ERROR: Process exited with code 25
Nochmal?Ich hab das sudo -H -u iobroker npm cache clear --force nicht gelesen.
Immer komplette Ein- und Ausgaben posten, dann sieht man auch was da passiert oder auch nicht. -
Nochmal?cd /opt/iobroker sudo -H -u iobroker npm install iobroker.js-controller -
Immer komplette Ein- und Ausgaben posten, dann sieht man auch was da passiert oder auch nicht.@thomas-braun
Problem ist das der Post nur 100000 Zeichenhaben darf sonst kann ich ihn nicht einstellen.So sieht es oben aus:
guido@iobroker:/opt/iobroker$ iobroker update -u Used repository: stable Adapter "daswetter" : 3.1.2 , installed 3.0.9 [Updatable] Adapter "discovery" : 3.0.3 , installed 2.8.0 [Updatable] Adapter "icons-mfd-svg": 1.1.0 , installed 1.0.2 [Updatable] Controller "js-controller": 4.0.23 , installed 4.0.21 [Updatable] Adapter "simple-api" : 2.6.4 , installed 2.6.3 [Updatable] Adapter "socketio" : 4.2.0 , installed 4.1.4 [Updatable] Adapter "sonoff" : 2.5.0 , installed 2.4.7 [Updatable] Adapter "telegram" : 1.12.2 , installed 1.11.1 [Updatable] Adapter "tr-064" : 4.2.16 , installed 4.2.15 [Updatable] Adapter "trashschedule": 1.4.5 , installed 1.4.1 [Updatable] Adapter "vis" : 1.4.15 , installed 1.4.5 [Updatable] Adapter "vis-hqwidgets": 1.2.0 , installed 1.1.9 [Updatable] Adapter "web" : 4.2.3 , installed 4.2.0 [Updatable] guido@iobroker:/opt/iobroker$ iobroker upgrade This upgrade of "web" will introduce the following changes: ========================================================================== -> 4.2.3: Updated ws and socketio to have `log` method in sockets -> 4.2.2: Updated ws and socketio to have `log` method in sockets -> 4.2.1: Provide state and object changes for simple-api ========================================================================== Would you like to upgrade web from @4.2.0 to @4.2.3 now? [(y)es, (n)o]: y Update web from @4.2.0 to @4.2.3 host.iobroker Adapter "system.adapter.web.0" is stopped. NPM version: 6.14.16 Installing iobroker.web@4.2.3... (System call) upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.83d9909b.chunk.js static/js/2.83d9909b.chunk.js application/javascript upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.83d9909b.chunk.js.LICENSE.txt static/js/2.83d9909b.chunk.js.LICENSE.txt text/plain upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.83d9909b.chunk.js.map static/js/2.83d9909b.chunk.js.map application/json upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.205b2673.chunk.js static/js/main.205b2673.chunk.js application/javascript upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.205b2673.chunk.js.map static/js/main.205b2673.chunk.js.map application/json upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.8b37c647.js static/js/runtime-main.8b37c647.js application/javascript upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.8b37c647.js.map static/js/runtime-main.8b37c647.js.map application/json upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png host.iobroker Adapter "system.adapter.web.0" is started This upgrade of "vis-hqwidgets" will introduce the following changes: ========================================================================== -> 1.2.0: Removed deprecated method `load` ========================================================================== Would you like to upgrade vis-hqwidgets from @1.1.9 to @1.2.0 now? [(y)es, (n)o]: y Update vis-hqwidgets from @1.1.9 to @1.2.0 NPM version: 6.14.16 Installing iobroker.vis-hqwidgets@1.2.0... (System call) INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted. Adapter "system.adapter.vis.0" restarted. upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html This upgrade of "vis" will at least introduce the following changes: ========================================================================== -> 1.4.15: Better check of the offline license -> 1.4.14: Corrected GUI bug -> 1.4.13: The group attributes will be replaced recursively -> 1.4.12: Fixed bug with the export of specific widgets -> 1.4.11: Removed ES6 commands to be supported by older browsers Fixed problem with update of grouped widgets Added web manifest to be able to handle vis as the web app -> 1.4.8: Added support for js-controller 4.x -> 1.4.7: Fixed subscribeOidAtRuntime if called with invalid IDs Added support of license manager ========================================================================== Would you like to upgrade vis from @1.4.5 to @1.4.15 now? [(y)es, (n)o]: y Update vis from @1.4.5 to @1.4.15 NPM version: 6.14.16 Installing iobroker.vis@1.4.15... (System call) Adapter "system.adapter.vis.0" restarted. upload [822] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest upload [800] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/cancel.png icon/cancel.png image/png upload [750] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulb_on.png img/bulb_on.png image/png upload [700] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/128/mp3.png js/fm/icon/mine/128/mp3.png image/png upload [650] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/signals/motionColor.png signals/motionColor.png image/png upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/micDetected.svg widgets/basic/img/micDetected.svg image/svg+xml upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqplot/img/Prev_MeterGauge.png widgets/jqplot/img/Prev_MeterGauge.png image/png upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_shutter_60.svg widgets/jqui-mfd/img/fts_shutter_60.svg image/svg+xml upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/sani_heating_temp.png widgets/jqui-mfd/img/sani_heating_temp.png image/png upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/materialdesign/img/preview.jpg