clean
    npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead. On the other hand, if you're debugging an issue with the installer, you can use `npm install --cache /tmp/empty-cache` to use a temporary cache instead of nuking the actual one.
    npm ERR!
    npm ERR! If you're sure you want to delete the entire cache, rerun this command with --force.
    npm ERR!     /home/pi/.npm/_logs/2022-05-02T12_18_38_690Z-debug.log
    pi@homee:/ $
    • SMSS SMS
      npm ERR!
      pi@homee:/ $
      @sms sagte in Probleme von 4.0.21 auf 4.0.23:
      sudo -H -u iobroker npm cache clean --force
      SMSS 1 Antwort Letzte Antwort
        SMSS Offline
        SMSS Offline
        SMS
        pi@homee:/opt/iobroker $ sudo -H -u iobroker npm cache clean --force
        npm WARN using --force I sure hope you know what you are doing.
        • SMSS SMS
          @sms
          iobroker update -u
          iobroker upgrade
            @sms
            iobroker update -u
            iobroker upgrade
            SMSS Offline
            SMSS Offline
            SMS
            danach nochmal?
            iob stop
            iob update
            iob fix
            iob upgrade self
            iob start
            • SMSS SMS
              danach nochmal?
              iob stop
              iob update
              iob fix
              iob upgrade self
              iob start
              SMSS Offline
              SMSS Offline
              SMS
              @sms
              pi@homee:/opt/iobroker $ iob upgrade self
              Update js-controller from @4.0.21 to @4.0.23
              Stopped Objects DB
              Stopped States DB
              NPM version: 6.14.16
              Installing iobroker.js-controller@4.0.23... (System call)
              > iobroker.js-controller@4.0.23 preinstall /opt/iobroker/node_modules/iobroker.js-controller
              > node lib/preinstallCheck.js
              > iobroker.js-controller@4.0.23 install /opt/iobroker/node_modules/iobroker.js-controller
              > node iobroker.js setup first
              object _design/system updated
                "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\n8c+yRUy82NcZpXaF02W9GpliRchYH815EJbHG6qgSu5qOhmoPWcJ\r\n-----END RSA PRIVATE KEY-----\r\n",
                "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\nDtENDH2XeedS+IRTE8uD/gGLjylBE6+5PJ1eKw==\r\n-----END CERTIFICATE-----\r\n"
              Update certificate defaultPrivate
              The object "system.certificates" was updated successfully.
              Update certificate defaultPublic
              ioBroker configuration updated
              + iobroker.js-controller@4.0.23
              removed 8 packages and updated 24 packages in 206.607s
              47 packages are looking for funding
                run `npm fund` for details
              Jetzt hat es geklappt. Muss ich das bei den Slaves auch machen?
              • SMSS SMS
                @sms
                Stopped Objects DB
                Stopped States DB
                @sms
                Du solltest ALLES auf Stand bringen. Alle Adapter auf Master und Slaves, alle js-controller auf Master und Slaves.
                  @sms
                  SMSS Offline
                  SMSS Offline
                  SMS
                  Alles auf den aktuellen Stand gebracht.
                  Nun habe ich allerdings das Proble, das meine GPIO's nicht mehr schalten.
                  Hier springt es zwar von false auf true:
                  aber am Pi selbst passiert nichts. Woran kann das jetzt wieder liegen?
                  • SMSS SMS
                    Keine Ahnung. Hört sich aber eher nach der Hardware an. Kann man im raspi-config nicht irgendwas diesbezüglich einstellen?
                    • SMSS Offline
                      SMSS Offline
                      SMS
                      schrieb am zuletzt editiert von SMS
                      Ich habe dort ja nichts geändert. Oder kann das durch Updates's vorkommen?
                      • SMSS SMS
                        Oder kann das doch Updates's vorkommen?
                        Welche Adapter sind denn da jetzt aktualisiert worden? Und woher kommt der microfitzelskleine Screenshot?
                        Auch Betriebssystem auf Stand gebracht?
                        Mi GPIOs hab ich aber nix am Hut, da muss dir wer anders helfen.
                          SMSS Offline
                          SMSS Offline
                          SMS
                          Ich lasse mal das hier durchlaufen:
                          pi@kellerkind4GB:~ $ iob stop
                          pi@kellerkind4GB:~ $ iobroker update -u
                          Adapter    "admin"        : 5.3.8    , installed 5.1.25 [Updatable]
                          Adapter    "backitup"     : 2.4.6    , installed 2.2.2  [Updatable]
                          Adapter    "discovery"    : 3.0.3    , installed 2.7.0  [Updatable]
                          Adapter    "growatt"      : 1.1.15   , installed 1.1.1  [Updatable]
                          Adapter    "info"         : 1.9.18   , installed 1.9.8  [Updatable]
                          Adapter    "modbus"       : 4.0.4    , installed 3.4.11 [Updatable]
                          Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
                          pi@kellerkind4GB:~ $ iobroker upgrade
                          Aktualisiert wird alles bis auf modbus, den brauch ich nicht mehr.
