  4. Wasserzähler (Funk 868) auslesen.
diehl868funkwasserzähleroms
220 Beiträge 23 Kommentatoren 91.1k Aufrufe 24 Beobachtet
  • hg6806H hg6806
    @michi_pi
    Keine Ahnung wo es schon wieder hängt.
    Ich hatte wmbusmeters erst deinstalliert über:
    sudo systemctl stop wmbusmeters
    cd wmbusmeters
    sudo make uninstall
    dann:
    pi@raspberrypi:~ $ git clone https://github.com/weetmuts/wmbusmeters.git
    fatal: Zielpfad 'wmbusmeters' existiert bereits und ist kein leeres Verzeichnis.
    pi@raspberrypi:~ $ sudo git clone https://github.com/weetmuts/wmbusmeters.git
    pi@raspberrypi:~ $ cd wmbusmeters
    pi@raspberrypi:~/wmbusmeters $ make && make test
    Building 1.3.0-23-g08b9153
    OK: test internals
    OK: Test C1 meters
    OK json: Test T1 meters
    OK fields: Test T1 meters
    OK json: Test S1 meters
    OK fields: Test S1 meters
    OK: Test meter with unknown driver
    OK json: Test naughty non-compliant apator162 meters
    OK fields: Test naughty non-compliant apator162 meters
    OK json: Test Izars meters
    OK: Test listen to all izars
    OK: Test aes encrypted telegrams
    OK: Test that failed decryption warning only prints once.
    OK: Test shell invocation
    OK: Test shell in config file
    OK: Test that normal meterfiles are written
    OK: Test that meterfiles with name-id are written
    OK: Test that meterfiles with id are written
    OK: Test that meterfiles with timestamps are written
    OK: Test normal config files with C1 meters
    OK: Test logfile
    OK: Test single meter conf file matches any id
    OK: Test listen and print any meter heard in logfile
    OK: Test listen and print any meter heard on stdout
    OK: Test detection of drivers for all telegrams
    OK: Test listen to wildcard * id
    OK: Test listen to wildcard suffix 8856* id
    OK: Test listen to two comma separted ids
    OK: Test listen to three comma separted ids
    OK: Test listen with negated ids
    OK: Test listen with wrong driver and wildcard
    OK: Test conversions of units
    OK: Test selected fields
    OK: Test oneshot
    OK: Test wrong keys
    OK: Test config4 with added conversions
    OK: Test that listen to t1+c1 works with meters transmitting using t1+c1
    OK: Test that setting supercom587 to c1 fails
    OK: Test additional json from cmdline
    OK: Test additional shell envs from cmdline
    OK: Test additional json from wmbusmeters.conf and from meter file
    OK: Test rtlwmbus starting background script to produce telegrams
    OK: Reading binary telegram from stdin
    OK: Reading binary telegram from file
    OK: Reading rtlwmbus formatted telegrams from stdin
    OK: Reading rtlwmbus formatted telegrams from file
    OK: Reading rtl433 formatted telegrams from stdin
    OK: Reading rtl433 formatted telegrams from file
    OK: Test ok serial rawtty telegram on stdin
    OK: Test bad serial rawtty telegram with interspersed noise, on stdin
    OK: Test duplicates are ignored
    OK: Test duplicates are left alone
    OK: Test match on dll id
    OK: Test match on tpl id
    OK: Test log timestamps
    Slower tests...
    OK: reading all stdin before closing down
    RUNNING Test alarms ...
