  4. Master und Slave klappt nicht.
43 Beiträge 5 Kommentatoren 3.9k Aufrufe 2 Beobachtet
    Achim55
    schrieb am zuletzt editiert von Achim55
    Morgen, ich bin gerade dabei ein Multihost zu bauen was nicht klappt.
    Der Slave startet nicht mehr :-(
    Auf dem Master habe ich folgendes eingegeben:
    root@debian:~# iobroker setup custom
    Current configuration:
    - Objects database:
     - Type: file
     - Host/Unix Socket: 0.0.0.0
     - Port: 9001
    - States database:
     - Type: redis
     - Host/Unix Socket: 127.0.0.1
     - Port: 6379
    - Data Directory: ../../iobroker-data/
    Type of objects DB [(f)ile, (r)edis, ...], default [file]: f
    Host / Unix Socket of objects DB(file), default[0.0.0.0]:
    Port of objects DB(file), default[9001]:
    Type of states DB [(f)file, (r)edis, ...], default [file]: r
    Host / Unix Socket of states DB (redis), default[127.0.0.1]: 0.0.0.0
    Port of states DB (redis), default[6379]:
    Data directory (file), default[../../iobroker-data/]: /opt/iobroker/iobroker-data/
    Host name of this machine [debian]:
    This host appears to be a Master or a Single host system. Is this correct? [Y/n]: y
    Do you want to migrate objects and states from "file/redis" to "file/redis" [y/N]:
    updating conf/iobroker.json
    root@debian:~# iobroker multihost enable
    Multihost discovery server activated on this host. If iobroker is currently not running please start befeore trying to discover this host.
    Important: Multihost discovery works with UDP packets. Make sure they are routed correctly in your network. If you use Docker you also need to configure this correctly.
    Multihost discovery will be automatically deactivated after 15 minutes. If you want to activate it permanently use the --persist flag
    Discovery authentication activated.
    Enter secret phrase for connection:
    Repeat secret phrase for connection:
    Please check the binding of the configured file server to allow remote connections.
    Please restart ioBroker for the changes to take effect: "iobroker restart"
    Multihost discovery server: enabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    file on 0.0.0.0
    States:                     redis on 0.0.0.0
    root@debian:~# iobroker restart
    root@debian:~#
    Auf dem Slave erhalte ich die Meldung :
    pi@iobrokerSLAVE:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs
    2022-01-14 09:51:22.208  - info: host.iobrokerSLAVE iobroker.js-controller version 3.3.22 js-controller starting
    2022-01-14 09:51:22.216  - info: host.iobrokerSLAVE Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2022-01-14 09:51:22.217  - info: host.iobrokerSLAVE hostname: iobrokerSLAVE, node: v12.22.9
    2022-01-14 09:51:22.218  - info: host.iobrokerSLAVE ip addresses: 192.168.178.68 2a02:8071:5057:a0c0:21e2:cbde:dc62:fd9a fe80::3307:349c:f80a:5b64
    2022-01-14 09:51:52.237  - error: host.iobrokerSLAVE No connection to databases possible, restart
    2022-01-14 09:51:52.250  - info: host.iobrokerSLAVE iobroker _restart
    2022-01-14 09:51:52.982  - info: host.iobrokerSLAVE iobroker Starting node restart.js
    • A Achim55
      - Objects database:
       - Type: file
       - Port: 9001
      - States database:
       - Type: redis
       - Port: 6379
      root@debian:~#
      @achim55 sagte in Master und Slave klappt nicht.:
      root@debian:~#
      Schon der falsche Ansatz.
      • A Achim55
        - Objects database:
         - Type: file
         - Port: 9001
        - States database:
         - Type: redis
         - Port: 6379
        root@debian:~#
        Type of objects DB [(f)ile, (r)edis, ...], default [file]: f Host / Unix Socket of objects DB(file), default[0.0.0.0]: Port of objects DB(file), default[9001]: Type of states DB [(f)file, (r)edis, ...], default [file]: r Host / Unix Socket of states DB (redis), default[127.0.0.1]: 0.0.0.0 Port of states DB (redis), default[6379]: Data directory (file), default[../../iobroker-data/]: /opt/iobroker/iobroker-data/ Host name of this machine [debian]:
        • was steht dann beim slave drin, wenn du iobroker setup custom aufrufst?
        • hast du den slave in der redis.conf freigegeben
          Achim55
          @homoran said in Master und Slave klappt nicht.:
          pi@iobrokerSLAVE:/opt/iobroker $ iobroker setup custom
          - Objects database:
            - Type: redis
            - Host/Unix Socket: 192.168.178.47
            - Port: 6379
          - States database:
            - Type: redis
            - Port: 6379
          Type of objects DB [(f)ile, (r)edis, ...], default [redis]:
          Ich kann aber noch mal alles neu ausetzten, wenn ich falsch vorgegangen bin.
          Der Slave ist auf einem Rasperry und der Master läuft unter Debian 10.
