  4. TuYa TS0121_plug Zigbee Messintervall verkürzen
    5.5k
31 Beiträge 6 Kommentatoren 3.5k Aufrufe 6 Beobachtet
  • H hertob81
    @arteck sagte in TuYa TS0121_plug Zigbee Messintervall verkürzen:
    @hertob81 dasding musst dir auch antworten.. und das dauert auch..
    Guten Abend,
    es tut mir leid, aber ich muss nochmal nerven. Ich habe den Intervall mittlerweile auf 25 Sekunden hochgesetzt, es bombt mir aber trotzdem noch das LOG zu...
    zigbee.0
    2022-03-09 20:34:00.045	warn	Device query for '0x04cd15fffe02c35d' blocked
    zigbee.0
    2022-03-09 20:34:00.032	warn	Device query for '0x04cd15fffe02cb39' blocked
    zigbee.0
    2022-03-09 20:33:00.032	warn	Device query for '0x04cd15fffe02cb39' blocked
    zigbee.0
    2022-03-09 20:33:00.025	warn	Device query for '0x04cd15fffe02c35d' blocked
    zigbee.0
    2022-03-09 20:32:00.027	warn	Device query for '0x04cd15fffe02c35d' blocked
    zigbee.0
    2022-03-09 20:32:00.021	warn	Device query for '0x04cd15fffe02cb39' blocked
    web.0
    2022-03-09 20:31:37.472	warn	State "javascript.0.VIS.Views" has no existing object, this might lead to an error in future versions
    web.0
    2022-03-09 20:31:20.308	warn	State "javascript.0.VIS.Views" has no existing object, this might lead to an error in future versions
    zigbee.0
    2022-03-09 20:31:00.041	warn	Device query for '0x04cd15fffe02cb39' blocked
    zigbee.0
    2022-03-09 20:31:00.029	warn	Device query for '0x04cd15fffe02c35d' blocked
    zigbee.0
    2022-03-09 20:30:00.079	warn	Device query for '0x04cd15fffe02c35d' blocked
    zigbee.0
    2022-03-09 20:30:00.074	warn	Device query for '0x04cd15fffe02cb39' blocked
    zigbee.0
    2022-03-09 20:29:00.030	warn	Device query for '0x04cd15fffe02cb39' blocke
    zigbee.0
    2022-03-09 20:29:00.020	warn	Device query for '0x04cd15fffe02c35d' blocked
    zigbee.0
    2022-03-09 20:28:00.024	warn	Device query for '0x04cd15fffe02c35d' blocked
    zigbee.0
    2022-03-09 20:28:00.017	warn	Device query for '0x04cd15fffe02cb39' blocked
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @hertob81 Poste bitte auch mal was dazwischen an Warnmeldungen kommt. Es muss etwas geben. Der Timeout startet wenn die letzte Antwort vom Gerät gekommen (oder nicht gekommen) ist.
    A.
    H 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      A.
      hertob81
      schrieb am zuletzt editiert von hertob81
      @asgothian
      Ich poste das gerne, aber es gab dazwischen wirklich KEINE andere Fehlermeldung - also zumindest nicht die Devices betreffend.
      Was ich nicht verstehe: In dem DP (Screenshot siehe unten) steht IMMER "TRUE" drin. Und er triggert trotzdem immer weiter mit TRUE. Beschwert er sich evtl. weil schon TRUE drinnen steht?
