  4. SHP-15+Zigbee Adp.: "TS011F" not described in statesMapping.
    5.6k
zigbee adapterconbee 2blitzwolf bw-shp15
60 Beiträge 14 Kommentatoren 8.8k Aufrufe 13 Beobachtet
    Schmetterfliege
    schrieb am zuletzt editiert von Schmetterfliege
    Also,
    die Debug Messages habe ich ausgeben lassen, die fehlenden Werte finde ich da allerdings nicht.
    2021-12-17 12:21:05.335 - warn: zigbee.0 (23201) ELEVATED: User stateChange zigbee.0.84ba20fffe77b200.device_query {"val":true,"ack":false,"ts":1639740065331,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1639690785654}
    2021-12-17 12:21:05.342 - warn: zigbee.0 (23201) ELEVATED Change state 'device_query' at device 0x84ba20fffe77b200 type 'TS011F_plug_1'
    2021-12-17 12:21:05.439 - warn: zigbee.0 (23201) ELEVATED publishToState: message received '{"linkquality":199}' from device 84ba20fffe77b200 type 'TS011F_plug_1'
    2021-12-17 12:21:05.440 - warn: zigbee.0 (23201) ELEVATED publishToState: value generated '199' from device 84ba20fffe77b200 for 'Link quality'
    2021-12-17 12:21:05.440 - warn: zigbee.0 (23201) ELEVATED publishToState: message received '{"msg_from_zigbee":"{\"type\":\"readResponse\",\"data\":{\"onOff\":1},\"linkquality\":199,\"groupID\":null,\"cluster\":\"genOnOff\",\"meta\":{\"zclTransactionSequenceNumber\":222,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 84ba20fffe77b200 type 'TS011F_plug_1'
    2021-12-17 12:21:05.440 - warn: zigbee.0 (23201) ELEVATED publishToState: value generated '"{\"type\":\"readResponse\",\"data\":{\"onOff\":1},\"linkquality\":199,\"groupID\":null,\"cluster\":\"genOnOff\",\"meta\":{\"zclTransactionSequenceNumber\":222,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 84ba20fffe77b200 for 'Message from Zigbee'
    2021-12-17 12:21:05.442 - warn: zigbee.0 (23201) ELEVATED publishToState: message received '{"state":"ON"}' from device 84ba20fffe77b200 type 'TS011F_plug_1'
    2021-12-17 12:21:05.442 - warn: zigbee.0 (23201) ELEVATED publishToState: value generated 'true' from device 84ba20fffe77b200 for 'On/off state of the switch'
    2021-12-17 12:21:05.524 - warn: zigbee.0 (23201) ELEVATED publishToState: message received '{"linkquality":207}' from device 84ba20fffe77b200 type 'TS011F_plug_1'
    2021-12-17 12:21:05.525 - warn: zigbee.0 (23201) ELEVATED publishToState: value generated '207' from device 84ba20fffe77b200 for 'Link quality'
    2021-12-17 12:21:05.525 - warn: zigbee.0 (23201) ELEVATED publishToState: message received '{"msg_from_zigbee":"{\"type\":\"readResponse\",\"data\":{\"onOff\":1},\"linkquality\":207,\"groupID\":null,\"cluster\":\"genOnOff\",\"meta\":{\"zclTransactionSequenceNumber\":223,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 84ba20fffe77b200 type 'TS011F_plug_1'
    2021-12-17 12:21:05.525 - warn: zigbee.0 (23201) ELEVATED publishToState: value generated '"{\"type\":\"readResponse\",\"data\":{\"onOff\":1},\"linkquality\":207,\"groupID\":null,\"cluster\":\"genOnOff\",\"meta\":{\"zclTransactionSequenceNumber\":223,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 84ba20fffe77b200 for 'Message from Zigbee'
    2021-12-17 12:21:05.527 - warn: zigbee.0 (23201) ELEVATED publishToState: message received '{"state":"ON"}' from device 84ba20fffe77b200 type 'TS011F_plug_1'
    2021-12-17 12:21:05.527 - warn: zigbee.0 (23201) ELEVATED publishToState: value generated 'true' from device 84ba20fffe77b200 for 'On/off state of the switch'
    2021-12-17 12:21:05.609 - warn: zigbee.0 (23201) ELEVATED publishToState: message received '{"linkquality":199}' from device 84ba20fffe77b200 type 'TS011F_plug_1'
    2021-12-17 12:21:05.609 - warn: zigbee.0 (23201) ELEVATED publishToState: value generated '199' from device 84ba20fffe77b200 for 'Link quality'
    2021-12-17 12:21:05.610 - warn: zigbee.0 (23201) ELEVATED publishToState: message received '{"msg_from_zigbee":"{\"type\":\"readResponse\",\"data\":{\"onOff\":1},\"linkquality\":199,\"groupID\":null,\"cluster\":\"genOnOff\",\"meta\":{\"zclTransactionSequenceNumber\":224,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 84ba20fffe77b200 type 'TS011F_plug_1'
    2021-12-17 12:21:05.610 - warn: zigbee.0 (23201) ELEVATED publishToState: value generated '"{\"type\":\"readResponse\",\"data\":{\"onOff\":1},\"linkquality\":199,\"groupID\":null,\"cluster\":\"genOnOff\",\"meta\":{\"zclTransactionSequenceNumber\":224,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 84ba20fffe77b200 for 'Message from Zigbee'
    2021-12-17 12:21:05.612 - warn: zigbee.0 (23201) ELEVATED publishToState: message received '{"state":"ON"}' from device 84ba20fffe77b200 type 'TS011F_plug_1'
    2021-12-17 12:21:05.613 - warn: zigbee.0 (23201) ELEVATED publishToState: value generated 'true' from device 84ba20fffe77b200 for 'On/off state of the switch'
    @Asgothian
    Im Herdsman-converters Github sind einige Issues diesbezüglich offen, und da hat jemand einen Converter gebastelt der die Devices dann auch alle 60 sec pollt.
    Ich verlinke das mal hier: LINK
    Ich habe mir das mal angeschaut, und zumindest alle libraries existieren auf meinem Pi.
    Mal unabhängig von den Versionen - kann ich einfach aus meiner Tuya.js den Fingerprint wieder löschen, und stattdessen dieses File auch im selben Ordner ablegen - und er würde dann beim pairen das Gerät finden und alle 60 Sekunden pollen?
    Oder kann ich ggfs in Tuya.js einfach einen neuen Converter machen und das von dem User copy-pasten?
    @alexzi
    Zunächst solltest du prüfen, ob dein converter genau so aussieht wie er sollte.
    Dazu auf dem Pi (oder was du benutzt) unter /opt/iobroker/node_modules/zigbee-herdsman-converters/devices zb. mit "nano" die Datei Tuya.js öffnen. Dort dann nach "BW-SHP15" suchen, um zu dem entsprechenden Converter zu kommen.
    Oben sind die Fingerprints, darunter dann was der Converter macht. Der relevante Teil in der Tuya.js sieht dann so aus:
           fingerprint: [
               {modelID: 'TS011F', manufacturerName: '_TZ3000_5f43h46b'},
               {modelID: 'TS011F', manufacturerName: '_TZ3000_cphmq0q7'},
               {modelID: 'TS011F', manufacturerName: '_TZ3000_dpo1ysak'},
               {modelID: 'TS011F', manufacturerName: '_TZ3000_ew3ldmgx'},
               {modelID: 'TS011F', manufacturerName: '_TZ3000_jvzvulen'},
               {modelID: 'TS011F', manufacturerName: '_TZ3000_mraovvmm'},
               {modelID: 'TS011F', manufacturerName: '_TZ3000_nfnmi125'},
               {modelID: 'TS011F', manufacturerName: '_TZ3000_ps3dmato'},
               {modelID: 'TS011F', manufacturerName: '_TZ3000_w0qqde0g'},
               {modelID: 'TS011F', manufacturerName: '_TZ3000_u5u4cakc'},
           model: 'TS011F_plug_1',
           description: 'Smart plug (with power monitoring)',
           vendor: 'TuYa',
           whiteLabel: [{vendor: 'LELLKI', model: 'TS011F_plug'}, {vendor: 'NEO', model: 'NAS-WR01B'},
               {vendor: 'BlitzWolf', model: 'BW-SHP15'}],
           fromZigbee: [fz.on_off, fz.electrical_measurement, fz.metering, fz.ignore_basic_report, fz.tuya_switch_power_outage_memory],
           toZigbee: [tz.on_off, tz.tuya_switch_power_outage_memory],
           configure: async (device, coordinatorEndpoint, logger) => {
               const endpoint = device.getEndpoint(1);
               await reporting.bind(endpoint, coordinatorEndpoint, ['genOnOff', 'haElectricalMeasurement', 'seMetering']);
               await reporting.rmsVoltage(endpoint, {change: 5});
               await reporting.rmsCurrent(endpoint, {change: 50});
               await reporting.activePower(endpoint, {change: 10});
               await reporting.currentSummDelivered(endpoint);
               endpoint.saveClusterAttributeKeyValue('haElectricalMeasurement', {acCurrentDivisor: 1000, acCurrentMultiplier: 1});
               endpoint.saveClusterAttributeKeyValue('seMetering', {divisor: 100, multiplier: 1});
               device.save();
           exposes: [e.switch(), e.power(), e.current(), e.voltage().withAccess(ea.STATE),
               e.energy(), exposes.enum('power_outage_memory', ea.STATE_SET, ['on', 'off', 'restore'])
                   .withDescription('Recover state after power outage')],
    Bei mir ist der Fingerprint mit
    bereits nachgetragen, bei dir wird er fehlen. Sollte alles unter dem Fingerprint genau so aussehen wie in meinem Auszug, kannst du einfach den Fingerprint hinzufügen und solltest dann in der Lage sein den Plug erfolgreich zu pairen. Eben aktuell noch mit der Einschränkung, dass:
    • keine Werte zurückgeliefert werden (Voltage, Power, etc.)
