  4. Raspi 3 Model B mit Samsung SSD 500GB
    5.5k
86 Beiträge 10 Kommentatoren 10.1k Aufrufe 7 Beobachtet
  • J JürgenIO
    @thomas-braun sagte in Raspi 3 Model B mit Samsung SSD 500GB:
    dmesg -T
    [Wed Jan  5 14:20:00 2022] Booting Linux on physical CPU 0x0
    [Wed Jan  5 14:20:00 2022] Linux version 5.10.17-v7+ (dom@buildbot) (arm-linux-g        nueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ub        untu) 2.34) #1403 SMP Mon Feb 22 11:29:51 GMT 2021
    [Wed Jan  5 14:20:00 2022] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), c        r=10c5383d
    [Wed Jan  5 14:20:00 2022] CPU: div instructions available: patching division co        de
    [Wed Jan  5 14:20:00 2022] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasin        g instruction cache
    [Wed Jan  5 14:20:00 2022] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus R        ev 1.3
    [Wed Jan  5 14:20:00 2022] Memory policy: Data cache writealloc
    [Wed Jan  5 14:20:00 2022] Reserved memory: created CMA memory pool at 0x3740000        0, size 64 MiB
    [Wed Jan  5 14:20:00 2022] OF: reserved mem: initialized node linux,cma, compati        ble id shared-dma-pool
    [Wed Jan  5 14:20:00 2022] Zone ranges:
    [Wed Jan  5 14:20:00 2022]   DMA      [mem 0x0000000000000000-0x000000003b3fffff        ]
    [Wed Jan  5 14:20:00 2022]   Normal   empty
    [Wed Jan  5 14:20:00 2022] Movable zone start for each node
    [Wed Jan  5 14:20:00 2022] Early memory node ranges
    [Wed Jan  5 14:20:00 2022]   node   0: [mem 0x0000000000000000-0x000000003b3ffff        f]
    [Wed Jan  5 14:20:00 2022] Initmem setup node 0 [mem 0x0000000000000000-0x000000        003b3fffff]
    [Wed Jan  5 14:20:00 2022] On node 0 totalpages: 242688
    [Wed Jan  5 14:20:00 2022]   DMA zone: 2133 pages used for memmap
    [Wed Jan  5 14:20:00 2022]   DMA zone: 0 pages reserved
    [Wed Jan  5 14:20:00 2022]   DMA zone: 242688 pages, LIFO batch:63
    [Wed Jan  5 14:20:00 2022] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81        920
    [Wed Jan  5 14:20:00 2022] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
    [Wed Jan  5 14:20:00 2022] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [Wed Jan  5 14:20:00 2022] Built 1 zonelists, mobility grouping on.  Total pages        : 240555
    [Wed Jan  5 14:20:00 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=6        56 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem        .mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=4c6fdb90-0        2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait ip=192.168.0.64::19        2.168.0.1:255.255.255.0:rpi:eth0:off
    [Wed Jan  5 14:20:00 2022] Kernel parameter elevator= does not have any effect a        nymore.
                               Please use sysfs to set IO scheduler for individual d        evices.
    [Wed Jan  5 14:20:00 2022] Dentry cache hash table entries: 131072 (order: 7, 52        4288 bytes, linear)
    [Wed Jan  5 14:20:00 2022] Inode-cache hash table entries: 65536 (order: 6, 2621        44 bytes, linear)
    [Wed Jan  5 14:20:00 2022] mem auto-init: stack:off, heap alloc:off, heap free:o        ff
    [Wed Jan  5 14:20:00 2022] Memory: 879832K/970752K available (9216K kernel code,        1311K rwdata, 2940K rodata, 1024K init, 860K bss, 25384K reserved, 65536K cma-r        eserved)
    [Wed Jan  5 14:20:00 2022] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, No        des=1
    [Wed Jan  5 14:20:00 2022] ftrace: allocating 31910 entries in 63 pages
    [Wed Jan  5 14:20:00 2022] ftrace: allocated 63 pages with 6 groups
    [Wed Jan  5 14:20:00 2022] rcu: Hierarchical RCU implementation.
    [Wed Jan  5 14:20:00 2022]      Rude variant of Tasks RCU enabled.
    [Wed Jan  5 14:20:00 2022]      Tracing variant of Tasks RCU enabled.
    [Wed Jan  5 14:20:00 2022] rcu: RCU calculated value of scheduler-enlistment del        ay is 10 jiffies.
    [Wed Jan  5 14:20:00 2022] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [Wed Jan  5 14:20:00 2022] random: get_random_bytes called from start_kernel+0x3        ac/0x580 with crng_init=0
    [Wed Jan  5 14:20:00 2022] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
    [Wed Jan  5 14:20:00 2022] clocksource: arch_sys_counter: mask: 0xffffffffffffff        max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
    [Wed Jan  5 14:20:00 2022] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps        every 4398046511078ns
    [Wed Jan  5 14:20:00 2022] Switching to timer-based delay loop, resolution 52ns
    [Wed Jan  5 14:20:00 2022] Console: colour dummy device 80x30
    [Wed Jan  5 14:20:00 2022] printk: console [tty1] enabled
    [Wed Jan  5 14:20:00 2022] Calibrating delay loop (skipped), value calculated us        ing timer frequency.. 38.40 BogoMIPS (lpj=192000)
    [Wed Jan  5 14:20:00 2022] pid_max: default: 32768 minimum: 301
    [Wed Jan  5 14:20:00 2022] LSM: Security Framework initializing
    [Wed Jan  5 14:20:00 2022] Mount-cache hash table entries: 2048 (order: 1, 8192        bytes, linear)
    [Wed Jan  5 14:20:00 2022] Mountpoint-cache hash table entries: 2048 (order: 1,        8192 bytes, linear)
    [Wed Jan  5 14:20:00 2022] Disabling memory control group subsystem
    [Wed Jan  5 14:20:00 2022] CPU: Testing write buffer coherency: ok
    [Wed Jan  5 14:20:00 2022] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [Wed Jan  5 14:20:00 2022] Setting up static identity map for 0x100000 - 0x10003        c
    [Wed Jan  5 14:20:00 2022] rcu: Hierarchical SRCU implementation.
