  4. Nach Update von WEB 3.4.16 kein VIS mehr
157 Beiträge 29 Kommentatoren 30.9k Aufrufe 22 Beobachtet
  • L LPTR
    Seltsam
    pi@IoBroker:~ $ iobroker update
    Used repository: stable
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.2.3    , installed 5.2.3
    Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
    Adapter    "alias-manager" : 1.2.4    , installed 1.2.4
    Adapter    "backitup"      : 2.2.3    , installed 2.2.3
    Adapter    "device-reminder": 1.2.9   , installed 1.2.9
    Adapter    "discovery"     : 2.7.3    , installed 2.7.3
    Adapter    "dwd"           : 2.7.7    , installed 2.7.7
    Adapter    "echarts"       : 1.0.3    , installed 1.0.3
    Adapter    "email"         : 1.0.10   , installed 1.0.10
    Adapter    "feiertage"     : 1.1.0    , installed 1.1.0
    Adapter    "heatingcontrol": 2.7.2    , installed 2.7.2
    Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
    Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
    Adapter    "info"          : 1.9.8    , installed 1.9.8
    Adapter    "iot"           : 1.8.24   , installed 1.8.24
    Adapter    "jarvis"        : 2.2.1    , installed 3.0.1
    Adapter    "javascript"    : 5.2.13   , installed 5.2.13
    Controller "js-controller" : 3.3.22   , installed 3.3.22
    Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
    Adapter    "ping"          : 1.5.0    , installed 1.5.0
    Adapter    "shuttercontrol": 1.4.10   , installed 1.4.10
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
    Adapter    "socketio"      : 3.1.5    , installed 3.1.5
    Adapter    "sql"           : 1.15.7   , installed 1.15.7
    Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
    Adapter    "vis"           : 1.4.5    , installed 1.4.5
    Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
    Adapter    "vis-icontwo"   : 0.84.0   , installed 0.84.0
    Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.5
    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
    Adapter    "vis-material-advanced": 1.7.2   , installed 1.7.2
    Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
    Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
    Adapter    "web"           : 3.4.16   , installed 3.4.16
    Adapter    "zigbee"        : 1.6.6    , installed 1.6.14
    @lptr sagte in Nach Update von WEB 3.4.16 kein VIS mehr:
    Seltsam
    Mal sehen, ob das heute im Laufe des Tages noch bei mir ankommt :-)
    Und ihr macht bitte ein Issue auf, wenn es reproduzierbar ist
    L 1 Antwort Letzte Antwort
      Seltsam
      LPTR
      schrieb am zuletzt editiert von LPTR
      Da bei allen wo es auftritt anscheinend soket.io auf 4.0.3 gezogen wird scheint das das Problem zu sein. Nach downgrade auf stable 3.1.5 läuft ja alles wieder.
      Bin nun nicht der Profi im Issues erstellen, aber ich probiere es mal.
      https://github.com/ioBroker/ioBroker.web/issues/182
      S HomoranH 2 Antworten Letzte Antwort
      • L LPTR
        SSW-mcor
        Ja, soket.io auf 3.1.5 und schon läuft wieder alles 😊
        F 1 Antwort Letzte Antwort
        • L LPTR
          @lptr Habe gerade eben beide Updates angeboten bekommen.
          Bin aber jetzt erst einmal vorsichtig.
          Mal sehen wie auf das Issue reagiert wird
            LPTR
            Wie gesagt, nicht WEB 3.1.16 ist das Problem, sondern Soket.io 4.0.3...
            • L LPTR
              ich tippe mal, dass diese Version auch für die web v4 gedacht ist.
              Die sollte natürlich auch abwärtskompatibel sein, bzw. nicht installierbar, wenn die versionen nicht passen
                LPTR
                So ist das, wenn man Sonntags zu viel Zeit hat und ein vorhandenes Update sofort installiert. 😁
                • L LPTR
                  du musst ja besonders viel Zeit gehabt haben :-)
                  du hast ja sogar 2 Updates installiert.
                  Und dann noch Ursachenforschung betrieben!
                    LPTR
                    Purer Eigennutz! Ich mache gerade meine erste VIS 😁
                      Matzeit
                      Für den Suchmaschinen-Algorhytmus:
                      Hatte auch das Problem mit den echarts Diagrammen in JARVIS 3.x. Update von web Adapter hatte bei mir ebenfalls socket.io hochgezogen. Downgrade auf socket 3.x hat es behoben.
                      • S SSW-mcor
                        FischerICT
                        schrieb am zuletzt editiert von FischerICT
                        @ssw-mcor Hat bei mir leider nicht funktioniert. Erst als ich auch den WEB Adapter von 3.4.16 wider auf 3.4.13 zurückgesetzt habe, hat die VIS wieder funktioniert.
                        • H Offline
                          Huem
                          Habe socket.io auf 3.1.5 zurück gesetzt und Vis ging wieder 😊
                          • FoGF Offline
                            FoGF Offline
                            FoG
                            schrieb am zuletzt editiert von FoG
                            Leider hier das Selbe - musste wieder zurück ...
                            Komischer Weise zeigte die Socket.IO Version die 3.1.5er unter Adapter an - hab dann revert auf die Version 3.1.5 gemacht und er zeigte an -> Updating from 4.X to 3.1.5...
                            Dann lief wieder alles (IQontrol...)
                            bin ebenfalls auf stable ...
                            Topas68T 1 Antwort Letzte Antwort
                            • S ssond0815
                              @uri3l Kann ich bestätigen. Nachdem ich das downgrade durchgeführt habe, lief die VIS wieder.
                              $ iobroker upgrade socketio@3.1.5
                              Update socketio from @4.0.3 to @3.1.5
                              NPM version: 6.14.15
                              Danke @uri3l!
                              Matti1993
                              @ssond0815 wie mache ich ein downgrade ?
                              • FoGF FoG
                                Topas68T Offline
                                Topas68T Offline
                                Topas68
                                Hier dasselbe Problem. Socket.io ist bei mir aber auf 3.1.4 und ein downgrade von web auf 3.4.9 brachte keine Änderung.
                                Bis dahin komme ich, klicke ich dann einen Link an, nichts mehr außer dem Ladebildschirm. :-/
                                • F FischerICT
                                  Matti1993
                                  @fischerict wie komme ich zurück auf 3.4.13 ?
                                  FoGF Michael SchmittM HomoranH 3 Antworten Letzte Antwort
                                  • M Matti1993
                                    FoGF Offline
                                    FoGF Offline
                                    FoG
                                    @matti1993 Den Experten Modus einschalten (Kopf-Symbol oben in der Leiste, geht dann auf "grüner Kopf") und dann beim Adapter drauf klicken und frühere Version aussuchen.
                                    • M Matti1993
                                      Michael SchmittM Online
                                      Michael Schmitt
                                      • M Matti1993
                                        @matti1993 https://www.iobroker.net/#de/documentation/tutorial/adapter.md?downgradeeinesadapters
                                        • Michael SchmittM Michael Schmitt
                                          Matti1993
                                          @michael-schmitt danke stehe jetzt wider bei 3.4.13 vis läuft nicht !!
                                          was kann ich noch machen ?
                                          Michael SchmittM Topas68T 2 Antworten Letzte Antwort
