  4. Warn und Error beim Start von iobroker
    6.3k
errorstart iob
8 Beiträge 3 Kommentatoren 506 Aufrufe 4 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    wenn ich iob neu starte kommt folgendes im log:
    javascript.1
    2022-03-12 03:11:57.377	error	In file included from ../src/binding.cc:1: /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^ /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~ ../src/binding.cc:153:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(cpufeatures, init) ^~~~~~~~~~~
    info.0
    2022-03-12 03:11:53.274	warn	This object will not be created in future versions. Please report this to the developer.
    info.0
    2022-03-12 03:11:53.273	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoadIrq is invalid: obj.common.min has an invalid type! Expected "number", received "string"
    info.0
    2022-03-12 03:11:53.259	warn	This object will not be created in future versions. Please report this to the developer.
    info.0
    2022-03-12 03:11:53.258	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoadIdle is invalid: obj.common.min has an invalid type! Expected "number", received "string"
    info.0
    2022-03-12 03:11:53.243	warn	This object will not be created in future versions. Please report this to the developer.
    info.0
    2022-03-12 03:11:53.242	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoadNice is invalid: obj.common.min has an invalid type! Expected "number", received "string"
    info.0
    2022-03-12 03:11:53.225	warn	This object will not be created in future versions. Please report this to the developer.
    info.0
    2022-03-12 03:11:53.224	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoadSystem is invalid: obj.common.min has an invalid type! Expected "number", received "string"
    info.0
    2022-03-12 03:11:53.074	warn	This object will not be created in future versions. Please report this to the developer.
    info.0
    2022-03-12 03:11:53.073	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoadUser is invalid: obj.common.min has an invalid type! Expected "number", received "string"
    info.0
    2022-03-12 03:11:53.015	warn	This object will not be created in future versions. Please report this to the developer.
    info.0
    2022-03-12 03:11:53.011	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoad is invalid: obj.common.min has an invalid type! Expected "number", received "string"
    mqtt.2
    2022-03-12 03:11:31.570	warn	This object will not be created in future versions. Please report this to the developer.
    mqtt.2
    2022-03-12 03:11:31.568	warn	Object mqtt.2.info.connection is invalid: Default value has to be type "string" but received type "boolean"
    Es läuft aber alles (zumindest fällt mir nichts auf).
    Die warn sind ja nur Hinweise.
    Kann ich die error ignorieren ?
    mfg
    Dieter
    Danke.
    • bahnuhrB bahnuhr
      javascript.1
      info.0
      info.0
      info.0
      info.0
      info.0
      info.0
      info.0
      info.0
      info.0
      info.0
      info.0
      info.0
      mqtt.2
      mqtt.2
      mfg
      Dieter
      crunchipC Offline
      crunchipC Offline
      @bahnuhr eventuell mal den cache löschen
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        @crunchip sagte in Warn und Error beim Start von iobroker:
        meinst du da ?
        Danke.
        • crunchipC Offline
          crunchipC Offline
          @bahnuhr ja
          sudo -u iobroker npm cache clean --force
          sollte das bereinigen
            @bahnuhr ja
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            @bahnuhr ja
            So, hab ich mal gemacht.
            Die zahlreichen mp3 Dateien sind aber immer noch drin.
            Folgende Warn/error kommen noch:
            mqtt
            mqtt.2
            2022-03-12 10:34:36.422	warn	This object will not be created in future versions. Please report this to the developer.
            mqtt.2
            2022-03-12 10:34:36.421	warn	Object mqtt.2.info.connection is invalid: Default value has to be type "string" but received type "boolean"
            info:
            info.0
            2022-03-12 10:34:55.098	warn	This object will not be created in future versions. Please report this to the developer.
            info.0
            2022-03-12 10:34:55.097	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoadIrq is invalid: obj.common.min has an invalid type! Expected "number", received "string"
            info.0
            2022-03-12 10:34:55.074	warn	This object will not be created in future versions. Please report this to the developer.
            info.0
            2022-03-12 10:34:55.073	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoadIdle is invalid: obj.common.min has an invalid type! Expected "number", received "string"
            info.0
            2022-03-12 10:34:55.044	warn	This object will not be created in future versions. Please report this to the developer.
