<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problems using influxDB on an external SSD]]></title><description><![CDATA[<p dir="auto">I am using influx DB in combination with ioBroker on an raspberry Pi.</p>
<p dir="auto">After issues with the SSD and too many write attempts I moved the influxDB database on an external SSD drive that is mounted with the raspberry and the new location is "/mnt/mySSD/InfluxDB".</p>
<p dir="auto">The problem is, that after a normal manual reboot influxDB has problems connecting the DB and in ioBroker I am getting the error message: "No connection to DB".</p>
<p dir="auto">How can I solve this issue?</p>
<p dir="auto">I hope you can help me. If you need any additional information feel free to ask me (in best case with the command how to get the information).</p>
<p dir="auto">Thanks a lot and kind regards Mathias</p>
]]></description><link>https://forum.iobroker.net/topic/53696/problems-using-influxdb-on-an-external-ssd</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Jul 2026 23:01:34 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/53696.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 24 Mar 2022 15:07:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Thu, 21 Apr 2022 05:06:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathias2803" aria-label="Profile: mathias2803">@<bdi>mathias2803</bdi></a> hab das gerade zufällig gesehen, vllt hilft es auf die Sprünge<br />
<a href="https://centurio.net/2018/11/21/configure-influxdb-to-store-its-data-in-a-different-folder/" rel="nofollow ugc">https://centurio.net/2018/11/21/configure-influxdb-to-store-its-data-in-a-different-folder/</a><br />
bzw<br />
<a href="https://centurio.net/2018/11/21/auto-mount-nfs-shares-on-raspbian/" rel="nofollow ugc">https://centurio.net/2018/11/21/auto-mount-nfs-shares-on-raspbian/</a></p>
]]></description><link>https://forum.iobroker.net/post/793403</link><guid isPermaLink="true">https://forum.iobroker.net/post/793403</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Thu, 21 Apr 2022 05:06:56 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Wed, 13 Apr 2022 11:22:00 GMT]]></title><description><![CDATA[<p dir="auto">Von Influx habe ich auch noch einen Artikel gefunden. Leider ist da auch sehr viel Info für jemanden, der sich mit Linux wenig auskennt.</p>
<p dir="auto">Habe ich etwas aus diesem Bericht nicht beachtet?</p>
<p dir="auto"><a href="https://docs.influxdata.com/influxdb/v2.2/reference/config-options/" rel="nofollow ugc">https://docs.influxdata.com/influxdb/v2.2/reference/config-options/</a></p>
]]></description><link>https://forum.iobroker.net/post/790613</link><guid isPermaLink="true">https://forum.iobroker.net/post/790613</guid><dc:creator><![CDATA[Mathias2803]]></dc:creator><pubDate>Wed, 13 Apr 2022 11:22:00 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Tue, 12 Apr 2022 12:05:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Hat sich nichts geändert, oder?<br />
Ist da alles in Ordnung?</p>
<pre><code>
pi@ioBroker:~ $ ls -la /mnt/mySSD
insgesamt 628
drwxr-xr-x 5 root root   4096 Okt  1  2021 .
drwxrwxrwx 3 root root   4096 Sep 23  2021 ..
drwxrwxrwx 2 root root 614400 Apr 12 02:00 Influx-BackUp
drwxrwxrwx 5 root root   4096 Okt  1  2021 InfluxDB
drwx------ 2 root root  16384 Sep 28  2021 lost+found
</code></pre>
]]></description><link>https://forum.iobroker.net/post/790290</link><guid isPermaLink="true">https://forum.iobroker.net/post/790290</guid><dc:creator><![CDATA[Mathias2803]]></dc:creator><pubDate>Tue, 12 Apr 2022 12:05:25 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Tue, 12 Apr 2022 11:59:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Danke,</p>
<p dir="auto">Muss ich noch irgendwie einstellen, dass er mit dem Infux Service warten muss bis das Mount fertig ist?</p>
<p dir="auto">Ich habe folgende Seite gefunden, kann es aber nicht auf mich "umsetzten". Bringt das etwas?</p>
<p dir="auto"><a href="https://unix.stackexchange.com/questions/246935/set-systemd-service-to-execute-after-fstab-mount" rel="nofollow ugc">https://unix.stackexchange.com/questions/246935/set-systemd-service-to-execute-after-fstab-mount</a></p>
]]></description><link>https://forum.iobroker.net/post/790288</link><guid isPermaLink="true">https://forum.iobroker.net/post/790288</guid><dc:creator><![CDATA[Mathias2803]]></dc:creator><pubDate>Tue, 12 Apr 2022 11:59:21 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Tue, 12 Apr 2022 11:39:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathias2803" aria-label="Profile: mathias2803">@<bdi>mathias2803</bdi></a></p>
<pre><code>nofail
Do not report errors for this device if it does not exist.
