  4. Fully Kiosk Browser
    5.8k
Fully Kiosk Browser
508 Beiträge 96 Kommentatoren 188.0k Aufrufe 83 Beobachtet
  • arteckA arteck
    @merlin123
    gibmal bitte im browser
    http://192.168.0.244:2323/?cmd=deviceInfo&type=json&password=xxxx
    ein bei ... xxxx das psw eingeben
    sollte sowas kommen
    rechts die werte.. die brauch ich aber nicht.. schau nur ob das was ich gepostet habe kommt
    Merlin123M Offline
    Merlin123M Offline
    Merlin123
    #353
    @arteck sagte in Fully Kiosk Browser:
    Da kommt das:
    {"status":"Error","statustext":"Please login"}
    Wenn ich das Passwort auf der Seite eingebe
    werde ich eingeloggt. Das Passwort stimmt also.
    Wenn ich danach nochmal deinen Befehl eingebe kommt das:
    {"deviceName":"Tab A8 von Oliver","packageName":"de.ozerov.fully","altitude":150.618,"locationProvide":"gps","batteryLevel":50,"isPlugged":false,"SSID":"\"Wizards-Tower2\"","BSSID":"cc:ce:1e:b1:1f:da","Mac":"XXXXXX","ip4":"192.168.0.244","ip6":"FE80::E8D5:50FF:XXXXXX","hostname4":"Tablet-VIS2.fritz.box","hostname6":"fe80::e8d5:50ff:fef1:3237%wlan0","wifiSignalLevel":7,"isMobileDataEnabled":false,"screenOrientation":90,"screenBrightness":22,"screenLocked":true,"screenOn":false,"batteryTemperature":21,"plugged":false,"keyguardLocked":true,"locale":"de_DE","serial":"unknown","build":"RP1A.200720.012.X200XXU1AVC1","androidVersion":"11","webviewUA":"Mozilla/5.0 (Linux; Android 11; SM-X200 Build/RP1A.200720.012; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/99.0.4844.88 Safari/537.36","motionDetectorStatus":0,"isDeviceAdmin":true,"isDeviceOwner":false,"internalStorageFreeSpace":16651935744,"internalStorageTotalSpace":23361204224,"ramUsedMemory":1932701696,"ramFreeMemory":664088576,"ramTotalMemory":2596790272,"appUsedMemory":10217408,"appFreeMemory":191109184,"appTotalMemory":201326592,"timestamp":1649140258137,"scopedStorage":true,"displayHeightPixels":1200,"displayWidthPixels":1920,"isMenuOpen":false,"topFragmentTag":"","isInDaydream":false,"isRooted":false,"isLicensed":true,"isInScreensaver":false,"kioskLocked":false,"isInForcedSleep":false,"maintenanceMode":false,"kioskMode":false,"startUrl":"http://iobroker.fritz.box:8082/vis/#Start","currentTabIndex":0,"deviceID":"a3f3f4e4-cbb722b7","locationLatitude":49.XXXX,"locationLongitude":8.XXXXX,"appVersionCode":1057,"appVersionName":"1.47.2-play","androidSdk":30,"deviceModel":"SM-X200","deviceManufacturer":"samsung","foregroundApp":"de.ozerov.fully","currentPage":"http://iobroker.fritz.box:8082/vis/#Start","lastAppStart":"04.04.22 18:14:11"}
    (ein paar Sachen hab ich unkenntlich gemacht)
    Beta-Tester
    • J JoergH
      Ich war länger nicht an meinem Tablet und habe nun festgestellt, dass die Farbtöne nun plötzlich invertiert erscheinen, also Buttons, die vorher schwarz waren, sind nun auf einmal weiß, etc.
      Sagt das jemandem was?
      Merlin123M Offline
      Merlin123M Offline
      Merlin123
      #354
      @joergh sagte in Fully Kiosk Browser:
      Schau mal da:
      Farbumkehr aktivieren
      Öffnen Sie auf Ihrem Gerät die Einstellungen .
      Tippen Sie auf Bedienungshilfen.
      Tippen Sie unter "Display" auf Farbumkehr.
      Schalten Sie Farbumkehr aktivieren ein.
      Optional: Aktivieren Sie die Verknüpfung für "Farbumkehr".
      Beta-Tester
      • Merlin123M Merlin123
        Da kommt das:
        arteckA Offline
        arteckA Offline
        arteck
        #355
        @merlin123 nochmal
        das muss gehen
        http://192.168.0.244:2323/?cmd=deviceInfo&type=json&password=Test12345
        hie rmüssen Daten geliefert werden.. egal ob es nach deinem Login geht ...dieser Link muss daten liefern..
        hast du Sonderzeichen im Password ? ist es extrem Lang ?? irgendwas stimmt da nicht..
        setzt das pSW mal auf Test12345..und rufe den link von oben auf
        Merlin123M 1 Antwort Letzte Antwort
        • arteckA arteck
          @merlin123 nochmal
          das muss gehen
          Merlin123M Offline
          Merlin123M Offline
          Merlin123
          schrieb am zuletzt editiert von Merlin123
          #356
          Jup... Da ist das Problem... ich hab ein "+" und ein "-" drin. Also nix exotisches. Ohne das liefert er das Ergebnis.
