  2. English
  3. Off Topic
  4. Problems using influxDB on an external SSD
    6.8k
48 Beiträge 8 Kommentatoren 20.8k Aufrufe 7 Beobachtet
    Mathias2803
    I am using influx DB in combination with ioBroker on an raspberry Pi.
    After issues with the SSD and too many write attempts I moved the influxDB database on an external SSD drive that is mounted with the raspberry and the new location is "/mnt/mySSD/InfluxDB".
    The problem is, that after a normal manual reboot influxDB has problems connecting the DB and in ioBroker I am getting the error message: "No connection to DB".
    How can I solve this issue?
    I hope you can help me. If you need any additional information feel free to ask me (in best case with the command how to get the information).
    Thanks a lot and kind regards Mathias
    • M Mathias2803
      Meister MopperM Online
      Meister Mopper
      @mathias2803 I think, you have to delay the mount.
      debian mount manual
      Remote filesystem
      The same applies to remote filesystem mounts. If you want them to be mounted only upon access, you will need to use the noauto,x-systemd.automount parameters. In addition, you can use the x-systemd.device-timeout= option to specify how long systemd should wait for the filesystem to show up. Also, the _netdev option ensures systemd understands that the mount is network dependent and order it after the network is online.
      noauto,x-systemd.automount,x-systemd.device-timeout=30,_netdev
      Proxmox und HA ...
        debian mount manual
        Remote filesystem
        Mathias2803
        @meister-mopper Thanks a lot!
        So it will wait for this time before all other apps are loaded, so the influx app won't end in a not existing DB?
        I would like to wait then for 30 seconds. So I guess your command is correct.
        BUT I don't remember where I have added the mounting command to add this.
        Where do I have to add this? I am not working so often in the raspberry system, Sorry.
        Thanks soo much for your support!
        • M Mathias2803
          Meister Mopper
          @mathias2803 sagte in Problems using influxDB on an external SSD:
          Yes
          I think in /etc/fstab
          Proxmox und HA ...
            Yes
            Mathias2803
            This is how my fstab looks like. The last line is to mount the external drive.
            But where and how should I add your command??
            "noauto,x-systemd.automount,x-systemd.device-timeout=30,_netdev" ??
            proc /proc proc defaults 0 0
            PARTUUID=f0881a94-01 /boot vfat defaults 0 2
            PARTUUID=f0881a94-02 / ext4 defaults,noatime 0 1
            UUID="49441976-e29b-4acc-a8ee-71f4eb91255c" /mnt/mySSD ext4 nofail,defaults,noatime 0 2
            • M Mathias2803
              Meister Mopper
              I would experiment with UUID="49441976-e29b-4acc-a8ee-71f4eb91255c" /mnt/mySSD ext4 nofail,x-systemd.device-timeout=30,defaults,noatime 0 2
              Proxmox und HA ...
                Mathias2803
                I still have the same problem.
                What else can I do? Anything I can provide for a better analyze?
                • M Mathias2803
                  Meister Mopper
                  What else can I do?
                  Watch the logs, i.e. cat /var/log/syslog
                  Proxmox und HA ...
                    What else can I do?
                    Mathias2803
                    schrieb am zuletzt editiert von Mathias2803
                    @meister-mopper said in Problems using influxDB on an external SSD:
                    cat /var/log/syslog
                    It is a very big file. I will send a part of it:
                    Mar 24 18:28:01 ioBroker influxd-systemd-start.sh[9806]: [httpd] ::1 - admin ....
                    Send again in the next message. Thanks for your help how to do it!.
                    • M Mathias2803
                      cat /var/log/syslog
                      Meister Mopper
                      @mathias2803
                      • Please, use code tags
                      • next:
                        Please attach these log files
                      • better:
                        show logs only when it happens
                      Proxmox und HA ...
                      M 2 Antworten Letzte Antwort
                        @mathias2803
                        • next:
                        • better:
                        Mathias2803
                        @meister-mopper Ok, is it better like this:
                        Mar 24 18:28:01 ioBroker influxd-systemd-start.sh[9806]: [httpd] ::1 - admin [24/Mar/2022:18:28:01 +0100] "GET /query?db=iobroker&epoch=s&q=SELECT+mean%28%22value%22%29+FROM+%22Feuchtigkeit+Wert%22+WHERE+time+%3E+now%28%29+-+24h+GROUP+BY+time%281m%29+fill%28null%29 HTTP/1.1" 200 57 "-" "Grafana" c1b52ef5-ab97-11ec-8013-dca63298f236 1649
                        Mar 24 18:28:01 ioBroker grafana-server[750]: t=2022-03-24T18:28:01+0100 lvl=info msg="Alert Rule returned no data" logger=alerting.evalContext ruleId=1 name=Wassermangel changing state to=keep_state
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopped target Timers.
                        Mar 24 18:28:02 ioBroker systemd[1]: Condition check resulted in Turns off Raspberry Pi display backlight on shutdown/reboot being skipped.
                        Mar 24 18:28:02 ioBroker systemd[1]: apt-daily-upgrade.timer: Succeeded.
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopped Daily apt upgrade and clean activities.
                        Mar 24 18:28:02 ioBroker systemd[1]: apt-daily.timer: Succeeded.
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopped Daily apt download activities.
                        Mar 24 18:28:02 ioBroker systemd[1]: Unmounting RPC Pipe File System...
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopping Session 3 of user pi.
                        Mar 24 18:28:02 ioBroker grafana-server[750]: t=2022-03-24T18:28:02+0100 lvl=info msg="Shutdown started" logger=server reason="System signal: terminated"
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopping Grafana instance...
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopped target Sound Card.
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopping Save/Restore Sound Card State...
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopped target Bluetooth.
                        Mar 24 18:28:02 ioBroker systemd[1]: systemd-rfkill.socket: Succeeded.
                        Mar 24 18:28:02 ioBroker bluetoothd[885]: Terminating
                        Mar 24 18:28:02 ioBroker systemd[1109]: run-rpc_pipefs.mount: Succeeded.
                        Mar 24 18:28:02 ioBroker systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopping Bluetooth service...
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopping Session 5 of user pi.
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopping Authorization Manager...
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopping Manage, Install and Generate Color Profiles...
                        Mar 24 18:28:02 ioBroker systemd[1]: systemd-tmpfiles-clean.timer: Succeeded.
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopped Daily Cleanup of Temporary Directories.
                        Mar 24 18:28:02 ioBroker systemd[1]: Unmounting /mnt/mySSD...
                        Mar 24 18:28:02 ioBroker systemd[1]: logrotate.timer: Succeeded.
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopped Daily rotation of log files.
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopped target Graphical Interface.
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopped target Multi-User System.
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopping Regular background program processing daemon...
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopping triggerhappy global hotkey daemon...
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopping dphys-swapfile - set up, mount/unmount, and delete a swap file...
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopping deCONZ: ZigBee gateway -- Update Service...
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopped target Login Prompts.
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopping Getty on tty1...
                        Mar 24 18:28:02 ioBroker systemd[1]: Stopping deCONZ: ZigBee gateway -- WIFI Service...
                        Mar 24 18:28:31 ioBroker systemd-modules-load[118]: Inserted module 'i2c_dev'
                        Mar 24 18:28:31 ioBroker fake-hwclock[117]: Do 24. Mär 17:28:09 UTC 2022
                        Mar 24 18:28:31 ioBroker systemd-fsck[144]: e2fsck 1.44.5 (15-Dec-2018)
                        Mar 24 18:28:31 ioBroker systemd-fsck[144]: rootfs: clean, 207316/1910656 files, 1637652/7725184 blocks
                        Mar 24 18:28:31 ioBroker systemd[1]: Started File System Check on Root Device.
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Remount Root and Kernel File Systems...
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Set the console keyboard layout.
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Remount Root and Kernel File Systems.
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Create System Users...
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Load/Save Random Seed...
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Flush Journal to Persistent Storage...
                        Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
                        Mar 24 18:28:31 ioBroker systemd[1]: Started udev Coldplug all Devices.
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Helper to synchronize boot up for ifupdown...
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Helper to synchronize boot up for ifupdown.
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Load/Save Random Seed.
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Create System Users.
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Create Static Device Nodes in /dev...
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Flush Journal to Persistent Storage.
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Create Static Device Nodes in /dev.
                        Mar 24 18:28:31 ioBroker systemd[1]: Reached target Local File Systems (Pre).
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting udev Kernel Device Manager...
                        Mar 24 18:28:31 ioBroker systemd[1]: Started udev Kernel Device Manager.
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Show Plymouth Boot Screen...
                        Mar 24 18:28:31 ioBroker systemd[1]: Received SIGRTMIN+20 from PID 170 (plymouthd).
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Show Plymouth Boot Screen.
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
                        Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
                        Mar 24 18:28:31 ioBroker systemd[1]: Reached target Local Encrypted Volumes.
                        Mar 24 18:28:31 ioBroker systemd-udevd[163]: Using default interface naming scheme 'v240'.
                        Mar 24 18:28:31 ioBroker mtp-probe: checking bus 1, device 3: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2"
                        Mar 24 18:28:31 ioBroker mtp-probe: bus: 1, device: 3 was not an MTP device
                        Mar 24 18:28:31 ioBroker mtp-probe: checking bus 2, device 2: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb2/2-1"
                        Mar 24 18:28:31 ioBroker mtp-probe: bus: 2, device: 2 was not an MTP device
                        Mar 24 18:28:31 ioBroker systemd[1]: Found device /dev/disk/by-partuuid/f0881a94-01.
                        Mar 24 18:28:31 ioBroker systemd-udevd[160]: Using default interface naming scheme 'v240'.
                        Mar 24 18:28:31 ioBroker usbmount[300]: /dev/sda does not contain a filesystem or disklabel
                        Mar 24 18:28:31 ioBroker systemd-udevd[169]: Process '/usr/share/usbmount/usbmount add' failed with exit code 1.
                        Mar 24 18:28:31 ioBroker systemd-udevd[159]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
                        Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in FUSE Control File System being skipped.
                        Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in Huge Pages File System being skipped.
                        Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
                        Mar 24 18:28:31 ioBroker systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting File System Check on /dev/disk/by-partuuid/f0881a94-01...
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Load/Save RF Kill Switch Status...
                        Mar 24 18:28:31 ioBroker usbmount[323]: executing command: mount -text4 -osync,noexec,nodev,noatime,nodiratime /dev/sda1 /media/usb0
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Load/Save RF Kill Switch Status.
                        Mar 24 18:28:31 ioBroker usbmount[323]: executing command: run-parts /etc/usbmount/mount.d
                        Mar 24 18:28:31 ioBroker systemd-fsck[340]: fsck.fat 4.1 (2017-01-24)
                        Mar 24 18:28:31 ioBroker systemd-fsck[340]: /dev/mmcblk0p1: 290 files, 98647/516190 clusters
                        Mar 24 18:28:31 ioBroker systemd[1]: Found device Portable_SSD 1.
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting File System Check on /dev/disk/by-uuid/49441976-e29b-4acc-a8ee-71f4eb91255c...
                        Mar 24 18:28:31 ioBroker systemd[1]: Started File System Check on /dev/disk/by-partuuid/f0881a94-01.
                        Mar 24 18:28:31 ioBroker systemd[1]: Mounting /boot...
                        Mar 24 18:28:31 ioBroker systemd[1]: Mounted /boot.
                        Mar 24 18:28:31 ioBroker systemd[1]: Reached target Local File Systems.
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Create Volatile Files and Directories...
                        Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
                        Mar 24 18:28:31 ioBroker systemd-fsck[376]: e2fsck 1.44.5 (15-Dec-2018)
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Raise network interfaces...
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Set console font and keymap...
                        Mar 24 18:28:31 ioBroker systemd-fsck[376]: /dev/sda1 is in use.
                        Mar 24 18:28:31 ioBroker systemd-fsck[376]: e2fsck: Cannot continue, aborting.
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Preprocess NFS configuration...
                        Mar 24 18:28:31 ioBroker systemd-fsck[376]: fsck failed with exit status 8.
                        Mar 24 18:28:31 ioBroker systemd-fsck[376]: Ignoring error.
                        Mar 24 18:28:31 ioBroker systemd[1]: plymouth-read-write.service: Succeeded.
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
                        Mar 24 18:28:31 ioBroker systemd[1]: Started File System Check on /dev/disk/by-uuid/49441976-e29b-4acc-a8ee-71f4eb91255c.
                        Mar 24 18:28:31 ioBroker systemd[1]: mnt-mySSD.mount: Directory /mnt/mySSD to mount over is not empty, mounting anyway.
                        Mar 24 18:28:31 ioBroker systemd[1]: Mounting /mnt/mySSD...
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Set console font and keymap.
                        Mar 24 18:28:31 ioBroker systemd[1]: nfs-config.service: Succeeded.
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Preprocess NFS configuration.
                        Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] Booting Linux on physical CPU 0x0
                        Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] Linux version 5.10.103-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1529 SMP Tue Mar 8 12:24:00 GMT 2022
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] CPU: div instructions available: patching division code
                        Mar 24 18:28:31 ioBroker systemd[1]: Reached target NFS client services.
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
                        Mar 24 18:28:31 ioBroker systemd[1]: Reached target Remote File Systems (Pre).
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] random: fast init done
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] Memory policy: Data cache writealloc
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
                        Mar 24 18:28:31 ioBroker systemd[1]: Reached target Remote File Systems.
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] Zone ranges:
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000]   Normal   empty
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] Movable zone start for each node
                        Mar 24 18:28:31 ioBroker systemd[1]: Mounted /mnt/mySSD.
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] Early memory node ranges
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] On node 0 totalpages: 1012736
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Create Volatile Files and Directories.
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000]   DMA zone: 1728 pages used for memmap
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000]   DMA zone: 0 pages reserved
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Network Time Synchronization...
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Update UTMP about System Boot/Shutdown...
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1011008
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Update UTMP about System Boot/Shutdown.
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:F2:36 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f0881a94-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles ip=192.168.1.95::192.168.0.1:255.255.128.0:ioBroker:eth0:off
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] Kernel parameter elevator= does not have any effect anymore.
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] Please use sysfs to set IO scheduler for individual devices.
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB)
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Raise network interfaces.
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] Memory: 3601140K/4050944K available (10240K kernel code, 1366K rwdata, 3196K rodata, 2048K init, 882K bss, 122124K reserved, 327680K cma-reserved, 3264512K highmem)
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Network Time Synchronization.
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] ftrace: allocating 34355 entries in 101 pages
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] ftrace: allocated 101 pages with 4 groups
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] rcu: Hierarchical RCU implementation.
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000]         Rude variant of Tasks RCU enabled.
                        Mar 24 18:28:31 ioBroker systemd[1]: Reached target System Time Synchronized.
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000]         Tracing variant of Tasks RCU enabled.
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                        Mar 24 18:28:31 ioBroker systemd[1]: Reached target System Initialization.
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
                        Mar 24 18:28:31 ioBroker kernel: [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1
                        Mar 24 18:28:31 ioBroker kernel: [    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
                        Mar 24 18:28:31 ioBroker kernel: [    0.000027] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
                        Mar 24 18:28:31 ioBroker kernel: [    0.000087] bcm2835: system timer (irq = 25)
                        Mar 24 18:28:31 ioBroker kernel: [    0.000731] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                        Mar 24 18:28:31 ioBroker kernel: [    0.000749] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                        Mar 24 18:28:31 ioBroker systemd[1]: Listening on D-Bus System Message Bus Socket.
                        Mar 24 18:28:31 ioBroker kernel: [    0.000768] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                        Mar 24 18:28:31 ioBroker kernel: [    0.000782] Switching to timer-based delay loop, resolution 18ns
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Daily Cleanup of Temporary Directories.
                        Mar 24 18:28:31 ioBroker kernel: [    0.001037] Console: colour dummy device 80x30
                        Mar 24 18:28:31 ioBroker kernel: [    0.001105] printk: console [tty1] enabled
                        Mar 24 18:28:31 ioBroker kernel: [    0.001157] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
                        Mar 24 18:28:31 ioBroker kernel: [    0.001189] pid_max: default: 32768 minimum: 301
                        Mar 24 18:28:31 ioBroker kernel: [    0.001355] LSM: Security Framework initializing
                        Mar 24 18:28:31 ioBroker kernel: [    0.001539] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                        Mar 24 18:28:31 ioBroker kernel: [    0.001565] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                        Mar 24 18:28:31 ioBroker systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
                        Mar 24 18:28:31 ioBroker kernel: [    0.003016] cgroup: Disabling memory control group subsystem
                        Mar 24 18:28:31 ioBroker kernel: [    0.003248] CPU: Testing write buffer coherency: ok
                        Mar 24 18:28:31 ioBroker kernel: [    0.003703] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Daily apt download activities.
                        Mar 24 18:28:31 ioBroker kernel: [    0.004910] Setting up static identity map for 0x200000 - 0x20003c
                        Mar 24 18:28:31 ioBroker kernel: [    0.005108] rcu: Hierarchical SRCU implementation.
                        Mar 24 18:28:31 ioBroker kernel: [    0.006026] smp: Bringing up secondary CPUs ...
                        Mar 24 18:28:31 ioBroker kernel: [    0.007235] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                        Mar 24 18:28:31 ioBroker kernel: [    0.008596] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Daily apt upgrade and clean activities.
                        Mar 24 18:28:31 ioBroker kernel: [    0.009885] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                        Mar 24 18:28:31 ioBroker kernel: [    0.010043] smp: Brought up 1 node, 4 CPUs
                        Mar 24 18:28:31 ioBroker kernel: [    0.010064] SMP: Total of 4 processors activated (432.00 BogoMIPS).
                        Mar 24 18:28:31 ioBroker kernel: [    0.010079] CPU: All CPU(s) started in HYP mode.
                        Mar 24 18:28:31 ioBroker systemd[1]: Listening on triggerhappy.socket.
                        Mar 24 18:28:31 ioBroker kernel: [    0.010102] CPU: Virtualization extensions available.
                        Mar 24 18:28:31 ioBroker kernel: [    0.010991] devtmpfs: initialized
                        Mar 24 18:28:31 ioBroker kernel: [    0.025185] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
                        Mar 24 18:28:31 ioBroker kernel: [    0.025417] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                        Mar 24 18:28:31 ioBroker systemd[1]: Started CUPS Scheduler.
                        Mar 24 18:28:31 ioBroker kernel: [    0.025448] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                        Mar 24 18:28:31 ioBroker systemd[1]: Reached target Paths.
                        Mar 24 18:28:31 ioBroker kernel: [    0.033687] pinctrl core: initialized pinctrl subsystem
                        Mar 24 18:28:31 ioBroker kernel: [    0.034765] NET: Registered protocol family 16
                        Mar 24 18:28:31 ioBroker kernel: [    0.038740] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                        Mar 24 18:28:31 ioBroker kernel: [    0.039509] audit: initializing netlink subsys (disabled)
                        Mar 24 18:28:31 ioBroker kernel: [    0.039765] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
                        Mar 24 18:28:31 ioBroker kernel: [    0.040347] thermal_sys: Registered thermal governor 'step_wise'
                        Mar 24 18:28:31 ioBroker kernel: [    0.041210] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                        Mar 24 18:28:31 ioBroker kernel: [    0.041227] hw-breakpoint: maximum watchpoint size is 8 bytes.
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Daily rotation of log files.
                        Mar 24 18:28:31 ioBroker kernel: [    0.041628] Serial: AMBA PL011 UART driver
                        Mar 24 18:28:31 ioBroker kernel: [    0.073692] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                        Mar 24 18:28:31 ioBroker kernel: [    0.090843] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-12-01T15:01:54, variant start
                        Mar 24 18:28:31 ioBroker kernel: [    0.100856] raspberrypi-firmware soc:firmware: Firmware hash is 71bd3109023a0c8575585ba87cbb374d2eeb038f
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Daily man-db regeneration.
                        Mar 24 18:28:31 ioBroker kernel: [    0.141989] Kprobes globally optimized
                        Mar 24 18:28:31 ioBroker kernel: [    0.147400] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                        Mar 24 18:28:31 ioBroker kernel: [    0.151590] vgaarb: loaded
                        Mar 24 18:28:31 ioBroker systemd[1]: Reached target Timers.
                        Mar 24 18:28:31 ioBroker kernel: [    0.152037] SCSI subsystem initialized
                        Mar 24 18:28:31 ioBroker kernel: [    0.152262] usbcore: registered new interface driver usbfs
                        Mar 24 18:28:31 ioBroker kernel: [    0.152322] usbcore: registered new interface driver hub
                        Mar 24 18:28:31 ioBroker kernel: [    0.152395] usbcore: registered new device driver usb
                        Mar 24 18:28:31 ioBroker systemd[1]: Listening on CUPS Scheduler.
                        Mar 24 18:28:31 ioBroker kernel: [    0.152731] usb_phy_generic phy: supply vcc not found, using dummy regulator
                        Mar 24 18:28:31 ioBroker kernel: [    0.154744] clocksource: Switched to clocksource arch_sys_counter
                        Mar 24 18:28:31 ioBroker kernel: [    1.099703] VFS: Disk quotas dquot_6.6.0
                        Mar 24 18:28:31 ioBroker kernel: [    1.099796] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                        Mar 24 18:28:31 ioBroker kernel: [    1.099958] FS-Cache: Loaded
                        Mar 24 18:28:31 ioBroker systemd[1]: Reached target Sockets.
                        Mar 24 18:28:31 ioBroker kernel: [    1.100170] CacheFiles: Loaded
                        Mar 24 18:28:31 ioBroker kernel: [    1.110354] NET: Registered protocol family 2
                        Mar 24 18:28:31 ioBroker kernel: [    1.110591] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
                        Mar 24 18:28:31 ioBroker systemd[1]: Reached target Basic System.
