  3. Einsteigerfragen
  4. KNX Adapter läuft nicht
    5.7k
21 Beiträge 4 Kommentatoren 2.0k Aufrufe 4 Beobachtet
  • R Offline
    Rookie 0
    pi@raspberrypi:~ $ pi@raspberrypi:~ $ iobroker logs --watch
    2022-01-31 17:36:42.377  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
    2022-01-31 17:36:42.386  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
    2022-01-31 17:36:42.389  - info: knx.1 (4737) Got terminate signal TERMINATE_YOURSELF
    2022-01-31 17:36:42.401  - info: knx.1 (4737) terminating
    2022-01-31 17:36:42.404  - info: knx.1 (4737) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-01-31 17:36:42.958  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-01-31 17:36:45.458  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4752
    2022-01-31 17:36:48.672  - info: knx.1 (4752) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
    2022-01-31 17:36:48.765  - warn: knx.1 (4752) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
    2022-01-31 17:36:48.770  - info: knx.1 (4752) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
    2022-01-31 17:36:48.938  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
    2022-01-31 17:36:48.949  - info: knx.1 (4752) Got terminate signal TERMINATE_YOURSELF
    2022-01-31 17:36:48.961  - info: knx.1 (4752) terminating
    2022-01-31 17:36:48.964  - info: knx.1 (4752) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-01-31 17:36:48.994  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
    2022-01-31 17:36:49.532  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-01-31 17:36:52.056  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4767
    2022-01-31 17:36:55.253  - info: knx.1 (4767) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
    2022-01-31 17:36:55.368  - warn: knx.1 (4767) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
    2022-01-31 17:36:55.373  - info: knx.1 (4767) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
    2022-01-31 17:36:55.473  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
    2022-01-31 17:36:55.484  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
    2022-01-31 17:36:55.512  - info: knx.1 (4767) Got terminate signal TERMINATE_YOURSELF
    2022-01-31 17:36:55.522  - info: knx.1 (4767) terminating
    2022-01-31 17:36:55.525  - info: knx.1 (4767) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-01-31 17:36:56.085  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-01-31 17:36:58.556  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4782
    2022-01-31 17:37:01.748  - info: knx.1 (4782) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
    2022-01-31 17:37:01.870  - warn: knx.1 (4782) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
    2022-01-31 17:37:01.874  - info: knx.1 (4782) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
    2022-01-31 17:37:01.968  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
    2022-01-31 17:37:01.995  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
    2022-01-31 17:37:02.026  - info: knx.1 (4782) Got terminate signal TERMINATE_YOURSELF
    2022-01-31 17:37:02.036  - info: knx.1 (4782) terminating
    2022-01-31 17:37:02.039  - info: knx.1 (4782) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-01-31 17:37:02.598  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-01-31 17:37:05.054  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4797
    2022-01-31 17:37:08.236  - info: knx.1 (4797) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
    2022-01-31 17:37:08.328  - warn: knx.1 (4797) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
    2022-01-31 17:37:08.333  - info: knx.1 (4797) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
    2022-01-31 17:37:08.806  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
    2022-01-31 17:37:08.818  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
    2022-01-31 17:37:08.818  - info: knx.1 (4797) Got terminate signal TERMINATE_YOURSELF
    2022-01-31 17:37:08.833  - info: knx.1 (4797) terminating
    2022-01-31 17:37:08.837  - info: knx.1 (4797) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-01-31 17:37:09.436  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-01-31 17:37:11.880  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4812
    2022-01-31 17:37:15.049  - info: knx.1 (4812) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
    2022-01-31 17:37:15.179  - warn: knx.1 (4812) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
    2022-01-31 17:37:15.184  - info: knx.1 (4812) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
    2022-01-31 17:37:15.623  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
    2022-01-31 17:37:15.631  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
    2022-01-31 17:37:15.631  - info: knx.1 (4812) Got terminate signal TERMINATE_YOURSELF
    2022-01-31 17:37:15.642  - info: knx.1 (4812) terminating
    2022-01-31 17:37:15.645  - info: knx.1 (4812) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-01-31 17:37:16.277  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-01-31 17:37:18.698  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4827
    2022-01-31 17:37:21.936  - info: knx.1 (4827) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
    2022-01-31 17:37:22.034  - warn: knx.1 (4827) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
    2022-01-31 17:37:22.040  - info: knx.1 (4827) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
    2022-01-31 17:37:22.453  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
    2022-01-31 17:37:22.462  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
    2022-01-31 17:51:23.128  - info: host.raspberrypi stopInstance system.adapter.knx.2 send kill signalocess=true)x, node: v14.18.3, js-controller: 3.3.225) not possible because of cancelled connection.D : 0 SeqCntIN : 0 SeqCntOUT : 0  msgC
    R 1 Antwort Letzte Antwort
    • R Rookie 0
      Rookie 0
      ist das so ok?