      Hier ein aktueller Ausschnitt (Bitte die MEROSS-Steckdose ignorieren):
      meross.0
      15035	2022-03-10 07:59:48.686	info	Can not get Data for Device 1909127140323125186448e1e9038373: Error: Timeout
      zigbee.0
      12191	2022-03-10 07:59:00.037	warn	Device query for '0x04cd15fffe02cb39' blocked
      zigbee.0
      12191	2022-03-10 07:59:00.029	warn	Device query for '0x04cd15fffe02c35d' blocked
      meross.0
      15035	2022-03-10 07:58:05.674	info	Can not get Data for Device 1909127140323125186448e1e9038373: Error: Timeout
      zigbee.0
      12191	2022-03-10 07:58:00.040	warn	Device query for '0x04cd15fffe02c35d' blocked
      zigbee.0
      12191	2022-03-10 07:58:00.026	warn	Device query for '0x04cd15fffe02cb39' blocked
      zigbee.0
      12191	2022-03-10 07:57:00.047	warn	Device query for '0x04cd15fffe02cb39' blocked
      zigbee.0
      12191	2022-03-10 07:57:00.035	warn	Device query for '0x04cd15fffe02c35d' blocked
      web.0
      12326	2022-03-10 07:56:25.231	info	<==Disconnect system.user.admin from ::ffff:192.168.0.109 vis.0
      web.0
      12326	2022-03-10 07:56:24.520	info	<==Disconnect system.user.admin from ::ffff:192.168.0.109 vis.0
      meross.0
      15035	2022-03-10 07:56:22.630	info	Can not get Data for Device 1909127140323125186448e1e9038373: Error: Timeout
      web.0
      12326	2022-03-10 07:56:18.487	info	<==Disconnect system.user.admin from ::ffff:192.168.0.109 flot
      web.0
      12326	2022-03-10 07:56:18.485	info	<==Disconnect system.user.admin from ::ffff:192.168.0.109 flot
      web.0
      12326	2022-03-10 07:56:18.484	info	<==Disconnect system.user.admin from ::ffff:192.168.0.109 flot
      web.0
      12326	2022-03-10 07:56:18.471	info	<==Disconnect system.user.admin from ::ffff:192.168.0.109 flot
      web.0
      12326	2022-03-10 07:56:18.470	info	<==Disconnect system.user.admin from ::ffff:192.168.0.109 flot
      web.0
      12326	2022-03-10 07:56:18.468	info	<==Disconnect system.user.admin from ::ffff:192.168.0.109 flot
      web.0
      12326	2022-03-10 07:56:13.422	info	<==Disconnect system.user.admin from ::ffff:192.168.0.109 flot
      web.0
      12326	2022-03-10 07:56:13.421	info	<==Disconnect system.user.admin from ::ffff:192.168.0.109 flot
      web.0
      12326	2022-03-10 07:56:13.416	info	<==Disconnect system.user.admin from ::ffff:192.168.0.109 flot
      web.0
      12326	2022-03-10 07:56:13.388	info	<==Disconnect system.user.admin from ::ffff:192.168.0.109 flot
      web.0
      12326	2022-03-10 07:56:12.361	info	<==Disconnect system.user.admin from ::ffff:192.168.0.109 flot
      web.0
      12326	2022-03-10 07:56:12.360	info	<==Disconnect system.user.admin from ::ffff:192.168.0.109 flot
      zigbee.0
      12191	2022-03-10 07:56:00.053	warn	Device query for '0x04cd15fffe02c35d' blocked
      zigbee.0
      12191	2022-03-10 07:56:00.038	warn	Device query for '0x04cd15fffe02cb39' blocked
      web.0
      12326	2022-03-10 07:55:15.978	info	<==Disconnect system.user.admin from ::ffff:192.168.0.109 flotPreset
      web.0
      12326	2022-03-10 07:55:15.976	info	<==Disconnect system.user.admin from ::ffff:192.168.0.109 flotPreset
      zigbee.0
      12191	2022-03-10 07:55:00.055	warn	Device query for '0x04cd15fffe02cb39' blocked
      zigbee.0
      12191	2022-03-10 07:55:00.043	warn	Device query for '0x04cd15fffe02c35d' blocked
      meross.0
      15035	2022-03-10 07:54:39.624	info	Can not get Data for Device 1909127140323125186448e1e9038373: Error: Timeout
      zigbee.0
      12191	2022-03-10 07:54:00.138	warn	Device query for '0x04cd15fffe02c35d' blocked
      zigbee.0
      12191	2022-03-10 07:54:00.132	warn	Device query for '0x04cd15fffe02cb39' blocked
      Und hier mal der Datenpunkt:
      AsgothianA arteckA 2 Antworten Letzte Antwort
      • H hertob81
        @asgothian
        meross.0
        zigbee.0
        zigbee.0
        meross.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        web.0
        web.0
        meross.0
        web.0
        web.0
        web.0
        web.0
        web.0
        web.0
        web.0
        web.0
        web.0
        web.0
        web.0
        web.0
        zigbee.0
        zigbee.0
        web.0
        web.0
        zigbee.0
        zigbee.0
        meross.0
        zigbee.0
        zigbee.0
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @hertob81
        Bitte trag den Wert 04cd15fffe02 in den Datenpunkt zigbee.0.info.debugmessages.
