  4. Zigbee und LED-Trading Unterputz Schalt Aktoren 16A
    6.3k
13 Beiträge 4 Kommentatoren 951 Aufrufe 2 Beobachtet
    mguenther
    schrieb am zuletzt editiert von mguenther
    Hallo Zusammen,
    Zigbee Adapter V1.6.6 ist installiert, ich nutze ein Zigbee LAN/USB/WLAN Gateway CC2652P von @dimaiv
    https://forum.iobroker.net/topic/48312/verkaufe-zigbee-lan-usb-wlan-gateway-cc2652p
    Nodejs/node 14.19.0
    npm 6.14.16
    Folgender Paring Log-File:
    Error: Device 0x0c4314fffe9e5719 "ON/OFF -M" not described in statesMapping.. undefined
    Pairing time left
    Pairing time left: 1
    Pairing time left: 2
    Pairing time left: 3
    Pairing time left: 4
    Pairing time left: 5
    Pairing time left: 6
    Pairing time left: 7
    Pairing time left: 8
    Pairing time left: 9
    Pairing time left: 10
    Pairing time left: 11
    Pairing time left: 12
    Pairing time left: 13
    Pairing time left: 14
    Pairing time left: 15
    Pairing time left: 16
    Pairing time left: 17
    Pairing time left: 18
    Pairing time left: 19
    Pairing time left: 20
    Pairing time left: 21
    Pairing time left: 22
    Pairing time left: 23
    Pairing time left: 24
    Pairing time left: 25
    Pairing time left: 26
    Pairing time left: 27
    Pairing time left: 28
    Pairing time left: 29
    Pairing time left: 30
    Pairing time left: 31
    Pairing time left: 32
    Pairing time left: 33
    Pairing time left: 34
    Pairing time left: 35
    Pairing time left: 36
    Pairing time left: 37
    Pairing time left: 38
    Pairing time left: 39
    Pairing time left: 40
    Pairing time left: 41
    Pairing time left: 42
    Pairing time left: 43
    Pairing time left: 44
    Pairing time left: 45
    Pairing time left: 46
    Pairing time left: 47
    Pairing time left: 48
    Pairing time left: 49
    New device joined '0x0c4314fffe9e5719' model ON/OFF -M
    Interview successful: [object Object]
    Pairing time left: 50
    Pairing time left: 51
    Device '0x0c4314fffe9e5719' announced itself
    Interview started: 0x0c4314fffe9e5719
    Pairing time left: 52
    Pairing time left: 53
    Pairing time left: 54
    Pairing time left: 55
    Pairing time left: 56
    Pairing time left: 57
    Pairing time left: 58
    Pairing time left: 59
    Pairing time left: 60
    Pairing started
    es handelt sich um den Unterputz Schalt Aktor für 16A Steckdosen (UP-SA-9127P)
    https://www.led-trading.de/zigbee-unterputz-schalter-steuergeraet-controller-230v-16a
    @arteck
    @Asgothian
    ich habe andere Threads schon gefunden, mir sagen die Fehlermeldungen nur bedingt was, aber ich glaube, der Aktor ist nicht richtig im Adapter angelegt?
    Wenn ich noch was liefern soll/kann, helfe ich gerne.
    Ich habe dann noch einen anderen Schaltaktor für Licht-Schalter von LED Trading (Artikelnummer: UP-SA-9127S)
    https://www.led-trading.de/ZigBee-Einbaudose-Unterputz-Schaltaktor-Steuergeraet-Controller-ZigBee-30-fuer-Schalter
    da klappt das Pairing ohne Probleme
    Was kann ich machen?
    Danke für jede Unterstützung
    Marcus
    • M mguenther
      Hallo Zusammen,
      Nodejs/node 14.19.0
      npm 6.14.16
      Pairing time left
      Pairing started
      @arteck
      @Asgothian
      Marcus
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @mguenther
      1. Zigbee adapter v. 1.6.12 installieren (unstable)
      2. Zigbee adapter v 1.6.15 installieren (GitHub)
      A.
      • AsgothianA Asgothian
        @mguenther
        A.
        mguenther
        @asgothian
        wenn ich z.b. die 1.6.15 von Github installiere - dann als zusätzliche Instanz?
        Oder was muss ich machen?
