  4. Zigbee iobroker Error while opening serialport
    6.6k
231 Beiträge 28 Kommentatoren 64.1k Aufrufe 24 Beobachtet
  • OmnedonO Omnedon
    ich bekomme leider meinen Zigbee Adapter nicht zum Laufen:
    zigbee.0 PID Zeit error Nachricht
    zigbee.0 944	2021-12-20 10:20:46.402	error	Error herdsman start
    zigbee.0 944	2021-12-20 10:20:46.401	error	Failed to start Zigbee
    zigbee.0 944	2021-12-20 10:20:46.401	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0 944	2021-12-20 10:20:36.208	error	Error herdsman start
    zigbee.0 944	2021-12-20 10:20:36.204	error	Failed to start Zigbee
    zigbee.0 944	2021-12-20 10:20:36.202	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0 944	2021-12-20 10:20:36.199	error	Re-commissioning your network will require re-pairing of all devices!
    zigbee.0 944	2021-12-20 10:20:36.197	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0 944	2021-12-20 10:20:36.196	error	Please update configuration to prevent further issues.
    zigbee.0 944	2021-12-20 10:20:36.195	error	- Channel List: configured=11, adapter=14
    zigbee.0 944	2021-12-20 10:20:36.193	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0 944	2021-12-20 10:20:36.192	error	- Extended PAN ID: configured=00124b00229819e0, adapter=ddddddddddddddda
    zigbee.0 944	2021-12-20 10:20:36.190	error	- PAN ID: configured=6754, adapter=6755
    zigbee.0 944	2021-12-20 10:20:36.189	error	Configuration is not consistent with adapter state/backup!
    zigbee.0 715	2021-12-20 10:20:17.803	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
    Den Port habe ich über
    ls -l /dev/serial/by-id
    insgesamt 0
    lrwxrwxrwx 1 root root 13 Dez 19 15:25 usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB0
    auf ttyUSB0 eingestellt:
    Vielen Dank für die Hilfe!
    Viele Grüße
    @omnedon sagte in Zigbee iobroker Error while opening serialport:
    Du sollst aber auf
    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    umstellen.
    Und die einzelnen Einstellungen sollten übereinstimmen:
    OmnedonO AsgothianA 2 Antworten Letzte Antwort
      Du sollst aber auf
      umstellen.
      OmnedonO Online
      OmnedonO Online
      Omnedon
      danke für die schnelle Antwort!
      Die "configured" Werte kann ich in der Instanz ändern und wo kann ich die "adapter"-Werte anpassen?
        Du sollst aber auf
        umstellen.
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @thomas-braun sagte in Zigbee iobroker Error while opening serialport:
        Du sollst aber auf
        umstellen.
        Ist irrelevant. Der Fehler hat nichts mit dem Port zu tun.
        @Omnedon
        Das von Dir gepostet Log beinhaltet:
        • den Grund warum es nicht läuft:
        • was genau nicht übereinstimmt:
        • Was zu tun ist um den adapter trotzdem zu starten (wenn die Konfigurationsanpassung absichtlich ist)
        • Was passiert wenn Du das tust:
        Du hast also 2 Möglichkeiten:
        • Konfiguration so einstellen wie es im backup steht
        • backup löschen, neu starten, alles neu pairen.
        A.
        • OmnedonO Omnedon
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          Nirgends. Du kannst entweder das Backup löschen um alles neu aufzubauen oder die Konfigurationswerte anpassen.
          A.
          • AsgothianA Asgothian
            Du sollst aber auf
            umstellen.
            @Omnedon
            A.
            @asgothian sagte in Zigbee iobroker Error while opening serialport:
            Stimmt, ich würde aber trotzdem den 'besseren' link verwenden.
            OmnedonO 1 Antwort Letzte Antwort
              OmnedonO Online
              OmnedonO Online
              Omnedon
              @thomas-braun @Asgothian
              Vielen Dank - es geht. 👍
              Ich muss mich an die eigene Nase fassen: 👃
              Wer nicht lesen kann .... 👓
              Nochmal herzlichen Dank!
              • C Offline
                calli236
                schrieb am zuletzt editiert von calli236
                Hallo ich habe ein Problem mit meinem Zigbee Netzwerk und zwar ist im iobroker alles grün in den instancen aber wenn ich ein gerät hinzufügen möchte kommt das
                ***Error: Failed to open the network: Error: SREQ '--> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":96,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[25,45,2,11,254,0]}}' failed with status '(0x10: MEM_ERROR)' (expected '(0x00: SUCCESS)')
                    at Object.func (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:322:27)
                    at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32). undefined
                Error: Failed to open the network: Error: Cannot execute command, in Inter-PAN mode
                    at ZStackAdapter.checkInterpanLock (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:1023:19)
                    at Object.func (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:197:18)
                    at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:42)
                    at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:22). undefined
                Pairing started***
                • C calli236
                  Pairing started***
                  @calli236 sagte in Zigbee iobroker Error while opening serialport:
                  Hört sich nach Firmware an. Was daran geändert?
                  C 1 Antwort Letzte Antwort
                    calli236
                    @thomas-braun said in Zigbee iobroker Error while opening serialport:
                    Hatte gestern das erstmal das Problem das er nicht mehr ging und habe darauf hin alles geupdatet
                    • C calli236
                      @calli236
                      Ich vermute, da ist beim flash was schief gelaufen. Kein Verify gemacht oder sowas.
                      C GlasfaserG 2 Antworten Letzte Antwort
                        @calli236
                        calli236
                        @thomas-braun ich habe so ein tool von Elzershark benutzt dafür
                          @calli236
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Ja ... bitte nicht aufregen
                          tool von Elzershark
                          • C calli236
                            Tja, herzlichen Glückwunsch...
                            Die 'superdollen Mega-HaX0r-Tolls' von dem Kollegen kannste dir an den Hut binden. Das ist quasi durch die Bank Murks.
                            C 2 Antworten Letzte Antwort
                              calli236
                              @thomas-braun na toll
                                calli236
                                @thomas-braun was sollte ich jetzt am bestem machen
                                • C calli236
                                  @calli236
                                  Versuchen nochmal drüber zu flashen vielleicht.
                                  Aber dann nicht mit dem windigen Zeug von der Spatzenforelle.
                                    @calli236
                                    calli236
                                    @thomas-braun ok :D und wie flashe ich es dann ?
                                    • C calli236
                                      @calli236
                                      Keine Ahnung. Was haste denn da für Hardware?
                                      Den von mir verwendeten Zigbee-Stick flashe ich immer danach über die Kommandozeile:
                                      https://slae.sh/projects/cc2652/#flashing
                                        @calli236
                                        calli236
                                        @thomas-braun ich hab ein cc2531 aber der war schon mit firmeware hab ich bei amazon bestellt und der ging bis gestern tadellos
                                        • C calli236
                                          @calli236
                                          Und dann bist du mit welchem Tool Machwerk da auf deine Installation losgegangen?