                        Mar 24 18:28:31 ioBroker kernel: [    1.112125] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                        Mar 24 18:28:31 ioBroker kernel: [    1.112169] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting System Logging Service...
                        Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
                        Mar 24 18:28:31 ioBroker systemd[1]: Started deCONZ: ZigBee gateway -- WIFI Service.
                        Mar 24 18:28:31 ioBroker systemd-timesyncd[401]: Synchronized to time server for the first time 136.243.66.91:123 (0.debian.pool.ntp.org).
                        Mar 24 18:28:31 ioBroker systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Disk Manager...
                        Mar 24 18:28:31 ioBroker systemd[1]: Started D-Bus System Message Bus.
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Configure Bluetooth Modems connected by UART...
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Check for v3d driver...
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting triggerhappy global hotkey daemon...
                        Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
                        Mar 24 18:28:31 ioBroker systemd[1]: Started Manage Sound Card State (restore and store).
                        Mar 24 18:28:31 ioBroker alsactl[461]: alsactl 1.1.8 daemon started
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Save/Restore Sound Card State...
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting rng-tools.service...
                        Mar 24 18:28:31 ioBroker rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
                        Mar 24 18:28:31 ioBroker rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="439" x-info="https://www.rsyslog.com"] start
                        Mar 24 18:28:31 ioBroker thd[458]: Found socket passed from systemd
                        Mar 24 18:28:31 ioBroker kernel: [    1.112234] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
                        Mar 24 18:28:31 ioBroker kernel: [    1.112301] TCP: Hash tables configured (established 8192 bind 8192)
                        Mar 24 18:28:31 ioBroker kernel: [    1.112461] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
                        Mar 24 18:28:31 ioBroker kernel: [    1.112497] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
                        Mar 24 18:28:31 ioBroker kernel: [    1.112742] NET: Registered protocol family 1
                        Mar 24 18:28:31 ioBroker kernel: [    1.113433] RPC: Registered named UNIX socket transport module.
                        Mar 24 18:28:31 ioBroker kernel: [    1.113449] RPC: Registered udp transport module.
                        Mar 24 18:28:31 ioBroker kernel: [    1.113463] RPC: Registered tcp transport module.
                        Mar 24 18:28:31 ioBroker kernel: [    1.113478] RPC: Registered tcp NFSv4.1 backchannel transport module.
                        Mar 24 18:28:31 ioBroker kernel: [    1.113502] PCI: CLS 0 bytes, default 64
                        Mar 24 18:28:31 ioBroker kernel: [    1.117337] Initialise system trusted keyrings
                        Mar 24 18:28:31 ioBroker kernel: [    1.117571] workingset: timestamp_bits=14 max_order=20 bucket_order=6
                        Mar 24 18:28:31 ioBroker kernel: [    1.125864] zbud: loaded
                        Mar 24 18:28:31 ioBroker kernel: [    1.127592] FS-Cache: Netfs 'nfs' registered for caching
                        Mar 24 18:28:31 ioBroker kernel: [    1.128353] NFS: Registering the id_resolver key type
                        Mar 24 18:28:31 ioBroker kernel: [    1.128389] Key type id_resolver registered
                        Mar 24 18:28:31 ioBroker kernel: [    1.128404] Key type id_legacy registered
                        Mar 24 18:28:31 ioBroker kernel: [    1.128548] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                        Mar 24 18:28:31 ioBroker kernel: [    1.128564] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
                        Mar 24 18:28:31 ioBroker kernel: [    1.129603] Key type asymmetric registered
                        Mar 24 18:28:31 ioBroker kernel: [    1.129620] Asymmetric key parser 'x509' registered
                        Mar 24 18:28:31 ioBroker kernel: [    1.129812] bounce: pool size: 64 pages
                        Mar 24 18:28:31 ioBroker kernel: [    1.129856] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
                        Mar 24 18:28:31 ioBroker kernel: [    1.130062] io scheduler mq-deadline registered
                        Mar 24 18:28:31 ioBroker kernel: [    1.130078] io scheduler kyber registered
                        Mar 24 18:28:31 ioBroker kernel: [    1.134489] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                        Mar 24 18:28:31 ioBroker kernel: [    1.134522] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                        Mar 24 18:28:31 ioBroker kernel: [    1.134603] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                        Mar 24 18:28:31 ioBroker kernel: [    1.134692] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
                        Mar 24 18:28:31 ioBroker kernel: [    1.196849] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                        Mar 24 18:28:31 ioBroker kernel: [    1.197233] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                        Mar 24 18:28:31 ioBroker kernel: [    1.197254] pci_bus 0000:00: root bus resource [bus 00-ff]
                        Mar 24 18:28:31 ioBroker kernel: [    1.197275] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                        Mar 24 18:28:31 ioBroker kernel: [    1.197365] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                        Mar 24 18:28:31 ioBroker kernel: [    1.197609] pci 0000:00:00.0: PME# supported from D0 D3hot
                        Mar 24 18:28:31 ioBroker kernel: [    1.201077] PCI: bus0: Fast back to back transfers disabled
                        Mar 24 18:28:31 ioBroker kernel: [    1.201450] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                        Mar 24 18:28:31 ioBroker kernel: [    1.201579] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                        Mar 24 18:28:31 ioBroker kernel: [    1.202014] pci 0000:01:00.0: PME# supported from D0 D3cold
                        Mar 24 18:28:31 ioBroker kernel: [    1.205479] PCI: bus1: Fast back to back transfers disabled
                        Mar 24 18:28:31 ioBroker kernel: [    1.205576] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                        Mar 24 18:28:31 ioBroker kernel: [    1.205601] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                        Mar 24 18:28:31 ioBroker kernel: [    1.205682] pci 0000:00:00.0: PCI bridge to [bus 01]
                        Mar 24 18:28:31 ioBroker kernel: [    1.205708] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                        Mar 24 18:28:31 ioBroker kernel: [    1.206131] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                        Mar 24 18:28:31 ioBroker kernel: [    1.206349] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
                        Mar 24 18:28:31 ioBroker kernel: [    1.215071] iproc-rng200 fe104000.rng: hwrng registered
                        Mar 24 18:28:31 ioBroker kernel: [    1.215381] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                        Mar 24 18:28:31 ioBroker kernel: [    1.216242] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                        Mar 24 18:28:31 ioBroker kernel: [    1.228478] brd: module loaded
                        Mar 24 18:28:31 ioBroker kernel: [    1.240727] loop: module loaded
                        Mar 24 18:28:31 ioBroker kernel: [    1.242456] Loading iSCSI transport class v2.0-870.
                        Mar 24 18:28:31 ioBroker kernel: [    1.247409] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                        Mar 24 18:28:31 ioBroker kernel: [    1.344907] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                        Mar 24 18:28:31 ioBroker kernel: [    1.346087] usbcore: registered new interface driver r8152
                        Mar 24 18:28:31 ioBroker kernel: [    1.346169] usbcore: registered new interface driver lan78xx
                        Mar 24 18:28:31 ioBroker kernel: [    1.346235] usbcore: registered new interface driver smsc95xx
                        Mar 24 18:28:31 ioBroker kernel: [    1.347872] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
                        Mar 24 18:28:31 ioBroker kernel: [    1.348035] xhci_hcd 0000:01:00.0: xHCI Host Controller
                        Mar 24 18:28:31 ioBroker kernel: [    1.348071] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                        Mar 24 18:28:31 ioBroker kernel: [    1.351436] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
                        Mar 24 18:28:31 ioBroker kernel: [    1.352763] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
                        Mar 24 18:28:31 ioBroker kernel: [    1.352783] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                        Mar 24 18:28:31 ioBroker kernel: [    1.352800] usb usb1: Product: xHCI Host Controller
                        Mar 24 18:28:31 ioBroker kernel: [    1.352817] usb usb1: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
                        Mar 24 18:28:31 ioBroker kernel: [    1.352834] usb usb1: SerialNumber: 0000:01:00.0
                        Mar 24 18:28:31 ioBroker kernel: [    1.353571] hub 1-0:1.0: USB hub found
                        Mar 24 18:28:31 ioBroker kernel: [    1.353669] hub 1-0:1.0: 1 port detected
                        Mar 24 18:28:31 ioBroker kernel: [    1.354339] xhci_hcd 0000:01:00.0: xHCI Host Controller
                        Mar 24 18:28:31 ioBroker kernel: [    1.354367] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                        Mar 24 18:28:31 ioBroker kernel: [    1.354392] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                        Mar 24 18:28:31 ioBroker kernel: [    1.354965] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
                        Mar 24 18:28:31 ioBroker kernel: [    1.354984] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                        Mar 24 18:28:31 ioBroker kernel: [    1.355001] usb usb2: Product: xHCI Host Controller
                        Mar 24 18:28:31 ioBroker kernel: [    1.355017] usb usb2: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
                        Mar 24 18:28:31 ioBroker kernel: [    1.355033] usb usb2: SerialNumber: 0000:01:00.0
                        Mar 24 18:28:31 ioBroker kernel: [    1.355744] hub 2-0:1.0: USB hub found
                        Mar 24 18:28:31 ioBroker kernel: [    1.355827] hub 2-0:1.0: 4 ports detected
                        Mar 24 18:28:31 ioBroker kernel: [    1.357502] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                        Mar 24 18:28:31 ioBroker kernel: [    1.357806] dwc_otg: FIQ enabled
                        Mar 24 18:28:31 ioBroker kernel: [    1.357821] dwc_otg: NAK holdoff enabled
                        Mar 24 18:28:31 ioBroker kernel: [    1.357835] dwc_otg: FIQ split-transaction FSM enabled
                        Mar 24 18:28:31 ioBroker kernel: [    1.357853] Module dwc_common_port init
                        Mar 24 18:28:31 ioBroker kernel: [    1.358316] usbcore: registered new interface driver uas
                        Mar 24 18:28:31 ioBroker kernel: [    1.358422] usbcore: registered new interface driver usb-storage
                        Mar 24 18:28:31 ioBroker kernel: [    1.358621] mousedev: PS/2 mouse device common for all mice
                        Mar 24 18:28:31 ioBroker kernel: [    1.360259] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                        Mar 24 18:28:31 ioBroker kernel: [    1.363566] sdhci: Secure Digital Host Controller Interface driver
                        Mar 24 18:28:31 ioBroker kernel: [    1.363582] sdhci: Copyright(c) Pierre Ossman
                        Mar 24 18:28:31 ioBroker kernel: [    1.364273] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                        Mar 24 18:28:31 ioBroker kernel: [    1.364878] sdhci-pltfm: SDHCI platform and OF driver helper
                        Mar 24 18:28:31 ioBroker kernel: [    1.368979] ledtrig-cpu: registered to indicate activity on CPUs
                        Mar 24 18:28:31 ioBroker kernel: [    1.369312] hid: raw HID events driver (C) Jiri Kosina
                        Mar 24 18:28:31 ioBroker kernel: [    1.369513] usbcore: registered new interface driver usbhid
                        Mar 24 18:28:31 ioBroker kernel: [    1.369528] usbhid: USB HID core driver
                        Mar 24 18:28:31 ioBroker kernel: [    1.375545] Initializing XFRM netlink socket
                        Mar 24 18:28:31 ioBroker kernel: [    1.375587] NET: Registered protocol family 17
                        Mar 24 18:28:31 ioBroker kernel: [    1.375709] Key type dns_resolver registered
                        Mar 24 18:28:31 ioBroker kernel: [    1.376181] Registering SWP/SWPB emulation handler
                        Mar 24 18:28:31 ioBroker kernel: [    1.376349] registered taskstats version 1
                        Mar 24 18:28:31 ioBroker kernel: [    1.376377] Loading compiled-in X.509 certificates
                        Mar 24 18:28:31 ioBroker kernel: [    1.377252] Key type ._fscrypt registered
                        Mar 24 18:28:31 ioBroker kernel: [    1.377268] Key type .fscrypt registered
                        Mar 24 18:28:31 ioBroker kernel: [    1.377283] Key type fscrypt-provisioning registered
                        Mar 24 18:28:31 ioBroker kernel: [    1.388800] uart-pl011 fe201000.serial: there is not valid maps for state default
                        Mar 24 18:28:31 ioBroker kernel: [    1.389104] uart-pl011 fe201000.serial: cts_event_workaround enabled
                        Mar 24 18:28:31 ioBroker kernel: [    1.389178] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
                        Mar 24 18:28:31 ioBroker kernel: [    1.395878] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                        Mar 24 18:28:31 ioBroker kernel: [    1.396958] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                        Mar 24 18:28:31 ioBroker kernel: [    1.396976] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                        Mar 24 18:28:31 ioBroker kernel: [    1.427233] of_cfs_init
                        Mar 24 18:28:31 ioBroker kernel: [    1.427502] of_cfs_init: OK
                        Mar 24 18:28:31 ioBroker kernel: [    1.447849] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                        Mar 24 18:28:31 ioBroker kernel: [    1.449537] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                        Mar 24 18:28:31 ioBroker kernel: [    1.451225] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                        Mar 24 18:28:31 ioBroker kernel: [    1.454243] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                        Mar 24 18:28:31 ioBroker kernel: [    1.455933] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                        Mar 24 18:28:31 ioBroker kernel: [    1.464035] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
                        Mar 24 18:28:31 ioBroker kernel: [    1.467908] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                        Mar 24 18:28:31 ioBroker kernel: [    1.468377] bcmgenet fd580000.ethernet eth0: Link is Down
                        Mar 24 18:28:31 ioBroker kernel: [    1.539345] mmc1: new high speed SDIO card at address 0001
                        Mar 24 18:28:31 ioBroker kernel: [    1.571836] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
                        Mar 24 18:28:31 ioBroker kernel: [    1.572715] mmcblk0: mmc0:aaaa SM32G 29.7 GiB
                        Mar 24 18:28:31 ioBroker kernel: [    1.574685]  mmcblk0: p1 p2
                        Mar 24 18:28:31 ioBroker kernel: [    1.634801] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                        Mar 24 18:28:31 ioBroker kernel: [    1.817708] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                        Mar 24 18:28:31 ioBroker kernel: [    1.817728] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                        Mar 24 18:28:31 ioBroker kernel: [    1.817746] usb 1-1: Product: USB2.0 Hub
                        Mar 24 18:28:31 ioBroker kernel: [    1.819641] hub 1-1:1.0: USB hub found
                        Mar 24 18:28:31 ioBroker kernel: [    1.819956] hub 1-1:1.0: 4 ports detected
                        Mar 24 18:28:31 ioBroker kernel: [    1.965140] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
                        Mar 24 18:28:31 ioBroker kernel: [    1.996737] usb 2-1: New USB device found, idVendor=152d, idProduct=0579, bcdDevice= 5.06
                        Mar 24 18:28:31 ioBroker kernel: [    1.996757] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                        Mar 24 18:28:31 ioBroker kernel: [    1.996774] usb 2-1: Product: Portable SSD
                        Mar 24 18:28:31 ioBroker kernel: [    1.996791] usb 2-1: Manufacturer: Intenso
                        Mar 24 18:28:31 ioBroker kernel: [    1.996808] usb 2-1: SerialNumber: 202104081005B
                        Mar 24 18:28:31 ioBroker kernel: [    2.020556] scsi host0: uas
                        Mar 24 18:28:31 ioBroker kernel: [    2.022077] scsi 0:0:0:0: Direct-Access     Intenso  Portable SSD     0506 PQ: 0 ANSI: 6
                        Mar 24 18:28:31 ioBroker kernel: [    2.144785] usb 1-1.2: new high-speed USB device number 3 using xhci_hcd
                        Mar 24 18:28:31 ioBroker kernel: [    2.286578] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=2838, bcdDevice= 1.00
                        Mar 24 18:28:31 ioBroker kernel: [    2.286598] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                        Mar 24 18:28:31 ioBroker kernel: [    2.286615] usb 1-1.2: Product: RTL2838UHIDIR
                        Mar 24 18:28:31 ioBroker kernel: [    2.286631] usb 1-1.2: Manufacturer: Realtek
                        Mar 24 18:28:31 ioBroker kernel: [    2.286648] usb 1-1.2: SerialNumber: 00000001
                        Mar 24 18:28:31 ioBroker kernel: [    2.394781] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
                        Mar 24 18:28:31 ioBroker kernel: [    2.533431] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
                        Mar 24 18:28:31 ioBroker kernel: [    2.533451] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                        Mar 24 18:28:31 ioBroker kernel: [    2.533468] usb 1-1.3: Product: ConBee II
                        Mar 24 18:28:31 ioBroker kernel: [    2.533484] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
                        Mar 24 18:28:31 ioBroker kernel: [    2.533501] usb 1-1.3: SerialNumber: DE2409981
                        Mar 24 18:28:31 ioBroker kernel: [    2.540150] sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
                        Mar 24 18:28:31 ioBroker kernel: [    2.540170] sd 0:0:0:0: [sda] 4096-byte physical blocks
                        Mar 24 18:28:31 ioBroker kernel: [    2.540435] sd 0:0:0:0: [sda] Write Protect is off
                        Mar 24 18:28:31 ioBroker kernel: [    2.540454] sd 0:0:0:0: [sda] Mode Sense: 53 00 00 08
                        Mar 24 18:28:31 ioBroker kernel: [    2.540929] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
                        Mar 24 18:28:31 ioBroker kernel: [    2.541753] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
                        Mar 24 18:28:31 ioBroker kernel: [    2.546234]  sda: sda1
                        Mar 24 18:28:31 ioBroker kernel: [    2.549985] sd 0:0:0:0: [sda] Attached SCSI disk
                        Mar 24 18:28:31 ioBroker kernel: [    5.595031] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
                        Mar 24 18:28:31 ioBroker kernel: [    5.634772] IP-Config: Complete:
                        Mar 24 18:28:31 ioBroker kernel: [    5.634795]      device=eth0, hwaddr=dc:a6:32:98:f2:36, ipaddr=192.168.1.95, mask=255.255.128.0, gw=192.168.0.1
                        Mar 24 18:28:31 ioBroker kernel: [    5.634812]      host=ioBroker, domain=, nis-domain=(none)
                        Mar 24 18:28:31 ioBroker kernel: [    5.634828]      bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath=
                        Mar 24 18:28:31 ioBroker kernel: [    5.657820] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                        Mar 24 18:28:31 ioBroker kernel: [    5.657893] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        Mar 24 18:28:31 ioBroker kernel: [    5.658691] devtmpfs: mounted
                        Mar 24 18:28:31 ioBroker kernel: [    5.668893] Freeing unused kernel memory: 2048K
                        Mar 24 18:28:31 ioBroker kernel: [    5.695082] Run /sbin/init as init process
                        Mar 24 18:28:31 ioBroker kernel: [    5.695097]   with arguments:
                        Mar 24 18:28:31 ioBroker kernel: [    5.695111]     /sbin/init
                        Mar 24 18:28:31 ioBroker kernel: [    5.695126]     splash
                        Mar 24 18:28:31 ioBroker kernel: [    5.695140]   with environment:
                        Mar 24 18:28:31 ioBroker kernel: [    5.695154]     HOME=/
                        Mar 24 18:28:31 ioBroker kernel: [    5.695168]     TERM=linux
                        Mar 24 18:28:31 ioBroker kernel: [    6.215554] NET: Registered protocol family 10
                        Mar 24 18:28:31 ioBroker kernel: [    6.217333] Segment Routing with IPv6
                        Mar 24 18:28:31 ioBroker kernel: [    7.080229] random: systemd: uninitialized urandom read (16 bytes read)
                        Mar 24 18:28:31 ioBroker kernel: [    7.091632] random: systemd: uninitialized urandom read (16 bytes read)
                        Mar 24 18:28:31 ioBroker kernel: [    7.095529] random: systemd: uninitialized urandom read (16 bytes read)
                        Mar 24 18:28:31 ioBroker kernel: [    7.216124] i2c /dev entries driver
                        Mar 24 18:28:31 ioBroker kernel: [    7.724093] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                        Mar 24 18:28:31 ioBroker kernel: [    8.458019] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                        Mar 24 18:28:31 ioBroker kernel: [    8.458580] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                        Mar 24 18:28:31 ioBroker kernel: [    8.459100] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                        Mar 24 18:28:31 ioBroker kernel: [    8.459608] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                        Mar 24 18:28:31 ioBroker kernel: [    8.517222] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                        Mar 24 18:28:31 ioBroker kernel: [    8.521149] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                        Mar 24 18:28:31 ioBroker kernel: [    8.521176] [vc_sm_connected_init]: start
                        Mar 24 18:28:31 ioBroker kernel: [    8.532574] mc: Linux media interface: v0.10
                        Mar 24 18:28:31 ioBroker kernel: [    8.533310] [vc_sm_connected_init]: installed successfully
                        Mar 24 18:28:31 ioBroker kernel: [    8.576553] videodev: Linux video capture interface: v2.00
                        Mar 24 18:28:31 ioBroker kernel: [    8.600858] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                        Mar 24 18:28:31 ioBroker kernel: [    8.603456] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                        Mar 24 18:28:31 ioBroker kernel: [    8.644995] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                        Mar 24 18:28:31 ioBroker kernel: [    8.646302] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                        Mar 24 18:28:31 ioBroker kernel: [    8.666285] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                        Mar 24 18:28:31 ioBroker kernel: [    8.668482] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                        Mar 24 18:28:31 ioBroker kernel: [    8.674404] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                        Mar 24 18:28:31 ioBroker kernel: [    8.681749] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                        Mar 24 18:28:31 ioBroker kernel: [    8.682261] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                        Mar 24 18:28:31 ioBroker kernel: [    8.682298] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                        Mar 24 18:28:31 ioBroker kernel: [    8.682339] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                        Mar 24 18:28:31 ioBroker kernel: [    8.682362] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                        Mar 24 18:28:31 ioBroker kernel: [    8.682385] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                        Mar 24 18:28:31 ioBroker kernel: [    8.682686] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                        Mar 24 18:28:31 ioBroker kernel: [    8.694033] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                        Mar 24 18:28:31 ioBroker kernel: [    8.714321] bcm2835_audio bcm2835_audio: card created with 8 channels
                        Mar 24 18:28:31 ioBroker kernel: [    8.748977] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                        Mar 24 18:28:31 ioBroker kernel: [    8.749025] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                        Mar 24 18:28:31 ioBroker kernel: [    8.798219] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                        Mar 24 18:28:31 ioBroker kernel: [    8.798287] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                        Mar 24 18:28:31 ioBroker kernel: [    8.814693] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                        Mar 24 18:28:31 ioBroker kernel: [    8.852223] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                        Mar 24 18:28:31 ioBroker kernel: [    8.852271] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                        Mar 24 18:28:31 ioBroker kernel: [    8.869747] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                        Mar 24 18:28:31 ioBroker kernel: [    8.898164] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                        Mar 24 18:28:31 ioBroker kernel: [    8.899042] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
                        Mar 24 18:28:31 ioBroker kernel: [    8.899087] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
                        Mar 24 18:28:31 ioBroker kernel: [    8.911116] [drm] No displays found. Consider forcing hotplug if HDMI is attached
                        Mar 24 18:28:31 ioBroker kernel: [    8.911243] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                        Mar 24 18:28:31 ioBroker kernel: [    8.911686] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                        Mar 24 18:28:31 ioBroker kernel: [    8.972204] brcmfmac: F1 signature read @0x18000000=0x15264345
                        Mar 24 18:28:31 ioBroker kernel: [    8.987589] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                        Mar 24 18:28:31 ioBroker kernel: [    8.988638] usbcore: registered new interface driver brcmfmac
                        Mar 24 18:28:31 ioBroker kernel: [    9.095451] usb 1-1.2: dvb_usb_v2: found a 'Realtek RTL2832U reference design' in warm state
                        Mar 24 18:28:31 ioBroker kernel: [    9.135627] usb 1-1.2: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
                        Mar 24 18:28:31 ioBroker kernel: [    9.135673] dvbdev: DVB: registering new adapter (Realtek RTL2832U reference design)
                        Mar 24 18:28:31 ioBroker kernel: [    9.135696] usb 1-1.2: media controller created
                        Mar 24 18:28:31 ioBroker kernel: [    9.140751] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
                        Mar 24 18:28:31 ioBroker kernel: [    9.203696] i2c i2c-22: Added multiplexed i2c bus 23
                        Mar 24 18:28:31 ioBroker kernel: [    9.203721] rtl2832 22-0010: Realtek RTL2832 successfully attached
                        Mar 24 18:28:31 ioBroker kernel: [    9.203852] usb 1-1.2: DVB: registering adapter 0 frontend 0 (Realtek RTL2832 (DVB-T))...