    [Wed Jan  5 14:20:00 2022] smp: Bringing up secondary CPUs ...
    [Wed Jan  5 14:20:00 2022] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [Wed Jan  5 14:20:00 2022] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [Wed Jan  5 14:20:00 2022] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [Wed Jan  5 14:20:00 2022] smp: Brought up 1 node, 4 CPUs
    [Wed Jan  5 14:20:00 2022] SMP: Total of 4 processors activated (153.60 BogoMIPS        ).
    [Wed Jan  5 14:20:00 2022] CPU: All CPU(s) started in HYP mode.
    [Wed Jan  5 14:20:00 2022] CPU: Virtualization extensions available.
    [Wed Jan  5 14:20:00 2022] devtmpfs: initialized
    [Wed Jan  5 14:20:00 2022] VFP support v0.3: implementor 41 architecture 3 part        40 variant 3 rev 4
    [Wed Jan  5 14:20:00 2022] clocksource: jiffies: mask: 0xffffffff max_cycles: 0x        ffffffff, max_idle_ns: 19112604462750000 ns
    [Wed Jan  5 14:20:00 2022] futex hash table entries: 1024 (order: 4, 65536 bytes        , linear)
    [Wed Jan  5 14:20:00 2022] pinctrl core: initialized pinctrl subsystem
    [Wed Jan  5 14:20:00 2022] NET: Registered protocol family 16
    [Wed Jan  5 14:20:00 2022] DMA: preallocated 1024 KiB pool for atomic coherent a        llocations
    [Wed Jan  5 14:20:00 2022] audit: initializing netlink subsys (disabled)
    [Wed Jan  5 14:20:00 2022] audit: type=2000 audit(0.040:1): state=initialized au        dit_enabled=0 res=1
    [Wed Jan  5 14:20:00 2022] thermal_sys: Registered thermal governor 'step_wise'
    [Wed Jan  5 14:20:00 2022] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4        watchpoint registers.
    [Wed Jan  5 14:20:00 2022] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [Wed Jan  5 14:20:00 2022] Serial: AMBA PL011 UART driver
    [Wed Jan  5 14:20:00 2022] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
    [Wed Jan  5 14:20:00 2022] raspberrypi-firmware soc:firmware: Attached to firmwa        re from 2021-02-25T12:12:09, variant start
    [Wed Jan  5 14:20:00 2022] raspberrypi-firmware soc:firmware: Firmware hash is 5        64e5f9b852b23a330b1764bcf0b2d022a20afd0
    [Wed Jan  5 14:20:00 2022] bcm2835-dma 3f007000.dma: DMA legacy API manager, dma        chans=0x1
    [Wed Jan  5 14:20:00 2022] SCSI subsystem initialized
    [Wed Jan  5 14:20:00 2022] usbcore: registered new interface driver usbfs
    [Wed Jan  5 14:20:00 2022] usbcore: registered new interface driver hub
    [Wed Jan  5 14:20:00 2022] usbcore: registered new device driver usb
    [Wed Jan  5 14:20:00 2022] clocksource: Switched to clocksource arch_sys_counter
    [Wed Jan  5 14:20:01 2022] VFS: Disk quotas dquot_6.6.0
    [Wed Jan  5 14:20:01 2022] VFS: Dquot-cache hash table entries: 1024 (order 0, 4        096 bytes)
    [Wed Jan  5 14:20:01 2022] FS-Cache: Loaded
    [Wed Jan  5 14:20:01 2022] CacheFiles: Loaded
    [Wed Jan  5 14:20:01 2022] NET: Registered protocol family 2
    [Wed Jan  5 14:20:01 2022] tcp_listen_portaddr_hash hash table entries: 512 (ord        er: 0, 6144 bytes, linear)
    [Wed Jan  5 14:20:01 2022] TCP established hash table entries: 8192 (order: 3, 3        2768 bytes, linear)
    [Wed Jan  5 14:20:01 2022] TCP bind hash table entries: 8192 (order: 4, 65536 by        tes, linear)
    [Wed Jan  5 14:20:01 2022] TCP: Hash tables configured (established 8192 bind 81        92)
    [Wed Jan  5 14:20:01 2022] UDP hash table entries: 512 (order: 2, 16384 bytes, l        inear)
    [Wed Jan  5 14:20:01 2022] UDP-Lite hash table entries: 512 (order: 2, 16384 byt        es, linear)
    [Wed Jan  5 14:20:01 2022] NET: Registered protocol family 1
    [Wed Jan  5 14:20:01 2022] RPC: Registered named UNIX socket transport module.
    [Wed Jan  5 14:20:01 2022] RPC: Registered udp transport module.
    [Wed Jan  5 14:20:01 2022] RPC: Registered tcp transport module.
