  4. js-controller 3.3 jetzt im Beta
    6.0k
791 Beiträge 75 Kommentatoren 285.7k Aufrufe 56 Beobachtet
  • D derrapf
    Jetzt hab ich mal nach Anleitung meinen Rock64 auch upgedatet und leider ging das bei mir voll in die Hose.
    Node ist bei mir v12.22.6
    Ich habe
    iobroker stop
    iobroker backup
    iobroker update
    iobroker upgrade self
    ausgeführt.
    Ausgabe:
    pi@rock64:/opt/iobroker$ iobroker upgrade self
    Update js-controller from @3.3.15 to @3.3.22
    NPM version: 6.14.15
    npm install iobroker.js-controller@3.3.22 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    sharp: Installation error: Use with glibc 2.28 requires manual installation of libvips >= 8.10.6
    ../src/common.cc:24:10: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden
     #include <vips/vips8>
    compilation terminated.
    make: *** [sharp.target.mk:139: Release/obj.target/sharp/src/common.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    gyp ERR! System Linux 5.10.63-rockchip64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/sharp
    gyp ERR! node -v v12.22.6
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    In file included from ../../nan/nan.h:58,
                     from ../src/unix_dgram.cc:5:
    /home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
    Kann mir da jemand helfen?
    Gruss Ralf
    #755
    @derrapf Die Ausgabe ist aber nicht vollständig oder?! macht er das Update oder kommt nur diese meldung in der Anzeige? iob fix gemacht?
    • D derrapf
      @thomas-braun Äh... und was heisst das jetzt?
      Hab grad noch ein Problem entdeckt: Mein zweiter Synology Adapter hatte ein Ausrufezeichen. Ich habe das nicht wegbekommen und ihn deinstalliert und nochmal installiert. Jetzt wird er nicht angezeigt obwohl er da ist:
      pi@rock64:~$ iobroker list instances | grep syno
      + system.adapter.synology.0               : synology              : rock64                                   -  enabled, port: 5001
        system.adapter.synology.1               : synology              : rock64                                   - disabled, port: 5000
      da_WoodyD Offline
      da_WoodyD Offline
      #756
      @derrapf 2 synos im selben portbereich? egal ob du die mit 5000, oder 5001 anquatscht. du kommst auf die selbe. selbst wenn du unterschiedliche IPs hast.
      meine private hat 5xxx, die andere 4xxx. nur so funzt das.
        derrapf
        schrieb am zuletzt editiert von derrapf
        #757
        Hallo alle
        Ich hatte alle Syno Adapter nochmal weggeschmissen und einen neu installiert. Auch nicht sichtbar.
        Heute morgen war der dann komischerweise auf einmal wieder sichtbar. Danach habe ich eine zweite Instanz installiert und die war sofort sichtbar.
        Ich habe aber trotzdem sicherheitshalber wie vorgeschlagen ein iob upload all gemacht.
        Zu den beiden Synology: Beide Diskstations haben eine unterschiedliche IP aber den gleichen Port. Die Webinterfaces funktionieren auf jeden Fall beide mit Port 5000.
        Die Instanz0 habe ich nun grün bekommen in dem ich HTTP abgehakt habe. Das hab ich auch bei der Instanz 1 so eingestellt. Nur die bleibt gelb mit Ausrufezeichen.
        Warum komme ich auf die Gleiche selbst wenn die unterschiedliche IPs haben? In jeder Syno-Instanz habe ich die jeweiige IP der Diskstation hinterlegt; beide Port 5000. Und das funktioniert nicht? Warum?
        Auf jeden Fall geht es auch nicht mit anderen Ports. Hab mal 4000 und 4001 auf der zweit Diskstation und der Instanz1 ausprobiert. Die Meldung ist die Gleiche.
