  4. IoBroker.js-controller 1.0
35 Beiträge 11 Kommentatoren 4.7k Aufrufe
  • BluefoxB Offline
    BluefoxB Offline
    da js-controller schon sehr stabil ist, ist es Zeit gekommen um 1.0 zu machen.
    Also Version js-controller 1.0.0 ist draußen.
    # 1.0.0 (2017-04-23)
    * (bluefox) No big changes, just version
    * (bluefox) remove warning about iDs
    * (Steiger04) create states with ack=true by default
    * (bluefox) ignore npm error 1
    * (bluefox) fix tests
    * (bluefox) fix possible error.
    MfG,
    • eric2905E Offline
      eric2905E Offline
      eric2905
      Dann werde ich mal unseren Wikipedia-Eintrag ändern.
      Gruß,
      Eric
      • kmxakK Offline
        kmxakK Offline
        kmxak
        Zur Info!
        js-controller update liefert folgende Fehler
        ! root@raspberrypi:/opt/iobroker# npm install iobroker.js-controller --production ! > unix-dgram@0.2.3 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram node-gyp rebuild ! gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.8.2" gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram/.node-gyp" make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram/build' CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o SOLINK_MODULE(target) Release/obj.target/unix_dgram.node COPY Release/unix_dgram.node make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram/build' ! > ursa@0.9.4 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa node-gyp rebuild ! gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.8.2" gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa/.node-gyp" make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa/build' CXX(target) Release/obj.target/ursaNative/src/ursaNative.o SOLINK_MODULE(target) Release/obj.target/ursaNative.node COPY Release/ursaNative.node make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa/build' ! > iobroker.js-controller@1.0.0 install /opt/iobroker/node_modules/iobroker.js-controller node iobroker.js setup first ! npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/node_modules/node-pre-gyp/node_modules/tar-pack requires debug@'~2.2.0' but will load npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/node_modules/debug, npm WARN unmet dependency which is version 2.6.4 iobroker.js-controller@1.0.0 node_modules/iobroker.js-controller ├── safe-replace@1.0.2 ├── le-challenge-fs@2.0.8 ├── le-sni-auto@2.1.1 ├── pyconf@1.1.2 ├── semver@5.3.0 ├── mime@1.3.4 ├── winston-daily-rotate-file@1.4.6 ├── daemonize2@0.4.2 ├── ncp@2.0.0 ├── node.extend@1.1.6 (is@3.2.1) ├── redis@2.7.1 (double-ended-queue@2.1.0-0, redis-commands@1.3.1, redis-parser@2.6.0) ├── node-schedule@1.2.1 (long-timeout@0.1.1, sorted-array-functions@1.0.0, cron-parser@1.1.0) ├── bluebird@3.5.0 ├── mkdirp@0.5.1 (minimist@0.0.8) ├── winston@2.3.1 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, isstream@0.1.2, async@1.0.0, colors@1.0.3) ├── socket.io@1.7.3 (object-assign@4.1.0, socket.io-adapter@0.5.0, has-binary@0.1.7, debug@2.3.3, socket.io-parser@2.3.1, engine.io@1.8.3) ├── socket.io-client@1.7.3 (to-array@0.1.4, component-emitter@1.2.1, indexof@0.0.1, component-bind@1.0.0, backo2@1.0.2, object-component@0.0.3, has-binary@0.1.7, debug@2.3.3, parseuri@0.0.5, socket.io-parser@2.3.1, engine.io-client@1.8.3) ├── yargs@6.6.0 (get-caller-file@1.0.2, decamelize@1.2.0, camelcase@3.0.0, y18n@3.2.1, which-module@1.0.0, set-blocking@2.0.0, yargs-parser@4.2.1, require-main-filename@1.0.1, require-directory@2.1.1, cliui@3.2.0, string-width@1.0.2, os-locale@1.4.0, read-pkg-up@1.0.1) ├── prompt@1.0.0 (revalidator@0.1.8, pkginfo@0.4.0, colors@1.1.2, read@1.0.7, winston@2.1.1, utile@0.3.0) ├── request@2.81.0 (aws-sign2@0.6.0, tunnel-agent@0.6.0, forever-agent@0.6.1, oauth-sign@0.8.2, caseless@0.12.0, is-typedarray@1.0.0, stringstream@0.0.5, safe-buffer@5.0.1, aws4@1.6.0, isstream@0.1.2, json-stringify-safe@5.0.1, extend@3.0.0, performance-now@0.2.0, uuid@3.0.1, qs@6.4.0, combined-stream@1.0.5, mime-types@2.1.15, tough-cookie@2.3.2, form-data@2.1.4, hawk@3.1.3, http-signature@1.1.1, har-validator@4.2.1) ├── winston-syslog@1.2.6 (cycle@1.0.3, glossy@0.1.7, unix-dgram@0.2.3) ├── tar.gz@1.0.5 (commander@2.9.0, tar@2.2.1, bluebird@2.11.0, fstream@1.0.11, mout@0.11.1) ├── jszip@3.1.3 (es6-promise@3.0.2, lie@3.1.1, pako@1.0.5, readable-stream@2.0.6, core-js@2.3.0) ├── greenlock@2.1.14 (le-store-certbot@2.0.5, homedir@0.6.0, asn1js@1.2.12, le-acme-core@2.0.9, certpem@1.0.1, pkijs@1.3.33, localhost.daplie.me-certificates@1.3.0, le-challenge-sni@2.0.1, rsa-compat@1.2.7) └── npm@2.15.12 root@raspberrypi:/opt/iobroker# !
        Das Problem ist hier das node-gyp trotz angestoßenem js-controller update ohne rechte ausgeführt wird. (diese Infos habe ich aus einem anderem Forum)
        Trotz Root muss man das update mit sudo machen! Dann läuft alles sauber durch.
        OS ist 2017-04-10-raspbian-jessie
        Nochwas:
        Die aktuelle Version wird noch nicht angezeigt. (iobroker update)
        Controller "js-controller" : 0.17.2 , installed 1.0.0
        Gruß Alex
        • L Offline
          Lebeao
          Hallo
          habe den js-controller installiert, läuft alles ohne irgendwelche Probleme. ;)
          MfG Marco
          piVCCU
          IOBroker Master auf Debian unter HyperV auf Intel Xeon D1520 mit 48 GB RAM
          IOBroker Slave auf Raspberry Pi 3
          • svenomattS Offline
            svenomattS Offline
            svenomatt
            ich habe Probleme nach dem Update auf den ioBroker.js-controller 1.0.
            Ich wollte gestern das System bei mir neu aufsetzen. Dafür habe ich zunächst das aktuelle Image von iobroker heruntergladen.
            Raspbian full für Raspberry Pi 2/3 mit pixel
            -nodejs 6.10.0
            -ioBroker
            -redis
            Adapter Version
            js-controller 0.15.3
            nach dem ersten Start wurde mir das update auf js-controller 17.3 vorgeschlagen (Verfügbar). nach dem update über die Konsole wurde mir dann ab die Version 1.0 als installiert angezeigt.
            soweit keine Probleme. Aber nach dem ich ich einige Adapter für die Visualisation nachinstalliert habe hatte ich Probleme mit der Darstellung dieser. (wurden nicht korekt dargestellt.)
            vis.timeandweather, vis-fancyswitch, vis-hqwidgets.0 usw. waren zwar in VIS Visualisation vorhhanden jedoch ohne Bilder. zudem konnte ich sie nicht auswählen.
            In de Konsole wurde mir wärend es Updates des js-controller dies angezeigt
            npm WARN prefer global npm@2.15.12 should be installed with -g
            Host "ioBroker-RasPi" (linux) updated Execute: chmod 777 -R /opt/iobroker
            Hat jemand ähnlich Pobleme oder einer eine Idee.
            Gruss Sven
              Hallo Sven,
              Mach mal bitte:
              iobroker stop
              iobroker upload vis
              iobroker start
                Ich habe jetzt auch die ersten Rechner auf js-controller 1.0 gebracht.