    [Wed Jan  5 14:20:01 2022] RPC: Registered tcp NFSv4.1 backchannel transport mod        ule.
    [Wed Jan  5 14:20:01 2022] hw perfevents: enabled with armv7_cortex_a7 PMU drive        r, 7 counters available
    [Wed Jan  5 14:20:01 2022] Initialise system trusted keyrings
    [Wed Jan  5 14:20:01 2022] workingset: timestamp_bits=14 max_order=18 bucket_ord        er=4
    [Wed Jan  5 14:20:01 2022] zbud: loaded
    [Wed Jan  5 14:20:01 2022] FS-Cache: Netfs 'nfs' registered for caching
    [Wed Jan  5 14:20:01 2022] NFS: Registering the id_resolver key type
    [Wed Jan  5 14:20:01 2022] Key type id_resolver registered
    [Wed Jan  5 14:20:01 2022] Key type id_legacy registered
    [Wed Jan  5 14:20:01 2022] nfs4filelayout_init: NFSv4 File Layout Driver Registe        ring...
    [Wed Jan  5 14:20:01 2022] Key type asymmetric registered
    [Wed Jan  5 14:20:01 2022] Asymmetric key parser 'x509' registered
    [Wed Jan  5 14:20:01 2022] Block layer SCSI generic (bsg) driver version 0.4 loa        ded (major 249)
    [Wed Jan  5 14:20:01 2022] io scheduler mq-deadline registered
    [Wed Jan  5 14:20:01 2022] io scheduler kyber registered
    [Wed Jan  5 14:20:01 2022] bcm2708_fb soc:fb: FB found 1 display(s)
    [Wed Jan  5 14:20:01 2022] Console: switching to colour frame buffer device 82x2        6
    [Wed Jan  5 14:20:01 2022] bcm2708_fb soc:fb: Registered framebuffer for display        0, size 656x416
    [Wed Jan  5 14:20:01 2022] bcm2835-rng 3f104000.rng: hwrng registered
    [Wed Jan  5 14:20:01 2022] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_        size:0x40000000(1024 MiB)
    [Wed Jan  5 14:20:01 2022] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Regist        ers at 0x3f200000
    [Wed Jan  5 14:20:02 2022] brd: module loaded
    [Wed Jan  5 14:20:02 2022] loop: module loaded
    [Wed Jan  5 14:20:02 2022] Loading iSCSI transport class v2.0-870.
    [Wed Jan  5 14:20:02 2022] libphy: Fixed MDIO Bus: probed
    [Wed Jan  5 14:20:02 2022] usbcore: registered new interface driver lan78xx
    [Wed Jan  5 14:20:02 2022] usbcore: registered new interface driver smsc95xx
    [Wed Jan  5 14:20:02 2022] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [Wed Jan  5 14:20:02 2022] Core Release: 2.80a
    [Wed Jan  5 14:20:02 2022] Setting default values for core params
    [Wed Jan  5 14:20:02 2022] Finished setting default values for core params
    [Wed Jan  5 14:20:02 2022] Using Buffer DMA mode
    [Wed Jan  5 14:20:02 2022] Periodic Transfer Interrupt Enhancement - disabled
    [Wed Jan  5 14:20:02 2022] Multiprocessor Interrupt Enhancement - disabled
    [Wed Jan  5 14:20:02 2022] OTG VER PARAM: 0, OTG VER FLAG: 0
    [Wed Jan  5 14:20:02 2022] Dedicated Tx FIFOs mode
    [Wed Jan  5 14:20:02 2022] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers:        virt = b7514000 dma = 0xf7514000 len=9024
    [Wed Jan  5 14:20:03 2022] FIQ FSM acceleration enabled for :
                               Non-periodic Split Transactions
                               Periodic Split Transactions
                               High-Speed Isochronous Endpoints
                               Interrupt/Control Split Transaction hack enabled
    [Wed Jan  5 14:20:03 2022] dwc_otg: Microframe scheduler enabled
    [Wed Jan  5 14:20:03 2022] WARN::hcd_init_fiq:457: FIQ on core 1
    [Wed Jan  5 14:20:03 2022] WARN::hcd_init_fiq:458: FIQ ASM at 807be568 length 36
    [Wed Jan  5 14:20:03 2022] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
    [Wed Jan  5 14:20:03 2022] dwc_otg 3f980000.usb: DWC OTG Controller
    [Wed Jan  5 14:20:03 2022] dwc_otg 3f980000.usb: new USB bus registered, assigne        d bus number 1
    [Wed Jan  5 14:20:03 2022] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
    [Wed Jan  5 14:20:03 2022] Init: Port Power? op_state=1
    [Wed Jan  5 14:20:03 2022] Init: Power Port (0)
    [Wed Jan  5 14:20:03 2022] usb usb1: New USB device found, idVendor=1d6b, idProd        uct=0002, bcdDevice= 5.10
    [Wed Jan  5 14:20:03 2022] usb usb1: New USB device strings: Mfr=3, Product=2, S        erialNumber=1
    [Wed Jan  5 14:20:03 2022] usb usb1: Product: DWC OTG Controller
    [Wed Jan  5 14:20:03 2022] usb usb1: Manufacturer: Linux 5.10.17-v7+ dwc_otg_hcd
    [Wed Jan  5 14:20:03 2022] usb usb1: SerialNumber: 3f980000.usb
    [Wed Jan  5 14:20:03 2022] hub 1-0:1.0: USB hub found
    [Wed Jan  5 14:20:03 2022] hub 1-0:1.0: 1 port detected
    [Wed Jan  5 14:20:03 2022] dwc_otg: FIQ enabled
    [Wed Jan  5 14:20:03 2022] dwc_otg: NAK holdoff enabled
    [Wed Jan  5 14:20:03 2022] dwc_otg: FIQ split-transaction FSM enabled
    [Wed Jan  5 14:20:03 2022] Module dwc_common_port init
    [Wed Jan  5 14:20:03 2022] usbcore: registered new interface driver usb-storage
    [Wed Jan  5 14:20:03 2022] mousedev: PS/2 mouse device common for all mice
    [Wed Jan  5 14:20:03 2022] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog ti        mer
