  3. Einsteigerfragen
  4. ioBroker kaputt "gerettet"
    5.6k
66 Beiträge 7 Kommentatoren 7.8k Aufrufe 5 Beobachtet
    @heavyd sagte in ioBroker kaputt "gerettet":
    cb.apply is not a function
    Die Meldung hab ich noch nie gesehen...
    Schau dir nodeJS an:
    which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    HeavyDH Offline
    HeavyDH Offline
    HeavyD
    HeavyD@heavydpi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
    HeavyD@heavydpi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v14.19.1
    v14.19.1
    4.6.1
    HeavyD
    /home/HeavyD
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
    Reading package lists... Done
    All packages are up to date.
    nodejs:
      Installed: 14.19.1-deb-1nodesource1
      Candidate: 14.19.1-deb-1nodesource1
      Version table:
     *** 14.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    HeavyD@heavydpi:~ $
    • HeavyDH HeavyD
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v14.19.1
      v14.19.1
      4.6.1
      HeavyD
      /home/HeavyD
      nodejs:
        Version table:
      HeavyD@heavydpi:~ $
      4.6.1
      Wie kommt man zu einer npm -v 4.6.1?
      Die passt nicht zu node14.
      apt policy npm
      sudo apt remove npm
      sudo apt install --reinstall nodejs
      HeavyDH 1 Antwort Letzte Antwort
        4.6.1
        apt policy npm
        sudo apt remove npm
        HeavyDH Offline
        HeavyDH Offline
        HeavyD
        @thomas-braun keine Ahnung! :man-shrugging:
        HeavyD@heavydpi:~ $ apt policy npm
        npm:
          Installed: (none)
          Candidate: 7.5.2+ds-2
          Version table:
             7.5.2+ds-2 500
                500 http://deb.debian.org/debian bullseye/main armhf Packages
        HeavyD@heavydpi:~ $ sudo apt remove npm
        Package 'npm' is not installed, so not removed
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        HeavyD@heavydpi:~ $ sudo apt install --reinstall nodejs
        0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
        Need to get 0 B/24.8 MB of archives.
        After this operation, 0 B of additional disk space will be used.
        (Reading database ... 48496 files and directories currently installed.)
        Preparing to unpack .../nodejs_14.19.1-deb-1nodesource1_arm64.deb ...
        Unpacking nodejs (14.19.1-deb-1nodesource1) over (14.19.1-deb-1nodesource1) ...
        Setting up nodejs (14.19.1-deb-1nodesource1) ...
        Processing triggers for man-db (2.9.4-2) ...
        HeavyD@heavydpi:~ $ iobroker fix
        library: loaded
        Library version=2022-02-10
        ioBroker is not installed in /opt/iobroker! Cannot fix anything...
        HeavyD@heavydpi:~ $ cd /opt/iobroker
        HeavyD@heavydpi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
        > iobroker.js-controller@4.0.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.16
        > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram
        > node-gyp rebuild
        make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
          CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
        In file included from ../../nan/nan.h:58,
                         from ../src/unix_dgram.cc:5:
        /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
          793 |       (node::addon_register_func) (regfunc),                          \
        /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
          827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
          404 | NODE_MODULE(unix_dgram, Initialize)
          SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
          COPY Release/unix_dgram.node
        make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
        > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
        > node rebuild.js
        ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
        > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
        > node-gyp rebuild
        make: Entering directory '/opt/iobroker/node_modules/diskusage/build'
          CXX(target) Release/obj.target/diskusage/src/main.o
                         from ../src/main.cpp:3:
        ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
           42 | NODE_MODULE(diskusage, Init)
          CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
          SOLINK_MODULE(target) Release/obj.target/diskusage.node
          COPY Release/diskusage.node
        make: Leaving directory '/opt/iobroker/node_modules/diskusage/build'
        > iobroker.js-controller@4.0.21 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        Successfully migrated 4344 objects to Redis Sets
        object _design/system updated
          "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\nEzQOwj4NxN8zwMKGJvzzqzDUYOh5g2eFq3C0gG8okyUH2odgNkvT\r\n-----END RSA PRIVATE KEY-----\r\n",
          "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\nMmyghqIkV4NjDcIDUIWSfgSpKF4hKS4/whMSRzq3VHVeBw==\r\n-----END CERTIFICATE-----\r\n"
        Update certificate defaultPrivate
        The object "system.certificates" was updated successfully.