            info.0
            2022-03-12 10:34:55.043	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoadNice is invalid: obj.common.min has an invalid type! Expected "number", received "string"
            info.0
            2022-03-12 10:34:55.021	warn	This object will not be created in future versions. Please report this to the developer.
            info.0
            2022-03-12 10:34:55.020	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoadSystem is invalid: obj.common.min has an invalid type! Expected "number", received "string"
            info.0
            2022-03-12 10:34:54.996	warn	This object will not be created in future versions. Please report this to the developer.
            info.0
            2022-03-12 10:34:54.995	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoadUser is invalid: obj.common.min has an invalid type! Expected "number", received "string"
            info.0
            2022-03-12 10:34:54.920	warn	This object will not be created in future versions. Please report this to the developer.
            info.0
            2022-03-12 10:34:54.914	warn	Object info.0.sysinfo.cpu.currentLoad.currentLoad is invalid: obj.common.min has an invalid type! Expected "number", received "string"
            yamaha:
            yamaha.0
            2022-03-12 10:36:39.277	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:39.276	warn	Object yamaha.0.powerAllZones is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:39.193	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:39.192	warn	Object yamaha.0.zone4 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:39.117	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:39.116	warn	Object yamaha.0.zone3 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:39.039	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:39.039	warn	Object yamaha.0.zone2 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:38.950	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:38.949	warn	Object yamaha.0.zone1 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:38.109	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:38.108	warn	Object yamaha.0.pureDirect is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:38.030	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:38.029	warn	Object yamaha.0.hdmiOut2 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:37.929	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:37.928	warn	Object yamaha.0.hdmiOut1 is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:37.844	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:37.844	warn	Object yamaha.0.Commands.partyModeVolumeDown is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:37.753	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:37.752	warn	Object yamaha.0.Commands.partyModeVolumeUp is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:37.533	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:37.532	warn	Object yamaha.0.partyMode is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:37.442	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:37.441	warn	Object yamaha.0.adaptiveDRC is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:37.270	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:37.269	warn	Object yamaha.0.extraBass is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:37.133	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:37.132	warn	Object yamaha.0.YPAOVolume is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:37.063	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:37.062	warn	Object yamaha.0.Commands.skip is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:36.936	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:36.936	warn	Object yamaha.0.Commands.rewind is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:36.812	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:36.812	warn	Object yamaha.0.Commands.skip is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:36.437	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:36.436	warn	Object yamaha.0.Commands.pause is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:36.353	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:36.352	warn	Object yamaha.0.Commands.stop is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:36.277	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:36.276	warn	Object yamaha.0.refresh is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:36.209	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:36.208	warn	Object yamaha.0.power is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:36.120	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:36.120	warn	Object yamaha.0.mute is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
            yamaha.0
            2022-03-12 10:36:35.964	warn	This object will not be created in future versions. Please report this to the developer.
            yamaha.0
            2022-03-12 10:36:35.960	warn	Object yamaha.0.Commands.toggleMute is invalid: Default value has to be type "boolean" but received type "number"
            Aber der Error kam nicht mehr.
            Danke schön.
            Danke.
            • bahnuhrB bahnuhr
              meinst du da ?
              @bahnuhr
              Nein, der npm cacache ist gemeint. Und den nicht per Filemanager anpacken sondern über ein Terminal.
              Und weil das der npm cache ist beobachtest du auch:
              npm hat nix mit mp3-Dateien zu tun.
                @bahnuhr
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                @thomas-braun sagte in Warn und Error beim Start von iobroker:
                @bahnuhr
                Danke für die Erläuterung.
                hat ja auch einwandfrei geklappt.
                Danke.
                • bahnuhrB bahnuhr
                  @bahnuhr ja
                  mqtt
                  mqtt.2
                  mqtt.2
                  info:
                  info.0
                  info.0
                  info.0
                  info.0
                  info.0
                  info.0
                  info.0
                  info.0
                  info.0
                  info.0
                  info.0
                  info.0
                  yamaha:
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  yamaha.0
                  Danke schön.
                  crunchipC Offline
                  crunchipC Offline
                  @bahnuhr sagte in Warn und Error beim Start von iobroker:
                  alt bekannt, falls es gefixt wurde, entsprechende Datenpunkte löschen, wenn weg, ok, wenn nicht, issue beim jeweiligen Adapter
