  4. Altere Version eines Adapters installieren?
    6.0k
16 Beiträge 3 Kommentatoren 2.1k Aufrufe 2 Beobachtet
    @jens-meyer mit welcher Meldung?
    Jens MeyerJ Offline
    Jens MeyerJ Offline
    Jens Meyer
    schrieb am zuletzt editiert von Jens Meyer
    @crunchip
    Das ist die aktuelle Meldung mit der neusten Version
    Die IP 192.168.35.49 ist der ioBroker
    	Zeit
    debug
    Nachricht
    sonoff.0
    2022-03-31 22:35:16.974	error	Can not start Server Error: listen EADDRINUSE: address already in use 192.168.35.49:1883
    sonoff.0
    2022-03-31 22:35:16.947	info	starting. Version 2.4.7 in /opt/iobroker/node_modules/iobroker.sonoff, node: v14.19.1, js-controller: 4.0.21
    Und das sind die mit der älteren Version 2.4.5
    host.IoBroker-Admin-5
    2022-03-31 22:40:47.359	error	instance system.adapter.sonoff.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-03-31 22:40:47.359	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:83:21)
    2022-03-31 22:40:47.359	error	Caught by controller[0]: at doListen (net.js:1516:7)
    2022-03-31 22:40:47.359	error	Caught by controller[0]: at listenInCluster (net.js:1379:12)
    2022-03-31 22:40:47.359	error	Caught by controller[0]: at Server.setupListenHandle [as _listen2] (net.js:1331:16)
    2022-03-31 22:40:47.359	error	Caught by controller[0]: Error: listen EADDRINUSE: address already in use 192.168.35.49:1883
    sonoff.0
    2022-03-31 22:40:47.320	error	Exception-Code: EADDRINUSE: listen EADDRINUSE: address already in use 192.168.35.49:1883
    sonoff.0
    2022-03-31 22:40:47.319	error	Error: listen EADDRINUSE: address already in use 192.168.35.49:1883 at Server.setupListenHandle [as _listen2] (net.js:1331:16) at listenInCluster (net.js:1379:12) at doListen (net.js:1516:7) at processTicksAndRejections (internal/process/task_queues.js:83:21)
    • Jens MeyerJ Jens Meyer
      @crunchip
      	Zeit
      debug
      Nachricht
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      crunchipC Abwesend
      crunchipC Abwesend
      @jens-meyer steht doch da, dein Problem
      Jens MeyerJ 1 Antwort Letzte Antwort
        Jens MeyerJ Offline
        Jens MeyerJ Offline
        Jens Meyer
        @crunchip
        Die 192.168.35.49 ist ja der ioBroker .. die muss ich doch angeben als host
          @crunchip
          crunchipC Abwesend
          crunchipC Abwesend
          @jens-meyer dein Port wird anderweitig verwendet werden.
          Mach mal
          sudo netstat -tulpen
            Mach mal
            Jens MeyerJ Offline
            Jens MeyerJ Offline
            Jens Meyer
            @crunchip
            Kann mir das mal jemand erklären…?
            2022-03-31 23:08:09.501 error instance system.adapter.sonoff.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2022-03-31 23:08:09.501 error Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:83:21)
            2022-03-31 23:08:09.501 error Caught by controller[0]: at doListen (net.js:1516:7)
            2022-03-31 23:08:09.501 error Caught by controller[0]: at listenInCluster (net.js:1379:12)
            2022-03-31 23:08:09.501 error Caught by controller[0]: at Server.setupListenHandle [as _listen2] (net.js:1331:16)
            2022-03-31 23:08:09.500 error Caught by controller[0]: Error: listen EADDRINUSE: address already in use 0.0.0.0:1883
            sonoff.0
            2022-03-31 23:08:09.462 error Exception-Code: EADDRINUSE: listen EADDRINUSE: address already in use 0.0.0.0:1883
            sonoff.0
            2022-03-31 23:08:09.462 error Error: listen EADDRINUSE: address already in use 0.0.0.0:1883 at Server.setupListenHandle [as _listen2] (net.js:1331:16) at listenInCluster (net.js:1379:12) at doListen (net.js:1516:7) at processTicksAndRejections (internal/process/task_queues.js:83:21)
            sonoff.0
            2022-03-31 23:08:09.462 error uncaught exception: listen EADDRINUSE: address already in use 0.0.0.0:1883
            Jens MeyerJ crunchipC 2 Antworten Letzte Antwort
              @crunchip
              sonoff.0
              sonoff.0
              sonoff.0
              Jens MeyerJ Offline
              Jens MeyerJ Offline
              Jens Meyer
              @jens-meyer
              Update…
              Habe jetzt Port , Benutzername,Passwort geändert
              Jetzt funktioniert es auch mit der sonoff Version 2.4.7
              Danke für die schubser in die richtige Richtung …
              Danke crunchip
                @crunchip
                sonoff.0
                sonoff.0
                sonoff.0
                crunchipC Abwesend
                crunchipC Abwesend
                @jens-meyer keine Ahnung was Master ist, aber das blockiert den Port
                Äh falsche Zeile, dein mqtt
                  Jens MeyerJ Offline
                  Jens MeyerJ Offline
                  Jens Meyer
                  @crunchip
                  Einen Post über deinen..
                  Danke an dich für den schubser in die richtige Richtung
                  • crunchipC Abwesend
                    crunchipC Abwesend
                    @jens-meyer ja das hatte sich überschnitten, hatte kein Handy Empfang
                      Jens MeyerJ Offline
                      Jens MeyerJ Offline
                      Jens Meyer
                      @crunchip
                      Nochmal danke an dich…
                      Immer wieder schön wenn man so schnell geHolfen Bekommt