    • schalten am Plug selbst wird nicht im IoBroker reflektiert.
      d.h.: wenn du den Knopf am Plug drückst, bekommt das der IoBroker nicht mit. Umgekehrt klappt es aber, also über IoBroker schalten funktioniert tadellos.
      Schmetterfliege
      Fun fact:
      Vor ~ 22 Stunden gabs einen Commit im Herdsman-converters (Tuya.js) der den Fingerprint zum plug_3 hinzufügt (der Converter hat polling schon mit drin).
      Da hab ich spaßeshalber mal den Fingerprint bei mir ebenfalls hinzugefügt und den Plug neu konfiguriert.
      EDIT: ich hatte nur den Fingerprint hinzugefügt, nicht aber den Converter gecheckt. Da sind inzwischen auch einige Zeilen anders, die ich jetzt ebenfalls übernommen, und dann das ganze nochmal getestet habe.
      Als TS011F_plug_3 funktioniert es jetzt insoweit, dass mein Zigbee Adapter nicht mehr crasht und ich die Dose weiterhin korrekt schalten kann. Nur das polling scheint nix zu tun - jedenfalls bekomme ich keine Werte.
      Allerdings weiß ich natürlich nicht, ob das Polling so im Zigbee Adapter überhaupt unterstützt wird!
      Falls die Werte jetzt gepollt werden, kommen sie jedenfalls nicht im Zigbee Adapter an.
      Also noch ist alles eher suboptimal^^
      • arteckA Offline
        arteckA Offline
        arteck
        das ding sollte gehen hab gerde zur sicherheit nochmal den Converter hochgezogen auf GIT also alle mal JETZT installieren.
        onb die Probleme mit der Frimware des sticks zusammenhängen falls dieser nicht erkannt wurde.. dazu kann ich nix sagen .. hab die Dose nicht hier.
        • S Schmetterfliege
          Fun fact:
          arteckA Offline
          arteckA Offline
          arteck
          @schmetterfliege sagte in SHP-15+Zigbee Adp.: "TS011F" not described in statesMapping.:
          wenn du daten haben willst musst du diese selbst abholen. per blockly oder script..
          den device_query button triggern
            Schmetterfliege
            Spoiler: der letzte Edit ganz unten ist der relevanteste.
            @arteck
            Vielen Dank für deine Rückmeldung und deine Mühe!
            Ich habe über GIT geupdatet (Adapter -> Expertenmodus -> Katze -> von Git -> Zigbee Adapter ausgewählt).
            Dann das Device gelöscht (erst Objektbaum, dann im Zigbee Adapter) und neu angelernt.
            Er wurde auch als plug_3 erkannt und hinzugefügt, allerdings kann ich ihn nicht steuern.
            Also im Adapter on/off triggern hat keine Auswirkung. Ebenso nicht wenn ich im Objektbaum den Wert auf true/false setze.
            Da sieht er übrigens so aus:
            Also es wird quasi gar nichts erkannt.
            Frage aller Fragen: Wenn ich den Adapter so wie oben beschrieben installiere (was ja dann "nur" ein Update ist), sollte ich davon ausgehen dass meine Files dann alle exakt so sind wie in der aktuellsten Github Version? Oder wären Änderungen die ich vorher manuell gemacht hab (zb Fingerprint hinzufügen) immer noch vorhanden? Falls ja, könnte das ja mein Problem sein :(
            Edit: theoretisch updatet das ja "nur" den Zigbee Adapter, und nicht das was ich von herdsman-converter habe.
            Oder updatet das dann auch alles was ich unter zigbee-herdsman-converter habe?
            96 -rw-r--r--+ 1 iobroker iobroker 95465 Oct 26  1985 tuya.js
            Zumindest diesem ls Eintrag nach wurde die Datei das letzte mal am 26. Oktober modifiziert, oder?
            Ich selbst habe die Datei doch heute Mittag schon mal modifiziert, hätte das nicht dieses Datum auf den 18. Dezember setzen müssen?
            Edit2:
            "_from": "zigbee-herdsman-converters@14.0.347",
              "_id": "zigbee-herdsman-converters@14.0.347",
            Laut package.json im herdsman-converter Folder hat es zumindest die gleiche Version wie im Zigbee Adapter aufgeführt.
            = Alle Dateien dürften dann auch exakt so sein wie in der aktuellen Adapter Version erwartet und meine Änderungen von heute Mittag dürften weg sein?
            Edit3:
            Ich hab mal einen zweiten Plug hinzugefügt. Den kann ich auch wieder schalten.
            Wenn ich allerdings versuche den ersten zu schalten, crasht der Zigbee Adapter instant.
            Ich hab mal das Debugging für den zweiten Plug (der den Adapter nicht abschießt) eingeschaltet und Device-Query getriggert, das hier ist der Output:
            zigbee.0
            2021-12-18 00:43:08.480	warn	ELEVATED publishToState: value generated 'true' from device 84ba20fffe77b835 for 'On/off state of the switch'
            zigbee.0
            2021-12-18 00:43:08.479	warn	ELEVATED publishToState: message received '{"state":"ON"}' from device 84ba20fffe77b835 type 'TS011F_plug_3'
            zigbee.0
            2021-12-18 00:43:08.478	warn	ELEVATED publishToState: value generated '"{\"type\":\"readResponse\",\"data\":{\"onOff\":1},\"linkquality\":127,\"groupID\":null,\"cluster\":\"genOnOff\",\"meta\":{\"zclTransactionSequenceNumber\":15,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 84ba20fffe77b835 for 'Message from Zigbee'
            zigbee.0
            2021-12-18 00:43:08.477	warn	ELEVATED publishToState: message received '{"msg_from_zigbee":"{\"type\":\"readResponse\",\"data\":{\"onOff\":1},\"linkquality\":127,\"groupID\":null,\"cluster\":\"genOnOff\",\"meta\":{\"zclTransactionSequenceNumber\":15,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 84ba20fffe77b835 type 'TS011F_plug_3'
            zigbee.0
            2021-12-18 00:43:08.477	warn	ELEVATED publishToState: value generated '127' from device 84ba20fffe77b835 for 'Link quality'
            zigbee.0
            2021-12-18 00:43:08.476	warn	ELEVATED publishToState: message received '{"linkquality":127}' from device 84ba20fffe77b835 type 'TS011F_plug_3'
            zigbee.0
            2021-12-18 00:43:08.403	warn	ELEVATED publishToState: value generated 'true' from device 84ba20fffe77b835 for 'On/off state of the switch'
            zigbee.0
            2021-12-18 00:43:08.403	warn	ELEVATED publishToState: message received '{"state":"ON"}' from device 84ba20fffe77b835 type 'TS011F_plug_3'
            zigbee.0
            2021-12-18 00:43:08.398	warn	ELEVATED publishToState: value generated '"{\"type\":\"readResponse\",\"data\":{\"onOff\":1},\"linkquality\":127,\"groupID\":null,\"cluster\":\"genOnOff\",\"meta\":{\"zclTransactionSequenceNumber\":14,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 84ba20fffe77b835 for 'Message from Zigbee'
            zigbee.0
            2021-12-18 00:43:08.398	warn	ELEVATED publishToState: message received '{"msg_from_zigbee":"{\"type\":\"readResponse\",\"data\":{\"onOff\":1},\"linkquality\":127,\"groupID\":null,\"cluster\":\"genOnOff\",\"meta\":{\"zclTransactionSequenceNumber\":14,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 84ba20fffe77b835 type 'TS011F_plug_3'
            zigbee.0
            2021-12-18 00:43:08.397	warn	ELEVATED publishToState: value generated '127' from device 84ba20fffe77b835 for 'Link quality'
            zigbee.0
            2021-12-18 00:43:08.396	warn	ELEVATED publishToState: message received '{"linkquality":127}' from device 84ba20fffe77b835 type 'TS011F_plug_3'
            zigbee.0
            2021-12-18 00:43:08.317	warn	ELEVATED publishToState: value generated 'true' from device 84ba20fffe77b835 for 'On/off state of the switch'
            zigbee.0
            2021-12-18 00:43:08.316	warn	ELEVATED publishToState: message received '{"state":"ON"}' from device 84ba20fffe77b835 type 'TS011F_plug_3'
            zigbee.0
            2021-12-18 00:43:08.312	warn	ELEVATED publishToState: value generated '"{\"type\":\"readResponse\",\"data\":{\"onOff\":1},\"linkquality\":127,\"groupID\":null,\"cluster\":\"genOnOff\",\"meta\":{\"zclTransactionSequenceNumber\":13,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 84ba20fffe77b835 for 'Message from Zigbee'
            zigbee.0
            2021-12-18 00:43:08.311	warn	ELEVATED publishToState: message received '{"msg_from_zigbee":"{\"type\":\"readResponse\",\"data\":{\"onOff\":1},\"linkquality\":127,\"groupID\":null,\"cluster\":\"genOnOff\",\"meta\":{\"zclTransactionSequenceNumber\":13,\"manufacturerCode\":null,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 84ba20fffe77b835 type 'TS011F_plug_3'
            zigbee.0
            2021-12-18 00:43:08.311	warn	ELEVATED publishToState: value generated '127' from device 84ba20fffe77b835 for 'Link quality'
            zigbee.0
            2021-12-18 00:43:08.310	warn	ELEVATED publishToState: message received '{"linkquality":127}' from device 84ba20fffe77b835 type 'TS011F_plug_3'
            zigbee.0
            2021-12-18 00:43:08.209	warn	ELEVATED Change state 'device_query' at device 0x84ba20fffe77b835 type 'TS011F_plug_3'
            zigbee.0
            2021-12-18 00:43:08.198	warn	ELEVATED: User stateChange zigbee.0.84ba20fffe77b835.device_query {"val":true,"ack":false,"ts":1639784588192,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1639784565583}
            EditDrölfzig:
            Hab den ersten Plug, der den Adapter crasht wenn ich ihn schalten will, nochmal gelöscht während er am Strom hängt und dann neu hinzugefügt. Auch den kann ich jetzt wieder über den Adapter schalten und es crasht (zumindest jetzt gerade) nicht mehr den Adapter.