widgets/materialdesign/img/preview.jpg image/jpeg upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/materialdesign/lib/myUnderscore.js widgets/materialdesign/lib/myUnderscore.js application/javascript upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/metro/img/light_light_dim_70.png widgets/metro/img/light_light_dim_70.png image/png upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/Prev_Carousel.png widgets/swipe/img/Prev_Carousel.png image/png upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/111-3.png widgets/timeandweather/img/clock/111-3.png image/png upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/9-1.png widgets/timeandweather/img/clock/9-1.png image/png upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/clockbg4.png widgets/timeandweather/img/clock/clockbg4.png image/png upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/js/jquery.zweatherfeed.js widgets/timeandweather/js/jquery.zweatherfeed.js application/javascript upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/trashschedule/js/trashschedule.js widgets/trashschedule/js/trashschedule.js application/javascript upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/0_Nav.png widgets/vis-inventwo/img/0_Nav.png image/png upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/Check.gif widgets/vis-inventwo/img/Check.gif image/gif upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/Slider2.gif widgets/vis-inventwo/img/Slider2.gif image/gif upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/ToggleSwitch/switch-1-vert-off-black.png widgets/vis-inventwo/img/ToggleSwitch/switch-1-vert-off-black.png image/png upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/01.png widgets/vis-inventwo/img/clock_analog/01.png image/png upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02/min.png widgets/vis-inventwo/img/clock_analog/02/min.png image/png upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02/sek.png widgets/vis-inventwo/img/clock_analog/02/sek.png image/png upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02/std.png widgets/vis-inventwo/img/clock_analog/02/std.png image/png upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02.png widgets/vis-inventwo/img/clock_analog/02.png image/png upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/min.png widgets/vis-inventwo/img/clock_analog/03/min.png image/png upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/sek.png widgets/vis-inventwo/img/clock_analog/03/sek.png image/png upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/std.png widgets/vis-inventwo/img/clock_analog/03/std.png image/png upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03.png widgets/vis-inventwo/img/clock_analog/03.png image/png upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04/min.png widgets/vis-inventwo/img/clock_analog/04/min.png image/png upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04/sek.png widgets/vis-inventwo/img/clock_analog/04/sek.png image/png upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04/std.png widgets/vis-inventwo/img/clock_analog/04/std.png image/png upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04.png widgets/vis-inventwo/img/clock_analog/04.png image/png upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05/min.png widgets/vis-inventwo/img/clock_analog/05/min.png image/png upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05/sek.png widgets/vis-inventwo/img/clock_analog/05/sek.png image/png upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05/std.png widgets/vis-inventwo/img/clock_analog/05/std.png image/png upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05.png widgets/vis-inventwo/img/clock_analog/05.png image/png upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/frame.png widgets/vis-inventwo/img/clock_analog/frame.png image/png upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/js/iro.min.js widgets/vis-inventwo/js/iro.min.js application/javascript upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/js/vis-inventwo.js widgets/vis-inventwo/js/vis-inventwo.js application/javascript upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo.html widgets/vis-inventwo.html text/html upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript This upgrade of "trashschedule" will introduce the following changes: ========================================================================== -> 1.4.5: Allow spaces in next text seperator -> 1.4.4: Updated dependencies -> 1.4.3: Updated state roles Added hint for Admin 4 configuration -> 1.4.2: Added check for ical configuration ========================================================================== Would you like to upgrade trashschedule from @1.4.1 to @1.4.5 now? [(y)es, (n)o]: y Update trashschedule from @1.4.1 to @1.4.5 NPM version: 6.14.16 Installing iobroker.trashschedule@1.4.5... (System call) Adapter "system.adapter.vis.0" restarted. upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png This upgrade of "tr-064" will introduce the following changes: ========================================================================== -> 4.2.16: Fix info logs on callee/caller Add special handling for potential broken external image links in phonebook Prevent some crash cases reported by Sentry ========================================================================== Would you like to upgrade tr-064 from @4.2.15 to @4.2.16 now? [(y)es, (n)o]: y Update tr-064 from @4.2.15 to @4.2.16 NPM version: 6.14.16 Installing iobroker.tr-064@4.2.16... (System call) upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript This upgrade of "telegram" will introduce