  4. ERROR: Process exited with code 25
    5.1k
updateerror
147 Beiträge 11 Kommentatoren 50.2k Aufrufe 10 Beobachtet
  • J joeysch
    Hier mal die Meldungen der letzten Adapter
    Läuft alles problemlos durch, nichts wurde aktualisiert.
    Would you like to upgrade simple-api from @2.6.3 to @2.6.4 now? [(y)es, (n)o]: y
    Update simple-api from @2.6.3 to @2.6.4
    NPM version: 6.14.16
    Installing iobroker.simple-api@2.6.4... (System call)
    upload [13] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [12] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [11] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [10] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [9] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [8] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [7] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [5] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [4] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [3] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
    upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index_m.html index_m.html text/html
    upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
    upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/javascript
    This upgrade of "icons-mfd-svg" will introduce the following changes:
    -> 1.1.0:
    update mfd icons (many new icons)
    Would you like to upgrade icons-mfd-svg from @1.0.2 to @1.1.0 now? [(y)es, (n)o]: y
    Update icons-mfd-svg from @1.0.2 to @1.1.0
    Installing iobroker.icons-mfd-svg@1.1.0... (System call)
    upload [877] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/audio_audio.svg audio_audio.svg image/svg+xml
    upload [850] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/control_3dot_hor_s.svg control_3dot_hor_s.svg image/svg+xml
    upload [800] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/control_building_flat_s_okg_eg.svg control_building_flat_s_okg_eg.svg image/svg+xml
    upload [750] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/control_building_s_eg.svg control_building_s_eg.svg image/svg+xml
    upload [700] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/control_zoom_out.svg control_zoom_out.svg image/svg+xml
    upload [650] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/fts_blade_s_10.svg fts_blade_s_10.svg image/svg+xml
    upload [600] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/fts_garage_door_70.svg fts_garage_door_70.svg image/svg+xml
    upload [550] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/fts_sliding_gate.svg fts_sliding_gate.svg image/svg+xml
    upload [500] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/info_no_state.svg info_no_state.svg image/svg+xml
    upload [450] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/light_indoor_dg.svg light_indoor_dg.svg image/svg+xml
    upload [400] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/light_x-mas_manger.svg light_x-mas_manger.svg image/svg+xml
    upload [350] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/message_caution.svg message_caution.svg image/svg+xml
    upload [300] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/sani_boiler_temp.svg sani_boiler_temp.svg image/svg+xml
    upload [250] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/scene_baby.svg scene_baby.svg image/svg+xml
    upload [200] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/scene_microwave_oven.svg scene_microwave_oven.svg image/svg+xml
    upload [150] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/secur_heat_protection.svg secur_heat_protection.svg image/svg+xml
    upload [100] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/time_calendar.svg time_calendar.svg image/svg+xml
    upload [90] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/user_away.svg user_away.svg image/svg+xml
    upload [80] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/vent_humidifier.svg vent_humidifier.svg image/svg+xml
    upload [70] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/vent_ventilation_level_2.svg vent_ventilation_level_2.svg image/svg+xml
    upload [60] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_directions_no.svg weather_directions_no.svg image/svg+xml
    upload [50] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_humidity.svg weather_humidity.svg image/svg+xml
    upload [40] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_moon_phases_6.svg weather_moon_phases_6.svg image/svg+xml
    upload [30] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_rain_gauge.svg weather_rain_gauge.svg image/svg+xml
    upload [20] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_station_quadra.svg weather_station_quadra.svg image/svg+xml