                        Mar 24 18:28:31 ioBroker kernel: [    9.203888] dvbdev: dvb_create_media_entity: media entity 'Realtek RTL2832 (DVB-T)' registered.
                        Mar 24 18:28:31 ioBroker kernel: [    9.248717] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
                        Mar 24 18:28:31 ioBroker kernel: [    9.257324] usbcore: registered new interface driver cdc_acm
                        Mar 24 18:28:31 ioBroker kernel: [    9.257343] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                        Mar 24 18:28:31 ioBroker kernel: [    9.267874] i2c i2c-23: fc0012: Fitipower FC0012 successfully identified
                        Mar 24 18:28:31 ioBroker kernel: [    9.278455] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                        Mar 24 18:28:31 ioBroker kernel: [    9.278615] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                        Mar 24 18:28:31 ioBroker kernel: [    9.290373] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                        Mar 24 18:28:31 ioBroker kernel: [    9.331843] rtl2832_sdr rtl2832_sdr.0.auto: Registered as swradio0
                        Mar 24 18:28:31 ioBroker kernel: [    9.331864] rtl2832_sdr rtl2832_sdr.0.auto: Realtek RTL2832 SDR attached
                        Mar 24 18:28:31 ioBroker kernel: [    9.331892] rtl2832_sdr rtl2832_sdr.0.auto: SDR API is still slightly experimental and functionality changes may follow
                        Mar 24 18:28:31 ioBroker kernel: [    9.341359] Registered IR keymap rc-empty
                        Mar 24 18:28:31 ioBroker kernel: [    9.341514] rc rc0: Realtek RTL2832U reference design as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/rc/rc0
                        Mar 24 18:28:31 ioBroker kernel: [    9.341750] rc rc0: lirc_dev: driver dvb_usb_rtl28xxu registered at minor = 0, raw IR receiver, no transmitter
                        Mar 24 18:28:31 ioBroker kernel: [    9.342034] input: Realtek RTL2832U reference design as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/rc/rc0/input0
                        Mar 24 18:28:31 ioBroker kernel: [    9.361375] usb 1-1.2: dvb_usb_v2: schedule remote query interval to 200 msecs
                        Mar 24 18:28:31 ioBroker kernel: [    9.369719] usb 1-1.2: dvb_usb_v2: 'Realtek RTL2832U reference design' successfully initialized and connected
                        Mar 24 18:28:31 ioBroker kernel: [    9.370054] usbcore: registered new interface driver dvb_usb_rtl28xxu
                        Mar 24 18:28:31 ioBroker kernel: [    9.650442] sd 0:0:0:0: Attached scsi generic sg0 type 0
                        Mar 24 18:28:31 ioBroker kernel: [   10.415477] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting WPA supplicant...
                        Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in Copy user wpa_supplicant.conf being skipped.
                        Mar 24 18:28:31 ioBroker systemd[1]: Started deCONZ: ZigBee gateway -- Update Service.
                        Mar 24 18:28:31 ioBroker rngd[500]: rngd 2-unofficial-mt.14 starting up...
                        Mar 24 18:28:31 ioBroker rng-tools[474]: Starting Hardware RNG entropy gatherer daemon: rngd.
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Login Service...
                        Mar 24 18:28:31 ioBroker systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
                        Mar 24 18:28:32 ioBroker rngd[500]: entropy feed to the kernel ready
                        Mar 24 18:28:32 ioBroker kernel: [   11.742196] random: crng init done
                        Mar 24 18:28:32 ioBroker kernel: [   11.742218] random: 7 urandom warning(s) missed due to ratelimiting
                        Mar 24 18:28:32 ioBroker systemd[1]: Started Regular background program processing daemon.
                        Mar 24 18:28:32 ioBroker kernel: [   11.767923] uart-pl011 fe201000.serial: no DMA platform data
                        Mar 24 18:28:32 ioBroker systemd[1]: Starting dhcpcd on all interfaces...
                        Mar 24 18:28:32 ioBroker udisksd[444]: udisks daemon version 2.8.1 starting
                        Mar 24 18:28:32 ioBroker systemd[1]: Starting Check for Raspberry Pi EEPROM updates...
                        Mar 24 18:28:32 ioBroker systemd[1]: Started System Logging Service.
                        Mar 24 18:28:32 ioBroker cron[523]: (CRON) INFO (pidfile fd = 3)
                        Mar 24 18:28:32 ioBroker systemd[1]: Started triggerhappy global hotkey daemon.
                        Mar 24 18:28:32 ioBroker systemd[1]: Started Check for v3d driver.
                        Mar 24 18:28:32 ioBroker systemd[1]: Started Save/Restore Sound Card State.
                        Mar 24 18:28:32 ioBroker systemd[1]: Started rng-tools.service.
                        Mar 24 18:28:32 ioBroker dphys-swapfile[443]: want /var/swap=100MByte, checking existing: keeping it
                        Mar 24 18:28:32 ioBroker avahi-daemon[518]: Found user 'avahi' (UID 108) and group 'avahi' (GID 113).
                        Mar 24 18:28:32 ioBroker avahi-daemon[518]: Successfully dropped root privileges.
                        Mar 24 18:28:32 ioBroker avahi-daemon[518]: avahi-daemon 0.7 starting up.
                        Mar 24 18:28:32 ioBroker systemd[1]: Reached target Sound Card.
                        Mar 24 18:28:32 ioBroker cron[523]: (CRON) INFO (Running @reboot jobs)
                        Mar 24 18:28:32 ioBroker dhcpcd[527]: dev: loaded udev
                        Mar 24 18:28:32 ioBroker kernel: [   12.056713] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
                        Mar 24 18:28:32 ioBroker kernel: [   12.173632] 8021q: 802.1Q VLAN Support v1.8
                        Mar 24 18:28:32 ioBroker systemd[1]: Started dphys-swapfile - set up, mount/unmount, and delete a swap file.
                        Mar 24 18:28:32 ioBroker avahi-daemon[518]: Successfully called chroot().
                        Mar 24 18:28:32 ioBroker avahi-daemon[518]: Successfully dropped remaining capabilities.
                        Mar 24 18:28:32 ioBroker wpa_supplicant[480]: Successfully initialized wpa_supplicant
                        Mar 24 18:28:32 ioBroker avahi-daemon[518]: No service file found in /etc/avahi/services.
                        Mar 24 18:28:32 ioBroker avahi-daemon[518]: Joining mDNS multicast group on interface eth0.IPv6 with address 2003:df:9708:f700:dea6:32ff:fe98:f236.
                        Mar 24 18:28:32 ioBroker avahi-daemon[518]: New relevant interface eth0.IPv6 for mDNS.
                        Mar 24 18:28:32 ioBroker avahi-daemon[518]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.95.
                        Mar 24 18:28:32 ioBroker avahi-daemon[518]: New relevant interface eth0.IPv4 for mDNS.
                        Mar 24 18:28:32 ioBroker avahi-daemon[518]: Network interface enumeration completed.
                        Mar 24 18:28:32 ioBroker avahi-daemon[518]: Registering new address record for 2003:df:9708:f700:dea6:32ff:fe98:f236 on eth0.*.
                        Mar 24 18:28:32 ioBroker avahi-daemon[518]: Registering new address record for 192.168.1.95 on eth0.IPv4.
                        Mar 24 18:28:32 ioBroker systemd[1]: deconz-init.service: Succeeded.
                        Mar 24 18:28:32 ioBroker systemd[1]: Started deCONZ: ZigBee gateway -- Initialisation.
                        Mar 24 18:28:32 ioBroker systemd[1]: Started Login Service.
                        Mar 24 18:28:32 ioBroker systemd[1]: Started WPA supplicant.
                        Mar 24 18:28:32 ioBroker systemd[1]: Started Avahi mDNS/DNS-SD Stack.
                        Mar 24 18:28:32 ioBroker systemd[1]: Started Make remote CUPS printers available locally.
                        Mar 24 18:28:32 ioBroker udisksd[444]: failed to load module crypto: libbd_crypto.so.2: cannot open shared object file: No such file or directory
                        Mar 24 18:28:32 ioBroker udisksd[444]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
                        Mar 24 18:28:32 ioBroker CRON[601]: (pi) CMD (RTL433.sh)
                        Mar 24 18:28:32 ioBroker CRON[602]: (pi) CMD (sudo service grafana-server start)
                        Mar 24 18:28:32 ioBroker CRON[553]: (CRON) info (No MTA installed, discarding output)
                        Mar 24 18:28:32 ioBroker udisksd[444]: Failed to load the 'mdraid' libblockdev plugin
                        Mar 24 18:28:32 ioBroker udisksd[444]: Failed to load the 'crypto' libblockdev plugin
                        Mar 24 18:28:32 ioBroker dbus-daemon[450]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.5' (uid=0 pid=444 comm="/usr/lib/udisks2/udisksd ")
                        Mar 24 18:28:32 ioBroker dhcpcd[527]: wlan0: starting wpa_supplicant
                        Mar 24 18:28:32 ioBroker dhcpcd-run-hooks[608]: wlan0: starting wpa_supplicant
                        Mar 24 18:28:32 ioBroker systemd[1]: Starting Authorization Manager...
                        Mar 24 18:28:33 ioBroker kernel: [   12.753109] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                        Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]: Skipping automatic bootloader upgrade. current 1599135103 >= min 1599135103
                        Mar 24 18:28:33 ioBroker raspi-config[442]: Checking if shift key is held down: No. Switching to ondemand scaling governor.
                        Mar 24 18:28:33 ioBroker dbus-daemon[450]: [system] Activating via systemd: service name='org.freedesktop.ColorManager' unit='colord.service' requested by ':1.7' (uid=0 pid=489 comm="/usr/sbin/cupsd -l ")
                        Mar 24 18:28:33 ioBroker dhcpcd[527]: wlan0: connected to Access Point `'
                        Mar 24 18:28:33 ioBroker dhcpcd[527]: DUID 00:01:00:01:28:de:03:31:dc:a6:32:98:f2:36
                        Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: IAID 32:98:f2:36
                        Mar 24 18:28:33 ioBroker dhcpcd[527]: wlan0: waiting for carrier
                        Mar 24 18:28:33 ioBroker avahi-daemon[518]: Server startup complete. Host name is ioBroker.local. Local service cookie is 4148147162.
                        Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: soliciting an IPv6 router
                        Mar 24 18:28:33 ioBroker deCONZ[441]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
                        Mar 24 18:28:33 ioBroker polkitd[610]: started daemon version 0.105 using authority implementation `local' version `0.105'
                        Mar 24 18:28:33 ioBroker dbus-daemon[450]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
                        Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]: BOOTLOADER: up to date
                        Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]:    CURRENT: Do 3. Sep 12:11:43 UTC 2020 (1599135103)
                        Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]:     LATEST: Di 25. Jan 14:30:41 UTC 2022 (1643121041)
                        Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]:    RELEASE: default (/lib/firmware/raspberrypi/bootloader/default)
                        Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]:             Use raspi-config to change the release.
                        Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]:   VL805_FW: Dedicated VL805 EEPROM
                        Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: Router Advertisement from fe80::1eed:6fff:fef5:ea4b
                        Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]:      VL805: up to date
                        Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]:    CURRENT: 000138a1
                        Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]:     LATEST: 000138a1
                        Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: adding address 2003:df:9708:f700:1fc5:fc3:682:3af1/64
                        Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: adding route to 2003:df:9708:f700::/64
                        Mar 24 18:28:33 ioBroker avahi-daemon[518]: Registering new address record for 2003:df:9708:f700:1fc5:fc3:682:3af1 on eth0.*.
                        Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: adding default route via fe80::1eed:6fff:fef5:ea4b
                        Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: requesting DHCPv6 information
                        Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: pid -864491050 deleted route to 2003:df:9708:f700::/64
                        Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: pid -303060302 deleted default route via fe80::1eed:6fff:fef5:ea4b
                        Mar 24 18:28:33 ioBroker kernel: [   13.381027] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                        Mar 24 18:28:33 ioBroker udisksd[444]: Acquired the name org.freedesktop.UDisks2 on the system message bus
                        Mar 24 18:28:33 ioBroker influxd-systemd-start.sh[438]: Merging with configuration at: /etc/influxdb/influxdb.conf
                        Mar 24 18:28:33 ioBroker influxd-systemd-start.sh[438]: ts=2022-03-24T17:28:33.878051Z lvl=info msg="InfluxDB starting" log_id=0_RFPqLW000 version=1.8.10 branch=1.8 commit=688e697c51fd
                        Mar 24 18:28:33 ioBroker influxd-systemd-start.sh[438]: ts=2022-03-24T17:28:33.878102Z lvl=info msg="Go runtime" log_id=0_RFPqLW000 version=go1.13.8 maxprocs=4
                        Mar 24 18:28:33 ioBroker influxd-systemd-start.sh[438]: ts=2022-03-24T17:28:33.902142Z lvl=info msg="Using data dir" log_id=0_RFPqLW000 service=store path=/mnt/mySSD/InfluxDB/data
                        Mar 24 18:28:33 ioBroker influxd-systemd-start.sh[438]: ts=2022-03-24T17:28:33.902266Z lvl=info msg="Compaction settings" log_id=0_RFPqLW000 service=store max_concurrent_compactions=2 throughput_bytes_per_second=50331648 throughput_bytes_per_second_burst=50331648
                        Mar 24 18:28:33 ioBroker influxd-systemd-start.sh[438]: ts=2022-03-24T17:28:33.902334Z lvl=info msg="Open store (start)" log_id=0_RFPqLW000 service=store trace_id=0_RFPqRW000 op_name=tsdb_open op_event=start
                        Mar 24 18:28:34 ioBroker dhcpcd[527]: eth0: rebinding lease of 192.168.1.99
                        Mar 24 18:28:34 ioBroker deCONZ[441]: libpng warning: iCCP: known incorrect sRGB profile
                        Mar 24 18:28:34 ioBroker influxd-systemd-start.sh[438]: ts=2022-03-24T17:28:34.077833Z lvl=info msg="Opened file" log_id=0_RFPqLW000 engine=tsm1 service=filestore path=/mnt/mySSD/InfluxDB/data/_internal/monitor/133/000000018-000000002.tsm id=0 duration=34.840ms
                        Mar 24 18:28:34 ioBroker influxd-systemd-start.sh[438]: ts=2022-03-24T17:28:34.094170Z lvl=info msg="Opened file" log_id=0_RFPqLW000 engine=tsm1 service=filestore path=/mnt/mySSD/InfluxDB/data/_internal/monitor/139/000000016-000000001.tsm id=1 duration=50.352ms
                        Mar 24 18:28:34 ioBroker influxd-systemd-start.sh[438]: ts=2022-03-24T17:28:34.074068Z lvl=info msg="Opened file" log_id=0_RFPqLW000 engine=tsm1 service=filestore path=/mnt/mySSD/InfluxDB/data/_internal/monitor/139/000000014-000000002.tsm id=0 duration=29.954ms
                        Mar 24 18:28:34 ioBroker dhcpcd[527]: eth0: probing address 192.168.1.99/17
                        Mar 24 18:28:34 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 1 attempts...
                        Mar 24 18:28:34 ioBroker dhcpcd[527]: eth0: adding route to 2003:df:9708:f700::/64
                        Mar 24 18:28:34 ioBroker dhcpcd[527]: eth0: adding default route via fe80::1eed:6fff:fef5:ea4b
                        Mar 24 18:28:34 ioBroker dhcpcd[527]: Too few arguments.
                        Mar 24 18:28:35 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 2 attempts...
                        Mar 24 18:28:35 ioBroker deCONZ[441]: This plugin does not support propagateSizeHints()
                        Mar 24 18:28:36 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 3 attempts...
                        Mar 24 18:28:36 ioBroker systemd[1]: systemd-rfkill.service: Succeeded.
                        Mar 24 18:28:36 ioBroker systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
                        Mar 24 18:28:36 ioBroker systemd[1]: Started Check for Raspberry Pi EEPROM updates.
                        Mar 24 18:28:36 ioBroker systemd[1]: Started Authorization Manager.
                        Mar 24 18:28:36 ioBroker systemd[1]: Started Disk Manager.
                        Mar 24 18:28:36 ioBroker systemd[1]: Starting Manage, Install and Generate Color Profiles...
                        Mar 24 18:28:36 ioBroker dbus-daemon[450]: [system] Successfully activated service 'org.freedesktop.ColorManager'
                        Mar 24 18:28:36 ioBroker systemd[1]: Started Manage, Install and Generate Color Profiles.
                        Mar 24 18:28:36 ioBroker colord[735]: failed to get session [pid 489]: Keine Daten verfügbar
                        Mar 24 18:28:36 ioBroker systemd[1]: Started Grafana instance.
                        Mar 24 18:28:37 ioBroker colord-sane: [bjnp] create_broadcast_socket: ERROR - bind socket to local address failed - Cannot assign requested address
                        Mar 24 18:28:37 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 4 attempts...
                        Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Starting Grafana" logger=server version=7.4.3 commit=010f20c1c8 branch=HEAD compiled=2021-02-24T11:29:10+0100
                        Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Config loaded from" logger=settings file=/usr/share/grafana/conf/defaults.ini
                        Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Config loaded from" logger=settings file=/etc/grafana/grafana.ini
                        Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.data=/var/lib/grafana"
                        Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.logs=/var/log/grafana"
                        Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.plugins=/var/lib/grafana/plugins"
                        Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.provisioning=/etc/grafana/provisioning"
                        Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Path Home" logger=settings path=/usr/share/grafana
                        Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Path Data" logger=settings path=/var/lib/grafana
                        Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Path Logs" logger=settings path=/var/log/grafana
                        Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Path Plugins" logger=settings path=/var/lib/grafana/plugins
                        Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Path Provisioning" logger=settings path=/etc/grafana/provisioning
                        Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="App mode production" logger=settings
                        Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Writing PID file" logger=server path=/var/run/grafana/grafana-server.pid pid=763
                        Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Connecting to DB" logger=sqlstore dbtype=sqlite3
                        Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=warn msg="SQLite database file has broader permissions than it should" logger=sqlstore path=/var/lib/grafana/grafana.db mode=-rw-r--r-- expected=-rw-r-----
                        Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Starting DB migrations" logger=migrator
                        Mar 24 18:28:38 ioBroker grafana-server[763]: t=2022-03-24T18:28:38+0100 lvl=info msg="Starting plugin search" logger=plugins
                        Mar 24 18:28:38 ioBroker deCONZ[441]: This plugin does not support propagateSizeHints()
                        Mar 24 18:28:38 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 5 attempts...
