  4. Zigbee: Sensor meldet sich doppelt an
21 Beiträge 3 Kommentatoren 724 Aufrufe 3 Beobachtet
  • 1Topf1 Offline
    1Topf1 Offline
    1Topf
    ich habe einen Xiaomi Temperatursensor, den ich eine Weile nicht in Gebrauch hatte (Batterie ist neu). Wenn ich den jetzt anlerne, meldet er sich doppelt (mehrfach probiert).
    2022-04-06 11:58:01.568 - info: zigbee.0 (3199932) Zigbee: allowing new devices to join.
    2022-04-06 11:58:27.245 - info: zigbee.0 (3199932) Starting interview of '0x00158d000241af85'
    2022-04-06 11:58:27.246 - info: zigbee.0 (3199932) Starting interview of '0x00158d000241af85'
    2022-04-06 11:58:28.312 - warn: zigbee.0 (3199932) Device '0x00158d000241af85' announced itself
    2022-04-06 11:58:28.315 - warn: zigbee.0 (3199932) Device '0x00158d000241af85' announced itself
    2022-04-06 11:58:39.373 - info: zigbee.0 (3199932) Successfully interviewed '0x00158d000241af85', device has succesfully been paired
    2022-04-06 11:58:39.374 - info: zigbee.0 (3199932) Device '0x00158d000241af85' is supported, identified as: Xiaomi MiJia temperature & humidity sensor (WSDCGQ01LM)
    2022-04-06 11:58:39.377 - info: zigbee.0 (3199932) Successfully interviewed '0x00158d000241af85', device has succesfully been paired
    2022-04-06 11:58:39.377 - info: zigbee.0 (3199932) Device '0x00158d000241af85' is supported, identified as: Xiaomi MiJia temperature & humidity sensor (WSDCGQ01LM)
    2022-04-06 11:59:02.833 - info: zigbee.0 (3199932) Zigbee: stop joining
    In der Kachel steht ein Fragezeichen, die Info zeigt aber das korrekte Gerät an:
        model:WSDCGQ01LM
        description:MiJia temperature & humidity sensor
        modelZigbee:lumi.sensor_ht
        type:EndDevice
        nwk:3186
        manuf id:4151
        manufacturer:LUMI
        power:Battery
        app version:2
        hard version:30
        zcl version:1
        stack version:2
        date code:20160516
        build:3000-0001
        interviewed:true
        configured:false
        endpoint:1
        profile:260
        input clusters:genBasic (0)
        genIdentify (3)
        genOta (25)
        65535
        genMultistateInput (18)
        output clusters:genBasic (0)
        genGroups (4)
        genIdentify (3)
        genScenes (5)
        genOta (25)
        65535
        endpoint:2
        profile:260
        input clusters:genIdentify (3)
        output clusters:genGroups (4)
        genIdentify (3)
        genScenes (5)
        endpoint:3
        profile:260
        genAnalogInput (12)
        genIdentify (3)
        genScenes (5)
        genAnalogInput (12)
    Könnte das ein Hardwaredefekt vom Sensor sein?
    Adapter ist die V 1.6.16, Coordinator ein CC2538 v 2-2.2.7.2. Rev. 20200327.
    Viele Grüße,
    Andi
    • arteckA Offline
      arteckA Offline
      arteck
      ist der auch in den objekten doppelt ?
      1Topf1 2 Antworten Letzte Antwort
      • arteckA arteck
        1Topf1 Offline
        1Topf1 Offline
        1Topf
        @arteck
        Nein. Und jetzt bin ich gerade etwas platt: in den Objekten wird alles korrekt angezeigt -> Temperatur, Batterie, Luftfeuchte, ...
        Muß jetzt erstmal zur Arbeit, kann erst heute abend weiter hier lesen.
        • arteckA arteck
          1Topf1 Offline
          1Topf1 Offline
          1Topf
          @arteck
          Hast Du ne Idee, wieso das Gerät doppelt gekoppelt wird bzw. wie ich die Kachel ordentlich angezeigt bekomme?
