  4. Zigbee Probleme
Zigbee Probleme
19 Beiträge 4 Kommentatoren 1.6k Aufrufe 4 Beobachtet
  • A Aladin0815
    iobroker update -i
    Used repository: stable
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.2.3    , installed 5.2.3
    Adapter    "alexa2"        : 3.11.2   , installed 3.12.0
    Adapter    "backitup"      : 2.2.2    , installed 2.2.2
    Adapter    "devices"       : 1.0.9    , installed 1.0.9
    Adapter    "discovery"     : 2.7.3    , installed 2.7.5
    Adapter    "echarts"       : 1.0.3    , installed 1.0.3
    Adapter    "fritzdect"     : 2.1.15   , installed 2.2.0
    Adapter    "influxdb"      : 1.9.5    , installed 1.9.5
    Adapter    "info"          : 1.9.8    , installed 1.9.16
    Adapter    "iot"           : 1.8.24   , installed 1.8.25
    Adapter    "javascript"    : 5.2.13   , installed 5.2.18
    Controller "js-controller" : 3.3.22   , installed 3.3.22
    Adapter    "klf200"        : 1.0.1    , installed 1.0.1
    Adapter    "lcn"           : 1.0.4    , installed 1.0.4
    Adapter    "mobile"        : 1.0.1    , installed 1.0.1
    Adapter    "modbus"        : 3.4.14   , installed 3.4.17
    Adapter    "onvif"         : 0.4.4    , installed 0.4.4
    Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.2
    Adapter    "socketio"      : 3.1.4    , installed 3.1.5
    Adapter    "tr-064"        : 4.2.14   , installed 4.2.15
    Adapter    "web"           : 3.4.9    , installed 3.4.16
    Adapter    "yahka"         : 0.13.1   , installed 0.13.1
    Aladin0815
    @aladin0815
    iobroker list adapters
    system.adapter.admin                   : admin          - v5.2.3
    system.adapter.alexa2                  : alexa2         - v3.12.0
    system.adapter.backitup                : backitup       - v2.2.2
    system.adapter.devices                 : devices        - v1.0.9
    system.adapter.discovery               : discovery      - v2.7.5
    system.adapter.echarts                 : echarts        - v1.0.3
    system.adapter.fritzdect               : fritzdect      - v2.2.0
    system.adapter.influxdb                : influxdb       - v1.9.5
    system.adapter.info                    : info           - v1.9.16
    system.adapter.iot                     : iot            - v1.8.25
    system.adapter.javascript              : javascript     - v5.2.18
    system.adapter.klf200                  : klf200         - v1.0.1
    system.adapter.lcn                     : lcn            - v1.0.4
    system.adapter.mobile                  : mobile         - v1.0.1
    system.adapter.modbus                  : modbus         - v3.4.17
    system.adapter.onvif                   : onvif          - v0.4.4
    system.adapter.rpi2                    : rpi2           - v1.3.1
    system.adapter.tr-064                  : tr-064         - v4.2.15
    system.adapter.web                     : web            - v3.4.16
    system.adapter.yahka                   : yahka          - v0.13.1
    system.adapter.zigbee                  : zigbee         - v1.6.6
    • A Aladin0815
      @aladin0815
      Aladin0815
      @aladin0815
      pi@raspberrypi:~ $ iobroker list instances
        system.adapter.devices.0                : devices               : raspberrypi                              - disabled
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        system.adapter.klf200.0                 : klf200                : raspberrypi                              -  enabled
        system.adapter.lcn.0                    : lcn                   : raspberrypi                              - disabled, port: 4114
        system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
      + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.tr-064.2                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.tr-064.3                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.yahka.1                  : yahka                 : raspberrypi                              -  enabled
      + instance is alive
      pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
      ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
      pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
      /usr/bin/nodejs
      /usr/local/bin/node
      /usr/local/bin/npm
      v14.18.2
      v16.13.0
      8.1.0
      OK:1 http://phoscon.de/apt/deconz buster InRelease
      OK:2 https://repos.influxdata.com/debian stretch InRelease
      Holen:3 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
      OK:4 https://packages.grafana.com/enterprise/deb stable InRelease
      Holen:5 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
      OK:6 https://deb.nodesource.com/node_14.x buster InRelease
      OK:7 https://packages.grafana.com/oss/deb stable InRelease
      E: Für das Depot »http://archive.raspberrypi.org/debian buster InRelease« wurde der »Suite«-Wert von »testing« in »oldstable« geändert.