</code></pre>
<pre><code>defaults
Use default options: rw, suid, dev, exec, auto, nouser, async, and relatime.
</code></pre>
]]></description><link>https://forum.iobroker.net/post/790285</link><guid isPermaLink="true">https://forum.iobroker.net/post/790285</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 12 Apr 2022 11:39:10 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Tue, 12 Apr 2022 11:36:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Falls ich "nofail" nicht habe, würde das System doch beim Hochfahren hängen bleiben, wenn etwas mit der Platte nicht in Ordnung ist, oder?</p>
<p dir="auto">Was beeinflusst das "defaults"?</p>
]]></description><link>https://forum.iobroker.net/post/790282</link><guid isPermaLink="true">https://forum.iobroker.net/post/790282</guid><dc:creator><![CDATA[Mathias2803]]></dc:creator><pubDate>Tue, 12 Apr 2022 11:36:19 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Tue, 12 Apr 2022 11:20:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathias2803" aria-label="Profile: mathias2803">@<bdi>mathias2803</bdi></a><br />
Da fehlt die Option 'defaults'.</p>
<p dir="auto">Muss also mindestens so aussehen:</p>
<pre><code>UUID="49441976-e29b-4acc-a8ee-71f4eb91255c" /mnt/mySSD ext4 defaults 0 2
</code></pre>
<p dir="auto">nofail würde ich nicht setzen und rw ist schon in defaults drin.</p>
]]></description><link>https://forum.iobroker.net/post/790268</link><guid isPermaLink="true">https://forum.iobroker.net/post/790268</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 12 Apr 2022 11:20:44 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Tue, 12 Apr 2022 11:15:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">sudo nano /etc/fstab:</p>
<pre><code>proc            /proc           proc    defaults          0       0
PARTUUID=f0881a94-01  /boot           vfat    defaults          0       2
PARTUUID=f0881a94-02  /               ext4    defaults,noatime  0       1
# a swapfile is not a swap partition, no line here
#   use  dphys-swapfile swap[on|off]  for that
UUID="49441976-e29b-4acc-a8ee-71f4eb91255c" /mnt/mySSD ext4 nofail,rw 0 2
</code></pre>
]]></description><link>https://forum.iobroker.net/post/790261</link><guid isPermaLink="true">https://forum.iobroker.net/post/790261</guid><dc:creator><![CDATA[Mathias2803]]></dc:creator><pubDate>Tue, 12 Apr 2022 11:15:33 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Tue, 12 Apr 2022 10:32:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathias2803" aria-label="Profile: mathias2803">@<bdi>mathias2803</bdi></a></p>
<p dir="auto">Sorry, das mit /media/data war aus meinem Beispiel, dein Mountpunkt lautet ja /mnt/mySSD</p>
<p dir="auto">Was steht denn jetzt in der /etc/fstab drin?</p>
]]></description><link>https://forum.iobroker.net/post/790243</link><guid isPermaLink="true">https://forum.iobroker.net/post/790243</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 12 Apr 2022 10:32:54 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Tue, 12 Apr 2022 10:23:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a></p>
<p dir="auto">In der influxdb.conf taucht auch keine "media/data" auf sondern nur folgende Einstellungen:</p>
<pre><code>[meta]
  dir = "/mnt/mySSD/InfluxDB/meta"
[data]
  dir = "/mnt/mySSD/InfluxDB/data"
  wal-dir = "/mnt/mySSD/InfluxDB/wal"
  series-id-set-cache-size = 100
[http]
  enabled = true
  bind-address = ":8086"
  auth-enabled = false
  log-enabled = true
  write-tracing = false
  pprof-enabled = false
  https-enabled = false
  https-certificate = "/etc/ssl/influxdb.pem"
</code></pre>
<p dir="auto">Alles andere sind nur Kommentare.</p>
]]></description><link>https://forum.iobroker.net/post/790236</link><guid isPermaLink="true">https://forum.iobroker.net/post/790236</guid><dc:creator><![CDATA[Mathias2803]]></dc:creator><pubDate>Tue, 12 Apr 2022 10:23:42 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Tue, 12 Apr 2022 10:18:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a></p>
<p dir="auto">Das Verzeichnis media/data gibt es gar nicht. Woher kommt das und warum?</p>
<pre><code>pi@ioBroker:~ $ sudo ls -la /media/data
ls: Zugriff auf '/media/data' nicht möglich: Datei oder Verzeichnis nicht gefunden
