  4. [HowTo]Echo Show 8 Audio Stream
    6.3k
audioecho show 8playertablet
56 Beiträge 7 Kommentatoren 5.3k Aufrufe 9 Beobachtet
  • liv-in-skyL liv-in-sky
    @skokarl
    hatte mal einen youtuber der ein unpack viedeo machte angeschrieben, ob silk überhaupt auf dem 15er läuft - leider hat er nie geantwortet
    skokarl
    @liv-in-sky
    super Idee..... ich such mir auch mal einen aus den USA.....
    hab aber gerade nen nie dagewesenes Problem, mir läuft der Speicher voll..... kann das was mit dem html widget und den mp4 "dauerfilm zu tun haben ?
    host.iobroker
    	2022-01-14 18:46:38.935	error	Caught by controller[1]: 6: 0xda496e v8::internal::EvacuateNewSpaceVisitor::Visit(v8::internal::HeapObject, int) [io.web.0]
    host.iobroker
    	2022-01-14 18:46:38.935	error	Caught by controller[1]: 5: 0xd73fd5 [io.web.0]
    host.iobroker
    	2022-01-14 18:46:38.935	error	Caught by controller[1]: 4: 0xbb7dc7 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.web.0]
    host.iobroker
    	2022-01-14 18:46:38.935	error	Caught by controller[1]: 3: 0xbb7a4e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.web.0]
    host.iobroker
    	2022-01-14 18:46:38.934	error	Caught by controller[1]: 2: 0x96e0af node::FatalError(char const*, char const*) [io.web.0]
    host.iobroker
    	2022-01-14 18:46:38.934	error	Caught by controller[1]: 1: 0xa389b0 node::Abort() [io.web.0]
    host.iobroker
    	2022-01-14 18:46:38.934	error	Caught by controller[1]: FATAL ERROR: MarkCompactCollector: young object promotion failed Allocation failed - JavaScript heap out of memory
    host.iobroker
    	2022-01-14 18:46:38.934	error	Caught by controller[1]: <--- JS stacktrace --->
    host.iobroker
    	2022-01-14 18:46:38.933	error	Caught by controller[0]: [8477:0x5477740] 618596 ms: Mark-sweep 1953.6 (2079.4) -> 1938.7 (2077.8) MB, 117.5 / 0.0 ms (average mu = 0.649, current mu = 0.435) allocation failure scavenge might not succeed
    host.iobroker
    	2022-01-14 18:46:38.933	error	Caught by controller[0]: [8477:0x5477740] 618388 ms: Mark-sweep 1958.0 (2082.7) -> 1933.0 (2074.8) MB, 93.9 / 0.0 ms (average mu = 0.758, current mu = 0.711) allocation failure scavenge might not succeed
    host.iobroker
    	2022-01-14 18:46:38.929	error	Caught by controller[0]: <--- Last few GCs --->
    • S skokarl
      @liv-in-sky
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      liv-in-skyL Offline
      liv-in-skyL Offline
      @skokarl
      habe bei beiden 2 jeweils videocams laufen und die zeigen den ganzen tag einen stream - ich habe aber ein extra project in der vis je echo
      hast du deine seite mal am pc geöffnet und unter den entwicklertools nachgeschaut, ob da fehler sind
      du kannst ja auch mal eine extra web instanz für den echo erzeugen und nutzen
        @skokarl
        skokarl
        schrieb am zuletzt editiert von skokarl
        @liv-in-sky
        Ich habe auf dem Tablet auch zwei Cams, und auch einen Stream von Mallorca.
        Nie Probleme gehabt.
        Das einzigste was wirklich neu ist, ist,dass ich diesen Trick mit dem mp4 file beim Echo angewendet habe,
        als ein Loop mp4 File damit der Bildschirm vom IOBroker bleibt.
        Hast Du das auch noch auf den Echos ?
        Echo ist bei mir auch ein Extra Projekt.
        crunchipC liv-in-skyL 2 Antworten Letzte Antwort
        • S skokarl
          @liv-in-sky
          crunchipC Abwesend
          crunchipC Abwesend
          @skokarl läuft bei mir auch ohne Probleme, loop video im Hintergrund und 2 Cam streams und auch die Tagesshow zusätzlich aufrufen
          • S skokarl
            @liv-in-sky
            liv-in-skyL Offline
            liv-in-skyL Offline
            @skokarl
            ja - das habe ich noch zusätzlich drin, da abends, die view die cam streams nicht mehr anzeigt und die cams abgeschalten sind
            <video height="135px" autoplay muted loop="true">
            <source src="http://192.168.178.59:8082/vis.0/armin/img/digital.mp4" type="video/mp4">
            </video>
            ich habe ab und an ein problem mit dem echo 5 - der stockt und schaltet silk ab - ich habe aber eine überwachung und dann wird die vis wieder mit my page gestartet - der echo 8 hat das problem nicht
              @skokarl
              </video>
              skokarl
              @liv-in-sky sagte in [HowTo]Echo Show 8 Audio Stream:
              @skokarl
              brauch ich das mp4 file nicht wenn ich einen Stream drin habe ?
              dann versuchs ich's mal nur mit ner Kamera.
