  4. Wollte mal wieder updaten, leider nur Probleme
    6.0k
93 Beiträge 5 Kommentatoren 9.4k Aufrufe 4 Beobachtet
  • P pingps
    uli@debian-uli:/home/iobroker$ iobroker update -i
    Used repository: beta
    Adapter    "admin"        : 5.3.0    , installed 4.2.1  [Updatable]
    Adapter    "backitup"     : 2.3.1    , installed 2.2.4  [Updatable]
    Adapter    "discovery"    : 2.7.5    , installed 2.7.5
    Controller "js-controller": 4.0.8    , installed 4.0.4  [Updatable]
    #79
    @pingps sagte in Wollte mal wieder updaten, leider nur Probleme:
    iobroker upgrade admin@5.3.0
    P 1 Antwort Letzte Antwort
      pingps
      #80
      uli@debian-uli:/home/iobroker$ iobroker upgrade admin@5.3.0
      This upgrade of "admin" will at least introduce the following changes:
      -> 5.3.0:
      Enable http compression in webserver
      Removed deprecated package "request"
      Added JSONL option for base settings
      Added small improvements
      Added the file viewer for binary states
      -> 5.2.3:
      Fixed error in `AutocompleteSendTo`
      Fixed error in charts
      -> 5.2.2:
      Changed the minimal required js-controller version to 3.3.22
      Used web-socket library 8 (no node 10 support anymore)
      -> 5.2.1:
      Allow in expert mode the creation of states and channels in mqtt branch
      -> 5.2.0:
      Fix crash cases reported via sentry
      Added support for multi-repositories
      -> 5.1.29:
      -> 5.1.28:
      Fixed discovery function
      Fixed some GUI bugs
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade admin from @4.2.1 to @5.3.0 now? [(y)es, (n)o]: y
      Update admin from @4.2.1 to @5.3.0
      host.debian-uli Adapter "system.adapter.admin.0" is stopped.
      NPM version: 6.14.16
      Installing iobroker.admin@5.3.0... (System call)
      Could not check npm version: This directory tree does not contain a package.json
      Assuming that correct version is installed.
      host.debian-uli Adapter "system.adapter.admin.0" is started
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
      • P pingps
        -> 5.3.0:
        -> 5.2.3:
        -> 5.2.2:
        -> 5.2.1:
        -> 5.2.0:
        -> 5.1.29:
        -> 5.1.28:
        Fixed some GUI bugs
        #81
        @pingps
        Dann versuch mal die harte Tour:
        cd /opt/iobroker
        sudo -u -H iobroker npm install iobroker.js-controller@4.0.8
          @pingps
          cd /opt/iobroker
          pingps
          #82
          @thomas-braun first try - fail:
          uli@debian-uli:/opt/iobroker$ sudo -u - H iobroker npm install iobroker.js-controller@4.0.8
          sudo: Unbekannter Benutzer: -
          sudo: Audit-Plugin sudoers_audit konnte nicht initialisiert werden
          wo steht da der Benutzer? sudo nano geht.
          • P pingps
            #83
            @pingps
            Typo von mir. Siehe oben.
              @pingps
              pingps
              #84
              uli@debian-uli:/opt/iobroker$ sudo -u -H iobroker npm install iobroker.js-controller@4.0.8
              sudo: Unbekannter Benutzer: -H
              • P pingps
                #85
                @pingps
                Argh.
                Jetzt aber.
                sudo -H -u iobroker npm install iobroker.js-controller@4.0.8
                  @pingps
                  Argh.
                  Jetzt aber.
                  pingps
                  #86
                  @thomas-braun sieht dann besser aus:
                  uli@debian-uli:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller@4.0.8
                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                  > iobroker.js-controller@4.0.8 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                  > node lib/preinstallCheck.js
                  > iobroker.js-controller@4.0.8 install /opt/iobroker/node_modules/iobroker.js-controller
                  > node iobroker.js setup first
                  Successfully migrated 20086 objects to Redis Sets
                  object _design/system updated
                    "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\n3iVC++tmYlFNE6tkj5MCLIaDyQRMDnD0cJMbcyRIQA1AhRTgIJzH24Y=\r\n-----END RSA PRIVATE KEY-----\r\n",
                    "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\nfSof2J1NytqAjEmN3+/Z6WiWsHqIJRPGT8LoTrPhz4MUUAbWZKnY\r\n-----END CERTIFICATE-----\r\n"
                  Update certificate defaultPrivate
                  The object "system.certificates" was updated successfully.
                  Update certificate defaultPublic
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                  + iobroker.js-controller@4.0.8
                  updated 1 package in 51.922s
                  22 packages are looking for funding
                    run `npm fund` for details
                  • P pingps
                    #87
                    @pingps
                    Dann versuch jetzt die Adapter hochzuziehen:
                    iobroker update
                    iobroker upgrade
                      @pingps
                      iobroker update
                      iobroker upgrade
                      pingps
                      #88
                      ok, scheint jetzt zu laufen.
                      jetzt möchte er den admin konfigurieren. Da wäre https anzukreuzen. Ist das sinnvoll?
                      Ich lass es jetzt mal.
                      Übrigens habe ich über paypal eine Spende eingeworfen. 😇
                      Danke, bis zum nächsten mal. Ich spiele mal wieder rum und schau mal ob alles läuft.
                      • P pingps
                        #89
                        machst du ja anscheinend schon die ganze Zeit.
                        Oder warum bist du im Beta-Tester Zweig.
                        Gerade jetzt, wo der controller v4 gerade erst aus Alpha raus ist
                          pingps
                          #90
                          @homoran bin kein beta tester. Das war wohl ein Versehen, wollte ich nie werden😬
                          • P pingps
                            #91
                            Und warum hast du dann das Beta-Repo aktiv?
                            Stells auf stable um:
                            iobroker repo set stable
                              pingps
                              #92
                              done!
                              thx
                              • P pingps
                                #93
                                und die Ursache für deine Probleme