        Ein Neustart des Adapters ist nicht notwendig. Du solltest im Log damit einiges an weiteren Log Meldungen von den betroffenen Steckdosen bekommen. Damit sollte zu erkennen sein was im Hintergrund passiert.
        A.
        • O Offline
          O Offline
          oFbEQnpoLKKl6mbY5e13
          @hertob81 sagte in TuYa TS0121_plug Zigbee Messintervall verkürzen:
          Nein, das ist schon korrekt so, da der Datenpunkt die Rolle "Button" (Taster) hat.
          • H hertob81
            @asgothian
            meross.0
            zigbee.0
            zigbee.0
            meross.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            web.0
            web.0
            meross.0
            web.0
            web.0
            web.0
            web.0
            web.0
            web.0
            web.0
            web.0
            web.0
            web.0
            web.0
            web.0
            zigbee.0
            zigbee.0
            web.0
            web.0
            zigbee.0
            zigbee.0
            meross.0
            zigbee.0
            zigbee.0
            arteckA Offline
            arteckA Offline
            arteck
            schalte die experten Sicht aus ... dan siehst du das es ein button ist
              @hertob81
              A.
              hertob81
              @asgothian sagte in TuYa TS0121_plug Zigbee Messintervall verkürzen:
              @hertob81
              A.
              Sorry, wo finde ich den DP?
              • arteckA arteck
                hertob81
                Die Expertensicht war aus...
                • H hertob81
                  @hertob81
                  A.
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @hertob81
                  :man-facepalming:
                  Steht da doch. Im Objektbaum, unter zigbee.0.info.debugmessages. Ich weiss nicht wie ich es noch genauer beschreiben soll.
                  A.
                  • H Offline
                    hertob81
                    @hertob81
                    :man-facepalming:
                    A.
                    Sorry, hatte den INFO Ordner übersehen...
                    zigbee.0
                    12191	2022-03-10 09:27:27.536	warn	ELEVATED publishToState: value generated 'false' from device 04cd15fffe02c35d for 'On/off state of the switch'
                    zigbee.0
                    12191	2022-03-10 09:27:27.535	warn	ELEVATED publishToState: message received '{"state":"OFF"}' from device 04cd15fffe02c35d type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:27.533	warn	ELEVATED publishToState: value generated '36' from device 04cd15fffe02c35d for 'Link quality'
                    zigbee.0
                    12191	2022-03-10 09:27:27.532	warn	ELEVATED publishToState: message received '{"linkquality":36}' from device 04cd15fffe02c35d type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:27.385	warn	ELEVATED publishToState: value generated 'false' from device 04cd15fffe02cb39 for 'On/off state of the switch'
                    zigbee.0
                    12191	2022-03-10 09:27:27.385	warn	ELEVATED publishToState: message received '{"state":"OFF"}' from device 04cd15fffe02cb39 type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:27.382	warn	ELEVATED publishToState: value generated '33' from device 04cd15fffe02cb39 for 'Link quality'
                    zigbee.0
                    12191	2022-03-10 09:27:27.381	warn	ELEVATED publishToState: message received '{"linkquality":33}' from device 04cd15fffe02cb39 type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:25.413	warn	ELEVATED publishToState: value generated 'false' from device 04cd15fffe02c35d for 'On/off state of the switch'
                    zigbee.0
                    12191	2022-03-10 09:27:25.412	warn	ELEVATED publishToState: message received '{"state":"OFF"}' from device 04cd15fffe02c35d type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:25.408	warn	ELEVATED publishToState: value generated '36' from device 04cd15fffe02c35d for 'Link quality'
                    zigbee.0
                    12191	2022-03-10 09:27:25.407	warn	ELEVATED publishToState: message received '{"linkquality":36}' from device 04cd15fffe02c35d type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:25.325	warn	ELEVATED publishToState: value generated 'false' from device 04cd15fffe02c35d for 'On/off state of the switch'
                    zigbee.0
                    12191	2022-03-10 09:27:25.325	warn	ELEVATED publishToState: message received '{"state":"OFF"}' from device 04cd15fffe02c35d type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:25.322	warn	ELEVATED publishToState: value generated '36' from device 04cd15fffe02c35d for 'Link quality'
