  4. Nacch update der node js probleme mit iobroker fix
    6.1k
38 Beiträge 2 Kommentatoren 3.5k Aufrufe 3 Beobachtet
    @webranger
    Du sollst nicht 'irgendwas, irgendwie herumprobieren'.
    Schon gar nicht als root (per sudo). Das führt nämlich zu genausolchen verfummelten Installationen wie hier offenbar.
    WebrangerW Offline
    WebrangerW Offline
    Webranger
    @thomas-braun ok sorry
    Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
    • WebrangerW Webranger
      @webranger
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
      WebrangerW 1 Antwort Letzte Antwort
        @webranger
        cd /opt/iobroker
        WebrangerW Offline
        WebrangerW Offline
        Webranger
        @thomas-braun sagte in Nacch update der node js probleme mit iobroker fix:
        danyel@debian-iobroker:~$ cd /opt/iobroker
        danyel@debian-iobroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        > iobroker.js-controller@3.3.22 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.16
        > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram
        > node-gyp rebuild
        make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
          CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
          SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
          COPY Release/unix_dgram.node
        make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
        > iobroker.js-controller@3.3.22 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        object _design/custom updated
        object _design/system updated
        The following notifications happened during sync:
        - Ignoring Directory "devices.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "fitbit-api.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "freshenergy.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "nina.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "pushover.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "radar.admin" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "unifi" because officially not created as meta object. Please remove directory!
        - Ignoring Directory "unifi.admin" because officially not created as meta object. Please remove directory!
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/@abandonware/noble/node_modules/xpc-connection):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.pushover/package.json'
        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.pushover/node_modules/@iobroker/adapter-core/package.json'
        npm WARN react-beautiful-dnd@8.0.7 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.
        npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.
        + iobroker.js-controller@3.3.22
        added 12 packages from 14 contributors, removed 10 packages, updated 23 packages and moved 4 packages in 130.023s
        75 packages are looking for funding
          run `npm fund` for details
          > node-gyp rebuild
          @webranger
          Sieht irgendwie alles etwas strubbelig aus.
          iobroker upload all
            > node-gyp rebuild
            @webranger
            which iob
            which iobroker
            ls -la /usr/bin/iob
            ls -la /usr/bin/iobroker
              @webranger
              which iob
              which iobroker
              ls -la /usr/bin/iob
              WebrangerW Offline
              WebrangerW Offline
              Webranger
              Das hat jetzt gedauert
              danyel@debian-iobroker:/opt/iobroker$ which iob
              /usr/bin/iob
              danyel@debian-iobroker:/opt/iobroker$ which iobroker
              /usr/bin/iobroker
              danyel@debian-iobroker:/opt/iobroker$ ls -la /usr/bin/iob
              lrwxrwxrwx 1 root root 22 Apr 23  2020 /usr/bin/iob -> /opt/iobroker/iobroker
              danyel@debian-iobroker:/opt/iobroker$ ls -la /usr/bin/iobroker
              lrwxrwxrwx 1 root root 22 Apr 23  2020 /usr/bin/iobroker -> /opt/iobroker/iobroker
                /usr/bin/iob
                /usr/bin/iobroker
                @webranger
                getfacl /opt/iobroker/iobroker
                  @webranger
                  WebrangerW Offline
                  WebrangerW Offline
                  Webranger
                  danyel@debian-iobroker:/opt/iobroker$ getfacl /opt/iobroker/iobroker
                  getfacl: Entferne führende '/' von absoluten Pfadnamen
                  file: opt/iobroker/iobroker
                  owner: iobroker
                  group: iobroker
                  user::rwx
                  group::rwx
                  group:iobroker:rwx
                  mask::rwx
                  other::rwx
                    owner: iobroker
                    group: iobroker
                    user::rwx
                    group::rwx
                    group:iobroker:rwx
                    mask::rwx
                    other::rwx
                    @webranger
                    Das sieht bei mir schon mal anders aus:
                    pi@chet:/opt/iobroker $ getfacl /opt/iobroker/iobroker
                    getfacl: Removing leading '/' from absolute path names
                    # file: opt/iobroker/iobroker
                    # owner: iobroker
                    # group: iobroker
                    user::rwx
                    group::r-x
                    group:iobroker:rwx              #effective:r-x
                    mask::r-x
                    other::r-x
                    Was liefert
                    groups
                      @webranger
                      # owner: iobroker
                      # group: iobroker
                      user::rwx
                      group::r-x
                      mask::r-x
                      other::r-x
                      Was liefert
                      groups
                      WebrangerW Offline
                      WebrangerW Offline
                      Webranger
                      groups
                      danyel cdrom floppy sudo audio dip video plugdev netdev iobroker
                        groups
                        @webranger
                        Keine Ahnung, fällt mir nix zu ein.
                        iob fix
                        ist das einzige Kommando, das sich so verhält?
                        WebrangerW 2 Antworten Letzte Antwort
                          @webranger
                          iob fix
                          WebrangerW Offline
                          WebrangerW Offline
                          Webranger
                          iob fix
                          keine Ahnung, vermute
                            @webranger
                            iob fix
                            WebrangerW Offline
                            WebrangerW Offline
                            Webranger
                            Danke für deine Hilfe.
                            Werde jetzt Backup einspielen und dann die Tage mal über eine neuinstallation nachdenken.
                            Evtl nach 5 Jahren oder so garnicht so schlecht.
                              @webranger
                              sudo apt update