    [Wed Jan  5 14:20:03 2022] sdhci: Secure Digital Host Controller Interface drive        r
    [Wed Jan  5 14:20:03 2022] sdhci: Copyright(c) Pierre Ossman
    [Wed Jan  5 14:20:03 2022] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferr        ing probe
    [Wed Jan  5 14:20:03 2022] sdhost-bcm2835 3f202000.mmc: could not get clk, defer        ring probe
    [Wed Jan  5 14:20:03 2022] sdhci-pltfm: SDHCI platform and OF driver helper
    [Wed Jan  5 14:20:03 2022] ledtrig-cpu: registered to indicate activity on CPUs
    [Wed Jan  5 14:20:03 2022] hid: raw HID events driver (C) Jiri Kosina
    [Wed Jan  5 14:20:03 2022] usbcore: registered new interface driver usbhid
    [Wed Jan  5 14:20:03 2022] usbhid: USB HID core driver
    [Wed Jan  5 14:20:03 2022] Initializing XFRM netlink socket
    [Wed Jan  5 14:20:03 2022] NET: Registered protocol family 17
    [Wed Jan  5 14:20:03 2022] Key type dns_resolver registered
    [Wed Jan  5 14:20:03 2022] Registering SWP/SWPB emulation handler
    [Wed Jan  5 14:20:03 2022] registered taskstats version 1
    [Wed Jan  5 14:20:03 2022] Loading compiled-in X.509 certificates
    [Wed Jan  5 14:20:03 2022] Key type ._fscrypt registered
    [Wed Jan  5 14:20:03 2022] Key type .fscrypt registered
    [Wed Jan  5 14:20:03 2022] Key type fscrypt-provisioning registered
    [Wed Jan  5 14:20:03 2022] uart-pl011 3f201000.serial: cts_event_workaround enab        led
    [Wed Jan  5 14:20:03 2022] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 11        4, base_baud = 0) is a PL011 rev2
    [Wed Jan  5 14:20:03 2022] bcm2835-power bcm2835-power: Broadcom BCM2835 power d        omains driver
    [Wed Jan  5 14:20:03 2022] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [Wed Jan  5 14:20:03 2022] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
    [Wed Jan  5 14:20:03 2022] sdhost: log_buf @ (ptrval) (f7513000)
    [Wed Jan  5 14:20:03 2022] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [Wed Jan  5 14:20:03 2022] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [Wed Jan  5 14:20:03 2022] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [Wed Jan  5 14:20:03 2022] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
    [Wed Jan  5 14:20:03 2022] of_cfs_init
    [Wed Jan  5 14:20:03 2022] of_cfs_init: OK
    [Wed Jan  5 14:20:03 2022] Indeed it is in host mode hprt0 = 00021501
    [Wed Jan  5 14:20:03 2022] random: fast init done
    [Wed Jan  5 14:20:03 2022] mmc1: new high speed SDIO card at address 0001
    [Wed Jan  5 14:20:03 2022] usb 1-1: new high-speed USB device number 2 using dwc        _otg
    [Wed Jan  5 14:20:03 2022] Indeed it is in host mode hprt0 = 00001101
    [Wed Jan  5 14:20:03 2022] usb 1-1: New USB device found, idVendor=0424, idProdu        ct=2514, bcdDevice= b.b3
    [Wed Jan  5 14:20:03 2022] usb 1-1: New USB device strings: Mfr=0, Product=0, Se        rialNumber=0
    [Wed Jan  5 14:20:03 2022] hub 1-1:1.0: USB hub found
    [Wed Jan  5 14:20:03 2022] hub 1-1:1.0: 4 ports detected
    [Wed Jan  5 14:20:04 2022] usb 1-1.1: new high-speed USB device number 3 using d        wc_otg
    [Wed Jan  5 14:20:04 2022] usb 1-1.1: New USB device found, idVendor=0424, idPro        duct=2514, bcdDevice= b.b3
    [Wed Jan  5 14:20:04 2022] usb 1-1.1: New USB device strings: Mfr=0, Product=0,        SerialNumber=0
    [Wed Jan  5 14:20:04 2022] hub 1-1.1:1.0: USB hub found
    [Wed Jan  5 14:20:04 2022] hub 1-1.1:1.0: 3 ports detected
    [Wed Jan  5 14:20:04 2022] dwc_otg_handle_wakeup_detected_intr lxstate = 2
    [Wed Jan  5 14:20:05 2022] usb 1-1.1.1: new high-speed USB device number 4 using        dwc_otg
    [Wed Jan  5 14:20:05 2022] usb 1-1.1.1: New USB device found, idVendor=0424, idP        roduct=7800, bcdDevice= 3.00
    [Wed Jan  5 14:20:05 2022] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0        , SerialNumber=0
    [Wed Jan  5 14:20:05 2022] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitializ        ed): No External EEPROM. Setting MAC Speed
    [Wed Jan  5 14:20:05 2022] libphy: lan78xx-mdiobus: probed
    [Wed Jan  5 14:20:05 2022] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitializ        ed): int urb period 64
    [Wed Jan  5 14:20:05 2022] usb 1-1.1.3: new high-speed USB device number 5 using        dwc_otg
    [Wed Jan  5 14:20:05 2022] usb 1-1.1.3: New USB device found, idVendor=04e8, idP        roduct=61f5, bcdDevice= 1.00
    [Wed Jan  5 14:20:05 2022] usb 1-1.1.3: New USB device strings: Mfr=2, Product=3        , SerialNumber=1
    [Wed Jan  5 14:20:05 2022] usb 1-1.1.3: Product: Portable SSD T5
    [Wed Jan  5 14:20:05 2022] usb 1-1.1.3: Manufacturer: Samsung
    [Wed Jan  5 14:20:05 2022] usb 1-1.1.3: SerialNumber: 12345688F623
    [Wed Jan  5 14:20:05 2022] usb 1-1.1.3: The driver for the USB controller dwc_ot        g_hcd does not support scatter-gather which is
    [Wed Jan  5 14:20:05 2022] usb 1-1.1.3: required by the UAS driver. Please try a        n other USB controller if you wish to use UAS.
