  4. Admin zeigt nur noch eine leere Webseite an? [gelöst]
    6.1k
53 Beiträge 3 Kommentatoren 5.4k Aufrufe 2 Beobachtet
  • P paradoxxa
    Zuletzt hab ich den sql Adapter ausprobiert. Also installiert und einige Datenpunkte eingetragen.
    Den sql Adapter hab ich mit iobroker stop sql.0 angehalten.
    Etwas gekürzt die Logs:
    iobroker logs
    2022-01-09 17:51:15.663  - info: host.buanet-iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-01-09 17:55:54.110  - info: host.buanet-iobroker iobroker.js-controller version 3.3.22 js-controller starting
    2022-01-09 17:55:54.117  - info: host.buanet-iobroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2022-01-09 17:55:54.118  - info: host.buanet-iobroker hostname: buanet-iobroker, node: v12.22.8
    2022-01-09 17:55:54.119  - info: host.buanet-iobroker ip addresses: 172.17.0.2
    2022-01-09 17:55:55.197  - info: host.buanet-iobroker connected to Objects and States
    2022-01-09 17:55:55.406  - info: host.buanet-iobroker added notifications configuration of host
    2022-01-09 17:55:55.645  - info: host.buanet-iobroker Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-01-09 17:55:55.811  - info: host.buanet-iobroker 42 instances found
    2022-01-09 17:55:55.892  - info: host.buanet-iobroker starting 27 instances
    2022-01-09 17:55:56.021  - info: host.buanet-iobroker instance system.adapter.admin.0 started with pid 108
    2022-01-09 17:55:58.011  - info: admin.0 (108) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-01-09 17:55:58.030  - info: admin.0 (108) starting. Version 5.2.3 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.8, js-controller: 3.3.22
    2022-01-09 17:55:58.136  - info: admin.0 (108) requesting all states
    2022-01-09 17:55:58.137  - info: admin.0 (108) requesting all objects
    2022-01-09 17:56:00.140  - info: host.buanet-iobroker instance system.adapter.javascript.0 started with pid 136
    2022-01-09 17:56:00.684  - info: admin.0 (108) received all objects
    2022-01-09 17:56:01.384  - info: admin.0 (108) https server listening on port 8081
    2022-01-09 17:56:01.386  - info: admin.0 (108) Use link "https://localhost:8081" to configure.
    2022-01-09 17:56:03.691  - info: javascript.0 (136) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-01-09 17:56:03.705  - info: javascript.0 (136) starting. Version 5.2.13 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.8, js-controller: 3.3.22
    2022-01-09 17:56:03.807  - info: javascript.0 (136) requesting all states
    2022-01-09 17:56:03.809  - info: javascript.0 (136) requesting all objects
    2022-01-09 17:56:05.400  - info: host.buanet-iobroker instance system.adapter.telegram.0 started with pid 151
    2022-01-09 17:56:05.446  - info: javascript.0 (136) received all states
    2022-01-09 17:56:06.081  - info: javascript.0 (136) received all objects
    2022-01-09 17:56:08.051  - info: host.buanet-iobroker instance system.adapter.history.0 started with pid 162
    2022-01-09 17:56:09.703  - info: telegram.0 (151) starting. Version 1.10.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.8, js-controller: 3.3.22
    2022-01-09 17:56:10.708  - info: history.0 (162) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-01-09 17:56:10.735  - info: history.0 (162) starting. Version 1.9.14 in /opt/iobroker/node_modules/iobroker.history, node: v12.22.8, js-controller: 3.3.22
    2022-01-09 17:56:10.970  - info: history.0 (162) enabled logging  ....
