  4. Hue 0.6.3 Error
    5.7k
Hue 0.6.3 Error
27 Beiträge 8 Kommentatoren 3.9k Aufrufe
  • BluefoxB Offline
    BluefoxB Offline
    Muss ich abends mal schauen.
    • BluefoxB Offline
      BluefoxB Offline
      Bitte neue 0.6.4 Version ausprobieren.
        simpixo
        @Bluefox:
        Bitte neue 0.6.4 Version ausprobieren. `
        Hallo Bluefox….
        Ich habe das Update installiert leider bekomme ich jetzt einen anderen Fehler mit der Version 0.6.0 funktioniert alles
        hue.0	2017-04-20 07:58:55.843	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
        hue.0	2017-04-20 07:58:55.843	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
        hue.0	2017-04-20 07:58:55.843	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
        hue.0	2017-04-20 07:58:55.843	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
        hue.0	2017-04-20 07:58:55.843	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
        hue.0	2017-04-20 07:58:55.843	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
        hue.0	2017-04-20 07:58:55.843	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
        hue.0	2017-04-20 07:58:55.843	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
        hue.0	2017-04-20 07:58:55.843	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
        hue.0	2017-04-20 07:58:55.843	error	at Socket. (/opt/iobroker/node_modules/iobroker.hue/hue.js:182:32)
        hue.0	2017-04-20 07:58:55.843	error	TypeError: ls.xy.split is not a function
        hue.0	2017-04-20 07:58:55.842	error	uncaught exception: ls.xy.split is not a function
        • lobomauL Offline
          lobomauL Offline
          lobomau
          @simpixo:
          @Bluefox:
          Hallo Bluefox….
          Bei mir sieht es auch so aus.
          Danach alle ca. 15sec.:
          host.brix-3150	2017-04-20 08:11:03.224	error	instance system.adapter.hue.0 terminated with code 0 (OK)
          hue.0	2017-04-20 08:11:02.723	error	TypeError: ls.xy.split is not a function at Socket. (/opt/iobroker/node_modules/iobroker.hue/hue.js:182:32) at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_m
          hue.0	2017-04-20 08:11:02.722	error	uncaught exception: ls.xy.split is not a function
          Host: NUC8i3 mit Proxmox:
          • Slave: Pi4
          • BluefoxB Offline
            BluefoxB Offline
            @lobomau:
            @simpixo:
            @Bluefox:
            Hallo Bluefox….
            Was schreibt ihr denn in xy?
            Es gibt neue Version aber ich bezweifle, dass es in 0.6.0 ging.
            • lobomauL Offline
              lobomauL Offline
              lobomau
              @Bluefox:
              @lobomau:
              @simpixo:
              Hallo Bluefox….
              Es gibt neue Version aber ich bezweifle, dass es in 0.6.0 ging. `
              Jetzt gibt es nur noch zwei Warnungen. Ich habe nur den Adapter aktualisiert und gestartet, steuere nix aktiv. Ich weiß nicht wofür xy ist, wahrscheinlich Farbe.
              hue.0	2017-04-20 09:15:07.365	warn	Invalid xy value: "0.6201,0.3619"
              hue.0	2017-04-20 09:15:07.245	warn	Invalid xy value: "0.7407,0.2572"
              EDIT: Warnung kam nur einmal beim Updaten. Jetzt beim SChalten nichts mehr. Szenen habe ich noch nicht probiert.
              • Slave: Pi4
              • C Offline
                CyberMicha
                Werden die Räume/Gruppen nun auch aktualisiert beim Polling?
                Hatte den Fehler gerade eben auch einmal. Scheint eben bei Gruppen / Räumen zu entstehen
                  Semenchkare
                  ich habe heute die 0.6.4 draufgespielt.
                  Irgendwann stellte ich fest, dass die Schlafzimmerlampe ohne entsprechende Steuerung eingeschaltet ist. Ein ausschalten bewirkte, dass nach ca. 10-20 Sekunden ein erneutes einschalten erfolgt.
                  Ca. 2 Stunden habe ich nach den Ursachen gesucht. Erst ein Deaktivieren des Adapters hat den Fehler behoben. Ich habe mal unter Adapter nachgesehen:
                  Ich habe den Adapter zwar aktiviert (grün), aber die Ausführen-Ampel steht auf rot.
                  die 0.64 ist die für mich am unbrauchbarsten!
                  LG
                  Seme
                  PS: Firmware Hue habe ich zwar heute abend ebenso aktualisiert. Aber der Einschalt-Fehler war jedenfalls vorher da!