        Update certificate defaultPublic
        > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
        > node scripts/postinstall
        > esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild
        > node install.js
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
        + iobroker.js-controller@4.0.21
        added 225 packages from 182 contributors in 170.509s
        49 packages are looking for funding
          run `npm fund` for details
        HeavyD@heavydpi:/opt/iobroker $ iobroker update -i
        internal/modules/cjs/loader.js:905
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
            at Function.Module._load (internal/modules/cjs/loader.js:746:27)
            at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
            at internal/main/run_main_module.js:17:47 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
        • HeavyDH HeavyD
          npm:
            Installed: (none)
            Version table:
               7.5.2+ds-2 500
          library: loaded
          > node-gyp rebuild
          > node rebuild.js
          > node-gyp rebuild
          > node install.js
            throw err;
            requireStack: []
          @heavyd
          Ich muss jetzt nochmal
          frisch sehen.
            @heavyd
            frisch sehen.
            HeavyDH Offline
            HeavyDH Offline
            HeavyD
            HeavyD@heavydpi:/opt/iobroker $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v14.19.1
            v14.19.1
            6.14.16
            HeavyD
            /opt/iobroker
            Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
            nodejs:
              Version table:
            • HeavyDH HeavyD
              Hi, ich bin Neuling bei ioBroker.
              Hab ihn mir gestern auf einem PI aufgesetzt und ein paar Adapter installiert zum Testen. Funktionierte alles soweit.
              Das ganze fand in einem "Test-LAN" statt.
              In meinem eigenen LAN (Fritzbox 7490AX, feste IP für den PI) konnte ich nicht auf das Webif zugreifen (http://ip-iobroker:8081).
              Hab dann über die Konsole diverse "Rettungsversuche" gamacht, aber jetzt listet mir "iobroker list instances" folgendes:
              Ist da noch was zu retten?
              Jan1
              Hm und warum eierst jetzt so lange mit nem Rettungsversuch rum und machst das Bisschen nicht einfach noch mal neu und sauber?
              Node und NPM sieht zumindest mal wieder vernünftig aus.
              • J Jan1
                HeavyDH Offline
                HeavyDH Offline
                HeavyD
                @jan1 ich hab ja nur gefragt ob da noch was zu retten ist? Wenn es halt zu aufwendig ist mach ich es neu.
                • Thomas BraunT Online
                  @heavyd
                  cd /opt/iobroker
                  iobroker start
                  iobroker status
                    @heavyd
                    cd /opt/iobroker
                    iobroker start
                    iobroker status
                    HeavyDH Offline
                    HeavyDH Offline
                    HeavyD
                    HeavyD@heavydpi:/opt/iobroker $ iobroker start
                    HeavyD@heavydpi:/opt/iobroker $ iobroker status
                    Objects type: jsonl
                    States  type: jsonl
                    • HeavyDH HeavyD
                      Objects type: jsonl
                      States  type: jsonl
                      Gut.
                      R 1 Antwort Letzte Antwort
                      • HeavyDH HeavyD
                        Jan1
                        @heavyd
                        Wenn man eh am Anfang steht, ist das eben am einfachsten und schneller gehts auch. Retten würde auch klappen und lernen wirst auch was dabei. Bleibt Dir überlassen. Die Frage ist immer nur, was hast noch so verbastelt und wird sich das später noch bemerkbar machen.
                          Gut.
                          rotamint
                          @thomas-braun @HeavyD Als stiller lerndender Mitleser - dankeschön, wieder was gelernt!
                            subman82
                            ich habe wohl ähnliche Probleme wie mein Vorgänger aber leider wurden meine mit dem letzten Schritt nicht gelöst. Ich komme nicht auf die Adminseite meines iobroker.
                            Ich versuche mal den Codetag hier anzuwenden,ich hoffe es funktioniert,ist mein erster Versuch....
                            aktuell:
                            Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
                            pi@raspberrypi:~ $ npm -v
                            6.14.17
                            pi@raspberrypi:~ $ node -v
                            v14.20.0
                            Ergebnis des letzten Schrittes deiner Anleitung:
                            pi@raspberrypi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
                            npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                            npm WARN checkPermissions Missing write access to /home/pi
                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                            npm WARN pi No description
                            npm WARN pi No repository field.
                            npm WARN pi No license field.
                            npm ERR! code EACCES
                            npm ERR! syscall access
                            npm ERR! path /home/pi
                            npm ERR! errno -13
                            npm ERR! Error: EACCES: permission denied, access '/home/pi'
                            npm ERR!  [Error: EACCES: permission denied, access '/home/pi'] {
                            npm ERR!   errno: -13,
                            npm ERR!   code: 'EACCES',
                            npm ERR!   syscall: 'access',
                            npm ERR!   path: '/home/pi'
                            npm ERR! }
                            npm ERR!