    2022-01-09 17:56:12.768  - info: host.buanet-iobroker instance system.adapter.hm-rpc.0 started with pid 195
    2022-01-09 17:56:16.167  - info: host.buanet-iobroker instance system.adapter.hm-rega.0 started with pid 206
    2022-01-09 17:56:16.954  - info: hm-rpc.0 (195) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-01-09 17:56:17.046  - info: hm-rpc.0 (195) starting. Version 1.14.50 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.22.8, js-controller: 3.3.22
    2022-01-09 17:56:17.603  - info: hm-rpc.0 (195) xmlrpc server is trying to listen on 0.0.0.0:42001
    2022-01-09 17:56:17.606  - info: hm-rpc.0 (195) xmlrpc client is trying to connect to 192.168.188.12:42010/ with ["http://192.168.188.11:42001","buanet-iobroker:hm-rpc.0"]
    2022-01-09 17:56:18.168  - info: javascript.0 (136) Start javascript script.js.Landroid-M500
    2022-01-09 17:56:18.257  - warn: javascript.0 (136) State "Object ID" not found
    2022-01-09 17:56:18.261  - warn: javascript.0 (136)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1439:20)
    2022-01-09 17:56:18.263  - warn: javascript.0 (136)     at script.js.Landroid-M500:223:1
    2022-01-09 17:56:18.264  - warn: javascript.0 (136)     at script.js.Landroid-M500:488:3
    2022-01-09 17:56:18.267  - info: javascript.0 (136) script.js.Landroid-M500: ...
    2022-01-09 17:56:20.366  - info: host.buanet-iobroker instance system.adapter.sonoff.0 started with pid 221
    2022-01-09 17:56:21.595  - info: hm-rega.0 (206) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-01-09 17:56:21.659  - info: hm-rega.0 (206) starting. Version 3.0.33 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v12.22.8, js-controller: 3.3.22
    2022-01-09 17:56:22.085  - info: hm-rega.0 (206) subscribe .BidCoS-RF.50.PRESS_SHORT
    2022-01-09 17:56:22.295  - info: hm-rega.0 (206) ReGaHSS 192.168.188.12 up
    2022-01-09 17:56:22.784  - info: hm-rega.0 (206) time difference local-ccu 1s
    2022-01-09 17:56:23.212  - info: sonoff.0 (221) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-01-09 17:56:23.268  - warn: javascript.0 (136) script.js.Landroid-M500: Aktuelle Systemzeit: 17:56:23
    2022-01-09 17:56:23.271  - info: sonoff.0 (221) starting. Version 2.4.5 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.8, js-controller: 3.3.22
    2022-01-09 17:56:23.364  - info: sonoff.0 (221) Starting MQTT authenticated  server on port 1883
    2022-01-09 17:56:24.063  - info: host.buanet-iobroker instance system.adapter.tr-064.0 started with pid 241
    2022-01-09 17:56:24.838  - info: hm-rega.0 (206) request state values
    2022-01-09 17:56:27.165  - info: tr-064.0 (241) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-01-09 17:56:27.251  - info: tr-064.0 (241) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v12.22.8, js-controller: 3.3.22
    2022-01-09 17:56:28.319  - info: host.buanet-iobroker instance system.adapter.ping.0 started with pid 268
    2022-01-09 17:56:29.137  - info: hm-rega.0 (206) Updated all datapoints
    2022-01-09 17:56:29.150  - info: hm-rega.0 (206) got 10 variables
    2022-01-09 17:56:29.521  - info: hm-rega.0 (206) added/updated 10 variables
    2022-01-09 17:56:29.522  - info: hm-rega.0 (206) deleted 0 variables
    2022-01-09 17:56:29.540  - info: hm-rega.0 (206) got 7 programs
    2022-01-09 17:56:29.562  - info: hm-rega.0 (206) update rooms to enum.rooms
    2022-01-09 17:56:29.717  - info: hm-rega.0 (206) update functions to enum.functions
    2022-01-09 17:56:29.891  - info: hm-rega.0 (206) update favorites to enum.favorites
    2022-01-09 17:56:30.116  - info: hm-rega.0 (206) added/updated 7 programs
    2022-01-09 17:56:30.117  - info: hm-rega.0 (206) deleted 0 programs
    2022-01-09 17:56:30.741  - info: ping.0 (268) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-01-09 17:56:30.757  - info: ping.0 (268) starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.ping, node: v12.22.8, js-controller: 3.3.22