          Wäre das sinnvoller ?
          A paul53P HomoranH 3 Antworten Letzte Antwort
          • A Achim55
            - Objects database:
              - Type: redis
              - Port: 6379
            - States database:
              - Type: redis
              - Port: 6379
            Achim55
            @achim55
            ich habe mich an die Vorlage gehalten:
            https://www.iobroker.net/#de/documentation/config/multihost.md
            • A Achim55
              @achim55
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              @achim55
              Die Anleitung funktioniert einwandfrei.
              Habe dies nach dieser schon x mal gemacht.
              Dein Screenshot unter #1 zeigt diese Anleitung aber nicht.
              Und warum redis.
              Irgendwo stand mal, dass 99% der user redis nicht brauchen.
              Danke.
              • A Achim55
                - Objects database:
                  - Type: redis
                  - Port: 6379
                - States database:
                  - Type: redis
                  - Port: 6379
                @achim55 sagte:
                - Objects database:
                 - Type: redis
                 - Port: 6379
                Stimmt nicht mit Master überein.
                • A Achim55
                  - Objects database:
                    - Type: redis
                    - Port: 6379
                  - States database:
                    - Type: redis
                    - Port: 6379
                  danach sollte es auch klappen, aber anscheinend ahst du da einiges gewürfelt
                  • Objects database: - Type: redis
                  objects Database bei Master ist aber file
                  Ist denn jetzt die redis-db im Master auf für den Slave offen?
                    Achim55
                    Irgendwie habe ich da murgs gemacht :-) , ich setzte da noch einmal sauber auf.
                    Beim durcharbeiten kamen aber noch fragen auf, die nicht beschrieben sind.
                    • A Achim55
                      Du weisst doch:
                      bei Fragen fragen!
                      Dann kann man auch die Anleitung ggf. noch anpassen
                        Du weisst doch:
                        bei Fragen fragen!
                        Achim55
                        Geht nicht mittlerweile so auch ?
                        Auf dem Master mit
                        und auf dem Slave:
                        iobroker multihost connect
                        A HomoranH 2 Antworten Letzte Antwort
                        • A Achim55
                          Auf dem Master mit
                          und auf dem Slave:
                          Achim55
                          @achim55
                          Wenn ich das durchlaufen lasse kommt die Frage:
                          Host / Unix Socket of objects DB(file), default[127.0.0.1]:
                          • A Achim55
                            Auf dem Master mit
                            und auf dem Slave:
                            Sollte.
                            Aber dann sieht man nicht wenn etwas nicht korrekt ist.
                            Ich mache es immer amnuell, da weiss man was man hat ;-)
                            Was läuft wo durch?
                            Wenn auf dem Master, wo ist deine Frage dazu?
                            • A Achim55
                              @achim55
                              Achim55
                              @achim55
                              War zu schnell mit ENTER :-)
                              Habe ich mit Y bestätigt.
                              Jetzt kommt die Frage :
                              Was soll ich da machen ?
                              • bahnuhrB bahnuhr
                                @achim55
                                Und warum redis.
                                Achim55
                                @bahnuhr
                                als ich vor ca. 2Jahren damit anfing hatte ich einen Raspberry. Dann folgte ein NUC.
                                Auf dem NUC Iobrocker blank installiert und die Datensicherung vom Raspberry eingespielt.
                                Da kam wohl irgendwie redis mit rein :-(
                                • A Achim55
                                  @achim55
                                  erst mal keine Nacherzählung von Teilinformationen, sondern den Konsolenoutput im Zusammenhang als Text in Code-Tags posten.
                                  Vielleicht kann ich dann etwas damit anfangen.
                                  Wie gesagt, arbeite ich manuell
                                  • A Achim55
                                    @bahnuhr
                                    da mag dann die Kofiguration mit drin gewesen sein, aber die Datenbank muss separat installiert werden.
                                    So out of the box hätte das gar nicht laufen dürfen
                                      Achim55
                                      okay :-)
                                      - Objects database:
                                        - Type: file
                                        - Port: 9001
                                      - States database:
                                        - Type: redis
                                        - Port: 6379
                                        Achim55
                                        kann ich das migrieren damit redis raus ist und ich die DB nutzen kann ?
                                        • A Achim55
                                          Achim55
                                          @achim55
                                          Wenn ich die Installation von ioBroker installer auf dem Raspberry starte kommen Meldungen mit warning.
                                          Der Iobroker läuft aber trotz dessen. Ist das okay so ?
