  4. Zigbee Probleme
Zigbee Probleme
19 Beiträge 4 Kommentatoren 1.6k Aufrufe 4 Beobachtet
  • A Aladin0815
    @aladin0815
    pi@raspberrypi:~ $ iobroker list instances
      system.adapter.devices.0                : devices               : raspberrypi                              - disabled
    + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      system.adapter.klf200.0                 : klf200                : raspberrypi                              -  enabled
      system.adapter.lcn.0                    : lcn                   : raspberrypi                              - disabled, port: 4114
      system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
    + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
    + system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.tr-064.2                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.tr-064.3                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.yahka.1                  : yahka                 : raspberrypi                              -  enabled
    + instance is alive
    pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
    ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
    pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    /usr/bin/nodejs
    /usr/local/bin/node
    /usr/local/bin/npm
    v14.18.2
    v16.13.0
    8.1.0
    OK:1 http://phoscon.de/apt/deconz buster InRelease
    OK:2 https://repos.influxdata.com/debian stretch InRelease
    Holen:3 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
    OK:4 https://packages.grafana.com/enterprise/deb stable InRelease
    Holen:5 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
    OK:6 https://deb.nodesource.com/node_14.x buster InRelease
    OK:7 https://packages.grafana.com/oss/deb stable InRelease
    E: Für das Depot »http://archive.raspberrypi.org/debian buster InRelease« wurde der »Suite«-Wert von »testing« in »oldstable« geändert.
    N: Sie müssen dies explizit bestätigen, bevor Aktualisierungen von diesem Depot angewendet werden können. Lesen Sie die apt-secure(8)-Handbuchseite, wenn Sie weitere Informationen benötigen.
    Möchten Sie diese Änderungen übernehmen und mit der Aktualisierung von diesem Depot fortfahren? [j/N] j
    Holen:8 http://archive.raspberrypi.org/debian buster/main armhf Packages [393 kB]
    E: Für das Depot »http://raspbian.raspberrypi.org/raspbian buster InRelease« wurde der »Suite«-Wert von »stable« in »oldstable« geändert.
    Holen:9 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
    Holen:10 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58,8 kB]
    Holen:11 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages [104 kB]
    Es wurden 13,6 MB in 29 s geholt (474 kB/s).
    Aktualisierung für 134 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
    W: Ziel Packages (main/binary-armhf/Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:3
    W: Ziel Packages (main/binary-all/Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:3
    W: Ziel Translations (main/i18n/Translation-de_DE) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:3
    W: Ziel Translations (main/i18n/Translation-de) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:3
    W: Ziel Translations (main/i18n/Translation-en) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:3
    W: Ziel Packages (main/binary-armhf/Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:4
    W: Ziel Packages (main/binary-all/Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:4
    W: Ziel Translations (main/i18n/Translation-de_DE) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:4
    W: Ziel Translations (main/i18n/Translation-de) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:4
    W: Ziel Translations (main/i18n/Translation-en) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:4
    W: Ziel Packages (main/binary-armhf/Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:5
    W: Ziel Packages (main/binary-all/Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:5
    W: Ziel Translations (main/i18n/Translation-de_DE) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:5
    W: Ziel Translations (main/i18n/Translation-de) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:5
    W: Ziel Translations (main/i18n/Translation-en) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:5
    OK:1 https://repos.influxdata.com/debian stretch InRelease
    OK:2 http://archive.raspberrypi.org/debian buster InRelease
    OK:3 https://deb.nodesource.com/node_14.x buster InRelease
    OK:5 https://packages.grafana.com/oss/deb stable InRelease
    OK:6 http://phoscon.de/apt/deconz buster InRelease
    OK:7 http://raspbian.raspberrypi.org/raspbian buster InRelease
    nodejs:
      Installiert:           14.18.2-deb-1nodesource1
      Installationskandidat: 14.18.2-deb-1nodesource1
      Versionstabelle:
     *** 14.18.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u1 500
    @aladin0815 sagte in Zigbee Probleme:
    Und weiter gehts. Falsches Release. Ich gehe davon aus, dass du buster fährst. Richte die influxdb.list richtig ein.