          • 1Topf1 1Topf
            @arteck
            arteckA Offline
            arteckA Offline
            arteck
            @1topf installier mal die GIT version.ich vermute du hast da was kaputtes installiert (es gab mal eine Version die kaputt war)
            1Topf1 1 Antwort Letzte Antwort
            • arteckA arteck
              1Topf1 Offline
              1Topf1 Offline
              1Topf
              @arteck Das ist die GIT - Version, hatte ich extra vor 2 oder 3 Tagen nochmal gemacht. Naja, Hauptsache über die Objekte funzt es.
              • 1Topf1 1Topf
                arteckA Offline
                arteckA Offline
                arteck
                @1topf ne ist die nicht .. zumindest nicht die JETZIGE also... nochmal JETZT von GIT installieren
                • arteckA arteck
                  1Topf1 Offline
                  1Topf1 Offline
                  1Topf
                  @arteck Also, ich hab die Katze angeklickt, VON GITHUB installiert, Ergebnis: meldet sich doppelt und die Kachel bleibt bei ihrem Fragezeichen. Wer weiß, was der hat ...
                  • 1Topf1 1Topf
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @1topf zeigmal LOG vom Start des adapter
                    • arteckA arteck
                      1Topf1 Offline
                      1Topf1 Offline
                      1Topf
                      @arteck
                      Es ist der xxxaf85. Sieht ja ganz normal aus.
                      2022-04-08 09:17:56.153 - info: host.ioBroker "system.adapter.zigbee.0" enabled
                      2022-04-08 09:17:56.467 - info: host.ioBroker instance system.adapter.zigbee.0 started with pid 3830533
                      2022-04-08 09:18:04.207 - info: zigbee.0 (3830533) starting. Version 1.6.16 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.21
                      2022-04-08 09:18:04.429 - info: zigbee.0 (3830533) Starting Zigbee npm ...
                      2022-04-08 09:18:05.958 - info: zigbee.0 (3830533) Installed Version: ioBroker/ioBroker.zigbee
                      2022-04-08 09:18:06.232 - info: zigbee.0 (3830533) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200327}}
                      2022-04-08 09:18:06.245 - info: zigbee.0 (3830533) Unable to disable LED, unsupported function.
                      2022-04-08 09:18:06.279 - info: zigbee.0 (3830533) --> transmitPower : high
                      2022-04-08 09:18:06.313 - info: zigbee.0 (3830533) Currently 33 devices are joined:
                      2022-04-08 09:18:06.492 - info: zigbee.0 (3830533) Configuring 0x804b50fffe1a44e6 TS0201
                      2022-04-08 09:18:06.499 - info: zigbee.0 (3830533) 0x00158d0006ba28d7 (addr 11029): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
                      2022-04-08 09:18:06.522 - info: zigbee.0 (3830533) 0x84182600000e1874 (addr 58066): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
                      2022-04-08 09:18:06.527 - info: zigbee.0 (3830533) 0x804b50fffe3f39a9 (addr 41713): ZL1000400-CCT-EU-2-V1A02 - Linkind Zigbee LED 5.4W C35 bulb E14, dimmable & tunable (Router)
                      2022-04-08 09:18:06.531 - info: zigbee.0 (3830533) 0x7cb03eaa0a04dd64 (addr 34216): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
                      2022-04-08 09:18:06.535 - info: zigbee.0 (3830533) 0x00158d00031e8abe (addr 11766): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                      2022-04-08 09:18:06.538 - info: zigbee.0 (3830533) 0x84182600000efdf2 (addr 55051): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2022-04-08 09:18:06.542 - info: zigbee.0 (3830533) 0x804b50fffe1a44e6 (addr 14093): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
                      2022-04-08 09:18:06.545 - info: zigbee.0 (3830533) 0x84182600000ee911 (addr 26846): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2022-04-08 09:18:06.548 - info: zigbee.0 (3830533) 0xec1bbdfffedf6d32 (addr 12424): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
                      2022-04-08 09:18:06.553 - info: zigbee.0 (3830533) 0xbc33acfffed6aa00 (addr 13393): HG06338 - Lidl Silvercrest 3 gang switch, with 4 USB (EU, FR, CZ, BS) (Router)
