  4. Proxmox Passthrough Zigbee nach neuinstallation
12 Beiträge 6 Kommentatoren 1.2k Aufrufe 4 Beobachtet
    thomson
    schrieb am zuletzt editiert von thomson
    Moin zusammen,
    finde meinen Fehler einfach nicht und langsam gehen mir die Ideen aus.
    Musste meinen NUC neu aufsetzen
    • nun mit Proxmox 7.1-7 statt 6.4
    • Den Container habe ich via Proxmox Backup wiederhergestellt. Soweit so gut.
      Nur der Zigbee Adapter wird nicht grün....
      Log:
      zigbee.0
      2022-01-25 15:21:10.126 error Error herdsman start
      zigbee.0
      2022-01-25 15:21:10.125 error Failed to start Zigbee
      zigbee.0
      2022-01-25 15:21:10.124 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0'"
      zigbee.0
      2022-01-25 15:21:09.929 info Installed Version: ioBroker/ioBroker.zigbee#9a112084b13a00e8d731097090a2cc1e597b1c1c
      zigbee.0
      2022-01-25 15:21:09.904 info Starting Zigbee npm ...
      zigbee.0
      2022-01-25 15:21:09.903 info Try to reconnect. 1 attempts left
      zigbee.0
      2022-01-25 15:20:59.903 info Installed Version: ioBroker/ioBroker.zigbee#9a112084b13a00e8d731097090a2cc1e597b1c1c
      zigbee.0
      2022-01-25 15:20:59.899 error Error herdsman start
      zigbee.0
      2022-01-25 15:20:59.898 error Failed to start Zigbee
      zigbee.0
      2022-01-25 15:20:59.897 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Permission denied, cannot open /dev/ttyACM0'"
      zigbee.0
      2022-01-25 15:20:59.320 info Starting Zigbee npm ...
      zigbee.0
      2022-01-25 15:20:59.214 info starting. Version 1.6.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 3.3.22
      host.ioBroker
      2022-01-25 14:20:55.564 info instance system.adapter.zigbee.0 started with pid 1035
      host.ioBroker
      2022-01-25 14:20:53.693 info instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.ioBroker
      2022-01-25 14:20:53.509 info stopInstance system.adapter.zigbee.0 killing pid 468
      zigbee.0
      2022-01-25 14:20:52.595 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0
      2022-01-25 14:20:52.593 info terminating
      zigbee.0
      2022-01-25 14:20:52.592 warn Failed to stop zigbee during startup
      zigbee.0
      2022-01-25 14:20:52.506 info Zigbee: disabling joining new devices.
      zigbee.0
      2022-01-25 14:20:52.405 info cleaned everything up...
      host.ioBroker
      2022-01-25 14:20:52.480 info stopInstance system.adapter.zigbee.0 send kill signal
      zigbee.0
      2022-01-25 14:20:52.404 info Got terminate signal TERMINATE_YOURSELF
    Habe dieses als Anleitung genommen. Meinte mich daran zu erinnern das es damit ging.
    https://coldcorner.de/2018/07/12/proxmox-usb-passthrough-fuer-lxc-container-z-wave-uzb1/
    Habt ihr da eine Idee?
    Danke!
    E 1 Antwort Letzte Antwort
    • T thomson
      Moin zusammen,
        Log:
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        host.ioBroker
        host.ioBroker
        host.ioBroker
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        host.ioBroker
        zigbee.0
      Danke!
      Einstein67
      schrieb am zuletzt editiert von Einstein67
      @thomson Du musst nur den Befehl "cgroup" auf "cgroup2" ändern (2. unleserlicher Screenshot).
      • E Einstein67
        thomson
        @einstein67
        Danke für die schnelle Antwort.
        Leider klappt das noch nicht
        Danach Reboot
        • david83D Offline
          david83D Offline
          david83
          @thomson
          Hi, ich habe vor einigen Wochen einen USB Passthrough nach dem folgendem Howto durchgeführt. Das Howto von Coldcorner hat bei mir auch nicht gefunzt.
          https://www.cooltux.net/doku.php?id=it-wiki:proxmox:usb_passthrough
          Mfg
          David
            thomson
            @david83 mit cgroup oder cgroup2 ?
            Es ging nun ein paar Stunden . Adapter wurde Grün.
            Nach einem Neustart wieder das selbe Problem..
            E M 2 Antworten Letzte Antwort
            • T thomson
              Einstein67
              @thomson "cgroup" gibt es bei PVE7 nicht mehr.
              Ist das einzige dass sich beim Update von PVE6 auf 7 geändert hat.
              Du hast da zuviele Zeilen in deiner xxxx.conf drinnen. Das dürfen nur 4 sein!
              • T thomson
                M Online
                M Online
                mrjeschke
                @thomson
                Moin,
                Ich habe meinen Zigbee-Stick mit dieser Anleitung durchgereicht.
                Funktioniert super und übersteht auch einen Neustart.
                Link Text
                T 2 Antworten Letzte Antwort
                • E Einstein67
                  thomson
                  @einstein67 said in Proxmox Passthrough Zigbee nach neuinstallation:
                  Welche müssten den raus?
                  • M mrjeschke
                    @thomson
                    Moin,
                    Link Text
                    thomson
                    @maik-0 said in Proxmox Passthrough Zigbee nach neuinstallation:
                    @thomson
                    Moin,
                    Link Text
                    Probiere ich das mal. Denke mal vorher die Config wieder bereinigen.
                    • M mrjeschke
                      @thomson
                      Moin,
                      Link Text
                      thomson
                      @thomson
                      Moin,
                      Link Text
                      Das hat geklappt! Danke!!!!
                      Hoffe mal das bleibt :D
                      Frage am Rande.... Wenn ich nun von dem cc2531 auf den Sonoff wechseln möchte. Dann müssen die Geräte ja neu angelernt werden.
                      Bleiben die Verknüpfungen in den Skripten den bestehen oder müssen die alle geändert werden?
                      AsgothianA arteckA 2 Antworten Letzte Antwort
                      • T thomson
                        @thomson
                        Moin,
                        Link Text
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @thomson sagte in Proxmox Passthrough Zigbee nach neuinstallation:
                        Die bleiben bestehen - die ID's der Datenpunkte sind Hardwareabhängig. Das gleiche Gerät bekommt dabei immer die gleiche ID.
                        A.
                        • T thomson
                          @thomson
                          Moin,
                          Link Text
                          arteckA Offline
                          arteckA Offline
                          arteck
                          nicht zwingend... musst du schauen.. ob der Stick die alten Daten übernimmt. einfach probieren
                          82.9k