                          Der Screenshot ist aus den Objekten. Betriebssystem ist auf aktuellem Stand.
                          Es handelt sich hierbei um einen Slave!
                          • SMSS SMS
                            Von welcher Instanz denn?
                            Und patch die Systeme durch. Danach kann man sich das dann anschauen.
                            Warum läuft auf dem kellerkind überhaupt ein Admin? Das ist doch ein slave-System, oder?
                              SMSS Offline
                              SMSS Offline
                              SMS
                              rpi2.
                              Nun geht's wieder!
                              worin liegt denn der Unterschied? iobroker upgrade und iob upgrade self
                              • SMSS SMS
                                rpi2.
                                Nun geht's wieder!
                                iobroker upgrade
                                zieht die Adapter aktuell,
                                iobroker upgrade self
                                dann danach den js-controller selber.
                                Und
                                iobroker update
                                schaut nur, welche Updates anstehen.
                                  iobroker upgrade
                                  Und
                                  iobroker update
                                  SMSS Offline
                                  SMSS Offline
                                  SMS
                                  also immer upgrade und dann upgrade self?
                                  • SMSS SMS
                                    @sms
                                    Immer zuerst schauen:
                                    iobroker update -u
                                    iobroker upgrade
                                    Den js-controller upgraded man ja nicht sooo häufig. Jedenfalls nicht im 'stable'-Zweig.
                                      @sms
                                      iobroker update -u
                                      iobroker upgrade
                                      SMSS Offline
                                      SMSS Offline
                                      SMS
                                      OK, Danke!!
                                      • SMSS Offline
                                        SMSS Offline
                                        SMS
                                        Hi!
                                        Sorry, ich nochmal!
                                        Seit dem Update wird es immer schlimmer! Die Auslastung meines Masters steigt mittlerweile dauerhaft über 4,5%. Wäre soweit nicht schlimm, aber es wird alles langsamer.
                                        Heute bemerkte ich,das ich erschwert bis gar nicht mehr auf die Seite mit den Skripten komme. Die Seite bleibt (in meinem Fall) dunkel.
                                        Hier mal ein Auszug vom LOG:
                                        rpi2.1
                                        2022-05-05 22:25:27.099	error	No Value found for cpu_frequency
                                        host.kellerkind4GB
                                        2022-05-05 22:25:16.144	error	States database error: connect ECONNREFUSED 192.168.178.58:9000
                                        host.kellerkind4GB
                                        2022-05-05 22:25:15.423	error	Objects database error: connect ECONNREFUSED 192.168.178.58:9001
                                        host.kellerkind4GB
                                        2022-05-05 22:24:05.464	error	States database error: write EPIPE
                                        host.kellerkind4GB
                                        2022-05-05 22:23:42.395	error	States database error: connect ECONNREFUSED 192.168.178.58:9000
                                        host.kellerkind4GB
                                        2022-05-05 22:23:37.478	error	Cannot find view "system" for search "instance" : Connection is closed.
                                        host.kellerkind4GB
                                        2022-05-05 22:23:37.474	error	Caught by controller[1]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied
                                        host.kellerkind4GB
                                        2022-05-05 22:23:37.473	error	Cannot find view "system" for search "instance" : Connection is closed.
                                        host.kellerkind4GB
                                        2022-05-05 22:23:37.468	error	Cannot find view "system" for search "instance" : Connection is closed.
                                        host.kellerkind4GB
                                        2022-05-05 22:23:37.389	error	States database error: connect ECONNREFUSED 192.168.178.58:9000
                                        systeminfo.1
                                        2022-05-05 22:23:11.061	error	Objects database error: connect ECONNREFUSED 192.168.178.58:9001
                                        host.kellerkind4GB
                                        2022-05-05 22:23:11.048	error	Objects database error: connect ECONNREFUSED 192.168.178.58:9001
                                        rpi2.1
                                        2022-05-05 22:23:11.034	error	Objects database error: connect ECONNREFUSED 192.168.178.58:9001
                                        ds18b20.1
                                        2022-05-05 22:23:32.394	error	States database error: connect ECONNREFUSED 192.168.178.58:9000
                                        Wenn ichmit meinem Handy auf vis zugreife und dort Trends mit Grafana anschauen möchte, funktioniert das auch nicht mehr.
                                        Woran könnte das alles liegen?
                                        (kellerkind4GB ist ein Slave)
                                        • SMSS SMS
                                          Hi!
                                          Sorry, ich nochmal!
                                          rpi2.1
                                          host.kellerkind4GB
                                          host.kellerkind4GB
                                          host.kellerkind4GB
                                          host.kellerkind4GB
                                          host.kellerkind4GB
                                          host.kellerkind4GB
                                          host.kellerkind4GB
                                          host.kellerkind4GB
                                          host.kellerkind4GB
                                          systeminfo.1
                                          host.kellerkind4GB
                                          rpi2.1
                                          ds18b20.1
                                          crunchipC Offline
                                          crunchipC Offline
                                          und welche Prozesse?