      Danke schonmal!
      Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
      • R Rookie 0
        ist das so ok?
        Danke schonmal!
        @rookie-0
        Deine Systemzeit steht offenbar auf London-Zeit. Stell das auf Berlin/MEZ um
        • R Rookie 0
          ist das so ok?
          Danke schonmal!
          GlasfaserG Offline
          GlasfaserG Offline
          @rookie-0
          Oben im Screenshot ist die Instanz knx.2
          und im Log knx.1 !?
          Wieviel instanzen hast du !?
          • GlasfaserG Glasfaser
            @rookie-0
            und im Log knx.1 !?
            Rookie 0
            Eine Instanz. Der Rest ist eigentlich raus gelöscht...
            • R Rookie 0
              Rookie 0
              System Zeit hatte ich eigentlich schon auf berlin gesetzt.
              Geht doch über rasperry-config oder?
              • R Rookie 0
                @rookie-0 Ja. Die geloggten Zeitstempel deuten aber auf eine Stunde Differenz hin.
                date && date -u
                liefert?
                • R Rookie 0
                  @rookie-0
                  iobroker list instances
                  iobroker update -i
                    date && date -u
                    liefert?
                    Rookie 0
                    Mon 31 Jan 20:08:12 CET 2022
                    Mon 31 Jan 19:08:12 UTC 2022
                      @rookie-0
                      iobroker update -i
                      Rookie 0
                      • system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      • system.adapter.discovery.0 : discovery : raspberrypi - enabled
                        system.adapter.knx.1 : knx : raspberrypi - disabled, bind: 127.0.0.1
                      • system.adapter.knx.2 : knx : raspberrypi - enabled, bind: 192.168.178.37
                      • instance is alive
                      • R Rookie 0
                        • instance is alive
                        Rookie 0
                        schrieb am zuletzt editiert von Rookie 0
                        R
                        Rookie 0
                        32 minutes ago
                        pi@raspberrypi:~ $ iobroker update -i
                        Used repository: default
                        hash changed or no sources cached => force download of new sources
                        update done
                        Adapter "admin" : 5.2.3 , installed 5.2.3
                        Adapter "backitup" : 2.2.3 , installed 2.2.3
                        Adapter "discovery" : 2.7.3 , installed 2.7.3
                        Controller "js-controller" : 3.3.22 , installed 3.3.22
                        Adapter "knx" : 2.0.5 , installed 2.0.5
                        R Thomas BraunT 2 Antworten Letzte Antwort
                        • R Rookie 0
                          R
                          Rookie 0
                          32 minutes ago
                          update done
                          Rookie 0
                          kann es an einer verkehrten physikalischen adresse liegen?
                          • R Rookie 0
                            R
                            Rookie 0
                            32 minutes ago
                            update done
                            @rookie-0
                            Bitte in CodeTags setzen. Danke.
                              @rookie-0
                              Rookie 0
                              hiermit geschehen...
                              Thomas BraunT T 2 Antworten Letzte Antwort
                              • R Rookie 0
                                @rookie-0
                                Nö, noch nicht geschehen.
                                Ist meist falsch. Lös das Binding auf.
                                • R Rookie 0
                                  tombox
                                  @rookie-0
                                  Also sicherstellen das nur eine instance läuft.
                                  Dann die IP und Physikalische adresse des gateways doppelt checken
                                  OpenKnx Adapter ausprobieren.
                                  • T tombox
                                    @rookie-0
                                    Rookie 0
                                    Ich habe es endlich hinbekommen.
                                    Die IP des Gateway war falsch...
                                    Danke an Alle!
                                    • R Rookie 0
                                      Danke an Alle!
                                      Rookie 0
                                      Jetzt würde ich gerne eine Visu installieren.
                                      Ich bekomme jedoch eine rote Meldung, wenn ich den Adapter hinzufügen möchte.
                                      Keine Versionsinfo für web
                                      Steht dann da und Hinzufügen ist ausgegraut.
                                      Was mache ich jetzt schon wieder verkehrt?
                                      • R Offline
                                        Rookie 0
                                        Ok, der Webadapter fehlt wohl.
                                        Den bekomme ich aber nicht installiert. Woran liegt es?
                                        $ iobroker add web auto --host raspberrypi
                                        NPM version: 6.14.15
                                        npm install iobroker.web@3.4.16 --loglevel error --prefix "/opt/iobroker" (System call)
                                        npm ERR! Cannot read property 'match' of undefined
                                        npm ERR! /home/iobroker/.npm/_logs/2022-02-01T08_53_20_360Z-debug.log
                                        host.raspberrypi Cannot install iobroker.web@3.4.16: 1
                                        ERROR: Process exited with code 25