    [Wed Jan  5 14:20:05 2022] usb-storage 1-1.1.3:1.0: USB Mass Storage device dete        cted
    [Wed Jan  5 14:20:05 2022] scsi host0: usb-storage 1-1.1.3:1.0
    [Wed Jan  5 14:20:06 2022] scsi 0:0:0:0: Direct-Access     Samsung  Portable SSD        T5  0    PQ: 0 ANSI: 6
    [Wed Jan  5 14:20:06 2022] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks:        (500 GB/466 GiB)
    [Wed Jan  5 14:20:06 2022] sd 0:0:0:0: [sda] Write Protect is off
    [Wed Jan  5 14:20:06 2022] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
    [Wed Jan  5 14:20:06 2022] sd 0:0:0:0: [sda] Write cache: enabled, read cache: e        nabled, doesn't support DPO or FUA
    [Wed Jan  5 14:20:06 2022]  sda: sda1 sda2
    [Wed Jan  5 14:20:06 2022] sd 0:0:0:0: [sda] Attached SCSI disk
    [Wed Jan  5 14:20:08 2022] IP-Config: Complete:
    [Wed Jan  5 14:20:08 2022]      device=eth0, hwaddr=b8:27:eb:67:27:a1, ipaddr=19        2.168.0.64, mask=255.255.255.0, gw=192.168.0.1
    [Wed Jan  5 14:20:08 2022]      host=rpi, domain=, nis-domain=(none)
    [Wed Jan  5 14:20:08 2022]      bootserver=255.255.255.255, rootserver=255.255.2        55.255, rootpath=
    [Wed Jan  5 14:20:08 2022] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Opts: (null)
    [Wed Jan  5 14:20:08 2022] VFS: Mounted root (ext4 filesystem) readonly on devic        e 8:2.
    [Wed Jan  5 14:20:08 2022] devtmpfs: mounted
    [Wed Jan  5 14:20:08 2022] Freeing unused kernel memory: 1024K
    [Wed Jan  5 14:20:08 2022] Run /sbin/init as init process
    [Wed Jan  5 14:20:08 2022]   with arguments:
    [Wed Jan  5 14:20:08 2022]     /sbin/init
    [Wed Jan  5 14:20:08 2022]   with environment:
    [Wed Jan  5 14:20:08 2022]     HOME=/
    [Wed Jan  5 14:20:08 2022]     TERM=linux
    [Wed Jan  5 14:20:09 2022] systemd[1]: System time before build time, advancing        clock.
    [Wed Jan  5 14:20:09 2022] random: crng init done
    [Wed Jan  5 14:20:09 2022] NET: Registered protocol family 10
    [Wed Jan  5 14:20:09 2022] Segment Routing with IPv6
    [Wed Jan  5 14:20:09 2022] systemd[1]: systemd 241 running in system mode. (+PAM        +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +G        NUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hi        erarchy=hybrid)
    [Wed Jan  5 14:20:09 2022] systemd[1]: Detected architecture arm.
    [Wed Jan  5 14:20:09 2022] systemd[1]: Set hostname to <ioBroker>.
    [Wed Jan  5 14:20:10 2022] systemd[1]: Listening on Syslog Socket.
    [Wed Jan  5 14:20:10 2022] systemd[1]: Listening on Journal Socket.
    [Wed Jan  5 14:20:10 2022] systemd[1]: Starting Create list of required static d        evice nodes for the current kernel...
    [Wed Jan  5 14:20:10 2022] systemd[1]: Listening on udev Kernel Socket.
    [Wed Jan  5 14:20:10 2022] systemd[1]: Listening on fsck to fsckd communication        Socket.
    [Wed Jan  5 14:20:10 2022] systemd[1]: Started Forward Password Requests to Wall        Directory Watch.
    [Wed Jan  5 14:20:10 2022] systemd[1]: Starting Restore / save the current clock        ...
    [Wed Jan  5 14:20:12 2022] EXT4-fs (sda2): re-mounted. Opts: (null)
    [Wed Jan  5 14:20:12 2022] systemd-journald[116]: Received request to flush runt        ime journal from PID 1
    [Wed Jan  5 14:20:13 2022] vc_sm_cma: module is from the staging directory, the        quality is unknown, you have been warned.