                Bei meinem Pine64 habe ich anschließend Probleme mit dem RF-Link-Adapter.
                Das angebotene Update auf 1.1.4 brach mit Error ab.
                Anschließend wurde der Adapter im Reiter Admin als nicht installiert angezeigt
                Löschen von "nicht installierten" Adaptern ist jetzt ausgegraut.
                Also Instanz gelöscht und über die Konsole ioBroker del rflink ausgeführt.
                Geht nicht -> angeblich nicht vorhanden
                Nochmal drüber installiert erfolgte mit den üblichen Fehlermeldungen wegen fehlender Zugriffsrechte beim serialport. und endete mit:
                host.ioBroker_Pine64 install adapter rflink
                host.ioBroker_Pine64 Cannot install rflink
                Kann natürlich am 64Bit System liegen :(
                Any help appreciated ;-)
                  svenomattS Offline
                  svenomatt
                  @Homoran:
                  Hallo Sven,
                  Mach mal bitte:
                  iobroker stop
                  iobroker upload vis
                  iobroker start
                  Rainer `
                  Hallo Rainer, vielen Dank für die schnelle Antwort, dein Tipp war ein Volltreffer.
                  Komisch ist nur, das ich dies jetzt bei jeder Erweiterung von Vis. machen muss. Bei meinem alten System ging das ohne.
                    michi050
                    ich wollte ebenfalls auf 1.0 updaten. Der ioBroker läuft auf einem NUC mit Win10. Vielleicht könnte mir einer von den Profis eine Hilfestellung zum Update geben. Ich Danke euch vielmals.
                    Gruß Michael
                    • apollon77A Offline
                      Interessant.
                      Ist built-essential Paket installiert?
                        michi050
                        Glaube nicht. Ich habe bisher nichts dergleichen installiert.
                          Dann mach mal :-)
                          apt-get install built-essential
                          • DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            @apollon77:
                            Dann mach mal :-)
                            apt-get install built-essential `
                            Gibts doch nicht auf windoof :), dafür aber
                            npm install --global windows-build-tools
                            Greetz
                            Dutch
                            Send from mobile device
                              @Dutchman:
                              Gibts doch nicht auf windoof :), `
                              Uups, dem hatte ich übersehen :-)
                                michi050
                                Die Installation npm install –global windows-build-tools auf Windoof scheint erfolgreich gewesen zu sein. Jetzt kommt die u.a. Meldung resultierend aus meinem unvollständigen Update. Was nun? Es sei im Voraus gedankt.
                                • DutchmanD Offline
                                  DutchmanD Offline
                                  Dutchman
                                  Sieht so aus als wen er bereits installiert ist ?!
                                  Was sagt den````
                                  iobroker update
                                  Eventuell mal npm Cache ler schmeißen
                                  npm cache clean
                                  Und Dan nochmal
                                    michi050
                                    ich habe gecleant. Hat leider am Ergebnis nix geändert :roll:
                                    1914_error3.rtf
                                    1914_error3.rtf
                                    • DutchmanD Offline
                                      DutchmanD Offline
                                      Dutchman
                                      @michi050:
                                      ich habe gecleant. Hat leider am Ergebnis nix geändert :roll: `
                                      Ok der Controller ist auf 1.0
                                      Controller "js-controller" : 1.0.0    , installed 1.0.0
                                      Verstehe jetzt Problem nicht ganz ? ;)
                                        michi050
                                        Nunja, ich frage mich jetzt natürlich, ob aufgrund der anfänglichen Fehlermeldungen wirklich alles geupdatet ist. Oder hat die Fehlermeldung keinerlei Auswirkung auf das Update?
                                          michi050
                                          Weiterhin frage ich mich, ob die bislang evtl. missratenen Updates dazu führen, dass ich kein VIS-Update bekomme. Das ist inzwischen bei 0.14.5 angekommen und wurde offensichtlich aus der Beta zusammengeführt. :roll:
                                          82.8k