              • S skokarl
                @skokarl
                liv-in-skyL Offline
                liv-in-skyL Offline
                @skokarl
                ich glaube nicht - habe ich nie wirklich getestet - ich habe auch noch zusätzlich das eingestellt - damit das wirklich dauernd läuft
                  @skokarl
                  skokarl
                  @skokarl
                  Ich hatte mehr Glück, war aber ne super Idee von Dir.
                  Ja, Silk ist auf dem Echo Show 15.
                  Test
                  Antwort von Chris
                  Ya, Silk.
                  • S skokarl
                    @skokarl
                    Test
                    Antwort von Chris
                    Ya, Silk.
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    @skokarl
                    ist schon verführerisch - 15" bildschirm ist entweder ein pi mit touchbildschirm oder ein tablet fürweit über 300 Euro- da ist der preis eigentlich ganz gut
                      @skokarl
                      skokarl
                      @liv-in-sky
                      für mich gibt's nichts zu überlegen, dieser ganze Tablet Kram mit Akku ist nicht ungefährlich,
                      selbst bei gesteuertem laden und entladen.
                      Ich hatte schonmal einen original aufgeblähten Akku von Samsung...egal, will hier auch keine sinnlose Diskussion anfangen.
                      Kurzum....jetzt such mal ein Touch Tablet, 15 Zoll, ohne Akku ( XORO wollte mir zu Testzwecken sogar eins leihen, die Dinger sind aber steinalt )...
                      am Ende des Tages, landest Du wieder beim Echo Show 15 .
                      Und jetzt bitte in diesem Thread von @liv-in-sky keine Diskussion, eigentlich wollte er ja nur nen Audio Stream 😁
                      Hab gerade mit Amazon gesprochen, wenn ich einen in den USA kaufe kann ich den später auf deutsch umstellen 😇
                      • S skokarl
                        @liv-in-sky
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        @skokarl bin ganz deiner meinung
                        kostet dort 218€ - habe eine cousine, die in ein paar tagen nach deutschland kommt
                        jetzt müßte ich nur noch rausfinden, ob da zoll zu zahlen wäre
                          skokarl
                          @liv-in-sky
                          frag mal nach 2 ..... 😬
                          echo 8 läuft übrigens durch, ohne mp4 file ..... nur ne Kamera mit Bild alle 2 Sekunden von der Surveillance Station
                          liv-in-skyL crunchipC 2 Antworten Letzte Antwort
                          • S skokarl
                            @liv-in-sky
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            @skokarl und der web adapter steht noch ?
                              skokarl
                              bin jetzt nicht so fit wie du
                              Wie kann ich das testen ?
                              ( hab noch den Malle Stream für meine Frau zusätzlich, hatte ich vergessen zu erwähnen. Aber das Speicherproblem ist
                              wieder weg, und der Browser bleibt schön auf dem Echo )
                              • S skokarl
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                @skokarl sagte in [HowTo]Echo Show 8 Audio Stream:
                                ich hatte das gemeint - dann ist ja alles gut und die frau ist auch nicht mehr allein :-)
                                • S skokarl
                                  @liv-in-sky
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  sicher?
                                  dachte auch anfangs es klappt, lief paar Stunden und dann gings wieder nicht mehr, musst mal durchtesten, Sprachbefehl, silk aus/ein schalten, display aus/ein....
                                    sicher?
                                    skokarl
                                    @crunchip sagte in [HowTo]Echo Show 8 Audio Stream:
                                    sicher?
                                    BOAH...... nen paar Stunden ?......hab heute morgen wieder neu eingeschaltet... warten wir mal den Tag ab.
                                    Ich werde berichten.
                                    Aber mit dem mp4 hab ich irgendwie Speicherstress.
                                      skokarl
                                      es juckt ....
                                      • S skokarl
                                        es juckt ....
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        @skokarl niemals für den Preis
                                          skokarl
                                          @crunchip
                                          ja, stimmt wohl.
