  4. Wollte mal wieder updaten, leider nur Probleme
    6.1k
93 Beiträge 5 Kommentatoren 9.4k Aufrufe 4 Beobachtet
  • P pingps
    uli@debian-uli:~$ iobroker update
    Used repository: beta
    Adapter    "admin"        : 5.3.0    , installed 4.2.1  [Updatable]
    Adapter    "backitup"     : 2.3.1    , installed 2.2.4  [Updatable]
    Adapter    "discovery"    : 2.7.5    , installed 2.7.5
    Controller "js-controller": 4.0.8    , installed 4.0.4  [Updatable]
    uli@debian-uli:~$ iobroker upgrade admin
    This upgrade of "admin" will at least introduce the following changes:
    -> 5.3.0:
    Enable http compression in webserver
    Removed deprecated package "request"
    Added JSONL option for base settings
    Added small improvements
    Added the file viewer for binary states
    -> 5.2.3:
    Fixed error in `AutocompleteSendTo`
    Fixed error in charts
    -> 5.2.2:
    Changed the minimal required js-controller version to 3.3.22
    Used web-socket library 8 (no node 10 support anymore)
    -> 5.2.1:
    Allow in expert mode the creation of states and channels in mqtt branch
    -> 5.2.0:
    Fix crash cases reported via sentry
    Added support for multi-repositories
    -> 5.1.29:
    -> 5.1.28:
    Fixed discovery function
    Fixed some GUI bugs
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade admin from @4.2.1 to @5.3.0 now? [(y)es, (n)o]: y
    Update admin from @4.2.1 to @5.3.0
    host.debian-uli Adapter "system.adapter.admin.0" is stopped.
    NPM version: 6.14.16
    Installing iobroker.admin@5.3.0... (System call)
    Could not check npm version: This directory tree does not contain a package.json
    Assuming that correct version is installed.
    host.debian-uli Adapter "system.adapter.admin.0" is started
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    uli@debian-uli:~$
    #77
    @pingps
    iobroker update -i
    P 1 Antwort Letzte Antwort
      @pingps
      iobroker update -i
      pingps
      schrieb am zuletzt editiert von pingps
      #78
      uli@debian-uli:/home/iobroker$ iobroker update -i
      • P pingps
        #79
        @pingps sagte in Wollte mal wieder updaten, leider nur Probleme:
        iobroker upgrade admin@5.3.0
          pingps
          #80
          uli@debian-uli:/home/iobroker$ iobroker upgrade admin@5.3.0
          -> 5.3.0:
          -> 5.2.3:
          -> 5.2.2:
          -> 5.2.1:
          -> 5.2.0:
          -> 5.1.29:
          -> 5.1.28:
          Fixed some GUI bugs
          • P pingps
            -> 5.3.0:
            -> 5.2.3:
            -> 5.2.2:
            -> 5.2.1:
            -> 5.2.0:
            -> 5.1.29:
            -> 5.1.28:
            Fixed some GUI bugs
            #81
            @pingps
            Dann versuch mal die harte Tour:
            cd /opt/iobroker
            sudo -u -H iobroker npm install iobroker.js-controller@4.0.8
              @pingps
              cd /opt/iobroker
              pingps
              #82
              @thomas-braun first try - fail:
              uli@debian-uli:/opt/iobroker$ sudo -u - H iobroker npm install iobroker.js-controller@4.0.8
              sudo: Unbekannter Benutzer: -
              sudo: Audit-Plugin sudoers_audit konnte nicht initialisiert werden
              wo steht da der Benutzer? sudo nano geht.
              • P pingps
                #83
                @pingps
                Typo von mir. Siehe oben.
                  @pingps
                  pingps
                  #84
                  uli@debian-uli:/opt/iobroker$ sudo -u -H iobroker npm install iobroker.js-controller@4.0.8
                  sudo: Unbekannter Benutzer: -H
                  • P pingps
                    #85
                    @pingps
                    Argh.
                    Jetzt aber.
                    sudo -H -u iobroker npm install iobroker.js-controller@4.0.8
                      @pingps
                      Argh.