    2022-01-09 17:56:31.970  - info: host.buanet-iobroker instance system.adapter.modbus.0 started with pid 284
    2022-01-09 17:56:33.549  - info: modbus.0 (284) Plugin sentry Sentry Plugin disabled for this process because data reporting is disabled on instance
    2022-01-09 17:56:33.606  - info: modbus.0 (284) starting. Version 3.4.14 in /opt/iobroker/node_modules/iobroker.modbus, node: v12.22.8, js-controller: 3.3.22
    2022-01-09 17:56:33.800  - info: javascript.0 (136) script.js.EnergieManager.Heizteppich: Heizteppich Modbus TCP Status Alive aus
    2022-01-09 17:56:33.817  - warn: sonoff.0 (221) Client "DVES_F944E9" not connected
    2022-01-09 17:56:35.105  - info: modbus.0 (284) Connected to slave 192.168.188.43
    2022-01-09 17:56:35.133  - info: javascript.0 (136) script.js.EnergieManager.Heizteppich: Heizteppich Modbus TCP Status Alive an
    2022-01-09 17:56:35.184  - warn: sonoff.0 (221) Client "DVES_F944E9" not connected
    2022-01-09 17:56:35.971  - info: host.buanet-iobroker instance system.adapter.info.0 started with pid 299
    2022-01-09 17:56:38.718  - info: javascript.0 (136) script.js.EnergieManager.Tasmota-Verbrauch: Tasmota Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 7
    2022-01-09 17:56:38.808  - info: info.0 (299) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-01-09 17:56:38.887  - info: javascript.0 (136) script.js.EnergieManager.PVA-Statistik: Tasmota Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 3
    2022-01-09 17:56:38.899  - info: info.0 (299) starting. Version 1.9.8 in /opt/iobroker/node_modules/iobroker.info, node: v12.22.8, js-controller: 3.3.22
    2022-01-09 17:56:38.920  - info: javascript.0 (136) script.js.EnergieManager.ETA-Statistik: Tasmota Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 2
    2022-01-09 17:56:39.006  - info: info.0 (299) Reading/updating systemdata.
    2022-01-09 17:56:40.116  - info: host.buanet-iobroker instance system.adapter.web.0 started with pid 355
    2022-01-09 17:56:40.360  - info: info.0 (299) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
    2022-01-09 17:56:40.438  - info: info.0 (299) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
    2022-01-09 17:56:40.618  - info: info.0 (299) cpu Temp res = {"main":35,"cores":[33,34],"max":35,"socket":[],"chipset":null}
    2022-01-09 17:56:43.987  - info: host.buanet-iobroker instance system.adapter.worx.0 started with pid 554
    2022-01-09 17:56:47.709  - info: hm-rpc.0 (195) Connected
    2022-01-09 17:56:47.724  - info: hm-rpc.0 (195) xmlrpc <- listDevices ["buanet-iobroker:hm-rpc.0"]
    2022-01-09 17:56:48.043  - info: hm-rpc.0 (195) xmlrpc -> 0 devices
    2022-01-09 17:56:48.300  - info: host.buanet-iobroker instance system.adapter.text2command.0 started with pid 678
    2022-01-09 17:56:48.989  - info: worx.0 (554) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-01-09 17:56:49.043  - info: worx.0 (554) starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.worx, node: v12.22.8, js-controller: 3.3.22
    2022-01-09 17:56:49.123  - info: worx.0 (554) worx is selected
    2022-01-09 17:56:49.669  - info: hm-rpc.0 (195) xmlrpc <- newDevices 212
    2022-01-09 17:56:49.769  - info: hm-rpc.0 (195) new HMIP devices/channels after filter: 0
    2022-01-09 17:56:50.479  - warn: admin.0 (108) Cannot parse "undefined"
    2022-01-09 17:56:50.512  - info: text2command.0 (678) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-01-09 17:56:50.535  - info: text2command.0 (678) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.text2command, node: v12.22.8, js-controller: 3.3.22
    2022-01-09 17:56:50.943  - info: worx.0 (554) found DoubleShedule, create states...
    2022-01-09 17:56:50.945  - info: worx.0 (554) found OneTimeShedule, create states...
    2022-01-09 17:56:50.945  - info: worx.0 (554) found PartyModus, create states...
    2022-01-09 17:56:53.746  - info: vis.0 (697) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v12.22.8, js-controller: 3.3.22
    2022-01-09 17:56:54.040  - info: vis.0 (697) vis license is OK.