        Die Instanz1 beschwert sich beim user "ralf", dass der nicht in der Admin Gruppe sei, obwohl er das ist:
        	2022-02-14 03:11:44.385	debug	Error: Reconnection after 10s
        synology.1
        	2022-02-14 03:11:44.384	debug	*** ERROR : src: sendPolling syno[dsm][getPollingData] To use the adapter, the user must be in the Administrators group! Also check the username and password in the adapter settings. Please try to enter the password again! code: 400 message: No such account or incorrect password
        synology.1
        	2022-02-14 03:11:44.383	debug	* No response, read next.
        synology.1
        	2022-02-14 03:11:44.247	debug	* Get info from (firstPoll) api: DSM method: getPollingData params: {}
        synology.1
        	2022-02-14 03:11:44.247	debug	* sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
        Aber ich schätze dafür sollte ich einen anderen Thread aufmachen. Das hat ja mit dem Update des JsControllers hoffentlich nichts zu tun.
        Mich würde noch interessieren ob ich diese sharp/libvips updaten muss und wenn ja wie.
        @apollon77 welche Ausgabe meintest Du? Ich hatte ja die iobroker list instances | grep syno gemacht damit nicht so viel kommt.
        "iob fix" werd ich noch machen. Es läuft grad immer noch der "iob upload all".
        Einen Bug meine ich noch gefunden zu haben:
        Ich hatte im Protokoll füher mal den Begriff "Schlafzimmer" als Filter eingegeben. Das bekomme ich nun nicht mehr aus dem Filter raus. Ich kann es zwar mit dem X Button löschen, aber sobald ich auf eine andere Anzeige wechsle (z.B. Instanzen) und dann wieder in's Protokoll gehe, steht wieder "Schlafzimmer" im Filter.
        Man muss das Wort mit Baclspace löschen und mit Return bestätigen nur dann fliegt es wirklich raus.
        Gruss Ralf
        • D derrapf
          Hallo alle
          synology.1
          synology.1
          synology.1
          synology.1
          Gruss Ralf
          da_WoodyD Offline
          da_WoodyD Offline
          #758
          @derrapf sagte in js-controller 3.3 jetzt im Beta:
          ich kann nur aus meiner erfahrung sagen, das glaub ich dir nicht. außer, du öffnest immer nur eine GUI im browser. wenn du beide oberflächen in 2 tabs aufrufst, wirst du ein problem haben. 5000 ist der HTTP, 5001 der HTTPS port. du kannst nicht 2x mit dem selben port auf 2 geräte zugreifen. darum kann sich deine instanz .1 nicht verbinden.
          die 4000/1 ist nur ein beispiel wie ich die beiden eingestellt hab. du kannst da auch 6000/1 verwenden. über 8000/1 wird z.b. mein synology-router angesprochen.
          eine verschiebung in einen eigenen tread wäre da sicher angebracht...
          • da_WoodyD da_Woody
            Samson71S Offline
            Samson71S Offline
            Samson71
            #759
            @da_woody sagte in js-controller 3.3 jetzt im Beta:
            Ich kann bestätigen, dass das genauso funktioniert. http://192.168.1.49:5000/ und http://192.168.1.51:5000/ beide als Favoriten in der Lesezeichenleiste. Um im Parallelbetrieb eine Unterscheidung zu haben und auf den 1. Blick zu sehen auf welcher Syno ich mich gerade befinde, habe ich jeweils die Hintergrundbilder unter den persönlichen Einstellungen (Desktop) angepasst .
            Markus
            Bitte beachten:
            • Samson71S Samson71
              da_WoodyD Offline
              da_WoodyD Offline
              #760
              @samson71 @Negalein hat das auch bestätigt. wie gesagt, bei mir hat das vor jahren nicht funktioniert. darum die unterschiedlichen ports. vllt geht das jetzt durch diverse FW updates.
              sorry, somit fällt mir nichts ein um dein prob zu lösen...
                derrapf
                #761
                @derrapf
                Stimmt. Geht. Hier der Beweis:
                • D derrapf
                  @derrapf
                  derrapf
                  #762
                  @derrapf
                  Ich habe nun aber noch ein viel schlimmeres Problem:
                  Die Scripte sind weg. Das hatte ich schon mal. Ich glaube da waren sie nur ausgeblendet, weiss es aber nicht mehr genau. Kann sein, dass ich die damals auch wieder aus einem Backup importiert habe.
                  Ich habe unten mit diesen Filterbuttons rumgespielt, aber es wird kein Script mehr angezeigt.
                  Die können doch nicht einfach durch ein JsController Update einfach verschwinden.