            Aber auch bei dem keine Werte wenn ich Device-Query trigger und in der Debug Ausgabe sehe ich auch keinerlei Eintrag zu Watt, Voltage etc. Nur Link Quality und State.
            ABER: (EditUnendlich) wenn ich den Plug an seinem Knöpfchen ein/ausschalte und dann Device_Query trigger, dann wird der State tatsächlich im Adapter geupdated. Polling funktioniert also schonmal, aber eben nur für den State, nicht für die anderen Values.
              alexzi
              @Schmetterfliege
              erst mal Danke für die vielen Test und Info. Bin trotzdem zu blöd die tuya.js zu aktualisieren, zumindest nicht über die Katze oder sonst wie. Manuell möchte ich eigentlich nicht drin rumfrickeln. Kannst du mir evtl. kurz schreiben wie ich die neue Datei bzw. Dateien bekomme? Merci
                Schmetterfliege
                @alexzi
                Ich habe tatsächlich einfach nur über die Katze den Zigbee Adapter ausgewählt und dann von Github geupdated.
                Alle manuellen Änderungen die ich gemacht habe waren weg, und die verschiedenen Versionen von dependencies waren auch so wie im Repository angegeben. Das Update hat also auch auf jeden Fall geklappt.
                An welcher Stelle hängt es denn bei dir?
                Hast du über die Katze geupdated und die Devices werden immer noch nicht erkannt?
                Falls dem so ist, schaue doch mal in die tuya.js und Kopiere die beiden entsprechenden converter raus (plug_1 und plug_3), damit ich das mal vergleichen kann mit dem was ich habe.
                Übrigens: Ich stehe in Kontakt mit Tuya und kenne nun zumindest den Grund wieso das Polling nicht geht etc.
                Mal schauen ob die ihre Änderungen wieder rückgängig machen - ansonsten gehen die Plugs sofort zurück nach China...
                  Schmetterfliege
                  @arteck
                  Das Problem konnte nun weitestgehend gelöst werden, siehe:
                  https://github.com/Koenkk/zigbee2mqtt/issues/9057
                  Wäre es möglich diese Änderungen im Zigbee Adapter zu übernehmen?
                  L arteckA 2 Antworten Letzte Antwort
                  • S Schmetterfliege
                    @arteck
                    LPTR
                    @schmetterfliege
                    Ich habe die SHP-15 seit gestern und sie laufen tadellos.
                    Adaperversion 1.6.11
                    • S Schmetterfliege
                      @arteck
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @schmetterfliege probier mal jetzt
                      • arteckA arteck
                        Schmetterfliege
                        @arteck
                        hammergeil! Vielen Dank für das sehr zügige Update!
                        Funktioniert genau wie erwartet :)
                          Schmetterfliege
                          @arteck
                          kurzer Nachtrag:
                          Das Update hat funktioniert, die Plugs funktionieren auch wie erwartet, allerdings wird mein Log nun mit Warnings vollgespammt wenn ich Geräte steuere.
                          Ich hänge mal das Log von beginn der Installation bis jetzt an.
                          Ich habe in der Küche 2 Tradfri Remote Controls. Die funktionieren auch noch problemlos, hauen aber nun warnings ins Log wenn ich die benutze.
                          2022-01-08 22:41:47.409 - info: zigbee.0 (10089) starting. Version 1.6.11 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.0, js-controller: 3.3.21
                          2022-01-08 22:41:47.563 - info: zigbee.0 (10089) Starting Zigbee npm ...
                          2022-01-08 22:41:47.565 - warn: zigbee.0 (10089) 4 extensions initialized
                          2022-01-08 22:41:47.566 - warn: zigbee.0 (10089) extension DeviceAvailability
                          2022-01-08 22:41:47.567 - warn: zigbee.0 (10089) extension DeviceConfigure
                          2022-01-08 22:41:47.568 - warn: zigbee.0 (10089) extension DeviceEvent
                          2022-01-08 22:41:47.569 - warn: zigbee.0 (10089) extension DelayedAction
                          2022-01-08 22:41:48.203 - info: zigbee.0 (10089) Installed Version: ioBroker/ioBroker.zigbee
                          2022-01-08 22:41:48.241 - info: zigbee.0 (10089) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
                          2022-01-08 22:41:48.265 - info: zigbee.0 (10089) Unable to disable LED, unsupported function.
                          2022-01-08 22:41:48.282 - info: zigbee.0 (10089) --> transmitPower : normal
                          2022-01-08 22:41:48.493 - info: zigbee.0 (10089) Unable to set transmit power, unsupported function.
                          2022-01-08 22:41:48.500 - info: zigbee.0 (10089) Currently 45 devices are joined:
                          2022-01-08 22:41:48.691 - info: zigbee.0 (10089) Configuring 0x84ba20fffe77b835 TS011F
                          2022-01-08 22:41:48.695 - info: zigbee.0 (10089) 0x00158d000410e87b (addr 32835): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.715 - info: zigbee.0 (10089) 0x00158d000411103a (addr 26950): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.717 - info: zigbee.0 (10089) 0x00158d000410e8ca (addr 1223): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.719 - info: zigbee.0 (10089) 0x00158d000309a45a (addr 35075): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.721 - info: zigbee.0 (10089) 0x00158d0005221c38 (addr 31581): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                          2022-01-08 22:41:48.723 - info: zigbee.0 (10089) 0x00158d0005221fbe (addr 11411): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                          2022-01-08 22:41:48.725 - info: zigbee.0 (10089) 0x00158d0005221c37 (addr 57703): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                          2022-01-08 22:41:48.727 - info: zigbee.0 (10089) 0x00158d00052debfb (addr 30191): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                          2022-01-08 22:41:48.729 - info: zigbee.0 (10089) 0x00158d00051dfd12 (addr 48749): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                          2022-01-08 22:41:48.731 - info: zigbee.0 (10089) 0x00158d00051e1633 (addr 39535): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                          2022-01-08 22:41:48.734 - info: zigbee.0 (10089) 0x00158d000283e67b (addr 50956): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.737 - info: zigbee.0 (10089) 0x00158d000283e64e (addr 18527): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.739 - info: zigbee.0 (10089) 0x00158d000163f2bc (addr 63165): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.741 - info: zigbee.0 (10089) 0x00158d00041d8697 (addr 26015): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.743 - info: zigbee.0 (10089) 0x00158d000412fc1e (addr 39417): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.745 - info: zigbee.0 (10089) 0x00158d000282eec7 (addr 19057): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.747 - info: zigbee.0 (10089) 0x00158d0003f0f373 (addr 46914): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                          2022-01-08 22:41:48.749 - info: zigbee.0 (10089) 0x00158d0005cf8b49 (addr 43071): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                          2022-01-08 22:41:48.751 - info: zigbee.0 (10089) 0x00178801089def32 (addr 26711): 929002240401 - Philips Hue smart plug - EU (Router)
                          2022-01-08 22:41:48.753 - info: zigbee.0 (10089) 0x00178801089de95e (addr 39138): 929002240401 - Philips Hue smart plug - EU (Router)
                          2022-01-08 22:41:48.755 - info: zigbee.0 (10089) 0x00158d00076565a1 (addr 35956): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.757 - info: zigbee.0 (10089) 0x00158d000774f35a (addr 23883): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.758 - info: zigbee.0 (10089) 0x00158d0001e4e9e3 (addr 29911): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                          2022-01-08 22:41:48.765 - info: zigbee.0 (10089) 0x00158d00019f3736 (addr 26600): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                          2022-01-08 22:41:48.769 - info: zigbee.0 (10089) 0x00158d000774f34a (addr 13527): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.773 - info: zigbee.0 (10089) 0x00158d00077dce53 (addr 62480): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.775 - info: zigbee.0 (10089) 0x00158d00075f6607 (addr 3323): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.777 - info: zigbee.0 (10089) 0x00158d000774f31c (addr 31399): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.779 - info: zigbee.0 (10089) 0x00158d00077dce21 (addr 56764): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.781 - info: zigbee.0 (10089) 0x00158d000774f2c9 (addr 16865): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.786 - info: zigbee.0 (10089) 0x00158d000774f2cb (addr 13799): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.787 - info: zigbee.0 (10089) 0x00158d00073c0c65 (addr 815): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:41:48.789 - info: zigbee.0 (10089) 0x00158d00044eefbe (addr 41589): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                          2022-01-08 22:41:48.791 - info: zigbee.0 (10089) 0x84fd27fffe245425 (addr 308): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                          2022-01-08 22:41:48.795 - info: zigbee.0 (10089) 0x00158d0005cf4ea4 (addr 42668): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                          2022-01-08 22:41:48.800 - info: zigbee.0 (10089) 0x804b50fffef8cf51 (addr 60471): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                          2022-01-08 22:41:48.805 - info: zigbee.0 (10089) 0x84ba20fffe77b835 (addr 487): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                          2022-01-08 22:41:48.810 - info: zigbee.0 (10089) 0x84ba20fffe77b200 (addr 29486): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                          2022-01-08 22:41:48.812 - info: zigbee.0 (10089) 0x84fd27fffe1f8f5d (addr 43353): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                          2022-01-08 22:41:48.813 - info: zigbee.0 (10089) 0x84fd27fffe1f8f8c (addr 8187): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                          2022-01-08 22:41:48.815 - info: zigbee.0 (10089) 0xb4e3f9fffeaae8c8 (addr 59871): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                          2022-01-08 22:41:48.817 - info: zigbee.0 (10089) 0x842e14fffe89313a (addr 26171): E2001/E2002 - IKEA STYRBAR remote control N2 (EndDevice)
                          2022-01-08 22:41:48.819 - info: zigbee.0 (10089) 0x842e14fffe285173 (addr 60803): E2001/E2002 - IKEA STYRBAR remote control N2 (EndDevice)
                          2022-01-08 22:41:48.820 - info: zigbee.0 (10089) 0x804b50fffe606093 (addr 21921): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                          2022-01-08 22:41:48.822 - info: zigbee.0 (10089) 0x540f57fffe8971d1 (addr 40423): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                          2022-01-08 22:41:48.824 - warn: zigbee.0 (10089) config :{"port":"/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2253809-if00","panID":"6754","extPanID":"DDDDDDDDDDDDDDDD","channel":"11","disableLed":false,"precfgkey":"abcdef01234567899876543210fedcba","countDown":"60","adapterType":"deconz","debugHerdsman":false,"transmitPower":null,"extPanIdFix":true,"disablePing":false,"external":"","startWithInconsistent":false}