    STDERR---------------------------------
    [ALARM DeviceInactivity] 4 seconds of inactivity resetting simulations/simulatio        n_alarm.txt simulation (timeout 4s expected mon-sun(00-23) now 2021-06-22 22:17)
    (wmbus) successfully reset wmbus device
    STDOUT---------------------------------
    TMP/OUTPUT-----------------------------
    METER =={"media":"cold water","meter":"multical21","name":"Water","id":"76348799        ","total_m3":6.408,"target_m3":6.408,"max_flow_m3h":0,"flow_temperature_c":127,"        external_temperature_c":19,"current_status":"DRY","time_dry":"22-31 days","time_        reversed":"","time_leaking":"","time_bursting":"","timestamp":"2021-06-22T20:17:        46Z"}==
    METER =={"media":"cold water","meter":"multical21","name":"Water","id":"76348799        ","total_m3":6.408,"target_m3":6.408,"max_flow_m3h":0,"flow_temperature_c":127,"        external_temperature_c":19,"current_status":"DRY","time_dry":"22-31 days","time_        reversed":"","time_leaking":"","time_bursting":"","timestamp":"2021-06-22T20:17:        52Z"}==
    TMP/ALARM------------------------------
    ALARM_SHELL DeviceInactivity [ALARM DeviceInactivity] 4 seconds of inactivity re        setting simulations/simulation_alarm.txt simulation (timeout 4s expected mon-sun        (00-23) now 2021-06-22 22:17)
    OK: Test alarms
    All tests ok!
    pi@raspberrypi:~/wmbusmeters $ sudo nano /etc/wmbusmeters.conf
    pi@raspberrypi:~/wmbusmeters $ sudo nano /etc/wmbusmeters.d/meinWasserzaehler
    pi@raspberrypi:~/wmbusmeters $ cd /etc/wmbusmeters.d
    -bash: cd: /etc/wmbusmeters.d: Datei oder Verzeichnis nicht gefunden
    pi@raspberrypi:~ $ cd etc
    -bash: cd: etc: Datei oder Verzeichnis nicht gefunden
    pi@raspberrypi:~ $ cd 7etc
    -bash: cd: 7etc: Datei oder Verzeichnis nicht gefunden
    pi@raspberrypi:~ $ cd /etc
    pi@raspberrypi:/etc $ makedir wmbusmeters.d
    -bash: makedir: Kommando nicht gefunden.
    pi@raspberrypi:/etc $ mkdir wmbusmeters.d
    mkdir: das Verzeichnis „wmbusmeters.d“ kann nicht angelegt werden: Keine Berecht        igung
    pi@raspberrypi:/etc $ sudo mkdir wmbusmeters.d
    pi@raspberrypi:/etc $ sudo nano /etc/wmbusmeters.d/meinWasserzaehler
    pi@raspberrypi:/etc $ sudo systemctl start wmbusmeters
    Warning: The unit file, source configuration file or drop-ins of wmbusmeters.ser        vice changed on disk. Run 'systemctl daemon-reload' to reload units.
    Job for wmbusmeters.service failed because the control process exited with error        code.
    See "systemctl status wmbusmeters.service" and "journalctl -xe" for details.
    pi@raspberrypi:/etc $ systemctl status wmbusmeters.service
    Warning: The unit file, source configuration file or drop-ins of wmbusmeters.service changed on disk. Run 'systemctl daemon-reload' to reload units.
    ● wmbusmeters.service - "wmbusmeters service"
       Loaded: loaded (/lib/systemd/system/wmbusmeters.service; enabled; vendor preset: enabled)
       Active: failed (Result: exit-code) since Tue 2021-06-22 22:27:35 CEST; 30s ago
         Docs: https://github.com/weetmuts/wmbusmeters
               man:wmbusmeters(1)
      Process: 27860 ExecStartPre=/bin/mkdir -p /var/log/wmbusmeters/meter_readings (code=exited, status=217/USER)
      Process: 27861 ExecStartPre=/bin/chown -R wmbusmeters:wmbusmeters /var/log/wmbusmeters (code=exited, status=217/USER)
    Jun 22 22:27:34 raspberrypi systemd[1]: wmbusmeters.service: Failed with result 'exit-code'.
    Jun 22 22:27:34 raspberrypi systemd[1]: Failed to start "wmbusmeters service".
    Jun 22 22:27:35 raspberrypi systemd[1]: wmbusmeters.service: Service RestartSec=1s expired, scheduling restart.
    Jun 22 22:27:35 raspberrypi systemd[1]: wmbusmeters.service: Scheduled restart job, restart counter is at 3.
    Jun 22 22:27:35 raspberrypi systemd[1]: Stopped "wmbusmeters service".