                        Mar 24 18:28:38 ioBroker dhcpcd[527]: wlan0: carrier acquired
                        Mar 24 18:28:38 ioBroker dhcpcd[527]: wlan0: connected to Access Point `WiFi-WZ'
                        Mar 24 18:28:38 ioBroker dhcpcd[527]: wlan0: IAID 32:98:f2:37
                        Mar 24 18:28:38 ioBroker dhcpcd[527]: wlan0: adding address fe80::9413:2652:11a6:f9f8
                        Mar 24 18:28:38 ioBroker kernel: [   18.406169] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
                        Mar 24 18:28:38 ioBroker avahi-daemon[518]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::9413:2652:11a6:f9f8.
                        Mar 24 18:28:38 ioBroker avahi-daemon[518]: New relevant interface wlan0.IPv6 for mDNS.
                        Mar 24 18:28:38 ioBroker avahi-daemon[518]: Registering new address record for fe80::9413:2652:11a6:f9f8 on wlan0.*.
                        Mar 24 18:28:38 ioBroker dhcpcd[527]: eth0: leased 192.168.1.99 for 864000 seconds
                        Mar 24 18:28:38 ioBroker dhcpcd[527]: eth0: adding route to 192.168.0.0/17
                        Mar 24 18:28:38 ioBroker dhcpcd[527]: eth0: adding default route via 192.168.0.1
                        Mar 24 18:28:38 ioBroker avahi-daemon[518]: Registering new address record for 192.168.1.99 on eth0.IPv4.
                        Mar 24 18:28:38 ioBroker dhcpcd[527]: Too few arguments.
                        Mar 24 18:28:38 ioBroker dhcpcd[527]: forked to background, child pid 828
                        Mar 24 18:28:38 ioBroker systemd[1]: Started dhcpcd on all interfaces.
                        Mar 24 18:28:38 ioBroker systemd[1]: Reached target Network.
                        Mar 24 18:28:38 ioBroker systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
                        Mar 24 18:28:38 ioBroker systemd[1]: Starting /etc/rc.local Compatibility...
                        Mar 24 18:28:38 ioBroker systemd[1]: Starting xrdp session manager...
                        Mar 24 18:28:38 ioBroker systemd[1]: Starting OpenBSD Secure Shell server...
                        Mar 24 18:28:38 ioBroker systemd[1]: Starting Permit User Sessions...
                        Mar 24 18:28:38 ioBroker systemd[1]: Started /etc/rc.local Compatibility.
                        Mar 24 18:28:39 ioBroker dhcpcd[828]: eth0: pid -1772649969 deleted route to 192.168.0.0/17
                        Mar 24 18:28:39 ioBroker dhcpcd[828]: eth0: pid -1131099856 deleted default route via 192.168.0.1
                        Mar 24 18:28:39 ioBroker xrdp-sesman[830]: (830)(-1225199680)[DEBUG] libscp initialized
                        Mar 24 18:28:39 ioBroker systemd[1]: Started Permit User Sessions.
                        Mar 24 18:28:39 ioBroker systemd[1]: Starting Light Display Manager...
                        Mar 24 18:28:39 ioBroker systemd[1]: Starting Hold until boot process finishes up...
                        Mar 24 18:28:39 ioBroker xrdp-sesman[830]: (830)(-1225199680)[DEBUG] Testing if xrdp-sesman can listen on 127.0.0.1 port 3350.
                        Mar 24 18:28:39 ioBroker xrdp-sesman[830]: (830)(-1225199680)[DEBUG] Closed socket 1 (AF_INET6 ::1 port 3350)
                        Mar 24 18:28:39 ioBroker xrdp-sesman[838]: (838)(-1225199680)[INFO ] starting xrdp-sesman with pid 838
                        Mar 24 18:28:39 ioBroker systemd[1]: Started xrdp session manager.
                        Mar 24 18:28:39 ioBroker xrdp-sesman[838]: (838)(-1225199680)[INFO ] listening to port 3350 on 127.0.0.1
                        Mar 24 18:28:39 ioBroker systemd[1]: Starting xrdp daemon...
                        Mar 24 18:28:39 ioBroker systemd[1]: Started OpenBSD Secure Shell server.
                        Mar 24 18:28:39 ioBroker lightdm[837]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
                        Mar 24 18:28:39 ioBroker xrdp[851]: (851)(-1225418624)[DEBUG] Testing if xrdp can listen on 0.0.0.0 port 3389.
                        Mar 24 18:28:39 ioBroker xrdp[851]: (851)(-1225418624)[DEBUG] Closed socket 7 (AF_INET6 :: port 3389)
                        Mar 24 18:28:39 ioBroker systemd[1]: Received SIGRTMIN+21 from PID 170 (plymouthd).
                        Mar 24 18:28:39 ioBroker systemd[1]: plymouth-start.service: Succeeded.
                        Mar 24 18:28:39 ioBroker systemd[1]: plymouth-quit-wait.service: Succeeded.
                        Mar 24 18:28:39 ioBroker systemd[1]: Started Hold until boot process finishes up.
                        Mar 24 18:28:39 ioBroker systemd[1]: Started Getty on tty1.
                        Mar 24 18:28:39 ioBroker systemd[1]: Reached target Login Prompts.
                        Mar 24 18:28:39 ioBroker lightdm[837]: Could not enumerate user data directory /var/lib/lightdm/data: Error opening directory '/var/lib/lightdm/data': No such file or directory
                        Mar 24 18:28:39 ioBroker systemd[1]: Started Light Display Manager.
                        Mar 24 18:28:39 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 6 attempts...
                        Mar 24 18:28:39 ioBroker systemd[1]: xrdp.service: Can't open PID file /run/xrdp/xrdp.pid (yet?) after start: No such file or directory
                        Mar 24 18:28:39 ioBroker dhcpcd[828]: wlan0: rebinding lease of 192.168.1.193
                        Mar 24 18:28:39 ioBroker dhcpcd[828]: wlan0: soliciting an IPv6 router
                        Mar 24 18:28:39 ioBroker dhcpcd[828]: wlan0: probing address 192.168.1.193/17
                        Mar 24 18:28:39 ioBroker grafana-server[763]: t=2022-03-24T18:28:39+0100 lvl=info msg="Registering plugin" logger=plugins id=input
                        Mar 24 18:28:40 ioBroker grafana-server[763]: t=2022-03-24T18:28:40+0100 lvl=info msg="HTTP Server Listen" logger=http.server address=[::]:3000 protocol=http subUrl= socket=
                        Mar 24 18:28:40 ioBroker systemd[1]: Started xrdp daemon.
                        Mar 24 18:28:40 ioBroker kernel: [   19.918364] Bluetooth: Core ver 2.22
                        Mar 24 18:28:40 ioBroker kernel: [   19.918428] NET: Registered protocol family 31
                        Mar 24 18:28:40 ioBroker kernel: [   19.918434] Bluetooth: HCI device and connection manager initialized
                        Mar 24 18:28:40 ioBroker kernel: [   19.919042] Bluetooth: HCI socket layer initialized
                        Mar 24 18:28:40 ioBroker kernel: [   19.919053] Bluetooth: L2CAP socket layer initialized
                        Mar 24 18:28:40 ioBroker kernel: [   19.919072] Bluetooth: SCO socket layer initialized
                        Mar 24 18:28:40 ioBroker kernel: [   19.937773] Bluetooth: HCI UART driver ver 2.3
                        Mar 24 18:28:40 ioBroker kernel: [   19.937784] Bluetooth: HCI UART protocol H4 registered
                        Mar 24 18:28:40 ioBroker kernel: [   19.937837] Bluetooth: HCI UART protocol Three-wire (H5) registered
                        Mar 24 18:28:40 ioBroker kernel: [   19.937978] Bluetooth: HCI UART protocol Broadcom registered
                        Mar 24 18:28:40 ioBroker btuart[451]: bcm43xx_init
                        Mar 24 18:28:40 ioBroker btuart[451]: Flash firmware /lib/firmware/brcm/BCM4345C0.hcd
                        Mar 24 18:28:40 ioBroker btuart[451]: Set Controller UART speed to 3000000 bit/s
                        Mar 24 18:28:40 ioBroker btuart[451]: Device setup complete
                        Mar 24 18:28:40 ioBroker systemd[1]: Starting Load/Save RF Kill Switch Status...
                        Mar 24 18:28:40 ioBroker systemd[1]: Started Configure Bluetooth Modems connected by UART.
                        Mar 24 18:28:40 ioBroker systemd[1]: Started Load/Save RF Kill Switch Status.
                        Mar 24 18:28:40 ioBroker systemd[1]: Created slice system-bthelper.slice.
                        Mar 24 18:28:40 ioBroker systemd[1]: Starting Raspberry Pi bluetooth helper...
                        Mar 24 18:28:40 ioBroker bthelper[880]: Raspberry Pi BDADDR already set
                        Mar 24 18:28:40 ioBroker systemd[1]: Started Raspberry Pi bluetooth helper.
                        Mar 24 18:28:40 ioBroker systemd[1]: Starting Bluetooth service...
                        Mar 24 18:28:40 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 7 attempts...
                        Mar 24 18:28:40 ioBroker bluetoothd[891]: Bluetooth daemon 5.50
                        Mar 24 18:28:40 ioBroker systemd[1]: Started Bluetooth service.
                        Mar 24 18:28:40 ioBroker systemd[1]: Reached target Bluetooth.
                        Mar 24 18:28:40 ioBroker bluetoothd[891]: Starting SDP server
                        Mar 24 18:28:40 ioBroker bluetoothd[891]: Bluetooth management interface 1.18 initialized
                        Mar 24 18:28:40 ioBroker dbus-daemon[450]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.20' (uid=0 pid=891 comm="/usr/lib/bluetooth/bluetoothd ")
                        Mar 24 18:28:40 ioBroker kernel: [   20.225799] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                        Mar 24 18:28:40 ioBroker kernel: [   20.225809] Bluetooth: BNEP filters: protocol multicast
                        Mar 24 18:28:40 ioBroker kernel: [   20.225822] Bluetooth: BNEP socket layer initialized
                        Mar 24 18:28:40 ioBroker bluetoothd[891]: Sap driver initialization failed.
                        Mar 24 18:28:40 ioBroker bluetoothd[891]: sap-server: Operation not permitted (1)
                        Mar 24 18:28:40 ioBroker systemd[1]: Starting Hostname Service...
                        Mar 24 18:28:40 ioBroker dbus-daemon[450]: [system] Successfully activated service 'org.freedesktop.hostname1'
                        Mar 24 18:28:40 ioBroker systemd[1]: Started Hostname Service.
                        Mar 24 18:28:40 ioBroker bluetoothd[891]: Failed to set privacy: Rejected (0x0b)
                        Mar 24 18:28:40 ioBroker dhcpcd[828]: eth0: Router Advertisement from fe80::1eed:6fff:fef5:ea4b
                        Mar 24 18:28:40 ioBroker dhcpcd[828]: wlan0: Router Advertisement from fe80::1eed:6fff:fef5:ea4b
                        Mar 24 18:28:40 ioBroker dhcpcd[828]: wlan0: adding address 2003:df:9708:f700:eb20:e7f4:fc6d:c2d0/64
                        Mar 24 18:28:40 ioBroker avahi-daemon[518]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::9413:2652:11a6:f9f8.
                        Mar 24 18:28:40 ioBroker avahi-daemon[518]: Joining mDNS multicast group on interface wlan0.IPv6 with address 2003:df:9708:f700:eb20:e7f4:fc6d:c2d0.
                        Mar 24 18:28:40 ioBroker avahi-daemon[518]: Registering new address record for 2003:df:9708:f700:eb20:e7f4:fc6d:c2d0 on wlan0.*.
                        Mar 24 18:28:40 ioBroker avahi-daemon[518]: Withdrawing address record for fe80::9413:2652:11a6:f9f8 on wlan0.
                        Mar 24 18:28:40 ioBroker dhcpcd[828]: wlan0: adding route to 2003:df:9708:f700::/64
                        Mar 24 18:28:40 ioBroker dhcpcd[828]: wlan0: requesting DHCPv6 information
                        Mar 24 18:28:40 ioBroker dhcpcd[828]: eth0: fe80::1eed:6fff:fef5:ea4b is reachable again
                        Mar 24 18:28:40 ioBroker dhcpcd[828]: wlan0: adding default route via fe80::1eed:6fff:fef5:ea4b
                        Mar 24 18:28:41 ioBroker xrdp[854]: (854)(-1225418624)[INFO ] starting xrdp with pid 854
                        Mar 24 18:28:41 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 8 attempts...
                        Mar 24 18:28:42 ioBroker xrdp[854]: (854)(-1225418624)[INFO ] listening to port 3389 on 0.0.0.0
                        Mar 24 18:28:42 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 9 attempts...
                        Mar 24 18:28:42 ioBroker dhcpcd[828]: eth0: fe80::1eed:6fff:fef5:ea4b is reachable again
                        Mar 24 18:28:43 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 10 attempts...
                        Mar 24 18:28:44 ioBroker dhcpcd[828]: wlan0: leased 192.168.1.193 for 864000 seconds
                        Mar 24 18:28:44 ioBroker avahi-daemon[518]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.193.
                        Mar 24 18:28:44 ioBroker avahi-daemon[518]: New relevant interface wlan0.IPv4 for mDNS.
                        Mar 24 18:28:44 ioBroker avahi-daemon[518]: Registering new address record for 192.168.1.193 on wlan0.IPv4.
                        Mar 24 18:28:44 ioBroker dhcpcd[828]: eth0: adding route to 192.168.0.0/17
                        Mar 24 18:28:44 ioBroker dhcpcd[828]: eth0: adding default route via 192.168.0.1
                        Mar 24 18:28:44 ioBroker dhcpcd[828]: wlan0: adding route to 192.168.0.0/17
                        Mar 24 18:28:44 ioBroker dhcpcd[828]: wlan0: adding default route via 192.168.0.1
                        Mar 24 18:28:44 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 11 attempts...
                        Mar 24 18:28:45 ioBroker systemd[1]: systemd-rfkill.service: Succeeded.
                        Mar 24 18:28:45 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 12 attempts...
                        Mar 24 18:28:46 ioBroker colord[735]: failed to get session [pid 489]: Keine Daten verfügbar
                        Mar 24 18:28:46 ioBroker systemd[1]: Created slice User Slice of UID 1000.
                        Mar 24 18:28:46 ioBroker systemd[1]: Starting User Runtime Directory /run/user/1000...
                        Mar 24 18:28:46 ioBroker kernel: [   26.055839] broken atomic modeset userspace detected, disabling atomic
                        Mar 24 18:28:46 ioBroker bthelper[880]: Changing power off succeeded
                        Mar 24 18:28:46 ioBroker bthelper[880]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:98:F2:38 Powered: no
                        Mar 24 18:28:46 ioBroker bthelper[880]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:98:F2:38 Discovering: no
                        Mar 24 18:28:46 ioBroker systemd[1]: Started User Runtime Directory /run/user/1000.
                        Mar 24 18:28:46 ioBroker systemd[1]: Starting User Manager for UID 1000...
                        Mar 24 18:28:46 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 13 attempts...
                        Mar 24 18:28:46 ioBroker bthelper[880]: Changing power on succeeded
                        Mar 24 18:28:47 ioBroker systemd[1082]: Listening on GnuPG cryptographic agent and passphrase cache.
                        Mar 24 18:28:47 ioBroker systemd[1082]: Listening on Sound System.
                        Mar 24 18:28:47 ioBroker systemd[1082]: Starting D-Bus User Message Bus Socket.
                        Mar 24 18:28:47 ioBroker systemd[1082]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
                        Mar 24 18:28:47 ioBroker systemd[1082]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
                        Mar 24 18:28:47 ioBroker systemd[1082]: Reached target Timers.
                        Mar 24 18:28:47 ioBroker systemd[1082]: Reached target Paths.
                        Mar 24 18:28:47 ioBroker systemd[1082]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
                        Mar 24 18:28:47 ioBroker systemd[1082]: Listening on GnuPG network certificate management daemon.
                        Mar 24 18:28:47 ioBroker systemd[1082]: Listening on D-Bus User Message Bus Socket.
                        Mar 24 18:28:47 ioBroker systemd[1082]: Reached target Sockets.
                        Mar 24 18:28:47 ioBroker systemd[1082]: Reached target Basic System.
                        Mar 24 18:28:47 ioBroker systemd[1082]: Reached target Default.
                        Mar 24 18:28:47 ioBroker systemd[1]: Started User Manager for UID 1000.
                        Mar 24 18:28:47 ioBroker systemd[1082]: Startup finished in 612ms.
                        Mar 24 18:28:47 ioBroker systemd[1]: Started Session 3 of user pi.
                        Mar 24 18:28:47 ioBroker systemd[1]: Started Session 5 of user pi.
                        Mar 24 18:28:47 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 14 attempts...
                        Mar 24 18:28:47 ioBroker kernel: [   27.436514] broken atomic modeset userspace detected, disabling atomic
                        Mar 24 18:28:47 ioBroker systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
                        Mar 24 18:28:47 ioBroker systemd[1]: lightdm.service: Failed with result 'exit-code'.
                        Mar 24 18:28:47 ioBroker systemd[1]: lightdm.service: Service RestartSec=100ms expired, scheduling restart.
                        Mar 24 18:28:47 ioBroker systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 1.
                        Mar 24 18:28:47 ioBroker systemd[1]: Stopped Light Display Manager.
                        Mar 24 18:28:47 ioBroker systemd[1]: Starting Light Display Manager...
                        Mar 24 18:28:47 ioBroker lightdm[1135]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
                        Mar 24 18:28:47 ioBroker lightdm[1135]: Could not enumerate user data directory /var/lib/lightdm/data: Error opening directory '/var/lib/lightdm/data': No such file or directory
                        Mar 24 18:28:47 ioBroker systemd[1]: Started Light Display Manager.
                        Mar 24 18:28:48 ioBroker kernel: [   28.232466] broken atomic modeset userspace detected, disabling atomic
                        Mar 24 18:28:48 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 15 attempts...
                        Mar 24 18:28:49 ioBroker kernel: [   28.834709] broken atomic modeset userspace detected, disabling atomic
                        Mar 24 18:28:49 ioBroker systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
                        Mar 24 18:28:49 ioBroker systemd[1]: lightdm.service: Failed with result 'exit-code'.
                        Mar 24 18:28:49 ioBroker systemd[1]: lightdm.service: Service RestartSec=100ms expired, scheduling restart.
                        Mar 24 18:28:49 ioBroker systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 2.
                        Mar 24 18:28:49 ioBroker systemd[1]: Stopped Light Display Manager.
                        Mar 24 18:28:49 ioBroker systemd[1]: Starting Light Display Manager...
                        Mar 24 18:28:49 ioBroker lightdm[1147]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
                        Mar 24 18:28:49 ioBroker lightdm[1147]: Could not enumerate user data directory /var/lib/lightdm/data: Error opening directory '/var/lib/lightdm/data': No such file or directory
                        Mar 24 18:28:49 ioBroker systemd[1]: Started Light Display Manager.
                        Mar 24 18:28:49 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 16 attempts...
                        Mar 24 18:28:50 ioBroker kernel: [   29.745198] broken atomic modeset userspace detected, disabling atomic
                        Mar 24 18:28:50 ioBroker kernel: [   30.339985] broken atomic modeset userspace detected, disabling atomic
                        Mar 24 18:28:50 ioBroker systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
                        Mar 24 18:28:50 ioBroker systemd[1]: lightdm.service: Failed with result 'exit-code'.
                        Mar 24 18:28:50 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 17 attempts...
                        Mar 24 18:28:50 ioBroker systemd[1]: lightdm.service: Service RestartSec=100ms expired, scheduling restart.
                        Mar 24 18:28:50 ioBroker systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 3.
                        Mar 24 18:28:50 ioBroker systemd[1]: Stopped Light Display Manager.
                        Mar 24 18:28:50 ioBroker systemd[1]: Starting Light Display Manager...
                        Mar 24 18:28:50 ioBroker lightdm[1163]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
                        Mar 24 18:28:50 ioBroker lightdm[1163]: Could not enumerate user data directory /var/lib/lightdm/data: Error opening directory '/var/lib/lightdm/data': No such file or directory
                        Mar 24 18:28:50 ioBroker systemd[1]: Started Light Display Manager.
                        Mar 24 18:28:51 ioBroker kernel: [   31.273930] broken atomic modeset userspace detected, disabling atomic
                        Mar 24 18:28:51 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 18 attempts...
                        Mar 24 18:28:51 ioBroker colord[735]: failed to get session [pid 489]: Keine Daten verfügbar
                        Mar 24 18:28:52 ioBroker kernel: [   31.886337] broken atomic modeset userspace detected, disabling atomic
                        Mar 24 18:28:52 ioBroker systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
                        Mar 24 18:28:52 ioBroker systemd[1]: lightdm.service: Failed with result 'exit-code'.
                        Mar 24 18:28:52 ioBroker deCONZ-update2.sh[494]: found deCONZ port 80
                        Mar 24 18:28:52 ioBroker deCONZ-update2.sh[494]: use database file /home/pi/.local/share/dresden-elektronik/deCONZ/zll.db
                        Mar 24 18:28:52 ioBroker systemd[1]: lightdm.service: Service RestartSec=100ms expired, scheduling restart.
                        Mar 24 18:28:52 ioBroker systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 4.
                        Mar 24 18:28:52 ioBroker systemd[1]: Stopped Light Display Manager.
                        Mar 24 18:28:52 ioBroker systemd[1]: Starting Light Display Manager...
                        Mar 24 18:28:52 ioBroker lightdm[1236]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
                        Mar 24 18:28:52 ioBroker lightdm[1236]: Could not enumerate user data directory /var/lib/lightdm/data: Error opening directory '/var/lib/lightdm/data': No such file or directory
                        Mar 24 18:28:52 ioBroker systemd[1]: Started Light Display Manager.
