  4. jarvis v3.0.0 - just another remarkable vis
    6.5k
4.5k Beiträge 254 Kommentatoren 3.1m Aufrufe 209 Beobachtet
  • Dominik F.D Dominik F.
    Ich bekomme in regelmäßgen Abständen folgende Fehlermeldungen:
    host.IoBroker
    2022-01-24 11:39:54.899	error	instance system.adapter.jarvis.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    jarvis.0
    2022-01-24 11:39:54.348	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    jarvis.0
    2022-01-24 11:39:54.348	info	terminating
    jarvis.0
    2022-01-24 11:39:54.348	info	Adapter stopped und unloaded.
    jarvis.0
    2022-01-24 11:39:54.345	error	Cannot read property 'ip' of undefined
    jarvis.0
    2022-01-24 11:39:54.345	error	TypeError: Cannot read property 'ip' of undefined at ioWebSocket.eventFromClient (/opt/iobroker/node_modules/iobroker.jarvis/lib/websocket.io.min.js:1:4231) at ioWebSocketClient._parentMessage (/opt/iobroker/node_modules/iobroker.jarvis/lib/websocket.io.min.js:1:6959) at ioWebSocketClient.disconnect (/opt/iobroker/node_modules/iobroker.jarvis/lib/websocket.io.min.js:1:8944) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.jarvis/lib/websocket.io.min.js:1:8136) at Socket.emit (events.js:400:28) at Socket.emitReserved (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/socket.io/dist/typed-events.js:56:22) at Socket._onclose (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/socket.io/dist/socket.js:358:14) at Client.onclose (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/socket.io/dist/client.js:239:20) at Socket.emit (events.js:412:35) at Socket.onClose (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/engine.io/build/socket.js:303:18)
    jarvis.0
    2022-01-24 11:39:54.343	error	uncaught exception: Cannot read property 'ip' of undefined
    Hat jemand eine Idee dazu?
    ZefauZ Offline
    ZefauZ Offline
    Zefau
    schrieb am zuletzt editiert von Zefau
    #1326
    @dominik-f bitte auf 3.0.10 gehen
    • ZefauZ Zefau
      Dominik F.D Offline
      Dominik F.D Offline
      Dominik F.
      #1327
      @zefau
      Mache ich, dank dir
      • RoddiEFR Offline
        RoddiEFR Offline
        RoddiEF
        #1328
        Eine Frage:
        wie kommt man denn an die (wie auf dem Bild zu sehen) unteren ran ?
        Man kann das Fenster nicht verschieben oder das die untere Liste (Server) nach oben aufgeht.
        So kommt man an die unteren nicht ran um diese Auszuwählen...
        Ich bin wie ich bin, was anderes bekommt man nicht !!
        • RoddiEFR RoddiEF
          Eine Frage:
          ZefauZ Offline
          ZefauZ Offline
          Zefau
          #1329
          @roddief v3.0.10
          RoddiEFR 1 Antwort Letzte Antwort
          • ZefauZ Zefau
            @roddief v3.0.10
            RoddiEFR Offline
            RoddiEFR Offline
            RoddiEF
            #1330
            @zefau mir wird keine v3.0.10 angezeigt.
            Aktuelle wird mir nur v3.0.9 gezeigt. "Repo" ist in den Einstellungen auf "latest" eingestellt.
            • RoddiEFR RoddiEF
              ZefauZ Offline
              ZefauZ Offline
              Zefau
              #1331
              @roddief dann aktualisiere mal im Adapter Tab die Update Liste
              Dominik F.D RoddiEFR 2 Antworten Letzte Antwort
              • ZefauZ Zefau
                Dominik F.D Offline
                Dominik F.D Offline
                Dominik F.
                #1332
                ich möchte folgendes realisieren:
                Ich möchte ein Drop Down erstellen,
                Die Texte sind in folgendem Datenpunkt:
                {heatingcontrol.0.vis.ProfileValueListText}
                Die Werte sind in folgendem Datenpunkt:
                {heatingcontrol.0.vis.ProfileValueListValue}
                Getriggert wird am Ende folgender Datenpunkt:
                heatingcontrol.0.CurrentProfile
                Wie bekomme ich die 3 Sachen unter einen Hut? Wie kann ich in der Anzeigevariante einen Datenpunkt angeben?
                  MCU
                  #1333
                  @dominik-f https://github.com/Zefau/ioBroker.jarvis/issues/486
                  Stell mal die Werte der DPs rein. Und beschreib mal deren Abhängigkeit.
                  Dominik F.D 2 Antworten Letzte Antwort
                  • M MCU
                    Dominik F.D Offline
                    Dominik F.D Offline
                    Dominik F.
                    #1334
                    @mcu
                    Ganz oben in der Anfrage steht ja ein Link, dort sind alle Datenpunkte beschrieben. Das ganze ist dort ja schon über 1 Jahr alt und erfreut sich leider keiner großen Beliebtheit.