    Jun 22 22:27:35 raspberrypi systemd[1]: wmbusmeters.service: Start request repeated too quickly.
    Jun 22 22:27:35 raspberrypi systemd[1]: wmbusmeters.service: Failed with result 'exit-code'.
    Jun 22 22:27:35 raspberrypi systemd[1]: Failed to start "wmbusmeters service".
    pi@raspberrypi:/etc $ sudo systemctl daemon-reload
       Loaded: not-found (Reason: Unit wmbusmeters.service not found.)
       Active: failed (Result: exit-code) since Tue 2021-06-22 22:27:35 CEST; 1min 13s ago
    Failed to start wmbusmeters.service: Unit wmbusmeters.service not found.
    Irgendwie fehlt der service.
    Michi_Pi
    #182
    @hg6806 ja, du warst zu schnell, du hast vergessen es zu installieren.
    Nach make && make test fehlt der Befehl sudo make install
    Da aber wohl noch was im Verzeichnis liegt, würde ich die Daten nochmal holen.
    Also so:
    cd wmbusmeters
    git pull https://github.com/weetmuts/wmbusmeters.git
    sudo make clean
    sudo make install
    danach legst deine configs an und startest den Dienst, wo wie du es eh vorgehabt hattest.
    hg6806H 1 Antwort Letzte Antwort
    • M Michi_Pi
      Also so:
      cd wmbusmeters
      sudo make clean
      sudo make install
      hg6806H Offline
      hg6806H Offline
      hg6806
      schrieb am zuletzt editiert von hg6806
      #183
      @michi_pi
      Danke, habe ich so gemacht, wirft jedoch noch immer den Fehler aus:
      pi@raspberrypi:/etc $ sudo systemctl stop wmbusmeters
      pi@raspberrypi:/etc $ cd wmbusmeters
      -bash: cd: wmbusmeters: Datei oder Verzeichnis nicht gefunden
      pi@raspberrypi:~/wmbusmeters $ git pull https://github.com/weetmuts/wmbusmeters.git
      Von https://github.com/weetmuts/wmbusmeters
       * branch            HEAD       -> FETCH_HEAD
      Bereits aktuell.
      pi@raspberrypi:~/wmbusmeters $ sudo make clean
      rm -rf build/* build_arm/* build_debug/* build_arm_debug/* *~
      pi@raspberrypi:~/wmbusmeters $ sudo make install
      g++ -Os -fPIC -std=c++11 -Wall -Werror=format-security -Ibuild src/aes.cc -c -E > build/aes.o.src
      g++ -Os -fPIC -std=c++11 -Wall -Werror=format-security -Ibuild src/aes.cc -MMD -c -o build/aes.o
      pi@raspberrypi:~/wmbusmeters $ sudo systemctl daemon-reload
      pi@raspberrypi:~/wmbusmeters $ sudo systemctl start wmbusmeters
      pi@raspberrypi:~/wmbusmeters $ sudo systemctl enable wmbusmeters
      pi@raspberrypi:~/wmbusmeters $ systemctl status wmbusmeters.service
         Active: failed (Result: protocol) since Wed 2021-06-23 14:14:04 CEST; 33s ago
                 man:wmbusmeters(1)
      Jun 23 14:14:04 raspberrypi systemd[1]: wmbusmeters.service: Service RestartSec=1s expired, scheduling restart.
      Jun 23 14:14:04 raspberrypi systemd[1]: wmbusmeters.service: Scheduled restart job, restart counter is at 3.
      Jun 23 14:14:04 raspberrypi systemd[1]: Stopped "wmbusmeters service".
      Jun 23 14:14:04 raspberrypi systemd[1]: wmbusmeters.service: Start request repeated too quickly.
      Jun 23 14:14:04 raspberrypi systemd[1]: wmbusmeters.service: Failed with result 'protocol'.
      Jun 23 14:14:04 raspberrypi systemd[1]: Failed to start "wmbusmeters service".
      • hg6806H hg6806
        @michi_pi
        Bereits aktuell.
                   man:wmbusmeters(1)
        Michi_Pi
        #184
        @hg6806 hast schon mal einen neustart durchgeführt?
