  4. Zigbee: Sensor meldet sich doppelt an
    6.0k
21 Beiträge 3 Kommentatoren 946 Aufrufe 3 Beobachtet
  • 1Topf1 1Topf
    @arteck
    Es ist der xxxaf85. Sieht ja ganz normal aus.
    2022-04-08 09:17:56.153 - info: host.ioBroker "system.adapter.zigbee.0" enabled
    2022-04-08 09:17:56.467 - info: host.ioBroker instance system.adapter.zigbee.0 started with pid 3830533
    2022-04-08 09:18:04.207 - info: zigbee.0 (3830533) starting. Version 1.6.16 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.21
    2022-04-08 09:18:04.429 - info: zigbee.0 (3830533) Starting Zigbee npm ...
    2022-04-08 09:18:05.958 - info: zigbee.0 (3830533) Installed Version: ioBroker/ioBroker.zigbee
    2022-04-08 09:18:06.232 - info: zigbee.0 (3830533) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200327}}
    2022-04-08 09:18:06.245 - info: zigbee.0 (3830533) Unable to disable LED, unsupported function.
    2022-04-08 09:18:06.279 - info: zigbee.0 (3830533) --> transmitPower : high
    2022-04-08 09:18:06.313 - info: zigbee.0 (3830533) Currently 33 devices are joined:
    2022-04-08 09:18:06.492 - info: zigbee.0 (3830533) Configuring 0x804b50fffe1a44e6 TS0201
    2022-04-08 09:18:06.499 - info: zigbee.0 (3830533) 0x00158d0006ba28d7 (addr 11029): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
    2022-04-08 09:18:06.522 - info: zigbee.0 (3830533) 0x84182600000e1874 (addr 58066): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
    2022-04-08 09:18:06.527 - info: zigbee.0 (3830533) 0x804b50fffe3f39a9 (addr 41713): ZL1000400-CCT-EU-2-V1A02 - Linkind Zigbee LED 5.4W C35 bulb E14, dimmable & tunable (Router)
    2022-04-08 09:18:06.531 - info: zigbee.0 (3830533) 0x7cb03eaa0a04dd64 (addr 34216): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
    2022-04-08 09:18:06.535 - info: zigbee.0 (3830533) 0x00158d00031e8abe (addr 11766): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2022-04-08 09:18:06.538 - info: zigbee.0 (3830533) 0x84182600000efdf2 (addr 55051): AB3257001NJ - OSRAM Smart+ plug (Router)
    2022-04-08 09:18:06.542 - info: zigbee.0 (3830533) 0x804b50fffe1a44e6 (addr 14093): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
    2022-04-08 09:18:06.545 - info: zigbee.0 (3830533) 0x84182600000ee911 (addr 26846): AB3257001NJ - OSRAM Smart+ plug (Router)
    2022-04-08 09:18:06.548 - info: zigbee.0 (3830533) 0xec1bbdfffedf6d32 (addr 12424): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
    2022-04-08 09:18:06.553 - info: zigbee.0 (3830533) 0xbc33acfffed6aa00 (addr 13393): HG06338 - Lidl Silvercrest 3 gang switch, with 4 USB (EU, FR, CZ, BS) (Router)
    2022-04-08 09:18:06.557 - info: zigbee.0 (3830533) 0x00158d0002772b63 (addr 13091): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2022-04-08 09:18:06.561 - info: zigbee.0 (3830533) 0x00158d000241af85 (addr 61936): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
    2022-04-08 09:18:06.564 - info: zigbee.0 (3830533) 0x842e14fffe5ad499 (addr 51975): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
    2022-04-08 09:18:06.567 - info: zigbee.0 (3830533) 0x00124b0018ed130a (addr 41819): CC2530.ROUTER - Custom devices (DiY) [CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/) (Router)