        • M mguenther
          @asgothian
          dimaiv
          @mguenther sagte in Zigbee und LED-Trading Unterputz Schalt Aktoren 16A:
          @asgothian
          Einfach laufende Adapter updaten. Fertig.
          ioBroker- NUC8i3 / Proxmox / VM
          Node.js v22.21.0
          NPM v10.9.4
          JS controller 7.1.0
          Admin 7.7.20
          ZigBee Adapter 3.3.1alpha.0
          Zigbee LAN Gateway CC2652P
          Zigbee Firmware 20250321
          • D dimaiv
            @asgothian
            mguenther
            @dimaiv sagte in Zigbee und LED-Trading Unterputz Schalt Aktoren 16A:
            @asgothian
            äh - wie?
            ich habe die Repositiy auf beta (http://download.iobroker.net/sources-dist-latest.json) umgestellt. Da zeigt er mir beim Adapter die 1.6.14 als mögliche Version an. Ich gehe mal davon aus, dass die auch funktioniert, aber ich komme über die Oberfläche weder auf die 1.6.12, noch auf die 1.6.15...
            edit - ich war zu blöd... 1.6.14 wird gerade installiert...
            • M mguenther
              @asgothian
              äh - wie?
              dimaiv
              @mguenther 1.6.14 ist auch gut.
              Node.js v22.21.0
              NPM v10.9.4
              JS controller 7.1.0
              Admin 7.7.20
              • D dimaiv
                mguenther
                @dimaiv
                @Asgothian
                also, einen Aktor bekomme ich gepaired, anbei der Logfile:
                Pairing time left
                Pairing started
                aber - ich sehe in der Übersicht nur:
                bzw.
                auch unter den Objekten sehe ich "nur":
                bei einem 2.Aktor kommt erst eine Fehlermeldung, dann paired er, aber das Ergebnis ist bei dem 1. Aktor
                Pairing time left
                New device joined '0x0c4314fffea33114' model ON/OFF -M
                Error: Device 0x0c4314fffea33114 "ON/OFF -M" not described in statesMapping.. undefined
                Device '0x0c4314fffea33114' announced itself
                Interview started: 0x0c4314fffea33114
                Pairing started
                • arteckA Offline
                  arteckA Offline
                  arteck
                  nur weil das ding genau so aussieht heisst es nicht dass das gleiche drinne ist...
                  hab PR gestellt.. wird aber dauern..der heisst anders
                  ON/OFF -M
                  und der ist noch nicht drin
                  bist du linux affin dann kannst du es dir temporär selber fixen..
                  • arteckA arteck
                    ON/OFF -M
                    mguenther
                    @arteck sagte in Zigbee und LED-Trading Unterputz Schalt Aktoren 16A:
                    @arteck
                    nicht wirklich... :(
                    aber - gibt es ne Anleitung, wie sowas eingerichtet werden kann?
                    braucht ihr noch andere Infos?
                    • M mguenther
                      @arteck
                      dimaiv
                      @mguenther ich kann dir ein Datei vorbereiten, den du nur in deiner System ersetzen muss. Schaffst du das?
                      Node.js v22.21.0
                      NPM v10.9.4
                      JS controller 7.1.0
                      Admin 7.7.20
                      • D dimaiv
                        mguenther
                        @dimaiv
                        glaube schon :)
                        erste Idee wäre mittels ftp?
                        wenn keine Berechtigung vorhanden, müsste ich sie als sudo von Stelle 1 an Stelle 2 kopieren. - ich hätte dazu den Befehl "cp" genommen, aber bin für alle Hinweise offen...
                        • M mguenther
                          @dimaiv
                          glaube schon :)
                          dimaiv
                          schrieb am zuletzt editiert von dimaiv
                          @mguenther
                          sunricher.zip
                          Zigbee Instanz stoppen!
                          Datei runterladen und entpacken, dann in folgenden Verzeichnis kopieren (existierende ersetzen):
                          "/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/"
                          Zigbee Instanz starten.
                          Node.js v22.21.0
                          NPM v10.9.4
                          JS controller 7.1.0
                          Admin 7.7.20
                          • D dimaiv
                            @mguenther
                            sunricher.zip
                            mguenther
                            @dimaiv
                            danke - hat erst einmal funktioniert