    [Wed Jan  5 14:20:13 2022] mc: Linux media interface: v0.10
    [Wed Jan  5 14:20:13 2022] bcm2835_vc_sm_cma_probe: Videocore shared memory driv        er
    [Wed Jan  5 14:20:13 2022] [vc_sm_connected_init]: start
    [Wed Jan  5 14:20:13 2022] [vc_sm_connected_init]: installed successfully
    [Wed Jan  5 14:20:13 2022] videodev: Linux video capture interface: v2.00
    [Wed Jan  5 14:20:13 2022] bcm2835_mmal_vchiq: module is from the staging direct        ory, the quality is unknown, you have been warned.
    [Wed Jan  5 14:20:13 2022] bcm2835_v4l2: module is from the staging directory, t        he quality is unknown, you have been warned.
    [Wed Jan  5 14:20:13 2022] bcm2835_isp: module is from the staging directory, th        e quality is unknown, you have been warned.
    [Wed Jan  5 14:20:13 2022] bcm2835-isp bcm2835-isp: Device node output[0] regist        ered as /dev/video13
    [Wed Jan  5 14:20:13 2022] bcm2835-isp bcm2835-isp: Device node capture[0] regis        tered as /dev/video14
    [Wed Jan  5 14:20:13 2022] bcm2835-isp bcm2835-isp: Device node capture[1] regis        tered as /dev/video15
    [Wed Jan  5 14:20:13 2022] bcm2835-isp bcm2835-isp: Device node stats[2] registe        red as /dev/video16
    [Wed Jan  5 14:20:13 2022] bcm2835-isp bcm2835-isp: Register output node 0 with        media controller
    [Wed Jan  5 14:20:13 2022] bcm2835-isp bcm2835-isp: Register capture node 1 with        media controller
    [Wed Jan  5 14:20:13 2022] bcm2835-isp bcm2835-isp: Register capture node 2 with        media controller
    [Wed Jan  5 14:20:13 2022] bcm2835-isp bcm2835-isp: Register capture node 3 with        media controller
    [Wed Jan  5 14:20:13 2022] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [Wed Jan  5 14:20:13 2022] snd_bcm2835: module is from the staging directory, th        e quality is unknown, you have been warned.
    [Wed Jan  5 14:20:13 2022] bcm2835_audio bcm2835_audio: card created with 8 chan        nels
    [Wed Jan  5 14:20:13 2022] bcm2835_codec: module is from the staging directory,        the quality is unknown, you have been warned.
    [Wed Jan  5 14:20:13 2022] bcm2835-codec bcm2835-codec: Device registered as /de        v/video10
    [Wed Jan  5 14:20:13 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [Wed Jan  5 14:20:13 2022] bcm2835-codec bcm2835-codec: Device registered as /de        v/video11
    [Wed Jan  5 14:20:13 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [Wed Jan  5 14:20:13 2022] bcm2835-codec bcm2835-codec: Device registered as /de        v/video12
    [Wed Jan  5 14:20:13 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [Wed Jan  5 14:20:13 2022] cfg80211: Loading compiled-in X.509 certificates for        regulatory database
    [Wed Jan  5 14:20:13 2022] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9        cea7'
    [Wed Jan  5 14:20:13 2022] usbcore: registered new interface driver uas
    [Wed Jan  5 14:20:13 2022] brcmfmac: F1 signature read @0x18000000=0x15264345
    [Wed Jan  5 14:20:13 2022] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac        43455-sdio for chip BCM4345/6
    [Wed Jan  5 14:20:13 2022] usbcore: registered new interface driver brcmfmac
    [Wed Jan  5 14:20:13 2022] brcmfmac mmc1:0001:1: Direct firmware load for brcm/b        rcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt failed with error -2
    [Wed Jan  5 14:20:14 2022] sd 0:0:0:0: Attached scsi generic sg0 type 0
    [Wed Jan  5 14:20:14 2022] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac        43455-sdio for chip BCM4345/6
    [Wed Jan  5 14:20:14 2022] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6        wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
    [Wed Jan  5 14:20:16 2022] 8021q: 802.1Q VLAN Support v1.8
    [Wed Jan  5 14:20:16 2022] 8021q: adding VLAN 0 to HW filter on device eth0
    [Wed Jan  5 14:20:16 2022] uart-pl011 3f201000.serial: no DMA platform data
    [Wed Jan  5 14:20:17 2022] Adding 102396k swap on /var/swap.  Priority:-2 extent        s:1 across:102396k FS
    [Wed Jan  5 14:20:17 2022] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save e        nabled
    [Wed Jan  5 14:20:22 2022] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes re        ady
    [Wed Jan  5 14:20:23 2022] Bluetooth: Core ver 2.22
    [Wed Jan  5 14:20:23 2022] NET: Registered protocol family 31
    [Wed Jan  5 14:20:23 2022] Bluetooth: HCI device and connection manager initiali        zed
    [Wed Jan  5 14:20:23 2022] Bluetooth: HCI socket layer initialized
    [Wed Jan  5 14:20:23 2022] Bluetooth: L2CAP socket layer initialized
    [Wed Jan  5 14:20:23 2022] Bluetooth: SCO socket layer initialized
    [Wed Jan  5 14:20:23 2022] Bluetooth: HCI UART driver ver 2.3
    [Wed Jan  5 14:20:23 2022] Bluetooth: HCI UART protocol H4 registered
    [Wed Jan  5 14:20:23 2022] Bluetooth: HCI UART protocol Three-wire (H5) register        ed
    [Wed Jan  5 14:20:23 2022] Bluetooth: HCI UART protocol Broadcom registered
    [Wed Jan  5 14:20:24 2022] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [Wed Jan  5 14:20:24 2022] Bluetooth: BNEP filters: protocol multicast
