  4. zigbee nach update gelb
    6.1k
50 Beiträge 12 Kommentatoren 6.9k Aufrufe 12 Beobachtet
  • J Offline
    Ja.rod
    Hallo zusammen, gibt es hier schon etwas positives zu berichten?
    Ja.rod
      mpl1338
      inzwischen geht 1.4.1 auch nicht mehr
      host.iobroker	2021-07-17 21:50:15.230	info	Do not restart adapter system.adapter.zigbee.0 because desired by instance
      host.iobroker	2021-07-17 21:50:15.230	error	instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      zigbee.0	2021-07-17 21:50:12.779	info	(615555) Installed Version: iobroker.zigbee@1.4.1
      zigbee.0	2021-07-17 21:50:12.776	warn	(615555) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
      zigbee.0	2021-07-17 21:50:12.724	info	(615555) Starting Zigbee npm ...
      zigbee.0	2021-07-17 21:50:12.694	info	(615555) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.14
      host.iobroker	2021-07-17 21:50:12.041	info	instance system.adapter.zigbee.0 started with pid 615555
      host.iobroker	2021-07-17 21:49:42.015	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.iobroker	2021-07-17 21:49:42.014	error	instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      host.iobroker	2021-07-17 21:49:40.796	info	instance system.adapter.zigbee.0 started with pid 615517
      host.iobroker	2021-07-17 21:49:38.768	info	stopInstance system.adapter.zigbee.0 killing pid 613791
      zigbee.0	2021-07-17 21:49:37.771	warn	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:310:33)). undefined"
      zigbee.0	2021-07-17 21:49:37.771	warn	at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:202:16)
      zigbee.0	2021-07-17 21:49:37.771	warn	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:23:12)
      zigbee.0	2021-07-17 21:49:37.771	warn	at new Promise (<anonymous>)
      zigbee.0	2021-07-17 21:49:37.771	warn	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:27:71
      zigbee.0	2021-07-17 21:49:37.771	warn	at Generator.next (<anonymous>)
      zigbee.0	2021-07-17 21:49:37.771	warn	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:203:18)
      zigbee.0	2021-07-17 21:49:37.771	warn	at Controller.databaseSave (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:222:45)
      zigbee.0	2021-07-17 21:49:37.771	warn	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:88:15)
      zigbee.0	2021-07-17 21:49:37.771	warn	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:55)
      zigbee.0	2021-07-17 21:49:37.771	warn	(613791) Read-only state "zigbee.0.info.pairingMessage" has been written without ack-flag with value "Error: Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
      zigbee.0	2021-07-17 21:49:37.770	error	(613791) Cannot read property 'getEntries' of null
      zigbee.0	2021-07-17 21:49:37.770	error	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8747:22)
      zigbee.0	2021-07-17 21:49:37.770	error	at Zigbee.emit (events.js:314:20)
      zigbee.0	2021-07-17 21:49:37.770	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:465:41)
      zigbee.0	2021-07-17 21:49:37.770	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:306:20)
      zigbee.0	2021-07-17 21:49:37.770	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:189:42)
      zigbee.0	2021-07-17 21:49:37.770	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:180:43)
      zigbee.0	2021-07-17 21:49:37.770	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:203:49)
      zigbee.0	2021-07-17 21:49:37.770	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:255:31)
      zigbee.0	2021-07-17 21:49:37.770	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:236:16)
      zigbee.0	2021-07-17 21:49:37.770	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55)
      zigbee.0	2021-07-17 21:49:37.770	error	(613791) TypeError: Cannot read property 'getEntries' of null
      zigbee.0	2021-07-17 21:49:37.769	error	(613791) unhandled promise rejection: Cannot read property 'getEntries' of null
      zigbee.0	2021-07-17 21:49:37.769	error	(613791) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0	2021-07-17 21:49:37.769	info	(613791) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0	2021-07-17 21:49:37.769	info	(613791) terminating
      zigbee.0	2021-07-17 21:49:37.768	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:310:33))
      zigbee.0	2021-07-17 21:49:37.768	error	at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:202:16)
      zigbee.0	2021-07-17 21:49:37.768	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:23:12)
      zigbee.0	2021-07-17 21:49:37.768	error	at new Promise (<anonymous>)
      zigbee.0	2021-07-17 21:49:37.768	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:27:71
      zigbee.0	2021-07-17 21:49:37.768	error	at Generator.next (<anonymous>)
      zigbee.0	2021-07-17 21:49:37.768	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:203:18)
      zigbee.0	2021-07-17 21:49:37.768	error	at Controller.databaseSave (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:222:45)
      zigbee.0	2021-07-17 21:49:37.768	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:88:15)
      zigbee.0	2021-07-17 21:49:37.768	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:55)
      zigbee.0	2021-07-17 21:49:37.768	error	(613791) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
      zigbee.0	2021-07-17 21:49:37.768	info	(613791) Zigbee: disabling joining new devices.
      zigbee.0	2021-07-17 21:49:37.767	info	(613791) cleaned everything up...
