  4. Test Adapter BMW/Mini v4.x.x
    6.7k
1.1k Beiträge 103 Kommentatoren 377.1k Aufrufe 89 Beobachtet
  • M MSPtrs
    @tombox @community
    habt ihr das selbe Problem mit den Adapter seit gestern Nachmittag?
    2022-03-17 14:24:08.931 - info: host.raspberrypimodbus "system.adapter.bmw.0" enabled
    2022-03-17 14:24:09.099 - info: host.raspberrypimodbus instance system.adapter.bmw.0 started with pid 27880
    2022-03-17 14:24:12.219 - info: bmw.0 (27880) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.bmw, node: v12.22.6, js-controller: 4.0.19
    2022-03-17 14:24:12.733 - error: bmw.0 (27880) Login failed
    2022-03-17 14:24:12.734 - error: bmw.0 (27880) Error: Request failed with status code 401
    2022-03-17 14:24:12.735 - error: bmw.0 (27880) {"error":"invalid_client","error_description":"Client authentication failed (e.g., login failure, unknown client, no client authentication included or unsupported authentication method)"}
    2022-03-17 14:24:12.736 - error: bmw.0 (27880) Please check username and password or too many logins in 5 minutes
    2022-03-17 14:24:12.737 - error: bmw.0 (27880) Start relogin in 5min
    2022-03-17 14:24:12.738 - error: bmw.0 (27880) undefined
    natürlich hab ich die Logindaten überprüft und den Adapter für über eine Stunde gestoppt.
    Hoffentlich bin ich nicht der einzige...
    EDIT: habs gelöst, der BMW Account hat das Passwort selbstständig geändert👍 🙄
    bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    #335
    seit heute wieder folgendes im debug:
    bmw.0
    2022-03-24 19:09:09.180	error	{"error":"invalid_request","error_description":"The request is missing a required parameter, includes an unsupported parameter value (other than grant type), repeats a parameter, includes multiple credentials, utilizes more than one mechanism for authenticating the client, or is otherwise malformed"}
    bmw.0
    2022-03-24 19:09:09.180	error	Error: Request failed with status code 400
    bmw.0
    2022-03-24 19:09:09.179	error	Login step 3 failed
    bmw.0
    2022-03-24 19:09:09.070	debug	{"redirect_to":"redirect_uri=com.bmw.connected://oauth?client_id=31c357a0-7a1d-4590-aa99-33b97244d048&response_type=code&scope=openid profile email offline_access smacc vehicle_data perseus dlm svds cesim vsapi remote_services fupo authenticate_user&state=cwU-gIE27j67poy2UcL3KQ&authorization=4VgjSefihLAANDVFMAAlMxAAIwMQ..*"}
    bmw.0
    2022-03-24 19:09:08.701	info	starting. Version 2.5.2 (non-npm: TA2k/ioBroker.bmw) in /opt/iobroker/node_modules/iobroker.bmw, node: v14.19.1, js-controller: 4.0.21
    Bitte bereinigen; oder Rückinfo was ich machen kann/soll.
    Danke.
    Danke.
    T 2 Antworten Letzte Antwort
    • bahnuhrB bahnuhr
      bmw.0
      bmw.0
      bmw.0
      bmw.0
      bmw.0
      Danke.
      tombox
      #336
      @bahnuhr Der login via app funktioniert ohne Probleme?
      • T tombox
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        #337
        @tombox sagte in Test Adapter BMW v2.0.0:
        Jo,
        am Handy bin ich rein gekommen.
        Es steht aber da: aktualisiert vom Fahrzeug am 18.03.22 um 14:32
        Dies ist aber schon alt.
        Funktioniert bei BMW da was nicht ?
        Danke.
        • bahnuhrB bahnuhr
          Jo,
          tombox
          #338
          @bahnuhr Auch ausloggen und einloggen geht noch.
          • T tombox
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            #339
            @tombox
            Habe eben mal "aufleuchten" gedrückt.
            Jetzt steht da:
            aktualisiert vom Fahrzeug am 24.03.22 um 19:17
            Das scheint geklappt zu haben.
            jetzt probier ich mal ausloggen.....
            Danke.
