  4. Tuya rgb LED Strip will nicht
    6.0k
40 Beiträge 3 Kommentatoren 3.7k Aufrufe 3 Beobachtet
  • O oFbEQnpoLKKl6mbY5e13
    @kla960
    Das weiß ich nicht
    kla960
    @ofbeqnpolkkl6mby5e13
    Sorry wenn ich Nerve. Aber einer will nicht online gehen. Liegt es ggf. daran, dass der Adapter das Schema nicht kennt?
    2022-02-25 17:38:21.303 - debug: tuya.0 (30968) Found 2 device schema information
    2022-02-25 17:38:21.303 - info: tuya.0 (30968) new Schema added for product type 5tnccdqna35enim9. Please send next line from logfile on disk to developer!
    2022-02-25 17:38:21.304 - info: tuya.0 (30968) {"schemaExt":"[{\"complexType\":\"\",\"id\":22,\"inputStyle\":\"\",\"inputType\":\"percent1\"},{\"complexType\":\"\",\"id\":23,\"inputStyle\":\"\",\"inputType\":\"percent\"},{\"complexType\":\"\",\"id\":26,\"inputStyle\":\"\",\"inputType\":\"countdown1\"}]","schema":"[{\"mode\":\"rw\",\"code\":\"switch_led\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power\",\"id\":20,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"work_mode\",\"name\":\"模式\",\"property\":{\"range\":[\"white\",\"colour\",\"scene\",\"music\"],\"type\":\"enum\"},\"iconname\":\"icon-dp_mode\",\"id\":21,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"colour_data\",\"name\":\"彩光\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-yanse\",\"id\":24,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"scene_data\",\"name\":\"场景\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-shoucang\",\"id\":25,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-a_nav_timer\",\"id\":26,\"type\":\"obj\"},{\"mode\":\"wr\",\"code\":\"music_data\",\"name\":\"音乐律动\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-dp_mic\",\"id\":27,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"mic_music_data\",\"name\":\"麦克风音乐律动\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-dp_mode\",\"id\":42,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"dreamlightmic_music_data\",\"name\":\"炫彩本地音乐律动\",\"property\":{\"type\":\"raw\",\"maxlen\":\"255\"},\"iconname\":\"icon-dp_mode\",\"id\":52,\"type\":\"raw\"}]"}
    2022-02-25 17:38:21.305 - debug: tuya.0 (30968) Found 2 devices
    2022-02-25 17:38:21.305 - debug: tuya.0 (30968) 08200118e868e759568a: Schema found for lwnbiytsfgk6slyr: {"schema":[{"mode":"rw","code":"switch_led","name":"开关","property":{"type":"bool"},"id":20,"type":"obj"},{"mode":"rw","code":"work_mode","name":"模式","property":{"range":["white","colour","scene","music","smooth","flash"],"type":"enum"},"id":21,"type":"obj"},{"mode":"rw","code":"bright_value","name":"亮度值","property":{"unit":"","min":10,"max":1000,"scale":0,"step":1,"type":"value"},"id":22,"type":"obj"},{"mode":"rw","code":"colour_data","name":"彩光","property":{"type":"string","maxlen":255},"id":24,"type":"obj"},{"mode":"rw","code":"scene_data","name":"场景","property":{"type":"string","maxlen":255},"id":25,"type":"obj"},{"mode":"rw","code":"countdown","name":"倒计时","property":{"unit":"","min":0,"max":86400,"scale":0,"step":1,"type":"value"},"id":26,"type":"obj"},{"mode":"wr","code":"music_data","name":"音乐灯","property":{"type":"string","maxlen":255},"id":27,"type":"obj"},{"mode":"wr","code":"control_data","name":"调节","property":{"type":"string","maxlen":255},"id":28,"type":"obj"},{"mode":"rw","code":"mic_sense","name":"麦克风灵敏度","property":{"unit":"","min":1,"max":100,"scale":0,"step":1,"type":"value"},"id":101,"type":"obj"},{"mode":"rw","code":"change_speed","name":"变化速度","property":{"unit":"","min":1,"max":100,"scale":0,"step":1,"type":"value"},"id":102,"type":"obj"},{"mode":"rw","code":"music_type","name":"音乐风格","property":{"range":["soft","classic","rock"],"type":"enum"},"id":106,"type":"obj"}],"schemaExt":[]}
    2022-02-25 17:38:21.308 - debug: tuya.0 (30968) 08200118e868e759568a: Disconnected from device
    2022-02-25 17:38:21.308 - debug: tuya.0 (30968) 08200118e868e759568a: Create device objects if not exist
    2022-02-25 17:38:21.310 - debug: tuya.0 (30968) 08200118e868e759568a: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music","4":"smooth","5":"flash"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"number","min":10,"max":1000,"read":true,"write":true,"name":"bright_value","id":22,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"mic_sense","id":101,"role":"level"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"change_speed","id":102,"role":"level"},{"type":"number","states":{"0":"soft","1":"classic","2":"rock"},"read":true,"write":true,"name":"music_type","id":106,"role":"level"}]
    2022-02-25 17:38:21.310 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 20
    2022-02-25 17:38:21.311 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 21
    2022-02-25 17:38:21.311 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 22
    2022-02-25 17:38:21.312 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 24
    2022-02-25 17:38:21.312 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 25
    2022-02-25 17:38:21.312 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 26
    2022-02-25 17:38:21.313 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 27
    2022-02-25 17:38:21.313 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 28
    2022-02-25 17:38:21.314 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 101
    2022-02-25 17:38:21.314 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 102
    2022-02-25 17:38:21.314 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 106
    2022-02-25 17:38:21.315 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Schema found for 5tnccdqna35enim9: {"schema":[{"mode":"rw","code":"switch_led","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power","id":20,"type":"obj"},{"mode":"rw","code":"work_mode","name":"模式","property":{"range":["white","colour","scene","music"],"type":"enum"},"iconname":"icon-dp_mode","id":21,"type":"obj"},{"mode":"rw","code":"colour_data","name":"彩光","property":{"type":"string","maxlen":255},"iconname":"icon-yanse","id":24,"type":"obj"},{"mode":"rw","code":"scene_data","name":"场景","property":{"type":"string","maxlen":255},"iconname":"icon-shoucang","id":25,"type":"obj"},{"mode":"rw","code":"countdown","name":"倒计时","property":{"min":0,"max":86400,"scale":0,"step":1,"type":"value"},"iconname":"icon-a_nav_timer","id":26,"type":"obj"},{"mode":"wr","code":"music_data","name":"音乐律动","property":{"type":"string","maxlen":255},"iconname":"icon-dp_mic","id":27,"type":"obj"},{"mode":"rw","code":"mic_music_data","name":"麦克风音乐律动","property":{"type":"string","maxlen":255},"iconname":"icon-dp_mode","id":42,"type":"obj"},{"mode":"rw","code":"dreamlightmic_music_data","name":"炫彩本地音乐律动","property":{"type":"raw","maxlen":"255"},"iconname":"icon-dp_mode","id":52,"type":"raw"}],"schemaExt":[{"complexType":"","id":22,"inputStyle":"","inputType":"percent1"},{"complexType":"","id":23,"inputStyle":"","inputType":"percent"},{"complexType":"","id":26,"inputStyle":"","inputType":"countdown1"}]}
    2022-02-25 17:38:21.317 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Create device objects if not exist
    2022-02-25 17:38:21.318 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"mic_music_data","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"dreamlightmic_music_data","id":52,"role":"text"}]
    2022-02-25 17:38:21.318 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 20
    2022-02-25 17:38:21.319 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 21
    2022-02-25 17:38:21.319 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 24
    2022-02-25 17:38:21.319 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 25
    2022-02-25 17:38:21.320 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 26
    2022-02-25 17:38:21.320 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 27
    2022-02-25 17:38:21.323 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 42
    2022-02-25 17:38:21.323 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 52
    2022-02-25 17:38:21.325 - debug: tuya.0 (30968) sendTo "getProxyResult" to system.adapter.admin.0 from system.adapter.tuya.0
    2022-02-25 17:38:21.337 - warn: tuya.0 (30968) State "tuya.0.bf69b3293c1edff39ffjsi.online" has no existing object, this might lead to an error in future versions
    2022-02-25 17:38:21.342 - debug: tuya.0 (30968) connected set to false
    2022-02-25 17:38:21.345 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1645807101339,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101339}
    2022-02-25 17:38:21.346 - debug: tuya.0 (30968) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1645807101339,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101339}
    2022-02-25 17:38:21.346 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1645807101339,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101339}
    2022-02-25 17:38:21.347 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.online {"val":false,"ack":true,"ts":1645807101339,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807097739}
    2022-02-25 17:38:21.359 - debug: tuya.0 (30968) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":620,"ack":false,"time":1645807101356},"_id":65753901}
    2022-02-25 17:38:21.360 - debug: tuya.0 (30968) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
    2022-02-25 17:38:21.368 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1645807101365,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709492529}
    2022-02-25 17:38:21.391 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1645807101386,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
    2022-02-25 17:38:21.397 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1645807101395,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
    2022-02-25 17:38:21.409 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.24 {"val":"00f003e803e8","ack":true,"ts":1645807101407,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709486787}
    2022-02-25 17:38:21.416 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1645807101414,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
    2022-02-25 17:38:21.429 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1645807101427,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
    2022-02-25 17:38:21.435 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.27 {"val":"","ack":true,"ts":1645807101433,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113069}
    2022-02-25 17:38:21.445 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.28 {"val":"","ack":true,"ts":1645807101443,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703822315}
    2022-02-25 17:38:21.450 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1645807101448,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
    2022-02-25 17:38:21.460 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1645807101458,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
    2022-02-25 17:38:21.464 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1645807101462,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
    2022-02-25 17:38:21.482 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.20 {"val":false,"ack":true,"ts":1645807101477,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101477}
    2022-02-25 17:38:21.494 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.21 {"val":1,"ack":true,"ts":1645807101491,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101491}
    2022-02-25 17:38:21.514 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.24 {"val":"007803e800b4","ack":true,"ts":1645807101511,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101511}
    2022-02-25 17:38:21.524 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.25 {"val":"04464602007803e803e800000000464602007803e8000a00000000","ack":true,"ts":1645807101522,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101522}
    2022-02-25 17:38:21.528 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.26 {"val":0,"ack":true,"ts":1645807101526,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101526}
    2022-02-25 17:38:21.538 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.27 {"val":"","ack":true,"ts":1645807101535,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101535}
    2022-02-25 17:38:21.542 - info: tuya.0 (30968) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
    2022-02-25 17:38:21.545 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.42 {"val":"0001c9026432007203e800900344005a03e800470289","ack":true,"ts":1645807101541,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101541}
    2022-02-25 17:38:21.589 - info: tuya.0 (30968) 08200118e868e759568a Init with IP=192.168.179.28, Key=f9e4d104d04a30ec, Version=3.3
    2022-02-25 17:38:21.591 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.52 {"val":"","ack":true,"ts":1645807101587,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101587}
    2022-02-25 17:38:21.655 - debug: tuya.0 (30968) 08200118e868e759568a: Connected to device
    2022-02-25 17:38:21.660 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1645807101659,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101659}
    2022-02-25 17:38:21.661 - debug: tuya.0 (30968) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1645807101659,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101659}
    2022-02-25 17:38:21.661 - debug: tuya.0 (30968) connected set to true
    2022-02-25 17:38:21.693 - debug: tuya.0 (30968) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"00f003e803e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
    2022-02-25 17:38:21.708 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1645807101697,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709492529}
    2022-02-25 17:38:21.719 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1645807101705,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
    2022-02-25 17:38:21.719 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1645807101705,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
    2022-02-25 17:38:21.720 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.24 {"val":"00f003e803e8","ack":true,"ts":1645807101706,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709486787}
    2022-02-25 17:38:21.720 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1645807101706,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
    2022-02-25 17:38:21.721 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1645807101706,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
    2022-02-25 17:38:21.721 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1645807101707,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
    2022-02-25 17:38:21.722 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1645807101707,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
    2022-02-25 17:38:21.722 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1645807101707,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
    2022-02-25 17:38:21.775 - debug: tuya.0 (30968) Found 2 device schema information
    2022-02-25 17:38:21.775 - debug: tuya.0 (30968) Found 2 devices
    2022-02-25 17:38:21.776 - debug: tuya.0 (30968) 08200118e868e759568a: Schema found for lwnbiytsfgk6slyr: {"schema":[{"mode":"rw","code":"switch_led","name":"开关","property":{"type":"bool"},"id":20,"type":"obj"},{"mode":"rw","code":"work_mode","name":"模式","property":{"range":["white","colour","scene","music","smooth","flash"],"type":"enum"},"id":21,"type":"obj"},{"mode":"rw","code":"bright_value","name":"亮度值","property":{"unit":"","min":10,"max":1000,"scale":0,"step":1,"type":"value"},"id":22,"type":"obj"},{"mode":"rw","code":"colour_data","name":"彩光","property":{"type":"string","maxlen":255},"id":24,"type":"obj"},{"mode":"rw","code":"scene_data","name":"场景","property":{"type":"string","maxlen":255},"id":25,"type":"obj"},{"mode":"rw","code":"countdown","name":"倒计时","property":{"unit":"","min":0,"max":86400,"scale":0,"step":1,"type":"value"},"id":26,"type":"obj"},{"mode":"wr","code":"music_data","name":"音乐灯","property":{"type":"string","maxlen":255},"id":27,"type":"obj"},{"mode":"wr","code":"control_data","name":"调节","property":{"type":"string","maxlen":255},"id":28,"type":"obj"},{"mode":"rw","code":"mic_sense","name":"麦克风灵敏度","property":{"unit":"","min":1,"max":100,"scale":0,"step":1,"type":"value"},"id":101,"type":"obj"},{"mode":"rw","code":"change_speed","name":"变化速度","property":{"unit":"","min":1,"max":100,"scale":0,"step":1,"type":"value"},"id":102,"type":"obj"},{"mode":"rw","code":"music_type","name":"音乐风格","property":{"range":["soft","classic","rock"],"type":"enum"},"id":106,"type":"obj"}],"schemaExt":[]}
    2022-02-25 17:38:21.778 - debug: tuya.0 (30968) 08200118e868e759568a: Disconnected from device
    2022-02-25 17:38:21.778 - debug: tuya.0 (30968) 08200118e868e759568a: Create device objects if not exist
    2022-02-25 17:38:21.779 - debug: tuya.0 (30968) 08200118e868e759568a: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music","4":"smooth","5":"flash"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"number","min":10,"max":1000,"read":true,"write":true,"name":"bright_value","id":22,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"mic_sense","id":101,"role":"level"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"change_speed","id":102,"role":"level"},{"type":"number","states":{"0":"soft","1":"classic","2":"rock"},"read":true,"write":true,"name":"music_type","id":106,"role":"level"}]
    2022-02-25 17:38:21.780 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 20
    2022-02-25 17:38:21.780 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 21
    2022-02-25 17:38:21.780 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 22
    2022-02-25 17:38:21.781 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 24
    2022-02-25 17:38:21.781 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 25
    2022-02-25 17:38:21.781 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 26
    2022-02-25 17:38:21.782 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 27
    2022-02-25 17:38:21.782 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 28
    2022-02-25 17:38:21.782 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 101
    2022-02-25 17:38:21.783 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 102
    2022-02-25 17:38:21.783 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 106
    2022-02-25 17:38:21.784 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Schema found for 5tnccdqna35enim9: {"schema":[{"mode":"rw","code":"switch_led","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power","id":20,"type":"obj"},{"mode":"rw","code":"work_mode","name":"模式","property":{"range":["white","colour","scene","music"],"type":"enum"},"iconname":"icon-dp_mode","id":21,"type":"obj"},{"mode":"rw","code":"colour_data","name":"彩光","property":{"type":"string","maxlen":255},"iconname":"icon-yanse","id":24,"type":"obj"},{"mode":"rw","code":"scene_data","name":"场景","property":{"type":"string","maxlen":255},"iconname":"icon-shoucang","id":25,"type":"obj"},{"mode":"rw","code":"countdown","name":"倒计时","property":{"min":0,"max":86400,"scale":0,"step":1,"type":"value"},"iconname":"icon-a_nav_timer","id":26,"type":"obj"},{"mode":"wr","code":"music_data","name":"音乐律动","property":{"type":"string","maxlen":255},"iconname":"icon-dp_mic","id":27,"type":"obj"},{"mode":"rw","code":"mic_music_data","name":"麦克风音乐律动","property":{"type":"string","maxlen":255},"iconname":"icon-dp_mode","id":42,"type":"obj"},{"mode":"rw","code":"dreamlightmic_music_data","name":"炫彩本地音乐律动","property":{"type":"raw","maxlen":"255"},"iconname":"icon-dp_mode","id":52,"type":"raw"}],"schemaExt":[{"complexType":"","id":22,"inputStyle":"","inputType":"percent1"},{"complexType":"","id":23,"inputStyle":"","inputType":"percent"},{"complexType":"","id":26,"inputStyle":"","inputType":"countdown1"}]}
    2022-02-25 17:38:21.785 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Create device objects if not exist
    2022-02-25 17:38:21.786 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"mic_music_data","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"dreamlightmic_music_data","id":52,"role":"text"}]
    2022-02-25 17:38:21.787 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 20
    2022-02-25 17:38:21.787 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 21
    2022-02-25 17:38:21.788 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 24
    2022-02-25 17:38:21.788 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 25
    2022-02-25 17:38:21.788 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 26
    2022-02-25 17:38:21.789 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 27
    2022-02-25 17:38:21.789 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 42
    2022-02-25 17:38:21.789 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 52
    2022-02-25 17:38:21.800 - warn: tuya.0 (30968) State "tuya.0.bf69b3293c1edff39ffjsi.online" has no existing object, this might lead to an error in future versions
    2022-02-25 17:38:21.810 - debug: tuya.0 (30968) connected set to false
    2022-02-25 17:38:21.815 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1645807101801,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101801}
    2022-02-25 17:38:21.815 - debug: tuya.0 (30968) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1645807101801,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101801}
    2022-02-25 17:38:21.816 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1645807101802,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101802}
    2022-02-25 17:38:21.817 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.online {"val":false,"ack":true,"ts":1645807101802,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807097739}
    2022-02-25 17:38:21.835 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1645807101828,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709492529}
    2022-02-25 17:38:21.854 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1645807101852,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
    2022-02-25 17:38:21.863 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1645807101861,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
    2022-02-25 17:38:21.878 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.24 {"val":"00f003e803e8","ack":true,"ts":1645807101873,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709486787}
    2022-02-25 17:38:21.884 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1645807101882,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
    2022-02-25 17:38:21.897 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1645807101894,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
    2022-02-25 17:38:21.902 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.27 {"val":"","ack":true,"ts":1645807101900,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113069}
    2022-02-25 17:38:21.917 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.28 {"val":"","ack":true,"ts":1645807101912,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703822315}
    2022-02-25 17:38:21.923 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1645807101921,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
    2022-02-25 17:38:21.935 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1645807101932,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
    2022-02-25 17:38:21.943 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1645807101939,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
    2022-02-25 17:38:21.958 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.20 {"val":false,"ack":true,"ts":1645807101956,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101477}
    2022-02-25 17:38:21.966 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.21 {"val":1,"ack":true,"ts":1645807101964,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101491}
    2022-02-25 17:38:21.988 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.24 {"val":"007803e800b4","ack":true,"ts":1645807101985,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101511}
    2022-02-25 17:38:21.993 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.25 {"val":"04464602007803e803e800000000464602007803e8000a00000000","ack":true,"ts":1645807101991,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101522}
    2022-02-25 17:38:22.014 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.26 {"val":0,"ack":true,"ts":1645807102012,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101526}
    2022-02-25 17:38:22.022 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.27 {"val":"","ack":true,"ts":1645807102019,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101535}
    2022-02-25 17:38:22.037 - info: tuya.0 (30968) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
    2022-02-25 17:38:22.042 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.42 {"val":"0001c9026432007203e800900344005a03e800470289","ack":true,"ts":1645807102036,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101541}
    2022-02-25 17:38:22.077 - info: tuya.0 (30968) 08200118e868e759568a Init with IP=192.168.179.28, Key=f9e4d104d04a30ec, Version=3.3
    2022-02-25 17:38:22.080 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.52 {"val":"","ack":true,"ts":1645807102077,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101587}
    2022-02-25 17:38:22.081 - debug: tuya.0 (30968) 08200118e868e759568a: Connected to device
    2022-02-25 17:38:22.088 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1645807102086,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807102086}
    2022-02-25 17:38:22.089 - debug: tuya.0 (30968) connected set to true
    2022-02-25 17:38:22.090 - debug: tuya.0 (30968) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1645807102086,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807102086}
    2022-02-25 17:38:22.116 - debug: tuya.0 (30968) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"00f003e803e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
    2022-02-25 17:38:22.125 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1645807102119,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709492529}