                    zigbee.0
                    12191	2022-03-10 09:27:25.322	warn	ELEVATED publishToState: message received '{"linkquality":36}' from device 04cd15fffe02c35d type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:25.266	warn	ELEVATED publishToState: value generated 'false' from device 04cd15fffe02cb39 for 'On/off state of the switch'
                    zigbee.0
                    12191	2022-03-10 09:27:25.266	warn	ELEVATED publishToState: message received '{"state":"OFF"}' from device 04cd15fffe02cb39 type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:25.263	warn	ELEVATED publishToState: value generated '33' from device 04cd15fffe02cb39 for 'Link quality'
                    zigbee.0
                    12191	2022-03-10 09:27:25.263	warn	ELEVATED publishToState: message received '{"linkquality":33}' from device 04cd15fffe02cb39 type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:25.186	warn	ELEVATED publishToState: value generated 'false' from device 04cd15fffe02cb39 for 'On/off state of the switch'
                    zigbee.0
                    12191	2022-03-10 09:27:25.185	warn	ELEVATED publishToState: message received '{"state":"OFF"}' from device 04cd15fffe02cb39 type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:25.180	warn	ELEVATED publishToState: value generated '36' from device 04cd15fffe02cb39 for 'Link quality'
                    zigbee.0
                    12191	2022-03-10 09:27:25.180	warn	ELEVATED publishToState: message received '{"linkquality":36}' from device 04cd15fffe02cb39 type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:25.168	warn	ELEVATED publishToState: value generated 'false' from device 04cd15fffe02c35d for 'On/off state of the switch'
                    zigbee.0
                    12191	2022-03-10 09:27:25.168	warn	ELEVATED publishToState: message received '{"state":"OFF"}' from device 04cd15fffe02c35d type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:25.165	warn	ELEVATED publishToState: value generated '36' from device 04cd15fffe02c35d for 'Link quality'
                    zigbee.0
                    12191	2022-03-10 09:27:25.165	warn	ELEVATED publishToState: message received '{"linkquality":36}' from device 04cd15fffe02c35d type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:25.105	warn	ELEVATED publishToState: value generated 'false' from device 04cd15fffe02cb39 for 'On/off state of the switch'
                    zigbee.0
                    12191	2022-03-10 09:27:25.104	warn	ELEVATED publishToState: message received '{"state":"OFF"}' from device 04cd15fffe02cb39 type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:25.102	warn	ELEVATED publishToState: value generated '33' from device 04cd15fffe02cb39 for 'Link quality'
                    zigbee.0
                    12191	2022-03-10 09:27:25.101	warn	ELEVATED publishToState: message received '{"linkquality":33}' from device 04cd15fffe02cb39 type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:25.041	warn	ELEVATED Change state 'device_query' at device 0x04cd15fffe02c35d type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:25.029	warn	ELEVATED Change state 'device_query' at device 0x04cd15fffe02cb39 type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:25.018	warn	ELEVATED: User stateChange zigbee.0.04cd15fffe02c35d.device_query {"val":true,"ack":false,"ts":1646900845012,"q":0,"c":"script.js.Energieüberwachung.Trigger_Trockner","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1646895950007}
                    zigbee.0
                    12191	2022-03-10 09:27:25.015	warn	ELEVATED: User stateChange zigbee.0.04cd15fffe02cb39.device_query {"val":true,"ack":false,"ts":1646900845011,"q":0,"c":"script.js.Energieüberwachung.Trigger_Trockner","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1646895960005}
                    meross.0
                    15035	2022-03-10 09:27:22.174	info	Can not get Data for Device 1909127140323125186448e1e9038373: Error: Timeout
                    zigbee.0
                    12191	2022-03-10 09:27:00.069	warn	Device query for '0x04cd15fffe02cb39' blocked
                    zigbee.0
                    12191	2022-03-10 09:27:00.065	warn	ELEVATED Change state 'device_query' at device 0x04cd15fffe02cb39 type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:00.060	warn	Device query for '0x04cd15fffe02c35d' blocked
                    zigbee.0
                    12191	2022-03-10 09:27:00.056	warn	ELEVATED Change state 'device_query' at device 0x04cd15fffe02c35d type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:27:00.052	warn	ELEVATED: User stateChange zigbee.0.04cd15fffe02cb39.device_query {"val":true,"ack":false,"ts":1646900820048,"q":0,"c":"script.js.Energieüberwachung.Trigger_Trockner","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1646895960005}