    upload [19] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_storm.svg weather_storm.svg image/svg+xml
    upload [18] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_summer.svg weather_summer.svg image/svg+xml
    upload [17] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_sun.svg weather_sun.svg image/svg+xml
    upload [16] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_sunrise.svg weather_sunrise.svg image/svg+xml
    upload [15] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_sunset.svg weather_sunset.svg image/svg+xml
    upload [14] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_thunderstorm.svg weather_thunderstorm.svg image/svg+xml
    upload [13] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind.svg weather_wind.svg image/svg+xml
    upload [12] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_directions_e.svg weather_wind_directions_e.svg image/svg+xml
    upload [11] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_directions_n.svg weather_wind_directions_n.svg image/svg+xml
    upload [10] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_directions_ne.svg weather_wind_directions_ne.svg image/svg+xml
    upload [9] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_directions_nw.svg weather_wind_directions_nw.svg image/svg+xml
    upload [8] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_directions_s.svg weather_wind_directions_s.svg image/svg+xml
    upload [7] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_directions_se.svg weather_wind_directions_se.svg image/svg+xml
    upload [6] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_directions_sw.svg weather_wind_directions_sw.svg image/svg+xml
    upload [5] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_directions_w.svg weather_wind_directions_w.svg image/svg+xml
    upload [4] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_no_wind.svg weather_wind_no_wind.svg image/svg+xml
    upload [3] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_speed.svg weather_wind_speed.svg image/svg+xml
    upload [2] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_speed_bft.svg weather_wind_speed_bft.svg image/svg+xml
    upload [1] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_speed_ms.svg weather_wind_speed_ms.svg image/svg+xml
    upload [0] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_winter.svg weather_winter.svg image/svg+xml
    upload [1] icons-mfd-svg.admin /opt/iobroker/node_modules/iobroker.icons-mfd-svg/admin/icons-mfd-svg.png icons-mfd-svg.png image/png
    upload [0] icons-mfd-svg.admin /opt/iobroker/node_modules/iobroker.icons-mfd-svg/admin/index.html index.html text/html
    This upgrade of "discovery" will introduce the following changes:
    -> 3.0.3:
    Fix crash cases reported by Sentry
    -> 3.0.2:
    Updated serialport package
    -> 3.0.1:
    -> 3.0.0:
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade discovery from @2.8.0 to @3.0.3 now? [(y)es, (n)o]: y
    Update discovery from @2.8.0 to @3.0.3
    Installing iobroker.discovery@3.0.3... (System call)
    upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
    upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
    upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
    upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
    upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
    upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
    upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
    This upgrade of "daswetter" will at least introduce the following changes:
    -> 3.1.2:
    some bug fixes
    -> 3.1.0:
    'bent' replaced by 'axios'
    Would you like to upgrade daswetter from @3.0.9 to @3.1.2 now? [(y)es, (n)o]: y
    Update daswetter from @3.0.9 to @3.1.2
    host.iobroker Adapter "system.adapter.daswetter.0" is stopped.
    Installing iobroker.daswetter@3.1.2... (System call)
    upload [479] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/daswettercom.png daswettercom.png image/png
    upload [450] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/luna-moon/8.png icons/luna-moon/8.png image/png
    upload [400] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria3/19.png icons/tiempo-weather/galeria3/19.png image/png
    upload [350] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/PNG/White/1.png icons/tiempo-weather/galeria5/PNG/White/1.png image/png
    upload [300] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/SVG/White/15.svg icons/tiempo-weather/galeria5/SVG/White/15.svg image/svg+xml
    upload [250] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria6/5.png icons/tiempo-weather/galeria6/5.png image/png