the following changes: ========================================================================== -> 1.12.2: Fix crash cases reported by Sentry -> 1.12.0: Add new JSON states communication.responseJson and communication.responseSilentJson to also accept json structures (stringified!) to send messages Try to prevent adapter crashes when internet is not available Add Sentry for crash reporting ========================================================================== Would you like to upgrade telegram from @1.11.1 to @1.12.2 now? [(y)es, (n)o]: y Update telegram from @1.11.1 to @1.12.2 NPM version: 6.14.16 Installing iobroker.telegram@1.12.2... (System call) upload [16] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript upload [15] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom_m.html custom_m.html text/html upload [14] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/de/translations.json i18n/de/translations.json application/json upload [13] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/en/translations.json i18n/en/translations.json application/json upload [12] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/es/translations.json i18n/es/translations.json application/json upload [11] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/fr/translations.json i18n/fr/translations.json application/json upload [10] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/it/translations.json i18n/it/translations.json application/json upload [9] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/nl/translations.json i18n/nl/translations.json application/json upload [8] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/pl/translations.json i18n/pl/translations.json application/json upload [7] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/pt/translations.json i18n/pt/translations.json application/json upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/ru/translations.json i18n/ru/translations.json application/json upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index.html index.html text/html upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index_m.html index_m.html text/html upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript This upgrade of "sonoff" will introduce the following changes: ========================================================================== -> 2.5.0: Implement writing of NSPanel Widget changes Fix crash case reported by Sentry ========================================================================== Would you like to upgrade sonoff from @2.4.7 to @2.5.0 now? [(y)es, (n)o]: y Update sonoff from @2.4.7 to @2.5.0 NPM version: 6.14.16 Installing iobroker.sonoff@2.5.0... (System call) ^C guido@iobroker:/opt/iobroker$ -
guido@iobroker:/opt/iobroker$ iobroker update -u Used repository: stable Adapter "daswetter" : 3.1.2 , installed 3.0.9 [Updatable] Adapter "discovery" : 3.0.3 , installed 2.8.0 [Updatable] Adapter "icons-mfd-svg": 1.1.0 , installed 1.0.2 [Updatable] Controller "js-controller": 4.0.23 , installed 4.0.21 [Updatable] Adapter "simple-api" : 2.6.4 , installed 2.6.3 [Updatable] Adapter "socketio" : 4.2.0 , installed 4.1.4 [Updatable] Adapter "sonoff" : 2.5.0 , installed 2.4.7 [Updatable] Adapter "telegram" : 1.12.2 , installed 1.11.1 [Updatable] Adapter "tr-064" : 4.2.16 , installed 4.2.15 [Updatable] Adapter "trashschedule": 1.4.5 , installed 1.4.1 [Updatable] Adapter "vis" : 1.4.15 , installed 1.4.5 [Updatable] Adapter "vis-hqwidgets": 1.2.0 , installed 1.1.9 [Updatable] Adapter "web" : 4.2.3 , installed 4.2.0 [Updatable] guido@iobroker:/opt/iobroker$ iobroker upgrade This upgrade of "web" will introduce the following changes: ========================================================================== -> 4.2.3: Updated ws and socketio to have `log` method in sockets -> 4.2.2: Updated ws and socketio to have `log` method in sockets -> 4.2.1: Provide state and object changes for simple-api ========================================================================== Would you like to upgrade web from @4.2.0 to @4.2.3 now? [(y)es, (n)o]: y Update web from @4.2.0 to @4.2.3 host.iobroker Adapter "system.adapter.web.0" is stopped. NPM version: 6.14.16 Installing iobroker.web@4.2.3... (System call) upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.83d9909b.chunk.js static/js/2.83d9909b.chunk.js application/javascript upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.83d9909b.chunk.js.LICENSE.txt static/js/2.83d9909b.chunk.js.LICENSE.txt text/plain upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.83d9909b.chunk.js.map static/js/2.83d9909b.chunk.js.map application/json upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.205b2673.chunk.js static/js/main.205b2673.chunk.js application/javascript upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.205b2673.chunk.js.map static/js/main.205b2673.chunk.js.map application/json upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.8b37c647.js static/js/runtime-main.8b37c647.js application/javascript upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.8b37c647.js.map static/js/runtime-main.8b37c647.js.map application/json upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png host.iobroker Adapter "system.adapter.web.0" is started This upgrade of "vis-hqwidgets" will introduce the following changes: ========================================================================== -> 1.2.0: Removed deprecated method `load` ========================================================================== Would you like to upgrade vis-hqwidgets from @1.1.9 to @1.2.0 now? [(y)es, (n)o]: y Update vis-hqwidgets from @1.1.9 to @1.2.0 NPM version: 6.14.16 Installing