                      2022-04-08 09:18:06.557 - info: zigbee.0 (3830533) 0x00158d0002772b63 (addr 13091): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                      2022-04-08 09:18:06.561 - info: zigbee.0 (3830533) 0x00158d000241af85 (addr 61936): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
                      2022-04-08 09:18:06.564 - info: zigbee.0 (3830533) 0x842e14fffe5ad499 (addr 51975): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
                      2022-04-08 09:18:06.567 - info: zigbee.0 (3830533) 0x00124b0018ed130a (addr 41819): CC2530.ROUTER - Custom devices (DiY) [CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/) (Router)
                      2022-04-08 09:18:06.572 - info: zigbee.0 (3830533) 0x7cb03eaa0a06863e (addr 65493): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2022-04-08 09:18:06.576 - info: zigbee.0 (3830533) 0x00158d0002741e28 (addr 59443): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                      2022-04-08 09:18:06.579 - info: zigbee.0 (3830533) 0x00158d0006ba1d92 (addr 40): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
                      2022-04-08 09:18:06.583 - info: zigbee.0 (3830533) 0xbc33acfffed75554 (addr 58963): HG06338 - Lidl Silvercrest 3 gang switch, with 4 USB (EU, FR, CZ, BS) (Router)
                      2022-04-08 09:18:06.586 - info: zigbee.0 (3830533) 0x00158d0001c9edc1 (addr 14147): RB 175 W - Innr E27 bulb warm dimming (Router)
                      2022-04-08 09:18:06.590 - info: zigbee.0 (3830533) 0x7cb03eaa00a95ddc (addr 11554): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
                      2022-04-08 09:18:06.593 - info: zigbee.0 (3830533) 0x7cb03eaa0a05a22c (addr 40785): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
                      2022-04-08 09:18:06.598 - info: zigbee.0 (3830533) 0x60a423fffea0d336 (addr 52644): TS0601_thermostat - TuYa Radiator valve with thermostat (EndDevice)
                      2022-04-08 09:18:06.629 - info: zigbee.0 (3830533) 0x000d6f00123bcc51 (addr 49287): AC0251100NJ/AC0251600NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
                      2022-04-08 09:18:06.633 - info: zigbee.0 (3830533) 0x00158d0002754c27 (addr 5906): HS3SA - HEIMAN Smoke detector (EndDevice)
                      2022-04-08 09:18:06.636 - info: zigbee.0 (3830533) 0xec1bbdfffe8d338a (addr 4458): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
                      2022-04-08 09:18:06.639 - info: zigbee.0 (3830533) 0x00158d0002090194 (addr 34826): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
                      2022-04-08 09:18:06.640 - info: zigbee.0 (3830533) 0x000d6f0016195803 (addr 54022): Not supported (model ColorDimmerSw-EM-3.0)(EndDevice)
                      2022-04-08 09:18:06.641 - info: zigbee.0 (3830533) 0x00158d0006c4adb2 (addr 34455): Not supported (model ColorLight)(Router)
                      2022-04-08 09:18:06.645 - info: zigbee.0 (3830533) 0x804b50fffe3f3b93 (addr 17063): ZL1000400-CCT-EU-2-V1A02 - Linkind Zigbee LED 5.4W C35 bulb E14, dimmable & tunable (Router)
                      2022-04-08 09:18:06.648 - info: zigbee.0 (3830533) 0x00158d00027746e5 (addr 17844): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                      2022-04-08 09:18:06.656 - info: zigbee.0 (3830533) 0x7cb03eaa00aed498 (addr 35069): AB3257001NJ - OSRAM Smart+ plug (Router)
                      2022-04-08 09:18:06.658 - info: zigbee.0 (3830533) 0x00124b0018e1cd13 (addr 3464): CC2530.ROUTER - Custom devices (DiY) [CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/) (Router)
                      2022-04-08 09:18:06.661 - info: zigbee.0 (3830533) 0x00124b0024ca825e (addr 15336): ti.router - Custom devices (DiY) Texas Instruments router (Router)
                      2022-04-08 09:18:06.663 - info: zigbee.0 (3830533) Zigbee started
                      2022-04-08 09:18:06.842 - info: zigbee.0 (3830533) debug devices set to []
                      2022-04-08 09:18:07.647 - error: zigbee.0 (3830533) Device 0x000d6f0016195803 "ColorDimmerSw-EM-3.0" not described in statesMapping.