    upload [200] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/41.png icons/viento-wind/Beaufort-White/41.png image/png
    upload [150] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/87.png icons/viento-wind/Beaufort-White/87.png image/png
    upload [100] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/104.png icons/viento-wind/galeria2-Beaufort/104.png image/png
    upload [90] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/2.png icons/viento-wind/galeria2-Beaufort/2.png image/png
    upload [80] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/29.png icons/viento-wind/galeria2-Beaufort/29.png image/png
    upload [70] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/38.png icons/viento-wind/galeria2-Beaufort/38.png image/png
    upload [60] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/47.png icons/viento-wind/galeria2-Beaufort/47.png image/png
    upload [50] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/56.png icons/viento-wind/galeria2-Beaufort/56.png image/png
    upload [40] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/65.png icons/viento-wind/galeria2-Beaufort/65.png image/png
    upload [30] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/74.png icons/viento-wind/galeria2-Beaufort/74.png image/png
    upload [20] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/83.png icons/viento-wind/galeria2-Beaufort/83.png image/png
    upload [19] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/84.png icons/viento-wind/galeria2-Beaufort/84.png image/png
    upload [18] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/85.png icons/viento-wind/galeria2-Beaufort/85.png image/png
    upload [17] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/86.png icons/viento-wind/galeria2-Beaufort/86.png image/png
    upload [16] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/87.png icons/viento-wind/galeria2-Beaufort/87.png image/png
    upload [15] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/88.png icons/viento-wind/galeria2-Beaufort/88.png image/png
    upload [14] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/89.png icons/viento-wind/galeria2-Beaufort/89.png image/png
    upload [13] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/9.png icons/viento-wind/galeria2-Beaufort/9.png image/png
    upload [12] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/90.png icons/viento-wind/galeria2-Beaufort/90.png image/png
    upload [11] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/91.png icons/viento-wind/galeria2-Beaufort/91.png image/png
    upload [10] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/92.png icons/viento-wind/galeria2-Beaufort/92.png image/png
    upload [9] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/93.png icons/viento-wind/galeria2-Beaufort/93.png image/png
    upload [8] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/94.png icons/viento-wind/galeria2-Beaufort/94.png image/png
    upload [7] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/95.png icons/viento-wind/galeria2-Beaufort/95.png image/png
    upload [6] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/96.png icons/viento-wind/galeria2-Beaufort/96.png image/png
    upload [5] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/97.png icons/viento-wind/galeria2-Beaufort/97.png image/png
    upload [4] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/98.png icons/viento-wind/galeria2-Beaufort/98.png image/png
    upload [3] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/99.png icons/viento-wind/galeria2-Beaufort/99.png image/png
    upload [2] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/index_m.html index_m.html text/html
    upload [1] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/jsonConfig.json jsonConfig.json application/json
    upload [0] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/words.js words.js application/javascript
    host.iobroker Adapter "system.adapter.daswetter.0" is started
    guido@iobroker:/opt/iobroker$
    @joeysch
    cd /opt/iobroker
    sudo -H -u iobroker npm cache clear --force
    iobroker update -u
    iobroker upgrade
      @joeysch
      cd /opt/iobroker
      iobroker update -u
      iobroker upgrade
      joeysch
      Nochmal?
      • J joeysch
        Nochmal?
        @joeysch
        Ich hab das sudo -H -u iobroker npm cache clear --force nicht gelesen.
        Immer komplette Ein- und Ausgaben posten, dann sieht man auch was da passiert oder auch nicht.
        • J joeysch
          Nochmal?
          @joeysch
          cd /opt/iobroker
          sudo -H -u iobroker npm install iobroker.js-controller
            @joeysch
            joeysch
            Problem ist das der Post nur 100000 Zeichenhaben darf sonst kann ich ihn nicht einstellen.