                          2022-01-08 22:41:48.824 - info: zigbee.0 (10089) Zigbee started
                          2022-01-08 22:41:48.953 - info: zigbee.0 (10089) debug devices set to []
                          2022-01-08 22:41:48.956 - warn: zigbee.0 (10089) State "zigbee.0.info.undefinedDevices" has no existing object, this might lead to an error in future versions
                          2022-01-08 22:41:49.708 - info: zigbee.0 (10089) Configuring 0x84ba20fffe77b200 TS011F
                          2022-01-08 22:41:50.058 - info: zigbee.0 (10089) DeviceConfigure successful 0x84ba20fffe77b200 TS011F
                          2022-01-08 22:41:50.089 - info: zigbee.0 (10089) Configuring 0xb4e3f9fffeaae8c8 TRADFRI Driver 30W
                          2022-01-08 22:41:50.095 - info: zigbee.0 (10089) DeviceConfigure successful 0xb4e3f9fffeaae8c8 TRADFRI Driver 30W
                          2022-01-08 22:41:50.278 - info: zigbee.0 (10089) Configuring 0x804b50fffe606093 TRADFRI Driver 30W
                          2022-01-08 22:41:50.283 - info: zigbee.0 (10089) DeviceConfigure successful 0x804b50fffe606093 TRADFRI Driver 30W
                          2022-01-08 22:41:50.458 - info: zigbee.0 (10089) Configuring 0x540f57fffe8971d1 TS011F
                          2022-01-08 22:41:50.581 - info: zigbee.0 (10089) DeviceConfigure successful 0x540f57fffe8971d1 TS011F
                          2022-01-08 22:41:52.542 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                          2022-01-08 22:41:54.334 - info: zigbee.0 (10089) Got terminate signal TERMINATE_YOURSELF
                          2022-01-08 22:41:54.335 - info: zigbee.0 (10089) cleaned everything up...
                          2022-01-08 22:41:54.501 - info: zigbee.0 (10089) Zigbee: disabling joining new devices.
                          2022-01-08 22:41:54.661 - info: zigbee.0 (10089) terminating
                          2022-01-08 22:41:54.663 - info: zigbee.0 (10089) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2022-01-08 22:41:55.496 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                          2022-01-08 22:41:55.530 - warn: zigbee.0 (10089) redis mget 0 9, err: DB closed
                          2022-01-08 22:41:55.531 - warn: zigbee.0 (10089) redis mget 0 9, err: DB closed
                          2022-01-08 22:41:55.532 - warn: zigbee.0 (10089) redis mget 0 9, err: DB closed
                          2022-01-08 22:41:55.533 - warn: zigbee.0 (10089) redis mget 0 9, err: DB closed
                          2022-01-08 22:41:55.534 - warn: zigbee.0 (10089) redis mget 0 9, err: DB closed
                          2022-01-08 22:41:55.535 - warn: zigbee.0 (10089) redis mget 0 9, err: DB closed
                          2022-01-08 22:41:55.536 - warn: zigbee.0 (10089) redis mget 0 11, err: DB closed
                          2022-01-08 22:41:55.536 - warn: zigbee.0 (10089) redis mget 0 8, err: DB closed
                          2022-01-08 22:41:55.537 - warn: zigbee.0 (10089) redis mget 0 11, err: DB closed
                          2022-01-08 22:41:55.537 - warn: zigbee.0 (10089) redis mget 0 8, err: DB closed
                          2022-01-08 22:41:55.538 - warn: zigbee.0 (10089) redis mget 0 11, err: DB closed
                          2022-01-08 22:41:55.538 - warn: zigbee.0 (10089) redis mget 0 8, err: DB closed
                          2022-01-08 22:41:55.539 - warn: zigbee.0 (10089) redis mget 0 9, err: DB closed
                          2022-01-08 22:41:55.539 - warn: zigbee.0 (10089) redis mget 0 14, err: DB closed
                          2022-01-08 22:41:55.540 - warn: zigbee.0 (10089) redis mget 0 11, err: DB closed
                          2022-01-08 22:41:55.836 - info: zigbee.0 (10089) terminating with timeout
                          2022-01-08 22:41:56.148 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.149 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.150 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.151 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.152 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.153 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.154 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.155 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.162 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at /opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:257:64
                          at runMicrotasks ()
                          at runNextTicks (internal/process/task_queues.js:62:5)
                          at processImmediate (internal/timers.js:434:9)
                          2022-01-08 22:41:56.165 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.168 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.171 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.174 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.177 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.181 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.184 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.186 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.189 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.530 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 10089
                          2022-01-08 22:41:56.664 - warn: zigbee.0 (10089) Cannot get view: Connection is closed.
                          2022-01-08 22:41:56.665 - warn: zigbee.0 (10089) Cannot get view: Connection is closed.
                          2022-01-08 22:41:56.666 - warn: zigbee.0 (10089) Cannot get view: Connection is closed.
                          2022-01-08 22:41:56.716 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00052debfb.link_quality: Connection is closed.
                          2022-01-08 22:41:56.717 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.717 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00051dfd12.available: Connection is closed.
                          2022-01-08 22:41:56.718 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00051dfd12.link_quality: Connection is closed.
                          2022-01-08 22:41:56.718 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.718 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00051e1633.available: Connection is closed.
                          2022-01-08 22:41:56.719 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.719 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00051e1633.link_quality: Connection is closed.
                          2022-01-08 22:41:56.720 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.720 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000283e67b.available: Connection is closed.
                          2022-01-08 22:41:56.721 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000283e67b.link_quality: Connection is closed.
                          2022-01-08 22:41:56.721 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.721 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000283e64e.available: Connection is closed.
                          2022-01-08 22:41:56.722 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.722 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000283e64e.link_quality: Connection is closed.
                          2022-01-08 22:41:56.723 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.723 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000163f2bc.available: Connection is closed.
                          2022-01-08 22:41:56.724 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000163f2bc.link_quality: Connection is closed.
                          2022-01-08 22:41:56.724 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.724 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00041d8697.available: Connection is closed.
                          2022-01-08 22:41:56.725 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.725 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00041d8697.link_quality: Connection is closed.
                          2022-01-08 22:41:56.726 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.726 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000412fc1e.available: Connection is closed.
                          2022-01-08 22:41:56.727 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000412fc1e.link_quality: Connection is closed.
                          2022-01-08 22:41:56.727 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.728 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000282eec7.available: Connection is closed.
                          2022-01-08 22:41:56.728 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.728 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000282eec7.link_quality: Connection is closed.
                          2022-01-08 22:41:56.729 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.729 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d0003f0f373.available: Connection is closed.
                          2022-01-08 22:41:56.730 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d0003f0f373.link_quality: Connection is closed.
                          2022-01-08 22:41:56.730 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.730 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d0005cf8b49.available: Connection is closed.
                          2022-01-08 22:41:56.731 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.732 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d0005cf8b49.link_quality: Connection is closed.
                          2022-01-08 22:41:56.732 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.732 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00178801089def32.available: Connection is closed.
                          2022-01-08 22:41:56.733 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.733 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00178801089def32.link_quality: Connection is closed.
                          2022-01-08 22:41:56.734 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00178801089de95e.available: Connection is closed.
                          2022-01-08 22:41:56.734 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.735 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00178801089de95e.link_quality: Connection is closed.
                          2022-01-08 22:41:56.735 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.735 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00076565a1.available: Connection is closed.
                          2022-01-08 22:41:56.736 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.736 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00076565a1.link_quality: Connection is closed.
                          2022-01-08 22:41:56.737 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000774f35a.available: Connection is closed.
                          2022-01-08 22:41:56.737 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.737 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000774f35a.link_quality: Connection is closed.
                          2022-01-08 22:41:56.738 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.738 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d0001e4e9e3.available: Connection is closed.
                          2022-01-08 22:41:56.739 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.739 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d0001e4e9e3.link_quality: Connection is closed.