                  Backitup hat eine javascripts_2022_02_10-02_41_06_backupiobroker.tar.gz Datei angelegt (auf dem NAS, über CIFS)
                  Wenn ich die nun restaurieren will kommt
                  Immerhin hat er diesen Tempfolder noch auf dem NAS angelegt:
                  pi@rock64:/mnt/nas/backit_up/iobroker$ ls
                  iobroker_2022_02_10-02_40_21_backupiobroker.tar.gz     javascripts_2022_02_11-02_41_05_backupiobroker.tar.gz
                  iobroker_2022_02_11-02_40_20_backupiobroker.tar.gz     javascripts_2022_02_12-02_41_05_backupiobroker.tar.gz
                  iobroker_2022_02_12-02_40_21_backupiobroker.tar.gz     javascripts_2022_02_13-02_41_27_backupiobroker.tar.gz
                  iobroker_2022_02_13-02_40_21_backupiobroker.tar.gz     javascripts_2022_02_14-02_41_54_backupiobroker.tar.gz
                  iobroker_2022_02_14-02_40_21_backupiobroker.tar.gz     tmpScripts
                  und ebenso hier
                  pi@rock64:/opt/iobroker/backups$ ls
                  Gruss Ralf
                    derrapf
                    #763
                    @derrapf Ich habe jetzt mal aus der JSON Datei alle Scripte mit der Hand am Arm wieder neu angelegt.
                    Die Java Script Instanz war wie vorher die Synology Instanz disabled und nicht sichtbar.
                    Ich konnte sie mit iob start javascript.0 starten.
                    Bin mal gespannt was noch alles auf der Strecke geblieben ist. So stelle ich mir ein Update leider nicht vor.
                    Ich hoffe das war's jetzt.
                    Gruss Ralf
                    apollon77A ? 2 Antworten Letzte Antwort
                    • D derrapf
                      Gruss Ralf
                      #764
                      Also das ist total unüblich für solche Updates!! Das hab ich an sich noch nie erlebt, es also auf das Update an sich zu schieben was tausendfach ohne solche Probleme funktioniert ist fragwürdig :-)
                      ? D 2 Antworten Letzte Antwort
                      • apollon77A apollon77
                        #765
                        @apollon77 Hier ist js-controller 4.0.10 absolut unauffaellig auf multihost:
                        lxc debian 10, node 14, npm 6
                        und 3x auf lxc debian 11, node 16, npm 8,
                        auf armv6 (raspi-zero) debian 10, node 14, npm 6,
                        auf armv7 debian 11, node 14, npm 6.
                        Es sind insgesamt 61 Adapter auf 6 Hosts aufgeteilt im Einsatz.
                        Datenbank redis/redis ( die schaufelt sich bei mir tot, aber das ist ein anderes topic..hab mal ausgemistet, nur noch ca. 60000 States..)
                        apollon77A 2 Antworten Letzte Antwort
                        • D derrapf
                          Gruss Ralf
                          #766
                          @derrapf ich kann dir nur empfehlen, vor jedem Update die wichtigen Daten zu sichern, das sind 3 Mausklicks..
                          1x Scripte - alle scripte exportieren
                          1x iob backup
                          1x snapshot system
                          fertich.. fuckt irgendwas ab, kannste wenn du keine Zeit hast, mit dem Snapshot zurueck,..
                          Aufm Raspi clone ich mir halt die SD, dauert aber sicher ist sicher..
                          und wie heisst es so schoen: kommt der Sysop mit nem Grinsen, war das letzte Backup hoffentlich nicht fuer die Binsen.. !
                          Und das Leitmotto: Backup ist toll!! Wenn das Restore funktioniert, isses noch besser!
                          Ich weiss, viele Sprueche, aber lern draus.. musst ich auch..
                            #767
                            @ilovegym Schreibst das bitte noch in den 4.0 Beta thread :-))) Das hier ist der 3.3 Thread :-)
                              #768
                              @ilovegym sagte in js-controller 3.3 jetzt im Beta:
                              Was meinst Du ? mit "schaufet sich tod"?