</code></pre>
]]></description><link>https://forum.iobroker.net/post/790234</link><guid isPermaLink="true">https://forum.iobroker.net/post/790234</guid><dc:creator><![CDATA[Mathias2803]]></dc:creator><pubDate>Tue, 12 Apr 2022 10:18:45 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Tue, 12 Apr 2022 09:21:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathias2803" aria-label="Profile: mathias2803">@<bdi>mathias2803</bdi></a> sagte in <a href="/post/790201">Problems using influxDB on an external SSD</a>:</p>
<blockquote>
<p dir="auto">An was siehst du das?</p>
</blockquote>
<p dir="auto">eben nicht, das war Bedingung:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/789924">Problems using influxDB on an external SSD</a>:</p>
<blockquote>
<p dir="auto">Wie sehen die Rechte an /media/data aus, <strong>wenn das Dateisystem nicht gemounted ist</strong>?</p>
</blockquote>
<p dir="auto">deswegen die Nachfrage</p>
]]></description><link>https://forum.iobroker.net/post/790203</link><guid isPermaLink="true">https://forum.iobroker.net/post/790203</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Tue, 12 Apr 2022 09:21:00 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Tue, 12 Apr 2022 09:12:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Wie meinst du, dass das Dateisystem nicht gemountet ist??<br />
]]></description><link>https://forum.iobroker.net/post/790201</link><guid isPermaLink="true">https://forum.iobroker.net/post/790201</guid><dc:creator><![CDATA[Mathias2803]]></dc:creator><pubDate>Tue, 12 Apr 2022 09:12:22 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Tue, 12 Apr 2022 07:55:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathias2803" aria-label="Profile: mathias2803">@<bdi>mathias2803</bdi></a></p>
<p dir="auto">Und das Dateisystem ist nicht gemounted?<br />
Dann muss der Mountpunkt leer sein.</p>
]]></description><link>https://forum.iobroker.net/post/790182</link><guid isPermaLink="true">https://forum.iobroker.net/post/790182</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 12 Apr 2022 07:55:46 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Tue, 12 Apr 2022 07:24:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<pre><code>pi@ioBroker:~ $ ls -la /mnt/mySSD
insgesamt 628
</code></pre>
]]></description><link>https://forum.iobroker.net/post/790173</link><guid isPermaLink="true">https://forum.iobroker.net/post/790173</guid><dc:creator><![CDATA[Mathias2803]]></dc:creator><pubDate>Tue, 12 Apr 2022 07:24:54 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Mon, 11 Apr 2022 16:10:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathias2803" aria-label="Profile: mathias2803">@<bdi>mathias2803</bdi></a></p>
<pre><code>ls -la /media/mySSD
</code></pre>
]]></description><link>https://forum.iobroker.net/post/789981</link><guid isPermaLink="true">https://forum.iobroker.net/post/789981</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 11 Apr 2022 16:10:40 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Mon, 11 Apr 2022 15:23:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Hast du mir nen Befehl, mit dem ich dir das rausfinden kann? Sorry. Bin nicht so fit mit Unix.</p>
]]></description><link>https://forum.iobroker.net/post/789958</link><guid isPermaLink="true">https://forum.iobroker.net/post/789958</guid><dc:creator><![CDATA[Mathias2803]]></dc:creator><pubDate>Mon, 11 Apr 2022 15:23:33 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Mon, 11 Apr 2022 13:45:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathias2803" aria-label="Profile: mathias2803">@<bdi>mathias2803</bdi></a> sagte in <a href="/post/789922">Problems using influxDB on an external SSD</a>:</p>
<blockquote>
<p dir="auto">/media/data</p>
</blockquote>
<p dir="auto">Wie sehen die Rechte an /media/data aus, wenn das Dateisystem nicht gemounted ist?</p>
]]></description><link>https://forum.iobroker.net/post/789924</link><guid isPermaLink="true">https://forum.iobroker.net/post/789924</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 11 Apr 2022 13:45:07 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Mon, 11 Apr 2022 13:38:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> said in <a href="/post/789896">Problems using influxDB on an external SSD</a>:</p>