                        Mar 24 18:28:52 ioBroker deCONZ-update2.sh[494]: process update state noupdates
                        • M Mathias2803
                          @meister-mopper Ok, is it better like this:
                          Mar 24 18:28:01 ioBroker influxd-systemd-start.sh[9806]: [httpd] ::1 - admin [24/Mar/2022:18:28:01 +0100] "GET /query?db=iobroker&epoch=s&q=SELECT+mean%28%22value%22%29+FROM+%22Feuchtigkeit+Wert%22+WHERE+time+%3E+now%28%29+-+24h+GROUP+BY+time%281m%29+fill%28null%29 HTTP/1.1" 200 57 "-" "Grafana" c1b52ef5-ab97-11ec-8013-dca63298f236 1649
                          Mar 24 18:28:01 ioBroker grafana-server[750]: t=2022-03-24T18:28:01+0100 lvl=info msg="Alert Rule returned no data" logger=alerting.evalContext ruleId=1 name=Wassermangel changing state to=keep_state
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopped target Timers.
                          Mar 24 18:28:02 ioBroker systemd[1]: Condition check resulted in Turns off Raspberry Pi display backlight on shutdown/reboot being skipped.
                          Mar 24 18:28:02 ioBroker systemd[1]: apt-daily-upgrade.timer: Succeeded.
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopped Daily apt upgrade and clean activities.
                          Mar 24 18:28:02 ioBroker systemd[1]: apt-daily.timer: Succeeded.
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopped Daily apt download activities.
                          Mar 24 18:28:02 ioBroker systemd[1]: Unmounting RPC Pipe File System...
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopping Session 3 of user pi.
                          Mar 24 18:28:02 ioBroker grafana-server[750]: t=2022-03-24T18:28:02+0100 lvl=info msg="Shutdown started" logger=server reason="System signal: terminated"
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopping Grafana instance...
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopped target Sound Card.
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopping Save/Restore Sound Card State...
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopped target Bluetooth.
                          Mar 24 18:28:02 ioBroker systemd[1]: systemd-rfkill.socket: Succeeded.
                          Mar 24 18:28:02 ioBroker bluetoothd[885]: Terminating
                          Mar 24 18:28:02 ioBroker systemd[1109]: run-rpc_pipefs.mount: Succeeded.
                          Mar 24 18:28:02 ioBroker systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopping Bluetooth service...
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopping Session 5 of user pi.
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopping Authorization Manager...
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopping Manage, Install and Generate Color Profiles...
                          Mar 24 18:28:02 ioBroker systemd[1]: systemd-tmpfiles-clean.timer: Succeeded.
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopped Daily Cleanup of Temporary Directories.
                          Mar 24 18:28:02 ioBroker systemd[1]: Unmounting /mnt/mySSD...
                          Mar 24 18:28:02 ioBroker systemd[1]: logrotate.timer: Succeeded.
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopped Daily rotation of log files.
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopped target Graphical Interface.
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopped target Multi-User System.
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopping Regular background program processing daemon...
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopping triggerhappy global hotkey daemon...
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopping dphys-swapfile - set up, mount/unmount, and delete a swap file...
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopping deCONZ: ZigBee gateway -- Update Service...
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopped target Login Prompts.
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopping Getty on tty1...
                          Mar 24 18:28:02 ioBroker systemd[1]: Stopping deCONZ: ZigBee gateway -- WIFI Service...
                          Mar 24 18:28:31 ioBroker systemd-modules-load[118]: Inserted module 'i2c_dev'
                          Mar 24 18:28:31 ioBroker fake-hwclock[117]: Do 24. Mär 17:28:09 UTC 2022
                          Mar 24 18:28:31 ioBroker systemd-fsck[144]: e2fsck 1.44.5 (15-Dec-2018)
                          Mar 24 18:28:31 ioBroker systemd-fsck[144]: rootfs: clean, 207316/1910656 files, 1637652/7725184 blocks
                          Mar 24 18:28:31 ioBroker systemd[1]: Started File System Check on Root Device.
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Remount Root and Kernel File Systems...
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Set the console keyboard layout.
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Remount Root and Kernel File Systems.
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Create System Users...
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Load/Save Random Seed...
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Flush Journal to Persistent Storage...
                          Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
                          Mar 24 18:28:31 ioBroker systemd[1]: Started udev Coldplug all Devices.
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Helper to synchronize boot up for ifupdown...
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Helper to synchronize boot up for ifupdown.
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Load/Save Random Seed.
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Create System Users.
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Create Static Device Nodes in /dev...
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Flush Journal to Persistent Storage.
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Create Static Device Nodes in /dev.
                          Mar 24 18:28:31 ioBroker systemd[1]: Reached target Local File Systems (Pre).
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting udev Kernel Device Manager...
                          Mar 24 18:28:31 ioBroker systemd[1]: Started udev Kernel Device Manager.
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Show Plymouth Boot Screen...
                          Mar 24 18:28:31 ioBroker systemd[1]: Received SIGRTMIN+20 from PID 170 (plymouthd).
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Show Plymouth Boot Screen.
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
                          Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
                          Mar 24 18:28:31 ioBroker systemd[1]: Reached target Local Encrypted Volumes.
                          Mar 24 18:28:31 ioBroker systemd-udevd[163]: Using default interface naming scheme 'v240'.
                          Mar 24 18:28:31 ioBroker mtp-probe: checking bus 1, device 3: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2"
                          Mar 24 18:28:31 ioBroker mtp-probe: bus: 1, device: 3 was not an MTP device
                          Mar 24 18:28:31 ioBroker mtp-probe: checking bus 2, device 2: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb2/2-1"
                          Mar 24 18:28:31 ioBroker mtp-probe: bus: 2, device: 2 was not an MTP device
                          Mar 24 18:28:31 ioBroker systemd[1]: Found device /dev/disk/by-partuuid/f0881a94-01.
                          Mar 24 18:28:31 ioBroker systemd-udevd[160]: Using default interface naming scheme 'v240'.
                          Mar 24 18:28:31 ioBroker usbmount[300]: /dev/sda does not contain a filesystem or disklabel
                          Mar 24 18:28:31 ioBroker systemd-udevd[169]: Process '/usr/share/usbmount/usbmount add' failed with exit code 1.
                          Mar 24 18:28:31 ioBroker systemd-udevd[159]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
                          Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in FUSE Control File System being skipped.
                          Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in Huge Pages File System being skipped.
                          Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
                          Mar 24 18:28:31 ioBroker systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting File System Check on /dev/disk/by-partuuid/f0881a94-01...
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Load/Save RF Kill Switch Status...
                          Mar 24 18:28:31 ioBroker usbmount[323]: executing command: mount -text4 -osync,noexec,nodev,noatime,nodiratime /dev/sda1 /media/usb0
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Load/Save RF Kill Switch Status.
                          Mar 24 18:28:31 ioBroker usbmount[323]: executing command: run-parts /etc/usbmount/mount.d
                          Mar 24 18:28:31 ioBroker systemd-fsck[340]: fsck.fat 4.1 (2017-01-24)
                          Mar 24 18:28:31 ioBroker systemd-fsck[340]: /dev/mmcblk0p1: 290 files, 98647/516190 clusters
                          Mar 24 18:28:31 ioBroker systemd[1]: Found device Portable_SSD 1.
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting File System Check on /dev/disk/by-uuid/49441976-e29b-4acc-a8ee-71f4eb91255c...
                          Mar 24 18:28:31 ioBroker systemd[1]: Started File System Check on /dev/disk/by-partuuid/f0881a94-01.
                          Mar 24 18:28:31 ioBroker systemd[1]: Mounting /boot...
                          Mar 24 18:28:31 ioBroker systemd[1]: Mounted /boot.
                          Mar 24 18:28:31 ioBroker systemd[1]: Reached target Local File Systems.
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Create Volatile Files and Directories...
                          Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
                          Mar 24 18:28:31 ioBroker systemd-fsck[376]: e2fsck 1.44.5 (15-Dec-2018)
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Raise network interfaces...
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Set console font and keymap...
                          Mar 24 18:28:31 ioBroker systemd-fsck[376]: /dev/sda1 is in use.
                          Mar 24 18:28:31 ioBroker systemd-fsck[376]: e2fsck: Cannot continue, aborting.
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Preprocess NFS configuration...
                          Mar 24 18:28:31 ioBroker systemd-fsck[376]: fsck failed with exit status 8.
                          Mar 24 18:28:31 ioBroker systemd-fsck[376]: Ignoring error.
                          Mar 24 18:28:31 ioBroker systemd[1]: plymouth-read-write.service: Succeeded.
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
                          Mar 24 18:28:31 ioBroker systemd[1]: Started File System Check on /dev/disk/by-uuid/49441976-e29b-4acc-a8ee-71f4eb91255c.
                          Mar 24 18:28:31 ioBroker systemd[1]: mnt-mySSD.mount: Directory /mnt/mySSD to mount over is not empty, mounting anyway.
                          Mar 24 18:28:31 ioBroker systemd[1]: Mounting /mnt/mySSD...
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Set console font and keymap.
                          Mar 24 18:28:31 ioBroker systemd[1]: nfs-config.service: Succeeded.
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Preprocess NFS configuration.
                          Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] Booting Linux on physical CPU 0x0
                          Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] Linux version 5.10.103-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1529 SMP Tue Mar 8 12:24:00 GMT 2022
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] CPU: div instructions available: patching division code
                          Mar 24 18:28:31 ioBroker systemd[1]: Reached target NFS client services.
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
                          Mar 24 18:28:31 ioBroker systemd[1]: Reached target Remote File Systems (Pre).
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] random: fast init done
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] Memory policy: Data cache writealloc
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
                          Mar 24 18:28:31 ioBroker systemd[1]: Reached target Remote File Systems.
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] Zone ranges:
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000]   Normal   empty
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] Movable zone start for each node
                          Mar 24 18:28:31 ioBroker systemd[1]: Mounted /mnt/mySSD.
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] Early memory node ranges
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] On node 0 totalpages: 1012736
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Create Volatile Files and Directories.
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000]   DMA zone: 1728 pages used for memmap
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000]   DMA zone: 0 pages reserved
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Network Time Synchronization...
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Update UTMP about System Boot/Shutdown...
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1011008
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Update UTMP about System Boot/Shutdown.
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:F2:36 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f0881a94-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles ip=192.168.1.95::192.168.0.1:255.255.128.0:ioBroker:eth0:off
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] Kernel parameter elevator= does not have any effect anymore.
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] Please use sysfs to set IO scheduler for individual devices.
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB)
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Raise network interfaces.
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] Memory: 3601140K/4050944K available (10240K kernel code, 1366K rwdata, 3196K rodata, 2048K init, 882K bss, 122124K reserved, 327680K cma-reserved, 3264512K highmem)
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Network Time Synchronization.
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] ftrace: allocating 34355 entries in 101 pages
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] ftrace: allocated 101 pages with 4 groups
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] rcu: Hierarchical RCU implementation.
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000]         Rude variant of Tasks RCU enabled.
                          Mar 24 18:28:31 ioBroker systemd[1]: Reached target System Time Synchronized.
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000]         Tracing variant of Tasks RCU enabled.
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                          Mar 24 18:28:31 ioBroker systemd[1]: Reached target System Initialization.
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
                          Mar 24 18:28:31 ioBroker kernel: [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1
                          Mar 24 18:28:31 ioBroker kernel: [    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
                          Mar 24 18:28:31 ioBroker kernel: [    0.000027] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
                          Mar 24 18:28:31 ioBroker kernel: [    0.000087] bcm2835: system timer (irq = 25)
                          Mar 24 18:28:31 ioBroker kernel: [    0.000731] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                          Mar 24 18:28:31 ioBroker kernel: [    0.000749] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                          Mar 24 18:28:31 ioBroker systemd[1]: Listening on D-Bus System Message Bus Socket.
                          Mar 24 18:28:31 ioBroker kernel: [    0.000768] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                          Mar 24 18:28:31 ioBroker kernel: [    0.000782] Switching to timer-based delay loop, resolution 18ns
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Daily Cleanup of Temporary Directories.
                          Mar 24 18:28:31 ioBroker kernel: [    0.001037] Console: colour dummy device 80x30
                          Mar 24 18:28:31 ioBroker kernel: [    0.001105] printk: console [tty1] enabled
                          Mar 24 18:28:31 ioBroker kernel: [    0.001157] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
                          Mar 24 18:28:31 ioBroker kernel: [    0.001189] pid_max: default: 32768 minimum: 301
                          Mar 24 18:28:31 ioBroker kernel: [    0.001355] LSM: Security Framework initializing
                          Mar 24 18:28:31 ioBroker kernel: [    0.001539] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                          Mar 24 18:28:31 ioBroker kernel: [    0.001565] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                          Mar 24 18:28:31 ioBroker systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
                          Mar 24 18:28:31 ioBroker kernel: [    0.003016] cgroup: Disabling memory control group subsystem
                          Mar 24 18:28:31 ioBroker kernel: [    0.003248] CPU: Testing write buffer coherency: ok
                          Mar 24 18:28:31 ioBroker kernel: [    0.003703] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Daily apt download activities.
                          Mar 24 18:28:31 ioBroker kernel: [    0.004910] Setting up static identity map for 0x200000 - 0x20003c
                          Mar 24 18:28:31 ioBroker kernel: [    0.005108] rcu: Hierarchical SRCU implementation.
                          Mar 24 18:28:31 ioBroker kernel: [    0.006026] smp: Bringing up secondary CPUs ...
                          Mar 24 18:28:31 ioBroker kernel: [    0.007235] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                          Mar 24 18:28:31 ioBroker kernel: [    0.008596] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Daily apt upgrade and clean activities.
                          Mar 24 18:28:31 ioBroker kernel: [    0.009885] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                          Mar 24 18:28:31 ioBroker kernel: [    0.010043] smp: Brought up 1 node, 4 CPUs
                          Mar 24 18:28:31 ioBroker kernel: [    0.010064] SMP: Total of 4 processors activated (432.00 BogoMIPS).
                          Mar 24 18:28:31 ioBroker kernel: [    0.010079] CPU: All CPU(s) started in HYP mode.
                          Mar 24 18:28:31 ioBroker systemd[1]: Listening on triggerhappy.socket.
                          Mar 24 18:28:31 ioBroker kernel: [    0.010102] CPU: Virtualization extensions available.
                          Mar 24 18:28:31 ioBroker kernel: [    0.010991] devtmpfs: initialized
                          Mar 24 18:28:31 ioBroker kernel: [    0.025185] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
                          Mar 24 18:28:31 ioBroker kernel: [    0.025417] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                          Mar 24 18:28:31 ioBroker systemd[1]: Started CUPS Scheduler.
                          Mar 24 18:28:31 ioBroker kernel: [    0.025448] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                          Mar 24 18:28:31 ioBroker systemd[1]: Reached target Paths.
                          Mar 24 18:28:31 ioBroker kernel: [    0.033687] pinctrl core: initialized pinctrl subsystem
                          Mar 24 18:28:31 ioBroker kernel: [    0.034765] NET: Registered protocol family 16
                          Mar 24 18:28:31 ioBroker kernel: [    0.038740] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                          Mar 24 18:28:31 ioBroker kernel: [    0.039509] audit: initializing netlink subsys (disabled)
                          Mar 24 18:28:31 ioBroker kernel: [    0.039765] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
                          Mar 24 18:28:31 ioBroker kernel: [    0.040347] thermal_sys: Registered thermal governor 'step_wise'
                          Mar 24 18:28:31 ioBroker kernel: [    0.041210] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                          Mar 24 18:28:31 ioBroker kernel: [    0.041227] hw-breakpoint: maximum watchpoint size is 8 bytes.
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Daily rotation of log files.
                          Mar 24 18:28:31 ioBroker kernel: [    0.041628] Serial: AMBA PL011 UART driver
                          Mar 24 18:28:31 ioBroker kernel: [    0.073692] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                          Mar 24 18:28:31 ioBroker kernel: [    0.090843] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-12-01T15:01:54, variant start
                          Mar 24 18:28:31 ioBroker kernel: [    0.100856] raspberrypi-firmware soc:firmware: Firmware hash is 71bd3109023a0c8575585ba87cbb374d2eeb038f
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Daily man-db regeneration.
                          Mar 24 18:28:31 ioBroker kernel: [    0.141989] Kprobes globally optimized
                          Mar 24 18:28:31 ioBroker kernel: [    0.147400] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                          Mar 24 18:28:31 ioBroker kernel: [    0.151590] vgaarb: loaded
                          Mar 24 18:28:31 ioBroker systemd[1]: Reached target Timers.
                          Mar 24 18:28:31 ioBroker kernel: [    0.152037] SCSI subsystem initialized
                          Mar 24 18:28:31 ioBroker kernel: [    0.152262] usbcore: registered new interface driver usbfs
                          Mar 24 18:28:31 ioBroker kernel: [    0.152322] usbcore: registered new interface driver hub
                          Mar 24 18:28:31 ioBroker kernel: [    0.152395] usbcore: registered new device driver usb
                          Mar 24 18:28:31 ioBroker systemd[1]: Listening on CUPS Scheduler.
                          Mar 24 18:28:31 ioBroker kernel: [    0.152731] usb_phy_generic phy: supply vcc not found, using dummy regulator
                          Mar 24 18:28:31 ioBroker kernel: [    0.154744] clocksource: Switched to clocksource arch_sys_counter
                          Mar 24 18:28:31 ioBroker kernel: [    1.099703] VFS: Disk quotas dquot_6.6.0
                          Mar 24 18:28:31 ioBroker kernel: [    1.099796] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                          Mar 24 18:28:31 ioBroker kernel: [    1.099958] FS-Cache: Loaded
                          Mar 24 18:28:31 ioBroker systemd[1]: Reached target Sockets.
                          Mar 24 18:28:31 ioBroker kernel: [    1.100170] CacheFiles: Loaded
                          Mar 24 18:28:31 ioBroker kernel: [    1.110354] NET: Registered protocol family 2
                          Mar 24 18:28:31 ioBroker kernel: [    1.110591] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
                          Mar 24 18:28:31 ioBroker systemd[1]: Reached target Basic System.
                          Mar 24 18:28:31 ioBroker kernel: [    1.112125] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                          Mar 24 18:28:31 ioBroker kernel: [    1.112169] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting System Logging Service...
                          Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
                          Mar 24 18:28:31 ioBroker systemd[1]: Started deCONZ: ZigBee gateway -- WIFI Service.
                          Mar 24 18:28:31 ioBroker systemd-timesyncd[401]: Synchronized to time server for the first time 136.243.66.91:123 (0.debian.pool.ntp.org).
                          Mar 24 18:28:31 ioBroker systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Disk Manager...
                          Mar 24 18:28:31 ioBroker systemd[1]: Started D-Bus System Message Bus.
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Configure Bluetooth Modems connected by UART...
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Check for v3d driver...
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting triggerhappy global hotkey daemon...
                          Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
                          Mar 24 18:28:31 ioBroker systemd[1]: Started Manage Sound Card State (restore and store).
                          Mar 24 18:28:31 ioBroker alsactl[461]: alsactl 1.1.8 daemon started
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Save/Restore Sound Card State...
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting rng-tools.service...
                          Mar 24 18:28:31 ioBroker rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
                          Mar 24 18:28:31 ioBroker rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="439" x-info="https://www.rsyslog.com"] start
                          Mar 24 18:28:31 ioBroker thd[458]: Found socket passed from systemd
                          Mar 24 18:28:31 ioBroker kernel: [    1.112234] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
                          Mar 24 18:28:31 ioBroker kernel: [    1.112301] TCP: Hash tables configured (established 8192 bind 8192)
                          Mar 24 18:28:31 ioBroker kernel: [    1.112461] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
                          Mar 24 18:28:31 ioBroker kernel: [    1.112497] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
                          Mar 24 18:28:31 ioBroker kernel: [    1.112742] NET: Registered protocol family 1
                          Mar 24 18:28:31 ioBroker kernel: [    1.113433] RPC: Registered named UNIX socket transport module.
                          Mar 24 18:28:31 ioBroker kernel: [    1.113449] RPC: Registered udp transport module.
                          Mar 24 18:28:31 ioBroker kernel: [    1.113463] RPC: Registered tcp transport module.
                          Mar 24 18:28:31 ioBroker kernel: [    1.113478] RPC: Registered tcp NFSv4.1 backchannel transport module.