                                #769
                                @apollon77 redis ist bei mir auf dem iobroker Host mit installiert, und verbraet jede Menge CPU.. das muss ich mal genauer investigieren und am besten auf einen externen Host umziehen.
                                  #770
                                  @ilovegym Am besten mal in nem eigenen Thread dazu reden. Interessant: Wie groß ist die Redis DB, Was ist als Persistenz aktiviert, wieviel Daten Durchsatz hast Du so in deinem System (Instanz Seite im expertenmodus wird da pro adapter angezeigt)
                                    1x iob backup
                                    1x snapshot system
                                    derrapf
                                    #771
                                    @ilovegym
                                    Bei mir läuft Backitup jeden Tag
                                    Und die Zips mit den Scripten waren ab einem bestimmten Tag leer..
                                    Gruss Ralf
                                      derrapf
                                      #772
                                      @apollon77
                                      Mich würde ja auch gerne interessieren was bei mir anders ist.
                                      Ich befürchte dass es an dem libvis ist das vielleicht zu alt ist und ich das nicht upgedatet bekomme.
                                      Denn gestern war wieder der Java Script Adapter nicht mehr unter den Instanzen zu sehen, nachdem ich den Rock resetten musste weil er nicht mehr über Putty erreichbar war.
                                      Er ist zwar angeblich installiert, aber nicht mehr zu sehen.
                                      Wenn man ihn deinstalliert bekommt man diese Meldung
                                      pi@rock64:/opt/iobroker$ iobroker del  javascript
                                      Delete adapter "javascript"
                                      host.rock64 Counted 1 meta of javascript
                                      host.rock64 Counted 1 adapter for javascript
                                      host.rock64 file javascript.admin deleted
                                      host.rock64 object javascript deleted
                                      host.rock64 object javascript.admin deleted
                                      host.rock64 Deleting 2 object(s).
                                      npm uninstall iobroker.javascript --loglevel error --prefix "/opt/iobroker" (System call)
                                      In file included from ../src/common.cc:24:
                                      /usr/local/include/vips/vips8:35:10: fatal error: glib-object.h: Datei oder Verzeichnis nicht gefunden
                                       #include <glib-object.h>
                                      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.iot/node_modules/sharp
                                      gyp ERR! not ok
                                      Also denke ich, ich habe weiterhin das Problem mit dem zu alten vips bzw. sharp
                                      pi@rock64:/opt/iobroker$ apt policy libvips42 libvips-dev
                                      libvips42:
                                        Installiert:           8.7.4-1+deb10u1
                                        Installationskandidat: 8.7.4-1+deb10u1
                                        Versionstabelle:
                                       *** 8.7.4-1+deb10u1 500
                                              500 http://deb.debian.org/debian buster/main arm64 Packages
                                      libvips-dev:
                                        Versionstabelle:
                                      Gibt es eine Möglichkeit die JS ScriptEngine wieder sauber zu installieren?
                                      Gruss Ralf
                                      Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                                      • D derrapf
                                        @apollon77
                                        gyp ERR! not ok
                                        libvips42:
                                          Versionstabelle:
                                        libvips-dev:
                                          Versionstabelle:
                                        Gruss Ralf
                                        #773
                                        glib-object.h
                                        Ist libglib2.0-dev und build-essential installiert?
                                        apt policy libglib2.0-dev build-essential
                                        Und bring deine nodejs-Installation auf Vordermann.
                                        node -v v12.22.6
                                        ist 'steinalt'. Installier die empfohlene Version 14.
                                        • D derrapf
                                          @apollon77
                                          gyp ERR! not ok
                                          libvips42:
                                            Versionstabelle:
                                          libvips-dev:
                                            Versionstabelle:
                                          Gruss Ralf
                                          #774
                                          @derrapf Ok ..... Aaaalso ... zwei komplett unterschiedliche Dinge...
                                          1.) Irgendwie hat dein system bzw einzelne Pakete problem mit der sharb bibliothek die von iot genutzt wird. NICHT von javascript
                                          2.) Instanzen verschwinden nicht einfach :-) Dann würde das heissen das Objekte verschunden sind. Also fangen wir mal da an:
                                          • Admin expertenmodus aktivieren
                                          • ist system.adapter.javascript.X da??