        • M Michi_Pi
          hg6806H Offline
          hg6806H Offline
          hg6806
          #185
          @michi_pi
          Ja, gerade mal Reboot gemacht.
          Danach noch immer das Problem:
          pi@raspberrypi:~ $ sudo systemctl start wmbusmeters
          Job for wmbusmeters.service failed because the service did not take the steps required by its unit configuration.
          pi@raspberrypi:~ $ sudo systemctl enable wmbusmeters
          pi@raspberrypi:~ $
          pi@raspberrypi:~ $ systemctl status wmbusmeters.service
             Active: failed (Result: exit-code) since Wed 2021-06-23 15:17:55 CEST; 15s ago
                     man:wmbusmeters(1)
           Main PID: 6031 (code=exited, status=1/FAILURE)
          Jun 23 15:17:55 raspberrypi systemd[1]: wmbusmeters.service: Service RestartSec=1s expired, scheduling restart.
          Jun 23 15:17:55 raspberrypi systemd[1]: wmbusmeters.service: Scheduled restart job, restart counter is at 3.
          Jun 23 15:17:55 raspberrypi systemd[1]: Stopped "wmbusmeters service".
          Jun 23 15:17:55 raspberrypi systemd[1]: wmbusmeters.service: Start request repeated too quickly.
          Jun 23 15:17:55 raspberrypi systemd[1]: wmbusmeters.service: Failed with result 'exit-code'.
          Jun 23 15:17:55 raspberrypi systemd[1]: Failed to start "wmbusmeters service".
             Active: failed (Result: exit-code) since Wed 2021-06-23 15:17:55 CEST; 25s ago
                     man:wmbusmeters(1)
          pi@raspberrypi:~ $
          An welcher Stelle der Installation sollte man generell ein Reboot machen?
          • hg6806H hg6806
            @michi_pi
            pi@raspberrypi:~ $
                       man:wmbusmeters(1)
                       man:wmbusmeters(1)
            pi@raspberrypi:~ $
            Michi_Pi
            #186
            @hg6806 steht in der Log was drinnen?
            tail -f /var/log/wmbusmeters/wmbusmeters.log
            • hg6806H Offline
              hg6806H Offline
              hg6806
              #187
              @michi_pi sagte in Wasserzähler (Funk 868) auslesen.:
              pi@raspberrypi:~ $ tail -f /var/log/wmbusmeters/wmbusmeters.log
              tail: '/var/log/wmbusmeters/wmbusmeters.log' kann nicht zum Lesen geöffnet werden: Datei oder Verzeichnis nicht gefunden
              tail: Keine Dateien mehr übrig
              • hg6806H Offline
                hg6806H Offline
                hg6806
                #188
                Also irgendwie fehlt noch immer der Service:
                Unit wmbusmeters.service could not be found.
                binaries: installed /usr/bin/wmbusmeters and /usr/sbin/wmbusmetersd
                man page: installed /usr/share/man/man1/wmbusmeters.1.gz
                group: added wmbusmeters
                user: added wmbusmeters
                user: added wmbusmeters to dialout group
                user: added wmbusmeters to uucp group
                user: added wmbusmeters to plugdev group
                log: created /var/log/wmbusmeters/meter_readings
                logrotate: created /etc/logrotate.d/wmbusmeters
                conf file: created /etc/wmbusmeters.conf
                conf dir: created /etc/wmbusmeters.d
                diff: /root/old.wmbusmeters.service.backup: Datei oder Verzeichnis nicht gefunde        n
                systemd: updated /lib/systemd/system/wmbusmeters.service
                You need to reload systemd configuration! Please do:
                pi@raspberrypi:~/wmbusmeters $ sudo systemctl stop wmbusmeters
                Failed to stop wmbusmeters.service: Unit wmbusmeters.service not loaded.
                pi@raspberrypi:~/wmbusmeters $ git pull https://github.com/weetmuts/wmbusmeters.        git
                Bereits aktuell.
