  4. Backup auf Synology Probleme
17 Beiträge 5 Kommentatoren 2.3k Aufrufe 4 Beobachtet
  • J jones88
    danke bad usage ist schon mal erledigt... funktionieren tut es trotzdem nicht :/
    Started iobroker ...
    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/Backupio/komplett/","dirMinimal":"/Backupio/komplett/","user":"backitup","pass":"****"}
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "mount -t cifs -o username=backitup,password=****,rw,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.178.2/Backupio/komplett/ /opt/iobroker/backups"
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [DEBUG] [mount] - cifs-mount command: "mount -t cifs -o username=backitup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.2/Backupio/komplett/ /opt/iobroker/backups"
    [ERROR] [mount] - [undefined Error: Command failed: mount -t cifs -o username=backitup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.2/Backupio/komplett/ /opt/iobroker/backups
    mount.cifs: permission denied: no match for /opt/iobroker/backups found in /etc/fstab
    [ERROR] [mount] - [IGNORED] Error: Command failed: mount -t cifs -o username=backitup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.2/Backupio/komplett/ /opt/iobroker/backups
    [DEBUG] [iobroker] start with {"type":"creator","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/Backupio/komplett/","dirMinimal":"/Backupio/komplett/","user":"backitup","pass":"****","context":{"fileNames":[],"errors":{"mount":"Error: Command failed: mount -t cifs -o username=backitup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.2/Backupio/komplett/ /opt/iobroker/backups\nmount.cifs: permission denied: no match for /opt/iobroker/backups found in /etc/fstab\n"},"done":[],"types":[]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [iobroker] - host.raspberrypi 4309 states saved
    [DEBUG] [iobroker] - host.raspberrypi 4909 objects saved
    Thomas BraunT Offline
    @jones88 sagte in Backup auf Synology Probleme:
    vers=1.0
    Vermutlich (und hoffentlich) zu niedrig. Versuch mal mit SMB3.
    Mountest du als user? Das geht so nicht. Entweder als root (per sudo) mounten ODER in der /etc/fstab ein Dateisystem einrichten. Das kann man dann auch so einrichten, dass ein user das dürfte.
      vers=1.0
      jones88
      also: ich habe auf SMB3 geändert und das Feld als root user mounten aktiviert. Windows Freigabe habe ich ebenfalls in der Synology aktiviert.
      nun habe ich folgenden code in backitup:
      [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/Backupio/komplett/","dirMinimal":"/Backupio/komplett/","user":"backitup","pass":"****"}
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=backitup,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.2/Backupio/komplett/ /opt/iobroker/backups"
      [DEBUG] [mount] - mount successfully completed
      [DEBUG] [mount] - done
      [DEBUG] [iobroker] start with {"type":"creator","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.2","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/Backupio/komplett/","dirMinimal":"/Backupio/komplett/","user":"backitup","pass":"****","context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      bedeutet das, dass das backup fertig gestellt wurde? Das Fenster bleibt nämlich geöffnet und der Ladebalken oben bewegt sich weiter... In der Synology sind auch noch keine Dateien erstellt worden.
      Liegt immer noch ein Fehler vor oder muss ich dem iobroker länger zeit geben?Bildschirmfoto 2021-12-23 um 22.21.41.png
      Thomas BraunT GlasfaserG 3 Antworten Letzte Antwort
      • J jones88
        @jones88
        Schaut aus als sei das durch.
          @jones88
          jones88
          komisch auf der nas wurden keine Dateien angelegt...
          • J jones88
            CinimodC Offline
            CinimodC Offline
            Cinimod
            @jones88
            es sollte eigentlich so enden:
            [DEBUG] [umount] - mount activ, umount is started ...
            [DEBUG] [umount] - umount successfully completed
            [DEBUG] [umount] - done
            [EXIT] 0
            Schau mal ob die dateien jetzt in /opt/iobroker/backups liegen ?
            • J jones88
              @jones88
              Hast du die Mitteilungen alle aktiv? Mach die mal aus.
              • CinimodC Cinimod
                @jones88
                [EXIT] 0
                jones88
                @cinimod
                nein dort ist das letzte am 06.12.2021 erstellt worden...Bildschirmfoto 2021-12-23 um 22.37.25.png
                  @jones88
                  jones88
                  kannst du das konkretisieren? welche Mitteilungen meinst du und wo mache ich die aus?
                  • J jones88
                    @jones88
                    In den Einstellungen.
                    Der mountpunkt sollte im übrigen leer sein, wenn dort das freigegebene Dateisystem eingehängt wird.
                    Und bitte keine Bilder von Text machen...
                    • J jones88
                      @cinimod
                      CinimodC Offline
                      CinimodC Offline
                      Cinimod
                      @jones88
                      Willst du mal smb2 probieren, das war bei mir das einzig funktionierenden
                      • CinimodC Cinimod
                        @jones88
                        jones88
                        @cinimod
                        habe ich versucht. kommt das gleiche dabei heraus wie bei smb 3....
                        • J jones88
                          GlasfaserG Offline
                          GlasfaserG Offline
                          ändere auf :
                          /Backupio/komplett
                          • J jones88
                            @cinimod
                            HomoranH Offline
                            HomoranH Offline
                            @jones88 Ich kann die Konfig von dir nicht mehr finden.
                            Kannst du sie nochmal posten?
                            und wie heisst die Freigabe genau?