    2022-02-25 17:38:22.135 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1645807102123,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
    2022-02-25 17:38:22.136 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1645807102124,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
    2022-02-25 17:38:22.136 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.24 {"val":"00f003e803e8","ack":true,"ts":1645807102124,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709486787}
    2022-02-25 17:38:22.136 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1645807102124,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
    2022-02-25 17:38:22.137 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1645807102124,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
    2022-02-25 17:38:22.137 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1645807102124,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
    2022-02-25 17:38:22.138 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1645807102125,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
    2022-02-25 17:38:22.138 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1645807102125,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
    2022-02-25 17:38:22.769 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Error from device (0): App still open on your mobile phone? Error: connection timed out
    2022-02-25 17:38:22.769 - error: tuya.0 (30968) bf69b3293c1edff39ffjsi: connection timed out
    2022-02-25 17:38:26.544 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Error from device (1): App still open on your mobile phone? Error: connection timed out
    2022-02-25 17:38:26.544 - error: tuya.0 (30968) bf69b3293c1edff39ffjsi: connection timed out
    2022-02-25 17:38:27.039 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Error from device (2): App still open on your mobile phone? Error: connection timed out
    2022-02-25 17:38:27.039 - error: tuya.0 (30968) bf69b3293c1edff39ffjsi: connection timed out
    2022-02-25 17:38:30.438 - warn: tuya.0 (30968) Exception: Error: first argument must be a valid error code number
    2022-02-25 17:38:30.439 - debug: tuya.0 (30968) 08200118e868e759568a: Disconnected from device
    2022-02-25 17:38:30.441 - error: tuya.0 (30968) uncaught exception: first argument must be a valid error code number
    2022-02-25 17:38:30.443 - error: tuya.0 (30968) Error: first argument must be a valid error code number
    at Sender.close (/opt/iobroker/node_modules/http-mitm-proxy/node_modules/ws/lib/Sender.js:121:13)
    at WebSocket.close (/opt/iobroker/node_modules/http-mitm-proxy/node_modules/ws/lib/WebSocket.js:281:18)
    at /opt/iobroker/node_modules/http-mitm-proxy/lib/proxy.js:983:38
    at wrapper (/opt/iobroker/node_modules/http-mitm-proxy/node_modules/async/dist/async.js:271:20)
    at eachOfArrayLike (/opt/iobroker/node_modules/http-mitm-proxy/node_modules/async/dist/async.js:490:13)
    at eachOf (/opt/iobroker/node_modules/http-mitm-proxy/node_modules/async/dist/async.js:626:16)
    at awaitable (/opt/iobroker/node_modules/http-mitm-proxy/node_modules/async/dist/async.js:211:32)
    at Object.eachLimit (/opt/iobroker/node_modules/http-mitm-proxy/node_modules/async/dist/async.js:2686:16)
    at Object.awaitable (/opt/iobroker/node_modules/http-mitm-proxy/node_modules/async/dist/async.js:211:32)
    at Proxy._onWebSocketClose (/opt/iobroker/node_modules/http-mitm-proxy/lib/proxy.js:975:11)
    2022-02-25 17:38:30.444 - error: tuya.0 (30968) first argument must be a valid error code number
    2022-02-25 17:38:30.452 - info: tuya.0 (30968) terminating
    2022-02-25 17:38:30.454 - debug: tuya.0 (30968) Plugin sentry destroyed
    2022-02-25 17:38:30.454 - warn: tuya.0 (30968) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-02-25 17:38:30.458 - debug: tuya.0 (30968) connected set to false
    2022-02-25 17:38:31.052 - error: host.iobroker-slave instance system.adapter.tuya.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-02-25 17:39:02.361 - debug: tuya.0 (32141) Redis Objects: Use Redis connection: iobroker-master:9001
    2022-02-25 17:39:02.414 - debug: tuya.0 (32141) Objects client ready ... initialize now
    2022-02-25 17:39:02.417 - debug: tuya.0 (32141) Objects create System PubSub Client
    2022-02-25 17:39:02.418 - debug: tuya.0 (32141) Objects create User PubSub Client
    2022-02-25 17:39:02.419 - debug: tuya.0 (32141) Objects client initialize lua scripts
    2022-02-25 17:39:02.433 - debug: tuya.0 (32141) Objects connected to redis: iobroker-master:9001
    2022-02-25 17:39:02.442 - debug: tuya.0 (32141) objectDB connected
    2022-02-25 17:39:02.445 - debug: tuya.0 (32141) Redis States: Use Redis connection: redis:6379
    2022-02-25 17:39:02.455 - debug: tuya.0 (32141) States create System PubSub Client
    2022-02-25 17:39:02.457 - debug: tuya.0 (32141) States create User PubSub Client
    2022-02-25 17:39:02.467 - debug: tuya.0 (32141) States connected to redis: redis:6379
    2022-02-25 17:39:02.468 - debug: tuya.0 (32141) statesDB connected
    2022-02-25 17:39:02.698 - debug: tuya.0 (32141) Plugin sentry Initialize Plugin (enabled=true)
    2022-02-25 17:39:02.703 - info: tuya.0 (32141) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-02-25 17:39:02.714 - info: tuya.0 (32141) starting. Version 3.6.15 in /opt/iobroker/node_modules/iobroker.tuya, node: v14.18.2, js-controller: 3.3.22
    2022-02-25 17:39:02.777 - debug: tuya.0 (32141) init 2 known devices
    2022-02-25 17:39:02.780 - debug: tuya.0 (32141) 08200118e868e759568a: Create device objects if not exist
    2022-02-25 17:39:02.783 - debug: tuya.0 (32141) 08200118e868e759568a: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music","4":"smooth","5":"flash"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"number","min":10,"max":1000,"read":true,"write":true,"name":"bright_value","id":22,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"mic_sense","id":101,"role":"level"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"change_speed","id":102,"role":"level"},{"type":"number","states":{"0":"soft","1":"classic","2":"rock"},"read":true,"write":true,"name":"music_type","id":106,"role":"level"}]
    2022-02-25 17:39:02.785 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 20
    2022-02-25 17:39:02.786 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 21
    2022-02-25 17:39:02.788 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 22
    2022-02-25 17:39:02.788 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 24
    2022-02-25 17:39:02.789 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 25
    2022-02-25 17:39:02.790 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 26
    2022-02-25 17:39:02.790 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 27
    2022-02-25 17:39:02.791 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 28
    2022-02-25 17:39:02.791 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 101
    2022-02-25 17:39:02.792 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 102
    2022-02-25 17:39:02.792 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 106
    2022-02-25 17:39:02.794 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi: Create device objects if not exist
    2022-02-25 17:39:02.796 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"mic_music_data","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"dreamlightmic_music_data","id":52,"role":"text"}]
    2022-02-25 17:39:02.796 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi Register onChange for 20
    2022-02-25 17:39:02.797 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi Register onChange for 21
    2022-02-25 17:39:02.797 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi Register onChange for 24
    2022-02-25 17:39:02.798 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi Register onChange for 25
    2022-02-25 17:39:02.798 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi Register onChange for 26
    2022-02-25 17:39:02.799 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi Register onChange for 27
    2022-02-25 17:39:02.799 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi Register onChange for 42
    2022-02-25 17:39:02.800 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi Register onChange for 52
    2022-02-25 17:39:02.807 - debug: tuya.0 (32141) connected set to false
    2022-02-25 17:39:02.952 - info: tuya.0 (32141) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
    2022-02-25 17:39:02.996 - info: tuya.0 (32141) 08200118e868e759568a Init with IP=192.168.179.28, Key=f9e4d104d04a30ec, Version=3.3
    2022-02-25 17:39:02.997 - info: tuya.0 (32141) Existing devices initialized
    2022-02-25 17:39:03.003 - info: tuya.0 (32141) Listen for local Tuya devices on port 6666
    2022-02-25 17:39:03.004 - info: tuya.0 (32141) Listen for encrypted local Tuya devices on port 6667
    2022-02-25 17:39:03.024 - debug: tuya.0 (32141) 08200118e868e759568a: Connected to device
    2022-02-25 17:39:03.036 - debug: tuya.0 (32141) 08200118e868e759568a: Error from device (0): App still open on your mobile phone? Error: Error from socket: write ECONNRESET
    2022-02-25 17:39:03.038 - debug: tuya.0 (32141) 08200118e868e759568a: Disconnected from device
    2022-02-25 17:39:03.047 - debug: tuya.0 (32141) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1645807143042,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807143042}
    2022-02-25 17:39:03.048 - debug: tuya.0 (32141) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1645807143043,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807143043}
    2022-02-25 17:39:03.049 - debug: tuya.0 (32141) connected set to false
    2022-02-25 17:39:03.051 - debug: tuya.0 (32141) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1645807143043,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807110457}
    2022-02-25 17:39:03.083 - debug: tuya.0 (32141) connected set to false
    2022-02-25 17:39:03.086 - debug: tuya.0 (32141) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1645807143082,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807143082}
    2022-02-25 17:39:06.466 - debug: tuya.0 (32141) Discovered encrypted device and store for later usage: 192.168.179.53:53813 - 000055aa00000000000000130000009c00000000d09766676f3369eb10b5e9f132fd802a58ef5662b8d5ed0ce59c56875111dfd0db47deeb95d128ee5671c7659fb0f99062752cccf8912dc171de390d8bc81f4159bd59981c26d5958da187e096d937c840b1058c6d8cd9456f3f7e28eed4932bd684776d4d3bbbcc727ed5338dc70040ebe90a09c0e74796dc81a6517ad39c8f8494c932e298de410f638ed8bf10587ab027a3c60000aa55
    2022-02-25 17:39:07.592 - debug: tuya.0 (32141) Discovered encrypted device and store for later usage: 192.168.179.28:49154 - 000055aa0000000000000013000000ac00000000d09766676f3369eb10b5e9f132fd802a0c92562f997bb947bcb6972c91d408d519c5020ec282229e73b2b864523d6a1f7f54fa4421812b6f2afc9adbe042a6295c907565b323a346d0de78c22f1fdaba1ae7c613c2cae004e54a474561367714379e7d68a02456269f4616388e2aa04eb49deffb70062d1a32380cd69ea07e8e77fba272ba2c7f0126b30472c4ce7d9d384363dcd0f0705ae4cac595bbf49625c46b79a30000aa55
    2022-02-25 17:39:07.959 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi: Error from device (0): App still open on your mobile phone? Error: connection timed out
    2022-02-25 17:39:07.960 - error: tuya.0 (32141) bf69b3293c1edff39ffjsi: connection timed out
    2022-02-25 17:39:33.128 - debug: tuya.0 (32141) 08200118e868e759568a: Connected to device
    2022-02-25 17:39:33.135 - debug: tuya.0 (32141) 08200118e868e759568a: Error from device (1): App still open on your mobile phone? Error: Error from socket: read ECONNRESET
    2022-02-25 17:39:33.137 - debug: tuya.0 (32141) 08200118e868e759568a: Disconnected from device
    2022-02-25 17:39:33.138 - debug: tuya.0 (32141) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1645807173133,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807173133}
    2022-02-25 17:39:33.141 - debug: tuya.0 (32141) connected set to false
    2022-02-25 17:39:33.143 - debug: tuya.0 (32141) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1645807173134,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807173134}
    2022-02-25 17:39:33.147 - debug: tuya.0 (32141) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1645807173144,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807173144}
    2022-02-25 17:39:33.148 - debug: tuya.0 (32141) connected set to false
    2022-02-25 17:39:33.150 - debug: tuya.0 (32141) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1645807173145,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807173145}
    2022-02-25 17:39:42.963 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi: Error from device (1): App still open on your mobile phone? Error: connection timed out
    2022-02-25 17:39:42.964 - warn: tuya.0 (32141) bf69b3293c1edff39ffjsi: Error on Reconnectconnection timed out
    2022-02-25 17:40:03.236 - debug: tuya.0 (32141) 08200118e868e759568a: Connected to device
    2022-02-25 17:40:03.243 - debug: tuya.0 (32141) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1645807203242,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807203242}
    2022-02-25 17:40:03.245 - debug: tuya.0 (32141) 08200118e868e759568a: Error from device (2): App still open on your mobile phone? Error: Error from socket: read ECONNRESET
    2022-02-25 17:40:03.247 - debug: tuya.0 (32141) connected set to true
    2022-02-25 17:40:03.248 - debug: tuya.0 (32141) 08200118e868e759568a: Disconnected from device
    2022-02-25 17:40:03.250 - debug: tuya.0 (32141) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1645807203242,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807203242}
    2022-02-25 17:40:03.256 - debug: tuya.0 (32141) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1645807203253,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807203253}
    2022-02-25 17:40:03.257 - debug: tuya.0 (32141) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1645807203254,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807203254}
    2022-02-25 17:40:03.258 - debug: tuya.0 (32141) connected set to false
    2022-02-25 17:40:17.965 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi: Error from device (2): App still open on your mobile phone? Error: connection timed out
    2022-02-25 17:40:17.966 - warn: tuya.0 (32141) bf69b3293c1edff39ffjsi: Error on Reconnectconnection timed out
    2022-02-25 17:40:33.342 - debug: tuya.0 (32141) 08200118e868e759568a: Connected to device
    2022-02-25 17:40:33.353 - debug: tuya.0 (32141) 08200118e868e759568a: Error from device (3): App still open on your mobile phone? Error: Error from socket: read ECONNRESET
    2022-02-25 17:40:33.354 - debug: tuya.0 (32141) 08200118e868e759568a: Disconnected from device
    2022-02-25 17:40:33.360 - debug: tuya.0 (32141) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1645807233348,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807233348}
    2022-02-25 17:40:33.361 - debug: tuya.0 (32141) connected set to false
    2022-02-25 17:40:33.367 - debug: tuya.0 (32141) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1645807233349,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807233349}
    2022-02-25 17:40:33.370 - debug: tuya.0 (32141) connected set to false
    2022-02-25 17:40:33.372 - debug: tuya.0 (32141) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1645807233363,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807233363}
    2022-02-25 17:40:33.373 - debug: tuya.0 (32141) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1645807233363,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807233363}
    2022-02-25 17:40:37.305 - info: tuya.0 (32141) Got terminate signal TERMINATE_YOURSELF
    2022-02-25 17:40:40.307 - info: tuya.0 (32141) terminating
    2022-02-25 17:40:40.308 - debug: tuya.0 (32141) Plugin sentry destroyed
    2022-02-25 17:40:40.309 - info: tuya.0 (32141) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-02-25 17:40:46.217 - debug: tuya.0 (32245) Redis Objects: Use Redis connection: iobroker-master:9001
    2022-02-25 17:40:46.290 - debug: tuya.0 (32245) Objects client ready ... initialize now
    2022-02-25 17:40:46.292 - debug: tuya.0 (32245) Objects create System PubSub Client
    2022-02-25 17:40:46.294 - debug: tuya.0 (32245) Objects create User PubSub Client
    2022-02-25 17:40:46.295 - debug: tuya.0 (32245) Objects client initialize lua scripts
    2022-02-25 17:40:46.308 - debug: tuya.0 (32245) Objects connected to redis: iobroker-master:9001
    2022-02-25 17:40:46.327 - debug: tuya.0 (32245) objectDB connected
    2022-02-25 17:40:46.330 - debug: tuya.0 (32245) Redis States: Use Redis connection: redis:6379
    2022-02-25 17:40:46.340 - debug: tuya.0 (32245) States create System PubSub Client
    2022-02-25 17:40:46.342 - debug: tuya.0 (32245) States create User PubSub Client
    2022-02-25 17:40:46.353 - debug: tuya.0 (32245) States connected to redis: redis:6379
    2022-02-25 17:40:46.354 - debug: tuya.0 (32245) statesDB connected
    2022-02-25 17:40:46.577 - debug: tuya.0 (32245) Plugin sentry Initialize Plugin (enabled=true)
    2022-02-25 17:40:46.582 - info: tuya.0 (32245) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-02-25 17:40:46.594 - info: tuya.0 (32245) starting. Version 3.6.15 in /opt/iobroker/node_modules/iobroker.tuya, node: v14.18.2, js-controller: 3.3.22
    2022-02-25 17:40:46.658 - debug: tuya.0 (32245) init 2 known devices
    2022-02-25 17:40:46.662 - debug: tuya.0 (32245) 08200118e868e759568a: Create device objects if not exist
    2022-02-25 17:40:46.665 - debug: tuya.0 (32245) 08200118e868e759568a: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music","4":"smooth","5":"flash"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"number","min":10,"max":1000,"read":true,"write":true,"name":"bright_value","id":22,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"mic_sense","id":101,"role":"level"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"change_speed","id":102,"role":"level"},{"type":"number","states":{"0":"soft","1":"classic","2":"rock"},"read":true,"write":true,"name":"music_type","id":106,"role":"level"}]
    2022-02-25 17:40:46.667 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 20
    2022-02-25 17:40:46.668 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 21
    2022-02-25 17:40:46.668 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 22
    2022-02-25 17:40:46.669 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 24
    2022-02-25 17:40:46.670 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 25
    2022-02-25 17:40:46.670 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 26
    2022-02-25 17:40:46.671 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 27
    2022-02-25 17:40:46.671 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 28
    2022-02-25 17:40:46.672 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 101
    2022-02-25 17:40:46.672 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 102
    2022-02-25 17:40:46.673 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 106
    2022-02-25 17:40:46.675 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi: Create device objects if not exist
    2022-02-25 17:40:46.676 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"mic_music_data","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"dreamlightmic_music_data","id":52,"role":"text"}]
    2022-02-25 17:40:46.677 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi Register onChange for 20
    2022-02-25 17:40:46.678 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi Register onChange for 21
    2022-02-25 17:40:46.678 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi Register onChange for 24
    2022-02-25 17:40:46.679 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi Register onChange for 25
    2022-02-25 17:40:46.679 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi Register onChange for 26
    2022-02-25 17:40:46.680 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi Register onChange for 27
    2022-02-25 17:40:46.680 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi Register onChange for 42
    2022-02-25 17:40:46.680 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi Register onChange for 52
    2022-02-25 17:40:46.689 - debug: tuya.0 (32245) connected set to false
    2022-02-25 17:40:46.819 - info: tuya.0 (32245) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
    2022-02-25 17:40:46.867 - info: tuya.0 (32245) 08200118e868e759568a Init with IP=192.168.179.28, Key=f9e4d104d04a30ec, Version=3.3
    2022-02-25 17:40:46.868 - info: tuya.0 (32245) Existing devices initialized
    2022-02-25 17:40:46.874 - info: tuya.0 (32245) Listen for local Tuya devices on port 6666
    2022-02-25 17:40:46.875 - info: tuya.0 (32245) Listen for encrypted local Tuya devices on port 6667
    2022-02-25 17:40:46.962 - debug: tuya.0 (32245) 08200118e868e759568a: Connected to device
    2022-02-25 17:40:46.980 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1645807246975,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807246975}
    2022-02-25 17:40:46.981 - debug: tuya.0 (32245) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1645807246975,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807246975}
    2022-02-25 17:40:46.982 - debug: tuya.0 (32245) connected set to true
    2022-02-25 17:40:47.007 - debug: tuya.0 (32245) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"00f003e803e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
    2022-02-25 17:40:47.036 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1645807247025,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709492529}
    2022-02-25 17:40:47.037 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1645807247025,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
    2022-02-25 17:40:47.038 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1645807247026,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
    2022-02-25 17:40:47.038 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.24 {"val":"00f003e803e8","ack":true,"ts":1645807247026,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709486787}
    2022-02-25 17:40:47.039 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1645807247026,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
    2022-02-25 17:40:47.043 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1645807247028,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
    2022-02-25 17:40:47.071 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1645807247067,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
    2022-02-25 17:40:47.072 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1645807247068,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
    2022-02-25 17:40:47.073 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1645807247068,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
    2022-02-25 17:40:51.602 - debug: tuya.0 (32245) Discovered encrypted device and store for later usage: 192.168.179.53:53813 - 000055aa00000000000000130000009c00000000d09766676f3369eb10b5e9f132fd802a58ef5662b8d5ed0ce59c56875111dfd0db47deeb95d128ee5671c7659fb0f99062752cccf8912dc171de390d8bc81f4159bd59981c26d5958da187e096d937c840b1058c6d8cd9456f3f7e28eed4932bd684776d4d3bbbcc727ed5338dc70040ebe90a09c0e74796dc81a6517ad39c8f8494c932e298de410f638ed8bf10587ab027a3c60000aa55
    2022-02-25 17:40:51.827 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi: Error from device (0): App still open on your mobile phone? Error: connection timed out
    2022-02-25 17:40:51.828 - error: tuya.0 (32245) bf69b3293c1edff39ffjsi: connection timed out
    2022-02-25 17:41:26.829 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi: Error from device (1): App still open on your mobile phone? Error: connection timed out
    2022-02-25 17:41:26.831 - warn: tuya.0 (32245) bf69b3293c1edff39ffjsi: Error on Reconnectconnection timed out
    2022-02-25 17:41:47.009 - debug: tuya.0 (32245) 08200118e868e759568a request data via get ...
    2022-02-25 17:41:47.137 - debug: tuya.0 (32245) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"00f003e803e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
    2022-02-25 17:41:47.151 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1645807307142,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709492529}
    2022-02-25 17:41:47.152 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1645807307142,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
    2022-02-25 17:41:47.153 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1645807307143,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
    2022-02-25 17:41:47.157 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.24 {"val":"00f003e803e8","ack":true,"ts":1645807307144,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709486787}
    2022-02-25 17:41:47.158 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1645807307145,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
    2022-02-25 17:41:47.159 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1645807307145,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
    2022-02-25 17:41:47.162 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1645807307147,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
    2022-02-25 17:41:47.165 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1645807307149,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
    2022-02-25 17:41:47.166 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1645807307150,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
    O 1 Antwort Letzte Antwort
    • K kla960
      @ofbeqnpolkkl6mby5e13
      Sorry wenn ich Nerve. Aber einer will nicht online gehen. Liegt es ggf. daran, dass der Adapter das Schema nicht kennt?
      2022-02-25 17:38:21.303 - debug: tuya.0 (30968) Found 2 device schema information
      2022-02-25 17:38:21.303 - info: tuya.0 (30968) new Schema added for product type 5tnccdqna35enim9. Please send next line from logfile on disk to developer!