                    zigbee.0
                    12191	2022-03-10 09:27:00.048	warn	ELEVATED: User stateChange zigbee.0.04cd15fffe02c35d.device_query {"val":true,"ack":false,"ts":1646900820036,"q":0,"c":"script.js.Energieüberwachung.Trigger_Trockner","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1646895950007}
                    zigbee.0
                    12191	2022-03-10 09:26:56.807	warn	ELEVATED publishToState: value generated '235' from device 04cd15fffe02cb39 for 'Load voltage'
                    zigbee.0
                    12191	2022-03-10 09:26:56.807	warn	ELEVATED publishToState: value generated '0' from device 04cd15fffe02cb39 for 'Instantaneous measured electrical current'
                    zigbee.0
                    12191	2022-03-10 09:26:56.807	warn	ELEVATED publishToState: value generated '0' from device 04cd15fffe02cb39 for 'Load power'
                    zigbee.0
                    12191	2022-03-10 09:26:56.806	warn	ELEVATED publishToState: message received '{"power":0,"current":0,"voltage":235}' from device 04cd15fffe02cb39 type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:26:56.800	warn	ELEVATED publishToState: value generated '36' from device 04cd15fffe02cb39 for 'Link quality'
                    zigbee.0
                    12191	2022-03-10 09:26:56.799	warn	ELEVATED publishToState: message received '{"linkquality":36}' from device 04cd15fffe02cb39 type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:26:56.635	warn	ELEVATED publishToState: value generated '235' from device 04cd15fffe02c35d for 'Load voltage'
                    zigbee.0
                    12191	2022-03-10 09:26:56.635	warn	ELEVATED publishToState: value generated '0' from device 04cd15fffe02c35d for 'Instantaneous measured electrical current'
                    zigbee.0
                    12191	2022-03-10 09:26:56.634	warn	ELEVATED publishToState: value generated '0' from device 04cd15fffe02c35d for 'Load power'
                    zigbee.0
                    12191	2022-03-10 09:26:56.634	warn	ELEVATED publishToState: message received '{"power":0,"current":0,"voltage":235}' from device 04cd15fffe02c35d type 'TS0121_plug'
                    zigbee.0
                    12191	2022-03-10 09:26:56.621	warn	ELEVATED publishToState: value generated '21' from device 04cd15fffe02c35d for 'Link quality'
                    zigbee.0
                    12191	2022-03-10 09:26:56.620	warn	ELEVATED publishToState: message received '{"linkquality":21}' from device 04cd15fffe02c35d type 'TS0121_plug'
                    • H hertob81
                      @hertob81
                      A.
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @hertob81
                      das ding antwortet nicht
                      H AsgothianA 2 Antworten Letzte Antwort
                      • arteckA arteck
                        @hertob81
                        hertob81
                        @hertob81
                        Hmmm, okay.
                        Ich habe aber zugriff über VIS, Alexa und Co.
                        Nochmal neu anlernen?
                        • arteckA arteck
                          @hertob81
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          @hertob81
                          Das "Ding" ist nicht im Zigbee Adapter. Das ist es also nicht.
                          A.
                          • arteckA Offline
                            arteckA Offline
                            arteck
                            @asgothian augenauf ist ja meross.... jo
                            • arteckA arteck
                              hertob81
                              Ja, das mit der MEROSS weiss ich, bzw. das ist klar.
                              • H hertob81
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @hertob81 Zurück zum Thema - ich muss verifizieren ob das Blockierende Intervall device spezifisch oder generell implementiert ist. das kann ich aber erst am Wochenende tun.
                                A.
                                  A.
                                  hertob81
                                  A.
                                  Hast Du schon schauen können?
                                  • H hertob81
                                    A.
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    @hertob81 Habe ich - das Intervall ist 10 sekunden nach der Antwort eines Gerätes und es ist gerätespezifisch.
                                    A.