                                          pi@raspberrypiSlave:~ $ curl -sLf https://deb.nodesource.com/setup_12.x | sudo -E bash -
                                          ## Installing the NodeSource Node.js 12.x repo...
                                          ## Populating apt-get cache...
                                          + apt-get update
                                          Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.5 kB]
                                          Get:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
                                          Get:3 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13.2 MB]
                                          Get:4 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [246 kB]
                                          Fetched 13.5 MB in 8s (1,622 kB/s)
                                          Reading package lists... Done
                                          N: Repository 'http://archive.raspberrypi.org/debian bullseye InRelease' changed its 'Suite' value from 'unstable' to 'stable'
                                          ## Confirming "bullseye" is supported...
                                          + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/bullseye/Release'
                                          ## Adding the NodeSource signing key to your keyring...
                                          + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                                          ## Creating apt sources list file for the NodeSource Node.js 12.x repo...
                                          + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_12.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
                                          + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_12.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
                                          ## Running `apt-get update` for you...
                                          + apt-get update
                                          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Get:3 https://deb.nodesource.com/node_12.x bullseye InRelease [4,586 B]
                                          Get:4 https://deb.nodesource.com/node_12.x bullseye/main armhf Packages [777 B]
                                          Fetched 5,363 B in 1s (5,258 B/s)
                                          ## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
                                          ## You may also need development tools to build native addons:
                                               sudo apt-get install gcc g++ make
                                          ## To install the Yarn package manager, run:
                                               curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                                               echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                                               sudo apt-get update && sudo apt-get install yarn
                                          pi@raspberrypiSlave:~ $ sudo apt-get install -y nodejs
                                          The following NEW packages will be installed:
                                            nodejs
                                          0 upgraded, 1 newly installed, 0 to remove and 44 not upgraded.
                                          Need to get 15.9 MB of archives.
                                          After this operation, 86.0 MB of additional disk space will be used.
                                          Get:1 https://deb.nodesource.com/node_12.x bullseye/main armhf nodejs armhf 12.22.9-deb-1nodesource1 [15.9 MB]
                                          Fetched 15.9 MB in 3s (4,939 kB/s)
                                          Selecting previously unselected package nodejs.
                                          (Reading database ... 40796 files and directories currently installed.)
                                          Preparing to unpack .../nodejs_12.22.9-deb-1nodesource1_armhf.deb ...
                                          Unpacking nodejs (12.22.9-deb-1nodesource1) ...
                                          Setting up nodejs (12.22.9-deb-1nodesource1) ...
                                          Processing triggers for man-db (2.9.4-2) ...
                                          pi@raspberrypiSlave:~ $ curl -sLf https://iobroker.net/install.sh | bash -
                                          library: loaded
                                          Library version=2021-12-27
                                              Welcome to the ioBroker installer!
                                              Installer version: 2021-12-27
                                              You might need to enter your password a couple of times.
                                              Installing prerequisites (1/4)
                                          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                          Hit:3 https://deb.nodesource.com/node_12.x bullseye InRelease
                                          Changing npm registry to https://registry.npmjs.org
                                          Installed acl
                                          Installed gcc-c++
                                          Installed libavahi-compat-libdnssd-dev
                                          Installed libudev-dev
                                          Installed libpam0g-dev
                                          Installed git
                                          Installed libcairo2-dev
                                          Installed libpango1.0-dev
                                          Installed libjpeg-dev
                                          Installed libgif-dev
                                          Installed librsvg2-dev
                                          Installed python-dev
                                          Installed cmake
                                              Creating ioBroker user and directory (2/4)
                                          User iobroker created
                                          Directory /opt/iobroker created
                                              Installing ioBroker (3/4)
                                          In file included from ../../nan/nan.h:58,
                                                           from ../src/main.cpp:3:
                                          /home/pi/.cache/node-gyp/12.22.9/include/node/node.h:736:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                            736 |       (node::addon_register_func) (regfunc),                          \
                                          /home/pi/.cache/node-gyp/12.22.9/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
                                            770 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                          ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
                                             42 | NODE_MODULE(diskusage, Init)
                                                           from ../src/unix_dgram.cc:5:
                                          ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                                            404 | NODE_MODULE(unix_dgram, Initialize)
                                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                                          ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                             78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                                          ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                            135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                                          ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                            175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                                          ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                            215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                                          ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                            271 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                                          ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                            316 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                                          ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                            366 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                                          ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                            412 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                                          ../src/serialport.cpp: At global scope:
                                          ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                                            433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                                          ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                                            452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                                          In file included from ../../../nan/nan.h:58,
                                                           from ../src/./serialport.h:13,
                                                           from ../src/serialport.cpp:1:
                                          /home/pi/.cache/node-gyp/12.22.9/include/node/node.h:736:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                          ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
                                            486 | NODE_MODULE(serialport, init);
                                          ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                                          ../src/serialport_unix.cpp:179:82: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
                                            179 |     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
                                          ../src/serialport_unix.cpp:179:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
                                          ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                                          ../src/serialport_unix.cpp:89:84: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
                                             89 |     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
                                          ../src/serialport_unix.cpp:89:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
                                          ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
                                          ioBroker wants to make sure to deliver the most stable smart home system.
                                          To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
                                          THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
                                          For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
                                          If you want to disable the error reporting you can use the command
                                          'iobroker plugin disable sentry'
                                          This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