                          Mar 24 18:28:31 ioBroker kernel: [    1.113502] PCI: CLS 0 bytes, default 64
                          Mar 24 18:28:31 ioBroker kernel: [    1.117337] Initialise system trusted keyrings
                          Mar 24 18:28:31 ioBroker kernel: [    1.117571] workingset: timestamp_bits=14 max_order=20 bucket_order=6
                          Mar 24 18:28:31 ioBroker kernel: [    1.125864] zbud: loaded
                          Mar 24 18:28:31 ioBroker kernel: [    1.127592] FS-Cache: Netfs 'nfs' registered for caching
                          Mar 24 18:28:31 ioBroker kernel: [    1.128353] NFS: Registering the id_resolver key type
                          Mar 24 18:28:31 ioBroker kernel: [    1.128389] Key type id_resolver registered
                          Mar 24 18:28:31 ioBroker kernel: [    1.128404] Key type id_legacy registered
                          Mar 24 18:28:31 ioBroker kernel: [    1.128548] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                          Mar 24 18:28:31 ioBroker kernel: [    1.128564] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
                          Mar 24 18:28:31 ioBroker kernel: [    1.129603] Key type asymmetric registered
                          Mar 24 18:28:31 ioBroker kernel: [    1.129620] Asymmetric key parser 'x509' registered
                          Mar 24 18:28:31 ioBroker kernel: [    1.129812] bounce: pool size: 64 pages
                          Mar 24 18:28:31 ioBroker kernel: [    1.129856] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
                          Mar 24 18:28:31 ioBroker kernel: [    1.130062] io scheduler mq-deadline registered
                          Mar 24 18:28:31 ioBroker kernel: [    1.130078] io scheduler kyber registered
                          Mar 24 18:28:31 ioBroker kernel: [    1.134489] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                          Mar 24 18:28:31 ioBroker kernel: [    1.134522] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                          Mar 24 18:28:31 ioBroker kernel: [    1.134603] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                          Mar 24 18:28:31 ioBroker kernel: [    1.134692] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
                          Mar 24 18:28:31 ioBroker kernel: [    1.196849] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                          Mar 24 18:28:31 ioBroker kernel: [    1.197233] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                          Mar 24 18:28:31 ioBroker kernel: [    1.197254] pci_bus 0000:00: root bus resource [bus 00-ff]
                          Mar 24 18:28:31 ioBroker kernel: [    1.197275] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                          Mar 24 18:28:31 ioBroker kernel: [    1.197365] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                          Mar 24 18:28:31 ioBroker kernel: [    1.197609] pci 0000:00:00.0: PME# supported from D0 D3hot
                          Mar 24 18:28:31 ioBroker kernel: [    1.201077] PCI: bus0: Fast back to back transfers disabled
                          Mar 24 18:28:31 ioBroker kernel: [    1.201450] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                          Mar 24 18:28:31 ioBroker kernel: [    1.201579] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                          Mar 24 18:28:31 ioBroker kernel: [    1.202014] pci 0000:01:00.0: PME# supported from D0 D3cold
                          Mar 24 18:28:31 ioBroker kernel: [    1.205479] PCI: bus1: Fast back to back transfers disabled
                          Mar 24 18:28:31 ioBroker kernel: [    1.205576] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                          Mar 24 18:28:31 ioBroker kernel: [    1.205601] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                          Mar 24 18:28:31 ioBroker kernel: [    1.205682] pci 0000:00:00.0: PCI bridge to [bus 01]
                          Mar 24 18:28:31 ioBroker kernel: [    1.205708] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                          Mar 24 18:28:31 ioBroker kernel: [    1.206131] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                          Mar 24 18:28:31 ioBroker kernel: [    1.206349] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
                          Mar 24 18:28:31 ioBroker kernel: [    1.215071] iproc-rng200 fe104000.rng: hwrng registered
                          Mar 24 18:28:31 ioBroker kernel: [    1.215381] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                          Mar 24 18:28:31 ioBroker kernel: [    1.216242] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                          Mar 24 18:28:31 ioBroker kernel: [    1.228478] brd: module loaded
                          Mar 24 18:28:31 ioBroker kernel: [    1.240727] loop: module loaded
                          Mar 24 18:28:31 ioBroker kernel: [    1.242456] Loading iSCSI transport class v2.0-870.
                          Mar 24 18:28:31 ioBroker kernel: [    1.247409] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                          Mar 24 18:28:31 ioBroker kernel: [    1.344907] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                          Mar 24 18:28:31 ioBroker kernel: [    1.346087] usbcore: registered new interface driver r8152
                          Mar 24 18:28:31 ioBroker kernel: [    1.346169] usbcore: registered new interface driver lan78xx
                          Mar 24 18:28:31 ioBroker kernel: [    1.346235] usbcore: registered new interface driver smsc95xx
                          Mar 24 18:28:31 ioBroker kernel: [    1.347872] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
                          Mar 24 18:28:31 ioBroker kernel: [    1.348035] xhci_hcd 0000:01:00.0: xHCI Host Controller
                          Mar 24 18:28:31 ioBroker kernel: [    1.348071] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                          Mar 24 18:28:31 ioBroker kernel: [    1.351436] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
                          Mar 24 18:28:31 ioBroker kernel: [    1.352763] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
                          Mar 24 18:28:31 ioBroker kernel: [    1.352783] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                          Mar 24 18:28:31 ioBroker kernel: [    1.352800] usb usb1: Product: xHCI Host Controller
                          Mar 24 18:28:31 ioBroker kernel: [    1.352817] usb usb1: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
                          Mar 24 18:28:31 ioBroker kernel: [    1.352834] usb usb1: SerialNumber: 0000:01:00.0
                          Mar 24 18:28:31 ioBroker kernel: [    1.353571] hub 1-0:1.0: USB hub found
                          Mar 24 18:28:31 ioBroker kernel: [    1.353669] hub 1-0:1.0: 1 port detected
                          Mar 24 18:28:31 ioBroker kernel: [    1.354339] xhci_hcd 0000:01:00.0: xHCI Host Controller
                          Mar 24 18:28:31 ioBroker kernel: [    1.354367] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                          Mar 24 18:28:31 ioBroker kernel: [    1.354392] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                          Mar 24 18:28:31 ioBroker kernel: [    1.354965] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
                          Mar 24 18:28:31 ioBroker kernel: [    1.354984] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                          Mar 24 18:28:31 ioBroker kernel: [    1.355001] usb usb2: Product: xHCI Host Controller
                          Mar 24 18:28:31 ioBroker kernel: [    1.355017] usb usb2: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
                          Mar 24 18:28:31 ioBroker kernel: [    1.355033] usb usb2: SerialNumber: 0000:01:00.0
                          Mar 24 18:28:31 ioBroker kernel: [    1.355744] hub 2-0:1.0: USB hub found
                          Mar 24 18:28:31 ioBroker kernel: [    1.355827] hub 2-0:1.0: 4 ports detected
                          Mar 24 18:28:31 ioBroker kernel: [    1.357502] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                          Mar 24 18:28:31 ioBroker kernel: [    1.357806] dwc_otg: FIQ enabled
                          Mar 24 18:28:31 ioBroker kernel: [    1.357821] dwc_otg: NAK holdoff enabled
                          Mar 24 18:28:31 ioBroker kernel: [    1.357835] dwc_otg: FIQ split-transaction FSM enabled
                          Mar 24 18:28:31 ioBroker kernel: [    1.357853] Module dwc_common_port init
                          Mar 24 18:28:31 ioBroker kernel: [    1.358316] usbcore: registered new interface driver uas
                          Mar 24 18:28:31 ioBroker kernel: [    1.358422] usbcore: registered new interface driver usb-storage
                          Mar 24 18:28:31 ioBroker kernel: [    1.358621] mousedev: PS/2 mouse device common for all mice
                          Mar 24 18:28:31 ioBroker kernel: [    1.360259] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                          Mar 24 18:28:31 ioBroker kernel: [    1.363566] sdhci: Secure Digital Host Controller Interface driver
                          Mar 24 18:28:31 ioBroker kernel: [    1.363582] sdhci: Copyright(c) Pierre Ossman
                          Mar 24 18:28:31 ioBroker kernel: [    1.364273] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                          Mar 24 18:28:31 ioBroker kernel: [    1.364878] sdhci-pltfm: SDHCI platform and OF driver helper
                          Mar 24 18:28:31 ioBroker kernel: [    1.368979] ledtrig-cpu: registered to indicate activity on CPUs
                          Mar 24 18:28:31 ioBroker kernel: [    1.369312] hid: raw HID events driver (C) Jiri Kosina
                          Mar 24 18:28:31 ioBroker kernel: [    1.369513] usbcore: registered new interface driver usbhid
                          Mar 24 18:28:31 ioBroker kernel: [    1.369528] usbhid: USB HID core driver
                          Mar 24 18:28:31 ioBroker kernel: [    1.375545] Initializing XFRM netlink socket
                          Mar 24 18:28:31 ioBroker kernel: [    1.375587] NET: Registered protocol family 17
                          Mar 24 18:28:31 ioBroker kernel: [    1.375709] Key type dns_resolver registered
                          Mar 24 18:28:31 ioBroker kernel: [    1.376181] Registering SWP/SWPB emulation handler
                          Mar 24 18:28:31 ioBroker kernel: [    1.376349] registered taskstats version 1
                          Mar 24 18:28:31 ioBroker kernel: [    1.376377] Loading compiled-in X.509 certificates
                          Mar 24 18:28:31 ioBroker kernel: [    1.377252] Key type ._fscrypt registered
                          Mar 24 18:28:31 ioBroker kernel: [    1.377268] Key type .fscrypt registered
                          Mar 24 18:28:31 ioBroker kernel: [    1.377283] Key type fscrypt-provisioning registered
                          Mar 24 18:28:31 ioBroker kernel: [    1.388800] uart-pl011 fe201000.serial: there is not valid maps for state default
                          Mar 24 18:28:31 ioBroker kernel: [    1.389104] uart-pl011 fe201000.serial: cts_event_workaround enabled
                          Mar 24 18:28:31 ioBroker kernel: [    1.389178] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
                          Mar 24 18:28:31 ioBroker kernel: [    1.395878] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                          Mar 24 18:28:31 ioBroker kernel: [    1.396958] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                          Mar 24 18:28:31 ioBroker kernel: [    1.396976] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                          Mar 24 18:28:31 ioBroker kernel: [    1.427233] of_cfs_init
                          Mar 24 18:28:31 ioBroker kernel: [    1.427502] of_cfs_init: OK
                          Mar 24 18:28:31 ioBroker kernel: [    1.447849] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                          Mar 24 18:28:31 ioBroker kernel: [    1.449537] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                          Mar 24 18:28:31 ioBroker kernel: [    1.451225] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                          Mar 24 18:28:31 ioBroker kernel: [    1.454243] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                          Mar 24 18:28:31 ioBroker kernel: [    1.455933] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                          Mar 24 18:28:31 ioBroker kernel: [    1.464035] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
                          Mar 24 18:28:31 ioBroker kernel: [    1.467908] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                          Mar 24 18:28:31 ioBroker kernel: [    1.468377] bcmgenet fd580000.ethernet eth0: Link is Down
                          Mar 24 18:28:31 ioBroker kernel: [    1.539345] mmc1: new high speed SDIO card at address 0001
                          Mar 24 18:28:31 ioBroker kernel: [    1.571836] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
                          Mar 24 18:28:31 ioBroker kernel: [    1.572715] mmcblk0: mmc0:aaaa SM32G 29.7 GiB
                          Mar 24 18:28:31 ioBroker kernel: [    1.574685]  mmcblk0: p1 p2
                          Mar 24 18:28:31 ioBroker kernel: [    1.634801] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                          Mar 24 18:28:31 ioBroker kernel: [    1.817708] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                          Mar 24 18:28:31 ioBroker kernel: [    1.817728] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                          Mar 24 18:28:31 ioBroker kernel: [    1.817746] usb 1-1: Product: USB2.0 Hub
                          Mar 24 18:28:31 ioBroker kernel: [    1.819641] hub 1-1:1.0: USB hub found
                          Mar 24 18:28:31 ioBroker kernel: [    1.819956] hub 1-1:1.0: 4 ports detected
                          Mar 24 18:28:31 ioBroker kernel: [    1.965140] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
                          Mar 24 18:28:31 ioBroker kernel: [    1.996737] usb 2-1: New USB device found, idVendor=152d, idProduct=0579, bcdDevice= 5.06
                          Mar 24 18:28:31 ioBroker kernel: [    1.996757] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                          Mar 24 18:28:31 ioBroker kernel: [    1.996774] usb 2-1: Product: Portable SSD
                          Mar 24 18:28:31 ioBroker kernel: [    1.996791] usb 2-1: Manufacturer: Intenso
                          Mar 24 18:28:31 ioBroker kernel: [    1.996808] usb 2-1: SerialNumber: 202104081005B
                          Mar 24 18:28:31 ioBroker kernel: [    2.020556] scsi host0: uas
                          Mar 24 18:28:31 ioBroker kernel: [    2.022077] scsi 0:0:0:0: Direct-Access     Intenso  Portable SSD     0506 PQ: 0 ANSI: 6
                          Mar 24 18:28:31 ioBroker kernel: [    2.144785] usb 1-1.2: new high-speed USB device number 3 using xhci_hcd
                          Mar 24 18:28:31 ioBroker kernel: [    2.286578] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=2838, bcdDevice= 1.00
                          Mar 24 18:28:31 ioBroker kernel: [    2.286598] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                          Mar 24 18:28:31 ioBroker kernel: [    2.286615] usb 1-1.2: Product: RTL2838UHIDIR
                          Mar 24 18:28:31 ioBroker kernel: [    2.286631] usb 1-1.2: Manufacturer: Realtek
                          Mar 24 18:28:31 ioBroker kernel: [    2.286648] usb 1-1.2: SerialNumber: 00000001
                          Mar 24 18:28:31 ioBroker kernel: [    2.394781] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
                          Mar 24 18:28:31 ioBroker kernel: [    2.533431] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
                          Mar 24 18:28:31 ioBroker kernel: [    2.533451] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                          Mar 24 18:28:31 ioBroker kernel: [    2.533468] usb 1-1.3: Product: ConBee II
                          Mar 24 18:28:31 ioBroker kernel: [    2.533484] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
                          Mar 24 18:28:31 ioBroker kernel: [    2.533501] usb 1-1.3: SerialNumber: DE2409981
                          Mar 24 18:28:31 ioBroker kernel: [    2.540150] sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
                          Mar 24 18:28:31 ioBroker kernel: [    2.540170] sd 0:0:0:0: [sda] 4096-byte physical blocks
                          Mar 24 18:28:31 ioBroker kernel: [    2.540435] sd 0:0:0:0: [sda] Write Protect is off
                          Mar 24 18:28:31 ioBroker kernel: [    2.540454] sd 0:0:0:0: [sda] Mode Sense: 53 00 00 08
                          Mar 24 18:28:31 ioBroker kernel: [    2.540929] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
                          Mar 24 18:28:31 ioBroker kernel: [    2.541753] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
                          Mar 24 18:28:31 ioBroker kernel: [    2.546234]  sda: sda1
                          Mar 24 18:28:31 ioBroker kernel: [    2.549985] sd 0:0:0:0: [sda] Attached SCSI disk
                          Mar 24 18:28:31 ioBroker kernel: [    5.595031] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
                          Mar 24 18:28:31 ioBroker kernel: [    5.634772] IP-Config: Complete:
                          Mar 24 18:28:31 ioBroker kernel: [    5.634795]      device=eth0, hwaddr=dc:a6:32:98:f2:36, ipaddr=192.168.1.95, mask=255.255.128.0, gw=192.168.0.1
                          Mar 24 18:28:31 ioBroker kernel: [    5.634812]      host=ioBroker, domain=, nis-domain=(none)
                          Mar 24 18:28:31 ioBroker kernel: [    5.634828]      bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath=
                          Mar 24 18:28:31 ioBroker kernel: [    5.657820] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                          Mar 24 18:28:31 ioBroker kernel: [    5.657893] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                          Mar 24 18:28:31 ioBroker kernel: [    5.658691] devtmpfs: mounted
                          Mar 24 18:28:31 ioBroker kernel: [    5.668893] Freeing unused kernel memory: 2048K
                          Mar 24 18:28:31 ioBroker kernel: [    5.695082] Run /sbin/init as init process
                          Mar 24 18:28:31 ioBroker kernel: [    5.695097]   with arguments:
                          Mar 24 18:28:31 ioBroker kernel: [    5.695111]     /sbin/init
                          Mar 24 18:28:31 ioBroker kernel: [    5.695126]     splash
                          Mar 24 18:28:31 ioBroker kernel: [    5.695140]   with environment:
                          Mar 24 18:28:31 ioBroker kernel: [    5.695154]     HOME=/
                          Mar 24 18:28:31 ioBroker kernel: [    5.695168]     TERM=linux
                          Mar 24 18:28:31 ioBroker kernel: [    6.215554] NET: Registered protocol family 10
                          Mar 24 18:28:31 ioBroker kernel: [    6.217333] Segment Routing with IPv6
                          Mar 24 18:28:31 ioBroker kernel: [    7.080229] random: systemd: uninitialized urandom read (16 bytes read)
                          Mar 24 18:28:31 ioBroker kernel: [    7.091632] random: systemd: uninitialized urandom read (16 bytes read)
                          Mar 24 18:28:31 ioBroker kernel: [    7.095529] random: systemd: uninitialized urandom read (16 bytes read)
                          Mar 24 18:28:31 ioBroker kernel: [    7.216124] i2c /dev entries driver
                          Mar 24 18:28:31 ioBroker kernel: [    7.724093] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                          Mar 24 18:28:31 ioBroker kernel: [    8.458019] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                          Mar 24 18:28:31 ioBroker kernel: [    8.458580] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                          Mar 24 18:28:31 ioBroker kernel: [    8.459100] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                          Mar 24 18:28:31 ioBroker kernel: [    8.459608] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                          Mar 24 18:28:31 ioBroker kernel: [    8.517222] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                          Mar 24 18:28:31 ioBroker kernel: [    8.521149] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                          Mar 24 18:28:31 ioBroker kernel: [    8.521176] [vc_sm_connected_init]: start
                          Mar 24 18:28:31 ioBroker kernel: [    8.532574] mc: Linux media interface: v0.10
                          Mar 24 18:28:31 ioBroker kernel: [    8.533310] [vc_sm_connected_init]: installed successfully
                          Mar 24 18:28:31 ioBroker kernel: [    8.576553] videodev: Linux video capture interface: v2.00
                          Mar 24 18:28:31 ioBroker kernel: [    8.600858] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                          Mar 24 18:28:31 ioBroker kernel: [    8.603456] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                          Mar 24 18:28:31 ioBroker kernel: [    8.644995] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                          Mar 24 18:28:31 ioBroker kernel: [    8.646302] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                          Mar 24 18:28:31 ioBroker kernel: [    8.666285] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                          Mar 24 18:28:31 ioBroker kernel: [    8.668482] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                          Mar 24 18:28:31 ioBroker kernel: [    8.674404] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                          Mar 24 18:28:31 ioBroker kernel: [    8.681749] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                          Mar 24 18:28:31 ioBroker kernel: [    8.682261] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                          Mar 24 18:28:31 ioBroker kernel: [    8.682298] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                          Mar 24 18:28:31 ioBroker kernel: [    8.682339] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                          Mar 24 18:28:31 ioBroker kernel: [    8.682362] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                          Mar 24 18:28:31 ioBroker kernel: [    8.682385] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                          Mar 24 18:28:31 ioBroker kernel: [    8.682686] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                          Mar 24 18:28:31 ioBroker kernel: [    8.694033] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                          Mar 24 18:28:31 ioBroker kernel: [    8.714321] bcm2835_audio bcm2835_audio: card created with 8 channels
                          Mar 24 18:28:31 ioBroker kernel: [    8.748977] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                          Mar 24 18:28:31 ioBroker kernel: [    8.749025] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                          Mar 24 18:28:31 ioBroker kernel: [    8.798219] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                          Mar 24 18:28:31 ioBroker kernel: [    8.798287] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                          Mar 24 18:28:31 ioBroker kernel: [    8.814693] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                          Mar 24 18:28:31 ioBroker kernel: [    8.852223] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                          Mar 24 18:28:31 ioBroker kernel: [    8.852271] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                          Mar 24 18:28:31 ioBroker kernel: [    8.869747] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                          Mar 24 18:28:31 ioBroker kernel: [    8.898164] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                          Mar 24 18:28:31 ioBroker kernel: [    8.899042] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
                          Mar 24 18:28:31 ioBroker kernel: [    8.899087] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
                          Mar 24 18:28:31 ioBroker kernel: [    8.911116] [drm] No displays found. Consider forcing hotplug if HDMI is attached
                          Mar 24 18:28:31 ioBroker kernel: [    8.911243] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                          Mar 24 18:28:31 ioBroker kernel: [    8.911686] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                          Mar 24 18:28:31 ioBroker kernel: [    8.972204] brcmfmac: F1 signature read @0x18000000=0x15264345
                          Mar 24 18:28:31 ioBroker kernel: [    8.987589] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                          Mar 24 18:28:31 ioBroker kernel: [    8.988638] usbcore: registered new interface driver brcmfmac
                          Mar 24 18:28:31 ioBroker kernel: [    9.095451] usb 1-1.2: dvb_usb_v2: found a 'Realtek RTL2832U reference design' in warm state
                          Mar 24 18:28:31 ioBroker kernel: [    9.135627] usb 1-1.2: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
                          Mar 24 18:28:31 ioBroker kernel: [    9.135673] dvbdev: DVB: registering new adapter (Realtek RTL2832U reference design)
                          Mar 24 18:28:31 ioBroker kernel: [    9.135696] usb 1-1.2: media controller created
                          Mar 24 18:28:31 ioBroker kernel: [    9.140751] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
                          Mar 24 18:28:31 ioBroker kernel: [    9.203696] i2c i2c-22: Added multiplexed i2c bus 23
                          Mar 24 18:28:31 ioBroker kernel: [    9.203721] rtl2832 22-0010: Realtek RTL2832 successfully attached
                          Mar 24 18:28:31 ioBroker kernel: [    9.203852] usb 1-1.2: DVB: registering adapter 0 frontend 0 (Realtek RTL2832 (DVB-T))...
                          Mar 24 18:28:31 ioBroker kernel: [    9.203888] dvbdev: dvb_create_media_entity: media entity 'Realtek RTL2832 (DVB-T)' registered.