      2022-02-25 17:38:21.304 - info: tuya.0 (30968) {"schemaExt":"[{\"complexType\":\"\",\"id\":22,\"inputStyle\":\"\",\"inputType\":\"percent1\"},{\"complexType\":\"\",\"id\":23,\"inputStyle\":\"\",\"inputType\":\"percent\"},{\"complexType\":\"\",\"id\":26,\"inputStyle\":\"\",\"inputType\":\"countdown1\"}]","schema":"[{\"mode\":\"rw\",\"code\":\"switch_led\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power\",\"id\":20,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"work_mode\",\"name\":\"模式\",\"property\":{\"range\":[\"white\",\"colour\",\"scene\",\"music\"],\"type\":\"enum\"},\"iconname\":\"icon-dp_mode\",\"id\":21,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"colour_data\",\"name\":\"彩光\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-yanse\",\"id\":24,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"scene_data\",\"name\":\"场景\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-shoucang\",\"id\":25,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-a_nav_timer\",\"id\":26,\"type\":\"obj\"},{\"mode\":\"wr\",\"code\":\"music_data\",\"name\":\"音乐律动\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-dp_mic\",\"id\":27,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"mic_music_data\",\"name\":\"麦克风音乐律动\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-dp_mode\",\"id\":42,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"dreamlightmic_music_data\",\"name\":\"炫彩本地音乐律动\",\"property\":{\"type\":\"raw\",\"maxlen\":\"255\"},\"iconname\":\"icon-dp_mode\",\"id\":52,\"type\":\"raw\"}]"}
      2022-02-25 17:38:21.305 - debug: tuya.0 (30968) Found 2 devices
      2022-02-25 17:38:21.305 - debug: tuya.0 (30968) 08200118e868e759568a: Schema found for lwnbiytsfgk6slyr: {"schema":[{"mode":"rw","code":"switch_led","name":"开关","property":{"type":"bool"},"id":20,"type":"obj"},{"mode":"rw","code":"work_mode","name":"模式","property":{"range":["white","colour","scene","music","smooth","flash"],"type":"enum"},"id":21,"type":"obj"},{"mode":"rw","code":"bright_value","name":"亮度值","property":{"unit":"","min":10,"max":1000,"scale":0,"step":1,"type":"value"},"id":22,"type":"obj"},{"mode":"rw","code":"colour_data","name":"彩光","property":{"type":"string","maxlen":255},"id":24,"type":"obj"},{"mode":"rw","code":"scene_data","name":"场景","property":{"type":"string","maxlen":255},"id":25,"type":"obj"},{"mode":"rw","code":"countdown","name":"倒计时","property":{"unit":"","min":0,"max":86400,"scale":0,"step":1,"type":"value"},"id":26,"type":"obj"},{"mode":"wr","code":"music_data","name":"音乐灯","property":{"type":"string","maxlen":255},"id":27,"type":"obj"},{"mode":"wr","code":"control_data","name":"调节","property":{"type":"string","maxlen":255},"id":28,"type":"obj"},{"mode":"rw","code":"mic_sense","name":"麦克风灵敏度","property":{"unit":"","min":1,"max":100,"scale":0,"step":1,"type":"value"},"id":101,"type":"obj"},{"mode":"rw","code":"change_speed","name":"变化速度","property":{"unit":"","min":1,"max":100,"scale":0,"step":1,"type":"value"},"id":102,"type":"obj"},{"mode":"rw","code":"music_type","name":"音乐风格","property":{"range":["soft","classic","rock"],"type":"enum"},"id":106,"type":"obj"}],"schemaExt":[]}
      2022-02-25 17:38:21.308 - debug: tuya.0 (30968) 08200118e868e759568a: Disconnected from device
      2022-02-25 17:38:21.308 - debug: tuya.0 (30968) 08200118e868e759568a: Create device objects if not exist
      2022-02-25 17:38:21.310 - debug: tuya.0 (30968) 08200118e868e759568a: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music","4":"smooth","5":"flash"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"number","min":10,"max":1000,"read":true,"write":true,"name":"bright_value","id":22,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"mic_sense","id":101,"role":"level"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"change_speed","id":102,"role":"level"},{"type":"number","states":{"0":"soft","1":"classic","2":"rock"},"read":true,"write":true,"name":"music_type","id":106,"role":"level"}]
      2022-02-25 17:38:21.310 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 20
      2022-02-25 17:38:21.311 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 21
      2022-02-25 17:38:21.311 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 22
      2022-02-25 17:38:21.312 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 24
      2022-02-25 17:38:21.312 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 25
      2022-02-25 17:38:21.312 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 26
      2022-02-25 17:38:21.313 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 27
      2022-02-25 17:38:21.313 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 28
      2022-02-25 17:38:21.314 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 101
      2022-02-25 17:38:21.314 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 102
      2022-02-25 17:38:21.314 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 106
      2022-02-25 17:38:21.315 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Schema found for 5tnccdqna35enim9: {"schema":[{"mode":"rw","code":"switch_led","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power","id":20,"type":"obj"},{"mode":"rw","code":"work_mode","name":"模式","property":{"range":["white","colour","scene","music"],"type":"enum"},"iconname":"icon-dp_mode","id":21,"type":"obj"},{"mode":"rw","code":"colour_data","name":"彩光","property":{"type":"string","maxlen":255},"iconname":"icon-yanse","id":24,"type":"obj"},{"mode":"rw","code":"scene_data","name":"场景","property":{"type":"string","maxlen":255},"iconname":"icon-shoucang","id":25,"type":"obj"},{"mode":"rw","code":"countdown","name":"倒计时","property":{"min":0,"max":86400,"scale":0,"step":1,"type":"value"},"iconname":"icon-a_nav_timer","id":26,"type":"obj"},{"mode":"wr","code":"music_data","name":"音乐律动","property":{"type":"string","maxlen":255},"iconname":"icon-dp_mic","id":27,"type":"obj"},{"mode":"rw","code":"mic_music_data","name":"麦克风音乐律动","property":{"type":"string","maxlen":255},"iconname":"icon-dp_mode","id":42,"type":"obj"},{"mode":"rw","code":"dreamlightmic_music_data","name":"炫彩本地音乐律动","property":{"type":"raw","maxlen":"255"},"iconname":"icon-dp_mode","id":52,"type":"raw"}],"schemaExt":[{"complexType":"","id":22,"inputStyle":"","inputType":"percent1"},{"complexType":"","id":23,"inputStyle":"","inputType":"percent"},{"complexType":"","id":26,"inputStyle":"","inputType":"countdown1"}]}
      2022-02-25 17:38:21.317 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Create device objects if not exist
      2022-02-25 17:38:21.318 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"mic_music_data","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"dreamlightmic_music_data","id":52,"role":"text"}]
      2022-02-25 17:38:21.318 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 20
      2022-02-25 17:38:21.319 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 21
      2022-02-25 17:38:21.319 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 24
      2022-02-25 17:38:21.319 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 25
      2022-02-25 17:38:21.320 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 26
      2022-02-25 17:38:21.320 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 27
      2022-02-25 17:38:21.323 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 42
      2022-02-25 17:38:21.323 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 52
      2022-02-25 17:38:21.325 - debug: tuya.0 (30968) sendTo "getProxyResult" to system.adapter.admin.0 from system.adapter.tuya.0
      2022-02-25 17:38:21.337 - warn: tuya.0 (30968) State "tuya.0.bf69b3293c1edff39ffjsi.online" has no existing object, this might lead to an error in future versions
      2022-02-25 17:38:21.342 - debug: tuya.0 (30968) connected set to false
      2022-02-25 17:38:21.345 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1645807101339,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101339}
      2022-02-25 17:38:21.346 - debug: tuya.0 (30968) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1645807101339,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101339}
      2022-02-25 17:38:21.346 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1645807101339,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101339}
      2022-02-25 17:38:21.347 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.online {"val":false,"ack":true,"ts":1645807101339,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807097739}
      2022-02-25 17:38:21.359 - debug: tuya.0 (30968) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":620,"ack":false,"time":1645807101356},"_id":65753901}
      2022-02-25 17:38:21.360 - debug: tuya.0 (30968) sendTo "getDeviceInfo" to system.adapter.admin.0 from system.adapter.tuya.0
      2022-02-25 17:38:21.368 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1645807101365,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709492529}
      2022-02-25 17:38:21.391 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1645807101386,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
      2022-02-25 17:38:21.397 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1645807101395,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
      2022-02-25 17:38:21.409 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.24 {"val":"00f003e803e8","ack":true,"ts":1645807101407,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709486787}
      2022-02-25 17:38:21.416 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1645807101414,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
      2022-02-25 17:38:21.429 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1645807101427,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
      2022-02-25 17:38:21.435 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.27 {"val":"","ack":true,"ts":1645807101433,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113069}
      2022-02-25 17:38:21.445 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.28 {"val":"","ack":true,"ts":1645807101443,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703822315}
      2022-02-25 17:38:21.450 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1645807101448,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
      2022-02-25 17:38:21.460 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1645807101458,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
      2022-02-25 17:38:21.464 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1645807101462,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
      2022-02-25 17:38:21.482 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.20 {"val":false,"ack":true,"ts":1645807101477,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101477}
      2022-02-25 17:38:21.494 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.21 {"val":1,"ack":true,"ts":1645807101491,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101491}
      2022-02-25 17:38:21.514 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.24 {"val":"007803e800b4","ack":true,"ts":1645807101511,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101511}
      2022-02-25 17:38:21.524 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.25 {"val":"04464602007803e803e800000000464602007803e8000a00000000","ack":true,"ts":1645807101522,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101522}
      2022-02-25 17:38:21.528 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.26 {"val":0,"ack":true,"ts":1645807101526,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101526}
      2022-02-25 17:38:21.538 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.27 {"val":"","ack":true,"ts":1645807101535,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101535}
      2022-02-25 17:38:21.542 - info: tuya.0 (30968) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
      2022-02-25 17:38:21.545 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.42 {"val":"0001c9026432007203e800900344005a03e800470289","ack":true,"ts":1645807101541,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101541}
      2022-02-25 17:38:21.589 - info: tuya.0 (30968) 08200118e868e759568a Init with IP=192.168.179.28, Key=f9e4d104d04a30ec, Version=3.3
      2022-02-25 17:38:21.591 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.52 {"val":"","ack":true,"ts":1645807101587,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101587}
      2022-02-25 17:38:21.655 - debug: tuya.0 (30968) 08200118e868e759568a: Connected to device
      2022-02-25 17:38:21.660 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1645807101659,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101659}
      2022-02-25 17:38:21.661 - debug: tuya.0 (30968) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1645807101659,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101659}
      2022-02-25 17:38:21.661 - debug: tuya.0 (30968) connected set to true
      2022-02-25 17:38:21.693 - debug: tuya.0 (30968) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"00f003e803e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
      2022-02-25 17:38:21.708 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1645807101697,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709492529}
      2022-02-25 17:38:21.719 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1645807101705,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
      2022-02-25 17:38:21.719 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1645807101705,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
      2022-02-25 17:38:21.720 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.24 {"val":"00f003e803e8","ack":true,"ts":1645807101706,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709486787}
      2022-02-25 17:38:21.720 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1645807101706,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
      2022-02-25 17:38:21.721 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1645807101706,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
      2022-02-25 17:38:21.721 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1645807101707,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
      2022-02-25 17:38:21.722 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1645807101707,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
      2022-02-25 17:38:21.722 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1645807101707,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
      2022-02-25 17:38:21.775 - debug: tuya.0 (30968) Found 2 device schema information
      2022-02-25 17:38:21.775 - debug: tuya.0 (30968) Found 2 devices
      2022-02-25 17:38:21.776 - debug: tuya.0 (30968) 08200118e868e759568a: Schema found for lwnbiytsfgk6slyr: {"schema":[{"mode":"rw","code":"switch_led","name":"开关","property":{"type":"bool"},"id":20,"type":"obj"},{"mode":"rw","code":"work_mode","name":"模式","property":{"range":["white","colour","scene","music","smooth","flash"],"type":"enum"},"id":21,"type":"obj"},{"mode":"rw","code":"bright_value","name":"亮度值","property":{"unit":"","min":10,"max":1000,"scale":0,"step":1,"type":"value"},"id":22,"type":"obj"},{"mode":"rw","code":"colour_data","name":"彩光","property":{"type":"string","maxlen":255},"id":24,"type":"obj"},{"mode":"rw","code":"scene_data","name":"场景","property":{"type":"string","maxlen":255},"id":25,"type":"obj"},{"mode":"rw","code":"countdown","name":"倒计时","property":{"unit":"","min":0,"max":86400,"scale":0,"step":1,"type":"value"},"id":26,"type":"obj"},{"mode":"wr","code":"music_data","name":"音乐灯","property":{"type":"string","maxlen":255},"id":27,"type":"obj"},{"mode":"wr","code":"control_data","name":"调节","property":{"type":"string","maxlen":255},"id":28,"type":"obj"},{"mode":"rw","code":"mic_sense","name":"麦克风灵敏度","property":{"unit":"","min":1,"max":100,"scale":0,"step":1,"type":"value"},"id":101,"type":"obj"},{"mode":"rw","code":"change_speed","name":"变化速度","property":{"unit":"","min":1,"max":100,"scale":0,"step":1,"type":"value"},"id":102,"type":"obj"},{"mode":"rw","code":"music_type","name":"音乐风格","property":{"range":["soft","classic","rock"],"type":"enum"},"id":106,"type":"obj"}],"schemaExt":[]}
      2022-02-25 17:38:21.778 - debug: tuya.0 (30968) 08200118e868e759568a: Disconnected from device
      2022-02-25 17:38:21.778 - debug: tuya.0 (30968) 08200118e868e759568a: Create device objects if not exist
      2022-02-25 17:38:21.779 - debug: tuya.0 (30968) 08200118e868e759568a: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music","4":"smooth","5":"flash"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"number","min":10,"max":1000,"read":true,"write":true,"name":"bright_value","id":22,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"mic_sense","id":101,"role":"level"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"change_speed","id":102,"role":"level"},{"type":"number","states":{"0":"soft","1":"classic","2":"rock"},"read":true,"write":true,"name":"music_type","id":106,"role":"level"}]
      2022-02-25 17:38:21.780 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 20
      2022-02-25 17:38:21.780 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 21
      2022-02-25 17:38:21.780 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 22
      2022-02-25 17:38:21.781 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 24
      2022-02-25 17:38:21.781 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 25
      2022-02-25 17:38:21.781 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 26
      2022-02-25 17:38:21.782 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 27
      2022-02-25 17:38:21.782 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 28
      2022-02-25 17:38:21.782 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 101
      2022-02-25 17:38:21.783 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 102
      2022-02-25 17:38:21.783 - debug: tuya.0 (30968) 08200118e868e759568a Register onChange for 106
      2022-02-25 17:38:21.784 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Schema found for 5tnccdqna35enim9: {"schema":[{"mode":"rw","code":"switch_led","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power","id":20,"type":"obj"},{"mode":"rw","code":"work_mode","name":"模式","property":{"range":["white","colour","scene","music"],"type":"enum"},"iconname":"icon-dp_mode","id":21,"type":"obj"},{"mode":"rw","code":"colour_data","name":"彩光","property":{"type":"string","maxlen":255},"iconname":"icon-yanse","id":24,"type":"obj"},{"mode":"rw","code":"scene_data","name":"场景","property":{"type":"string","maxlen":255},"iconname":"icon-shoucang","id":25,"type":"obj"},{"mode":"rw","code":"countdown","name":"倒计时","property":{"min":0,"max":86400,"scale":0,"step":1,"type":"value"},"iconname":"icon-a_nav_timer","id":26,"type":"obj"},{"mode":"wr","code":"music_data","name":"音乐律动","property":{"type":"string","maxlen":255},"iconname":"icon-dp_mic","id":27,"type":"obj"},{"mode":"rw","code":"mic_music_data","name":"麦克风音乐律动","property":{"type":"string","maxlen":255},"iconname":"icon-dp_mode","id":42,"type":"obj"},{"mode":"rw","code":"dreamlightmic_music_data","name":"炫彩本地音乐律动","property":{"type":"raw","maxlen":"255"},"iconname":"icon-dp_mode","id":52,"type":"raw"}],"schemaExt":[{"complexType":"","id":22,"inputStyle":"","inputType":"percent1"},{"complexType":"","id":23,"inputStyle":"","inputType":"percent"},{"complexType":"","id":26,"inputStyle":"","inputType":"countdown1"}]}
      2022-02-25 17:38:21.785 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Create device objects if not exist
      2022-02-25 17:38:21.786 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"mic_music_data","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"dreamlightmic_music_data","id":52,"role":"text"}]
      2022-02-25 17:38:21.787 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 20
      2022-02-25 17:38:21.787 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 21
      2022-02-25 17:38:21.788 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 24
      2022-02-25 17:38:21.788 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 25
      2022-02-25 17:38:21.788 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 26
      2022-02-25 17:38:21.789 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 27
      2022-02-25 17:38:21.789 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 42
      2022-02-25 17:38:21.789 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi Register onChange for 52
      2022-02-25 17:38:21.800 - warn: tuya.0 (30968) State "tuya.0.bf69b3293c1edff39ffjsi.online" has no existing object, this might lead to an error in future versions
      2022-02-25 17:38:21.810 - debug: tuya.0 (30968) connected set to false
      2022-02-25 17:38:21.815 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1645807101801,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101801}
      2022-02-25 17:38:21.815 - debug: tuya.0 (30968) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1645807101801,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101801}
      2022-02-25 17:38:21.816 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1645807101802,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101802}
      2022-02-25 17:38:21.817 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.online {"val":false,"ack":true,"ts":1645807101802,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807097739}
      2022-02-25 17:38:21.835 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1645807101828,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709492529}
      2022-02-25 17:38:21.854 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1645807101852,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
      2022-02-25 17:38:21.863 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1645807101861,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
      2022-02-25 17:38:21.878 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.24 {"val":"00f003e803e8","ack":true,"ts":1645807101873,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709486787}
      2022-02-25 17:38:21.884 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1645807101882,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
      2022-02-25 17:38:21.897 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1645807101894,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
      2022-02-25 17:38:21.902 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.27 {"val":"","ack":true,"ts":1645807101900,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113069}
      2022-02-25 17:38:21.917 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.28 {"val":"","ack":true,"ts":1645807101912,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703822315}
      2022-02-25 17:38:21.923 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1645807101921,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
      2022-02-25 17:38:21.935 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1645807101932,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
      2022-02-25 17:38:21.943 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1645807101939,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
      2022-02-25 17:38:21.958 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.20 {"val":false,"ack":true,"ts":1645807101956,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101477}
      2022-02-25 17:38:21.966 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.21 {"val":1,"ack":true,"ts":1645807101964,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101491}
      2022-02-25 17:38:21.988 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.24 {"val":"007803e800b4","ack":true,"ts":1645807101985,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101511}
      2022-02-25 17:38:21.993 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.25 {"val":"04464602007803e803e800000000464602007803e8000a00000000","ack":true,"ts":1645807101991,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101522}
      2022-02-25 17:38:22.014 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.26 {"val":0,"ack":true,"ts":1645807102012,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101526}
      2022-02-25 17:38:22.022 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.27 {"val":"","ack":true,"ts":1645807102019,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101535}
      2022-02-25 17:38:22.037 - info: tuya.0 (30968) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
      2022-02-25 17:38:22.042 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.42 {"val":"0001c9026432007203e800900344005a03e800470289","ack":true,"ts":1645807102036,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101541}
      2022-02-25 17:38:22.077 - info: tuya.0 (30968) 08200118e868e759568a Init with IP=192.168.179.28, Key=f9e4d104d04a30ec, Version=3.3
      2022-02-25 17:38:22.080 - debug: tuya.0 (30968) stateChange tuya.0.bf69b3293c1edff39ffjsi.52 {"val":"","ack":true,"ts":1645807102077,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807101587}
      2022-02-25 17:38:22.081 - debug: tuya.0 (30968) 08200118e868e759568a: Connected to device
      2022-02-25 17:38:22.088 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1645807102086,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807102086}
      2022-02-25 17:38:22.089 - debug: tuya.0 (30968) connected set to true
      2022-02-25 17:38:22.090 - debug: tuya.0 (30968) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1645807102086,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807102086}
      2022-02-25 17:38:22.116 - debug: tuya.0 (30968) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"00f003e803e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
      2022-02-25 17:38:22.125 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1645807102119,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709492529}
      2022-02-25 17:38:22.135 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1645807102123,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
      2022-02-25 17:38:22.136 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1645807102124,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
      2022-02-25 17:38:22.136 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.24 {"val":"00f003e803e8","ack":true,"ts":1645807102124,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709486787}
      2022-02-25 17:38:22.136 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1645807102124,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
      2022-02-25 17:38:22.137 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1645807102124,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
      2022-02-25 17:38:22.137 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1645807102124,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
      2022-02-25 17:38:22.138 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1645807102125,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
      2022-02-25 17:38:22.138 - debug: tuya.0 (30968) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1645807102125,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
      2022-02-25 17:38:22.769 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Error from device (0): App still open on your mobile phone? Error: connection timed out
      2022-02-25 17:38:22.769 - error: tuya.0 (30968) bf69b3293c1edff39ffjsi: connection timed out
      2022-02-25 17:38:26.544 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Error from device (1): App still open on your mobile phone? Error: connection timed out
      2022-02-25 17:38:26.544 - error: tuya.0 (30968) bf69b3293c1edff39ffjsi: connection timed out
      2022-02-25 17:38:27.039 - debug: tuya.0 (30968) bf69b3293c1edff39ffjsi: Error from device (2): App still open on your mobile phone? Error: connection timed out
      2022-02-25 17:38:27.039 - error: tuya.0 (30968) bf69b3293c1edff39ffjsi: connection timed out
      2022-02-25 17:38:30.438 - warn: tuya.0 (30968) Exception: Error: first argument must be a valid error code number
      2022-02-25 17:38:30.439 - debug: tuya.0 (30968) 08200118e868e759568a: Disconnected from device
      2022-02-25 17:38:30.441 - error: tuya.0 (30968) uncaught exception: first argument must be a valid error code number
      2022-02-25 17:38:30.443 - error: tuya.0 (30968) Error: first argument must be a valid error code number
      at Sender.close (/opt/iobroker/node_modules/http-mitm-proxy/node_modules/ws/lib/Sender.js:121:13)
      at WebSocket.close (/opt/iobroker/node_modules/http-mitm-proxy/node_modules/ws/lib/WebSocket.js:281:18)
      at /opt/iobroker/node_modules/http-mitm-proxy/lib/proxy.js:983:38
      at wrapper (/opt/iobroker/node_modules/http-mitm-proxy/node_modules/async/dist/async.js:271:20)
      at eachOfArrayLike (/opt/iobroker/node_modules/http-mitm-proxy/node_modules/async/dist/async.js:490:13)
      at eachOf (/opt/iobroker/node_modules/http-mitm-proxy/node_modules/async/dist/async.js:626:16)
      at awaitable (/opt/iobroker/node_modules/http-mitm-proxy/node_modules/async/dist/async.js:211:32)
      at Object.eachLimit (/opt/iobroker/node_modules/http-mitm-proxy/node_modules/async/dist/async.js:2686:16)
      at Object.awaitable (/opt/iobroker/node_modules/http-mitm-proxy/node_modules/async/dist/async.js:211:32)
      at Proxy._onWebSocketClose (/opt/iobroker/node_modules/http-mitm-proxy/lib/proxy.js:975:11)
      2022-02-25 17:38:30.444 - error: tuya.0 (30968) first argument must be a valid error code number
      2022-02-25 17:38:30.452 - info: tuya.0 (30968) terminating
      2022-02-25 17:38:30.454 - debug: tuya.0 (30968) Plugin sentry destroyed
      2022-02-25 17:38:30.454 - warn: tuya.0 (30968) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-02-25 17:38:30.458 - debug: tuya.0 (30968) connected set to false
      2022-02-25 17:38:31.052 - error: host.iobroker-slave instance system.adapter.tuya.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2022-02-25 17:39:02.361 - debug: tuya.0 (32141) Redis Objects: Use Redis connection: iobroker-master:9001
      2022-02-25 17:39:02.414 - debug: tuya.0 (32141) Objects client ready ... initialize now
      2022-02-25 17:39:02.417 - debug: tuya.0 (32141) Objects create System PubSub Client
      2022-02-25 17:39:02.418 - debug: tuya.0 (32141) Objects create User PubSub Client
      2022-02-25 17:39:02.419 - debug: tuya.0 (32141) Objects client initialize lua scripts
      2022-02-25 17:39:02.433 - debug: tuya.0 (32141) Objects connected to redis: iobroker-master:9001
      2022-02-25 17:39:02.442 - debug: tuya.0 (32141) objectDB connected
      2022-02-25 17:39:02.445 - debug: tuya.0 (32141) Redis States: Use Redis connection: redis:6379
      2022-02-25 17:39:02.455 - debug: tuya.0 (32141) States create System PubSub Client
      2022-02-25 17:39:02.457 - debug: tuya.0 (32141) States create User PubSub Client
      2022-02-25 17:39:02.467 - debug: tuya.0 (32141) States connected to redis: redis:6379
      2022-02-25 17:39:02.468 - debug: tuya.0 (32141) statesDB connected
      2022-02-25 17:39:02.698 - debug: tuya.0 (32141) Plugin sentry Initialize Plugin (enabled=true)
      2022-02-25 17:39:02.703 - info: tuya.0 (32141) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-02-25 17:39:02.714 - info: tuya.0 (32141) starting. Version 3.6.15 in /opt/iobroker/node_modules/iobroker.tuya, node: v14.18.2, js-controller: 3.3.22
      2022-02-25 17:39:02.777 - debug: tuya.0 (32141) init 2 known devices
      2022-02-25 17:39:02.780 - debug: tuya.0 (32141) 08200118e868e759568a: Create device objects if not exist
      2022-02-25 17:39:02.783 - debug: tuya.0 (32141) 08200118e868e759568a: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music","4":"smooth","5":"flash"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"number","min":10,"max":1000,"read":true,"write":true,"name":"bright_value","id":22,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"mic_sense","id":101,"role":"level"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"change_speed","id":102,"role":"level"},{"type":"number","states":{"0":"soft","1":"classic","2":"rock"},"read":true,"write":true,"name":"music_type","id":106,"role":"level"}]
      2022-02-25 17:39:02.785 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 20
      2022-02-25 17:39:02.786 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 21
      2022-02-25 17:39:02.788 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 22
      2022-02-25 17:39:02.788 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 24
      2022-02-25 17:39:02.789 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 25