            So sieht es oben aus:
            guido@iobroker:/opt/iobroker$ iobroker update -u
            Used repository: stable
            Adapter    "daswetter"    : 3.1.2    , installed 3.0.9  [Updatable]
            Adapter    "discovery"    : 3.0.3    , installed 2.8.0  [Updatable]
            Adapter    "icons-mfd-svg": 1.1.0    , installed 1.0.2  [Updatable]
            Controller "js-controller": 4.0.23   , installed 4.0.21 [Updatable]
            Adapter    "simple-api"   : 2.6.4    , installed 2.6.3  [Updatable]
            Adapter    "socketio"     : 4.2.0    , installed 4.1.4  [Updatable]
            Adapter    "sonoff"       : 2.5.0    , installed 2.4.7  [Updatable]
            Adapter    "telegram"     : 1.12.2   , installed 1.11.1 [Updatable]
            Adapter    "tr-064"       : 4.2.16   , installed 4.2.15 [Updatable]
            Adapter    "trashschedule": 1.4.5    , installed 1.4.1  [Updatable]
            Adapter    "vis"          : 1.4.15   , installed 1.4.5  [Updatable]
            Adapter    "vis-hqwidgets": 1.2.0    , installed 1.1.9  [Updatable]
            Adapter    "web"          : 4.2.3    , installed 4.2.0  [Updatable]
            guido@iobroker:/opt/iobroker$ iobroker upgrade
            This upgrade of "web" will introduce the following changes:
            -> 4.2.3:
            Updated ws and socketio to have `log` method in sockets
            -> 4.2.2:
            -> 4.2.1:
            Provide state and object changes for simple-api
            Would you like to upgrade web from @4.2.0 to @4.2.3 now? [(y)es, (n)o]: y
            Update web from @4.2.0 to @4.2.3
            host.iobroker Adapter "system.adapter.web.0" is stopped.
            Installing iobroker.web@4.2.3... (System call)
            upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
            upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
            upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
            upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
            upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
            upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
            upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
            upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
            upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
            upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
            upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
            upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
            upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
            upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
            upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
            upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
            upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
            upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
            upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
            upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
            upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
            upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
            upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
            upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
            upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
            upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
            upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
            upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
            upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
            upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
            upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
            upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
            upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
            upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
            upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
            upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
            upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
            upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
            upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
            upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
            upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
            upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
            upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
            upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.83d9909b.chunk.js static/js/2.83d9909b.chunk.js application/javascript
            upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.83d9909b.chunk.js.LICENSE.txt static/js/2.83d9909b.chunk.js.LICENSE.txt text/plain
            upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.83d9909b.chunk.js.map static/js/2.83d9909b.chunk.js.map application/json
            upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.205b2673.chunk.js static/js/main.205b2673.chunk.js application/javascript
            upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.205b2673.chunk.js.map static/js/main.205b2673.chunk.js.map application/json
            upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.8b37c647.js static/js/runtime-main.8b37c647.js application/javascript
            upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.8b37c647.js.map static/js/runtime-main.8b37c647.js.map application/json
            upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
            upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
            host.iobroker Adapter "system.adapter.web.0" is started
            This upgrade of "vis-hqwidgets" will introduce the following changes:
            -> 1.2.0:
            Removed deprecated method `load`
            Would you like to upgrade vis-hqwidgets from @1.1.9 to @1.2.0 now? [(y)es, (n)o]: y
            Update vis-hqwidgets from @1.1.9 to @1.2.0
            Installing iobroker.vis-hqwidgets@1.2.0... (System call)
            INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
            Adapter "system.adapter.vis.0" restarted.
            upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
            upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
            This upgrade of "vis" will at least introduce the following changes:
            -> 1.4.15:
            Better check of the offline license
            -> 1.4.14:
            Corrected GUI bug
            -> 1.4.13:
            The group attributes will be replaced recursively
            -> 1.4.12:
            Fixed bug with the export of specific widgets
            -> 1.4.11:
            Removed ES6 commands to be supported by older browsers
            Fixed problem with update of grouped widgets
            Added web manifest to be able to handle vis as the web app
            -> 1.4.8:
            Added support for js-controller 4.x
            -> 1.4.7:
            Fixed subscribeOidAtRuntime if called with invalid IDs
            Added support of license manager
            Would you like to upgrade vis from @1.4.5 to @1.4.15 now? [(y)es, (n)o]: y
            Update vis from @1.4.5 to @1.4.15
            Installing iobroker.vis@1.4.15... (System call)
            upload [822] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
            upload [800] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/cancel.png icon/cancel.png image/png
            upload [750] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulb_on.png img/bulb_on.png image/png
            upload [700] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/128/mp3.png js/fm/icon/mine/128/mp3.png image/png
            upload [650] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
            upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/signals/motionColor.png signals/motionColor.png image/png
            upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/micDetected.svg widgets/basic/img/micDetected.svg image/svg+xml
            upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqplot/img/Prev_MeterGauge.png widgets/jqplot/img/Prev_MeterGauge.png image/png
            upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_shutter_60.svg widgets/jqui-mfd/img/fts_shutter_60.svg image/svg+xml
            upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/sani_heating_temp.png widgets/jqui-mfd/img/sani_heating_temp.png image/png
            upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/materialdesign/img/preview.jpg widgets/materialdesign/img/preview.jpg image/jpeg
            upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/materialdesign/lib/myUnderscore.js widgets/materialdesign/lib/myUnderscore.js application/javascript
            upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/metro/img/light_light_dim_70.png widgets/metro/img/light_light_dim_70.png image/png
            upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/Prev_Carousel.png widgets/swipe/img/Prev_Carousel.png image/png
            upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/111-3.png widgets/timeandweather/img/clock/111-3.png image/png
            upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/9-1.png widgets/timeandweather/img/clock/9-1.png image/png
            upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/clockbg4.png widgets/timeandweather/img/clock/clockbg4.png image/png
            upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/js/jquery.zweatherfeed.js widgets/timeandweather/js/jquery.zweatherfeed.js application/javascript
            upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/trashschedule/js/trashschedule.js widgets/trashschedule/js/trashschedule.js application/javascript
            upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/0_Nav.png widgets/vis-inventwo/img/0_Nav.png image/png
            upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/Check.gif widgets/vis-inventwo/img/Check.gif image/gif
            upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/Slider2.gif widgets/vis-inventwo/img/Slider2.gif image/gif
            upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/ToggleSwitch/switch-1-vert-off-black.png widgets/vis-inventwo/img/ToggleSwitch/switch-1-vert-off-black.png image/png
            upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/01.png widgets/vis-inventwo/img/clock_analog/01.png image/png
            upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02/min.png widgets/vis-inventwo/img/clock_analog/02/min.png image/png
            upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02/sek.png widgets/vis-inventwo/img/clock_analog/02/sek.png image/png
            upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02/std.png widgets/vis-inventwo/img/clock_analog/02/std.png image/png
            upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/02.png widgets/vis-inventwo/img/clock_analog/02.png image/png
            upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/min.png widgets/vis-inventwo/img/clock_analog/03/min.png image/png
            upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/sek.png widgets/vis-inventwo/img/clock_analog/03/sek.png image/png
            upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/std.png widgets/vis-inventwo/img/clock_analog/03/std.png image/png
            upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03.png widgets/vis-inventwo/img/clock_analog/03.png image/png
            upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04/min.png widgets/vis-inventwo/img/clock_analog/04/min.png image/png
            upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04/sek.png widgets/vis-inventwo/img/clock_analog/04/sek.png image/png
            upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04/std.png widgets/vis-inventwo/img/clock_analog/04/std.png image/png
            upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/04.png widgets/vis-inventwo/img/clock_analog/04.png image/png
            upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05/min.png widgets/vis-inventwo/img/clock_analog/05/min.png image/png
            upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05/sek.png widgets/vis-inventwo/img/clock_analog/05/sek.png image/png
            upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05/std.png widgets/vis-inventwo/img/clock_analog/05/std.png image/png
            upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/05.png widgets/vis-inventwo/img/clock_analog/05.png image/png
            upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/frame.png widgets/vis-inventwo/img/clock_analog/frame.png image/png
            upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/js/iro.min.js widgets/vis-inventwo/js/iro.min.js application/javascript
            upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/js/vis-inventwo.js widgets/vis-inventwo/js/vis-inventwo.js application/javascript
            upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo.html widgets/vis-inventwo.html text/html
            upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
            upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
            upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
            upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
            This upgrade of "trashschedule" will introduce the following changes:
            -> 1.4.5:
            Allow spaces in next text seperator
            -> 1.4.4:
            Updated dependencies
            -> 1.4.3:
            Updated state roles
            Added hint for Admin 4 configuration
            -> 1.4.2:
            Added check for ical configuration
            Would you like to upgrade trashschedule from @1.4.1 to @1.4.5 now? [(y)es, (n)o]: y
            Update trashschedule from @1.4.1 to @1.4.5
            Installing iobroker.trashschedule@1.4.5... (System call)
            upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
            upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
            This upgrade of "tr-064" will introduce the following changes:
            -> 4.2.16:
            Fix info logs on callee/caller
            Add special handling for potential broken external image links in phonebook
            Prevent some crash cases reported by Sentry
            Would you like to upgrade tr-064 from @4.2.15 to @4.2.16 now? [(y)es, (n)o]: y
            Update tr-064 from @4.2.15 to @4.2.16
            Installing iobroker.tr-064@4.2.16... (System call)
            upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
            upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
            upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
            This upgrade of "telegram" will introduce the following changes:
            -> 1.12.2:
            -> 1.12.0:
            Add new JSON states communication.responseJson and communication.responseSilentJson to also accept json structures (stringified!) to send messages
            Try to prevent adapter crashes when internet is not available
            Add Sentry for crash reporting
            Would you like to upgrade telegram from @1.11.1 to @1.12.2 now? [(y)es, (n)o]: y
            Update telegram from @1.11.1 to @1.12.2
            Installing iobroker.telegram@1.12.2... (System call)
            upload [16] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
            upload [15] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom_m.html custom_m.html text/html
            upload [14] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [13] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [12] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [11] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [10] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [9] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [8] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [7] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index.html index.html text/html
            upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index_m.html index_m.html text/html
            upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
            upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
            upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
            This upgrade of "sonoff" will introduce the following changes:
            -> 2.5.0:
            Implement writing of NSPanel Widget changes
            Fix crash case reported by Sentry
            Would you like to upgrade sonoff from @2.4.7 to @2.5.0 now? [(y)es, (n)o]: y
            Update sonoff from @2.4.7 to @2.5.0
            Installing iobroker.sonoff@2.5.0... (System call)
            ^C
            • J joeysch
              -> 4.2.3:
              -> 4.2.2:
              -> 4.2.1:
              -> 1.2.0:
              -> 1.4.15:
              -> 1.4.14:
              Corrected GUI bug
              -> 1.4.13:
              -> 1.4.12:
              -> 1.4.11:
              -> 1.4.8:
              -> 1.4.7:
              -> 1.4.5:
              -> 1.4.4:
              -> 1.4.3:
              Updated state roles
              -> 1.4.2:
              -> 4.2.16:
              -> 1.12.2:
              -> 1.12.0:
              -> 2.5.0:
              ^C
              @joeysch sagte in ERROR: Process exited with code 25:
              ^C
              Du knallst den Prozess weg. Machst du das öfter? Kann nämlich zu solchen Fehlern führen wie du die jetzt hier hast.
                ^C
                joeysch
                Nein, das war ein Strg+C fürs Kopieren, das hatte der nur dazwischen gesetzt.
                Das gleiche wie Oben
                npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www'
                npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/low.png'
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                npm ERR! Error while executing:
                npm ERR! /usr/bin/git ls-remote -h -t ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
                npm ERR!
                npm ERR! git@github.com: Permission denied (publickey).
                npm ERR! fatal: Could not read from remote repository.
                npm ERR!
                npm ERR! Please make sure you have the correct access rights
                npm ERR! and the repository exists.
                npm ERR!
                npm ERR! exited with error code: 128
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www-react/css/adapter.css.map'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/M.png'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/M2.png'
                npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/docs'
                npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/admin'
                npm WARN tar ENOENT: no such file or directory, lstat '/opt/iobroker/node_modules/.staging/iobroker.admin-9fa75f19/www'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/plus.png'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/reload1.png'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/reload2.png'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/reload3.png'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/rgb.png'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/search.png'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/settings.png'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/shutdown.png'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/sleep_no.png'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/sleep_yes.png'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/star.png'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/stop.png'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/stop2.png'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/stop3.png'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/stop4.png'
                npm WARN tar ENOENT: no such file or directory, open '/opt/iobroker/node_modules/.staging/iobroker.vis-icontwo-0d266445/www/Misc/timer.png'
                npm ERR!     /home/iobroker/.npm/_logs/2022-04-29T14_27_16_140Z-debug.log
                • J joeysch
                  npm ERR!
                  npm ERR!
                  npm ERR!