    • A Aladin0815
      @aladin0815
      + instance is alive
      /usr/bin/nodejs
      /usr/local/bin/node
      /usr/local/bin/npm
      v14.18.2
      v16.13.0
      8.1.0
      nodejs:
        Versionstabelle:
      Hier würde ich die OSS-Quelle nehmen, nicht die Enterprise-Version.
        Gleich mehrere Baustellen.
        nodejs ist krumm installiert. Schau in meiner Signatur wie es richtig geht und wie man das repariert. Installier node14 richtig, NICHT 16.
        Dann ist die grafana.list falsch aufgebaut, da sind Doubletten drin.
        Wenn das alles richtig gemacht wurde:
        Halte dein System auf Stand! Da ist offenbar ewig kein (oder sogar noch nie) Update mehr gefahren worden.
        Aladin0815
        Also habe nun die nodejs Version 14.8.2 hinbekommen. Aber das löst mein Problem mit Zigbee und der Fehlermeldung nicht.
        Mit dem rest bin ich überfordert was du da allles noch willst, ich bin noch Anfänger.
        • A Aladin0815
          @aladin0815
          Dann eins nach dem anderen...
          nodeJS ist sauber?
          which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
          zeigen.
          • A Aladin0815
            Also gestern hat sich mein IObroker zerschossen.
            Nun habe ich fast alles wieder hin bekommen bis auf Zigbee.
            Habe es mit dem Backup versucht und mit dem Hauseigenen Elzershark Skript, geht nicht.
            Nach dem deinstallieren des Adapter, komme ich nicht dazu ihn neu zu installieren, weil immer folgende Fehlermeldung kommt.
            Was will die Meldung mir sagen, bitte um Hilfe dabei.
            $ iobroker add zigbee --host raspberrypi
            /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:207 if (arr.rows[id].value.common.enabled && hostname === arr.rows[id].value.common.host) { ^TypeError: Cannot read properties of undefined (reading 'enabled') at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:207:55) at processImmediate (node:internal/timers:466:21)
            ERROR: Process exited with code 1
            Dankeschön!!!
            GlasfaserG Offline
            GlasfaserG Offline
            @Thomas-Braun
            Das ist 1:1 die gleiche Fehlermeldung wie hier
            https://forum.iobroker.net/topic/50786/gelöst-admin-5-2-3-update-error
            • GlasfaserG Glasfaser
              @Thomas-Braun
              @glasfaser
              Bei den ganzen andere Problemen hab ich mir das noch gar nicht angeschaut. Das muss erstmal auf stabile Füße.
                @aladin0815
                nodeJS ist sauber?
                zeigen.
                Aladin0815
                @thomas-braun sagte in Zigbee Probleme:
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v14.18.2
                v14.18.2
                6.14.15
                nodejs:
                  Versionstabelle:
                N: Datei »nodesource.list.save.1« in Verzeichnis »/etc/apt/sources.list.d/« wird ignoriert, da sie eine ungültige Dateinamen-Erweiterung hat.
                • A Aladin0815
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v14.18.2
                  v14.18.2
                  6.14.15
                  nodejs:
                    Versionstabelle:
                  @aladin0815
                  Jetzt haste den nächsten Bock geschossen...
                  sudo rm /etc/apt/sources.list.d/nodesource.list.save.1
                  Dann grafana:
                  In der /etc/apt/sources.list.d/grafana.list sollte nur diese eine Zeile drin stehen:
                  deb https://packages.grafana.com/oss/deb stable main
                  Änder das ab.
                    @aladin0815
                    Dann grafana:
                    Änder das ab.
                    Aladin0815
                    Also das obere habe ich gemacht aber das untere bekomme ich nicht hin. Dazu fehlt mir das wissen und die Erfahrung.
                    • A Aladin0815
                      @aladin0815
                      sudo nano /etc/apt/sources.list.d/grafana.list
                      Änderungen machen, mit Strg-x abspeichern, dabei die grafana.list nach der Rückfrage überschreiben.