                          Mar 24 18:28:31 ioBroker kernel: [    9.248717] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
                          Mar 24 18:28:31 ioBroker kernel: [    9.257324] usbcore: registered new interface driver cdc_acm
                          Mar 24 18:28:31 ioBroker kernel: [    9.257343] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                          Mar 24 18:28:31 ioBroker kernel: [    9.267874] i2c i2c-23: fc0012: Fitipower FC0012 successfully identified
                          Mar 24 18:28:31 ioBroker kernel: [    9.278455] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                          Mar 24 18:28:31 ioBroker kernel: [    9.278615] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                          Mar 24 18:28:31 ioBroker kernel: [    9.290373] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                          Mar 24 18:28:31 ioBroker kernel: [    9.331843] rtl2832_sdr rtl2832_sdr.0.auto: Registered as swradio0
                          Mar 24 18:28:31 ioBroker kernel: [    9.331864] rtl2832_sdr rtl2832_sdr.0.auto: Realtek RTL2832 SDR attached
                          Mar 24 18:28:31 ioBroker kernel: [    9.331892] rtl2832_sdr rtl2832_sdr.0.auto: SDR API is still slightly experimental and functionality changes may follow
                          Mar 24 18:28:31 ioBroker kernel: [    9.341359] Registered IR keymap rc-empty
                          Mar 24 18:28:31 ioBroker kernel: [    9.341514] rc rc0: Realtek RTL2832U reference design as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/rc/rc0
                          Mar 24 18:28:31 ioBroker kernel: [    9.341750] rc rc0: lirc_dev: driver dvb_usb_rtl28xxu registered at minor = 0, raw IR receiver, no transmitter
                          Mar 24 18:28:31 ioBroker kernel: [    9.342034] input: Realtek RTL2832U reference design as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/rc/rc0/input0
                          Mar 24 18:28:31 ioBroker kernel: [    9.361375] usb 1-1.2: dvb_usb_v2: schedule remote query interval to 200 msecs
                          Mar 24 18:28:31 ioBroker kernel: [    9.369719] usb 1-1.2: dvb_usb_v2: 'Realtek RTL2832U reference design' successfully initialized and connected
                          Mar 24 18:28:31 ioBroker kernel: [    9.370054] usbcore: registered new interface driver dvb_usb_rtl28xxu
                          Mar 24 18:28:31 ioBroker kernel: [    9.650442] sd 0:0:0:0: Attached scsi generic sg0 type 0
                          Mar 24 18:28:31 ioBroker kernel: [   10.415477] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting WPA supplicant...
                          Mar 24 18:28:31 ioBroker systemd[1]: Condition check resulted in Copy user wpa_supplicant.conf being skipped.
                          Mar 24 18:28:31 ioBroker systemd[1]: Started deCONZ: ZigBee gateway -- Update Service.
                          Mar 24 18:28:31 ioBroker rngd[500]: rngd 2-unofficial-mt.14 starting up...
                          Mar 24 18:28:31 ioBroker rng-tools[474]: Starting Hardware RNG entropy gatherer daemon: rngd.
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Login Service...
                          Mar 24 18:28:31 ioBroker systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
                          Mar 24 18:28:32 ioBroker rngd[500]: entropy feed to the kernel ready
                          Mar 24 18:28:32 ioBroker kernel: [   11.742196] random: crng init done
                          Mar 24 18:28:32 ioBroker kernel: [   11.742218] random: 7 urandom warning(s) missed due to ratelimiting
                          Mar 24 18:28:32 ioBroker systemd[1]: Started Regular background program processing daemon.
                          Mar 24 18:28:32 ioBroker kernel: [   11.767923] uart-pl011 fe201000.serial: no DMA platform data
                          Mar 24 18:28:32 ioBroker systemd[1]: Starting dhcpcd on all interfaces...
                          Mar 24 18:28:32 ioBroker udisksd[444]: udisks daemon version 2.8.1 starting
                          Mar 24 18:28:32 ioBroker systemd[1]: Starting Check for Raspberry Pi EEPROM updates...
                          Mar 24 18:28:32 ioBroker systemd[1]: Started System Logging Service.
                          Mar 24 18:28:32 ioBroker cron[523]: (CRON) INFO (pidfile fd = 3)
                          Mar 24 18:28:32 ioBroker systemd[1]: Started triggerhappy global hotkey daemon.
                          Mar 24 18:28:32 ioBroker systemd[1]: Started Check for v3d driver.
                          Mar 24 18:28:32 ioBroker systemd[1]: Started Save/Restore Sound Card State.
                          Mar 24 18:28:32 ioBroker systemd[1]: Started rng-tools.service.
                          Mar 24 18:28:32 ioBroker dphys-swapfile[443]: want /var/swap=100MByte, checking existing: keeping it
                          Mar 24 18:28:32 ioBroker avahi-daemon[518]: Found user 'avahi' (UID 108) and group 'avahi' (GID 113).
                          Mar 24 18:28:32 ioBroker avahi-daemon[518]: Successfully dropped root privileges.
                          Mar 24 18:28:32 ioBroker avahi-daemon[518]: avahi-daemon 0.7 starting up.
                          Mar 24 18:28:32 ioBroker systemd[1]: Reached target Sound Card.
                          Mar 24 18:28:32 ioBroker cron[523]: (CRON) INFO (Running @reboot jobs)
                          Mar 24 18:28:32 ioBroker dhcpcd[527]: dev: loaded udev
                          Mar 24 18:28:32 ioBroker kernel: [   12.056713] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
                          Mar 24 18:28:32 ioBroker kernel: [   12.173632] 8021q: 802.1Q VLAN Support v1.8
                          Mar 24 18:28:32 ioBroker systemd[1]: Started dphys-swapfile - set up, mount/unmount, and delete a swap file.
                          Mar 24 18:28:32 ioBroker avahi-daemon[518]: Successfully called chroot().
                          Mar 24 18:28:32 ioBroker avahi-daemon[518]: Successfully dropped remaining capabilities.
                          Mar 24 18:28:32 ioBroker wpa_supplicant[480]: Successfully initialized wpa_supplicant
                          Mar 24 18:28:32 ioBroker avahi-daemon[518]: No service file found in /etc/avahi/services.
                          Mar 24 18:28:32 ioBroker avahi-daemon[518]: Joining mDNS multicast group on interface eth0.IPv6 with address 2003:df:9708:f700:dea6:32ff:fe98:f236.
                          Mar 24 18:28:32 ioBroker avahi-daemon[518]: New relevant interface eth0.IPv6 for mDNS.
                          Mar 24 18:28:32 ioBroker avahi-daemon[518]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.95.
                          Mar 24 18:28:32 ioBroker avahi-daemon[518]: New relevant interface eth0.IPv4 for mDNS.
                          Mar 24 18:28:32 ioBroker avahi-daemon[518]: Network interface enumeration completed.
                          Mar 24 18:28:32 ioBroker avahi-daemon[518]: Registering new address record for 2003:df:9708:f700:dea6:32ff:fe98:f236 on eth0.*.
                          Mar 24 18:28:32 ioBroker avahi-daemon[518]: Registering new address record for 192.168.1.95 on eth0.IPv4.
                          Mar 24 18:28:32 ioBroker systemd[1]: deconz-init.service: Succeeded.
                          Mar 24 18:28:32 ioBroker systemd[1]: Started deCONZ: ZigBee gateway -- Initialisation.
                          Mar 24 18:28:32 ioBroker systemd[1]: Started Login Service.
                          Mar 24 18:28:32 ioBroker systemd[1]: Started WPA supplicant.
                          Mar 24 18:28:32 ioBroker systemd[1]: Started Avahi mDNS/DNS-SD Stack.
                          Mar 24 18:28:32 ioBroker systemd[1]: Started Make remote CUPS printers available locally.
                          Mar 24 18:28:32 ioBroker udisksd[444]: failed to load module crypto: libbd_crypto.so.2: cannot open shared object file: No such file or directory
                          Mar 24 18:28:32 ioBroker udisksd[444]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
                          Mar 24 18:28:32 ioBroker CRON[601]: (pi) CMD (RTL433.sh)
                          Mar 24 18:28:32 ioBroker CRON[602]: (pi) CMD (sudo service grafana-server start)
                          Mar 24 18:28:32 ioBroker CRON[553]: (CRON) info (No MTA installed, discarding output)
                          Mar 24 18:28:32 ioBroker udisksd[444]: Failed to load the 'mdraid' libblockdev plugin
                          Mar 24 18:28:32 ioBroker udisksd[444]: Failed to load the 'crypto' libblockdev plugin
                          Mar 24 18:28:32 ioBroker dbus-daemon[450]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.5' (uid=0 pid=444 comm="/usr/lib/udisks2/udisksd ")
                          Mar 24 18:28:32 ioBroker dhcpcd[527]: wlan0: starting wpa_supplicant
                          Mar 24 18:28:32 ioBroker dhcpcd-run-hooks[608]: wlan0: starting wpa_supplicant
                          Mar 24 18:28:32 ioBroker systemd[1]: Starting Authorization Manager...
                          Mar 24 18:28:33 ioBroker kernel: [   12.753109] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                          Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]: Skipping automatic bootloader upgrade. current 1599135103 >= min 1599135103
                          Mar 24 18:28:33 ioBroker raspi-config[442]: Checking if shift key is held down: No. Switching to ondemand scaling governor.
                          Mar 24 18:28:33 ioBroker dbus-daemon[450]: [system] Activating via systemd: service name='org.freedesktop.ColorManager' unit='colord.service' requested by ':1.7' (uid=0 pid=489 comm="/usr/sbin/cupsd -l ")
                          Mar 24 18:28:33 ioBroker dhcpcd[527]: wlan0: connected to Access Point `'
                          Mar 24 18:28:33 ioBroker dhcpcd[527]: DUID 00:01:00:01:28:de:03:31:dc:a6:32:98:f2:36
                          Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: IAID 32:98:f2:36
                          Mar 24 18:28:33 ioBroker dhcpcd[527]: wlan0: waiting for carrier
                          Mar 24 18:28:33 ioBroker avahi-daemon[518]: Server startup complete. Host name is ioBroker.local. Local service cookie is 4148147162.
                          Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: soliciting an IPv6 router
                          Mar 24 18:28:33 ioBroker deCONZ[441]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
                          Mar 24 18:28:33 ioBroker polkitd[610]: started daemon version 0.105 using authority implementation `local' version `0.105'
                          Mar 24 18:28:33 ioBroker dbus-daemon[450]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
                          Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]: BOOTLOADER: up to date
                          Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]:    CURRENT: Do 3. Sep 12:11:43 UTC 2020 (1599135103)
                          Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]:     LATEST: Di 25. Jan 14:30:41 UTC 2022 (1643121041)
                          Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]:    RELEASE: default (/lib/firmware/raspberrypi/bootloader/default)
                          Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]:             Use raspi-config to change the release.
                          Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]:   VL805_FW: Dedicated VL805 EEPROM
                          Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: Router Advertisement from fe80::1eed:6fff:fef5:ea4b
                          Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]:      VL805: up to date
                          Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]:    CURRENT: 000138a1
                          Mar 24 18:28:33 ioBroker rpi-eeprom-update[533]:     LATEST: 000138a1
                          Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: adding address 2003:df:9708:f700:1fc5:fc3:682:3af1/64
                          Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: adding route to 2003:df:9708:f700::/64
                          Mar 24 18:28:33 ioBroker avahi-daemon[518]: Registering new address record for 2003:df:9708:f700:1fc5:fc3:682:3af1 on eth0.*.
                          Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: adding default route via fe80::1eed:6fff:fef5:ea4b
                          Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: requesting DHCPv6 information
                          Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: pid -864491050 deleted route to 2003:df:9708:f700::/64
                          Mar 24 18:28:33 ioBroker dhcpcd[527]: eth0: pid -303060302 deleted default route via fe80::1eed:6fff:fef5:ea4b
                          Mar 24 18:28:33 ioBroker kernel: [   13.381027] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                          Mar 24 18:28:33 ioBroker udisksd[444]: Acquired the name org.freedesktop.UDisks2 on the system message bus
                          Mar 24 18:28:33 ioBroker influxd-systemd-start.sh[438]: Merging with configuration at: /etc/influxdb/influxdb.conf
                          Mar 24 18:28:33 ioBroker influxd-systemd-start.sh[438]: ts=2022-03-24T17:28:33.878051Z lvl=info msg="InfluxDB starting" log_id=0_RFPqLW000 version=1.8.10 branch=1.8 commit=688e697c51fd
                          Mar 24 18:28:33 ioBroker influxd-systemd-start.sh[438]: ts=2022-03-24T17:28:33.878102Z lvl=info msg="Go runtime" log_id=0_RFPqLW000 version=go1.13.8 maxprocs=4
                          Mar 24 18:28:33 ioBroker influxd-systemd-start.sh[438]: ts=2022-03-24T17:28:33.902142Z lvl=info msg="Using data dir" log_id=0_RFPqLW000 service=store path=/mnt/mySSD/InfluxDB/data
                          Mar 24 18:28:33 ioBroker influxd-systemd-start.sh[438]: ts=2022-03-24T17:28:33.902266Z lvl=info msg="Compaction settings" log_id=0_RFPqLW000 service=store max_concurrent_compactions=2 throughput_bytes_per_second=50331648 throughput_bytes_per_second_burst=50331648
                          Mar 24 18:28:33 ioBroker influxd-systemd-start.sh[438]: ts=2022-03-24T17:28:33.902334Z lvl=info msg="Open store (start)" log_id=0_RFPqLW000 service=store trace_id=0_RFPqRW000 op_name=tsdb_open op_event=start
                          Mar 24 18:28:34 ioBroker dhcpcd[527]: eth0: rebinding lease of 192.168.1.99
                          Mar 24 18:28:34 ioBroker deCONZ[441]: libpng warning: iCCP: known incorrect sRGB profile
                          Mar 24 18:28:34 ioBroker influxd-systemd-start.sh[438]: ts=2022-03-24T17:28:34.077833Z lvl=info msg="Opened file" log_id=0_RFPqLW000 engine=tsm1 service=filestore path=/mnt/mySSD/InfluxDB/data/_internal/monitor/133/000000018-000000002.tsm id=0 duration=34.840ms
                          Mar 24 18:28:34 ioBroker influxd-systemd-start.sh[438]: ts=2022-03-24T17:28:34.094170Z lvl=info msg="Opened file" log_id=0_RFPqLW000 engine=tsm1 service=filestore path=/mnt/mySSD/InfluxDB/data/_internal/monitor/139/000000016-000000001.tsm id=1 duration=50.352ms
                          Mar 24 18:28:34 ioBroker influxd-systemd-start.sh[438]: ts=2022-03-24T17:28:34.074068Z lvl=info msg="Opened file" log_id=0_RFPqLW000 engine=tsm1 service=filestore path=/mnt/mySSD/InfluxDB/data/_internal/monitor/139/000000014-000000002.tsm id=0 duration=29.954ms
                          Mar 24 18:28:34 ioBroker dhcpcd[527]: eth0: probing address 192.168.1.99/17
                          Mar 24 18:28:34 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 1 attempts...
                          Mar 24 18:28:34 ioBroker dhcpcd[527]: eth0: adding route to 2003:df:9708:f700::/64
                          Mar 24 18:28:34 ioBroker dhcpcd[527]: eth0: adding default route via fe80::1eed:6fff:fef5:ea4b
                          Mar 24 18:28:34 ioBroker dhcpcd[527]: Too few arguments.
                          Mar 24 18:28:35 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 2 attempts...
                          Mar 24 18:28:35 ioBroker deCONZ[441]: This plugin does not support propagateSizeHints()
                          Mar 24 18:28:36 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 3 attempts...
                          Mar 24 18:28:36 ioBroker systemd[1]: systemd-rfkill.service: Succeeded.
                          Mar 24 18:28:36 ioBroker systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
                          Mar 24 18:28:36 ioBroker systemd[1]: Started Check for Raspberry Pi EEPROM updates.
                          Mar 24 18:28:36 ioBroker systemd[1]: Started Authorization Manager.
                          Mar 24 18:28:36 ioBroker systemd[1]: Started Disk Manager.
                          Mar 24 18:28:36 ioBroker systemd[1]: Starting Manage, Install and Generate Color Profiles...
                          Mar 24 18:28:36 ioBroker dbus-daemon[450]: [system] Successfully activated service 'org.freedesktop.ColorManager'
                          Mar 24 18:28:36 ioBroker systemd[1]: Started Manage, Install and Generate Color Profiles.
                          Mar 24 18:28:36 ioBroker colord[735]: failed to get session [pid 489]: Keine Daten verfügbar
                          Mar 24 18:28:36 ioBroker systemd[1]: Started Grafana instance.
                          Mar 24 18:28:37 ioBroker colord-sane: [bjnp] create_broadcast_socket: ERROR - bind socket to local address failed - Cannot assign requested address
                          Mar 24 18:28:37 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 4 attempts...
                          Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Starting Grafana" logger=server version=7.4.3 commit=010f20c1c8 branch=HEAD compiled=2021-02-24T11:29:10+0100
                          Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Config loaded from" logger=settings file=/usr/share/grafana/conf/defaults.ini
                          Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Config loaded from" logger=settings file=/etc/grafana/grafana.ini
                          Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.data=/var/lib/grafana"
                          Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.logs=/var/log/grafana"
                          Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.plugins=/var/lib/grafana/plugins"
                          Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.provisioning=/etc/grafana/provisioning"
                          Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Path Home" logger=settings path=/usr/share/grafana
                          Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Path Data" logger=settings path=/var/lib/grafana
                          Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Path Logs" logger=settings path=/var/log/grafana
                          Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Path Plugins" logger=settings path=/var/lib/grafana/plugins
                          Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Path Provisioning" logger=settings path=/etc/grafana/provisioning
                          Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="App mode production" logger=settings
                          Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Writing PID file" logger=server path=/var/run/grafana/grafana-server.pid pid=763
                          Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Connecting to DB" logger=sqlstore dbtype=sqlite3
                          Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=warn msg="SQLite database file has broader permissions than it should" logger=sqlstore path=/var/lib/grafana/grafana.db mode=-rw-r--r-- expected=-rw-r-----
                          Mar 24 18:28:37 ioBroker grafana-server[763]: t=2022-03-24T18:28:37+0100 lvl=info msg="Starting DB migrations" logger=migrator
                          Mar 24 18:28:38 ioBroker grafana-server[763]: t=2022-03-24T18:28:38+0100 lvl=info msg="Starting plugin search" logger=plugins
                          Mar 24 18:28:38 ioBroker deCONZ[441]: This plugin does not support propagateSizeHints()
                          Mar 24 18:28:38 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 5 attempts...
                          Mar 24 18:28:38 ioBroker dhcpcd[527]: wlan0: carrier acquired
                          Mar 24 18:28:38 ioBroker dhcpcd[527]: wlan0: connected to Access Point `WiFi-WZ'
                          Mar 24 18:28:38 ioBroker dhcpcd[527]: wlan0: IAID 32:98:f2:37
                          Mar 24 18:28:38 ioBroker dhcpcd[527]: wlan0: adding address fe80::9413:2652:11a6:f9f8
                          Mar 24 18:28:38 ioBroker kernel: [   18.406169] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
                          Mar 24 18:28:38 ioBroker avahi-daemon[518]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::9413:2652:11a6:f9f8.
                          Mar 24 18:28:38 ioBroker avahi-daemon[518]: New relevant interface wlan0.IPv6 for mDNS.
                          Mar 24 18:28:38 ioBroker avahi-daemon[518]: Registering new address record for fe80::9413:2652:11a6:f9f8 on wlan0.*.
                          Mar 24 18:28:38 ioBroker dhcpcd[527]: eth0: leased 192.168.1.99 for 864000 seconds
                          Mar 24 18:28:38 ioBroker dhcpcd[527]: eth0: adding route to 192.168.0.0/17
                          Mar 24 18:28:38 ioBroker dhcpcd[527]: eth0: adding default route via 192.168.0.1
                          Mar 24 18:28:38 ioBroker avahi-daemon[518]: Registering new address record for 192.168.1.99 on eth0.IPv4.
                          Mar 24 18:28:38 ioBroker dhcpcd[527]: Too few arguments.
                          Mar 24 18:28:38 ioBroker dhcpcd[527]: forked to background, child pid 828
                          Mar 24 18:28:38 ioBroker systemd[1]: Started dhcpcd on all interfaces.
                          Mar 24 18:28:38 ioBroker systemd[1]: Reached target Network.
                          Mar 24 18:28:38 ioBroker systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
                          Mar 24 18:28:38 ioBroker systemd[1]: Starting /etc/rc.local Compatibility...
                          Mar 24 18:28:38 ioBroker systemd[1]: Starting xrdp session manager...
                          Mar 24 18:28:38 ioBroker systemd[1]: Starting OpenBSD Secure Shell server...
                          Mar 24 18:28:38 ioBroker systemd[1]: Starting Permit User Sessions...
                          Mar 24 18:28:38 ioBroker systemd[1]: Started /etc/rc.local Compatibility.
                          Mar 24 18:28:39 ioBroker dhcpcd[828]: eth0: pid -1772649969 deleted route to 192.168.0.0/17
                          Mar 24 18:28:39 ioBroker dhcpcd[828]: eth0: pid -1131099856 deleted default route via 192.168.0.1
                          Mar 24 18:28:39 ioBroker xrdp-sesman[830]: (830)(-1225199680)[DEBUG] libscp initialized
                          Mar 24 18:28:39 ioBroker systemd[1]: Started Permit User Sessions.
                          Mar 24 18:28:39 ioBroker systemd[1]: Starting Light Display Manager...
                          Mar 24 18:28:39 ioBroker systemd[1]: Starting Hold until boot process finishes up...
                          Mar 24 18:28:39 ioBroker xrdp-sesman[830]: (830)(-1225199680)[DEBUG] Testing if xrdp-sesman can listen on 127.0.0.1 port 3350.
                          Mar 24 18:28:39 ioBroker xrdp-sesman[830]: (830)(-1225199680)[DEBUG] Closed socket 1 (AF_INET6 ::1 port 3350)
                          Mar 24 18:28:39 ioBroker xrdp-sesman[838]: (838)(-1225199680)[INFO ] starting xrdp-sesman with pid 838
                          Mar 24 18:28:39 ioBroker systemd[1]: Started xrdp session manager.