      2022-02-25 17:39:02.790 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 26
      2022-02-25 17:39:02.790 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 27
      2022-02-25 17:39:02.791 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 28
      2022-02-25 17:39:02.791 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 101
      2022-02-25 17:39:02.792 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 102
      2022-02-25 17:39:02.792 - debug: tuya.0 (32141) 08200118e868e759568a Register onChange for 106
      2022-02-25 17:39:02.794 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi: Create device objects if not exist
      2022-02-25 17:39:02.796 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"mic_music_data","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"dreamlightmic_music_data","id":52,"role":"text"}]
      2022-02-25 17:39:02.796 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi Register onChange for 20
      2022-02-25 17:39:02.797 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi Register onChange for 21
      2022-02-25 17:39:02.797 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi Register onChange for 24
      2022-02-25 17:39:02.798 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi Register onChange for 25
      2022-02-25 17:39:02.798 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi Register onChange for 26
      2022-02-25 17:39:02.799 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi Register onChange for 27
      2022-02-25 17:39:02.799 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi Register onChange for 42
      2022-02-25 17:39:02.800 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi Register onChange for 52
      2022-02-25 17:39:02.807 - debug: tuya.0 (32141) connected set to false
      2022-02-25 17:39:02.952 - info: tuya.0 (32141) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
      2022-02-25 17:39:02.996 - info: tuya.0 (32141) 08200118e868e759568a Init with IP=192.168.179.28, Key=f9e4d104d04a30ec, Version=3.3
      2022-02-25 17:39:02.997 - info: tuya.0 (32141) Existing devices initialized
      2022-02-25 17:39:03.003 - info: tuya.0 (32141) Listen for local Tuya devices on port 6666
      2022-02-25 17:39:03.004 - info: tuya.0 (32141) Listen for encrypted local Tuya devices on port 6667
      2022-02-25 17:39:03.024 - debug: tuya.0 (32141) 08200118e868e759568a: Connected to device
      2022-02-25 17:39:03.036 - debug: tuya.0 (32141) 08200118e868e759568a: Error from device (0): App still open on your mobile phone? Error: Error from socket: write ECONNRESET
      2022-02-25 17:39:03.038 - debug: tuya.0 (32141) 08200118e868e759568a: Disconnected from device
      2022-02-25 17:39:03.047 - debug: tuya.0 (32141) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1645807143042,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807143042}
      2022-02-25 17:39:03.048 - debug: tuya.0 (32141) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1645807143043,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807143043}
      2022-02-25 17:39:03.049 - debug: tuya.0 (32141) connected set to false
      2022-02-25 17:39:03.051 - debug: tuya.0 (32141) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1645807143043,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807110457}
      2022-02-25 17:39:03.083 - debug: tuya.0 (32141) connected set to false
      2022-02-25 17:39:03.086 - debug: tuya.0 (32141) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1645807143082,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807143082}
      2022-02-25 17:39:06.466 - debug: tuya.0 (32141) Discovered encrypted device and store for later usage: 192.168.179.53:53813 - 000055aa00000000000000130000009c00000000d09766676f3369eb10b5e9f132fd802a58ef5662b8d5ed0ce59c56875111dfd0db47deeb95d128ee5671c7659fb0f99062752cccf8912dc171de390d8bc81f4159bd59981c26d5958da187e096d937c840b1058c6d8cd9456f3f7e28eed4932bd684776d4d3bbbcc727ed5338dc70040ebe90a09c0e74796dc81a6517ad39c8f8494c932e298de410f638ed8bf10587ab027a3c60000aa55
      2022-02-25 17:39:07.592 - debug: tuya.0 (32141) Discovered encrypted device and store for later usage: 192.168.179.28:49154 - 000055aa0000000000000013000000ac00000000d09766676f3369eb10b5e9f132fd802a0c92562f997bb947bcb6972c91d408d519c5020ec282229e73b2b864523d6a1f7f54fa4421812b6f2afc9adbe042a6295c907565b323a346d0de78c22f1fdaba1ae7c613c2cae004e54a474561367714379e7d68a02456269f4616388e2aa04eb49deffb70062d1a32380cd69ea07e8e77fba272ba2c7f0126b30472c4ce7d9d384363dcd0f0705ae4cac595bbf49625c46b79a30000aa55
      2022-02-25 17:39:07.959 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi: Error from device (0): App still open on your mobile phone? Error: connection timed out
      2022-02-25 17:39:07.960 - error: tuya.0 (32141) bf69b3293c1edff39ffjsi: connection timed out
      2022-02-25 17:39:33.128 - debug: tuya.0 (32141) 08200118e868e759568a: Connected to device
      2022-02-25 17:39:33.135 - debug: tuya.0 (32141) 08200118e868e759568a: Error from device (1): App still open on your mobile phone? Error: Error from socket: read ECONNRESET
      2022-02-25 17:39:33.137 - debug: tuya.0 (32141) 08200118e868e759568a: Disconnected from device
      2022-02-25 17:39:33.138 - debug: tuya.0 (32141) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1645807173133,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807173133}
      2022-02-25 17:39:33.141 - debug: tuya.0 (32141) connected set to false
      2022-02-25 17:39:33.143 - debug: tuya.0 (32141) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1645807173134,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807173134}
      2022-02-25 17:39:33.147 - debug: tuya.0 (32141) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1645807173144,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807173144}
      2022-02-25 17:39:33.148 - debug: tuya.0 (32141) connected set to false
      2022-02-25 17:39:33.150 - debug: tuya.0 (32141) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1645807173145,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807173145}
      2022-02-25 17:39:42.963 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi: Error from device (1): App still open on your mobile phone? Error: connection timed out
      2022-02-25 17:39:42.964 - warn: tuya.0 (32141) bf69b3293c1edff39ffjsi: Error on Reconnectconnection timed out
      2022-02-25 17:40:03.236 - debug: tuya.0 (32141) 08200118e868e759568a: Connected to device
      2022-02-25 17:40:03.243 - debug: tuya.0 (32141) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1645807203242,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807203242}
      2022-02-25 17:40:03.245 - debug: tuya.0 (32141) 08200118e868e759568a: Error from device (2): App still open on your mobile phone? Error: Error from socket: read ECONNRESET
      2022-02-25 17:40:03.247 - debug: tuya.0 (32141) connected set to true
      2022-02-25 17:40:03.248 - debug: tuya.0 (32141) 08200118e868e759568a: Disconnected from device
      2022-02-25 17:40:03.250 - debug: tuya.0 (32141) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1645807203242,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807203242}
      2022-02-25 17:40:03.256 - debug: tuya.0 (32141) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1645807203253,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807203253}
      2022-02-25 17:40:03.257 - debug: tuya.0 (32141) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1645807203254,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807203254}
      2022-02-25 17:40:03.258 - debug: tuya.0 (32141) connected set to false
      2022-02-25 17:40:17.965 - debug: tuya.0 (32141) bf69b3293c1edff39ffjsi: Error from device (2): App still open on your mobile phone? Error: connection timed out
      2022-02-25 17:40:17.966 - warn: tuya.0 (32141) bf69b3293c1edff39ffjsi: Error on Reconnectconnection timed out
      2022-02-25 17:40:33.342 - debug: tuya.0 (32141) 08200118e868e759568a: Connected to device
      2022-02-25 17:40:33.353 - debug: tuya.0 (32141) 08200118e868e759568a: Error from device (3): App still open on your mobile phone? Error: Error from socket: read ECONNRESET
      2022-02-25 17:40:33.354 - debug: tuya.0 (32141) 08200118e868e759568a: Disconnected from device
      2022-02-25 17:40:33.360 - debug: tuya.0 (32141) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1645807233348,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807233348}
      2022-02-25 17:40:33.361 - debug: tuya.0 (32141) connected set to false
      2022-02-25 17:40:33.367 - debug: tuya.0 (32141) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1645807233349,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807233349}
      2022-02-25 17:40:33.370 - debug: tuya.0 (32141) connected set to false
      2022-02-25 17:40:33.372 - debug: tuya.0 (32141) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1645807233363,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807233363}
      2022-02-25 17:40:33.373 - debug: tuya.0 (32141) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1645807233363,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807233363}
      2022-02-25 17:40:37.305 - info: tuya.0 (32141) Got terminate signal TERMINATE_YOURSELF
      2022-02-25 17:40:40.307 - info: tuya.0 (32141) terminating
      2022-02-25 17:40:40.308 - debug: tuya.0 (32141) Plugin sentry destroyed
      2022-02-25 17:40:40.309 - info: tuya.0 (32141) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-02-25 17:40:46.217 - debug: tuya.0 (32245) Redis Objects: Use Redis connection: iobroker-master:9001
      2022-02-25 17:40:46.290 - debug: tuya.0 (32245) Objects client ready ... initialize now
      2022-02-25 17:40:46.292 - debug: tuya.0 (32245) Objects create System PubSub Client
      2022-02-25 17:40:46.294 - debug: tuya.0 (32245) Objects create User PubSub Client
      2022-02-25 17:40:46.295 - debug: tuya.0 (32245) Objects client initialize lua scripts
      2022-02-25 17:40:46.308 - debug: tuya.0 (32245) Objects connected to redis: iobroker-master:9001
      2022-02-25 17:40:46.327 - debug: tuya.0 (32245) objectDB connected
      2022-02-25 17:40:46.330 - debug: tuya.0 (32245) Redis States: Use Redis connection: redis:6379
      2022-02-25 17:40:46.340 - debug: tuya.0 (32245) States create System PubSub Client
      2022-02-25 17:40:46.342 - debug: tuya.0 (32245) States create User PubSub Client
      2022-02-25 17:40:46.353 - debug: tuya.0 (32245) States connected to redis: redis:6379
      2022-02-25 17:40:46.354 - debug: tuya.0 (32245) statesDB connected
      2022-02-25 17:40:46.577 - debug: tuya.0 (32245) Plugin sentry Initialize Plugin (enabled=true)
      2022-02-25 17:40:46.582 - info: tuya.0 (32245) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-02-25 17:40:46.594 - info: tuya.0 (32245) starting. Version 3.6.15 in /opt/iobroker/node_modules/iobroker.tuya, node: v14.18.2, js-controller: 3.3.22
      2022-02-25 17:40:46.658 - debug: tuya.0 (32245) init 2 known devices
      2022-02-25 17:40:46.662 - debug: tuya.0 (32245) 08200118e868e759568a: Create device objects if not exist
      2022-02-25 17:40:46.665 - debug: tuya.0 (32245) 08200118e868e759568a: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music","4":"smooth","5":"flash"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"number","min":10,"max":1000,"read":true,"write":true,"name":"bright_value","id":22,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"mic_sense","id":101,"role":"level"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"change_speed","id":102,"role":"level"},{"type":"number","states":{"0":"soft","1":"classic","2":"rock"},"read":true,"write":true,"name":"music_type","id":106,"role":"level"}]
      2022-02-25 17:40:46.667 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 20
      2022-02-25 17:40:46.668 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 21
      2022-02-25 17:40:46.668 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 22
      2022-02-25 17:40:46.669 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 24
      2022-02-25 17:40:46.670 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 25
      2022-02-25 17:40:46.670 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 26
      2022-02-25 17:40:46.671 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 27
      2022-02-25 17:40:46.671 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 28
      2022-02-25 17:40:46.672 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 101
      2022-02-25 17:40:46.672 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 102
      2022-02-25 17:40:46.673 - debug: tuya.0 (32245) 08200118e868e759568a Register onChange for 106
      2022-02-25 17:40:46.675 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi: Create device objects if not exist
      2022-02-25 17:40:46.676 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"mic_music_data","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"dreamlightmic_music_data","id":52,"role":"text"}]
      2022-02-25 17:40:46.677 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi Register onChange for 20
      2022-02-25 17:40:46.678 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi Register onChange for 21
      2022-02-25 17:40:46.678 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi Register onChange for 24
      2022-02-25 17:40:46.679 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi Register onChange for 25
      2022-02-25 17:40:46.679 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi Register onChange for 26
      2022-02-25 17:40:46.680 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi Register onChange for 27
      2022-02-25 17:40:46.680 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi Register onChange for 42
      2022-02-25 17:40:46.680 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi Register onChange for 52
      2022-02-25 17:40:46.689 - debug: tuya.0 (32245) connected set to false
      2022-02-25 17:40:46.819 - info: tuya.0 (32245) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
      2022-02-25 17:40:46.867 - info: tuya.0 (32245) 08200118e868e759568a Init with IP=192.168.179.28, Key=f9e4d104d04a30ec, Version=3.3
      2022-02-25 17:40:46.868 - info: tuya.0 (32245) Existing devices initialized
      2022-02-25 17:40:46.874 - info: tuya.0 (32245) Listen for local Tuya devices on port 6666
      2022-02-25 17:40:46.875 - info: tuya.0 (32245) Listen for encrypted local Tuya devices on port 6667
      2022-02-25 17:40:46.962 - debug: tuya.0 (32245) 08200118e868e759568a: Connected to device
      2022-02-25 17:40:46.980 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1645807246975,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807246975}
      2022-02-25 17:40:46.981 - debug: tuya.0 (32245) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1645807246975,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645807246975}
      2022-02-25 17:40:46.982 - debug: tuya.0 (32245) connected set to true
      2022-02-25 17:40:47.007 - debug: tuya.0 (32245) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"00f003e803e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
      2022-02-25 17:40:47.036 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1645807247025,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709492529}
      2022-02-25 17:40:47.037 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1645807247025,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
      2022-02-25 17:40:47.038 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1645807247026,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
      2022-02-25 17:40:47.038 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.24 {"val":"00f003e803e8","ack":true,"ts":1645807247026,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709486787}
      2022-02-25 17:40:47.039 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1645807247026,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
      2022-02-25 17:40:47.043 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1645807247028,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
      2022-02-25 17:40:47.071 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1645807247067,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
      2022-02-25 17:40:47.072 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1645807247068,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
      2022-02-25 17:40:47.073 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1645807247068,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
      2022-02-25 17:40:51.602 - debug: tuya.0 (32245) Discovered encrypted device and store for later usage: 192.168.179.53:53813 - 000055aa00000000000000130000009c00000000d09766676f3369eb10b5e9f132fd802a58ef5662b8d5ed0ce59c56875111dfd0db47deeb95d128ee5671c7659fb0f99062752cccf8912dc171de390d8bc81f4159bd59981c26d5958da187e096d937c840b1058c6d8cd9456f3f7e28eed4932bd684776d4d3bbbcc727ed5338dc70040ebe90a09c0e74796dc81a6517ad39c8f8494c932e298de410f638ed8bf10587ab027a3c60000aa55
      2022-02-25 17:40:51.827 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi: Error from device (0): App still open on your mobile phone? Error: connection timed out
      2022-02-25 17:40:51.828 - error: tuya.0 (32245) bf69b3293c1edff39ffjsi: connection timed out
      2022-02-25 17:41:26.829 - debug: tuya.0 (32245) bf69b3293c1edff39ffjsi: Error from device (1): App still open on your mobile phone? Error: connection timed out
      2022-02-25 17:41:26.831 - warn: tuya.0 (32245) bf69b3293c1edff39ffjsi: Error on Reconnectconnection timed out
      2022-02-25 17:41:47.009 - debug: tuya.0 (32245) 08200118e868e759568a request data via get ...
      2022-02-25 17:41:47.137 - debug: tuya.0 (32245) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"00f003e803e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
      2022-02-25 17:41:47.151 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1645807307142,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709492529}
      2022-02-25 17:41:47.152 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1645807307142,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
      2022-02-25 17:41:47.153 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1645807307143,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
      2022-02-25 17:41:47.157 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.24 {"val":"00f003e803e8","ack":true,"ts":1645807307144,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709486787}
      2022-02-25 17:41:47.158 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1645807307145,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
      2022-02-25 17:41:47.159 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1645807307145,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
      2022-02-25 17:41:47.162 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1645807307147,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
      2022-02-25 17:41:47.165 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1645807307149,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
      2022-02-25 17:41:47.166 - debug: tuya.0 (32245) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1645807307150,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
      O Offline
      O Offline
      oFbEQnpoLKKl6mbY5e13
      @kla960
      Zunächst, weshalb solltest du nerven?
      Auf jeden Fall kennt der Tuya-Adapter kein passendes Schema für die zwei Geräte.
      2022-02-25 17:38:21.304 - info: tuya.0 (30968) {"schemaExt":"[{\"complexType\":\"\",\"id\":22,\"inputStyle\":\"\",\"inputType\":\"percent1\"},{\"complexType\":\"\",\"id\":23,\"inputStyle\":\"\",\"inputType\":\"percent\"},{\"complexType\":\"\",\"id\":26,\"inputStyle\":\"\",\"inputType\":\"countdown1\"}]","schema":"[{\"mode\":\"rw\",\"code\":\"switch_led\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power\",\"id\":20,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"work_mode\",\"name\":\"模式\",\"property\":{\"range\":[\"white\",\"colour\",\"scene\",\"music\"],\"type\":\"enum\"},\"iconname\":\"icon-dp_mode\",\"id\":21,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"colour_data\",\"name\":\"彩光\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-yanse\",\"id\":24,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"scene_data\",\"name\":\"场景\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-shoucang\",\"id\":25,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-a_nav_timer\",\"id\":26,\"type\":\"obj\"},{\"mode\":\"wr\",\"code\":\"music_data\",\"name\":\"音乐律动\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-dp_mic\",\"id\":27,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"mic_music_data\",\"name\":\"麦克风音乐律动\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-dp_mode\",\"id\":42,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"dreamlightmic_music_data\",\"name\":\"炫彩本地音乐律动\",\"property\":{\"type\":\"raw\",\"maxlen\":\"255\"},\"iconname\":\"icon-dp_mode\",\"id\":52,\"type\":\"raw\"}]"}
      Da sind aber auch noch andere Meldungen, die den Entwickler @apollon77 vielleicht interessiere:
      Hier crashed was:
      • O oFbEQnpoLKKl6mbY5e13
        @kla960
        Hier crashed was:
        kla960
        @ofbeqnpolkkl6mby5e13
        Muss ich das dem Entwickler irgendwo melden?
        O 1 Antwort Letzte Antwort
        • K kla960
          O Offline
          O Offline
          @kla960
          Du kannst ihn noch mal ansprechen, vielleicht hat er jetzt mehr Zeit. Name hatte ich oben ja schon genannt. Ansonsten kannst du bzgl. des unbekannten Schemas ein Issue auf der Github-Seite des Adapter aufmachen. Wenn du kein Github-Konto hast, kann ich das aber auch für dich übernehmen.
            kla960
            schrieb am zuletzt editiert von kla960
            @apollon77
            Hi, hast du mal zeit drauf zu schauen? Wenn du noch logs benötigst. Kein Problem!
            @oFbEQnpoLKKl6mbY5e13
            Einen Github Account habe ich leider nicht.
            O apollon77A 2 Antworten Letzte Antwort
            • apollon77A Offline
              @kla960 sagte in Tuya rgb LED Strip will nicht:
              Geht es immer noch darum? Oder geht es um denn "Websocket fehler mit dem Proxy"? Wenn um ersteres dann bekommt der Adapter keine lokale Antwort vom Gerät ... Ggf mal strom weg und neu starten, hilft dabei manchmal ...
              • apollon77A apollon77
                kla960
                @apollon77
                Es geht um connection timed out. Strom weg/ Neustart hilft leider auch nicht. Netzwerkkommunikation findet irgendwie statt. .53 ist der Tuya Controller und .110 ioBroker.
                Ganau wie hier, steht bei den Strips mit connection timout, dass die App nicht mehr unterstützt wird.
                https://github.com/Apollon77/ioBroker.tuya/issues/384
                • K kla960
                  @apollon77
                  @kla960 Let's not mix stuff bitte. Ich hatte verstanden das bei dir der Sync geklappt hatte und alles da ist und IP dabei und nur keine Verbding kommt?
                  Das scheinbar die App nicht mehr tut weiss ich und ich arbeite wie Zeit ist an einer anderen Lösung.
                    kla960
                    @apollon77 sagte in Tuya rgb LED Strip will nicht:
                    So stellt sich das für mich dar. Habe das nochmal nachgestellt und ein frisches log erstellt, da ich die Tage alles upgedated habe.
                    • Objekte des Tuya Adapters gelöscht
                    • Proxy gestartet
                    • Tuya App neu geöffnet
                    • Adapter findet 2 Devices
                    • Tuya App abgemeldet und geschlossen
                    • Adapter neu gestartet
                    • Device online status bleibt auf false und im Log steht connection timed out
                    2022-03-04 10:55:32.335 - info: tuya.0 (18234) Got terminate signal TERMINATE_YOURSELF
                    2022-03-04 10:55:32.336 - debug: tuya.0 (18234) 08200118e868e759568a: Disconnected from device
                    2022-03-04 10:55:32.361 - debug: tuya.0 (18234) connected set to false
                    2022-03-04 10:55:35.337 - info: tuya.0 (18234) terminating
                    2022-03-04 10:55:35.338 - debug: tuya.0 (18234) Plugin sentry destroyed
                    2022-03-04 10:55:35.339 - info: tuya.0 (18234) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-03-04 10:55:41.407 - debug: tuya.0 (24119) Redis Objects: Use Redis connection: iobroker-master:9001
                    2022-03-04 10:55:41.456 - debug: tuya.0 (24119) Objects client ready ... initialize now
                    2022-03-04 10:55:41.458 - debug: tuya.0 (24119) Objects create System PubSub Client
                    2022-03-04 10:55:41.459 - debug: tuya.0 (24119) Objects create User PubSub Client
                    2022-03-04 10:55:41.496 - debug: tuya.0 (24119) Objects client initialize lua scripts
                    2022-03-04 10:55:41.504 - debug: tuya.0 (24119) Objects connected to redis: iobroker-master:9001
                    2022-03-04 10:55:41.535 - debug: tuya.0 (24119) Redis States: Use Redis connection: redis:6379
                    2022-03-04 10:55:41.545 - debug: tuya.0 (24119) States create System PubSub Client
                    2022-03-04 10:55:41.546 - debug: tuya.0 (24119) States create User PubSub Client
                    2022-03-04 10:55:41.561 - debug: tuya.0 (24119) States connected to redis: redis:6379
                    2022-03-04 10:55:41.607 - debug: tuya.0 (24119) Plugin sentry Initialize Plugin (enabled=true)
                    2022-03-04 10:55:41.613 - info: tuya.0 (24119) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                    2022-03-04 10:55:41.795 - info: tuya.0 (24119) starting. Version 3.6.15 in /opt/iobroker/node_modules/iobroker.tuya, node: v14.19.0, js-controller: 4.0.15
                    2022-03-04 10:55:41.851 - debug: tuya.0 (24119) connected set to false
                    2022-03-04 10:55:41.858 - debug: tuya.0 (24119) init 2 known devices
                    2022-03-04 10:55:41.862 - debug: tuya.0 (24119) 08200118e868e759568a: Create device objects if not exist
                    2022-03-04 10:55:41.865 - debug: tuya.0 (24119) 08200118e868e759568a: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music","4":"smooth","5":"flash"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"number","min":10,"max":1000,"read":true,"write":true,"name":"bright_value","id":22,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"mic_sense","id":101,"role":"level"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"change_speed","id":102,"role":"level"},{"type":"number","states":{"0":"soft","1":"classic","2":"rock"},"read":true,"write":true,"name":"music_type","id":106,"role":"level"}]
                    2022-03-04 10:55:41.866 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 20
                    2022-03-04 10:55:41.867 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 21
                    2022-03-04 10:55:41.868 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 22
                    2022-03-04 10:55:41.869 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 24
                    2022-03-04 10:55:41.869 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 25
                    2022-03-04 10:55:41.870 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 26
                    2022-03-04 10:55:41.870 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 27
                    2022-03-04 10:55:41.871 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 28
                    2022-03-04 10:55:41.871 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 101
                    2022-03-04 10:55:41.872 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 102
                    2022-03-04 10:55:41.872 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 106
                    2022-03-04 10:55:41.874 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Schema found for b1kede78g4onnhgl: null
                    2022-03-04 10:55:41.875 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Create device objects if not exist
                    2022-03-04 10:55:41.986 - info: tuya.0 (24119) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
                    2022-03-04 10:55:42.030 - info: tuya.0 (24119) 08200118e868e759568a Init with IP=192.168.179.28, Key=f9e4d104d04a30ec, Version=3.3
                    2022-03-04 10:55:42.031 - info: tuya.0 (24119) Existing devices initialized
                    2022-03-04 10:55:42.036 - info: tuya.0 (24119) Listen for local Tuya devices on port 6666
                    2022-03-04 10:55:42.037 - info: tuya.0 (24119) Listen for encrypted local Tuya devices on port 6667
                    2022-03-04 10:55:42.105 - debug: tuya.0 (24119) 08200118e868e759568a: Connected to device
                    2022-03-04 10:55:42.132 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1646387742127,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387742127}
                    2022-03-04 10:55:42.133 - debug: tuya.0 (24119) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1646387742127,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387742127}
                    2022-03-04 10:55:42.134 - debug: tuya.0 (24119) connected set to true
                    2022-03-04 10:55:42.150 - debug: tuya.0 (24119) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"0000000003e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
                    2022-03-04 10:55:42.169 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646387742159,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                    2022-03-04 10:55:42.170 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646387742159,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                    2022-03-04 10:55:42.170 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646387742159,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                    2022-03-04 10:55:42.171 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646387742159,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                    2022-03-04 10:55:42.171 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646387742160,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                    2022-03-04 10:55:42.172 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646387742162,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                    2022-03-04 10:55:42.173 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646387742162,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                    2022-03-04 10:55:42.173 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646387742163,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                    2022-03-04 10:55:42.177 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646387742163,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                    2022-03-04 10:55:42.785 - debug: tuya.0 (24119) Discovered encrypted device and store for later usage: 192.168.179.53:53813 - 000055aa00000000000000130000009c00000000d09766676f3369eb10b5e9f132fd802a58ef5662b8d5ed0ce59c56875111dfd0db47deeb95d128ee5671c7659fb0f99062752cccf8912dc171de390d8bc81f4159bd59981c26d5958da187e096d937c840b1058c6d8cd9456f3f7e28eed4932bd684776d4d3bbbcc727ed5338dc70040ebe90a09c0e74796dc81a6517ad39c8f8494c932e298de410f638ed8bf10587ab027a3c60000aa55
                    2022-03-04 10:55:46.992 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (0): App still open on your mobile phone? Error: connection timed out
                    2022-03-04 10:55:46.993 - error: tuya.0 (24119) bf69b3293c1edff39ffjsi: connection timed out
                    2022-03-04 10:56:18.036 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Connected to device
                    2022-03-04 10:56:18.044 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.online {"val":true,"ack":true,"ts":1646387778042,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387778042}
                    2022-03-04 10:56:18.052 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (1): App still open on your mobile phone? json obj data unvalid
                    2022-03-04 10:56:18.053 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Received data: {"1":null,"2":null,"3":null,"101":null,"102":null,"103":null}
                    2022-03-04 10:56:18.054 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Ignore invalid data (Counter: 1)
                    2022-03-04 10:56:18.153 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi request data via get ...