                  In der bash ist Strg-C ein 'kill den laufenden Prozess'.
                  • J joeysch
                    npm ERR!
                    npm ERR!
                    npm ERR!
                    @joeysch
                    Mir fällt sonst dazu nix mehr ein.
                      @joeysch
                      joeysch
                      Platt machen und neu installieren?
                      Debian oder Ubuntu?
                      • Thomas BraunT Online
                        @joeysch
                        Musst du wissen.
                        Ich würde aber statt ubuntu als Server immer ein aktuelles Debian vorziehen.
                          @joeysch
                          Musst du wissen.
                          joeysch
                          Ich muß dich nochmal belästigen. Ich hab jetzt eine neues System eingerichtet Debian 11 usw. dann das Backup eingespielt.
                          Jetzt kommt diese Meldung und alle Adapter werden nicht installiert. Kann es sein, ich hatte ja vorher die 16er NPM usw. drauf, das die nicht abwärtskompatible sind und es deshalb nicht funktioniert?
                          [DEBUG] [iobroker] Start ioBroker Restore ...
                          [DEBUG] [iobroker] iobroker controller daemon is not running
                          [DEBUG] [iobroker] host.iobroker2 OK.
                          [DEBUG] [iobroker] The current version of js-controller differs from the version in the backup.
                          [DEBUG] [iobroker] The js-controller version of the backup can not be restored automatically.
                          [DEBUG] [iobroker] Note, that your backup might differ in behavior due to this version change!
                          [DEBUG] [iobroker] Removing current installation of iobroker.admin
                          [DEBUG] [iobroker] removed 4 packages in 9.755s
                          [DEBUG] [iobroker] 170 packages are looking for funding
                          [DEBUG] [iobroker] run `npm fund` for details
                          [DEBUG] [iobroker] Removing current installation of iobroker.backitup
                          [DEBUG] [iobroker] removed 37 packages in 9.537s
                          • J joeysch
                            Die Version des js-controllers wird hier angemerkt.
                            Bei npm bzw. dem Format der lock-Files hat sich aber auch von npm6 zu neueren Versionen was getan. Dann installier node16 sauber, vielleicht gibt das dann weniger Schluckauf.
                            • J joeysch
                              HomoranH Offline
                              HomoranH Offline
                              nein, du hast in der Neuinstallation eine aktuelle Controller version, die wahrscheinlich noch nicht im Backup drin war.
                              Weiterhin vermutlich auch dadurch jsonl in der neuen und im Backup file als interne Datenbank
                                joeysch
                                und wie krieg ich das jetzt zum laufen?
                                • J joeysch
                                  @joeysch
                                  Welche Datenbanktypen hattest du denn im alten js-controller? (Und welche Versionsnummer hatte der?)
                                    @joeysch
                                    joeysch
                                    wie kann ich das rauskriegen?
                                    • J joeysch
                                      @joeysch
                                      iobroker status
                                      spuckt das für den laufenden Controller aus.
                                        @joeysch
                                        iobroker status
                                        joeysch
                                        #66
                                        @thomas-braun sagte in ERROR: Process exited with code 25:
                                        iobroker status
                                        guido@iobroker:~$ iobroker status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        guido@iobroker:~$
                                        • J joeysch
                                          iobroker status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          guido@iobroker:~$
                                          #67
                                          @joeysch
                                          Der alte Controller könnte file/file gewesen sein, wenn da nichts anderes eingestellt war.