iobroker.vis-hqwidgets@1.2.0... (System call) INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted. Adapter "system.adapter.vis.0" restarted. upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html This upgrade of "vis" will at least introduce the following changes: ========================================================================== -> 1.4.15: Better check of the offline license -> 1.4.14: Corrected GUI bug -> 1.4.13: The group attributes will be replaced recursively -> 1.4.12: Fixed bug with the export of specific widgets -> 1.4.11: Removed ES6 commands to be supported by older browsers Fixed problem with update of grouped widgets Added web manifest to be able to handle vis as the web app -> 1.4.8: Added support for js-controller 4.x -> 1.4.7: Fixed subscribeOidAtRuntime if called with invalid IDs Added support of license manager ========================================================================== Would you like to upgrade vis from @1.4.5 to @1.4.15 now? [(y)es, (n)o]: y Update vis from @1.4.5 to @1.4.15 NPM version: 6.14.16 Installing iobroker.vis@1.4.15... (System call) Adapter "system.adapter.vis.0" restarted. upload [822] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest upload [800] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/cancel.png icon/cancel.png image/png upload [750] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulb_on.png img/bulb_on.png image/png upload [700] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/128/mp3.png js/fm/icon/mine/128/mp3.png image/png upload [650] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/signals/motionColor.png signals/motionColor.png image/png upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/micDetected.svg widgets/basic/img/micDetected.svg image/svg+xml upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqplot/img/Prev_MeterGauge.png widgets/jqplot/img/Prev_MeterGauge.png image/png upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_shutter_60.svg widgets/jqui-mfd/img/fts_shutter_60.svg image/svg+xml upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/sani_heating_temp.png widgets/jqui-mfd/img/sani_heating_temp.png image/png upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/materialdesign/img/preview.jpg widgets/materialdesign/img/preview.jpg image/jpeg upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/materialdesign/lib/myUnderscore.js widgets/materialdesign/lib/myUnderscore.js application/javascript upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/metro/img/light_light_dim_70.png widgets/metro/img/light_light_dim_70.png image/png upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/Prev_Carousel.png widgets/swipe/img/Prev_Carousel.png image/png upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/111-3.png widgets/timeandweather/img/clock/111-3.png image/png upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/9-1.png widgets/timeandweather/img/clock/9-1.png image/png upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/clockbg4.png widgets/timeandweather/img/clock/clockbg4.png image/png upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/js/jquery.zweatherfeed.js widgets/timeandweather/js/jquery.zweatherfeed.js application/javascript upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/trashschedule/js/trashschedule.js widgets/trashschedule/js/trashschedule.js application/javascript upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/0_Nav.png widgets/vis-inventwo/img/0_Nav.png image/png upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/Check.gif widgets/vis-inventwo/img/Check.gif image/gif upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/Slider2.gif widgets/vis-inventwo/img/Slider2.gif image/gif upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/ToggleSwitch/switch-1-vert-off-black.png widgets/vis-inventwo/img/ToggleSwitch/switch-1-vert-off-black.png image/png upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/01.png widgets/vis-inventwo/img/clock_analog/01.png image/png upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02/min.png widgets/vis-inventwo/img/clock_analog/02/min.png image/png upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02/sek.png widgets/vis-inventwo/img/clock_analog/02/sek.png image/png upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02/std.png widgets/vis-inventwo/img/clock_analog/02/std.png image/png upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02.png widgets/vis-inventwo/img/clock_analog/02.png image/png upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/min.png widgets/vis-inventwo/img/clock_analog/03/min.png image/png upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/sek.png widgets/vis-inventwo/img/clock_analog/03/sek.png image/png upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/std.png widgets/vis-inventwo/img/clock_analog/03/std.png image/png upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03.png widgets/vis-inventwo/img/clock_analog/03.png image/png upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04/min.png widgets/vis-inventwo/img/clock_analog/04/min.png image/png upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04/sek.png widgets/vis-inventwo/img/clock_analog/04/sek.png image/png upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04/std.png widgets/vis-inventwo/img/clock_analog/04/std.png image/png upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04.png widgets/vis-inventwo/img/clock_analog/04.png image/png upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05/min.png widgets/vis-inventwo/img/clock_analog/05/min.png image/png upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05/sek.png