                    2022-03-04 10:56:30.039 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Disconnected from device
                    2022-03-04 10:56:30.045 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.online {"val":false,"ack":true,"ts":1646387790042,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387790042}
                    2022-03-04 10:56:42.152 - debug: tuya.0 (24119) 08200118e868e759568a request data via get ...
                    2022-03-04 10:56:42.187 - debug: tuya.0 (24119) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"0000000003e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
                    2022-03-04 10:56:42.205 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646387802193,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                    2022-03-04 10:56:42.206 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646387802193,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                    2022-03-04 10:56:42.206 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646387802194,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                    2022-03-04 10:56:42.207 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646387802194,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                    2022-03-04 10:56:42.207 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646387802197,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                    2022-03-04 10:56:42.208 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646387802197,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                    2022-03-04 10:56:42.208 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646387802197,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                    2022-03-04 10:56:42.209 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646387802197,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                    2022-03-04 10:56:42.212 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646387802197,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                    2022-03-04 10:57:05.040 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (0): App still open on your mobile phone? Error: connection timed out
                    2022-03-04 10:57:05.041 - warn: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error on Reconnectconnection timed out
                    2022-03-04 10:57:28.473 - debug: tuya.0 (24119) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":144,"ack":false,"time":1646387848472},"_id":6825466}
                    2022-03-04 10:57:30.074 - debug: tuya.0 (24119) Message: {"command":"startProxy","message":{"proxyPort":"8888","proxyWebPort":"8889"},"from":"system.adapter.admin.0","callback":{"message":{"proxyPort":"8888","proxyWebPort":"8889"},"id":145,"ack":false,"time":1646387850073},"_id":6825467}
                    2022-03-04 10:57:30.076 - debug: tuya.0 (24119) Use first network interface (172.29.8.4)
                    2022-03-04 10:57:30.078 - info: tuya.0 (24119) Could not check/recreate proxy certificates
                    2022-03-04 10:57:30.120 - info: tuya.0 (24119) SSL-Proxy ready to receive requests
                    2022-03-04 10:57:30.312 - debug: tuya.0 (24119) Message: {"command":"getProxyResult","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":146,"ack":false,"time":1646387850310},"_id":6825468}
                    2022-03-04 10:57:40.043 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (1): App still open on your mobile phone? Error: connection timed out
                    2022-03-04 10:57:40.044 - warn: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error on Reconnectconnection timed out
                    2022-03-04 10:57:42.189 - debug: tuya.0 (24119) 08200118e868e759568a request data via get ...
                    2022-03-04 10:57:42.259 - debug: tuya.0 (24119) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"0000000003e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
                    2022-03-04 10:57:42.274 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646387862265,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                    2022-03-04 10:57:42.274 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646387862265,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                    2022-03-04 10:57:42.275 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646387862265,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                    2022-03-04 10:57:42.275 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646387862265,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                    2022-03-04 10:57:42.276 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646387862265,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                    2022-03-04 10:57:42.276 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646387862266,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                    2022-03-04 10:57:42.277 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646387862268,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                    2022-03-04 10:57:42.277 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646387862268,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                    2022-03-04 10:57:42.281 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646387862268,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                    2022-03-04 10:57:47.112 - debug: tuya.0 (24119) Found 2 device schema information
                    2022-03-04 10:57:47.113 - info: tuya.0 (24119) new Schema added for product type 5tnccdqna35enim9. Please send next line from logfile on disk to developer!
                    2022-03-04 10:57:47.113 - info: tuya.0 (24119) {"schemaExt":"[{\"complexType\":\"\",\"id\":22,\"inputStyle\":\"\",\"inputType\":\"percent1\"},{\"complexType\":\"\",\"id\":23,\"inputStyle\":\"\",\"inputType\":\"percent\"},{\"complexType\":\"\",\"id\":26,\"inputStyle\":\"\",\"inputType\":\"countdown1\"}]","schema":"[{\"mode\":\"rw\",\"code\":\"switch_led\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power\",\"id\":20,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"work_mode\",\"name\":\"模式\",\"property\":{\"range\":[\"white\",\"colour\",\"scene\",\"music\"],\"type\":\"enum\"},\"iconname\":\"icon-dp_mode\",\"id\":21,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"colour_data\",\"name\":\"彩光\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-yanse\",\"id\":24,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"scene_data\",\"name\":\"场景\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-shoucang\",\"id\":25,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-a_nav_timer\",\"id\":26,\"type\":\"obj\"},{\"mode\":\"wr\",\"code\":\"music_data\",\"name\":\"音乐律动\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-dp_mic\",\"id\":27,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"mic_music_data\",\"name\":\"麦克风音乐律动\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-dp_mode\",\"id\":42,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"dreamlightmic_music_data\",\"name\":\"炫彩本地音乐律动\",\"property\":{\"type\":\"raw\",\"maxlen\":\"255\"},\"iconname\":\"icon-dp_mode\",\"id\":52,\"type\":\"raw\"}]"}
                    2022-03-04 10:57:47.115 - debug: tuya.0 (24119) Found 2 devices
                    2022-03-04 10:57:47.115 - debug: tuya.0 (24119) 08200118e868e759568a: Schema found for lwnbiytsfgk6slyr: {"schema":[{"mode":"rw","code":"switch_led","name":"开关","property":{"type":"bool"},"id":20,"type":"obj"},{"mode":"rw","code":"work_mode","name":"模式","property":{"range":["white","colour","scene","music","smooth","flash"],"type":"enum"},"id":21,"type":"obj"},{"mode":"rw","code":"bright_value","name":"亮度值","property":{"unit":"","min":10,"max":1000,"scale":0,"step":1,"type":"value"},"id":22,"type":"obj"},{"mode":"rw","code":"colour_data","name":"彩光","property":{"type":"string","maxlen":255},"id":24,"type":"obj"},{"mode":"rw","code":"scene_data","name":"场景","property":{"type":"string","maxlen":255},"id":25,"type":"obj"},{"mode":"rw","code":"countdown","name":"倒计时","property":{"unit":"","min":0,"max":86400,"scale":0,"step":1,"type":"value"},"id":26,"type":"obj"},{"mode":"wr","code":"music_data","name":"音乐灯","property":{"type":"string","maxlen":255},"id":27,"type":"obj"},{"mode":"wr","code":"control_data","name":"调节","property":{"type":"string","maxlen":255},"id":28,"type":"obj"},{"mode":"rw","code":"mic_sense","name":"麦克风灵敏度","property":{"unit":"","min":1,"max":100,"scale":0,"step":1,"type":"value"},"id":101,"type":"obj"},{"mode":"rw","code":"change_speed","name":"变化速度","property":{"unit":"","min":1,"max":100,"scale":0,"step":1,"type":"value"},"id":102,"type":"obj"},{"mode":"rw","code":"music_type","name":"音乐风格","property":{"range":["soft","classic","rock"],"type":"enum"},"id":106,"type":"obj"}],"schemaExt":[]}
                    2022-03-04 10:57:47.118 - debug: tuya.0 (24119) 08200118e868e759568a: Disconnected from device
                    2022-03-04 10:57:47.119 - debug: tuya.0 (24119) 08200118e868e759568a: Create device objects if not exist
                    2022-03-04 10:57:47.121 - debug: tuya.0 (24119) 08200118e868e759568a: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music","4":"smooth","5":"flash"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"number","min":10,"max":1000,"read":true,"write":true,"name":"bright_value","id":22,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"mic_sense","id":101,"role":"level"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"change_speed","id":102,"role":"level"},{"type":"number","states":{"0":"soft","1":"classic","2":"rock"},"read":true,"write":true,"name":"music_type","id":106,"role":"level"}]
                    2022-03-04 10:57:47.121 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 20
                    2022-03-04 10:57:47.122 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 21
                    2022-03-04 10:57:47.123 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 22
                    2022-03-04 10:57:47.123 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 24
                    2022-03-04 10:57:47.124 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 25
                    2022-03-04 10:57:47.124 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 26
                    2022-03-04 10:57:47.125 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 27
                    2022-03-04 10:57:47.125 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 28
                    2022-03-04 10:57:47.126 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 101
                    2022-03-04 10:57:47.126 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 102
                    2022-03-04 10:57:47.126 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 106
                    2022-03-04 10:57:47.127 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Schema found for 5tnccdqna35enim9: {"schema":[{"mode":"rw","code":"switch_led","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power","id":20,"type":"obj"},{"mode":"rw","code":"work_mode","name":"模式","property":{"range":["white","colour","scene","music"],"type":"enum"},"iconname":"icon-dp_mode","id":21,"type":"obj"},{"mode":"rw","code":"colour_data","name":"彩光","property":{"type":"string","maxlen":255},"iconname":"icon-yanse","id":24,"type":"obj"},{"mode":"rw","code":"scene_data","name":"场景","property":{"type":"string","maxlen":255},"iconname":"icon-shoucang","id":25,"type":"obj"},{"mode":"rw","code":"countdown","name":"倒计时","property":{"min":0,"max":86400,"scale":0,"step":1,"type":"value"},"iconname":"icon-a_nav_timer","id":26,"type":"obj"},{"mode":"wr","code":"music_data","name":"音乐律动","property":{"type":"string","maxlen":255},"iconname":"icon-dp_mic","id":27,"type":"obj"},{"mode":"rw","code":"mic_music_data","name":"麦克风音乐律动","property":{"type":"string","maxlen":255},"iconname":"icon-dp_mode","id":42,"type":"obj"},{"mode":"rw","code":"dreamlightmic_music_data","name":"炫彩本地音乐律动","property":{"type":"raw","maxlen":"255"},"iconname":"icon-dp_mode","id":52,"type":"raw"}],"schemaExt":[{"complexType":"","id":22,"inputStyle":"","inputType":"percent1"},{"complexType":"","id":23,"inputStyle":"","inputType":"percent"},{"complexType":"","id":26,"inputStyle":"","inputType":"countdown1"}]}
                    2022-03-04 10:57:47.129 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Create device objects if not exist
                    2022-03-04 10:57:47.130 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"mic_music_data","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"dreamlightmic_music_data","id":52,"role":"text"}]
                    2022-03-04 10:57:47.131 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 20
                    2022-03-04 10:57:47.132 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 21
                    2022-03-04 10:57:47.132 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 24
                    2022-03-04 10:57:47.133 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 25
                    2022-03-04 10:57:47.133 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 26
                    2022-03-04 10:57:47.133 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 27
                    2022-03-04 10:57:47.134 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 42
                    2022-03-04 10:57:47.134 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 52
                    2022-03-04 10:57:47.169 - debug: tuya.0 (24119) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":147,"ack":false,"time":1646387867166},"_id":6825469}
                    2022-03-04 10:57:47.173 - debug: tuya.0 (24119) connected set to false
                    2022-03-04 10:57:47.178 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1646387867160,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867160}
                    2022-03-04 10:57:47.179 - debug: tuya.0 (24119) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1646387867160,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867160}
                    2022-03-04 10:57:47.180 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1646387867161,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867161}
                    2022-03-04 10:57:47.181 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.online {"val":false,"ack":true,"ts":1646387867161,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387790042}
                    2022-03-04 10:57:47.201 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646387867197,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                    2022-03-04 10:57:47.212 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646387867210,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                    2022-03-04 10:57:47.223 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646387867221,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                    2022-03-04 10:57:47.236 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646387867233,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                    2022-03-04 10:57:47.243 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646387867241,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                    2022-03-04 10:57:47.246 - debug: tuya.0 (24119) Found 2 device schema information
                    2022-03-04 10:57:47.247 - debug: tuya.0 (24119) Found 2 devices
                    2022-03-04 10:57:47.247 - debug: tuya.0 (24119) 08200118e868e759568a: Schema found for lwnbiytsfgk6slyr: {"schema":[{"mode":"rw","code":"switch_led","name":"开关","property":{"type":"bool"},"id":20,"type":"obj"},{"mode":"rw","code":"work_mode","name":"模式","property":{"range":["white","colour","scene","music","smooth","flash"],"type":"enum"},"id":21,"type":"obj"},{"mode":"rw","code":"bright_value","name":"亮度值","property":{"unit":"","min":10,"max":1000,"scale":0,"step":1,"type":"value"},"id":22,"type":"obj"},{"mode":"rw","code":"colour_data","name":"彩光","property":{"type":"string","maxlen":255},"id":24,"type":"obj"},{"mode":"rw","code":"scene_data","name":"场景","property":{"type":"string","maxlen":255},"id":25,"type":"obj"},{"mode":"rw","code":"countdown","name":"倒计时","property":{"unit":"","min":0,"max":86400,"scale":0,"step":1,"type":"value"},"id":26,"type":"obj"},{"mode":"wr","code":"music_data","name":"音乐灯","property":{"type":"string","maxlen":255},"id":27,"type":"obj"},{"mode":"wr","code":"control_data","name":"调节","property":{"type":"string","maxlen":255},"id":28,"type":"obj"},{"mode":"rw","code":"mic_sense","name":"麦克风灵敏度","property":{"unit":"","min":1,"max":100,"scale":0,"step":1,"type":"value"},"id":101,"type":"obj"},{"mode":"rw","code":"change_speed","name":"变化速度","property":{"unit":"","min":1,"max":100,"scale":0,"step":1,"type":"value"},"id":102,"type":"obj"},{"mode":"rw","code":"music_type","name":"音乐风格","property":{"range":["soft","classic","rock"],"type":"enum"},"id":106,"type":"obj"}],"schemaExt":[]}
                    2022-03-04 10:57:47.249 - debug: tuya.0 (24119) 08200118e868e759568a: Create device objects if not exist
                    2022-03-04 10:57:47.250 - debug: tuya.0 (24119) 08200118e868e759568a: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music","4":"smooth","5":"flash"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"number","min":10,"max":1000,"read":true,"write":true,"name":"bright_value","id":22,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"mic_sense","id":101,"role":"level"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"change_speed","id":102,"role":"level"},{"type":"number","states":{"0":"soft","1":"classic","2":"rock"},"read":true,"write":true,"name":"music_type","id":106,"role":"level"}]
                    2022-03-04 10:57:47.251 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 20
                    2022-03-04 10:57:47.251 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 21
                    2022-03-04 10:57:47.252 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 22
                    2022-03-04 10:57:47.252 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 24
                    2022-03-04 10:57:47.253 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 25
                    2022-03-04 10:57:47.253 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 26
                    2022-03-04 10:57:47.254 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 27
                    2022-03-04 10:57:47.254 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 28
                    2022-03-04 10:57:47.255 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 101
                    2022-03-04 10:57:47.255 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 102
                    2022-03-04 10:57:47.260 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 106
                    2022-03-04 10:57:47.260 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Schema found for 5tnccdqna35enim9: {"schema":[{"mode":"rw","code":"switch_led","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power","id":20,"type":"obj"},{"mode":"rw","code":"work_mode","name":"模式","property":{"range":["white","colour","scene","music"],"type":"enum"},"iconname":"icon-dp_mode","id":21,"type":"obj"},{"mode":"rw","code":"colour_data","name":"彩光","property":{"type":"string","maxlen":255},"iconname":"icon-yanse","id":24,"type":"obj"},{"mode":"rw","code":"scene_data","name":"场景","property":{"type":"string","maxlen":255},"iconname":"icon-shoucang","id":25,"type":"obj"},{"mode":"rw","code":"countdown","name":"倒计时","property":{"min":0,"max":86400,"scale":0,"step":1,"type":"value"},"iconname":"icon-a_nav_timer","id":26,"type":"obj"},{"mode":"wr","code":"music_data","name":"音乐律动","property":{"type":"string","maxlen":255},"iconname":"icon-dp_mic","id":27,"type":"obj"},{"mode":"rw","code":"mic_music_data","name":"麦克风音乐律动","property":{"type":"string","maxlen":255},"iconname":"icon-dp_mode","id":42,"type":"obj"},{"mode":"rw","code":"dreamlightmic_music_data","name":"炫彩本地音乐律动","property":{"type":"raw","maxlen":"255"},"iconname":"icon-dp_mode","id":52,"type":"raw"}],"schemaExt":[{"complexType":"","id":22,"inputStyle":"","inputType":"percent1"},{"complexType":"","id":23,"inputStyle":"","inputType":"percent"},{"complexType":"","id":26,"inputStyle":"","inputType":"countdown1"}]}
                    2022-03-04 10:57:47.262 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Create device objects if not exist
                    2022-03-04 10:57:47.263 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"mic_music_data","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"dreamlightmic_music_data","id":52,"role":"text"}]
                    2022-03-04 10:57:47.264 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 20
                    2022-03-04 10:57:47.264 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 21
                    2022-03-04 10:57:47.265 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 24
                    2022-03-04 10:57:47.266 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 25
                    2022-03-04 10:57:47.266 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 26
                    2022-03-04 10:57:47.267 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 27
                    2022-03-04 10:57:47.268 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 42
                    2022-03-04 10:57:47.268 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 52
                    2022-03-04 10:57:47.294 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1646387867288,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867161}
                    2022-03-04 10:57:47.295 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.online {"val":false,"ack":true,"ts":1646387867289,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387790042}
                    2022-03-04 10:57:47.306 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646387867303,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                    2022-03-04 10:57:47.316 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.27 {"val":"","ack":true,"ts":1646387867312,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113069}
                    2022-03-04 10:57:47.322 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.28 {"val":"","ack":true,"ts":1646387867317,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703822315}
                    2022-03-04 10:57:47.324 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646387867319,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                    2022-03-04 10:57:47.340 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646387867333,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                    2022-03-04 10:57:47.345 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646387867343,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                    2022-03-04 10:57:47.355 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.20 {"val":false,"ack":true,"ts":1646387867349,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867349}
                    2022-03-04 10:57:47.365 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.21 {"val":1,"ack":true,"ts":1646387867361,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867361}
                    2022-03-04 10:57:47.370 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.24 {"val":"007803e803e8","ack":true,"ts":1646387867365,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867365}
                    2022-03-04 10:57:47.373 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.25 {"val":"000e0d0000000000000000c80000","ack":true,"ts":1646387867367,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867367}
                    2022-03-04 10:57:47.378 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.26 {"val":0,"ack":true,"ts":1646387867373,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867373}
                    2022-03-04 10:57:47.392 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.27 {"val":"","ack":true,"ts":1646387867387,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867387}
                    2022-03-04 10:57:47.393 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.42 {"val":"000000016432000003e8007803e800f003e8003c03e800b403e8012c03e8","ack":true,"ts":1646387867388,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867388}
                    2022-03-04 10:57:47.402 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.52 {"val":"","ack":true,"ts":1646387867396,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867396}
                    2022-03-04 10:57:47.416 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646387867414,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                    2022-03-04 10:57:47.423 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646387867419,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                    2022-03-04 10:57:47.423 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646387867419,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                    2022-03-04 10:57:47.434 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646387867428,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                    2022-03-04 10:57:47.447 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646387867443,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                    2022-03-04 10:57:47.448 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646387867444,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                    2022-03-04 10:57:47.455 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.27 {"val":"","ack":true,"ts":1646387867450,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113069}
                    2022-03-04 10:57:47.462 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.28 {"val":"","ack":true,"ts":1646387867457,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703822315}
                    2022-03-04 10:57:47.475 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646387867470,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                    2022-03-04 10:57:47.476 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646387867470,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                    2022-03-04 10:57:47.483 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646387867480,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                    2022-03-04 10:57:47.496 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.20 {"val":false,"ack":true,"ts":1646387867492,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867349}
                    2022-03-04 10:57:47.500 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.21 {"val":1,"ack":true,"ts":1646387867496,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867361}
                    2022-03-04 10:57:47.511 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.24 {"val":"007803e803e8","ack":true,"ts":1646387867502,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867365}
                    2022-03-04 10:57:47.512 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.25 {"val":"000e0d0000000000000000c80000","ack":true,"ts":1646387867502,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867367}
                    2022-03-04 10:57:47.530 - info: tuya.0 (24119) 08200118e868e759568a Init with IP=192.168.179.28, Key=f9e4d104d04a30ec, Version=3.3
                    2022-03-04 10:57:47.533 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.26 {"val":0,"ack":true,"ts":1646387867528,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867373}
                    2022-03-04 10:57:47.535 - info: tuya.0 (24119) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
                    2022-03-04 10:57:47.537 - debug: tuya.0 (24119) 08200118e868e759568a: Connected to device
                    2022-03-04 10:57:47.539 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.27 {"val":"","ack":true,"ts":1646387867532,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867387}
                    2022-03-04 10:57:47.543 - info: tuya.0 (24119) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
                    2022-03-04 10:57:47.546 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.42 {"val":"000000016432000003e8007803e800f003e8003c03e800b403e8012c03e8","ack":true,"ts":1646387867541,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867388}
                    2022-03-04 10:57:47.547 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.52 {"val":"","ack":true,"ts":1646387867542,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867396}
                    2022-03-04 10:57:47.547 - info: tuya.0 (24119) 08200118e868e759568a Init with IP=192.168.179.28, Key=f9e4d104d04a30ec, Version=3.3
                    2022-03-04 10:57:47.551 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1646387867543,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867543}
                    2022-03-04 10:57:47.551 - debug: tuya.0 (24119) 08200118e868e759568a: Connected to device
                    2022-03-04 10:57:47.555 - debug: tuya.0 (24119) connected set to true
                    2022-03-04 10:57:47.557 - debug: tuya.0 (24119) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1646387867554,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867554}
                    2022-03-04 10:57:47.559 - debug: tuya.0 (24119) 08200118e868e759568a: Error from device (0): App still open on your mobile phone? Error: Error from socket: read ECONNRESET
                    2022-03-04 10:57:47.560 - debug: tuya.0 (24119) 08200118e868e759568a: Disconnected from device
                    2022-03-04 10:57:47.563 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1646387867562,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867543}
                    2022-03-04 10:57:47.586 - debug: tuya.0 (24119) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"0000000003e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
                    2022-03-04 10:57:47.596 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1646387867590,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867590}