    2022-04-08 09:18:06.572 - info: zigbee.0 (3830533) 0x7cb03eaa0a06863e (addr 65493): AB3257001NJ - OSRAM Smart+ plug (Router)
    2022-04-08 09:18:06.576 - info: zigbee.0 (3830533) 0x00158d0002741e28 (addr 59443): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2022-04-08 09:18:06.579 - info: zigbee.0 (3830533) 0x00158d0006ba1d92 (addr 40): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
    2022-04-08 09:18:06.583 - info: zigbee.0 (3830533) 0xbc33acfffed75554 (addr 58963): HG06338 - Lidl Silvercrest 3 gang switch, with 4 USB (EU, FR, CZ, BS) (Router)
    2022-04-08 09:18:06.586 - info: zigbee.0 (3830533) 0x00158d0001c9edc1 (addr 14147): RB 175 W - Innr E27 bulb warm dimming (Router)
    2022-04-08 09:18:06.590 - info: zigbee.0 (3830533) 0x7cb03eaa00a95ddc (addr 11554): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
    2022-04-08 09:18:06.593 - info: zigbee.0 (3830533) 0x7cb03eaa0a05a22c (addr 40785): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
    2022-04-08 09:18:06.598 - info: zigbee.0 (3830533) 0x60a423fffea0d336 (addr 52644): TS0601_thermostat - TuYa Radiator valve with thermostat (EndDevice)
    2022-04-08 09:18:06.629 - info: zigbee.0 (3830533) 0x000d6f00123bcc51 (addr 49287): AC0251100NJ/AC0251600NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
    2022-04-08 09:18:06.633 - info: zigbee.0 (3830533) 0x00158d0002754c27 (addr 5906): HS3SA - HEIMAN Smoke detector (EndDevice)
    2022-04-08 09:18:06.636 - info: zigbee.0 (3830533) 0xec1bbdfffe8d338a (addr 4458): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
    2022-04-08 09:18:06.639 - info: zigbee.0 (3830533) 0x00158d0002090194 (addr 34826): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
    2022-04-08 09:18:06.640 - info: zigbee.0 (3830533) 0x000d6f0016195803 (addr 54022): Not supported (model ColorDimmerSw-EM-3.0)(EndDevice)
    2022-04-08 09:18:06.641 - info: zigbee.0 (3830533) 0x00158d0006c4adb2 (addr 34455): Not supported (model ColorLight)(Router)
    2022-04-08 09:18:06.645 - info: zigbee.0 (3830533) 0x804b50fffe3f3b93 (addr 17063): ZL1000400-CCT-EU-2-V1A02 - Linkind Zigbee LED 5.4W C35 bulb E14, dimmable & tunable (Router)
    2022-04-08 09:18:06.648 - info: zigbee.0 (3830533) 0x00158d00027746e5 (addr 17844): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2022-04-08 09:18:06.656 - info: zigbee.0 (3830533) 0x7cb03eaa00aed498 (addr 35069): AB3257001NJ - OSRAM Smart+ plug (Router)
    2022-04-08 09:18:06.658 - info: zigbee.0 (3830533) 0x00124b0018e1cd13 (addr 3464): CC2530.ROUTER - Custom devices (DiY) [CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/) (Router)
    2022-04-08 09:18:06.661 - info: zigbee.0 (3830533) 0x00124b0024ca825e (addr 15336): ti.router - Custom devices (DiY) Texas Instruments router (Router)
    2022-04-08 09:18:06.663 - info: zigbee.0 (3830533) Zigbee started
    2022-04-08 09:18:06.842 - info: zigbee.0 (3830533) debug devices set to []
    2022-04-08 09:18:07.647 - error: zigbee.0 (3830533) Device 0x000d6f0016195803 "ColorDimmerSw-EM-3.0" not described in statesMapping.
    2022-04-08 09:18:07.658 - error: zigbee.0 (3830533) Device 0x00158d0006c4adb2 "ColorLight" not described in statesMapping.