          Jetzt sind auch alle Objekte da.
          Das ist ja ein Mist.... Ich mein, da muss ich nicht wirklich ein sicheres Passwort nutzen, aber grundsätzlich ist das schon doof....
          Auf jeden Fall danke für die Hilfe (auch wenn wir uns am Anfang in der Kommunikation etwas schwer getan haben ;) )
          Dann kann ich jetzt wieder auf Deinen Adapter zurück gehen :) Den mag ich eh lieber
          Beta-Tester
            arteckA Offline
            arteckA Offline
            arteck
            #357
            @merlin123 war ne schwere Geburt... also doch Sonderzeichen im psw
            HomoranH Merlin123M 2 Antworten Letzte Antwort
            • arteckA arteck
              #358
              ich glaube nicht, dass + und - unter "Sonderzeichen" im engeren Sinne fallen
              • arteckA arteck
                Merlin123M Offline
                Merlin123M Offline
                Merlin123
                #359
                Aber wo liegt das Problem? Ist das in Deinem Adapter oder im Browser ein Problem? Das sind ja noch harmlose Zeichen, die eigentlich kein Problem sein sollten...
                Beta-Tester
                  arteckA Offline
                  arteckA Offline
                  arteck
                  #360
                  @merlin123 @Homoran das problem ist dass man diese Zeichen nicht in der URL mit übertragen kann..
                  das ist so
                  http://192.168.0.244:2323/?cmd=deviceInfo&type=json&password=Test12345+-+
                  das geht nicht genausowenig wie
                  http://192.168.0.244:2323/?cmd=deviceInfo&type=json&password=Töstäöü
                  • arteckA arteck
                    das ist so
                    #361
                    das ist so
                    das ist was anderes, aber ich fürchte dann sollte man die Beschreibung/Info ändern. Aber selbst bei Beschränkung auf "alphanumerische Zeichen" bin ich mir nicht sicher, ob das die Vorzeichen ausschließt.
                      das ist so
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #362
                      @homoran wir reden hier über ein PSW für den fullyBrowser und nicht über fort knox..
                      also ich bitte dich..
                      • arteckA arteck
                        #363
                        das ist mir bewusst.
                        Ich rede noch nicht einmal darüber sondern nur über die korrekte Formulierung der "Einschränkung", damit es nicht zu solchen Problemen kommt wenn es z.B. heisst man dürfe keine Sonderzeichen verwenden
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #364
                          @homoran ok aufgenommen
                            Schau mal da:
                            JoergH
                            #365
                            @merlin123 Danke, der Tipp hat weitergeholfen!
                            Es gibt tatsächlich im Tablet einen "Dark mode" der sich aus unerklärlichen Gründen aktiviert hatte.
                            • Merlin123M Offline
                              Merlin123M Offline
                              Merlin123
                              #366
                              @arteck Du kannst das abfangen.
                              http://192.168.0.244:2323/?cmd=deviceInfo&type=json&password=xyz+
                              musst Du als
                              http://192.168.0.244:2323/?cmd=deviceInfo&type=json&password=xyz%2B
                              übergeben. Für die ganzen Sonderzeichen gibt es entsprechende Codierungen. Hab es eben getestet und das geht.
                              Beta-Tester
                                musst Du als
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #367
                                @merlin123 ja ich weiss.. es ist nur eine kodierung..
                                • arteckA arteck
                                  Merlin123M Offline
                                  Merlin123M Offline
                                  Merlin123
                                  #368
                                  @arteck Kannst Du das nicht entsprechend einbauen? Wäre für die Anwender sicher nicht verkehrt
                                  Beta-Tester
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #369
                                    @merlin123
                                    kannst mal testen.installier mal das Repo
                                    https://github.com/arteck/ioBroker.fullybrowser/tarball/encodeurl
                                    • arteckA arteck
                                      @merlin123
                                      Merlin123M Offline
                                      Merlin123M Offline
                                      Merlin123
                                      #370
                                      Mach ich. Meld mich schnellstmöglich
                                      Beta-Tester
                                      • arteckA arteck
                                        @merlin123
                                        Merlin123M Offline
                                        Merlin123M Offline
                                        Merlin123
                                        #371
                                        @merlin123
                                        Wie installier ich das richtig?
                                        Beta-Tester
                                          @merlin123
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #372
                                          @merlin123 über die katze ..
                                          https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
                                          hier ist beschrieben wie man es macht...
                                          nimmst nur halt mein link und nicht das zigbee gelumpe