                          2022-01-08 22:41:56.740 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00019f3736.available: Connection is closed.
                          2022-01-08 22:41:56.740 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.740 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00019f3736.link_quality: Connection is closed.
                          2022-01-08 22:41:56.741 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.741 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000774f34a.available: Connection is closed.
                          2022-01-08 22:41:56.742 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.742 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000774f34a.link_quality: Connection is closed.
                          2022-01-08 22:41:56.743 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.743 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00077dce53.available: Connection is closed.
                          2022-01-08 22:41:56.744 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00077dce53.link_quality: Connection is closed.
                          2022-01-08 22:41:56.744 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.744 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00075f6607.available: Connection is closed.
                          2022-01-08 22:41:56.745 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.745 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00075f6607.link_quality: Connection is closed.
                          2022-01-08 22:41:56.746 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.746 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000774f31c.available: Connection is closed.
                          2022-01-08 22:41:56.747 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000774f31c.link_quality: Connection is closed.
                          2022-01-08 22:41:56.747 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.747 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00077dce21.available: Connection is closed.
                          2022-01-08 22:41:56.748 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.748 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00077dce21.link_quality: Connection is closed.
                          2022-01-08 22:41:56.749 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000774f2c9.available: Connection is closed.
                          2022-01-08 22:41:56.749 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.750 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000774f2c9.link_quality: Connection is closed.
                          2022-01-08 22:41:56.750 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.750 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000774f2cb.available: Connection is closed.
                          2022-01-08 22:41:56.751 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.751 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d000774f2cb.link_quality: Connection is closed.
                          2022-01-08 22:41:56.752 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00073c0c65.available: Connection is closed.
                          2022-01-08 22:41:56.752 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.752 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00073c0c65.link_quality: Connection is closed.
                          2022-01-08 22:41:56.753 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.753 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00044eefbe.available: Connection is closed.
                          2022-01-08 22:41:56.754 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.754 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d00044eefbe.link_quality: Connection is closed.
                          2022-01-08 22:41:56.755 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.84fd27fffe245425.available: Connection is closed.
                          2022-01-08 22:41:56.755 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.755 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.84fd27fffe245425.link_quality: Connection is closed.
                          2022-01-08 22:41:56.756 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.756 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d0005cf4ea4.available: Connection is closed.
                          2022-01-08 22:41:56.757 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d0005cf4ea4.link_quality: Connection is closed.
                          2022-01-08 22:41:56.757 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.758 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.804b50fffef8cf51.available: Connection is closed.
                          2022-01-08 22:41:56.758 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.758 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.804b50fffef8cf51.link_quality: Connection is closed.
                          2022-01-08 22:41:56.759 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.759 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.84ba20fffe77b835.available: Connection is closed.
                          2022-01-08 22:41:56.760 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.84ba20fffe77b835.link_quality: Connection is closed.
                          2022-01-08 22:41:56.760 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.760 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.84ba20fffe77b200.available: Connection is closed.
                          2022-01-08 22:41:56.761 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.761 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.84ba20fffe77b200.link_quality: Connection is closed.
                          2022-01-08 22:41:56.762 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.84fd27fffe1f8f5d.available: Connection is closed.
                          2022-01-08 22:41:56.762 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.762 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.84fd27fffe1f8f5d.link_quality: Connection is closed.
                          2022-01-08 22:41:56.763 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.763 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.84fd27fffe1f8f8c.available: Connection is closed.
                          2022-01-08 22:41:56.764 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.84fd27fffe1f8f8c.link_quality: Connection is closed.
                          2022-01-08 22:41:56.764 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.765 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.b4e3f9fffeaae8c8.available: Connection is closed.
                          2022-01-08 22:41:56.765 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.765 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.b4e3f9fffeaae8c8.link_quality: Connection is closed.
                          2022-01-08 22:41:56.766 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.766 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.842e14fffe89313a.available: Connection is closed.
                          2022-01-08 22:41:56.767 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.767 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.842e14fffe89313a.link_quality: Connection is closed.
                          2022-01-08 22:41:56.768 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.842e14fffe285173.available: Connection is closed.
                          2022-01-08 22:41:56.768 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.768 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.842e14fffe285173.link_quality: Connection is closed.
                          2022-01-08 22:41:56.769 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.769 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.804b50fffe606093.available: Connection is closed.
                          2022-01-08 22:41:56.770 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.804b50fffe606093.link_quality: Connection is closed.
                          2022-01-08 22:41:56.770 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.770 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.540f57fffe8971d1.available: Connection is closed.
                          2022-01-08 22:41:56.771 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.771 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.540f57fffe8971d1.link_quality: Connection is closed.
                          2022-01-08 22:41:56.772 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:56.772 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d0005cf4ea4.occupancy: Connection is closed.
                          2022-01-08 22:41:56.776 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.778 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.785 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.787 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.790 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.804 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.806 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.809 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.812 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.814 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.817 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.819 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.822 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.825 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.827 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.830 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.833 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.835 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.838 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.841 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.843 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.846 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.848 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.851 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.853 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.856 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.858 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.861 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.863 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.866 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.869 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.871 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.875 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.878 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          at runMicrotasks ()
                          2022-01-08 22:41:56.880 - error: zigbee.0 (10089) getDevices error: TypeError: Cannot read property 'resolveEntity' of undefined
                          2022-01-08 22:41:56.884 - warn: zigbee.0 (10089) Could not perform strict object check of state zigbee.0.00158d0005cf4ea4.no_motion: Connection is closed.
                          2022-01-08 22:41:56.885 - warn: zigbee.0 (10089) get state error: Connection is closed.
                          2022-01-08 22:41:57.196 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2022-01-08 22:41:58.539 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 10117
                          2022-01-08 22:42:02.938 - info: zigbee.0 (10117) starting. Version 1.6.11 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.0, js-controller: 3.3.21
                          2022-01-08 22:42:03.050 - info: zigbee.0 (10117) Starting Zigbee npm ...
                          2022-01-08 22:42:03.051 - warn: zigbee.0 (10117) 4 extensions initialized
                          2022-01-08 22:42:03.052 - warn: zigbee.0 (10117) extension DeviceAvailability
                          2022-01-08 22:42:03.053 - warn: zigbee.0 (10117) extension DeviceConfigure
                          2022-01-08 22:42:03.053 - warn: zigbee.0 (10117) extension DeviceEvent
                          2022-01-08 22:42:03.053 - warn: zigbee.0 (10117) extension DelayedAction
                          2022-01-08 22:42:03.560 - info: zigbee.0 (10117) Installed Version: ioBroker/ioBroker.zigbee
                          2022-01-08 22:42:03.589 - info: zigbee.0 (10117) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
                          2022-01-08 22:42:03.610 - info: zigbee.0 (10117) Unable to disable LED, unsupported function.
                          2022-01-08 22:42:03.621 - info: zigbee.0 (10117) --> transmitPower : normal
                          2022-01-08 22:42:03.791 - info: zigbee.0 (10117) Unable to set transmit power, unsupported function.