    [Wed Jan  5 14:20:24 2022] Bluetooth: BNEP socket layer initialized
    [Wed Jan  5 14:21:07 2022] FS-Cache: Netfs 'cifs' registered for caching
    [Wed Jan  5 14:21:07 2022] Key type cifs.spnego registered
    [Wed Jan  5 14:21:07 2022] Key type cifs.idmap registered
    [Wed Jan  5 14:21:07 2022] CIFS: Attempting to mount //192.168.0.54/IoBroker/Ent        wicklungssystem
    [Wed Jan  5 14:21:07 2022] CIFS: VFS: Use of the less secure dialect vers=1.0 is        not recommended unless required for access to very old servers
    das ist von "dmesg -T"
    JürgenIO
    @jürgenio
    -- Logs begin at Wed 2022-01-05 14:05:21 CET, end at Wed 2022-01-05 18:51:12 CET. --
    Jan 05 14:05:21 ioBroker kernel: Booting Linux on physical CPU 0x0
    Jan 05 14:05:21 ioBroker kernel: Linux version 5.10.17-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 2
    Jan 05 14:05:21 ioBroker kernel: CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
    Jan 05 14:05:21 ioBroker kernel: CPU: div instructions available: patching division code
    Jan 05 14:05:21 ioBroker kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    Jan 05 14:05:21 ioBroker kernel: OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
    Jan 05 14:05:21 ioBroker kernel: Memory policy: Data cache writealloc
    Jan 05 14:05:21 ioBroker kernel: Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
    Jan 05 14:05:21 ioBroker kernel: OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    Jan 05 14:05:21 ioBroker kernel: Zone ranges:
    Jan 05 14:05:21 ioBroker kernel:   DMA      [mem 0x0000000000000000-0x000000003b3fffff]
    Jan 05 14:05:21 ioBroker kernel:   Normal   empty
    Jan 05 14:05:21 ioBroker kernel: Movable zone start for each node
    Jan 05 14:05:21 ioBroker kernel: Early memory node ranges
    Jan 05 14:05:21 ioBroker kernel:   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
    Jan 05 14:05:21 ioBroker kernel: Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
    Jan 05 14:05:21 ioBroker kernel: On node 0 totalpages: 242688
    Jan 05 14:05:21 ioBroker kernel:   DMA zone: 2133 pages used for memmap
    Jan 05 14:05:21 ioBroker kernel:   DMA zone: 0 pages reserved
    Jan 05 14:05:21 ioBroker kernel:   DMA zone: 242688 pages, LIFO batch:63
    Jan 05 14:05:21 ioBroker kernel: percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
    Jan 05 14:05:21 ioBroker kernel: pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
    Jan 05 14:05:21 ioBroker kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    Jan 05 14:05:21 ioBroker kernel: Built 1 zonelists, mobility grouping on.  Total pages: 240555
    Jan 05 14:05:21 ioBroker kernel: Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2
    Jan 05 14:05:21 ioBroker kernel: Kernel parameter elevator= does not have any effect anymore.
                                     Please use sysfs to set IO scheduler for individual devices.
    Jan 05 14:05:21 ioBroker kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    Jan 05 14:05:21 ioBroker kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    Jan 05 14:05:21 ioBroker kernel: mem auto-init: stack:off, heap alloc:off, heap free:off
    Jan 05 14:05:21 ioBroker kernel: Memory: 879832K/970752K available (9216K kernel code, 1311K rwdata, 2940K rodata, 1024K init, 860K bss, 25384K reserved, 65536K cma-reserved)
    Jan 05 14:05:21 ioBroker kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    Jan 05 14:05:21 ioBroker kernel: ftrace: allocating 31910 entries in 63 pages
    Jan 05 14:05:21 ioBroker kernel: ftrace: allocated 63 pages with 6 groups
    Jan 05 14:05:21 ioBroker kernel: rcu: Hierarchical RCU implementation.
    Jan 05 14:05:21 ioBroker kernel:         Rude variant of Tasks RCU enabled.
    Jan 05 14:05:21 ioBroker kernel:         Tracing variant of Tasks RCU enabled.
    Jan 05 14:05:21 ioBroker kernel: rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    Jan 05 14:05:21 ioBroker kernel: NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    Jan 05 14:05:21 ioBroker kernel: random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=0
    Jan 05 14:05:21 ioBroker kernel: arch_timer: cp15 timer(s) running at 19.20MHz (phys).
    Jan 05 14:05:21 ioBroker kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
    Jan 05 14:05:21 ioBroker kernel: sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
    Jan 05 14:05:21 ioBroker kernel: Switching to timer-based delay loop, resolution 52ns
    Jan 05 14:05:21 ioBroker kernel: Console: colour dummy device 80x30
    Jan 05 14:05:21 ioBroker kernel: printk: console [tty1] enabled
    Jan 05 14:05:21 ioBroker kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
    Jan 05 14:05:21 ioBroker kernel: pid_max: default: 32768 minimum: 301
    Jan 05 14:05:21 ioBroker kernel: LSM: Security Framework initializing
    Jan 05 14:05:21 ioBroker kernel: Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    und das von "journalctl -b"
    • J JürgenIO
      @jürgenio
      @jürgenio
      Welches Terminal-Programm zaubert eigentlich immer diese zerhackten logfiles? puTTY?