      Stick ist von @arteck
      • M mpl1338
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @mpl1338 Der entscheidende Fehler fehlt leider in dem Log.
        Bitte
        • zigbee adapter anhalten
        • log löschen
        • zigbeeadapter starten
        • 1 minute warten
        • zigbeeadapter anhalten falls er nicht durchgestartet ist.
        • log posten.
        A.
        • 1Topf1 Offline
          1Topf1 Offline
          1Topf
          schrieb am zuletzt editiert von 1Topf
          ich hab nach langer Zeit meinem Linux mal wieder ein Update gegönnt und auch gleich alle Adapter glattgezogen. Ergebnis: Zigbee 1.5.6 funzt nicht, auch nicht mit einspielen von Backup. Hab jetzt ein Downgrade auf 1.4.1 gemacht und alles geht wieder (liest man ja auch hier). Scheint ja laut Forum und auch Log am Herdsman zu liegen? Auszüge aus meinem Log:
          2021-07-21 12:42:40.482 - error: zigbee.0 (28165) Configuration is not consistent with adapter state/backup!
          2021-07-21 12:42:40.483 - error: zigbee.0 (28165) - PAN ID: configured=6754, adapter=6755
          2021-07-21 12:42:40.484 - error: zigbee.0 (28165) - Extended PAN ID: configured=00124b001940bb2e, adapter=00124b001940bb2e
          2021-07-21 12:42:40.485 - error: zigbee.0 (28165) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
          2021-07-21 12:42:40.486 - error: zigbee.0 (28165) - Channel List: configured=11, adapter=11
          2021-07-21 12:42:40.487 - error: zigbee.0 (28165) Please update configuration to prevent further issues.
          2021-07-21 12:42:40.488 - error: zigbee.0 (28165) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
          2021-07-21 12:42:40.489 - error: zigbee.0 (28165) Re-commissioning your network will require re-pairing of all devices!
          2021-07-21 12:42:40.490 - error: zigbee.0 (28165) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
          2021-07-21 12:42:40.491 - error: zigbee.0 (28165) Failed to start Zigbee
          2021-07-21 12:42:40.492 - error: zigbee.0 (28165) Error herdsman start
          2021-07-21 12:42:50.752 - error: zigbee.0 (28165) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
          2021-07-21 12:42:50.753 - error: zigbee.0 (28165) Failed to start Zigbee
          2021-07-21 12:42:50.754 - error: zigbee.0 (28165) Error herdsman start
          Kann ich bei der Einkreisung des Problems behilflich sein? 😇
          Viele Grüße,
          Andi
          • 1Topf1 1Topf
            Viele Grüße,
            Andi
            @1topf Bitte CodeTags verwenden.
            Und die PAN-Id anpassen.
            1Topf1 1 Antwort Letzte Antwort
              1Topf1 Offline
              1Topf1 Offline
              1Topf
              @thomas-braun Was und wo ist denn die PAN-ID???
              • 1Topf1 1Topf
                @1topf
                Kann im Adapter eingestellt werden. Ich weiß nur nicht ob dann alle Geräte neuangelernt werden müssen. Ist aber gut möglich.
                  @1topf
                  1Topf1 Offline
                  1Topf1 Offline
                  1Topf
                  @thomas-braun Ach ja, ok. Da ich aber wieder zurück auf 1.4.1. bin, hab ich auch keinen PAN-ID - Fehler mehr 😜 . Muß mal demnächst in Ruhe updaten, wenn die Familie abwesend ist.
                  • joggeJ Offline
                    joggeJ Offline
                    jogge
                    Moin, hab gesehen das es eine Version 1.6.6 gibt. Hat einer der Betroffenen mal getestet, ob das Update damit funktioniert?
                    Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
                    • joggeJ jogge
                      @jogge
                      Gibt auch eine 1.6.12 (im Beta-Stage). Und warum soll ein Update nicht funktionieren?
                      • joggeJ jogge
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @jogge sagte in zigbee nach update gelb:
                        Der Effekt mit den "wandernden" panID und ExtPanId beim Update von 1.4.x auf 1.6.x ist weiterhin vorhanden. Allerdings ist es üblicherweise kein Problem den Adapter auf das einzustellen was im Backup hinterlegt ist, damit wurde das bestehende Netz sowieso betrieben.
                        Wie dieser Shift zustande gekommen ist kann ich mir bisher noch nicht sauber erklären - auch da ich kein System habe welches dieses Verhalten zeigt.
                        Einzig Nutzer von einem bestimmten Koordinator mit einer bestimmten Firmware können nicht updaten - da sind aber nicht die vom OP genannten log einträge zu sehen.
                        A.