                    2022-03-04 10:57:47.597 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646387867592,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                    2022-03-04 10:57:47.597 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646387867592,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                    2022-03-04 10:57:47.598 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646387867592,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                    2022-03-04 10:57:47.598 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646387867592,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                    2022-03-04 10:57:47.599 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646387867593,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                    2022-03-04 10:57:47.601 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646387867593,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                    2022-03-04 10:57:47.601 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646387867593,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                    2022-03-04 10:57:47.633 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646387867631,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                    2022-03-04 10:57:47.634 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646387867631,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                    2022-03-04 10:57:52.537 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (0): App still open on your mobile phone? Error: connection timed out
                    2022-03-04 10:57:52.538 - error: tuya.0 (24119) bf69b3293c1edff39ffjsi: connection timed out
                    2022-03-04 10:57:52.545 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (1): App still open on your mobile phone? Error: connection timed out
                    2022-03-04 10:57:52.546 - error: tuya.0 (24119) bf69b3293c1edff39ffjsi: connection timed out
                    2022-03-04 10:58:02.153 - debug: tuya.0 (24119) Message: {"command":"stopProxy","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":148,"ack":false,"time":1646387882152},"_id":6825470}
                    2022-03-04 10:58:17.563 - debug: tuya.0 (24119) 08200118e868e759568a: Connected to device
                    2022-03-04 10:58:17.568 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1646387897567,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387897567}
                    2022-03-04 10:58:17.570 - debug: tuya.0 (24119) 08200118e868e759568a: Error from device (0): App still open on your mobile phone? Error: Error from socket: read ECONNRESET
                    2022-03-04 10:58:17.571 - debug: tuya.0 (24119) 08200118e868e759568a: Disconnected from device
                    2022-03-04 10:58:17.576 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1646387897574,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387897574}
                    2022-03-04 10:58:27.548 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (2): App still open on your mobile phone? Error: connection timed out
                    2022-03-04 10:58:27.549 - warn: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error on Reconnectconnection timed out
                    2022-03-04 10:58:28.479 - debug: tuya.0 (24119) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":149,"ack":false,"time":1646387908477},"_id":6825471}
                    2022-03-04 10:58:47.152 - debug: tuya.0 (24119) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":150,"ack":false,"time":1646387927150},"_id":6825472}
                    2022-03-04 10:58:47.575 - debug: tuya.0 (24119) 08200118e868e759568a: Connected to device
                    2022-03-04 10:58:47.579 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1646387927578,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387927578}
                    2022-03-04 10:58:47.581 - debug: tuya.0 (24119) 08200118e868e759568a: Error from device (1): App still open on your mobile phone? Error: Error from socket: read ECONNRESET
                    2022-03-04 10:58:47.582 - debug: tuya.0 (24119) 08200118e868e759568a: Disconnected from device
                    2022-03-04 10:58:47.586 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1646387927585,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387927585}
                    2022-03-04 10:59:02.550 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (3): App still open on your mobile phone? Error: connection timed out
                    2022-03-04 10:59:02.550 - warn: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error on Reconnectconnection timed out
                    2022-03-04 10:59:11.393 - debug: tuya.0 (24119) Discovered encrypted device and store for later usage: 192.168.179.53:53813 - 000055aa00000000000000130000009c00000000d09766676f3369eb10b5e9f132fd802a58ef5662b8d5ed0ce59c56875111dfd0db47deeb95d128ee5671c7659fb0f99062752cccf8912dc171de390d8bc81f4159bd59981c26d5958da187e096d937c840b1058c6d8cd9456f3f7e28eed4932bd684776d4d3bbbcc727ed5338dc70040ebe90a09c0e74796dc81a6517ad39c8f8494c932e298de410f638ed8bf10587ab027a3c60000aa55
                    2022-03-04 10:59:11.395 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Try to initialize encrypted device with received UDP messages (#IPs: 1): version=3.3, key=68c09a743f096846
                    2022-03-04 10:59:11.396 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Schema found for b1kede78g4onnhgl: null
                    2022-03-04 10:59:11.397 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Create device objects if not exist
                    2022-03-04 10:59:11.404 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.online {"val":false,"ack":true,"ts":1646387951401,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387790042}
                    2022-03-04 10:59:11.404 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.ip {"val":"192.168.179.53","ack":true,"ts":1646387951401,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387716407}
                    2022-03-04 10:59:11.411 - info: tuya.0 (24119) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
                    2022-03-04 10:59:16.412 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (0): App still open on your mobile phone? Error: connection timed out
                    2022-03-04 10:59:16.413 - error: tuya.0 (24119) bf69b3293c1edff39ffjsi: connection timed out
                    2022-03-04 10:59:17.586 - debug: tuya.0 (24119) 08200118e868e759568a: Connected to device
                    2022-03-04 10:59:17.590 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1646387957588,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387957588}
                    2022-03-04 10:59:17.594 - debug: tuya.0 (24119) 08200118e868e759568a: Error from device (2): App still open on your mobile phone? Error: Error from socket: read ECONNRESET
                    2022-03-04 10:59:17.596 - debug: tuya.0 (24119) 08200118e868e759568a: Disconnected from device
                    2022-03-04 10:59:17.601 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1646387957598,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387957598}
                    2022-03-04 10:59:21.982 - info: tuya.0 (24119) Got terminate signal TERMINATE_YOURSELF
                    2022-03-04 10:59:21.988 - debug: tuya.0 (24119) connected set to false
                    2022-03-04 10:59:24.985 - info: tuya.0 (24119) terminating
                    2022-03-04 10:59:24.986 - debug: tuya.0 (24119) Plugin sentry destroyed
                    2022-03-04 10:59:24.986 - info: tuya.0 (24119) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-03-04 10:59:31.098 - debug: tuya.0 (24349) Redis Objects: Use Redis connection: iobroker-master:9001
                    2022-03-04 10:59:31.148 - debug: tuya.0 (24349) Objects client ready ... initialize now
                    2022-03-04 10:59:31.150 - debug: tuya.0 (24349) Objects create System PubSub Client
                    2022-03-04 10:59:31.152 - debug: tuya.0 (24349) Objects create User PubSub Client
                    2022-03-04 10:59:31.195 - debug: tuya.0 (24349) Objects client initialize lua scripts
                    2022-03-04 10:59:31.203 - debug: tuya.0 (24349) Objects connected to redis: iobroker-master:9001
                    2022-03-04 10:59:31.236 - debug: tuya.0 (24349) Redis States: Use Redis connection: redis:6379
                    2022-03-04 10:59:31.246 - debug: tuya.0 (24349) States create System PubSub Client
                    2022-03-04 10:59:31.247 - debug: tuya.0 (24349) States create User PubSub Client
                    2022-03-04 10:59:31.261 - debug: tuya.0 (24349) States connected to redis: redis:6379
                    2022-03-04 10:59:31.293 - debug: tuya.0 (24349) Plugin sentry Initialize Plugin (enabled=true)
                    2022-03-04 10:59:31.298 - info: tuya.0 (24349) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                    2022-03-04 10:59:31.444 - info: tuya.0 (24349) starting. Version 3.6.15 in /opt/iobroker/node_modules/iobroker.tuya, node: v14.19.0, js-controller: 4.0.15
                    2022-03-04 10:59:31.499 - debug: tuya.0 (24349) connected set to false
                    2022-03-04 10:59:31.506 - debug: tuya.0 (24349) init 2 known devices
                    2022-03-04 10:59:31.510 - debug: tuya.0 (24349) 08200118e868e759568a: Create device objects if not exist
                    2022-03-04 10:59:31.512 - debug: tuya.0 (24349) 08200118e868e759568a: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music","4":"smooth","5":"flash"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"number","min":10,"max":1000,"read":true,"write":true,"name":"bright_value","id":22,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"mic_sense","id":101,"role":"level"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"change_speed","id":102,"role":"level"},{"type":"number","states":{"0":"soft","1":"classic","2":"rock"},"read":true,"write":true,"name":"music_type","id":106,"role":"level"}]
                    2022-03-04 10:59:31.514 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 20
                    2022-03-04 10:59:31.515 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 21
                    2022-03-04 10:59:31.516 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 22
                    2022-03-04 10:59:31.516 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 24
                    2022-03-04 10:59:31.517 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 25
                    2022-03-04 10:59:31.518 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 26
                    2022-03-04 10:59:31.518 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 27
                    2022-03-04 10:59:31.519 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 28
                    2022-03-04 10:59:31.519 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 101
                    2022-03-04 10:59:31.520 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 102
                    2022-03-04 10:59:31.520 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 106
                    2022-03-04 10:59:31.522 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi: Create device objects if not exist
                    2022-03-04 10:59:31.524 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"mic_music_data","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"dreamlightmic_music_data","id":52,"role":"text"}]
                    2022-03-04 10:59:31.524 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi Register onChange for 20
                    2022-03-04 10:59:31.525 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi Register onChange for 21
                    2022-03-04 10:59:31.526 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi Register onChange for 24
                    2022-03-04 10:59:31.526 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi Register onChange for 25
                    2022-03-04 10:59:31.527 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi Register onChange for 26
                    2022-03-04 10:59:31.527 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi Register onChange for 27
                    2022-03-04 10:59:31.528 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi Register onChange for 42
                    2022-03-04 10:59:31.528 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi Register onChange for 52
                    2022-03-04 10:59:31.666 - info: tuya.0 (24349) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
                    2022-03-04 10:59:31.713 - info: tuya.0 (24349) 08200118e868e759568a Init with IP=192.168.179.28, Key=f9e4d104d04a30ec, Version=3.3
                    2022-03-04 10:59:31.714 - info: tuya.0 (24349) Existing devices initialized
                    2022-03-04 10:59:31.719 - info: tuya.0 (24349) Listen for local Tuya devices on port 6666
                    2022-03-04 10:59:31.720 - info: tuya.0 (24349) Listen for encrypted local Tuya devices on port 6667
                    2022-03-04 10:59:31.792 - debug: tuya.0 (24349) 08200118e868e759568a: Connected to device
                    2022-03-04 10:59:31.806 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1646387971802,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387971802}
                    2022-03-04 10:59:31.807 - debug: tuya.0 (24349) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1646387971802,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387971802}
                    2022-03-04 10:59:31.807 - debug: tuya.0 (24349) connected set to true
                    2022-03-04 10:59:31.836 - debug: tuya.0 (24349) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"0000000003e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
                    2022-03-04 10:59:31.852 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646387971843,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                    2022-03-04 10:59:31.853 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646387971843,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                    2022-03-04 10:59:31.854 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646387971843,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                    2022-03-04 10:59:31.854 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646387971844,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                    2022-03-04 10:59:31.855 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646387971844,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                    2022-03-04 10:59:31.855 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646387971844,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                    2022-03-04 10:59:31.856 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646387971844,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                    2022-03-04 10:59:31.856 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646387971846,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                    2022-03-04 10:59:31.857 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646387971846,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                    2022-03-04 10:59:32.397 - debug: tuya.0 (24349) Discovered encrypted device and store for later usage: 192.168.179.53:53813 - 000055aa00000000000000130000009c00000000d09766676f3369eb10b5e9f132fd802a58ef5662b8d5ed0ce59c56875111dfd0db47deeb95d128ee5671c7659fb0f99062752cccf8912dc171de390d8bc81f4159bd59981c26d5958da187e096d937c840b1058c6d8cd9456f3f7e28eed4932bd684776d4d3bbbcc727ed5338dc70040ebe90a09c0e74796dc81a6517ad39c8f8494c932e298de410f638ed8bf10587ab027a3c60000aa55
                    2022-03-04 10:59:36.672 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi: Error from device (0): App still open on your mobile phone? Error: connection timed out
                    2022-03-04 10:59:36.673 - error: tuya.0 (24349) bf69b3293c1edff39ffjsi: connection timed out
                    Das scheinbar die App nicht mehr tut weiss ich und ich arbeite wie Zeit ist an einer anderen Lösung.
                    Ok. Dachte es gibt vielleicht einen Zusammenhang ;-)
                    • K kla960
                      @apollon77 sagte in Tuya rgb LED Strip will nicht:
                      @kla960 Let's not mix stuff bitte. Ich hatte verstanden das bei dir der Sync geklappt hatte und alles da ist und IP dabei und nur keine Verbding kommt?
                      So stellt sich das für mich dar. Habe das nochmal nachgestellt und ein frisches log erstellt, da ich die Tage alles upgedated habe.
                      • Objekte des Tuya Adapters gelöscht
                      • Proxy gestartet
                      • Tuya App neu geöffnet
                      • Adapter findet 2 Devices
                      • Tuya App abgemeldet und geschlossen
                      • Adapter neu gestartet
                      • Device online status bleibt auf false und im Log steht connection timed out
                      2022-03-04 10:55:32.335 - info: tuya.0 (18234) Got terminate signal TERMINATE_YOURSELF
                      2022-03-04 10:55:32.336 - debug: tuya.0 (18234) 08200118e868e759568a: Disconnected from device
                      2022-03-04 10:55:32.361 - debug: tuya.0 (18234) connected set to false
                      2022-03-04 10:55:35.337 - info: tuya.0 (18234) terminating
                      2022-03-04 10:55:35.338 - debug: tuya.0 (18234) Plugin sentry destroyed
                      2022-03-04 10:55:35.339 - info: tuya.0 (18234) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2022-03-04 10:55:41.407 - debug: tuya.0 (24119) Redis Objects: Use Redis connection: iobroker-master:9001
                      2022-03-04 10:55:41.456 - debug: tuya.0 (24119) Objects client ready ... initialize now
                      2022-03-04 10:55:41.458 - debug: tuya.0 (24119) Objects create System PubSub Client
                      2022-03-04 10:55:41.459 - debug: tuya.0 (24119) Objects create User PubSub Client
                      2022-03-04 10:55:41.496 - debug: tuya.0 (24119) Objects client initialize lua scripts
                      2022-03-04 10:55:41.504 - debug: tuya.0 (24119) Objects connected to redis: iobroker-master:9001
                      2022-03-04 10:55:41.535 - debug: tuya.0 (24119) Redis States: Use Redis connection: redis:6379
                      2022-03-04 10:55:41.545 - debug: tuya.0 (24119) States create System PubSub Client
                      2022-03-04 10:55:41.546 - debug: tuya.0 (24119) States create User PubSub Client
                      2022-03-04 10:55:41.561 - debug: tuya.0 (24119) States connected to redis: redis:6379
                      2022-03-04 10:55:41.607 - debug: tuya.0 (24119) Plugin sentry Initialize Plugin (enabled=true)
                      2022-03-04 10:55:41.613 - info: tuya.0 (24119) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      2022-03-04 10:55:41.795 - info: tuya.0 (24119) starting. Version 3.6.15 in /opt/iobroker/node_modules/iobroker.tuya, node: v14.19.0, js-controller: 4.0.15
                      2022-03-04 10:55:41.851 - debug: tuya.0 (24119) connected set to false
                      2022-03-04 10:55:41.858 - debug: tuya.0 (24119) init 2 known devices
                      2022-03-04 10:55:41.862 - debug: tuya.0 (24119) 08200118e868e759568a: Create device objects if not exist
                      2022-03-04 10:55:41.865 - debug: tuya.0 (24119) 08200118e868e759568a: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music","4":"smooth","5":"flash"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"number","min":10,"max":1000,"read":true,"write":true,"name":"bright_value","id":22,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"mic_sense","id":101,"role":"level"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"change_speed","id":102,"role":"level"},{"type":"number","states":{"0":"soft","1":"classic","2":"rock"},"read":true,"write":true,"name":"music_type","id":106,"role":"level"}]
                      2022-03-04 10:55:41.866 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 20
                      2022-03-04 10:55:41.867 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 21
                      2022-03-04 10:55:41.868 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 22
                      2022-03-04 10:55:41.869 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 24
                      2022-03-04 10:55:41.869 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 25
                      2022-03-04 10:55:41.870 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 26
                      2022-03-04 10:55:41.870 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 27
                      2022-03-04 10:55:41.871 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 28
                      2022-03-04 10:55:41.871 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 101
                      2022-03-04 10:55:41.872 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 102
                      2022-03-04 10:55:41.872 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 106
                      2022-03-04 10:55:41.874 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Schema found for b1kede78g4onnhgl: null
                      2022-03-04 10:55:41.875 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Create device objects if not exist
                      2022-03-04 10:55:41.986 - info: tuya.0 (24119) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
                      2022-03-04 10:55:42.030 - info: tuya.0 (24119) 08200118e868e759568a Init with IP=192.168.179.28, Key=f9e4d104d04a30ec, Version=3.3
                      2022-03-04 10:55:42.031 - info: tuya.0 (24119) Existing devices initialized
                      2022-03-04 10:55:42.036 - info: tuya.0 (24119) Listen for local Tuya devices on port 6666
                      2022-03-04 10:55:42.037 - info: tuya.0 (24119) Listen for encrypted local Tuya devices on port 6667
                      2022-03-04 10:55:42.105 - debug: tuya.0 (24119) 08200118e868e759568a: Connected to device
                      2022-03-04 10:55:42.132 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1646387742127,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387742127}
                      2022-03-04 10:55:42.133 - debug: tuya.0 (24119) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1646387742127,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387742127}
                      2022-03-04 10:55:42.134 - debug: tuya.0 (24119) connected set to true
                      2022-03-04 10:55:42.150 - debug: tuya.0 (24119) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"0000000003e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
                      2022-03-04 10:55:42.169 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646387742159,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                      2022-03-04 10:55:42.170 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646387742159,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                      2022-03-04 10:55:42.170 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646387742159,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                      2022-03-04 10:55:42.171 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646387742159,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                      2022-03-04 10:55:42.171 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646387742160,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                      2022-03-04 10:55:42.172 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646387742162,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                      2022-03-04 10:55:42.173 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646387742162,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                      2022-03-04 10:55:42.173 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646387742163,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                      2022-03-04 10:55:42.177 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646387742163,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                      2022-03-04 10:55:42.785 - debug: tuya.0 (24119) Discovered encrypted device and store for later usage: 192.168.179.53:53813 - 000055aa00000000000000130000009c00000000d09766676f3369eb10b5e9f132fd802a58ef5662b8d5ed0ce59c56875111dfd0db47deeb95d128ee5671c7659fb0f99062752cccf8912dc171de390d8bc81f4159bd59981c26d5958da187e096d937c840b1058c6d8cd9456f3f7e28eed4932bd684776d4d3bbbcc727ed5338dc70040ebe90a09c0e74796dc81a6517ad39c8f8494c932e298de410f638ed8bf10587ab027a3c60000aa55
                      2022-03-04 10:55:46.992 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (0): App still open on your mobile phone? Error: connection timed out
                      2022-03-04 10:55:46.993 - error: tuya.0 (24119) bf69b3293c1edff39ffjsi: connection timed out
                      2022-03-04 10:56:18.036 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Connected to device
                      2022-03-04 10:56:18.044 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.online {"val":true,"ack":true,"ts":1646387778042,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387778042}
                      2022-03-04 10:56:18.052 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (1): App still open on your mobile phone? json obj data unvalid
                      2022-03-04 10:56:18.053 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Received data: {"1":null,"2":null,"3":null,"101":null,"102":null,"103":null}
                      2022-03-04 10:56:18.054 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Ignore invalid data (Counter: 1)
                      2022-03-04 10:56:18.153 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi request data via get ...
                      2022-03-04 10:56:30.039 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Disconnected from device
                      2022-03-04 10:56:30.045 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.online {"val":false,"ack":true,"ts":1646387790042,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387790042}
                      2022-03-04 10:56:42.152 - debug: tuya.0 (24119) 08200118e868e759568a request data via get ...
                      2022-03-04 10:56:42.187 - debug: tuya.0 (24119) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"0000000003e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
                      2022-03-04 10:56:42.205 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646387802193,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                      2022-03-04 10:56:42.206 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646387802193,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                      2022-03-04 10:56:42.206 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646387802194,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                      2022-03-04 10:56:42.207 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646387802194,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                      2022-03-04 10:56:42.207 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646387802197,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                      2022-03-04 10:56:42.208 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646387802197,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                      2022-03-04 10:56:42.208 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646387802197,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                      2022-03-04 10:56:42.209 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646387802197,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                      2022-03-04 10:56:42.212 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646387802197,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                      2022-03-04 10:57:05.040 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (0): App still open on your mobile phone? Error: connection timed out
                      2022-03-04 10:57:05.041 - warn: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error on Reconnectconnection timed out
                      2022-03-04 10:57:28.473 - debug: tuya.0 (24119) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":144,"ack":false,"time":1646387848472},"_id":6825466}
                      2022-03-04 10:57:30.074 - debug: tuya.0 (24119) Message: {"command":"startProxy","message":{"proxyPort":"8888","proxyWebPort":"8889"},"from":"system.adapter.admin.0","callback":{"message":{"proxyPort":"8888","proxyWebPort":"8889"},"id":145,"ack":false,"time":1646387850073},"_id":6825467}
                      2022-03-04 10:57:30.076 - debug: tuya.0 (24119) Use first network interface (172.29.8.4)
                      2022-03-04 10:57:30.078 - info: tuya.0 (24119) Could not check/recreate proxy certificates
                      2022-03-04 10:57:30.120 - info: tuya.0 (24119) SSL-Proxy ready to receive requests
                      2022-03-04 10:57:30.312 - debug: tuya.0 (24119) Message: {"command":"getProxyResult","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":146,"ack":false,"time":1646387850310},"_id":6825468}
                      2022-03-04 10:57:40.043 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (1): App still open on your mobile phone? Error: connection timed out
                      2022-03-04 10:57:40.044 - warn: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error on Reconnectconnection timed out
                      2022-03-04 10:57:42.189 - debug: tuya.0 (24119) 08200118e868e759568a request data via get ...
                      2022-03-04 10:57:42.259 - debug: tuya.0 (24119) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"0000000003e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
                      2022-03-04 10:57:42.274 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646387862265,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                      2022-03-04 10:57:42.274 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646387862265,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                      2022-03-04 10:57:42.275 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646387862265,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                      2022-03-04 10:57:42.275 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646387862265,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                      2022-03-04 10:57:42.276 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646387862265,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                      2022-03-04 10:57:42.276 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646387862266,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                      2022-03-04 10:57:42.277 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646387862268,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                      2022-03-04 10:57:42.277 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646387862268,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                      2022-03-04 10:57:42.281 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646387862268,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                      2022-03-04 10:57:47.112 - debug: tuya.0 (24119) Found 2 device schema information
                      2022-03-04 10:57:47.113 - info: tuya.0 (24119) new Schema added for product type 5tnccdqna35enim9. Please send next line from logfile on disk to developer!