                    Da ich ja eh gerade alles von 0 aufbaue finde ich es nicht schlimm, mir die Sachen selber zusammenzuschustern. Dabei lerne ich ja gleichzeitig auch sehr viel von Jarvis. Ich hab es z.B. hinbekommen, dass ich einen Taster erstelle, der die Farbe ändert wenn sich ein anderer Datenpunkt ändert. Da bin ich schon ein wenig stolz auf mich :D
                    Ich denke wenn ich das mit dem Drop Down hin bekomme, kann ich mir danach fast alles schon so bauen wie ich mir das brauche. Macht auch gerade spaß auch wenn ich viel von deiner Zeit in Anspruch nehme. Sorry und Danke gleichzeit dafür
                      @mcu
                      MCU
                      #1335
                      @dominik-f Stell mal die Einstellung mit dem Taster rein, dann nehme ich das in die Doku.
                      • M MCU
                        Dominik F.D Offline
                        Dominik F.D Offline
                        Dominik F.
                        schrieb am zuletzt editiert von Dominik F.
                        #1336
                        @mcu
                        Der Button schaltet den Datenpunkt immer wieder zurück auf "auto". Ist der Datenpunkt auf "auto", ist der Button grün, wenn er auf "manual" steht rot.
                        • ZefauZ Zefau
                          RoddiEFR Offline
                          RoddiEFR Offline
                          RoddiEF
                          #1337
                          @zefau Thx, es kann manchmal so einfach sein... ;)
                          Wenn man Stundenlang am PC sitzt, vergisst man die einfachsten Sachen (Reload der Seite)....
                          • M MCU
                            Dominik F.D Offline
                            Dominik F.D Offline
                            Dominik F.
                            #1338
                            @mcu
                            Hast du denn eine Idee wie ich die Datenpunkte in die Anzeigewerte bekomme?
                            Dann hab ich noch eine andere Frage:
                            Habe folgendes in eine Anzeigevariante geschrieben:
                              "manual": "false",
                              "val.indexOf('auto')": "true"
                            Nur leider funktioniert das mit dem Index nicht, habe ich da was falsch geschrieben?
                              @mcu
                                "manual": "false",
                              MCU
                              #1339
                              @dominik-f Was steht im DP-Wert? -> val.indexOf('auto')?
                              In der Anzeigevariante kannst du nur echte DP-Werte nutzen.
                              • M MCU
                                Dominik F.D Offline
                                Dominik F.D Offline
                                Dominik F.
                                #1340
                                @mcu
                                der eine Wert ist "manual", den hab ich mit false ja abgedeckt. Die anderen Werte haben immer "auto" mit im Wert stehen, deshalb wollte ich das mit indexOF lösen. Dies hat in den Bindings in Vis bisher immer funktioniert.
                                Ich wollte dort nicht jeden Wert einzelnd aufschreiben müssen.
                                • M MCU
                                  Dominik F.D Offline
                                  Dominik F.D Offline
                                  Dominik F.
                                  #1341
                                  @mcu
                                  Ich hab eine Lösung gefunden. Allerdings verstehe ich das nicht so wirklich aber es funktioniert:
                                  {"manual":"false","val.indexOf('auto')==-1":"true"}
                                    @mcu
                                    MCU
                                    #1342
                                    @dominik-f sagte in jarvis v3.0.0 - just another remarkable vis:
                                    Es ist immer dann true, wenn es kein "manual" ist.
                                    Kannst auch "test" in den DP schreiben, kommt auch true.
                                    M Dominik F.D 2 Antworten Letzte Antwort
                                    • M MCU
                                      MCU
                                      #1343
                                      @mcu Wenn es sowieso nur manual und auto* gibt, kannst du auch mit "default":"true", "manual":"false" arbeiten
                                      • M MCU
                                        Dominik F.D Offline
                                        Dominik F.D Offline
                                        Dominik F.
                                        #1344
                                        @mcu
                                        Okay, dann funktionierte es durch Zufall^^ Wie müsste das denn aussehen, dass nur wenn "auto" vor kommt, der Wert true ist.
                                        Ich frage deshalb, weil ich das von Anfang an vernünftig machen will. Ich bin leider nur ein reiner Anwender. Ich kann mir sehr gut merken was ich wo nutzen muss und das auch gut verändern.
                                        Sagen wir mal ich habe 4 Werte
                                        "auto", "auto Window", "manual", "test". Wenn auto im Datenpunkt vor kommt soll es immer true sein.
                                        Mir ist klar, dass ich jeden Wert einzelnd deklarieren könnte, aber es gibt doch sicher eine schönere Variante?
                                          @mcu
                                          MCU
                                          #1345
                                          @dominik-f Bei 4 Werten würde ich nicht überlegen, sondern eintragen. Falls es 200 Werte wären, dann würde ich anfangen zu überlegen, ob es noch eine andere Variante gibt.
                                          Es gibt ja den default. Den nutzt man dann für die 200 auto-Varianten. Und die anderen 2 legt man an.