    2022-01-09 17:56:55.324  - info: vis.0 (697) Terminated (NO_ERROR): Without reason
    2022-01-09 17:56:55.920  - info: host.buanet-iobroker instance system.adapter.vis.0 terminated while should be started once
    2022-01-09 17:56:56.198  - info: host.buanet-iobroker instance scheduled system.adapter.daswetter.0 */15 * * * *
    2022-01-09 17:56:56.218  - info: host.buanet-iobroker instance system.adapter.daswetter.0 started with pid 718
    2022-01-09 17:57:00.082  - info: host.buanet-iobroker instance system.adapter.shelly.0 started with pid 747
    2022-01-09 17:57:02.552  - info: shelly.0 (747) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-01-09 17:57:02.575  - info: shelly.0 (747) starting. Version 4.0.8 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.22.8, js-controller: 3.3.22
    2022-01-09 17:57:02.610  - info: shelly.0 (747) Starting Adapter shelly.0 in version 4.0.8
    2022-01-09 17:57:02.759  - info: shelly.0 (747) Starting Shelly adapter in MQTT modus. Listening on 0.0.0.0:1882
    2022-01-09 17:57:04.239  - info: host.buanet-iobroker instance system.adapter.echarts.0 started with pid 762
    2022-01-09 17:57:06.016  - info: sonoff.0 (221) Client [DVES_CBDCE2] connected with secret 1641747426007_9197
    2022-01-09 17:57:06.331  - info: sonoff.0 (221) Client [DVES_WASCHMASCHINE_224D63] connected with secret 1641747426328_4018
    2022-01-09 17:57:06.655  - info: sonoff.0 (221) Client [DVES_F944E9] connected with secret 1641747426654_5721
    2022-01-09 17:57:06.679  - info: sonoff.0 (221) Client [DVES_PI_92DC6D] connected with secret 1641747426678_6317
    2022-01-09 17:57:06.698  - info: sonoff.0 (221) Client [DVES_F977E7] connected with secret 1641747426694_2357
    2022-01-09 17:57:06.722  - info: sonoff.0 (221) Client [DVES_F9252E] connected with secret 1641747426721_8271
    2022-01-09 17:57:06.732  - info: sonoff.0 (221) Client [DVES_TROCKNER_923E8C] connected with secret 1641747426731_8271
    2022-01-09 17:57:06.746  - info: sonoff.0 (221) Client [DVES_TV_92E227] connected with secret 1641747426745_6408
    2022-01-09 17:57:06.840  - info: echarts.0 (762) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.echarts, node: v12.22.8, js-controller: 3.3.22
    GlasfaserG Offline
    GlasfaserG Offline
    @paradoxxa sagte in Admin zeigt nur noch eine leere Webseite an?:
    Du hast Edit gemacht ...
    Admin ist doch da
    P 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      Weil es nicht mehr so auftritt
      Was ist jetzt hiermit , auch nicht mehr aktuell !?
      Nach einem Neustart des buanet-iobroker Containers bleibt die Admin Webseite leer (eine weiße Webseite).
      paradoxxa
      schrieb am zuletzt editiert von paradoxxa
      @glasfaser said in Admin zeigt nur noch eine leere Webseite an?:
      Doch, es ist noch aktuell. Die Logs sehen jetzt so an der Stelle aus:
      -----                Step 4 of 5: Applying special settings                -----
      Some adapters have special requirements/ settings which can be activated by the use of environment variables.
      For more information take a look at readme.md on Github!
      -----                    Step 5 of 5: ioBroker startup                     -----
      Starting ioBroker...
      ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting]
      host.buanet-iobroker-Broken check instance "system.adapter.admin.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.javascript.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.email.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.telegram.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.history.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.hm-rpc.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.hm-rega.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.sonoff.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.tr-064.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.ping.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.modbus.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.info.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.backitup.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.web.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.worx.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.text2command.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.vis.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.vis-material.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.vis-material-webfont.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.vw-connect.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.web-speedy.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.vis-inventwo.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.vis-material-advanced.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.vis-hqwidgets.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.feiertage.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.daswetter.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.shelly.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.sql.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.vis-jqui-mfd.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.vis-metro.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.vis-canvas-gauges.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.vis-justgage.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.vis-materialdesign.0" for host "buanet-iobroker-Broken"
      host.buanet-iobroker-Broken check instance "system.adapter.echarts.0" for host "buanet-iobroker-Broken"
      /bin/sh: 1: iw: not found
      /bin/sh: 1: hcitool: not found
      • P paradoxxa
        warum hast du das Log von der Syn rausgenommen .