                          2022-01-08 22:42:03.799 - info: zigbee.0 (10117) Currently 45 devices are joined:
                          2022-01-08 22:42:03.954 - info: zigbee.0 (10117) Configuring 0x84ba20fffe77b835 TS011F
                          2022-01-08 22:42:03.958 - info: zigbee.0 (10117) 0x00158d000410e87b (addr 32835): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:03.972 - info: zigbee.0 (10117) 0x00158d000411103a (addr 26950): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:03.974 - info: zigbee.0 (10117) 0x00158d000410e8ca (addr 1223): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:03.976 - info: zigbee.0 (10117) 0x00158d000309a45a (addr 35075): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:03.977 - info: zigbee.0 (10117) 0x00158d0005221c38 (addr 31581): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                          2022-01-08 22:42:03.978 - info: zigbee.0 (10117) 0x00158d0005221fbe (addr 11411): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                          2022-01-08 22:42:03.980 - info: zigbee.0 (10117) 0x00158d0005221c37 (addr 57703): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                          2022-01-08 22:42:03.981 - info: zigbee.0 (10117) 0x00158d00052debfb (addr 30191): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                          2022-01-08 22:42:03.983 - info: zigbee.0 (10117) 0x00158d00051dfd12 (addr 48749): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                          2022-01-08 22:42:03.984 - info: zigbee.0 (10117) 0x00158d00051e1633 (addr 39535): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                          2022-01-08 22:42:03.986 - info: zigbee.0 (10117) 0x00158d000283e67b (addr 50956): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:03.989 - info: zigbee.0 (10117) 0x00158d000283e64e (addr 18527): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:03.991 - info: zigbee.0 (10117) 0x00158d000163f2bc (addr 63165): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:03.992 - info: zigbee.0 (10117) 0x00158d00041d8697 (addr 26015): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:03.994 - info: zigbee.0 (10117) 0x00158d000412fc1e (addr 39417): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:03.995 - info: zigbee.0 (10117) 0x00158d000282eec7 (addr 19057): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:03.996 - info: zigbee.0 (10117) 0x00158d0003f0f373 (addr 46914): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                          2022-01-08 22:42:03.998 - info: zigbee.0 (10117) 0x00158d0005cf8b49 (addr 43071): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                          2022-01-08 22:42:03.999 - info: zigbee.0 (10117) 0x00178801089def32 (addr 26711): 929002240401 - Philips Hue smart plug - EU (Router)
                          2022-01-08 22:42:04.001 - info: zigbee.0 (10117) 0x00178801089de95e (addr 39138): 929002240401 - Philips Hue smart plug - EU (Router)
                          2022-01-08 22:42:04.002 - info: zigbee.0 (10117) 0x00158d00076565a1 (addr 35956): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:04.003 - info: zigbee.0 (10117) 0x00158d000774f35a (addr 23883): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:04.005 - info: zigbee.0 (10117) 0x00158d0001e4e9e3 (addr 29911): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                          2022-01-08 22:42:04.006 - info: zigbee.0 (10117) 0x00158d00019f3736 (addr 26600): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                          2022-01-08 22:42:04.007 - info: zigbee.0 (10117) 0x00158d000774f34a (addr 13527): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:04.009 - info: zigbee.0 (10117) 0x00158d00077dce53 (addr 62480): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:04.010 - info: zigbee.0 (10117) 0x00158d00075f6607 (addr 3323): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:04.011 - info: zigbee.0 (10117) 0x00158d000774f31c (addr 31399): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:04.013 - info: zigbee.0 (10117) 0x00158d00077dce21 (addr 56764): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:04.014 - info: zigbee.0 (10117) 0x00158d000774f2c9 (addr 16865): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:04.017 - info: zigbee.0 (10117) 0x00158d000774f2cb (addr 13799): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:04.019 - info: zigbee.0 (10117) 0x00158d00073c0c65 (addr 815): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                          2022-01-08 22:42:04.020 - info: zigbee.0 (10117) 0x00158d00044eefbe (addr 41589): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                          2022-01-08 22:42:04.022 - info: zigbee.0 (10117) 0x84fd27fffe245425 (addr 308): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                          2022-01-08 22:42:04.023 - info: zigbee.0 (10117) 0x00158d0005cf4ea4 (addr 42668): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                          2022-01-08 22:42:04.025 - info: zigbee.0 (10117) 0x804b50fffef8cf51 (addr 60471): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                          2022-01-08 22:42:04.027 - info: zigbee.0 (10117) 0x84ba20fffe77b835 (addr 487): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                          2022-01-08 22:42:04.029 - info: zigbee.0 (10117) 0x84ba20fffe77b200 (addr 29486): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                          2022-01-08 22:42:04.030 - info: zigbee.0 (10117) 0x84fd27fffe1f8f5d (addr 43353): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                          2022-01-08 22:42:04.032 - info: zigbee.0 (10117) 0x84fd27fffe1f8f8c (addr 8187): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                          2022-01-08 22:42:04.033 - info: zigbee.0 (10117) 0xb4e3f9fffeaae8c8 (addr 59871): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                          2022-01-08 22:42:04.034 - info: zigbee.0 (10117) 0x842e14fffe89313a (addr 26171): E2001/E2002 - IKEA STYRBAR remote control N2 (EndDevice)
                          2022-01-08 22:42:04.035 - info: zigbee.0 (10117) 0x842e14fffe285173 (addr 60803): E2001/E2002 - IKEA STYRBAR remote control N2 (EndDevice)
                          2022-01-08 22:42:04.037 - info: zigbee.0 (10117) 0x804b50fffe606093 (addr 21921): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                          2022-01-08 22:42:04.038 - info: zigbee.0 (10117) 0x540f57fffe8971d1 (addr 40423): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                          2022-01-08 22:42:04.039 - warn: zigbee.0 (10117) config :{"port":"/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2253809-if00","panID":"6754","extPanID":"DDDDDDDDDDDDDDDD","channel":"11","disableLed":false,"precfgkey":"abcdef01234567899876543210fedcba","countDown":"60","adapterType":"deconz","debugHerdsman":false,"transmitPower":null,"extPanIdFix":true,"disablePing":false,"external":"","startWithInconsistent":false}
                          2022-01-08 22:42:04.040 - info: zigbee.0 (10117) Zigbee started
                          2022-01-08 22:42:04.147 - info: zigbee.0 (10117) debug devices set to []
                          2022-01-08 22:43:03.996 - warn: zigbee.0 (10117) DeviceConfigure:DeviceConfigure failed 0x84ba20fffe77b835 TS011F, attempt 1 (Error: Read 0x84ba20fffe77b835/1 genBasic(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received)
                          at DeconzAdapter.sendZclFrameToEndpoint (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:641:23))
                          2022-01-08 22:43:03.998 - info: zigbee.0 (10117) Configuring 0x84fd27fffe1f8f5d TRADFRI on/off switch
                          2022-01-08 22:43:36.915 - info: zigbee.0 (10117) Zigbee: allowing new devices to join.
                          2022-01-08 22:43:48.292 - info: zigbee.0 (10117) Starting interview of '0x84ba20fffe80c9ba'
                          2022-01-08 22:43:49.801 - info: zigbee.0 (10117) Successfully interviewed '0x84ba20fffe80c9ba', device has succesfully been paired
                          2022-01-08 22:43:49.801 - info: zigbee.0 (10117) Device '0x84ba20fffe80c9ba' is supported, identified as: TuYa Smart plug (with power monitoring by polling) (TS011F_plug_3)
                          2022-01-08 22:43:49.804 - info: zigbee.0 (10117) Configuring 0x84ba20fffe80c9ba TS011F
                          2022-01-08 22:43:49.929 - info: zigbee.0 (10117) DeviceConfigure successful 0x84ba20fffe80c9ba TS011F
                          2022-01-08 22:44:01.437 - warn: zigbee.0 (10117) SetState_typed called without type
                          2022-01-08 22:44:04.362 - warn: zigbee.0 (10117) DeviceConfigure:DeviceConfigure failed 0x84fd27fffe1f8f5d TRADFRI on/off switch, attempt 1 (Error: Bind 0x84fd27fffe1f8f5d/1 genOnOff from '901' failed (waiting for response TIMEOUT)
                          at DeconzAdapter.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:753:19))
                          2022-01-08 22:44:04.363 - info: zigbee.0 (10117) Configuring 0x84fd27fffe1f8f8c TRADFRI on/off switch
                          2022-01-08 22:44:05.587 - warn: zigbee.0 (10117) DeviceAvailability:Failed to ping 0x84ba20fffe77b835 TS011F
                          2022-01-08 22:44:38.635 - info: zigbee.0 (10117) Zigbee: stop joining
                          2022-01-08 22:45:04.401 - warn: zigbee.0 (10117) DeviceConfigure:DeviceConfigure failed 0x84fd27fffe1f8f8c TRADFRI on/off switch, attempt 1 (Error: Bind 0x84fd27fffe1f8f8c/1 genOnOff from '901' failed (waiting for response TIMEOUT)
                          2022-01-08 22:45:04.402 - info: zigbee.0 (10117) Configuring 0x842e14fffe89313a Remote Control N2
                          2022-01-08 22:46:04.613 - warn: zigbee.0 (10117) DeviceConfigure:DeviceConfigure failed 0x842e14fffe89313a Remote Control N2, attempt 1 (Error: Bind 0x842e14fffe89313a/1 genPowerCfg from '0x00212effff065d89/1' failed (waiting for response TIMEOUT)
                          2022-01-08 22:46:04.614 - info: zigbee.0 (10117) Configuring 0x842e14fffe285173 Remote Control N2
                          2022-01-08 22:46:07.876 - warn: zigbee.0 (10117) SetState_typed called without type
                          2022-01-08 22:47:05.557 - warn: zigbee.0 (10117) DeviceConfigure:DeviceConfigure failed 0x842e14fffe285173 Remote Control N2, attempt 1 (Error: Bind 0x842e14fffe285173/1 genPowerCfg from '0x00212effff065d89/1' failed (waiting for response TIMEOUT)
                          2022-01-08 22:47:44.618 - warn: zigbee.0 (10117) SetState_typed called without type
                          2022-01-08 22:48:45.631 - error: zigbee.0 (10117) Send command to 0x84ba20fffe80c9ba failed with no error code (no response received)
                          2022-01-08 22:49:03.882 - warn: zigbee.0 (10117) SetState_typed called without type
                          2022-01-08 22:52:37.065 - info: zigbee.0 (10117) Configuring 0x842e14fffe285173 Remote Control N2
                          2022-01-08 22:53:37.661 - warn: zigbee.0 (10117) DeviceConfigure:DeviceConfigure failed 0x842e14fffe285173 Remote Control N2, attempt 2 (Error: Bind 0x842e14fffe285173/1 genPowerCfg from '0x00212effff065d89/1' failed (waiting for response TIMEOUT)
                          2022-01-08 22:58:31.232 - info: hue-extended.0 (23663) Attempt 1x - Successfully set Bad Kevin.
                          2022-01-08 23:02:10.523 - info: zigbee.0 (10117) Configuring 0x842e14fffe285173 Remote Control N2
                          2022-01-08 23:02:18.456 - info: zigbee.0 (10117) Configuring 0x842e14fffe89313a Remote Control N2
                          2022-01-08 23:02:21.525 - info: zigbee.0 (10117) DeviceConfigure successful 0x842e14fffe89313a Remote Control N2
                          2022-01-08 23:03:10.742 - warn: zigbee.0 (10117) DeviceConfigure:DeviceConfigure failed 0x842e14fffe285173 Remote Control N2, attempt 3 (Error: Bind 0x842e14fffe285173/1 genPowerCfg from '0x00212effff065d89/1' failed (waiting for response TIMEOUT)
                          at processTimers (internal/timers.js:494:9))
                          Und:
                          Wenn ich über den Zigbee Adapter den Power Plug ein/ausschalte, steht folgendes im log:
                          zigbee.0 2022-01-08 23:07:14.263	warn	SetState_typed called without type
                          Ich beobachte das ganze mal und berichte wieder :)
                          Note: ich hab über Github geupdated, dann Zigbee selbst nochmal neu gestartet (über iobroker), und dann einen neuen Plug hinzugefügt. Wieso nun so viele andere Geräte ebenfalls konfiguriert werden - obwohl sie es schon sind - weiß ich nicht.