    2022-04-08 09:18:27.103 - warn: zigbee.0 (3830533) DeviceConfigure:DeviceConfigure failed 0x804b50fffe1a44e6 TS0201, attempt 1 (Error: Read 0x804b50fffe1a44e6/1 genBasic(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
    at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:414:23)
    at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32))
    2022-04-08 09:18:29.282 - warn: zigbee.0 (3830533) DeviceAvailability:Failed to ping 0x00158d0006c4adb2 ColorLight
    2022-04-08 09:18:30.544 - warn: zigbee.0 (3830533) DeviceAvailability:Failed to ping 0x84182600000efdf2 Plug 01
    2022-04-08 09:18:47.886 - warn: zigbee.0 (3830533) DeviceAvailability:Failed to ping 0x7cb03eaa0a05a22c Classic A60 W clear - LIGHTIFY
    Da fällt mir gleich noch was ein: was mich ein wenig stört ist der TS0201 / xxx44e6. Der ist baugleich mit xxx6d32, nur von einem anderen "Hersteller". Vom xxx44e6 wird aber keine Spannung angezeigt. Im Log wird er ja auch mit warn angezeigt.
    Andi
    arteckA Offline
    arteckA Offline
    arteck
    @1topf sagte in Zigbee: Sensor meldet sich doppelt an:
    af85
    der ist doch nur einmal drin
    im ernst.. nur weil es 4 Räder hat und ein Lenkrad ist es immer ein Porsche ??
    die Teile sehen fast alle gleich aus.. die Firmware ist der unterschied..
    1Topf1 1 Antwort Letzte Antwort
    • arteckA arteck
      af85
      1Topf1 Offline
      1Topf1 Offline
      1Topf
      @arteck sagte in Zigbee: Sensor meldet sich doppelt an:
      Ja, aber wie du ganz oben in meinem ersten Beitrag siehst, meldet er sich doppelt. Und die Kachel bleibt ein Fragezeichen. DU wolltest das Startlog haben. 😁
      Hauptsache Heckantrieb. 😀 😀
      Nee, mal ernsthaft. Ich weiß nicht genau, ob der die Spannung jemals angezeigt hat. Ich weiß aber, daß in früheren Adapterversionen nie eine warn - Meldung ausgegeben wurde. Kann es jetzt aber nicht mehr nachvollziehen.
      • 1Topf1 1Topf
        @arteck
        Andi
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        Bitte prüfen:
        wie melden sich die beiden Geräte auf der Info Kachel - insbesondere interessant ist die "manufacturer_info". Da es sich um TuYa Geräte handelt wird da irgendetwas wie "__TZE200_asgsrges" stehen. In den meisten Fällen beschreibt der vordere Teil (_TZE200) die Hardware und der hintere Teil die Firmware. Selbst bei identischer Hardware liefern unterschiedliche Firmwarestände unterschiedliche Datenpunkte.
        Und nein - ein Austausch der Firmware ist nicht "mal eben so" gemacht.
        Auch bei dem Sensor der mit einem ? dargestellt wird ist interessant wie die Info Kachel aussieht.. bitte posten.
        A.
        • AsgothianA Asgothian
          Bitte prüfen:
          A.
          1Topf1 Offline
          1Topf1 Offline
          1Topf
          schrieb am zuletzt editiert von 1Topf
          @asgothian
          Erstmal das ?. ℹ steht bereits ganz oben im ersten Beitrag.
          Nun zu den anderen, TS0201.