<blockquote>
<p dir="auto">sudo chown -R UserNameOfSudo:users /media/data        sudo chmod -R g+rw /media/data</p>
</blockquote>
<p dir="auto">Aber das kann ich dann nicht in "/etc/fstab" reinschreiben. Ich müsste es in einen Chronjob nach dem Start? Oder wie lege ich das fest? Ist das dann nicht wieder zu spät, also erst nachdem schon influxDB gestartet ist?</p>
]]></description><link>https://forum.iobroker.net/post/789922</link><guid isPermaLink="true">https://forum.iobroker.net/post/789922</guid><dc:creator><![CDATA[Mathias2803]]></dc:creator><pubDate>Mon, 11 Apr 2022 13:38:39 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Mon, 11 Apr 2022 12:52:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathias2803" aria-label="Profile: mathias2803">@<bdi>mathias2803</bdi></a> sagte in <a href="/post/789885">Problems using influxDB on an external SSD</a>:</p>
<blockquote>
<p dir="auto">Ist es ausreichend, wenn ich an meinen mount Befehl "users" anhänge?</p>
</blockquote>
<p dir="auto">Nein, lt. man page beschreibt das nur, dass jeder user das Dateisystem mounten darf.<br />
Die Rechte ergeben sich aus den Rechten des mount-Punktes.</p>
<p dir="auto">Man kann nach dem mounten z. B. so in der Art die Rechte vergeben:</p>
<pre><code>sudo chown -R UserNameOfSudo:users /media/data
</code></pre>
]]></description><link>https://forum.iobroker.net/post/789896</link><guid isPermaLink="true">https://forum.iobroker.net/post/789896</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 11 Apr 2022 12:52:27 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Mon, 11 Apr 2022 12:14:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">"UUID="49441976-e29b-4acc-a8ee-71f4eb91255c" /mnt/mySSD ext4 nofail,rw,users 0 2"</p>
<p dir="auto">Oder wie stelle ich ein, dass jeder volle Zugriffsrechte auf die Platte hat?</p>
]]></description><link>https://forum.iobroker.net/post/789885</link><guid isPermaLink="true">https://forum.iobroker.net/post/789885</guid><dc:creator><![CDATA[Mathias2803]]></dc:creator><pubDate>Mon, 11 Apr 2022 12:14:24 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Mon, 11 Apr 2022 12:02:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathias2803" aria-label="Profile: mathias2803">@<bdi>mathias2803</bdi></a></p>
<p dir="auto">Schau in die man-page:</p>
<p dir="auto"><a href="https://linux.die.net/man/8/mount" rel="nofollow ugc">https://linux.die.net/man/8/mount</a></p>
<p dir="auto">Da stehen alle Optionen für die einzelnen Dateisysteme drin.</p>
]]></description><link>https://forum.iobroker.net/post/789882</link><guid isPermaLink="true">https://forum.iobroker.net/post/789882</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 11 Apr 2022 12:02:56 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Mon, 11 Apr 2022 12:00:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Und wie stelle ich die Zugriffsrechte richtig ein?</p>
]]></description><link>https://forum.iobroker.net/post/789880</link><guid isPermaLink="true">https://forum.iobroker.net/post/789880</guid><dc:creator><![CDATA[Mathias2803]]></dc:creator><pubDate>Mon, 11 Apr 2022 12:00:53 GMT</pubDate></item><item><title><![CDATA[Reply to Problems using influxDB on an external SSD on Mon, 11 Apr 2022 11:57:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathias2803" aria-label="Profile: mathias2803">@<bdi>mathias2803</bdi></a> sagte in <a href="/post/789877">Problems using influxDB on an external SSD</a>:</p>
<blockquote>
<p dir="auto">1.) dass das System hochfährt, die Platte erst nach dem Start von influxDB verbunden wird und sie deshalb an einer anderen Stelle etwas schreibt.</p>
</blockquote>
<p dir="auto">Die Reihenfolge wie Dienste gestartet werden kann man in systemd sehr genau definieren. Das mounten der Dateisysteme (per fstab) geschieht allerdings recht früh, das wird vermutlich nicht ursächlich sein.</p>
]]></description><link>https://forum.iobroker.net/post/789879</link><guid isPermaLink="true">https://forum.iobroker.net/post/789879</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 11 Apr 2022 11:57:09 GMT</pubDate></item></channel></rss>