                  Viele Grüße
                  Semenchkare
                  raspberry 5 8GB mit iobroker,
                  raspberry 5 8GB mit Raspberrymatic
                  • lobomauL Offline
                    lobomauL Offline
                    lobomau
                    0.6.5. läuft scheinbar ohne Probleme. Mal weiter beobachten….
                    • Slave: Pi4
                    • BluefoxB Offline
                      BluefoxB Offline
                      @Semenchkare:
                      LG
                      Seme
                      PS: Firmware Hue habe ich zwar heute abend ebenso aktualisiert. Aber der Einschalt-Fehler war jedenfalls vorher da! `
                      Log eingeschaltet und geschaut woher die Meldung kommt?
                      Sei bitte konstruktiv und versuche mehr Info zu bringen.
                        Semenchkare
                        OK. jetzt ist ja die 0.6.6 draussen, die logs von vorhin habe ich nicht mehr.
                        Bei der 0.6.6 fällt mir noch auf, dass beim Neustart des Adapters oder vom gesamten IOBroker immer alle Lampen eingeschaltet werden…
                        Jetzt nervt das zwar nicht mehr so wie zuvor, als nach manuellem ausschalten einige Sekunden später wieder alles automatisch angeschaltet wird.
                        Hier mal der Log nach einem Neustart:
                        ` > hue.0 2017-04-21 15:12:54.080 info final lightState for Philips_hue_1.Nachtischlampe_Yasmin:{"bri":0,"on":false,"level":0}
                        hue.0 2017-04-21 15:12:53.244 info final lightState for Philips_hue_1.Nachtischlampe_Wand:{"bri":0,"on":false,"level":0}
                        hue.0 2017-04-21 15:12:52.688 info final lightState for Philips_hue_1.Nachtischlampe_Justin:{"bri":0,"on":false,"level":0}
                        hue.0 2017-04-21 15:09:09.271 info final lightState for Philips_hue_1.Nachtischlampe_Fenster:{"bri":0,"on":false,"level":0}
                        hue.0 2017-04-21 15:09:06.951 info final lightState for Philips_hue_1.Tischlampe:{"bri":0,"on":false,"level":0}
                        fritzdect.0 2017-04-21 15:09:01.267 info setting up thermostat object 109710175648
                        fritzdect.0 2017-04-21 15:09:01.261 info Comet AIDs: 109710175648
                        fritzdect.0 2017-04-21 15:09:00.905 info setting up switch object 116570032151
                        fritzdect.0 2017-04-21 15:09:00.900 info setting up switch object 087610156430
                        fritzdect.0 2017-04-21 15:09:00.895 info setting up switch object 087610122890
                        fritzdect.0 2017-04-21 15:09:00.891 info setting up switch object 087610141954
                        fritzdect.0 2017-04-21 15:09:00.886 info setting up switch object 087610078659
                        fritzdect.0 2017-04-21 15:09:00.879 info setting up switch object 087610042159
                        fritzdect.0 2017-04-21 15:09:00.838 info setting up switch object 24:65:11:C3:DD:FB
                        fritzdect.0 2017-04-21 15:09:00.831 info Switches AIDs: 24:65:11:C3:DD:FB,087610042159,087610078659,087610141954,087610122890,087610156430,116570032151
                        hue.0 2017-04-21 15:08:59.786 info final lightState for Philips_hue_1.hgrp-0000000062:{"bri":254,"on":true,"xy":"0.641,0.3332","r":254,"g":91,"b":39,"colormode":"xy","level":100}
                        hue.0 2017-04-21 15:08:59.466 info final lightState for Philips_hue_1.Custom_group_for_$group:{"bri":254,"on":true,"xy":"0.641,0.3332","r":254,"g":91,"b":39,"colormode":"xy","level":100}
                        hue.0 2017-04-21 15:08:59.246 info final lightState for Philips_hue_1.HueHalloweenActiveLightsGroup:{"bri":254,"on":true,"xy":"0.641,0.3332","r":254,"g":91,"b":39,"colormode":"xy","level":100}
                        hue.0 2017-04-21 15:08:58.980 info final lightState for Philips_hue_1.thunderAGroupOdd:{"bri":254,"on":true,"xy":"0.641,0.3332","r":254,"g":91,"b":39,"colormode":"xy","level":100}
                        hue.0 2017-04-21 15:08:58.682 info final lightState for Philips_hue_1.thunderAGroup:{"bri":254,"on":true,"xy":"0.641,0.3332","r":254,"g":91,"b":39,"colormode":"xy","level":100}
                        hue.0 2017-04-21 15:08:58.420 info final lightState for Philips_hue_1.Wohnzimmer:{"bri":254,"on":true,"xy":"0.641,0.3332","r":254,"g":91,"b":39,"colormode":"xy","level":100}
                        fritzdect.0 2017-04-21 15:08:58.289 info polling! fritzdect is alive
                        fritzdect.0 2017-04-21 15:08:58.206 info entered ready
                        fritzdect.0 2017-04-21 15:08:58.173 info starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v4.5.0