          Der Sensor mit Voltanzeige ist von Blitzwolf:
          ℹ :
              model:TS0201
              description:Temperature & humidity sensor with display
              modelZigbee:TS0201
              type:EndDevice
              nwk:12424
              manuf id:4098
              manufacturer:_TYZB01_hjsgdkfl
              power:Battery
              app version:65
              hard version:1
              zcl version:3
              stack version:0
              date code:
              interviewed:true
              configured:false
              endpoint:1
              profile:260
              input clusters:genBasic (0)
              genPowerCfg (1)
              msTemperatureMeasurement (1026)
              msRelativeHumidity (1029)
              output clusters:genOta (25)
          Von wem der Sensor ohne Voltanzeige ist weiß ich nicht, hab die Verpackung nicht mehr:
          ℹ :
              model:TS0201
              modelZigbee:TS0201
              type:EndDevice
              nwk:14093
              manuf id:4098
              manufacturer:_TZ2000_a476raq2
              power:Battery
              app version:72
              hard version:1
              zcl version:3
              stack version:0
              date code:
              interviewed:true
              configured:false
              endpoint:1
              profile:260
              genPowerCfg (1)
              genTime (10)
          Da die Geräte grundsätzlich funktionieren, sind das "Luxusprobleme". Wenn es keine Lösung gibt, kann ich damit leben 😊 . Beim Gerät mit Fragezeichen ist nur doof, daß man keinen Namen vergeben kann. Ich hab den zwar manuell in den Objekten eingetragen, der taucht aber z.B. in VIS (wenn man ihn auswählen will) nicht auf. Also der Name steht nicht dort, daß Gerät schon.
          Andi
          Edit: Hab gerade bissl in den Objekten rumgespielt. Für das "Fragezeichen" war kein Typ hinterlegt. Habe "Device" eingetragen, nun wird die Kachel korrekt angezeigt. 😳
          • arteckA Offline
            arteckA Offline
            arteck
            @1Topf kannst du bitte ganz stupide auf das I kliken und die Kachel posten wie die kommt.. und nicht den Text rauskopieren
            • arteckA arteck
              1Topf1 Offline
              1Topf1 Offline
              1Topf
              @arteck
              • 1Topf1 1Topf
                @arteck
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @1topf
                Die beiden TS0201 sind nicht identisch:_
                Hoftür hat die Herstellerkennung _TZ2000_a476raq2
                Kellergang hat die Herstellerkennung _TYZB01_hjsgdkfl
                Damit mag die Hardware gleich sein, die Firmware ist es nicht - daher das unterschiedliche Verhalten.
                Willkommen in dem Wahnsinn der sich TuYa nennt.
                A.
                  @1topf
                  A.
                  1Topf1 Offline
                  1Topf1 Offline
                  1Topf
                  @asgothian
                  Ja, hatte oben schon geschrieben, daß "Kellergang" ein Blitzwolf ist (BW-IS4) und ich es von "Hoftür" nicht mehr weiß, da ich keine Verpackung mehr habe. Wie gesagt, Luxusproblem, muß ich den Batteriestatus eben immer direkt am Gerät ablesen.
                  Was ich mich aber immer noch frage: wieso meldet sich dieser andere Sensor (also das ursprüngliche Threadthema) beim anlernen doppelt an und wieso erscheint die Kachel richtig (kein Fragezeichen mehr), nachdem ich in den Objekten den Typ auf "Device" gesetzt habe.?.
                  • 1Topf1 1Topf
                    @asgothian
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    Auf die erste Frage habe ich keine Antwort. Die zweite Frage lässt sich eindeutig beantworten - wenn das Gerät falsch in den Objekten angelegt wird werden nicht alle Parameter korrekt gesetzt. Das anpassen des States auf "Device" hat das gefixed. Alternativ hättest du das Objekt auch im Baum löschen können und der Adapter sollte den korrekt wieder anlegen.
                    A.
                      A.
                      1Topf1 Offline
                      1Topf1 Offline
                      1Topf
                      @asgothian OK, weiß ich bescheid, wenn das wieder mal passiert. Danke. 👍
                      • 1Topf1 1Topf
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @1topf kann sein dass du mal eine eine kaputte GIT version installiert hast... und das ein nebeneffect ist ?
                        machmal folgendes
                        stope den adapter
                        lösche das object mit dem gerät dass sich doppelt angemeldet hat (falls es 2 davon unter objecte gibt lösche beide)
                        starte den adapter