                          Mar 24 18:28:39 ioBroker xrdp-sesman[838]: (838)(-1225199680)[INFO ] listening to port 3350 on 127.0.0.1
                          Mar 24 18:28:39 ioBroker systemd[1]: Starting xrdp daemon...
                          Mar 24 18:28:39 ioBroker systemd[1]: Started OpenBSD Secure Shell server.
                          Mar 24 18:28:39 ioBroker lightdm[837]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
                          Mar 24 18:28:39 ioBroker xrdp[851]: (851)(-1225418624)[DEBUG] Testing if xrdp can listen on 0.0.0.0 port 3389.
                          Mar 24 18:28:39 ioBroker xrdp[851]: (851)(-1225418624)[DEBUG] Closed socket 7 (AF_INET6 :: port 3389)
                          Mar 24 18:28:39 ioBroker systemd[1]: Received SIGRTMIN+21 from PID 170 (plymouthd).
                          Mar 24 18:28:39 ioBroker systemd[1]: plymouth-start.service: Succeeded.
                          Mar 24 18:28:39 ioBroker systemd[1]: plymouth-quit-wait.service: Succeeded.
                          Mar 24 18:28:39 ioBroker systemd[1]: Started Hold until boot process finishes up.
                          Mar 24 18:28:39 ioBroker systemd[1]: Started Getty on tty1.
                          Mar 24 18:28:39 ioBroker systemd[1]: Reached target Login Prompts.
                          Mar 24 18:28:39 ioBroker lightdm[837]: Could not enumerate user data directory /var/lib/lightdm/data: Error opening directory '/var/lib/lightdm/data': No such file or directory
                          Mar 24 18:28:39 ioBroker systemd[1]: Started Light Display Manager.
                          Mar 24 18:28:39 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 6 attempts...
                          Mar 24 18:28:39 ioBroker systemd[1]: xrdp.service: Can't open PID file /run/xrdp/xrdp.pid (yet?) after start: No such file or directory
                          Mar 24 18:28:39 ioBroker dhcpcd[828]: wlan0: rebinding lease of 192.168.1.193
                          Mar 24 18:28:39 ioBroker dhcpcd[828]: wlan0: soliciting an IPv6 router
                          Mar 24 18:28:39 ioBroker dhcpcd[828]: wlan0: probing address 192.168.1.193/17
                          Mar 24 18:28:39 ioBroker grafana-server[763]: t=2022-03-24T18:28:39+0100 lvl=info msg="Registering plugin" logger=plugins id=input
                          Mar 24 18:28:40 ioBroker grafana-server[763]: t=2022-03-24T18:28:40+0100 lvl=info msg="HTTP Server Listen" logger=http.server address=[::]:3000 protocol=http subUrl= socket=
                          Mar 24 18:28:40 ioBroker systemd[1]: Started xrdp daemon.
                          Mar 24 18:28:40 ioBroker kernel: [   19.918364] Bluetooth: Core ver 2.22
                          Mar 24 18:28:40 ioBroker kernel: [   19.918428] NET: Registered protocol family 31
                          Mar 24 18:28:40 ioBroker kernel: [   19.918434] Bluetooth: HCI device and connection manager initialized
                          Mar 24 18:28:40 ioBroker kernel: [   19.919042] Bluetooth: HCI socket layer initialized
                          Mar 24 18:28:40 ioBroker kernel: [   19.919053] Bluetooth: L2CAP socket layer initialized
                          Mar 24 18:28:40 ioBroker kernel: [   19.919072] Bluetooth: SCO socket layer initialized
                          Mar 24 18:28:40 ioBroker kernel: [   19.937773] Bluetooth: HCI UART driver ver 2.3
                          Mar 24 18:28:40 ioBroker kernel: [   19.937784] Bluetooth: HCI UART protocol H4 registered
                          Mar 24 18:28:40 ioBroker kernel: [   19.937837] Bluetooth: HCI UART protocol Three-wire (H5) registered
                          Mar 24 18:28:40 ioBroker kernel: [   19.937978] Bluetooth: HCI UART protocol Broadcom registered
                          Mar 24 18:28:40 ioBroker btuart[451]: bcm43xx_init
                          Mar 24 18:28:40 ioBroker btuart[451]: Flash firmware /lib/firmware/brcm/BCM4345C0.hcd
                          Mar 24 18:28:40 ioBroker btuart[451]: Set Controller UART speed to 3000000 bit/s
                          Mar 24 18:28:40 ioBroker btuart[451]: Device setup complete
                          Mar 24 18:28:40 ioBroker systemd[1]: Starting Load/Save RF Kill Switch Status...
                          Mar 24 18:28:40 ioBroker systemd[1]: Started Configure Bluetooth Modems connected by UART.
                          Mar 24 18:28:40 ioBroker systemd[1]: Started Load/Save RF Kill Switch Status.
                          Mar 24 18:28:40 ioBroker systemd[1]: Created slice system-bthelper.slice.
                          Mar 24 18:28:40 ioBroker systemd[1]: Starting Raspberry Pi bluetooth helper...
                          Mar 24 18:28:40 ioBroker bthelper[880]: Raspberry Pi BDADDR already set
                          Mar 24 18:28:40 ioBroker systemd[1]: Started Raspberry Pi bluetooth helper.
                          Mar 24 18:28:40 ioBroker systemd[1]: Starting Bluetooth service...
                          Mar 24 18:28:40 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 7 attempts...
                          Mar 24 18:28:40 ioBroker bluetoothd[891]: Bluetooth daemon 5.50
                          Mar 24 18:28:40 ioBroker systemd[1]: Started Bluetooth service.
                          Mar 24 18:28:40 ioBroker systemd[1]: Reached target Bluetooth.
                          Mar 24 18:28:40 ioBroker bluetoothd[891]: Starting SDP server
                          Mar 24 18:28:40 ioBroker bluetoothd[891]: Bluetooth management interface 1.18 initialized
                          Mar 24 18:28:40 ioBroker dbus-daemon[450]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.20' (uid=0 pid=891 comm="/usr/lib/bluetooth/bluetoothd ")
                          Mar 24 18:28:40 ioBroker kernel: [   20.225799] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                          Mar 24 18:28:40 ioBroker kernel: [   20.225809] Bluetooth: BNEP filters: protocol multicast
                          Mar 24 18:28:40 ioBroker kernel: [   20.225822] Bluetooth: BNEP socket layer initialized
                          Mar 24 18:28:40 ioBroker bluetoothd[891]: Sap driver initialization failed.
                          Mar 24 18:28:40 ioBroker bluetoothd[891]: sap-server: Operation not permitted (1)
                          Mar 24 18:28:40 ioBroker systemd[1]: Starting Hostname Service...
                          Mar 24 18:28:40 ioBroker dbus-daemon[450]: [system] Successfully activated service 'org.freedesktop.hostname1'
                          Mar 24 18:28:40 ioBroker systemd[1]: Started Hostname Service.
                          Mar 24 18:28:40 ioBroker bluetoothd[891]: Failed to set privacy: Rejected (0x0b)
                          Mar 24 18:28:40 ioBroker dhcpcd[828]: eth0: Router Advertisement from fe80::1eed:6fff:fef5:ea4b
                          Mar 24 18:28:40 ioBroker dhcpcd[828]: wlan0: Router Advertisement from fe80::1eed:6fff:fef5:ea4b
                          Mar 24 18:28:40 ioBroker dhcpcd[828]: wlan0: adding address 2003:df:9708:f700:eb20:e7f4:fc6d:c2d0/64
                          Mar 24 18:28:40 ioBroker avahi-daemon[518]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::9413:2652:11a6:f9f8.
                          Mar 24 18:28:40 ioBroker avahi-daemon[518]: Joining mDNS multicast group on interface wlan0.IPv6 with address 2003:df:9708:f700:eb20:e7f4:fc6d:c2d0.
                          Mar 24 18:28:40 ioBroker avahi-daemon[518]: Registering new address record for 2003:df:9708:f700:eb20:e7f4:fc6d:c2d0 on wlan0.*.
                          Mar 24 18:28:40 ioBroker avahi-daemon[518]: Withdrawing address record for fe80::9413:2652:11a6:f9f8 on wlan0.
                          Mar 24 18:28:40 ioBroker dhcpcd[828]: wlan0: adding route to 2003:df:9708:f700::/64
                          Mar 24 18:28:40 ioBroker dhcpcd[828]: wlan0: requesting DHCPv6 information
                          Mar 24 18:28:40 ioBroker dhcpcd[828]: eth0: fe80::1eed:6fff:fef5:ea4b is reachable again
                          Mar 24 18:28:40 ioBroker dhcpcd[828]: wlan0: adding default route via fe80::1eed:6fff:fef5:ea4b
                          Mar 24 18:28:41 ioBroker xrdp[854]: (854)(-1225418624)[INFO ] starting xrdp with pid 854
                          Mar 24 18:28:41 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 8 attempts...
                          Mar 24 18:28:42 ioBroker xrdp[854]: (854)(-1225418624)[INFO ] listening to port 3389 on 0.0.0.0
                          Mar 24 18:28:42 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 9 attempts...
                          Mar 24 18:28:42 ioBroker dhcpcd[828]: eth0: fe80::1eed:6fff:fef5:ea4b is reachable again
                          Mar 24 18:28:43 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 10 attempts...
                          Mar 24 18:28:44 ioBroker dhcpcd[828]: wlan0: leased 192.168.1.193 for 864000 seconds
                          Mar 24 18:28:44 ioBroker avahi-daemon[518]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.193.
                          Mar 24 18:28:44 ioBroker avahi-daemon[518]: New relevant interface wlan0.IPv4 for mDNS.
                          Mar 24 18:28:44 ioBroker avahi-daemon[518]: Registering new address record for 192.168.1.193 on wlan0.IPv4.
                          Mar 24 18:28:44 ioBroker dhcpcd[828]: eth0: adding route to 192.168.0.0/17
                          Mar 24 18:28:44 ioBroker dhcpcd[828]: eth0: adding default route via 192.168.0.1
                          Mar 24 18:28:44 ioBroker dhcpcd[828]: wlan0: adding route to 192.168.0.0/17
                          Mar 24 18:28:44 ioBroker dhcpcd[828]: wlan0: adding default route via 192.168.0.1
                          Mar 24 18:28:44 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 11 attempts...
                          Mar 24 18:28:45 ioBroker systemd[1]: systemd-rfkill.service: Succeeded.
                          Mar 24 18:28:45 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 12 attempts...
                          Mar 24 18:28:46 ioBroker colord[735]: failed to get session [pid 489]: Keine Daten verfügbar
                          Mar 24 18:28:46 ioBroker systemd[1]: Created slice User Slice of UID 1000.
                          Mar 24 18:28:46 ioBroker systemd[1]: Starting User Runtime Directory /run/user/1000...
                          Mar 24 18:28:46 ioBroker kernel: [   26.055839] broken atomic modeset userspace detected, disabling atomic
                          Mar 24 18:28:46 ioBroker bthelper[880]: Changing power off succeeded
                          Mar 24 18:28:46 ioBroker bthelper[880]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:98:F2:38 Powered: no
                          Mar 24 18:28:46 ioBroker bthelper[880]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:98:F2:38 Discovering: no
                          Mar 24 18:28:46 ioBroker systemd[1]: Started User Runtime Directory /run/user/1000.
                          Mar 24 18:28:46 ioBroker systemd[1]: Starting User Manager for UID 1000...
                          Mar 24 18:28:46 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 13 attempts...
                          Mar 24 18:28:46 ioBroker bthelper[880]: Changing power on succeeded
                          Mar 24 18:28:47 ioBroker systemd[1082]: Listening on GnuPG cryptographic agent and passphrase cache.
                          Mar 24 18:28:47 ioBroker systemd[1082]: Listening on Sound System.
                          Mar 24 18:28:47 ioBroker systemd[1082]: Starting D-Bus User Message Bus Socket.
                          Mar 24 18:28:47 ioBroker systemd[1082]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
                          Mar 24 18:28:47 ioBroker systemd[1082]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
                          Mar 24 18:28:47 ioBroker systemd[1082]: Reached target Timers.
                          Mar 24 18:28:47 ioBroker systemd[1082]: Reached target Paths.
                          Mar 24 18:28:47 ioBroker systemd[1082]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
                          Mar 24 18:28:47 ioBroker systemd[1082]: Listening on GnuPG network certificate management daemon.
                          Mar 24 18:28:47 ioBroker systemd[1082]: Listening on D-Bus User Message Bus Socket.
                          Mar 24 18:28:47 ioBroker systemd[1082]: Reached target Sockets.
                          Mar 24 18:28:47 ioBroker systemd[1082]: Reached target Basic System.
                          Mar 24 18:28:47 ioBroker systemd[1082]: Reached target Default.
                          Mar 24 18:28:47 ioBroker systemd[1]: Started User Manager for UID 1000.
                          Mar 24 18:28:47 ioBroker systemd[1082]: Startup finished in 612ms.
                          Mar 24 18:28:47 ioBroker systemd[1]: Started Session 3 of user pi.
                          Mar 24 18:28:47 ioBroker systemd[1]: Started Session 5 of user pi.
                          Mar 24 18:28:47 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 14 attempts...
                          Mar 24 18:28:47 ioBroker kernel: [   27.436514] broken atomic modeset userspace detected, disabling atomic
                          Mar 24 18:28:47 ioBroker systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
                          Mar 24 18:28:47 ioBroker systemd[1]: lightdm.service: Failed with result 'exit-code'.
                          Mar 24 18:28:47 ioBroker systemd[1]: lightdm.service: Service RestartSec=100ms expired, scheduling restart.
                          Mar 24 18:28:47 ioBroker systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 1.
                          Mar 24 18:28:47 ioBroker systemd[1]: Stopped Light Display Manager.
                          Mar 24 18:28:47 ioBroker systemd[1]: Starting Light Display Manager...
                          Mar 24 18:28:47 ioBroker lightdm[1135]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
                          Mar 24 18:28:47 ioBroker lightdm[1135]: Could not enumerate user data directory /var/lib/lightdm/data: Error opening directory '/var/lib/lightdm/data': No such file or directory
                          Mar 24 18:28:47 ioBroker systemd[1]: Started Light Display Manager.
                          Mar 24 18:28:48 ioBroker kernel: [   28.232466] broken atomic modeset userspace detected, disabling atomic
                          Mar 24 18:28:48 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 15 attempts...
                          Mar 24 18:28:49 ioBroker kernel: [   28.834709] broken atomic modeset userspace detected, disabling atomic
                          Mar 24 18:28:49 ioBroker systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
                          Mar 24 18:28:49 ioBroker systemd[1]: lightdm.service: Failed with result 'exit-code'.
                          Mar 24 18:28:49 ioBroker systemd[1]: lightdm.service: Service RestartSec=100ms expired, scheduling restart.
                          Mar 24 18:28:49 ioBroker systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 2.
                          Mar 24 18:28:49 ioBroker systemd[1]: Stopped Light Display Manager.
                          Mar 24 18:28:49 ioBroker systemd[1]: Starting Light Display Manager...
                          Mar 24 18:28:49 ioBroker lightdm[1147]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
                          Mar 24 18:28:49 ioBroker lightdm[1147]: Could not enumerate user data directory /var/lib/lightdm/data: Error opening directory '/var/lib/lightdm/data': No such file or directory
                          Mar 24 18:28:49 ioBroker systemd[1]: Started Light Display Manager.
                          Mar 24 18:28:49 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 16 attempts...
                          Mar 24 18:28:50 ioBroker kernel: [   29.745198] broken atomic modeset userspace detected, disabling atomic
                          Mar 24 18:28:50 ioBroker kernel: [   30.339985] broken atomic modeset userspace detected, disabling atomic
                          Mar 24 18:28:50 ioBroker systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
                          Mar 24 18:28:50 ioBroker systemd[1]: lightdm.service: Failed with result 'exit-code'.
                          Mar 24 18:28:50 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 17 attempts...
                          Mar 24 18:28:50 ioBroker systemd[1]: lightdm.service: Service RestartSec=100ms expired, scheduling restart.
                          Mar 24 18:28:50 ioBroker systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 3.
                          Mar 24 18:28:50 ioBroker systemd[1]: Stopped Light Display Manager.
                          Mar 24 18:28:50 ioBroker systemd[1]: Starting Light Display Manager...
                          Mar 24 18:28:50 ioBroker lightdm[1163]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
                          Mar 24 18:28:50 ioBroker lightdm[1163]: Could not enumerate user data directory /var/lib/lightdm/data: Error opening directory '/var/lib/lightdm/data': No such file or directory
                          Mar 24 18:28:50 ioBroker systemd[1]: Started Light Display Manager.
                          Mar 24 18:28:51 ioBroker kernel: [   31.273930] broken atomic modeset userspace detected, disabling atomic
                          Mar 24 18:28:51 ioBroker influxd-systemd-start.sh[438]: InfluxDB API unavailable after 18 attempts...
                          Mar 24 18:28:51 ioBroker colord[735]: failed to get session [pid 489]: Keine Daten verfügbar
                          Mar 24 18:28:52 ioBroker kernel: [   31.886337] broken atomic modeset userspace detected, disabling atomic
                          Mar 24 18:28:52 ioBroker systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
                          Mar 24 18:28:52 ioBroker systemd[1]: lightdm.service: Failed with result 'exit-code'.
                          Mar 24 18:28:52 ioBroker deCONZ-update2.sh[494]: found deCONZ port 80
                          Mar 24 18:28:52 ioBroker deCONZ-update2.sh[494]: use database file /home/pi/.local/share/dresden-elektronik/deCONZ/zll.db
                          Mar 24 18:28:52 ioBroker systemd[1]: lightdm.service: Service RestartSec=100ms expired, scheduling restart.
                          Mar 24 18:28:52 ioBroker systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 4.
                          Mar 24 18:28:52 ioBroker systemd[1]: Stopped Light Display Manager.
                          Mar 24 18:28:52 ioBroker systemd[1]: Starting Light Display Manager...
                          Mar 24 18:28:52 ioBroker lightdm[1236]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
                          Mar 24 18:28:52 ioBroker lightdm[1236]: Could not enumerate user data directory /var/lib/lightdm/data: Error opening directory '/var/lib/lightdm/data': No such file or directory
                          Mar 24 18:28:52 ioBroker systemd[1]: Started Light Display Manager.
                          Mar 24 18:28:52 ioBroker deCONZ-update2.sh[494]: process update state noupdates
                          Mathias2803
                          Any other logs I can provide to solve the problem?
                            @mathias2803
                            • Please, use code tags
                            • next:
                              Please attach these log files
                            • better:
                              show logs only when it happens
                            Mathias2803
                            @meister-mopper said in Problems using influxDB on an external SSD:
                            better:
                            What do you mean by this?
                            • M Mathias2803
                              better:
                              @mathias2803
                              Mar 24 18:28:31 ioBroker usbmount[300]: /dev/sda does not contain a filesystem or disklabel
                              Mar 24 18:28:31 ioBroker systemd-udevd[169]: Process '/usr/share/usbmount/usbmount add' failed with exit code 1.
                              Mar 24 18:28:31 ioBroker systemd-udevd[159]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
                              Da ist wohl auf dem Speichermedium /dev/sda was krumm.
                              Und dann schalte den Desktop-Mist (mit Remote-Desktop) aus. Server immer ohne GUI, per SSH-Zugang betreiben.
                              M crunchipC 3 Antworten Letzte Antwort
                                @mathias2803
                                Mathias2803
                                @thomas-braun said in Problems using influxDB on an external SSD:
                                Was kann da falsch sein? Ich kann normal darauf zugreifen und lesen und schreiben.
                                Ich habe auf einer Seite gelesen, dass es falsch eingebunden ist und man nur mit Root Rechten darauf zugreifen kann und es daran liegen soll.
                                pi@ioBroker:~ $ ls -l /media
                                insgesamt 32
                                lrwxrwxrwx 1 root root    4 Sep 28 15:54 usb -> usb0
                                drwxr-xr-x 2 root root 4096 Sep 28 15:54 usb0
                                drwxr-xr-x 2 root root 4096 Sep 28 15:54 usb1
                                drwxr-xr-x 2 root root 4096 Sep 28 15:54 usb2
                                drwxr-xr-x 2 root root 4096 Sep 28 15:54 usb3
                                drwxr-xr-x 2 root root 4096 Sep 28 15:54 usb4
                                drwxr-xr-x 2 root root 4096 Sep 28 15:54 usb5
                                drwxr-xr-x 2 root root 4096 Sep 28 15:54 usb6
                                drwxr-xr-x 2 root root 4096 Sep 28 15:54 usb7
                                Wie kann ich das Problem beheben??
                                  @mathias2803
                                  Mathias2803
                                  @thomas-braun Kann ich noch etwas machen? Ich habe leider das Problem immer noch nicht gelöst.
                                  • M Mathias2803
                                    @mathias2803
                                    Keine Ahnung. Mir ist immer noch nicht klar, wie das Dateisystem gemounted wird. Per automount?
                                      @mathias2803
                                      crunchipC Offline
                                      crunchipC Offline
                                      @thomas-braun sagte in Problems using influxDB on an external SSD:
                                      bedeutet doch eher, das die Platte nicht korrekt formatiert ist
                                      @Mathias2803 vllt hilft https://github.com/rbrito/usbmount/issues/24
                                      Thomas BraunT M 2 Antworten Letzte Antwort
                                        @crunchip
                                        Ja, hatte ich ja auch schon geschrieben.
                                          @mathias2803
                                          Mathias2803
                                          Das mouten passiert durch "/etc/fstab" und dem Eintrag:
                                          "UUID="49441976-e29b-4acc-a8ee-71f4eb91255c" /mnt/mySSD ext4 nofail,rw 0 2"