                            npm ERR! The operation was rejected by your operating system.
                            npm ERR! It is likely you do not have the permissions to access this file as the current user
                            npm ERR!
                            npm ERR! If you believe this might be a permissions issue, please double-check the
                            npm ERR! permissions of the file and its containing directories, or try running
                            npm ERR! the command again as root/Administrator.
                            npm ERR!     /home/iobroker/.npm/_logs/2022-09-10T22_20_09_875Z-debug.log
                            pi@raspberrypi:~ $ iobroker start
                            pi@raspberrypi:~ $ iobroker status
                              throw err;
                              requireStack: []
                            Es lief soweit alles stabil bis ich ein node update durchgeführt habe von v14 auf v16. npm war meine ich 8.1.5 als noch alles lief.
                            Ich wollte eigentlich nur den Shellyadapter updaten aber dafür musste ich Updates vom System durchführen.
                            Das hat auch ungefähr 10min funktioniert , alle Instanzen waren auch auch grün und dann wollte ich den Shellyadapter
                            updaten und seit dem komme ich nicht mehr auf die Benutzeroberfläche.
                            Wie oben dargestellt , habe ich aktuell node auf 14.20.0 und npm 6.14.17 zurückgestellt aber das half noch nicht.
                            Ich sitz hier schon 5 Stunden dran und komm nicht weiter.Ich hoffe ihr könnt mir helfen,.
                            Besten Dank vorab,Gruss Peter
                            • S subman82
                              aktuell:
                              6.14.17
                              v14.20.0
                              npm ERR! errno -13
                              npm ERR! }
                              npm ERR!
                              npm ERR!
                                throw err;
                                requireStack: []
                              @subman82 sagte in ioBroker kaputt "gerettet":
                              Du stehst im falschen Verzeichnis.
                              cd /opt/iobroker
                              Und wie bist du da nun grundsätzlich unterwegs?
                              uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              anschauen.
                                cd /opt/iobroker
                                anschauen.
                                subman82
                                Moin und danke für die schnelle Rückmeldung.
                                Ich glaub das mit dem falschem Verzeichnis liegt daran , wenn man keine Ahnung hat und aus allen Posts etwas versucht um es zu retten....Schande über mein Haupt. Ich könnte mir auch vorstellen, dass die Versionen von nodejs,node und npm nicht kompatibel sind. Ich habe immer regelmässig upgedatet aber diesmal ist was schief gelaufen:/
                                pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                                pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                armv7l
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v14.20.0
                                v14.20.0
                                6.14.17
                                pi
                                /home/pi
                                Danke für deine Mühe!!
                                • S subman82
                                  armv7l
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v14.20.0
                                  v14.20.0
                                  6.14.17
                                  pi
                                  /home/pi
                                  Vermutlich ewig keine Updates mehr eingespielt.
                                    subman82
                                    Ich schaue wirklich regelmässig nach Updates,ich würde sagen mindestens einmal im Monat.
                                    Ich habe in den Adaptern und unter der Benutzeroberfläche unter Info immer kontrolliert dass alles aktuell ist, vielleicht habe ich aus Unwissenheit etwas vergessen?Bisher hab ich immer node.js und js-controller über Putty upgedatet meine ich . Node ist ebefalls ein separates Programm habe ich jetzt festgestellt. Ich schau später nochmal nach einer Anleitung, wie ich es zukünftig richtig mache.
                                    pi@raspberrypi:~ $ sudo apt update && apt policy nodejs
                                    OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                    OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                    OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                                    Aktualisierung für 9 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                    nodejs:
                                      Installiert:           14.20.0-deb-1nodesource1
                                      Installationskandidat: 14.20.0-deb-1nodesource1
                                      Versionstabelle:
                                     *** 14.20.0-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                         10.24.0~dfsg-1~deb10u1 500
                                    Thomas BraunT S 2 Antworten Letzte Antwort
                                    • S subman82
                                      nodejs:
                                        Versionstabelle:
                                      Aktualisier das System.
                                      Und wo klemmt es denn nun konkret?
                                      • S subman82
                                        nodejs:
                                          Versionstabelle:
                                        subman82
                                        @subman82 Die jetzt installierten Versionen habe ich nur installiert, weil ich gehofft hatte dass mit den alten Versionen es wieder laufen würde und ich könnte dann neu updaten.
                                        • S subman82
                                          @subman82
                                          Und konkret bedeutet das? Läuft der iobroker? Wenn nicht, mit welchen Meldungen?