                g++ -Os -fPIC -std=c++11 -Wall -Werror=format-security -Ibuild src/aes.cc -MMD -        c -o build/aes.o
                g++ -Os -fPIC -std=c++11 -Wall -Werror=format-security -Ibuild src/aescmac.cc -c        -E > build/aescmac.o.src
                g++ -Os -fPIC -std=c++11 -Wall -Werror=format-security -Ibuild src/aescmac.cc -M        MD -c -o build/aescmac.o
                g++ -Os -fPIC -std=c++11 -Wall -Werror=format-security -Ibuild src/bus.cc -c -E        > build/bus.o.src
                g++ -Os -fPIC -std=c++11 -Wall -Werror=format-security -Ibuild src/bus.cc -MMD -        c -o build/bus.o
                g++ -o build/wmbusmeters build/aes.o build/aescmac.o build/bus.o build/cmdline.o build/config.o build/dvparser.o build/mbus_rawtty.o build/meters.o build/manufacturer_specificities.o build/printer.o build/rtlsdr.o build/serial.o build/shell.o build/sha256.o build/threads.o build/util.o build/units.o build/wmbus.o build/meter_auto.o build/meter_unknown.o build/meter_amiplus.o build/wmbus_amb8465.o build/wmbus_im871a.o build/wmbus_cul.o build/wmbus_rtlwmbus.o build/wmbus_rtl433.o build/wmbus_simulator.o build/wmbus_rawtty.o build/wmbus_rc1180.o build/wmbus_utils.o build/meter_apator08.o build/meter_apator162.o build/meter_cma12w.o build/meter_compact5.o build/meter_dme_07.o build/meter_ebzwmbe.o build/meter_ehzp.o build/meter_esyswm.o build/meter_elf.o build/meter_em24.o build/meter_emerlin868.o build/meter_ev200.o build/meter_evo868.o build/meter_eurisii.o build/meter_fhkvdataiii.o build/meter_fhkvdataiv.o build/meter_flowiq2200.o build/meter_hydrus.o build/meter_hydrocalm3.o build/meter_hydrodigit.o build/meter_ei6500.o build/meter_iperl.o build/meter_izar.o build/meter_izar3.o build/meter_lansendw.o build/meter_lansensm.o build/meter_lansenth.o build/meter_lansenpu.o build/meter_lse_07_17.o build/meter_mkradio3.o build/meter_mkradio4.o build/meter_multical21.o build/meter_multical302.o build/meter_multical403.o build/meter_multical603.o build/meter_multical803.o build/meter_omnipower.o build/meter_piigth.o build/meter_q400.o build/meter_qcaloric.o build/meter_rfmamb.o build/meter_rfmtx1.o build/meter_sharky.o build/meter_supercom587.o build/meter_sontex868.o build/meter_topaseskr.o build/meter_tsd2.o build/meter_ultrimis.o build/meter_vario451.o build/meter_waterstarm.o build/meter_whe46x.o build/meter_whe5x.o build/meter_sensostar.o build/meter_gransystems_ccx01.o build/meter_lse_08.o build/meter_weh_07.o  build/main.o  -lrtlsdr -lusb-1.0 -lpthread
                group: wmbusmeters unmodified
                user: wmbusmeters unmodified
                user: wmbusmeters already added to dialout
                user: wmbusmeters already added to uucp
                user: wmbusmeters already added to plugdev
                conf file: /etc/logrotate.d/wmbusmeters unchanged
                conf file: /etc/wmbusmeters.conf unchanged
                conf dir: /etc/wmbusmeters.d unchanged
                systemd: backing up /lib/systemd/system/wmbusmeters.service to here: /root/old.wmbusmeters.service.backup
                systemd: no changes to /lib/systemd/system/wmbusmeters.service
                   Active: failed (Result: exit-code) since Thu 2021-06-24 17:34:32 CEST; 58s ago
                           man:wmbusmeters(1)
                 Main PID: 1110 (code=exited, status=1/FAILURE)
                Jun 24 17:34:32 raspberrypi systemd[1]: wmbusmeters.service: Service RestartSec=1s expired, scheduling restart.
                Jun 24 17:34:32 raspberrypi systemd[1]: wmbusmeters.service: Scheduled restart job, restart counter is at 3.