            • bahnuhrB bahnuhr
              @tombox
              Jetzt steht da:
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              #340
              @bahnuhr sagte in Test Adapter BMW v2.0.0:
              und ja, das hat auch geklappt.
              Nachtrag:
              Adapter bleibt gelb.
              Danke.
              • bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                #341
                @tombox
                Hat du schon eine Idee?
                Adapter ist weiterhin gelb.
                Kann ich irgendwas testen ?
                Danke.
                • bahnuhrB bahnuhr
                  bmw.0
                  bmw.0
                  bmw.0
                  bmw.0
                  bmw.0
                  Danke.
                  tombox
                  #342
                  @bahnuhr bitte die 2.5.3 ausprobieren. Irgendwie wurden die Cookies von BMW falsch konfiguriert und das fand die http library schlecht
                  • T tombox
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    #343
                    2.5.3. installaiert und die Instanz wurde sofort grün.
                    Danke schön für das schnelle reagieren und nachschauen.
                    Du kümmerst dich um deine Adapter (gibt ja auch andere).
                    nochmals Danke.
                    Läuft wieder.
                    Danke.
                    E 1 Antwort Letzte Antwort
                    • bahnuhrB bahnuhr
                      nochmals Danke.
                      Läuft wieder.
                      Eufi
                      #344
                      Also bei mir funktioniert das Update nicht mehr. Passwort neu gesetzt, Adapter gelöscht und neu installiert.
                      Meldung: Please check username and password or too many logins in 5 minutes
                      Installiert ist die 2.5.3
                      Gibt es irgendwelche Tipps?
                      • E Eufi
                        lobomauL Offline
                        lobomauL Offline
                        lobomau
                        #345
                        @eufi das Offensichtlichste wäre es, den Adapter etwas länger nicht zu benutzen. 5min aus wirst du wahrscheinlich schon probiert haben, oder? Vielleicht mal einen Tag auslassen und nochmal testen?
                        Host: NUC8i3 mit Proxmox:
                        • Slave: Pi4
                        • lobomauL lobomau
                          Eufi
                          #346
                          @lobomau
                          Der war ne Woche aus bis ich es wieder probiert habe jetzt…
                          • E Eufi
                            @lobomau
                            lobomauL Offline
                            lobomauL Offline
                            lobomau
                            schrieb am zuletzt editiert von lobomau
                            #347
                            @eufi da der Adapter bei mir störungsfrei läuft, müssen wir den Fehler bei dir suchen.
                            Wir können ja einmal die installierten Versionen/Einstellungen vergleichen. Ich habe:
                            • BMW Adapter: 2.5.3
                            • js-controller: 4.0.23
                            • Nodejs: 14.19.1
                            • npm: 6.14.16
                            • Adapter Update interval: 1 min
                            Zu guter Letzt könnte man über die BMW Handy-App neues Passwort vergeben und/oder BMW-Adapter neu installieren.
                            • Slave: Pi4
                            • lobomauL lobomau
                              • Nodejs: 14.19.1
                              • npm: 6.14.16
                              Eufi
                              #348
                              @lobomau
                              Sorry für die späte Antwort. Bei mir war leider die letzten Tage leider Stress angesagt...
                              BMW Adapter: 2.5.3
                              js-controller: 4.0.15
                              Nodejs: 14.19.1
                              npm: 6.14.16
                              Adapter Update interval: 5 min
                              Ich versuche mal den js-controller heute upzudaten.
                              Meinst du es kann daran liegen?
                              • E Eufi
                                @lobomau
                                BMW Adapter: 2.5.3
                                Nodejs: 14.19.1
                                npm: 6.14.16
                                Eufi
                                #349
                                @lobomau
                                Ich habe jetzt noch einmal ein neues Passwort vergeben und jetzt geht es wieder.... ganz dubiose Sache.
                                Sorry für die Mühe, die ich gemacht habe.