widgets/vis-inventwo/img/clock_analog/05/sek.png image/png upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05/std.png widgets/vis-inventwo/img/clock_analog/05/std.png image/png upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05.png widgets/vis-inventwo/img/clock_analog/05.png image/png upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/frame.png widgets/vis-inventwo/img/clock_analog/frame.png image/png upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/js/iro.min.js widgets/vis-inventwo/js/iro.min.js application/javascript upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/js/vis-inventwo.js widgets/vis-inventwo/js/vis-inventwo.js application/javascript upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo.html widgets/vis-inventwo.html text/html upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript This upgrade of "trashschedule" will introduce the following changes: ========================================================================== -> 1.4.5: Allow spaces in next text seperator -> 1.4.4: Updated dependencies -> 1.4.3: Updated state roles Added hint for Admin 4 configuration -> 1.4.2: Added check for ical configuration ========================================================================== Would you like to upgrade trashschedule from @1.4.1 to @1.4.5 now? [(y)es, (n)o]: y Update trashschedule from @1.4.1 to @1.4.5 NPM version: 6.14.16 Installing iobroker.trashschedule@1.4.5... (System call) Adapter "system.adapter.vis.0" restarted. upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png This upgrade of "tr-064" will introduce the following changes: ========================================================================== -> 4.2.16: Fix info logs on callee/caller Add special handling for potential broken external image links in phonebook Prevent some crash cases reported by Sentry ========================================================================== Would you like to upgrade tr-064 from @4.2.15 to @4.2.16 now? [(y)es, (n)o]: y Update tr-064 from @4.2.15 to @4.2.16 NPM version: 6.14.16 Installing iobroker.tr-064@4.2.16... (System call) upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript This upgrade of "telegram" will introduce the following changes: ========================================================================== -> 1.12.2: Fix crash cases reported by Sentry -> 1.12.0: Add new JSON states communication.responseJson and communication.responseSilentJson to also accept json structures (stringified!) to send messages Try to prevent adapter crashes when internet is not available Add Sentry for crash reporting ========================================================================== Would you like to upgrade telegram from @1.11.1 to @1.12.2 now? [(y)es, (n)o]: y Update telegram from @1.11.1 to @1.12.2 NPM version: 6.14.16 Installing iobroker.telegram@1.12.2... (System call) upload [16] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript upload [15] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom_m.html custom_m.html text/html upload [14] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/de/translations.json i18n/de/translations.json application/json upload [13] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/en/translations.json i18n/en/translations.json application/json upload [12] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/es/translations.json i18n/es/translations.json application/json upload [11] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/fr/translations.json i18n/fr/translations.json application/json upload [10] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/it/translations.json i18n/it/translations.json application/json upload [9] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/nl/translations.json i18n/nl/translations.json application/json upload [8] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/pl/translations.json i18n/pl/translations.json application/json upload [7] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/pt/translations.json i18n/pt/translations.json application/json upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/ru/translations.json i18n/ru/translations.json application/json upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index.html index.html text/html upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index_m.html index_m.html text/html upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript This upgrade of "sonoff" will introduce the following changes: ========================================================================== -> 2.5.0: Implement writing of NSPanel Widget changes Fix crash case reported by Sentry ========================================================================== Would you like to upgrade sonoff from @2.4.7 to @2.5.0 now? [(y)es, (n)o]: y Update sonoff from @2.4.7 to @2.5.0 NPM version: 6.14.16 Installing iobroker.sonoff@2.5.0... (System call) ^C guido@iobroker:/opt/iobroker$@joeysch sagte in ERROR: Process exited with code 25:
^C
guido@iobroker:/opt/iobroker$Du knallst den Prozess weg. Machst du das öfter? Kann nämlich zu solchen Fehlern führen wie du die jetzt hier hast.
^C
Nein, das war ein Strg+C fürs Kopieren, das hatte der nur dazwischen gesetzt.
Das gleiche wie Oben
npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/low.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm ERR! Error while executing: npm ERR! /usr/bin/git ls-remote -h -t ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git npm ERR! npm ERR! git@github.com: Permission denied (publickey). npm ERR! fatal: Could not read from remote repository. npm ERR! npm ERR! Please make sure you have the correct access rights npm ERR! and the repository exists. npm ERR! npm ERR! exited with error code: 128 npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react/css/adapter.css.map' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/M.png' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/M2.png' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.admin- npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/admin' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/plus.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/reload1.png' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/reload2.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/reload3.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/rgb.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/search.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/settings.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/shutdown.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/sleep_no.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/sleep_yes.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/star.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/stop.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/stop2.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/stop3.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/stop4.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/timer.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-04-29T14_27_16_140Z-debug.log -
Nein, das war ein Strg+C fürs Kopieren, das hatte der nur dazwischen gesetzt.
Das gleiche wie Oben
npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/low.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm ERR! Error while executing: npm ERR! /usr/bin/git ls-remote -h -t ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git npm ERR! npm ERR! git@github.com: Permission denied (publickey). npm ERR! fatal: Could not read from remote repository. npm ERR! npm ERR! Please make sure you have the correct access rights npm ERR! and the repository exists. npm ERR! npm ERR! exited with error code: 128 npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react/css/adapter.css.map' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/M.png' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/M2.png' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.admin- npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/admin' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/plus.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/reload1.png' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/reload2.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/reload3.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/rgb.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/search.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/settings.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/shutdown.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/sleep_no.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/sleep_yes.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/star.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/stop.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/stop2.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/stop3.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/stop4.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/timer.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-04-29T14_27_16_140Z-debug.log@joeysch sagte in ERROR: Process exited with code 25:
Strg+C fürs Kopieren
In der bash ist Strg-C ein 'kill den laufenden Prozess'.
Nein, das war ein Strg+C fürs Kopieren, das hatte der nur dazwischen gesetzt.
Das gleiche wie Oben
npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/low.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm ERR! Error while executing: npm ERR! /usr/bin/git ls-remote -h -t ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git npm ERR! npm ERR! git@github.com: Permission denied (publickey). npm ERR! fatal: Could not read from remote repository. npm ERR! npm ERR! Please make sure you have the correct access rights npm ERR! and the repository exists. npm ERR! npm ERR! exited with error code: 128 npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react/css/adapter.css.map' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/M.png' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/M2.png' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.admin- npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/admin' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/plus.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/reload1.png' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/reload2.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/reload3.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/rgb.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/search.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/settings.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/shutdown.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/sleep_no.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/sleep_yes.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/star.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/stop.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/stop2.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/stop3.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/stop4.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/timer.png' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www' npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-04-29T14_27_16_140Z-debug.logMir fällt sonst dazu nix mehr ein.