      J HomoranH 2 Antworten Letzte Antwort
        @jürgenio
        JürgenIO
        ja.
        sorry - ich weiß es nicht besser... :)
          @jürgenio
          @jürgenio
          Ja, wenn man das Fenster nicht breit genug hat
            @jürgenio
            Dann muss ich meine 'Warum-ich-puTTY-nicht-nutze'-Liste noch um einen Punkt erweitern.
              ich fürchte das gilt auch für andere Terminals.
              Wenn dort ein Zeilenumbruch erzeugt wird scheint das hier im Forum mit vielen Tabs oder Leerzeichen in einer Zeile aneinandergehängt zu werden
              J Thomas BraunT 2 Antworten Letzte Antwort
                JürgenIO
                seht ihr da ein "Hasenfuß"?
                • J JürgenIO
                  @jürgenio sagte in Raspi 3 Model B mit Samsung SSD 500GB:
                  was meinst du damit?
                  Sieh dir dein log mal an:
                  https://forum.iobroker.net/topic/51046/raspi-3-model-b-mit-samsung-ssd-500gb/23?_=1641405869024
                  Die Zeilen sind total auseinandergerissen
                    PowerShell macht das nicht. Ganz stumpf per C&P hier reingekloppt:
                    echad@chet:~ $ dmesg -T
                    [Fri Dec 31 18:12:18 2021] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
                    [Fri Dec 31 18:12:18 2021] Linux version 5.10.63-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1488 SMP PREEMPT Thu Nov 18 16:16:16 GMT 2021
                    [Fri Dec 31 18:12:18 2021] random: fast init done
                      dmesg -T
                      waren da Zeilenumbrüche in der Shell?
                      Hier mit schmalem puTTy Fenster und Zeilenumbrüchen
                      Mal sehen:
                      pi@raspberrypi:~ $ dmesg -T
                      [Fr Nov  5 15:48:53 2021] Booting Linux on physical CPU 0x0
                      [Fr Nov  5 15:48:53 2021] Linux version 5.10.63-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1459 SMP Wed Oct 6 16:41:57 BST 2021
                      [Fr Nov  5 15:48:53 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
                      EDIT:
                      auch alles gut.
                      Dann weiß ich nicht mehr wo ich das Problem mit den langen Leerzeichen/Tabs hatte :-(
                      muss dann wohl ein Windoof Tool gewesen sein
                      (aber wieso habe ich da Ubuntu/Linaro auf einem Pi4?????)
                      EDIT2:
                      geht doch :-)
                      Das Gegenteil von gut ist gut gemeint!
                      Wenn man nachträglich das Fenster größer zieht und dann kopiert...
                      [Fr Nov  5 15:48:53 2021] Linux version 5.10.63-v7l+ (dom@buildbot) (arm-linux-g        nueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ub        untu) 2.34) #1459 SMP Wed Oct 6 16:41:57 BST 2021
                      [Fr Nov  5 15:48:53 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr        =30c5383d
                        dmesg -T
                        Mal sehen:
                        EDIT:
                        auch alles gut.
                        EDIT2:
                        geht doch :-)
                        @homoran sagte in Raspi 3 Model B mit Samsung SSD 500GB:
                        Logisch. Sonst wäre das ja keine Aussage. Ist aber auch OT.
                        Nachträglich aufgezogen aber auch kein Ding:
                          JürgenIO
                          und jetzt?
                          • J JürgenIO
                            @jürgenio
                            Da ich das so nicht im Einsatz habe:
                            Du bootest von der SD-Karte und die Partition auf der SSD wird dann (über die fstab?) beim Boot-Vorgang eingehängt?
                              @jürgenio
                              JürgenIO
                              Nein. Keine SD Karte. Komplett von SSD
                              • J JürgenIO
                                JürgenIO
                                @jürgenio
                                nur so eine Idee:
                                Wenn ich eine minimal Konfiguration auf SD Karte mache. Ohne ioBroker. Dann alles auf die SSD.
                                Sollte das laufen, mit ioBroker weiter machen????
                                • J JürgenIO
                                  @jürgenio
                                  nur so eine Idee:
                                  @jürgenio
                                  Kann ich dir nicht sagen.
                                    @jürgenio
                                    JürgenIO
                                    vielleicht hat ja noch jemand eine Idee, was ich probieren kann.
                                    Wenn nicht, würde ich das mal testen...
                                    Grüße und Danke für eure Hilfe
                                    • J JürgenIO
                                      ich bin mir nicht sicher, aber ich denke @Thomas-Braun wollte dir sagen, dass dmesg diese Konfiguration ausspuckt.
                                      Kann mich aber auch irren
                                        Ich bin nicht sicher. Aber ich meine da wären Hinweise auf eine SD-Karte drin, stimmt.
                                        @JürgenIO
                                        cat /etc/fstab
                                        blkid
                                        sagt?
                                          @JürgenIO
                                          cat /etc/fstab
                                          blkid
                                          sagt?
                                          JürgenIO
                                          cat /etc/fstab
                                          proc            /proc           proc    defaults          0       0
                                          PARTUUID=4c6fdb90-01  /boot           vfat    defaults          0       2
                                          PARTUUID=4c6fdb90-02  /               ext4    defaults,noatime  0       1
                                          # a swapfile is not a swap partition, no line here
                                          #   use  dphys-swapfile swap[on|off]  for that