                Jun 24 17:34:32 raspberrypi systemd[1]: Stopped "wmbusmeters service".
                Jun 24 17:34:32 raspberrypi systemd[1]: wmbusmeters.service: Start request repeated too quickly.
                Jun 24 17:34:32 raspberrypi systemd[1]: wmbusmeters.service: Failed with result 'exit-code'.
                Jun 24 17:34:32 raspberrypi systemd[1]: Failed to start "wmbusmeters service".
                • hg6806H hg6806
                  OK, habe soweit alles installieren können, jedoch bekomme ich schon wieder keine Daten und bin am Verzweifeln!
                  Ich hatte mir die letzten Configs gespeichert, aber irgendwie will es nicht.
                  Hier die Ausgaben:
                  pi@raspberrypi:/etc/wmbusmeters.d $ ls -l /dev/serial/by-id
                  insgesamt 0
                  lrwxrwxrwx 1 root root 13 Jun 17 18:40 usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB2
                  lrwxrwxrwx 1 root root 13 Jun 17 18:40 usb-SHA_CUL868-if00 -> ../../ttyACM0
                  lrwxrwxrwx 1 root root 13 Jun 17 18:40 usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01304FAA-if00-port0 -> ../../ttyUSB0
                  lrwxrwxrwx 1 root root 13 Jun 17 18:40 usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01304FAE-if00-port0 -> ../../ttyUSB1
                  pi@raspberrypi:/etc/wmbusmeters.d $ sudo nano ./meinwasserzaehler
                  name=meinwasserzaehler
                  type=iperl:t1
                  id=2xxxxxxx6
                  key=2xxxxxxxxxxxxxxx2
                  pi@raspberrypi:/etc/wmbusmeters.d $ sudo nano /etc/wmbusmeters.conf
                  loglevel=normal
                  device=auto:t1
                  logtelegrams=true
                  format=json
                  logfile=/var/log/wmbusmeters/wmbusmeters.log
                  shell=/usr/bin/mosquitto_pub -h 192.168.178.18 -p 1883 -u user -P password -t wmbusmeters/21200936/Gesamt -m "$METER_TOTAL_M3"
                  shell=/usr/bin/mosquitto_pub -h 192.168.178.18 -p 1883 -u user -P password -t wmbusmeters/21200936/RSSI -m "$METER_RSSI_DBM"
                  pi@raspberrypi:/etc/wmbusmeters.d $ wmbusmeters auto:t1
                  No wmbus device detected, waiting for a device to be plugged in.
                  Notice! Other wmbusmeters (pid 17064) is running and it might hog any wmbus devices.
                  No meters configured. Printing id:s of all telegrams heard!
                  ^Cpi@raspberrypi:/etc/wmbusmeters.d sudo killall -HUP wmbusmeters
                  pi@raspberrypi:/etc/wmbusmeters.d $ sudo killall -HUP wmbusmetersd
                  wmbusmetersd: Kein Prozess gefunden
                  pi@raspberrypi:/etc/wmbusmeters.d $ sudo wmbusmeters auto:t1
                  Hat das was damit zu tun, dass der CUL jetzt an ACM0 hängt?
                  Michi_Pi
                  schrieb am zuletzt editiert von Michi_Pi
                  #189
                  @hg6806 sagte in Wasserzähler (Funk 868) auslesen.:
                  type=iperl:t1
                  id=2xxxxxxx6
                  lösche mal das ":t1" hier raus. Denke das ist das Problem.
                  danach
                  Edit: bzw. kannst du die komplette Zeile löschen type=iperl:t1 wird in der neuen Version automatisch erkannt.
                  • hg6806H Offline
                    hg6806H Offline
                    hg6806
                    #190
                    So, ich wollte nochmal Rückmeldung geben.
                    Es läuft endlich wieder.
                    Es lag 1. an dem ":t1". Habe auch das komplette "type:iperl:t1" rausgelöscht.
                    Status war danach komplett successfull, jedoch kamen trotzdem keine Daten über MQTT.
                    In der Config hatte komischerweise die beiden Shell-Befehle für MQTT gefehlt, obwohl ich die reinkopiert hatte.