                      2022-04-08 09:18:07.658 - error: zigbee.0 (3830533) Device 0x00158d0006c4adb2 "ColorLight" not described in statesMapping.
                      2022-04-08 09:18:27.103 - warn: zigbee.0 (3830533) DeviceConfigure:DeviceConfigure failed 0x804b50fffe1a44e6 TS0201, attempt 1 (Error: Read 0x804b50fffe1a44e6/1 genBasic(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
                      at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:414:23)
                      at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32))
                      2022-04-08 09:18:29.282 - warn: zigbee.0 (3830533) DeviceAvailability:Failed to ping 0x00158d0006c4adb2 ColorLight
                      2022-04-08 09:18:30.544 - warn: zigbee.0 (3830533) DeviceAvailability:Failed to ping 0x84182600000efdf2 Plug 01
                      2022-04-08 09:18:47.886 - warn: zigbee.0 (3830533) DeviceAvailability:Failed to ping 0x7cb03eaa0a05a22c Classic A60 W clear - LIGHTIFY
                      Da fällt mir gleich noch was ein: was mich ein wenig stört ist der TS0201 / xxx44e6. Der ist baugleich mit xxx6d32, nur von einem anderen "Hersteller". Vom xxx44e6 wird aber keine Spannung angezeigt. Im Log wird er ja auch mit warn angezeigt.
                      Andi
                      arteckA AsgothianA 2 Antworten Letzte Antwort
                      • 1Topf1 1Topf
                        @arteck
                        Andi
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @1topf sagte in Zigbee: Sensor meldet sich doppelt an:
                        af85
                        der ist doch nur einmal drin
                        im ernst.. nur weil es 4 Räder hat und ein Lenkrad ist es immer ein Porsche ??
                        die Teile sehen fast alle gleich aus.. die Firmware ist der unterschied..
                        • arteckA arteck
                          af85
                          1Topf1 Offline
                          1Topf1 Offline
                          1Topf
                          @arteck sagte in Zigbee: Sensor meldet sich doppelt an:
                          Ja, aber wie du ganz oben in meinem ersten Beitrag siehst, meldet er sich doppelt. Und die Kachel bleibt ein Fragezeichen. DU wolltest das Startlog haben. 😁
                          Hauptsache Heckantrieb. 😀 😀
                          Nee, mal ernsthaft. Ich weiß nicht genau, ob der die Spannung jemals angezeigt hat. Ich weiß aber, daß in früheren Adapterversionen nie eine warn - Meldung ausgegeben wurde. Kann es jetzt aber nicht mehr nachvollziehen.
                          • 1Topf1 1Topf
                            @arteck
                            Andi
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            Bitte prüfen:
                            wie melden sich die beiden Geräte auf der Info Kachel - insbesondere interessant ist die "manufacturer_info". Da es sich um TuYa Geräte handelt wird da irgendetwas wie "__TZE200_asgsrges" stehen. In den meisten Fällen beschreibt der vordere Teil (_TZE200) die Hardware und der hintere Teil die Firmware. Selbst bei identischer Hardware liefern unterschiedliche Firmwarestände unterschiedliche Datenpunkte.
                            Und nein - ein Austausch der Firmware ist nicht "mal eben so" gemacht.
                            Auch bei dem Sensor der mit einem ? dargestellt wird ist interessant wie die Info Kachel aussieht.. bitte posten.
                            A.
                            • AsgothianA Asgothian
                              Bitte prüfen:
                              A.
                              1Topf1 Offline
                              1Topf1 Offline
                              1Topf
                              schrieb am zuletzt editiert von 1Topf
                              @asgothian
                              Erstmal das ?. ℹ steht bereits ganz oben im ersten Beitrag.
                              Nun zu den anderen, TS0201.