                      2022-03-04 10:57:47.113 - info: tuya.0 (24119) {"schemaExt":"[{\"complexType\":\"\",\"id\":22,\"inputStyle\":\"\",\"inputType\":\"percent1\"},{\"complexType\":\"\",\"id\":23,\"inputStyle\":\"\",\"inputType\":\"percent\"},{\"complexType\":\"\",\"id\":26,\"inputStyle\":\"\",\"inputType\":\"countdown1\"}]","schema":"[{\"mode\":\"rw\",\"code\":\"switch_led\",\"name\":\"开关\",\"property\":{\"type\":\"bool\"},\"iconname\":\"icon-dp_power\",\"id\":20,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"work_mode\",\"name\":\"模式\",\"property\":{\"range\":[\"white\",\"colour\",\"scene\",\"music\"],\"type\":\"enum\"},\"iconname\":\"icon-dp_mode\",\"id\":21,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"colour_data\",\"name\":\"彩光\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-yanse\",\"id\":24,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"scene_data\",\"name\":\"场景\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-shoucang\",\"id\":25,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"countdown\",\"name\":\"倒计时\",\"property\":{\"min\":0,\"max\":86400,\"scale\":0,\"step\":1,\"type\":\"value\"},\"iconname\":\"icon-a_nav_timer\",\"id\":26,\"type\":\"obj\"},{\"mode\":\"wr\",\"code\":\"music_data\",\"name\":\"音乐律动\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-dp_mic\",\"id\":27,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"mic_music_data\",\"name\":\"麦克风音乐律动\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"iconname\":\"icon-dp_mode\",\"id\":42,\"type\":\"obj\"},{\"mode\":\"rw\",\"code\":\"dreamlightmic_music_data\",\"name\":\"炫彩本地音乐律动\",\"property\":{\"type\":\"raw\",\"maxlen\":\"255\"},\"iconname\":\"icon-dp_mode\",\"id\":52,\"type\":\"raw\"}]"}
                      2022-03-04 10:57:47.115 - debug: tuya.0 (24119) Found 2 devices
                      2022-03-04 10:57:47.115 - debug: tuya.0 (24119) 08200118e868e759568a: Schema found for lwnbiytsfgk6slyr: {"schema":[{"mode":"rw","code":"switch_led","name":"开关","property":{"type":"bool"},"id":20,"type":"obj"},{"mode":"rw","code":"work_mode","name":"模式","property":{"range":["white","colour","scene","music","smooth","flash"],"type":"enum"},"id":21,"type":"obj"},{"mode":"rw","code":"bright_value","name":"亮度值","property":{"unit":"","min":10,"max":1000,"scale":0,"step":1,"type":"value"},"id":22,"type":"obj"},{"mode":"rw","code":"colour_data","name":"彩光","property":{"type":"string","maxlen":255},"id":24,"type":"obj"},{"mode":"rw","code":"scene_data","name":"场景","property":{"type":"string","maxlen":255},"id":25,"type":"obj"},{"mode":"rw","code":"countdown","name":"倒计时","property":{"unit":"","min":0,"max":86400,"scale":0,"step":1,"type":"value"},"id":26,"type":"obj"},{"mode":"wr","code":"music_data","name":"音乐灯","property":{"type":"string","maxlen":255},"id":27,"type":"obj"},{"mode":"wr","code":"control_data","name":"调节","property":{"type":"string","maxlen":255},"id":28,"type":"obj"},{"mode":"rw","code":"mic_sense","name":"麦克风灵敏度","property":{"unit":"","min":1,"max":100,"scale":0,"step":1,"type":"value"},"id":101,"type":"obj"},{"mode":"rw","code":"change_speed","name":"变化速度","property":{"unit":"","min":1,"max":100,"scale":0,"step":1,"type":"value"},"id":102,"type":"obj"},{"mode":"rw","code":"music_type","name":"音乐风格","property":{"range":["soft","classic","rock"],"type":"enum"},"id":106,"type":"obj"}],"schemaExt":[]}
                      2022-03-04 10:57:47.118 - debug: tuya.0 (24119) 08200118e868e759568a: Disconnected from device
                      2022-03-04 10:57:47.119 - debug: tuya.0 (24119) 08200118e868e759568a: Create device objects if not exist
                      2022-03-04 10:57:47.121 - debug: tuya.0 (24119) 08200118e868e759568a: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music","4":"smooth","5":"flash"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"number","min":10,"max":1000,"read":true,"write":true,"name":"bright_value","id":22,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"mic_sense","id":101,"role":"level"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"change_speed","id":102,"role":"level"},{"type":"number","states":{"0":"soft","1":"classic","2":"rock"},"read":true,"write":true,"name":"music_type","id":106,"role":"level"}]
                      2022-03-04 10:57:47.121 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 20
                      2022-03-04 10:57:47.122 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 21
                      2022-03-04 10:57:47.123 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 22
                      2022-03-04 10:57:47.123 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 24
                      2022-03-04 10:57:47.124 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 25
                      2022-03-04 10:57:47.124 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 26
                      2022-03-04 10:57:47.125 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 27
                      2022-03-04 10:57:47.125 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 28
                      2022-03-04 10:57:47.126 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 101
                      2022-03-04 10:57:47.126 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 102
                      2022-03-04 10:57:47.126 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 106
                      2022-03-04 10:57:47.127 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Schema found for 5tnccdqna35enim9: {"schema":[{"mode":"rw","code":"switch_led","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power","id":20,"type":"obj"},{"mode":"rw","code":"work_mode","name":"模式","property":{"range":["white","colour","scene","music"],"type":"enum"},"iconname":"icon-dp_mode","id":21,"type":"obj"},{"mode":"rw","code":"colour_data","name":"彩光","property":{"type":"string","maxlen":255},"iconname":"icon-yanse","id":24,"type":"obj"},{"mode":"rw","code":"scene_data","name":"场景","property":{"type":"string","maxlen":255},"iconname":"icon-shoucang","id":25,"type":"obj"},{"mode":"rw","code":"countdown","name":"倒计时","property":{"min":0,"max":86400,"scale":0,"step":1,"type":"value"},"iconname":"icon-a_nav_timer","id":26,"type":"obj"},{"mode":"wr","code":"music_data","name":"音乐律动","property":{"type":"string","maxlen":255},"iconname":"icon-dp_mic","id":27,"type":"obj"},{"mode":"rw","code":"mic_music_data","name":"麦克风音乐律动","property":{"type":"string","maxlen":255},"iconname":"icon-dp_mode","id":42,"type":"obj"},{"mode":"rw","code":"dreamlightmic_music_data","name":"炫彩本地音乐律动","property":{"type":"raw","maxlen":"255"},"iconname":"icon-dp_mode","id":52,"type":"raw"}],"schemaExt":[{"complexType":"","id":22,"inputStyle":"","inputType":"percent1"},{"complexType":"","id":23,"inputStyle":"","inputType":"percent"},{"complexType":"","id":26,"inputStyle":"","inputType":"countdown1"}]}
                      2022-03-04 10:57:47.129 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Create device objects if not exist
                      2022-03-04 10:57:47.130 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"mic_music_data","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"dreamlightmic_music_data","id":52,"role":"text"}]
                      2022-03-04 10:57:47.131 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 20
                      2022-03-04 10:57:47.132 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 21
                      2022-03-04 10:57:47.132 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 24
                      2022-03-04 10:57:47.133 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 25
                      2022-03-04 10:57:47.133 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 26
                      2022-03-04 10:57:47.133 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 27
                      2022-03-04 10:57:47.134 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 42
                      2022-03-04 10:57:47.134 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 52
                      2022-03-04 10:57:47.169 - debug: tuya.0 (24119) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":147,"ack":false,"time":1646387867166},"_id":6825469}
                      2022-03-04 10:57:47.173 - debug: tuya.0 (24119) connected set to false
                      2022-03-04 10:57:47.178 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1646387867160,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867160}
                      2022-03-04 10:57:47.179 - debug: tuya.0 (24119) stateChange tuya.0.info.connection {"val":false,"ack":true,"ts":1646387867160,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867160}
                      2022-03-04 10:57:47.180 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1646387867161,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867161}
                      2022-03-04 10:57:47.181 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.online {"val":false,"ack":true,"ts":1646387867161,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387790042}
                      2022-03-04 10:57:47.201 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646387867197,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                      2022-03-04 10:57:47.212 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646387867210,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                      2022-03-04 10:57:47.223 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646387867221,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                      2022-03-04 10:57:47.236 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646387867233,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                      2022-03-04 10:57:47.243 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646387867241,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                      2022-03-04 10:57:47.246 - debug: tuya.0 (24119) Found 2 device schema information
                      2022-03-04 10:57:47.247 - debug: tuya.0 (24119) Found 2 devices
                      2022-03-04 10:57:47.247 - debug: tuya.0 (24119) 08200118e868e759568a: Schema found for lwnbiytsfgk6slyr: {"schema":[{"mode":"rw","code":"switch_led","name":"开关","property":{"type":"bool"},"id":20,"type":"obj"},{"mode":"rw","code":"work_mode","name":"模式","property":{"range":["white","colour","scene","music","smooth","flash"],"type":"enum"},"id":21,"type":"obj"},{"mode":"rw","code":"bright_value","name":"亮度值","property":{"unit":"","min":10,"max":1000,"scale":0,"step":1,"type":"value"},"id":22,"type":"obj"},{"mode":"rw","code":"colour_data","name":"彩光","property":{"type":"string","maxlen":255},"id":24,"type":"obj"},{"mode":"rw","code":"scene_data","name":"场景","property":{"type":"string","maxlen":255},"id":25,"type":"obj"},{"mode":"rw","code":"countdown","name":"倒计时","property":{"unit":"","min":0,"max":86400,"scale":0,"step":1,"type":"value"},"id":26,"type":"obj"},{"mode":"wr","code":"music_data","name":"音乐灯","property":{"type":"string","maxlen":255},"id":27,"type":"obj"},{"mode":"wr","code":"control_data","name":"调节","property":{"type":"string","maxlen":255},"id":28,"type":"obj"},{"mode":"rw","code":"mic_sense","name":"麦克风灵敏度","property":{"unit":"","min":1,"max":100,"scale":0,"step":1,"type":"value"},"id":101,"type":"obj"},{"mode":"rw","code":"change_speed","name":"变化速度","property":{"unit":"","min":1,"max":100,"scale":0,"step":1,"type":"value"},"id":102,"type":"obj"},{"mode":"rw","code":"music_type","name":"音乐风格","property":{"range":["soft","classic","rock"],"type":"enum"},"id":106,"type":"obj"}],"schemaExt":[]}
                      2022-03-04 10:57:47.249 - debug: tuya.0 (24119) 08200118e868e759568a: Create device objects if not exist
                      2022-03-04 10:57:47.250 - debug: tuya.0 (24119) 08200118e868e759568a: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music","4":"smooth","5":"flash"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"number","min":10,"max":1000,"read":true,"write":true,"name":"bright_value","id":22,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"mic_sense","id":101,"role":"level"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"change_speed","id":102,"role":"level"},{"type":"number","states":{"0":"soft","1":"classic","2":"rock"},"read":true,"write":true,"name":"music_type","id":106,"role":"level"}]
                      2022-03-04 10:57:47.251 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 20
                      2022-03-04 10:57:47.251 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 21
                      2022-03-04 10:57:47.252 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 22
                      2022-03-04 10:57:47.252 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 24
                      2022-03-04 10:57:47.253 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 25
                      2022-03-04 10:57:47.253 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 26
                      2022-03-04 10:57:47.254 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 27
                      2022-03-04 10:57:47.254 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 28
                      2022-03-04 10:57:47.255 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 101
                      2022-03-04 10:57:47.255 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 102
                      2022-03-04 10:57:47.260 - debug: tuya.0 (24119) 08200118e868e759568a Register onChange for 106
                      2022-03-04 10:57:47.260 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Schema found for 5tnccdqna35enim9: {"schema":[{"mode":"rw","code":"switch_led","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power","id":20,"type":"obj"},{"mode":"rw","code":"work_mode","name":"模式","property":{"range":["white","colour","scene","music"],"type":"enum"},"iconname":"icon-dp_mode","id":21,"type":"obj"},{"mode":"rw","code":"colour_data","name":"彩光","property":{"type":"string","maxlen":255},"iconname":"icon-yanse","id":24,"type":"obj"},{"mode":"rw","code":"scene_data","name":"场景","property":{"type":"string","maxlen":255},"iconname":"icon-shoucang","id":25,"type":"obj"},{"mode":"rw","code":"countdown","name":"倒计时","property":{"min":0,"max":86400,"scale":0,"step":1,"type":"value"},"iconname":"icon-a_nav_timer","id":26,"type":"obj"},{"mode":"wr","code":"music_data","name":"音乐律动","property":{"type":"string","maxlen":255},"iconname":"icon-dp_mic","id":27,"type":"obj"},{"mode":"rw","code":"mic_music_data","name":"麦克风音乐律动","property":{"type":"string","maxlen":255},"iconname":"icon-dp_mode","id":42,"type":"obj"},{"mode":"rw","code":"dreamlightmic_music_data","name":"炫彩本地音乐律动","property":{"type":"raw","maxlen":"255"},"iconname":"icon-dp_mode","id":52,"type":"raw"}],"schemaExt":[{"complexType":"","id":22,"inputStyle":"","inputType":"percent1"},{"complexType":"","id":23,"inputStyle":"","inputType":"percent"},{"complexType":"","id":26,"inputStyle":"","inputType":"countdown1"}]}
                      2022-03-04 10:57:47.262 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Create device objects if not exist
                      2022-03-04 10:57:47.263 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"mic_music_data","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"dreamlightmic_music_data","id":52,"role":"text"}]
                      2022-03-04 10:57:47.264 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 20
                      2022-03-04 10:57:47.264 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 21
                      2022-03-04 10:57:47.265 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 24
                      2022-03-04 10:57:47.266 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 25
                      2022-03-04 10:57:47.266 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 26
                      2022-03-04 10:57:47.267 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 27
                      2022-03-04 10:57:47.268 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 42
                      2022-03-04 10:57:47.268 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi Register onChange for 52
                      2022-03-04 10:57:47.294 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1646387867288,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867161}
                      2022-03-04 10:57:47.295 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.online {"val":false,"ack":true,"ts":1646387867289,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387790042}
                      2022-03-04 10:57:47.306 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646387867303,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                      2022-03-04 10:57:47.316 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.27 {"val":"","ack":true,"ts":1646387867312,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113069}
                      2022-03-04 10:57:47.322 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.28 {"val":"","ack":true,"ts":1646387867317,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703822315}
                      2022-03-04 10:57:47.324 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646387867319,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                      2022-03-04 10:57:47.340 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646387867333,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                      2022-03-04 10:57:47.345 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646387867343,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                      2022-03-04 10:57:47.355 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.20 {"val":false,"ack":true,"ts":1646387867349,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867349}
                      2022-03-04 10:57:47.365 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.21 {"val":1,"ack":true,"ts":1646387867361,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867361}
                      2022-03-04 10:57:47.370 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.24 {"val":"007803e803e8","ack":true,"ts":1646387867365,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867365}
                      2022-03-04 10:57:47.373 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.25 {"val":"000e0d0000000000000000c80000","ack":true,"ts":1646387867367,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867367}
                      2022-03-04 10:57:47.378 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.26 {"val":0,"ack":true,"ts":1646387867373,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867373}
                      2022-03-04 10:57:47.392 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.27 {"val":"","ack":true,"ts":1646387867387,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867387}
                      2022-03-04 10:57:47.393 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.42 {"val":"000000016432000003e8007803e800f003e8003c03e800b403e8012c03e8","ack":true,"ts":1646387867388,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867388}
                      2022-03-04 10:57:47.402 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.52 {"val":"","ack":true,"ts":1646387867396,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867396}
                      2022-03-04 10:57:47.416 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646387867414,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                      2022-03-04 10:57:47.423 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646387867419,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                      2022-03-04 10:57:47.423 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646387867419,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                      2022-03-04 10:57:47.434 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646387867428,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                      2022-03-04 10:57:47.447 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646387867443,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                      2022-03-04 10:57:47.448 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646387867444,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                      2022-03-04 10:57:47.455 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.27 {"val":"","ack":true,"ts":1646387867450,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113069}
                      2022-03-04 10:57:47.462 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.28 {"val":"","ack":true,"ts":1646387867457,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703822315}
                      2022-03-04 10:57:47.475 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646387867470,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                      2022-03-04 10:57:47.476 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646387867470,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                      2022-03-04 10:57:47.483 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646387867480,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                      2022-03-04 10:57:47.496 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.20 {"val":false,"ack":true,"ts":1646387867492,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867349}
                      2022-03-04 10:57:47.500 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.21 {"val":1,"ack":true,"ts":1646387867496,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867361}
                      2022-03-04 10:57:47.511 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.24 {"val":"007803e803e8","ack":true,"ts":1646387867502,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867365}
                      2022-03-04 10:57:47.512 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.25 {"val":"000e0d0000000000000000c80000","ack":true,"ts":1646387867502,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867367}
                      2022-03-04 10:57:47.530 - info: tuya.0 (24119) 08200118e868e759568a Init with IP=192.168.179.28, Key=f9e4d104d04a30ec, Version=3.3
                      2022-03-04 10:57:47.533 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.26 {"val":0,"ack":true,"ts":1646387867528,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867373}
                      2022-03-04 10:57:47.535 - info: tuya.0 (24119) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
                      2022-03-04 10:57:47.537 - debug: tuya.0 (24119) 08200118e868e759568a: Connected to device
                      2022-03-04 10:57:47.539 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.27 {"val":"","ack":true,"ts":1646387867532,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867387}
                      2022-03-04 10:57:47.543 - info: tuya.0 (24119) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
                      2022-03-04 10:57:47.546 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.42 {"val":"000000016432000003e8007803e800f003e8003c03e800b403e8012c03e8","ack":true,"ts":1646387867541,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867388}
                      2022-03-04 10:57:47.547 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.52 {"val":"","ack":true,"ts":1646387867542,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867396}
                      2022-03-04 10:57:47.547 - info: tuya.0 (24119) 08200118e868e759568a Init with IP=192.168.179.28, Key=f9e4d104d04a30ec, Version=3.3
                      2022-03-04 10:57:47.551 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1646387867543,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867543}
                      2022-03-04 10:57:47.551 - debug: tuya.0 (24119) 08200118e868e759568a: Connected to device
                      2022-03-04 10:57:47.555 - debug: tuya.0 (24119) connected set to true
                      2022-03-04 10:57:47.557 - debug: tuya.0 (24119) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1646387867554,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867554}
                      2022-03-04 10:57:47.559 - debug: tuya.0 (24119) 08200118e868e759568a: Error from device (0): App still open on your mobile phone? Error: Error from socket: read ECONNRESET
                      2022-03-04 10:57:47.560 - debug: tuya.0 (24119) 08200118e868e759568a: Disconnected from device
                      2022-03-04 10:57:47.563 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1646387867562,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867543}
                      2022-03-04 10:57:47.586 - debug: tuya.0 (24119) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"0000000003e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
                      2022-03-04 10:57:47.596 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1646387867590,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867590}
                      2022-03-04 10:57:47.597 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646387867592,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                      2022-03-04 10:57:47.597 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646387867592,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                      2022-03-04 10:57:47.598 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646387867592,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                      2022-03-04 10:57:47.598 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646387867592,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                      2022-03-04 10:57:47.599 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646387867593,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                      2022-03-04 10:57:47.601 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646387867593,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                      2022-03-04 10:57:47.601 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646387867593,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                      2022-03-04 10:57:47.633 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646387867631,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                      2022-03-04 10:57:47.634 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646387867631,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                      2022-03-04 10:57:52.537 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (0): App still open on your mobile phone? Error: connection timed out
                      2022-03-04 10:57:52.538 - error: tuya.0 (24119) bf69b3293c1edff39ffjsi: connection timed out
                      2022-03-04 10:57:52.545 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (1): App still open on your mobile phone? Error: connection timed out
                      2022-03-04 10:57:52.546 - error: tuya.0 (24119) bf69b3293c1edff39ffjsi: connection timed out
                      2022-03-04 10:58:02.153 - debug: tuya.0 (24119) Message: {"command":"stopProxy","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":148,"ack":false,"time":1646387882152},"_id":6825470}
                      2022-03-04 10:58:17.563 - debug: tuya.0 (24119) 08200118e868e759568a: Connected to device
                      2022-03-04 10:58:17.568 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1646387897567,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387897567}
                      2022-03-04 10:58:17.570 - debug: tuya.0 (24119) 08200118e868e759568a: Error from device (0): App still open on your mobile phone? Error: Error from socket: read ECONNRESET
                      2022-03-04 10:58:17.571 - debug: tuya.0 (24119) 08200118e868e759568a: Disconnected from device
                      2022-03-04 10:58:17.576 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1646387897574,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387897574}
                      2022-03-04 10:58:27.548 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (2): App still open on your mobile phone? Error: connection timed out
                      2022-03-04 10:58:27.549 - warn: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error on Reconnectconnection timed out
                      2022-03-04 10:58:28.479 - debug: tuya.0 (24119) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":149,"ack":false,"time":1646387908477},"_id":6825471}
                      2022-03-04 10:58:47.152 - debug: tuya.0 (24119) Message: {"command":"getDeviceInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":150,"ack":false,"time":1646387927150},"_id":6825472}
                      2022-03-04 10:58:47.575 - debug: tuya.0 (24119) 08200118e868e759568a: Connected to device
                      2022-03-04 10:58:47.579 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1646387927578,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387927578}
                      2022-03-04 10:58:47.581 - debug: tuya.0 (24119) 08200118e868e759568a: Error from device (1): App still open on your mobile phone? Error: Error from socket: read ECONNRESET
                      2022-03-04 10:58:47.582 - debug: tuya.0 (24119) 08200118e868e759568a: Disconnected from device
                      2022-03-04 10:58:47.586 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1646387927585,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387927585}
                      2022-03-04 10:59:02.550 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (3): App still open on your mobile phone? Error: connection timed out
                      2022-03-04 10:59:02.550 - warn: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error on Reconnectconnection timed out
                      2022-03-04 10:59:11.393 - debug: tuya.0 (24119) Discovered encrypted device and store for later usage: 192.168.179.53:53813 - 000055aa00000000000000130000009c00000000d09766676f3369eb10b5e9f132fd802a58ef5662b8d5ed0ce59c56875111dfd0db47deeb95d128ee5671c7659fb0f99062752cccf8912dc171de390d8bc81f4159bd59981c26d5958da187e096d937c840b1058c6d8cd9456f3f7e28eed4932bd684776d4d3bbbcc727ed5338dc70040ebe90a09c0e74796dc81a6517ad39c8f8494c932e298de410f638ed8bf10587ab027a3c60000aa55
                      2022-03-04 10:59:11.395 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Try to initialize encrypted device with received UDP messages (#IPs: 1): version=3.3, key=68c09a743f096846
                      2022-03-04 10:59:11.396 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Schema found for b1kede78g4onnhgl: null
                      2022-03-04 10:59:11.397 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Create device objects if not exist
                      2022-03-04 10:59:11.404 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.online {"val":false,"ack":true,"ts":1646387951401,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387790042}
                      2022-03-04 10:59:11.404 - debug: tuya.0 (24119) stateChange tuya.0.bf69b3293c1edff39ffjsi.ip {"val":"192.168.179.53","ack":true,"ts":1646387951401,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387716407}
                      2022-03-04 10:59:11.411 - info: tuya.0 (24119) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
                      2022-03-04 10:59:16.412 - debug: tuya.0 (24119) bf69b3293c1edff39ffjsi: Error from device (0): App still open on your mobile phone? Error: connection timed out
                      2022-03-04 10:59:16.413 - error: tuya.0 (24119) bf69b3293c1edff39ffjsi: connection timed out
                      2022-03-04 10:59:17.586 - debug: tuya.0 (24119) 08200118e868e759568a: Connected to device
                      2022-03-04 10:59:17.590 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1646387957588,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387957588}
                      2022-03-04 10:59:17.594 - debug: tuya.0 (24119) 08200118e868e759568a: Error from device (2): App still open on your mobile phone? Error: Error from socket: read ECONNRESET
                      2022-03-04 10:59:17.596 - debug: tuya.0 (24119) 08200118e868e759568a: Disconnected from device
                      2022-03-04 10:59:17.601 - debug: tuya.0 (24119) stateChange tuya.0.08200118e868e759568a.online {"val":false,"ack":true,"ts":1646387957598,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387957598}
                      2022-03-04 10:59:21.982 - info: tuya.0 (24119) Got terminate signal TERMINATE_YOURSELF
                      2022-03-04 10:59:21.988 - debug: tuya.0 (24119) connected set to false
                      2022-03-04 10:59:24.985 - info: tuya.0 (24119) terminating
                      2022-03-04 10:59:24.986 - debug: tuya.0 (24119) Plugin sentry destroyed
                      2022-03-04 10:59:24.986 - info: tuya.0 (24119) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2022-03-04 10:59:31.098 - debug: tuya.0 (24349) Redis Objects: Use Redis connection: iobroker-master:9001
                      2022-03-04 10:59:31.148 - debug: tuya.0 (24349) Objects client ready ... initialize now
                      2022-03-04 10:59:31.150 - debug: tuya.0 (24349) Objects create System PubSub Client
                      2022-03-04 10:59:31.152 - debug: tuya.0 (24349) Objects create User PubSub Client
                      2022-03-04 10:59:31.195 - debug: tuya.0 (24349) Objects client initialize lua scripts
                      2022-03-04 10:59:31.203 - debug: tuya.0 (24349) Objects connected to redis: iobroker-master:9001
                      2022-03-04 10:59:31.236 - debug: tuya.0 (24349) Redis States: Use Redis connection: redis:6379
                      2022-03-04 10:59:31.246 - debug: tuya.0 (24349) States create System PubSub Client
                      2022-03-04 10:59:31.247 - debug: tuya.0 (24349) States create User PubSub Client
                      2022-03-04 10:59:31.261 - debug: tuya.0 (24349) States connected to redis: redis:6379
                      2022-03-04 10:59:31.293 - debug: tuya.0 (24349) Plugin sentry Initialize Plugin (enabled=true)
                      2022-03-04 10:59:31.298 - info: tuya.0 (24349) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      2022-03-04 10:59:31.444 - info: tuya.0 (24349) starting. Version 3.6.15 in /opt/iobroker/node_modules/iobroker.tuya, node: v14.19.0, js-controller: 4.0.15
                      2022-03-04 10:59:31.499 - debug: tuya.0 (24349) connected set to false
                      2022-03-04 10:59:31.506 - debug: tuya.0 (24349) init 2 known devices
                      2022-03-04 10:59:31.510 - debug: tuya.0 (24349) 08200118e868e759568a: Create device objects if not exist
                      2022-03-04 10:59:31.512 - debug: tuya.0 (24349) 08200118e868e759568a: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music","4":"smooth","5":"flash"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"number","min":10,"max":1000,"read":true,"write":true,"name":"bright_value","id":22,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"mic_sense","id":101,"role":"level"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"change_speed","id":102,"role":"level"},{"type":"number","states":{"0":"soft","1":"classic","2":"rock"},"read":true,"write":true,"name":"music_type","id":106,"role":"level"}]
                      2022-03-04 10:59:31.514 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 20
                      2022-03-04 10:59:31.515 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 21
                      2022-03-04 10:59:31.516 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 22
                      2022-03-04 10:59:31.516 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 24
                      2022-03-04 10:59:31.517 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 25
                      2022-03-04 10:59:31.518 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 26
                      2022-03-04 10:59:31.518 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 27
                      2022-03-04 10:59:31.519 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 28
                      2022-03-04 10:59:31.519 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 101
                      2022-03-04 10:59:31.520 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 102
                      2022-03-04 10:59:31.520 - debug: tuya.0 (24349) 08200118e868e759568a Register onChange for 106
                      2022-03-04 10:59:31.522 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi: Create device objects if not exist
                      2022-03-04 10:59:31.524 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"mic_music_data","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"dreamlightmic_music_data","id":52,"role":"text"}]
                      2022-03-04 10:59:31.524 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi Register onChange for 20
                      2022-03-04 10:59:31.525 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi Register onChange for 21
                      2022-03-04 10:59:31.526 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi Register onChange for 24
                      2022-03-04 10:59:31.526 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi Register onChange for 25
                      2022-03-04 10:59:31.527 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi Register onChange for 26
                      2022-03-04 10:59:31.527 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi Register onChange for 27
                      2022-03-04 10:59:31.528 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi Register onChange for 42
                      2022-03-04 10:59:31.528 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi Register onChange for 52
                      2022-03-04 10:59:31.666 - info: tuya.0 (24349) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
                      2022-03-04 10:59:31.713 - info: tuya.0 (24349) 08200118e868e759568a Init with IP=192.168.179.28, Key=f9e4d104d04a30ec, Version=3.3
                      2022-03-04 10:59:31.714 - info: tuya.0 (24349) Existing devices initialized
                      2022-03-04 10:59:31.719 - info: tuya.0 (24349) Listen for local Tuya devices on port 6666
                      2022-03-04 10:59:31.720 - info: tuya.0 (24349) Listen for encrypted local Tuya devices on port 6667
                      2022-03-04 10:59:31.792 - debug: tuya.0 (24349) 08200118e868e759568a: Connected to device
                      2022-03-04 10:59:31.806 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1646387971802,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387971802}
                      2022-03-04 10:59:31.807 - debug: tuya.0 (24349) stateChange tuya.0.info.connection {"val":true,"ack":true,"ts":1646387971802,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387971802}
                      2022-03-04 10:59:31.807 - debug: tuya.0 (24349) connected set to true
                      2022-03-04 10:59:31.836 - debug: tuya.0 (24349) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"0000000003e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
                      2022-03-04 10:59:31.852 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646387971843,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                      2022-03-04 10:59:31.853 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646387971843,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                      2022-03-04 10:59:31.854 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646387971843,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                      2022-03-04 10:59:31.854 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646387971844,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                      2022-03-04 10:59:31.855 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646387971844,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                      2022-03-04 10:59:31.855 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646387971844,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                      2022-03-04 10:59:31.856 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646387971844,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                      2022-03-04 10:59:31.856 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646387971846,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                      2022-03-04 10:59:31.857 - debug: tuya.0 (24349) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646387971846,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                      2022-03-04 10:59:32.397 - debug: tuya.0 (24349) Discovered encrypted device and store for later usage: 192.168.179.53:53813 - 000055aa00000000000000130000009c00000000d09766676f3369eb10b5e9f132fd802a58ef5662b8d5ed0ce59c56875111dfd0db47deeb95d128ee5671c7659fb0f99062752cccf8912dc171de390d8bc81f4159bd59981c26d5958da187e096d937c840b1058c6d8cd9456f3f7e28eed4932bd684776d4d3bbbcc727ed5338dc70040ebe90a09c0e74796dc81a6517ad39c8f8494c932e298de410f638ed8bf10587ab027a3c60000aa55
                      2022-03-04 10:59:36.672 - debug: tuya.0 (24349) bf69b3293c1edff39ffjsi: Error from device (0): App still open on your mobile phone? Error: connection timed out
                      2022-03-04 10:59:36.673 - error: tuya.0 (24349) bf69b3293c1edff39ffjsi: connection timed out
                      Das scheinbar die App nicht mehr tut weiss ich und ich arbeite wie Zeit ist an einer anderen Lösung.