                      Jetzt aber.
                      pingps
                      #86
                      @thomas-braun sieht dann besser aus:
                      uli@debian-uli:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller@4.0.8
                      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                      > iobroker.js-controller@4.0.8 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                      > node lib/preinstallCheck.js
                      > iobroker.js-controller@4.0.8 install /opt/iobroker/node_modules/iobroker.js-controller
                      > node iobroker.js setup first
                      Successfully migrated 20086 objects to Redis Sets
                      object _design/system updated
                        "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\n3iVC++tmYlFNE6tkj5MCLIaDyQRMDnD0cJMbcyRIQA1AhRTgIJzH24Y=\r\n-----END RSA PRIVATE KEY-----\r\n",
                        "defaultPublic": "-----BEGIN CERTIFICATE-----\r\nMIIDgzCCAmugAwIBAgIJBvH3yGxSG0agMA0GCSqGSIb3DQEBCwUAMD4xETAPBgNV\r\nBAMTCGlvYnJva2VyMRYwFAYDVQQKEw1pb0Jyb2tlciBHbWJIMREwDwYDVQQLEwhp\r\nb2Jyb2tlcjAeFw0yMjAyMTMxMzQwMTRaFw0yMzAyMTMxMzQwMTRaMEAxEzARBgNV\r\nBAMTCmRlYmlhbi11bGkxFjAUBgNVBAoTDWlvQnJva2VyIEdtYkgxETAPBgNVBAsT\r\nCGlvYnJva2VyMIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAyxrd6zIA\r\niFERHq8u8C02pZ1gwPDbsZgy3waqhMssDxaV2TQ6P3zgMH/63K6AMW/rRC1VhbLy\r\n5dFhdUlOzoq33DospTAE0JW+zeawL/Q8VKPWDsbX5CcB6NdgYvHu9bOYkubCDAGS\r\nt/59C31Bmm8ZGGMm/YsBUhyNb/xU+JPlnADFKGcEb9z1Zm4bXheWsaTHk0XMF1cK\r\nUK0p/ESirZIQmGpvovFrwCBBWhbnUL5XXsBKGcssOQ68AVK2jxicJmgoAUElJLqK\r\n6oSoGdDg/Sm1HRUjxTju+cSZEFzOySmvnUwCBRzobWoG4gTj/IVFHMUUyg0CR3dI\r\nbu1RcllB19nxfQIDAQABo4GBMH8wDAYDVR0TAQH/BAIwADAPBgNVHQ8BAf8EBQMD\r\nB7+AMBUGA1UdEQQOMAyCCmRlYmlhbi11bGkwHQYDVR0OBBYEFE/OCvu3Ih+VdIkS\r\nRg40pIoO6lMQMB0GA1UdJQQWMBQGCCsGAQUFBwMBBggrBgEFBQcDAjAJBgNVHSME\r\nAjAAMA0GCSqGSIb3DQEBCwUAA4IBAQBTlsbLpAHB91RLS+XGw0vKDdDB4NmmQbXI\r\nTP26q697vELSaRChYAv1gNw7vm0Ta+SdKh5MqCZxY+8lZBrdUy+2JlFjgMJuqD6M\r\nxhtaz8dtHO2XEt1mu+yXw8RUTdWm6k+kDhIsxGfzyEO/O7Fa9508kkjJRVqkgXNj\r\n3qYb31As0EUcKb5oEfiAYWReEpnTC729A4WPcrax0tDhosygMFqpp28HCmp9Dr5d\r\n1MIpx29jahP5a8At0o8BCb7mmMJaO56mWmhQMspbwvkY1P9cbxU2MtCUw5E9yblG\r\nfSof2J1NytqAjEmN3+/Z6WiWsHqIJRPGT8LoTrPhz4MUUAbWZKnY\r\n-----END CERTIFICATE-----\r\n"
                      Update certificate defaultPrivate
                      The object "system.certificates" was updated successfully.
                      Update certificate defaultPublic
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                      + iobroker.js-controller@4.0.8
                      updated 1 package in 51.922s
                      22 packages are looking for funding
                        run `npm fund` for details
                      • P pingps
                        #87
                        @pingps
                        Dann versuch jetzt die Adapter hochzuziehen:
                        iobroker update
                        iobroker upgrade
                          @pingps
                          iobroker update
                          iobroker upgrade
                          pingps
                          #88
                          ok, scheint jetzt zu laufen.
                          jetzt möchte er den admin konfigurieren. Da wäre https anzukreuzen. Ist das sinnvoll?
                          Ich lass es jetzt mal.
                          Übrigens habe ich über paypal eine Spende eingeworfen. 😇
                          Danke, bis zum nächsten mal. Ich spiele mal wieder rum und schau mal ob alles läuft.
                          • P pingps
                            #89
                            machst du ja anscheinend schon die ganze Zeit.
                            Oder warum bist du im Beta-Tester Zweig.
                            Gerade jetzt, wo der controller v4 gerade erst aus Alpha raus ist
                              pingps
                              #90
                              @homoran bin kein beta tester. Das war wohl ein Versehen, wollte ich nie werden😬
                              • P pingps
                                #91
                                Und warum hast du dann das Beta-Repo aktiv?
                                Stells auf stable um:
                                iobroker repo set stable
                                  pingps
                                  #92
                                  done!
                                  thx
                                  • P pingps
                                    #93
                                    und die Ursache für deine Probleme