                          • S Schmetterfliege
                            @arteck
                            kurzer Nachtrag:
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            at runMicrotasks ()
                            Und:
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @schmetterfliege sagte in SHP-15+Zigbee Adp.: "TS011F" not described in statesMapping.:
                            Und:
                            was bedeutet "über den Zigbee Adapter" ausschalten ?
                            A.
                              Schmetterfliege
                              schrieb am zuletzt editiert von Schmetterfliege
                              @asgothian
                              Darüber :)
                              EDIT: wenn ich über den physischen Button an dem Gerät schalte, steht nichts in den Logs. Der state im zigbee Adapter (siehe screenshot) wird aber sofort geupdated.
                                Schmetterfliege
                                Hab gerade gesehen dass Zigbee scheinbar abgestürzt ist, warum weiß ich aber nicht zu 100%.
                                Mein iobroker lässt mich leider das Log (noch?) nicht runterladen, daher einfach mal so aus dem Browser kopiert:
                                Muss leider von unten nach oben gelesen werden :/
                                Kann mir da jemand weiterhelfen und weiß, was da passiert ist?
                                zigbee.0
                                2022-01-13 22:13:50.187	warn	DeviceConfigure:DeviceConfigure failed 0x842e14fffe285173 Remote Control N2, attempt 5 (Error: Bind 0x842e14fffe285173/1 genPowerCfg from '0x00212effff065d89/1' failed (waiting for response TIMEOUT) at DeconzAdapter.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:753:19))
                                zigbee.0
                                2022-01-13 22:12:49.799	info	Configuring 0x842e14fffe285173 Remote Control N2
                                javascript.0
                                2022-01-13 21:58:06.213	info	script.js.Wohnzimmer.Wohnzimmer_Heizung: KEVQU: Balkon Wohnbereich geöffnet
                                zigbee.0
                                2022-01-13 21:54:52.090	warn	DeviceConfigure:DeviceConfigure failed 0x842e14fffe285173 Remote Control N2, attempt 4 (Error: Bind 0x842e14fffe285173/1 genPowerCfg from '0x00212effff065d89/1' failed (waiting for response TIMEOUT) at DeconzAdapter.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:753:19) at runMicrotasks (<anonymous>) at runNextTicks (internal/process/task_queues.js:62:5) at processTimers (internal/timers.js:494:9))
                                zigbee.0
                                2022-01-13 21:53:51.868	info	Configuring 0x842e14fffe285173 Remote Control N2
                                hue-extended.0
                                2022-01-13 20:58:58.262	info	Attempt 1x - Successfully set Bad Kevin.
                                hue-extended.0
                                2022-01-13 20:56:05.324	info	Attempt 1x - Successfully set Bad Kevin.
                                zigbee.0
                                2022-01-13 20:32:49.050	warn	DeviceAvailability:Stopping to ping 0x84ba20fffe77b835 TS011F after 4 ping attempts
                                zigbee.0
                                2022-01-13 20:29:01.986	warn	DeviceConfigure:DeviceConfigure failed 0x842e14fffe285173 Remote Control N2, attempt 3 (Error: Bind 0x842e14fffe285173/1 genPowerCfg from '0x00212effff065d89/1' failed (waiting for response TIMEOUT) at DeconzAdapter.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:753:19))
                                zigbee.0
                                2022-01-13 20:28:01.493	info	Configuring 0x842e14fffe285173 Remote Control N2
                                sonoff.0
                                2022-01-13 20:24:54.257	info	Client [Wohnzimmer Sideboard] reconnected. Old secret 1642070506761_3379. New secret 1642101894254_3674
                                sonoff.0
                                2022-01-13 20:24:50.112	info	Client [Schlafzimmer_TV] reconnected. Old secret 1642070503612_6846. New secret 1642101890111_5336
                                sonoff.0
                                2022-01-13 20:24:39.443	info	Client [Nachttisch Tamara] reconnected. Old secret 1642070518106_1636. New secret 1642101879442_9980
                                sonoff.0
                                2022-01-13 20:24:38.331	info	Client [Vitrinenlicht] reconnected. Old secret 1642070504959_7204. New secret 1642101878330_8129
                                sonoff.0
                                2022-01-13 20:24:34.355	info	Client [Wohnwand] reconnected. Old secret 1642070508982_6725. New secret 1642101874351_7033
                                zigbee.0
                                2022-01-13 19:53:09.352	warn	DeviceConfigure:DeviceConfigure failed 0x842e14fffe285173 Remote Control N2, attempt 2 (Error: Bind 0x842e14fffe285173/1 genPowerCfg from '0x00212effff065d89/1' failed (waiting for response TIMEOUT) at DeconzAdapter.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:753:19))
                                zigbee.0
                                2022-01-13 19:52:09.335	info	Configuring 0x842e14fffe285173 Remote Control N2
                                zigbee.0
                                2022-01-13 19:51:49.345	warn	DeviceConfigure:DeviceConfigure failed 0x842e14fffe285173 Remote Control N2, attempt 1 (Error: Bind 0x842e14fffe285173/1 genPowerCfg from '0x00212effff065d89/1' failed (waiting for response TIMEOUT) at DeconzAdapter.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:753:19) at runNextTicks (internal/process/task_queues.js:62:5) at processTimers (internal/timers.js:494:9))
                                zigbee.0
                                2022-01-13 19:50:48.344	info	Configuring 0x842e14fffe285173 Remote Control N2
                                zigbee.0
                                2022-01-13 19:50:48.341	warn	DeviceAvailability:Failed to ping 0x84ba20fffe77b835 TS011F
                                zigbee.0
                                2022-01-13 19:50:48.339	warn	DeviceConfigure:DeviceConfigure failed 0x84fd27fffe1f8f8c TRADFRI on/off switch, attempt 1 (Error: Bind 0x84fd27fffe1f8f8c/1 genOnOff from '901' failed (waiting for response TIMEOUT) at DeconzAdapter.bind (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:753:19))
                                zigbee.0
                                2022-01-13 19:49:47.334	info	Configuring 0x84fd27fffe1f8f8c TRADFRI on/off switch
                                zigbee.0
                                2022-01-13 19:49:47.331	warn	DeviceConfigure:DeviceConfigure failed 0x84ba20fffe77b835 TS011F, attempt 1 (Error: Read 0x84ba20fffe77b835/1 genBasic(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received) at DeconzAdapter.sendZclFrameToEndpoint (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:641:23) at runNextTicks (internal/process/task_queues.js:62:5) at processTimers (internal/timers.js:494:9))
                                zigbee.0
                                2022-01-13 19:48:47.027	info	debug devices set to []
                                zigbee.0
                                2022-01-13 19:48:46.888	info	Zigbee started
                                zigbee.0
                                2022-01-13 19:48:46.888	warn	config :{"port":"/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2253809-if00","panID":"6754","extPanID":"DDDDDDDDDDDDDDDD","channel":"11","disableLed":false,"precfgkey":"abcdef01234567899876543210fedcba","countDown":"60","adapterType":"deconz","debugHerdsman":false,"transmitPower":null,"extPanIdFix":true,"disablePing":false,"external":"","startWithInconsistent":false}
                                zigbee.0
                                2022-01-13 19:48:46.887	info	0x84ba20fffe80c9ba (addr 37695): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                                zigbee.0
                                2022-01-13 19:48:46.885	info	0x540f57fffe8971d1 (addr 40423): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                                zigbee.0
                                2022-01-13 19:48:46.883	info	0x804b50fffe606093 (addr 21921): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                                zigbee.0
                                2022-01-13 19:48:46.881	info	0x842e14fffe285173 (addr 60803): E2001/E2002 - IKEA STYRBAR remote control N2 (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.880	info	0x842e14fffe89313a (addr 26171): E2001/E2002 - IKEA STYRBAR remote control N2 (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.878	info	0xb4e3f9fffeaae8c8 (addr 59871): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                                zigbee.0
                                2022-01-13 19:48:46.877	info	0x84fd27fffe1f8f8c (addr 8187): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.875	info	0x84fd27fffe1f8f5d (addr 43353): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.871	info	0x84ba20fffe77b200 (addr 29486): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                                zigbee.0
                                2022-01-13 19:48:46.870	info	0x84ba20fffe77b835 (addr 487): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                                zigbee.0
                                2022-01-13 19:48:46.867	info	0x804b50fffef8cf51 (addr 60471): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.866	info	0x00158d0005cf4ea4 (addr 42668): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.865	info	0x84fd27fffe245425 (addr 308): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.863	info	0x00158d00044eefbe (addr 41589): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.862	info	0x00158d00073c0c65 (addr 815): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.860	info	0x00158d000774f2cb (addr 13799): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.859	info	0x00158d000774f2c9 (addr 16865): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.858	info	0x00158d00077dce21 (addr 56764): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.856	info	0x00158d000774f31c (addr 31399): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.855	info	0x00158d00075f6607 (addr 3323): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.852	info	0x00158d00077dce53 (addr 62480): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.850	info	0x00158d000774f34a (addr 13527): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.849	info	0x00158d00019f3736 (addr 26600): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.847	info	0x00158d0001e4e9e3 (addr 29911): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.846	info	0x00158d000774f35a (addr 23883): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.843	info	0x00158d00076565a1 (addr 35956): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.837	info	0x00178801089de95e (addr 39138): 929002240401 - Philips Hue smart plug - EU (Router)
                                zigbee.0
                                2022-01-13 19:48:46.835	info	0x00178801089def32 (addr 26711): 929002240401 - Philips Hue smart plug - EU (Router)
                                zigbee.0
                                2022-01-13 19:48:46.834	info	0x00158d0005cf8b49 (addr 43071): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.832	info	0x00158d0003f0f373 (addr 46914): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.831	info	0x00158d000282eec7 (addr 19057): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.829	info	0x00158d000412fc1e (addr 39417): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.828	info	0x00158d00041d8697 (addr 26015): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.826	info	0x00158d000163f2bc (addr 63165): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.824	info	0x00158d000283e64e (addr 18527): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.822	info	0x00158d000283e67b (addr 50956): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.820	info	0x00158d00051e1633 (addr 39535): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.818	info	0x00158d00051dfd12 (addr 48749): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.817	info	0x00158d00052debfb (addr 30191): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.815	info	0x00158d0005221c37 (addr 57703): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.814	info	0x00158d0005221fbe (addr 11411): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.813	info	0x00158d0005221c38 (addr 31581): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.809	info	0x00158d000309a45a (addr 35075): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.806	info	0x00158d000410e8ca (addr 1223): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.804	info	0x00158d000411103a (addr 26950): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.786	info	0x00158d000410e87b (addr 32835): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                zigbee.0
                                2022-01-13 19:48:46.781	info	Configuring 0x84ba20fffe77b835 TS011F
                                zigbee.0
                                2022-01-13 19:48:46.586	info	Currently 46 devices are joined:
                                zigbee.0
                                2022-01-13 19:48:46.576	info	Unable to set transmit power, unsupported function.