        Weil es nicht mehr so auftritt ;)
        iobroker list instances
        + system.adapter.admin.0                  : admin                 : buanet-iobroker-Broken                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          system.adapter.backitup.0               : backitup              : buanet-iobroker-Broken                   - disabled
          system.adapter.daswetter.0              : daswetter             : buanet-iobroker-Broken                   -  enabled
        + system.adapter.echarts.0                : echarts               : buanet-iobroker-Broken                   -  enabled
          system.adapter.email.0                  : email                 : buanet-iobroker-Broken                   - disabled
          system.adapter.feiertage.0              : feiertage             : buanet-iobroker-Broken                   - disabled
          system.adapter.flot.0                   : flot                  : buanet-iobroker-Broken                   -  enabled
        + system.adapter.history.0                : history               : buanet-iobroker-Broken                   -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : buanet-iobroker-Broken                   -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : buanet-iobroker-Broken                   -  enabled, port: 42001
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: buanet-iobroker-Broken                   -  enabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : buanet-iobroker-Broken                   -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : buanet-iobroker-Broken                   -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: buanet-iobroker-Broken                   -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : buanet-iobroker-Broken                   -  enabled
        + system.adapter.info.0                   : info                  : buanet-iobroker-Broken                   -  enabled
        + system.adapter.javascript.0             : javascript            : buanet-iobroker-Broken                   -  enabled
        + system.adapter.modbus.0                 : modbus                : buanet-iobroker-Broken                   -  enabled
        + system.adapter.ping.0                   : ping                  : buanet-iobroker-Broken                   -  enabled
          system.adapter.rickshaw.0               : rickshaw              : buanet-iobroker-Broken                   -  enabled
        + system.adapter.shelly.0                 : shelly                : buanet-iobroker-Broken                   -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sonoff.0                 : sonoff                : buanet-iobroker-Broken                   -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.sql.0                    : sql                   : buanet-iobroker-Broken                   - disabled
        + system.adapter.telegram.0               : telegram              : buanet-iobroker-Broken                   -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : buanet-iobroker-Broken                   -  enabled
        + system.adapter.tr-064.0                 : tr-064                : buanet-iobroker-Broken                   -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : buanet-iobroker-Broken                   -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : buanet-iobroker-Broken                   -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : buanet-iobroker-Broken                   -  enabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : buanet-iobroker-Broken                   - disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : buanet-iobroker-Broken                   -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : buanet-iobroker-Broken                   -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : buanet-iobroker-Broken                   -  enabled
          system.adapter.vis-material-webfont.0   : vis-material-webfont  : buanet-iobroker-Broken                   -  enabled
          system.adapter.vis-material.0           : vis-material          : buanet-iobroker-Broken                   -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : buanet-iobroker-Broken                   -  enabled
          system.adapter.vis-metro.0              : vis-metro             : buanet-iobroker-Broken                   -  enabled
          system.adapter.vis.0                    : vis                   : buanet-iobroker-Broken                   -  enabled
          system.adapter.vw-connect.0             : vw-connect            : buanet-iobroker-Broken                   - disabled
          system.adapter.web-speedy.0             : web-speedy            : buanet-iobroker-Broken                   - disabled
        + system.adapter.web.0                    : web                   : buanet-iobroker-Broken                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.worx.0                   : worx                  : buanet-iobroker-Broken                   -  enabled