                    • hg6806H hg6806
                      knopers1
                      schrieb am zuletzt editiert von knopers1
                      #191
                      ich habe auch seit 2021 den Hydrus 171a mit der 868 Funk Schnittstelle.
                      Wasserverbrauch lässt sich dort aber auch ganz einfach über den Kabel abgreifen.
                      Hierzu reicht ein ESP8266 mit dem Eingang am 10K Pullup Wiederstand.
                      Die weiße Leitung liefert bei mir einen Impuls pro 10l Wasser mit einer Wellenlänge von 125ms.
                      Dies lässt sich locker über einen Counterzähler des ESP´s8266 erfassen und mit dem Betriebsstundenzähler hochrechnen.
                        Berchemer
                        #192
                        Über die Suchfunktion des Forums konnte ich leider nichts finden.
                        Meine Suche im Internet war auch nicht von Erfolg gekrönt :-(
                        Daher die Frage...
                        Wo kann man denn einen solchen Zähler von Diehl Hydrus 171A/B käuflich erwerben???
                        Meinetwegen auch über Chat-Funktion, falls eine offene Antwort im Forum als Werbung angesehen würde.
                          saeft_2003
                          #193
                          @csr
                          Hast du es mittlerweile geschafft deine Kampstrup Wasserzähler per Funk auszulesen?
                          -cs-- sonnenscheinS 2 Antworten Letzte Antwort
                          • S saeft_2003
                            @csr
                            -cs-- Offline
                            -cs-- Offline
                            -cs-
                            schrieb am zuletzt editiert von -cs-
                            #194
                            @saeft_2003
                            Ja, halbherzig, es läuft für mich soweit ausreichend, bin aber für eine Weiterempfehlung noch nicht zufrieden damit.
                            Aber das wurde hier in dem Thread ja schon besprochen dachte ich. ... muss mir mal Zeit nehmen und nochmal alles lesen.
                            Mit wmbusmeters und Mosquitto.
                            • S saeft_2003
                              @csr
                              sonnenscheinS Offline
                              sonnenschein
                              schrieb am zuletzt editiert von sonnenschein
                              #195
                              @saeft_2003 sagte in Wasserzähler (Funk 868) auslesen.:
                              @csr
                              Halĺo!
                              ich habe seit kurzem eine Kampstrupzähler. Auslesung via wmbus M
                              mit dem Adapter von lvogt. Es gibt hier im Forum dazu einen Beitrag.
                              Wmbus adapter
                              PlatformBetriebssystem:linux Architektur:arm64 CPUs:4 Geschwindigkeit:1800 MHz Modell:Cortex-A72
                              RAM:3.7 GB System-Betriebszeit:00:19:02 Node.js:v20.18.0
                              _nodeCurrent:20.18.0
                              _npmCurrent:10.8.2
                              Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.6.57-v8+
                              • sonnenscheinS sonnenschein
                                @csr
                                Halĺo!
                                Wmbus adapter
                                Michi_Pi
                                #196
                                @sonnenschein klingt interessant, bei mir funktioniert zwar wmbusmeter ohne probleme. aber werde den adapter auch mal testen.
                                • O oxident
                                  ~~Es scheint, als wäre nicht jeder Versorger so nett und rückt den Schlüssel raus. Trotz Argument der "Leckage-Erkennung" wurde ich direkt abgeschmettert. Solch sensible Informationen gebe man nicht preis ~~
                                  Nach mehrmaligem Nachhaken wurde wohl doch erkannt, dass ich ein Anrecht auf den Key habe ;-)
                                  ThorstenR
                                  #197
                                  @oxident Mein Versorger will den Schlüssel auch nicht rausrücken, wie war denn deine Begründung, dass du ein Anrecht drauf hast?
                                  • T ThorstenR
                                    hg6806H Offline
                                    hg6806H Offline
                                    hg6806
                                    #198
                                    @thorstenr
                                    Das Problem ist, dass bei Verkauf des Objektes du den Zähler weiterhin auslesen könntest.
                                    Wie ungeheuerlich! :-)
                                    Auf jeden Fall wäre das dann wohl datenschutztechnisch ein Problem.