                                • E Eufi
                                  @lobomau
                                  lobomauL Offline
                                  lobomauL Offline
                                  lobomau
                                  #350
                                  Ich glaube der Server/Api hat heute ein Problem. Die Werte über den Adapter kommen sauber rein in ioBroker. Es gibt aber den Fehler im log und ich komme grad nicht per Handy-App auf den BMW:
                                  bmw.0
                                  2022-05-18 14:54:53.649	error	Error: Request failed with status code 500
                                  bmw.0
                                  2022-05-18 14:54:53.648	error	getvehicles v2 failed
                                  bmw.0
                                  2022-05-18 14:54:29.280	error	Error: Request failed with status code 500
                                  bmw.0
                                  2022-05-18 14:54:29.280	error	getvehicles v2 failed
                                  bmw.0
                                  2022-05-18 14:54:24.462	error	Error: Request failed with status code 500
                                  bmw.0
                                  2022-05-18 14:54:24.461	error	getvehicles v2 failed
                                  bmw.0
                                  2022-05-18 14:53:59.191	error	Error: Request failed with status code 500
                                  bmw.0
                                  2022-05-18 14:53:59.190	error	getvehicles v2 failed
                                  bmw.0
                                  2022-05-18 14:53:53.616	error	Error: Request failed with status code 500
                                  bmw.0
                                  2022-05-18 14:53:53.616	error	getvehicles v2 failed
                                  bmw.0
                                  2022-05-18 14:53:21.173	error	Error: Request failed with status code 500
                                  bmw.0
                                  2022-05-18 14:53:21.172	error	getvehicles v2 failed
                                  • Slave: Pi4
                                  • lobomauL lobomau
                                    bmw.0
                                    bmw.0
                                    bmw.0
                                    bmw.0
                                    bmw.0
                                    bmw.0
                                    bmw.0
                                    bmw.0
                                    bmw.0
                                    bmw.0
                                    bmw.0
                                    bmw.0
                                    bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    #351
                                    @lobomau sagte in Test Adapter BMW v2.0.0:
                                    bei mir das gleiche.
                                    Fehler im log und komme auch nicht auf die app im Handy
                                    Danke.
                                    • bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      #352
                                      Fehler hat sich geändert.
                                      Bis 20:07 kam code 500.
                                      jetzt kommt code 429 (to many requests)
                                      bmw.0
                                      2022-05-18 20:26:40.319	error	Error: Request failed with status code 429
                                      bmw.0
                                      2022-05-18 20:26:40.318	error	getvehicles v2 failed
                                      bmw.0
                                      2022-05-18 20:26:40.266	error	Error: Request failed with status code 429
                                      bmw.0
                                      2022-05-18 20:26:40.265	error	getvehicles v2 failed
                                      bmw.0
                                      2022-05-18 20:16:40.387	error	Error: Request failed with status code 429
                                      bmw.0
                                      2022-05-18 20:16:40.386	error	getvehicles v2 failed
                                      bmw.0
                                      2022-05-18 20:16:40.292	error	Error: Request failed with status code 429
                                      bmw.0
                                      2022-05-18 20:16:40.291	error	getvehicles v2 failed
                                      bmw.0
                                      2022-05-18 20:07:40.462	error	Error: Request failed with status code 500
                                      bmw.0
                                      2022-05-18 20:07:40.462	error	getvehicles v2 failed
                                      bmw.0
                                      2022-05-18 20:07:10.363	error	Error: Request failed with status code 500
                                      bmw.0
                                      2022-05-18 20:07:10.362	error	getvehicles v2 failed
                                      bmw.0
                                      2022-05-18 19:57:41.123	error	Error: Request failed with status code 500
                                      bmw.0
                                      2022-05-18 19:57:41.123	error	getvehicles v2 failed
                                      bmw.0
                                      2022-05-18 19:57:10.472	error	Error: Request failed with status code 500
                                      bmw.0
                                      2022-05-18 19:57:10.471	error	getvehicles v2 failed
                                      Liegt hier irgendwo ein Adapter Fehler vor.
                                      Oder liegt es wieder an BMW?
                                      Danke.
                                      • bahnuhrB bahnuhr
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        bmw.0
                                        lobomauL Offline
                                        lobomauL Offline
                                        lobomau
                                        #353
                                        @bahnuhr da waren die grad am "fertig machen" :-) Seit 20:38 Uhr kommen keine errors mehr im log 👍
                                        • Slave: Pi4
                                        • lobomauL lobomau
                                          bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          #354
                                          hast recht,
                                          habe heute auch keine Fehler mehr im log.
                                          Danke.