      N: Sie müssen dies explizit bestätigen, bevor Aktualisierungen von diesem Depot angewendet werden können. Lesen Sie die apt-secure(8)-Handbuchseite, wenn Sie weitere Informationen benötigen.
      Möchten Sie diese Änderungen übernehmen und mit der Aktualisierung von diesem Depot fortfahren? [j/N] j
      Holen:8 http://archive.raspberrypi.org/debian buster/main armhf Packages [393 kB]
      E: Für das Depot »http://raspbian.raspberrypi.org/raspbian buster InRelease« wurde der »Suite«-Wert von »stable« in »oldstable« geändert.
      Holen:9 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
      Holen:10 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58,8 kB]
      Holen:11 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages [104 kB]
      Es wurden 13,6 MB in 29 s geholt (474 kB/s).
      Aktualisierung für 134 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
      W: Ziel Packages (main/binary-armhf/Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:3
      W: Ziel Packages (main/binary-all/Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:3
      W: Ziel Translations (main/i18n/Translation-de_DE) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:3
      W: Ziel Translations (main/i18n/Translation-de) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:3
      W: Ziel Translations (main/i18n/Translation-en) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:3
      W: Ziel Packages (main/binary-armhf/Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:4
      W: Ziel Packages (main/binary-all/Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:4
      W: Ziel Translations (main/i18n/Translation-de_DE) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:4
      W: Ziel Translations (main/i18n/Translation-de) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:4
      W: Ziel Translations (main/i18n/Translation-en) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:4
      W: Ziel Packages (main/binary-armhf/Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:5
      W: Ziel Packages (main/binary-all/Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:5
      W: Ziel Translations (main/i18n/Translation-de_DE) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:5
      W: Ziel Translations (main/i18n/Translation-de) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:5
      W: Ziel Translations (main/i18n/Translation-en) ist mehrfach konfiguriert in /etc/apt/sources.list.d/grafana.list:2 und /etc/apt/sources.list.d/grafana.list:5
      OK:1 https://repos.influxdata.com/debian stretch InRelease
      OK:2 http://archive.raspberrypi.org/debian buster InRelease
      OK:3 https://deb.nodesource.com/node_14.x buster InRelease
      OK:5 https://packages.grafana.com/oss/deb stable InRelease
      OK:6 http://phoscon.de/apt/deconz buster InRelease
      OK:7 http://raspbian.raspberrypi.org/raspbian buster InRelease
      nodejs:
        Installiert:           14.18.2-deb-1nodesource1
        Installationskandidat: 14.18.2-deb-1nodesource1
        Versionstabelle:
       *** 14.18.2-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
           10.24.0~dfsg-1~deb10u1 500
      Thomas BraunT 3 Antworten Letzte Antwort
      • A Aladin0815
        @aladin0815
        + instance is alive
        /usr/bin/nodejs
        /usr/local/bin/node
        /usr/local/bin/npm
        v14.18.2
        v16.13.0
        8.1.0
        nodejs:
          Versionstabelle:
        @aladin0815 sagte in Zigbee Probleme:
        Gleich mehrere Baustellen.
        nodejs ist krumm installiert. Schau in meiner Signatur wie es richtig geht und wie man das repariert. Installier node14 richtig, NICHT 16.
        Dann ist die grafana.list falsch aufgebaut, da sind Doubletten drin.
        Wenn das alles richtig gemacht wurde:
        Halte dein System auf Stand! Da ist offenbar ewig kein (oder sogar noch nie) Update mehr gefahren worden.