                                zigbee.0
                                2022-01-13 19:48:46.399	info	--> transmitPower : normal
                                zigbee.0
                                2022-01-13 19:48:46.388	info	Unable to disable LED, unsupported function.
                                zigbee.0
                                2022-01-13 19:48:46.367	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
                                zigbee.0
                                2022-01-13 19:48:46.334	info	Installed Version: ioBroker/ioBroker.zigbee
                                zigbee.0
                                2022-01-13 19:48:45.775	warn	extension DelayedAction
                                zigbee.0
                                2022-01-13 19:48:45.774	warn	extension DeviceEvent
                                zigbee.0
                                2022-01-13 19:48:45.774	warn	extension DeviceConfigure
                                zigbee.0
                                2022-01-13 19:48:45.773	warn	extension DeviceAvailability
                                zigbee.0
                                2022-01-13 19:48:45.773	warn	4 extensions initialized
                                zigbee.0
                                2022-01-13 19:48:45.771	info	Starting Zigbee npm ...
                                zigbee.0
                                2022-01-13 19:48:45.654	info	starting. Version 1.6.11 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.0, js-controller: 3.3.21
                                host.raspberrypi
                                2022-01-13 19:48:41.359	info	instance system.adapter.zigbee.0 started with pid 15729
                                host.raspberrypi
                                2022-01-13 19:48:11.308	info	Restart adapter system.adapter.zigbee.0 because enabled
                                host.raspberrypi
                                2022-01-13 19:48:11.307	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                host.raspberrypi
                                2022-01-13 19:48:11.307	error	Caught by controller[1]: at Parser.EventEmitter.emit (domain.js:483:12)
                                host.raspberrypi
                                2022-01-13 19:48:11.306	error	Caught by controller[1]: at Parser.emit (events.js:314:20)
                                host.raspberrypi
                                2022-01-13 19:48:11.306	error	Caught by controller[1]: at Driver.onParsed (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:784:14)
                                host.raspberrypi
                                2022-01-13 19:48:11.306	error	Caught by controller[1]: at Driver.EventEmitter.emit (domain.js:483:12)
                                host.raspberrypi
                                2022-01-13 19:48:11.306	error	Caught by controller[1]: at Driver.emit (events.js:314:20)
                                host.raspberrypi
                                2022-01-13 19:48:11.305	error	Caught by controller[1]: at Driver.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:63:59)
                                host.raspberrypi
                                2022-01-13 19:48:11.305	error	Caught by controller[1]: at processFrame (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:405:59)
                                host.raspberrypi
                                2022-01-13 19:48:11.305	error	Caught by controller[1]: at parseFrame (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:458:32)
                                host.raspberrypi
                                2022-01-13 19:48:11.305	error	Caught by controller[1]: at parseGreenPowerDataIndication (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:313:33)
                                host.raspberrypi
                                2022-01-13 19:48:11.304	error	Caught by controller[1]: at DataView.getUint32 (<anonymous>)
                                host.raspberrypi
                                2022-01-13 19:48:11.304	error	Caught by controller[1]: RangeError: Offset is outside the bounds of the DataView
                                host.raspberrypi
                                2022-01-13 19:48:11.291	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                zigbee.0
                                2022-01-13 19:48:10.644	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                zigbee.0
                                2022-01-13 19:48:10.640	info	terminating
                                zigbee.0
                                2022-01-13 19:48:10.494	info	Zigbee: disabling joining new devices.
                                zigbee.0
                                2022-01-13 19:48:10.353	info	cleaned everything up...
                                zigbee.0
                                2022-01-13 19:48:10.288	error	Offset is outside the bounds of the DataView
                                zigbee.0
                                2022-01-13 19:48:10.288	error	RangeError: Offset is outside the bounds of the DataView at DataView.getUint32 (<anonymous>) at parseGreenPowerDataIndication (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:313:33) at parseFrame (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:458:32) at processFrame (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/frameParser.ts:405:59) at Driver.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:63:59) at Driver.emit (events.js:314:20) at Driver.EventEmitter.emit (domain.js:483:12) at Driver.onParsed (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:784:14) at Parser.emit (events.js:314:20) at Parser.EventEmitter.emit (domain.js:483:12)
                                zigbee.0
                                2022-01-13 19:48:10.228	error	unhandled promise rejection: Offset is outside the bounds of the DataView
                                zigbee.0
                                2022-01-13 19:48:10.224	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                info.0
                                2022-01-13 19:20:27.453	info	cpu Temp res = {"main":43.816,"cores":[],"max":43.816,"socket":[],"chipset":null}
                                info.0
                                2022-01-13 19:20:27.299	info	State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                                info.0
                                2022-01-13 19:20:27.292	info	State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
                                info.0
                                2022-01-13 19:20:27.286	info	State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
                                info.0
                                2022-01-13 19:20:27.238	info	State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
                                info.0
                                2022-01-13 19:20:27.185	info	State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                                info.0
                                2022-01-13 19:20:26.622	info	Reading/updating systemdata.
                                hue-extended.0
                                2022-01-13 19:13:39.979	info	Attempt 1x - Successfully set Bad Kevin.
                                hue-extended.0
                                2022-01-13 19:06:18.482	info	Attempt 1x - Successfully set Bad Kevin.
                                zigbee.0
                                2022-01-13 15:50:55.730	warn	Device '0x84fd27fffe1f8f5d' announced itself
                                zigbee.0
                                2022-01-13 12:15:39.375	warn	Device '0x84fd27fffe1f8f5d' announced itself
                                zigbee.0
                                2022-01-13 12:10:23.250	warn	Device '0x804b50fffef8cf51' announced itself
                                • S Schmetterfliege
                                  zigbee.0
                                  zigbee.0
                                  javascript.0
                                  zigbee.0
                                  zigbee.0
                                  hue-extended.0
                                  hue-extended.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  sonoff.0
                                  sonoff.0
                                  sonoff.0
                                  sonoff.0
                                  sonoff.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  info.0
                                  info.0
                                  info.0
                                  info.0
                                  info.0
                                  info.0
                                  info.0
                                  hue-extended.0
                                  hue-extended.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  @schmetterfliege
                                  Da hat die deconz Stick ein “malformed packet” bekommen und konnte damit nicht umgehen. Welches Geräte dafür verantwortlich ist kann das log nicht zeigen.
                                  A.
                                  • AsgothianA Asgothian
                                    @schmetterfliege
                                    A.
                                    Schmetterfliege
                                    @asgothian
                                    habe so ein bisschen die Sorge dass es das neueste Update ist das dafür sorgt.
                                    Vorher hatte ich diesen Crash noch nie, und auch dass da einige Geräte die ganze Zeit warnings ausgeben ist erst seit dem.
                                    Kann aber natürlich auch an den Ikea Remote Controls liegen.
                                    Kann ich irgendwas tun um bessere Infos zu liefern?
                                    • S Schmetterfliege
                                      @asgothian
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      @schmetterfliege wenn das ganze öfter auftrittt kannst du den Adapter im debug und mit zigbee herdsman debug info Aktiv in der Konfiguration.
                                      Warnung - das log kann dabei sehr groß werden. Wenn du den Fehler also nicht triggern kannst dann wird das schwierig.
                                      A.
                                        A.
                                        Schmetterfliege
                                        @asgothian
                                        Okay, dann werde ich es mal beobachten und falls ich ein Muster erkenne Debug aktivieren :)
                                        YodameisterY 1 Antwort Letzte Antwort
                                        • S Schmetterfliege
                                          @asgothian
                                          YodameisterY Offline
                                          Yodameister
                                          @schmetterfliege @Asgothian
                                          Hallo Ihr Lieben, ich beiße mir auch gerade die Zähne aus an Blitzwolf bw-shp13 , Adapter ist 1.6.15 ( mit 1.6.16 habe ich das auch probiert ).
                                          er findet das Gerät TS011F aber mehr nicht.
                                          2022-03-09 17_12_24-instances - ubuntu und 3 weitere Seiten - Persönlich – Microsoft​ Edge.png
                                          kann mir jemand auf die Sprünge helfen ?
                                          Maik