                                    Bei den Stadtwerken musste ich dann eine Vereinbarung unterschreiben u.a. mit folgendem Wortlaut:
                                    "„..verpflichtet sich der o.g. Eigentümer, bei einem Eigentümerwechsel (wie z.B. Verkauf,
                                    Schenkung) innerhalb der Eichzeit von 12 Jahren (ab Zählereinbau)
                                    den Restbuchwert des Zählers sowie die Montage des neuen Funkzählers zu zahlen.“
                                    So ein Zähler ist übrigens richtig teuer, aber so schnell wird die Hütte nicht verkauft.
                                    Geh doch einfach damit mal auf deinen Versorger zu.
                                    • hg6806H hg6806
                                      @thorstenr
                                      ThorstenR
                                      #199
                                      @hg6806 Ich hab ihn schon gefragt, Antwort war, den Schlüssel gibt's nicht.
                                      • T ThorstenR
                                        hg6806H Offline
                                        hg6806H Offline
                                        hg6806
                                        #200
                                        @thorstenr
                                        Schade - mit welcher Begründung?
                                        Mit einer solchen unterschriebenen Vereinbarung sind die eigentlich safe.
                                        • O Online
                                          O Online
                                          oxident
                                          #201
                                          @ThorstenR Tja, diese "Betonwand" kenne ich leider nur zu gut. Selbst auf nochmaliges Nachfragen ein Jahr später kam nur ein lapidares "das haben wir Ihnen doch letztes Jahr schon gesagt".
                                          Ich hatte direkt mit Gründen der Havarievermeidung (und damit eingehender Wasserverschwendung) argumentiert. Bei mir gab es in der Tat schon zwei Rohrbrüche die ich prima frühzeitig entdeckt hätte wenn ich den Wasserbrauch überwacht hätte. Da mein Wasserzähler in einer Grube im Garten ist, ist eine ständige "optische" Überwachung kaum möglich. Das habe ich denen auch so mitgeteilt. Ebenfalls stand hier in der Lokalpresse vor einigen Jahren, dass die neuen Wasserzähler alle mit individuellen Schlüsseln ausgestattet sind. Daher dürfte es auch kein Problem mit den Zählern der Nachbarn geben (mittlerweile weiß ich jedoch, dass das gelogen war und die ganze Stadt den gleichen Schlüssel verwendet).
                                          Ebenfalls angeführt habe ich den Anspruch auf die "Datenhoheit" meiner Daten.
                                          Hat alles nichts gebracht. Im Gegenteil, mir wurde sogar gedroht, dass ich keine Manipulationen an deren Eigentum vorzunehmen habe. Andernfalls müsste ich für den Schaden aufkommen (!).
                                          Nächster Schritt war dann der Landesdatenschutzbeauftragte. Argument meinerseits: Es sind doch meine Daten.
                                          Da bekam ich in der Tat ein zweiseitiges Schreiben ... grob zusammengefasst: Nein, sind keine persönlichen Daten.
                                          Nächster Schritt: Bundesdatenschutzbeauftragter. Antwort kam schnell: Ist Ländersache :-(
                                          Nächster Schritt: Anwalt. Der hat mir gesagt, dass er nur Aussicht auf Erfolg sieht, wenn ich sicherstellen kann, dass die Schlüssel individuell sind. Ansonsten wäre das ein Killerargument vom Datenschutz.
                                          Nächster Schritt: Gemeinevertretung. Hier habe ich in der Tat Verständnis für mein Anliegen bekommen, jedoch wurde mir auch gesagt, dass man kaum Möglichkeiten hat. Man werde es "ansprechen".
                                          @hg6806 Genau die Punkte aus Deiner Vereinbarung hatte ich dem Versorger ja sogar beim Erstkontakt direkt vorgeschlagen. Darauf wurde nicht mal mit einem Satz eingegangen. Wie gesagt, das Hauptproblem wird sein, dass ich in der Tat die Verbräuche der Nachbarn sehen könnte und die (unbegründete) Angst des Versorgers, ich könnte den Zähler manipulieren.