        • A Aladin0815
          @aladin0815
          + instance is alive
          /usr/bin/nodejs
          /usr/local/bin/node
          /usr/local/bin/npm
          v14.18.2
          v16.13.0
          8.1.0
          nodejs:
            Versionstabelle:
          Und weiter gehts. Falsches Release. Ich gehe davon aus, dass du buster fährst. Richte die influxdb.list richtig ein.
          • A Aladin0815
            @aladin0815
            + instance is alive
            /usr/bin/nodejs
            /usr/local/bin/node
            /usr/local/bin/npm
            v14.18.2
            v16.13.0
            8.1.0
            nodejs:
              Versionstabelle:
            Hier würde ich die OSS-Quelle nehmen, nicht die Enterprise-Version.
              Aladin0815
              Also habe nun die nodejs Version 14.8.2 hinbekommen. Aber das löst mein Problem mit Zigbee und der Fehlermeldung nicht.
              Mit dem rest bin ich überfordert was du da allles noch willst, ich bin noch Anfänger.
              • A Aladin0815
                @aladin0815
                Dann eins nach dem anderen...
                nodeJS ist sauber?
                which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                zeigen.
                • A Aladin0815
                  Also gestern hat sich mein IObroker zerschossen.
                  Nun habe ich fast alles wieder hin bekommen bis auf Zigbee.
                  Habe es mit dem Backup versucht und mit dem Hauseigenen Elzershark Skript, geht nicht.
                  Nach dem deinstallieren des Adapter, komme ich nicht dazu ihn neu zu installieren, weil immer folgende Fehlermeldung kommt.
                  Was will die Meldung mir sagen, bitte um Hilfe dabei.
                  $ iobroker add zigbee --host raspberrypi
                  /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:207 if (arr.rows[id].value.common.enabled && hostname === arr.rows[id].value.common.host) { ^TypeError: Cannot read properties of undefined (reading 'enabled') at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:207:55) at processImmediate (node:internal/timers:466:21)
                  ERROR: Process exited with code 1
                  Dankeschön!!!
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @Thomas-Braun
                  Das ist 1:1 die gleiche Fehlermeldung wie hier
                  https://forum.iobroker.net/topic/50786/gelöst-admin-5-2-3-update-error
                  • GlasfaserG Glasfaser
                    @Thomas-Braun
                    @glasfaser
                    Bei den ganzen andere Problemen hab ich mir das noch gar nicht angeschaut. Das muss erstmal auf stabile Füße.
                      @aladin0815
                      nodeJS ist sauber?
                      zeigen.
                      Aladin0815
                      @thomas-braun sagte in Zigbee Probleme:
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v14.18.2
                      v14.18.2
                      6.14.15
                      nodejs:
                        Versionstabelle:
                      N: Datei »nodesource.list.save.1« in Verzeichnis »/etc/apt/sources.list.d/« wird ignoriert, da sie eine ungültige Dateinamen-Erweiterung hat.
                      • A Aladin0815
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v14.18.2
                        v14.18.2
                        6.14.15
                        nodejs:
                          Versionstabelle:
                        @aladin0815
                        Jetzt haste den nächsten Bock geschossen...
                        sudo rm /etc/apt/sources.list.d/nodesource.list.save.1
                        Dann grafana:
                        In der /etc/apt/sources.list.d/grafana.list sollte nur diese eine Zeile drin stehen:
                        deb https://packages.grafana.com/oss/deb stable main
                        Änder das ab.
                          @aladin0815
                          Dann grafana:
                          Änder das ab.
                          Aladin0815
                          Also das obere habe ich gemacht aber das untere bekomme ich nicht hin. Dazu fehlt mir das wissen und die Erfahrung.
                          • A Aladin0815
                            @aladin0815
                            sudo nano /etc/apt/sources.list.d/grafana.list
                            Änderungen machen, mit Strg-x abspeichern, dabei die grafana.list nach der Rückfrage überschreiben.