                        hue.0 2017-04-21 15:08:58.186 info final lightState for Philips_hue_1.Schlafzimmer:{"bri":32,"on":true,"xy":"0.4574,0.41","r":116,"g":93,"b":51,"colormode":"xy","level":13}
                        hue.0 2017-04-21 15:08:57.666 info final lightState for Philips_hue_1.Nachtischlampe_Fenster:{"bri":32,"on":true,"xy":"0.4574,0.41","r":116,"g":93,"b":51,"colormode":"xy","level":13}
                        hue.0 2017-04-21 15:08:57.032 info final lightState for Philips_hue_1.Tischlampe:{"bri":254,"on":true,"xy":"0.641,0.3332","r":254,"g":91,"b":39,"colormode":"xy","level":100}
                        host.bananapim2 2017-04-21 15:08:52.766 info instance system.adapter.fritzdect.0 started with pid 15646
                        hue.0 2017-04-21 15:08:51.736 info creating/updating bridge device
                        hue.0 2017-04-21 15:08:51.735 info created/updated 13 light groups
                        hue.0 2017-04-21 15:08:51.730 warn channel "Philips hue 1.thunderAGroupOdd" already exists, skipping group
                        hue.0 2017-04-21 15:08:51.726 warn channel "Philips hue 1.thunderAGroup" already exists, skipping group
                        hue.0 2017-04-21 15:08:51.712 info creating/updating light groups
                        hue.0 2017-04-21 15:08:51.711 info created/updated 5 light channels
                        hue.0 2017-04-21 15:08:51.695 info creating/updating light channels
                        hue.0 2017-04-21 15:08:51.472 info starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.hue, node: v4.5.0 `
                        Ich hoffe das hilft Dir konstruktiv
                        Viele Grüße
                        Semenchkare
                        • lobomauL Offline
                          lobomauL Offline
                          lobomau
                          @Semenchkare:
                          Bei der 0.6.6 fällt mir noch auf, dass beim Neustart des Adapters oder vom gesamten IOBroker immer alle Lampen eingeschaltet werden… `
                          Ich hatte auch alle Lampen an (nachm Neustart) :D
                          Aber waren wohl nur die hue Lampen.
                          • Slave: Pi4
                            Semenchkare
                            Genau, bei mir sind es ausschließlich HUE.
                            Viele Grüße
                            Semenchkare
                            • BluefoxB Offline
                              BluefoxB Offline
                              @Semenchkare:
                              Ich hoffe das hilft Dir konstruktiv `
                              Das hat tatsächlich geholfen. Danke. ;)
                                Semenchkare
                                vielen herzlichen Dank für die 0.6.7. Hier bleiben die Hue's auch bei einem Neustart aus.
                                Es funktioniert alles.
                                Zur Info und Kontrolle; Im Log stehen dennoch ein paar Meldungen, die ich hier Zeigen möchte:
                                ` > hue.0 2017-04-22 17:33:39.839 error Cannot get result for lightStatus2
                                hue.0 2017-04-22 17:33:39.838 error Error: timeout of 10000ms exceeded
                                hue.0 2017-04-22 17:33:29.771 error Cannot get result for lightStatus1
                                hue.0 2017-04-22 17:33:29.769 error Error: timeout of 10000ms exceeded `
                                Dies etwa alle 12-15 Minuten.
                                Viele Grüße
                                Semenchkare
                                • BluefoxB Offline
                                  BluefoxB Offline
                                  @Semenchkare:
                                  Dies etwa alle 12-15 Minuten. `
                                  Die Gruppen werden jetzt auch "gepollt".
                                  Diese Meldung "timeout of" kommt wenn kein Antwort vom Gateway innerhalb 10 Sekunden kommt. Da kann man nichts machen. Ich weiß nicht, warum Gateway nicht antwortet. Oder diese Meldung auf debug stufen.
                                  • ruhr70R Offline
                                    ruhr70R Offline
                                    ruhr70
                                    Die 0.6.7 funktioniert ohne Auffälligkeiten! :-)
                                    • arteckA Offline
                                      arteckA Offline
                                      arteck
                                      version 0.6.9 nachdem ich eine ligtify lampe eingebunden habe
                                      nach adapter und bridge restart