                      Ok. Dachte es gibt vielleicht einen Zusammenhang ;-)
                      @kla960 sagte in Tuya rgb LED Strip will nicht:
                      Das ist das issue ... Der Adapter versucht eine verbindung zu der IP herzustellen und bekommt keine Antwort.
                      • apollon77A apollon77
                        kla960
                        @apollon77
                        Liegt das dann am Device? IP ist die Richtige. Im Netzwerk Trace sehe ich auch Kommunikation zwischen Device und ioBroker.
                        • K kla960
                          @apollon77
                          @kla960 haste es mal versucht zu restarten (Strom weg/hin?)
                            kla960
                            @apollon77
                            Ja, ohne Verbesserung.
                            • K kla960
                              @apollon77
                              @kla960 Dann ehrlich keine Anhnung ... vllt haben Sie echt Geräte gestartet die lokal nichts mehr anbieten als Port?
                                kla960
                                schrieb am zuletzt editiert von kla960
                                @apollon77
                                irgendwie doch. für kurze Zeit war das Ding verbunden. Konnte sogar ein und ausschalten über den ioBroker. Leider war die Verbindung nicht von dauer :(
                                Hier das log. relevant sind die Einträge für tuya.0.bf69b3293c1edff39ffjsi
                                2022-03-04 15:12:50.936 - info: tuya.0 (24349) terminating
                                2022-03-04 15:12:50.937 - debug: tuya.0 (24349) Plugin sentry destroyed
                                2022-03-04 15:12:50.938 - info: tuya.0 (24349) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2022-03-04 15:12:57.008 - debug: tuya.0 (6082) Redis Objects: Use Redis connection: iobroker-master:9001
                                2022-03-04 15:12:57.057 - debug: tuya.0 (6082) Objects client ready ... initialize now
                                2022-03-04 15:12:57.059 - debug: tuya.0 (6082) Objects create System PubSub Client
                                2022-03-04 15:12:57.061 - debug: tuya.0 (6082) Objects create User PubSub Client
                                2022-03-04 15:12:57.101 - debug: tuya.0 (6082) Objects client initialize lua scripts
                                2022-03-04 15:12:57.109 - debug: tuya.0 (6082) Objects connected to redis: iobroker-master:9001
                                2022-03-04 15:12:57.140 - debug: tuya.0 (6082) Redis States: Use Redis connection: redis:6379
                                2022-03-04 15:12:57.149 - debug: tuya.0 (6082) States create System PubSub Client
                                2022-03-04 15:12:57.151 - debug: tuya.0 (6082) States create User PubSub Client
                                2022-03-04 15:12:57.164 - debug: tuya.0 (6082) States connected to redis: redis:6379
                                2022-03-04 15:12:57.205 - debug: tuya.0 (6082) Plugin sentry Initialize Plugin (enabled=true)
                                2022-03-04 15:12:57.210 - info: tuya.0 (6082) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                2022-03-04 15:12:57.360 - info: tuya.0 (6082) starting. Version 3.6.15 in /opt/iobroker/node_modules/iobroker.tuya, node: v14.19.0, js-controller: 4.0.15
                                2022-03-04 15:12:57.416 - debug: tuya.0 (6082) connected set to false
                                2022-03-04 15:12:57.424 - debug: tuya.0 (6082) init 2 known devices
                                2022-03-04 15:12:57.428 - debug: tuya.0 (6082) 08200118e868e759568a: Create device objects if not exist
                                2022-03-04 15:12:57.431 - debug: tuya.0 (6082) 08200118e868e759568a: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music","4":"smooth","5":"flash"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"number","min":10,"max":1000,"read":true,"write":true,"name":"bright_value","id":22,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"control_data","id":28,"role":"text"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"mic_sense","id":101,"role":"level"},{"type":"number","min":1,"max":100,"read":true,"write":true,"name":"change_speed","id":102,"role":"level"},{"type":"number","states":{"0":"soft","1":"classic","2":"rock"},"read":true,"write":true,"name":"music_type","id":106,"role":"level"}]
                                2022-03-04 15:12:57.433 - debug: tuya.0 (6082) 08200118e868e759568a Register onChange for 20
                                2022-03-04 15:12:57.434 - debug: tuya.0 (6082) 08200118e868e759568a Register onChange for 21
                                2022-03-04 15:12:57.434 - debug: tuya.0 (6082) 08200118e868e759568a Register onChange for 22
                                2022-03-04 15:12:57.435 - debug: tuya.0 (6082) 08200118e868e759568a Register onChange for 24
                                2022-03-04 15:12:57.436 - debug: tuya.0 (6082) 08200118e868e759568a Register onChange for 25
                                2022-03-04 15:12:57.436 - debug: tuya.0 (6082) 08200118e868e759568a Register onChange for 26
                                2022-03-04 15:12:57.437 - debug: tuya.0 (6082) 08200118e868e759568a Register onChange for 27
                                2022-03-04 15:12:57.437 - debug: tuya.0 (6082) 08200118e868e759568a Register onChange for 28
                                2022-03-04 15:12:57.438 - debug: tuya.0 (6082) 08200118e868e759568a Register onChange for 101
                                2022-03-04 15:12:57.438 - debug: tuya.0 (6082) 08200118e868e759568a Register onChange for 102
                                2022-03-04 15:12:57.439 - debug: tuya.0 (6082) 08200118e868e759568a Register onChange for 106
                                2022-03-04 15:12:57.441 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi: Create device objects if not exist
                                2022-03-04 15:12:57.443 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi: Objects [{"type":"boolean","read":true,"write":true,"name":"switch_led","id":20,"role":"switch"},{"type":"number","states":{"0":"white","1":"colour","2":"scene","3":"music"},"read":true,"write":true,"name":"work_mode","id":21,"role":"level"},{"type":"string","read":true,"write":true,"name":"colour_data","id":24,"role":"text"},{"type":"string","read":true,"write":true,"name":"scene_data","id":25,"role":"text"},{"type":"number","max":86400,"read":true,"write":true,"name":"countdown","id":26,"role":"level"},{"type":"string","read":true,"write":true,"name":"music_data","id":27,"role":"text"},{"type":"string","read":true,"write":true,"name":"mic_music_data","id":42,"role":"text"},{"type":"string","read":true,"write":true,"name":"dreamlightmic_music_data","id":52,"role":"text"}]
                                2022-03-04 15:12:57.443 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi Register onChange for 20
                                2022-03-04 15:12:57.444 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi Register onChange for 21
                                2022-03-04 15:12:57.445 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi Register onChange for 24
                                2022-03-04 15:12:57.445 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi Register onChange for 25
                                2022-03-04 15:12:57.446 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi Register onChange for 26
                                2022-03-04 15:12:57.446 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi Register onChange for 27
                                2022-03-04 15:12:57.447 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi Register onChange for 42
                                2022-03-04 15:12:57.447 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi Register onChange for 52
                                2022-03-04 15:12:57.591 - info: tuya.0 (6082) bf69b3293c1edff39ffjsi Init with IP=192.168.179.53, Key=68c09a743f096846, Version=3.3
                                2022-03-04 15:12:57.602 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi: Connected to device
                                2022-03-04 15:12:57.615 - debug: tuya.0 (6082) connected set to true
                                2022-03-04 15:12:57.624 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi: Received data: {"20":false,"21":"colour","24":"007803e803e8","25":"000e0d0000000000000000c80000","26":0,"42":"000000016432000003e8007803e800f003e8003c03e800b403e8012c03e8"}
                                2022-03-04 15:12:57.674 - info: tuya.0 (6082) 08200118e868e759568a Init with IP=192.168.179.28, Key=f9e4d104d04a30ec, Version=3.3
                                2022-03-04 15:12:57.676 - info: tuya.0 (6082) Existing devices initialized
                                2022-03-04 15:12:57.681 - info: tuya.0 (6082) Listen for local Tuya devices on port 6666
                                2022-03-04 15:12:57.682 - info: tuya.0 (6082) Listen for encrypted local Tuya devices on port 6667
                                2022-03-04 15:12:57.766 - debug: tuya.0 (6082) 08200118e868e759568a: Connected to device
                                2022-03-04 15:12:57.773 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.online {"val":true,"ack":true,"ts":1646403177770,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646403177770}
                                2022-03-04 15:12:57.805 - debug: tuya.0 (6082) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"0000000003e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
                                2022-03-04 15:12:57.821 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646403177811,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                                2022-03-04 15:12:57.822 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646403177811,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                                2022-03-04 15:12:57.823 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646403177814,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                                2022-03-04 15:12:57.823 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646403177814,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                                2022-03-04 15:12:57.824 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646403177814,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                                2022-03-04 15:12:57.825 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646403177814,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                                2022-03-04 15:12:57.825 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646403177815,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                                2022-03-04 15:12:57.828 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646403177815,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                                2022-03-04 15:12:57.855 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646403177853,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                                2022-03-04 15:13:06.250 - debug: tuya.0 (6082) Discovered encrypted device and store for later usage: 192.168.179.53:53813 - 000055aa00000000000000130000009c00000000d09766676f3369eb10b5e9f132fd802a58ef5662b8d5ed0ce59c56875111dfd0db47deeb95d128ee5671c7659fb0f99062752cccf8912dc171de390d8bc81f4159bd59981c26d5958da187e096d937c840b1058c6d8cd9456f3f7e28eed4932bd684776d4d3bbbcc727ed5338dc70040ebe90a09c0e74796dc81a6517ad39c8f8494c932e298de410f638ed8bf10587ab027a3c60000aa55
                                2022-03-04 15:13:57.626 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi request data via get ...
                                2022-03-04 15:13:57.644 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi: Received data: {"20":false,"21":"colour","24":"007803e803e8","25":"000e0d0000000000000000c80000","26":0,"42":"000000016432000003e8007803e800f003e8003c03e800b403e8012c03e8"}
                                2022-03-04 15:13:57.657 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.20 {"val":false,"ack":true,"ts":1646403237649,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867349}
                                2022-03-04 15:13:57.658 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.21 {"val":1,"ack":true,"ts":1646403237649,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867361}
                                2022-03-04 15:13:57.658 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.24 {"val":"007803e803e8","ack":true,"ts":1646403237649,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867365}
                                2022-03-04 15:13:57.659 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.25 {"val":"000e0d0000000000000000c80000","ack":true,"ts":1646403237651,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867367}
                                2022-03-04 15:13:57.660 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.26 {"val":0,"ack":true,"ts":1646403237652,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867373}
                                2022-03-04 15:13:57.662 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.42 {"val":"000000016432000003e8007803e800f003e8003c03e800b403e8012c03e8","ack":true,"ts":1646403237652,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867388}
                                2022-03-04 15:13:57.807 - debug: tuya.0 (6082) 08200118e868e759568a request data via get ...
                                2022-03-04 15:13:57.885 - debug: tuya.0 (6082) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"0000000003e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
                                2022-03-04 15:13:57.901 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646403237890,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                                2022-03-04 15:13:57.902 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646403237890,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                                2022-03-04 15:13:57.903 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646403237890,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                                2022-03-04 15:13:57.904 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646403237892,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                                2022-03-04 15:13:57.905 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646403237893,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                                2022-03-04 15:13:57.906 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646403237894,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                                2022-03-04 15:13:57.911 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646403237896,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                                2022-03-04 15:13:57.912 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646403237896,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                                2022-03-04 15:13:57.912 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646403237896,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                                2022-03-04 15:14:29.417 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.20 {"val":true,"ack":false,"ts":1646403269415,"q":0,"from":"system.adapter.admin.0","user":"system.user.Klaus","lc":1646403269415}
                                2022-03-04 15:14:29.418 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi onChange triggered for 20 and value true
                                2022-03-04 15:14:29.471 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi: Received data: {"20":true,"26":0}
                                2022-03-04 15:14:29.472 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi.20: set value true via bf69b3293c1edff39ffjsi
                                2022-03-04 15:14:29.476 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi: Received data: {"20":true,"26":0}
                                2022-03-04 15:14:29.483 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.20 {"val":true,"ack":true,"ts":1646403269477,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646403269415}
                                2022-03-04 15:14:29.483 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.26 {"val":0,"ack":true,"ts":1646403269477,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867373}
                                2022-03-04 15:14:29.487 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.20 {"val":true,"ack":true,"ts":1646403269482,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646403269415}
                                2022-03-04 15:14:29.488 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.26 {"val":0,"ack":true,"ts":1646403269482,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867373}
                                2022-03-04 15:14:57.479 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.20 {"val":false,"ack":false,"ts":1646403297477,"q":0,"from":"system.adapter.admin.0","user":"system.user.Klaus","lc":1646403297477}
                                2022-03-04 15:14:57.480 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi onChange triggered for 20 and value false
                                2022-03-04 15:14:57.530 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi: Received data: {"20":false,"26":0}
                                2022-03-04 15:14:57.531 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi.20: set value false via bf69b3293c1edff39ffjsi
                                2022-03-04 15:14:57.538 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.20 {"val":false,"ack":true,"ts":1646403297535,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646403297477}
                                2022-03-04 15:14:57.540 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.26 {"val":0,"ack":true,"ts":1646403297535,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867373}
                                2022-03-04 15:14:57.541 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi: Received data: {"20":false,"26":0}
                                2022-03-04 15:14:57.549 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.20 {"val":false,"ack":true,"ts":1646403297545,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646403297477}
                                2022-03-04 15:14:57.551 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.26 {"val":0,"ack":true,"ts":1646403297547,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867373}
                                2022-03-04 15:14:57.887 - debug: tuya.0 (6082) 08200118e868e759568a request data via get ...
                                2022-03-04 15:14:57.925 - debug: tuya.0 (6082) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"0000000003e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
                                2022-03-04 15:14:57.953 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646403297933,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                                2022-03-04 15:14:57.954 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646403297933,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                                2022-03-04 15:14:57.954 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646403297933,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                                2022-03-04 15:14:57.955 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646403297933,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                                2022-03-04 15:14:57.955 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646403297935,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                                2022-03-04 15:14:57.956 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646403297936,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                                2022-03-04 15:14:57.956 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646403297936,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                                2022-03-04 15:14:57.957 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646403297937,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                                2022-03-04 15:14:57.957 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646403297940,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                                2022-03-04 15:15:57.542 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi request data via get ...
                                2022-03-04 15:15:57.558 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi: Received data: {"20":false,"21":"colour","24":"007803e803e8","25":"000e0d0000000000000000c80000","26":0,"42":"000000016432000003e8007803e800f003e8003c03e800b403e8012c03e8"}
                                2022-03-04 15:15:57.566 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.20 {"val":false,"ack":true,"ts":1646403357561,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646403297477}
                                2022-03-04 15:15:57.567 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.21 {"val":1,"ack":true,"ts":1646403357563,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867361}
                                2022-03-04 15:15:57.571 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.24 {"val":"007803e803e8","ack":true,"ts":1646403357564,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867365}
                                2022-03-04 15:15:57.571 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.25 {"val":"000e0d0000000000000000c80000","ack":true,"ts":1646403357564,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867367}
                                2022-03-04 15:15:57.572 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.26 {"val":0,"ack":true,"ts":1646403357564,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867373}
                                2022-03-04 15:15:57.573 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.42 {"val":"000000016432000003e8007803e800f003e8003c03e800b403e8012c03e8","ack":true,"ts":1646403357564,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646387867388}
                                2022-03-04 15:15:57.927 - debug: tuya.0 (6082) 08200118e868e759568a request data via get ...
                                2022-03-04 15:15:57.964 - debug: tuya.0 (6082) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"0000000003e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
                                2022-03-04 15:15:57.977 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646403357971,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                                2022-03-04 15:15:57.978 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646403357971,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                                2022-03-04 15:15:57.979 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646403357971,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                                2022-03-04 15:15:57.980 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646403357973,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                                2022-03-04 15:15:57.982 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646403357974,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                                2022-03-04 15:15:57.983 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646403357974,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                                2022-03-04 15:15:57.983 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646403357974,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                                2022-03-04 15:15:57.984 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646403357974,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                                2022-03-04 15:15:58.013 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646403358011,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                                2022-03-04 15:16:09.606 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi: Disconnected from device
                                2022-03-04 15:16:09.611 - debug: tuya.0 (6082) stateChange tuya.0.bf69b3293c1edff39ffjsi.online {"val":false,"ack":true,"ts":1646403369609,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646403369609}
                                2022-03-04 15:16:44.608 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi: Error from device (0): App still open on your mobile phone? Error: connection timed out
                                2022-03-04 15:16:44.609 - warn: tuya.0 (6082) bf69b3293c1edff39ffjsi: Error on Reconnectconnection timed out
                                2022-03-04 15:16:57.966 - debug: tuya.0 (6082) 08200118e868e759568a request data via get ...
                                2022-03-04 15:16:58.014 - debug: tuya.0 (6082) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"0000000003e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
                                2022-03-04 15:16:58.029 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646403418019,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                                2022-03-04 15:16:58.029 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646403418019,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                                2022-03-04 15:16:58.030 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646403418019,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                                2022-03-04 15:16:58.030 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646403418022,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                                2022-03-04 15:16:58.031 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646403418022,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                                2022-03-04 15:16:58.031 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646403418022,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                                2022-03-04 15:16:58.032 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646403418022,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                                2022-03-04 15:16:58.032 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646403418023,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                                2022-03-04 15:16:58.035 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646403418024,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                                2022-03-04 15:17:19.610 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi: Error from device (1): App still open on your mobile phone? Error: connection timed out
                                2022-03-04 15:17:19.612 - warn: tuya.0 (6082) bf69b3293c1edff39ffjsi: Error on Reconnectconnection timed out
                                2022-03-04 15:17:54.614 - debug: tuya.0 (6082) bf69b3293c1edff39ffjsi: Error from device (2): App still open on your mobile phone? Error: connection timed out
                                2022-03-04 15:17:54.615 - warn: tuya.0 (6082) bf69b3293c1edff39ffjsi: Error on Reconnectconnection timed out
                                2022-03-04 15:17:58.016 - debug: tuya.0 (6082) 08200118e868e759568a request data via get ...
                                2022-03-04 15:17:58.095 - debug: tuya.0 (6082) 08200118e868e759568a: Received data: {"20":false,"21":"colour","22":1000,"24":"0000000003e8","25":"00000a00000003e803e800000000","26":0,"101":95,"102":60,"106":"soft"}
                                2022-03-04 15:17:58.113 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.20 {"val":false,"ack":true,"ts":1646403478103,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646373208416}
                                2022-03-04 15:17:58.113 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.21 {"val":1,"ack":true,"ts":1646403478103,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645709446161}
                                2022-03-04 15:17:58.114 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.22 {"val":1000,"ack":true,"ts":1646403478103,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645704489672}
                                2022-03-04 15:17:58.114 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.24 {"val":"0000000003e8","ack":true,"ts":1646403478103,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1646372238440}
                                2022-03-04 15:17:58.116 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.25 {"val":"00000a00000003e803e800000000","ack":true,"ts":1646403478103,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529400234}
                                2022-03-04 15:17:58.116 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.26 {"val":0,"ack":true,"ts":1646403478105,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113063}
                                2022-03-04 15:17:58.117 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.101 {"val":95,"ack":true,"ts":1646403478106,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645527113087}
                                2022-03-04 15:17:58.120 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.102 {"val":60,"ack":true,"ts":1646403478106,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645703889410}
                                2022-03-04 15:17:58.121 - debug: tuya.0 (6082) stateChange tuya.0.08200118e868e759568a.106 {"val":0,"ack":true,"ts":1646403478107,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1645529365339}
                                • K kla960
                                  @apollon77
                                  @kla960 Tja ... und wirklich KEINE Tuya App irgendwo noch offen oder im Hintergrund?
                                    kla960
                                    @apollon77
                                    definitiv nicht.
                                    Danke jedenfalls erst mal.
                                    • K kla960
                                      @apollon77
                                      Hi, hast du mal zeit drauf zu schauen? Wenn du noch logs benötigst. Kein Problem!
                                      @oFbEQnpoLKKl6mbY5e13
                                      Einen Github Account habe ich leider nicht.
                                      O Offline
                                      O Offline
                                      Erledigt:
                                      https://github.com/Apollon77/ioBroker.tuya/issues/393
                                      • K kla960
                                        @apollon77
                                        Gehe auf https://github.com, klicke oben rechte auf "Sign up", Email und Passwort angeben, fertig. Dann hast Du einen Account und kannst an der ioBroker Community teilnehmen ;-)
                                        @oFbEQnpoLKKl6mbY5e13 Danke!
                                          kla960
                                          @apollon77 sagte in Tuya rgb LED Strip will nicht:
                                          Wenn ich nochmal was habe, werde ich das machen ;-)
                                          Würde dir ein Netzwerktrace helfen, dass Problem zu finden?
                                          @oFbEQnpoLKKl6mbY5e13 Meinerseits auch Danke 👍