        + instance is alive
         iobroker update -i
        hash changed or no sources cached => force download of new sources
        update done
        Adapter    "admin"         : 5.2.3    , installed 5.2.3
        Adapter    "backitup"      : 2.2.2    , installed 2.2.2
        Adapter    "daswetter"     : 3.0.9    , installed 3.0.9
        Adapter    "echarts"       : 1.0.3    , installed 1.0.3
        Adapter    "email"         : 1.0.10   , installed 1.0.10
        Adapter    "feiertage"     : 1.1.0    , installed 1.1.0
        Adapter    "flot"          : 1.10.7   , installed 1.10.7
        Adapter    "history"       : 1.9.14   , installed 1.9.14
        Adapter    "hm-rega"       : 3.0.33   , installed 3.0.33
        Adapter    "hm-rpc"        : 1.14.50  , installed 1.14.50
        Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
        Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
        Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
        Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
        Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
        Adapter    "info"          : 1.9.8    , installed 1.9.8
        Adapter    "javascript"    : 5.2.13   , installed 5.2.13
        Controller "js-controller" : 3.3.22   , installed 3.3.22
        Adapter    "modbus"        : 3.4.14   , installed 3.4.14
        Adapter    "ping"          : 1.5.0    , installed 1.5.0
        Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
        Adapter    "shelly"        : 4.0.7    , installed 4.0.8
        Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
        Adapter    "socketio"      : 3.1.4    , installed 3.1.4
        Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
        Adapter    "sql"           : 1.15.7   , installed 1.15.7
        Adapter    "telegram"      : 1.10.0   , installed 1.10.0
        Adapter    "text2command"  : 2.1.1    , installed 2.1.1
        Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
        Adapter    "vis"           : 1.4.5    , installed 1.4.5
        Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
        Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
        Adapter    "vis-icontwo"   : 0.84.0   , installed 0.84.0
        Adapter    "vis-inventwo"  : 3.2.0    , installed 3.2.0
        Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
        Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
        Adapter    "vis-material-advanced": 1.7.2   , installed 1.7.2
        Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
        Adapter    "vw-connect"    : 0.0.45   , installed 0.0.45
        Adapter    "web"           : 3.4.9    , installed 3.4.9
        Adapter    "worx"          : 1.5.5    , installed 1.5.5
        r
        iobroker status
        Objects type: file
        States  type: file
        iobroker version
        3.3.22
        which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt updat
        e && apt policy nodejs
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v12.22.8
        v12.22.8
        6.14.15
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 https://deb.nodesource.com/node_12.x bullseye InRelease
        Reading package lists... Done
        All packages are up to date.
        nodejs:
          Installed: 12.22.8-deb-1nodesource1
          Candidate: 12.22.8-deb-1nodesource1
          Version table:
         *** 12.22.8-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x bullseye/main amd64 Packages
             12.22.5~dfsg-2~11u1 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
        GlasfaserG Offline
        GlasfaserG Offline
        • system.adapter.admin.0 : admin : buanet-iobroker-Broken - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        Was heißt bei dir weiße Seite , kann ich nicht viel mit anfangen !?
        Browser Cache mal geleert .
        oder Stelle mal um
        iobroker set admin.0 --secure false
          Admin ist doch da
          paradoxxa
          Admin ist doch da
          Ja, es wird aber nicht die oberfläche geladen sondern nichts angezeigt.
          Der Seitenquelltext gibt folgendes her:
          <!doctype html><html lang="en"><head><meta charset="utf-8"/><link rel="icon" href="./favicon.ico"/><meta name="viewport" content="width=device-width,initial-scale=1,user-scalable=no"/><meta name="theme-color" content="#000000"/><meta name="description" content="admin - ioBroker"/><link rel="apple-touch-icon" href="./logo192.png"/><link rel="stylesheet" href="./css/leaflet.css"/><link rel="manifest" href="./manifest.json"/><script type="text/javascript" onerror="setTimeout(function(){window.location.reload()}, 5000)" src="./lib/js/socket.io.js"></script><script type="text/javascript" src="./lib/js/sparkline.js"></script><title>Admin</title><script>window.loginHideLogo="false",window.loginMotto="",window.login="true",window.loginLogo="",window.loginLink="",window.loginTitle="",window.vendorPrefix="",window.loginBackgroundColor="",window.disableDataReporting="@@disableDataReporting@@"</script><style>body{background-color:;background-image:url();background-size:cover}.root{background-color:rgba(255,255,255,.87);border-radius:10px}.unsupported{width:200px;background-color:#aaa;margin:auto;margin-top:3rem;padding:10px;line-height:25px;border-radius:4px;text-align:center}.leaflet-container{height:400px;width:100%}</style><script>window.addEventListener("load",(function e(n){window.removeEventListener("load",e,!1);if(window.navigator.userAgent.indexOf("MSIE ")>0||navigator.userAgent.match(/Trident.*rv\:11\./)){const e=document.getElementById("root");e.classList.add("unsupported"),e.innerHTML="Browser is not supported. Please use Firefox or Chrome."}}),!1)</script><link href="./static/css/5.66aabfbf.chunk.css" rel="stylesheet"><link href="./static/css/main.950070b4.chunk.css" rel="stylesheet"></head><body><noscript>You need to enable JavaScript to run this app.</noscript><div id="root"></div><script>!function(e){function t(t){for(var n,o,u=t[0],f=t[1],i=t[2],l=0,d=[];l<u.length;l++)o=u[l],Object.prototype.hasOwnProperty.call(a,o)&&a[o]&&d.push(a[o][0]),a[o]=0;for(n in f)Object.prototype.hasOwnProperty.call(f,n)&&(e[n]=f[n]);for(s&&s(t);d.length;)d.shift()();return c.push.apply(c,i||[]),r()}function r(){for(var e,t=0;t<c.length;t++){for(var r=c[t],n=!0,o=1;o<r.length;o++){var f=r[o];0!==a[f]&&(n=!1)}n&&(c.splice(t--,1),e=u(u.s=r[0]))}return e}var n={},o={4:0},a={4:0},c=[];function u(t){if(n[t])return n[t].exports;var r=n[t]={i:t,l:!1,exports:{}};return e[t].call(r.exports,r,r.exports,u),r.l=!0,r.exports}u.e=function(e){var t=[];o[e]?t.push(o[e]):0!==o[e]&&{6:1}[e]&&t.push(o[e]=new Promise((function(t,r){for(var n="static/css/"+({}[e]||e)+"."+{0:"31d6cfe0",1:"31d6cfe0",2:"31d6cfe0",6:"41d5431a",7:"31d6cfe0",8:"31d6cfe0",9:"31d6cfe0",10:"31d6cfe0",11:"31d6cfe0",12:"31d6cfe0",13:"31d6cfe0",14:"31d6cfe0",15:"31d6cfe0",16:"31d6cfe0"}[e]+".chunk.css",a=u.p+n,c=document.getElementsByTagName("link"),f=0;f<c.length;f++){var i=(s=c[f]).getAttribute("data-href")||s.getAttribute("href");if("stylesheet"===s.rel&&(i===n||i===a))return t()}var l=document.getElementsByTagName("style");for(f=0;f<l.length;f++){var s;if((i=(s=l[f]).getAttribute("data-href"))===n||i===a)return t()}var d=document.createElement("link");d.rel="stylesheet",d.type="text/css",d.onload=t,d.onerror=function(t){var n=t&&t.target&&t.target.src||a,c=new Error("Loading CSS chunk "+e+" failed.\n("+n+")");c.code="CSS_CHUNK_LOAD_FAILED",c.request=n,delete o[e],d.parentNode.removeChild(d),r(c)},d.href=a,document.getElementsByTagName("head")[0].appendChild(d)})).then((function(){o[e]=0})));var r=a[e];if(0!==r)if(r)t.push(r[2]);else{var n=new Promise((function(t,n){r=a[e]=[t,n]}));t.push(r[2]=n);var c,f=document.createElement("script");f.charset="utf-8",f.timeout=120,u.nc&&f.setAttribute("nonce",u.nc),f.src=function(e){return u.p+"static/js/"+({}[e]||e)+"."+{0:"0349f77e",1:"961894c5",2:"3d1b50fc",6:"630fb469",7:"34479e94",8:"d988ca16",9:"992f72fe",10:"c6cfac01",11:"5d187238",12:"490971aa",13:"7d21ae26",14:"f5e1a630",15:"1f242916",16:"bbbe6952"}[e]+".chunk.js"}(e);var i=new Error;c=function(t){f.onerror=f.onload=null,clearTimeout(l);var r=a[e];if(0!==r){if(r){var n=t&&("load"===t.type?"missing":t.type),o=t&&t.target&&t.target.src;i.message="Loading chunk "+e+" failed.\n("+n+": "+o+")",i.name="ChunkLoadError",i.type=n,i.request=o,r[1](i)}a[e]=void 0}};var l=setTimeout((function(){c({type:"timeout",target:f})}),12e4);f.onerror=f.onload=c,document.head.appendChild(f)}return Promise.all(t)},u.m=e,u.c=n,u.d=function(e,t,r){u.o(e,t)||Object.defineProperty(e,t,{enumerable:!0,get:r})},u.r=function(e){"undefined"!=typeof Symbol&&Symbol.toStringTag&&Object.defineProperty(e,Symbol.toStringTag,{value:"Module"}),Object.defineProperty(e,"__esModule",{value:!0})},u.t=function(e,t){if(1&t&&(e=u(e)),8&t)return e;if(4&t&&"object"==typeof e&&e&&e.__esModule)return e;var r=Object.create(null);if(u.r(r),Object.defineProperty(r,"default",{enumerable:!0,value:e}),2&t&&"string"!=typeof e)for(var n in e)u.d(r,n,function(t){return e[t]}.bind(null,n));return r},u.n=function(e){var t=e&&e.__esModule?function(){return e.default}:function(){return e};return u.d(t,"a",t),t},u.o=function(e,t){return Object.prototype.hasOwnProperty.call(e,t)},u.p="./",u.oe=function(e){throw console.error(e),e};var f=this["webpackJsonpsrc-rx"]=this["webpackJsonpsrc-rx"]||[],i=f.push.bind(f);f.push=t,f=f.slice();for(var l=0;l<f.length;l++)t(f[l]);var s=i;r()}([])</script><script src="./static/js/5.bde6ca2f.chunk.js"></script><script src="./static/js/main.1892293b.chunk.js"></script></body></html>
            oder Stelle mal um
            paradoxxa
            oder Stelle mal um
            Nach dem Umstellen bleibt das Ergebnis mit http://ip:8081 gleich. Der Browser zeigt nur eine weiße Fläche an.