                              Der Sensor mit Voltanzeige ist von Blitzwolf:
                              ℹ :
                                  model:TS0201
                                  description:Temperature & humidity sensor with display
                                  modelZigbee:TS0201
                                  type:EndDevice
                                  nwk:12424
                                  manuf id:4098
                                  manufacturer:_TYZB01_hjsgdkfl
                                  power:Battery
                                  app version:65
                                  hard version:1
                                  zcl version:3
                                  stack version:0
                                  date code:
                                  interviewed:true
                                  configured:false
                                  endpoint:1
                                  profile:260
                                  genPowerCfg (1)
                                  msTemperatureMeasurement (1026)
                                  msRelativeHumidity (1029)
                                  output clusters:genOta (25)
                              Von wem der Sensor ohne Voltanzeige ist weiß ich nicht, hab die Verpackung nicht mehr:
                              ℹ :
                                  model:TS0201
                                  modelZigbee:TS0201
                                  type:EndDevice
                                  nwk:14093
                                  manuf id:4098
                                  manufacturer:_TZ2000_a476raq2
                                  power:Battery
                                  app version:72
                                  hard version:1
                                  zcl version:3
                                  stack version:0
                                  date code:
                                  interviewed:true
                                  configured:false
                                  endpoint:1
                                  profile:260
                                  genPowerCfg (1)
                                  genTime (10)
                              Da die Geräte grundsätzlich funktionieren, sind das "Luxusprobleme". Wenn es keine Lösung gibt, kann ich damit leben 😊 . Beim Gerät mit Fragezeichen ist nur doof, daß man keinen Namen vergeben kann. Ich hab den zwar manuell in den Objekten eingetragen, der taucht aber z.B. in VIS (wenn man ihn auswählen will) nicht auf. Also der Name steht nicht dort, daß Gerät schon.
                              Andi
                              Edit: Hab gerade bissl in den Objekten rumgespielt. Für das "Fragezeichen" war kein Typ hinterlegt. Habe "Device" eingetragen, nun wird die Kachel korrekt angezeigt. 😳
                              • arteckA Offline
                                arteckA Offline
                                arteck
                                @1Topf kannst du bitte ganz stupide auf das I kliken und die Kachel posten wie die kommt.. und nicht den Text rauskopieren
                                • arteckA arteck
                                  1Topf1 Offline
                                  1Topf1 Offline
                                  1Topf
                                  @arteck
                                  • 1Topf1 1Topf
                                    @arteck
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    @1topf
                                    Die beiden TS0201 sind nicht identisch:_
                                    Hoftür hat die Herstellerkennung _TZ2000_a476raq2
                                    Kellergang hat die Herstellerkennung _TYZB01_hjsgdkfl
                                    Damit mag die Hardware gleich sein, die Firmware ist es nicht - daher das unterschiedliche Verhalten.
                                    Willkommen in dem Wahnsinn der sich TuYa nennt.
                                    A.
                                      @1topf
                                      A.
                                      1Topf1 Offline
                                      1Topf1 Offline
                                      1Topf
                                      @asgothian
                                      Ja, hatte oben schon geschrieben, daß "Kellergang" ein Blitzwolf ist (BW-IS4) und ich es von "Hoftür" nicht mehr weiß, da ich keine Verpackung mehr habe. Wie gesagt, Luxusproblem, muß ich den Batteriestatus eben immer direkt am Gerät ablesen.
                                      Was ich mich aber immer noch frage: wieso meldet sich dieser andere Sensor (also das ursprüngliche Threadthema) beim anlernen doppelt an und wieso erscheint die Kachel richtig (kein Fragezeichen mehr), nachdem ich in den Objekten den Typ auf "Device" gesetzt habe.?.
                                      • 1Topf1 1Topf
                                        @asgothian
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        Auf die erste Frage habe ich keine Antwort. Die zweite Frage lässt sich eindeutig beantworten - wenn das Gerät falsch in den Objekten angelegt wird werden nicht alle Parameter korrekt gesetzt. Das anpassen des States auf "Device" hat das gefixed. Alternativ hättest du das Objekt auch im Baum löschen können und der Adapter sollte den korrekt wieder anlegen.
                                        A.
                                          A.
                                          1Topf1 Offline
                                          1Topf1 Offline
                                          1Topf
                                          @asgothian OK, weiß ich bescheid, wenn das wieder mal passiert. Danke. 👍