Platt machen und neu installieren?
Debian oder Ubuntu? -
Musst du wissen.
Ich würde aber statt ubuntu als Server immer ein aktuelles Debian vorziehen. -
Musst du wissen.
Ich würde aber statt ubuntu als Server immer ein aktuelles Debian vorziehen.@thomas-braun
Ich muß dich nochmal belästigen. Ich hab jetzt eine neues System eingerichtet Debian 11 usw. dann das Backup eingespielt.
Jetzt kommt diese Meldung und alle Adapter werden nicht installiert. Kann es sein, ich hatte ja vorher die 16er NPM usw. drauf, das die nicht abwärtskompatible sind und es deshalb nicht funktioniert?[DEBUG] [iobroker] Start ioBroker Restore ... [DEBUG] [iobroker] iobroker controller daemon is not running [DEBUG] [iobroker] host.iobroker2 OK. [DEBUG] [iobroker] The current version of js-controller differs from the version in the backup. [DEBUG] [iobroker] The js-controller version of the backup can not be restored automatically. [DEBUG] [iobroker] Note, that your backup might differ in behavior due to this version change! [DEBUG] [iobroker] Removing current installation of iobroker.admin [DEBUG] [iobroker] removed 4 packages in 9.755s [DEBUG] [iobroker] 170 packages are looking for funding [DEBUG] [iobroker] run `npm fund` for details [DEBUG] [iobroker] Removing current installation of iobroker.backitup [DEBUG] [iobroker] removed 37 packages in 9.537s -
Jetzt kommt diese Meldung und alle Adapter werden nicht installiert. Kann es sein, ich hatte ja vorher die 16er NPM usw. drauf, das die nicht abwärtskompatible sind und es deshalb nicht funktioniert?[DEBUG] [iobroker] Start ioBroker Restore ... [DEBUG] [iobroker] iobroker controller daemon is not running [DEBUG] [iobroker] host.iobroker2 OK. [DEBUG] [iobroker] The current version of js-controller differs from the version in the backup. [DEBUG] [iobroker] The js-controller version of the backup can not be restored automatically. [DEBUG] [iobroker] Note, that your backup might differ in behavior due to this version change! [DEBUG] [iobroker] Removing current installation of iobroker.admin [DEBUG] [iobroker] removed 4 packages in 9.755s [DEBUG] [iobroker] 170 packages are looking for funding [DEBUG] [iobroker] run `npm fund` for details [DEBUG] [iobroker] Removing current installation of iobroker.backitup [DEBUG] [iobroker] removed 37 packages in 9.537s@joeysch sagte in ERROR: Process exited with code 25:
[DEBUG] [iobroker] The js-controller version of the backup can not be restored automatically.Die Version des js-controllers wird hier angemerkt.
Bei npm bzw. dem Format der lock-Files hat sich aber auch von npm6 zu neueren Versionen was getan. Dann installier node16 sauber, vielleicht gibt das dann weniger Schluckauf. -
nein, du hast in der Neuinstallation eine aktuelle Controller version, die wahrscheinlich noch nicht im Backup drin war.
Weiterhin vermutlich auch dadurch jsonl in der neuen und im Backup file als interne Datenbank -
Welche Datenbanktypen hattest du denn im alten js-controller? (Und welche Versionsnummer hatte der?)
wie kann ich das rauskriegen? -
@thomas-braun sagte in ERROR: Process exited with code 25:
iobroker status
guido@iobroker:~$ iobroker status iobroker is running on this host. Objects type: jsonl States type: jsonl guido@iobroker:~$ -
iobroker status
guido@iobroker:~$ iobroker status iobroker is running on this host. Objects type: jsonl States type: jsonl guido@iobroker:~$@joeysch
Der alte Controller könnte file/file gewesen sein, wenn da nichts anderes eingestellt war. -
@joeysch
Der alte Controller könnte file/file gewesen sein, wenn da nichts anderes eingestellt war.@thomas-braun
und kann man das migrieren oder umstellen? -