            • P paradoxxa
              oder Stelle mal um
              GlasfaserG Offline
              GlasfaserG Offline
              Anderen Browser mal genutzt.
              wenn nicht mache mal :
              iob u admin
              P 2 Antworten Letzte Antwort
                iob u admin
                paradoxxa
                Ja klar, Chrome und Edge und normal Firefox.
                • P paradoxxa
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Ja klar,
                  So klar ist das nicht ... das weist nur du ... deshalb meine Frage dazu .
                  Was ist jetzt mit dem Befehl geworden
                    iob u admin
                    paradoxxa
                    iob u admin
                    iob u admin
                    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
                    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json appli
                    cation/json
                    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/
                    json
                    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/
                    json
                    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/
                    json
                    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/
                    json
                    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/
                    json
                    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/
                    json
                    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/
                    json
                    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/
                    json
                    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/
                    json
                    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                    r
                    • P paradoxxa
                      iob u admin
                      iob u admin
                      cation/json
                      json
                      json
                      json
                      json
                      json
                      json
                      json
                      json
                      json
                      r
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @paradoxxa
                      Ja ... und Admin erreichbar
                        @paradoxxa
                        paradoxxa
                        @paradoxxa
                        Leider Nein
                        • P paradoxxa
                          iobroker logs
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Wie ist dein Container aufgebaut !?
                          Auf welchen System !?
                          bzw. unter welcher IP ist ioBroker erreichbar
                            paradoxxa
                            Das läuft auf einer Synology NAS und hat die IP 192.168.188.11
                            • GlasfaserG Offline
                              GlasfaserG Offline
                              @glasfaser sagte in Admin zeigt nur noch eine leere Webseite an?:
                              in bridge /
                              Macvlan
                              Gleichzeitig funktionieren die andern Webdienste wie VIS Runtime, VIS Editor und der FLOT Editor.
                              diese sind erreichbar !?
                                in bridge /
                                Macvlan
                                paradoxxa
                                in bridge /
                                Macvlan
                                Genau, das ist im Bridge Mode
                                Die anderen Dienste sind erreichbar und funktional.
                                  GlasfaserG Offline
                                  @paradoxxa
                                  Admin zusätzlich installieren ;
                                  iobroker add admin --port 8089
                                  ENV auch eintragen
                                  dann ?
                                  192.168.188.11:8089
                                  • P paradoxxa
                                    in bridge /
                                    Macvlan
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    im Bridge Mode
                                    Zeige mal deine Einstellungen davon . inkl. ENV und der Port Einstellungen .
                                    Die kann ich oben nicht im Syn Log von dir sehen
                                      @paradoxxa
                                      ENV auch eintragen
                                      dann ?
                                      192.168.188.11:8089
                                      paradoxxa
                                      ENV auch eintragen
                                      dann ?
                                      192.168.188.11:8089
                                      Das verhält sich genau gleich wie die andere Instanz. Nichts wird angezeigt.
                                        im Bridge Mode
                                        paradoxxa
                                        • P paradoxxa
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @paradoxxa
                                          fehlt da jetzt nicht 8089
