  4. Crash - no connection to states 0.0.0.0:6370[redis]
59 Beiträge 4 Kommentatoren 6.0k Aufrufe 3 Beobachtet
  • S Sirfauntleroy
    das Fenster bleibt jetzt so, bis alles wiederhergestellt ist?
    einfach mal so laufen lassen. ... kommen da zwischen drin neue Zeilen, dass man sieht, das was passiert?
    @sirfauntleroy
    Konsole auf, per
    iobroker logs --watch
    den Fortgang beobachten
      @sirfauntleroy
      Konsole auf, per
      Sirfauntleroy
      will nicht ungeduldig sein, aber ist es normal, dass der Start des Backup-Resores nicht im log steht?
      2021-12-20 21:04:34.397  - info: host.raspberrypi iobroker.js-controller version 3.3.21 js-controller starting
      2021-12-20 21:04:34.403  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-12-20 21:04:34.404  - info: host.raspberrypi hostname: raspberrypi, node: v14.18.2
      2021-12-20 21:04:34.404  - info: host.raspberrypi ip addresses: 192.168.10.11 fe80::1c60:4643:360d:88a7
      2021-12-20 21:04:34.601  - info: host.raspberrypi connected to Objects and States
      2021-12-20 21:04:34.667  - info: host.raspberrypi added notifications configuration of host
      2021-12-20 21:04:34.987  - info: host.raspberrypi 3 instances found
      2021-12-20 21:04:34.999  - info: host.raspberrypi starting 3 instances
      2021-12-20 21:04:35.052  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 7454
      2021-12-20 21:04:37.005  - info: admin.0 (7454) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v14.18.2, js-controller: 3.3.21
      2021-12-20 21:04:37.054  - info: admin.0 (7454) requesting all states
      2021-12-20 21:04:37.055  - info: admin.0 (7454) requesting all objects
      2021-12-20 21:04:37.135  - info: admin.0 (7454) received all objects
      2021-12-20 21:04:37.231  - info: admin.0 (7454) http server listening on port 8081
      2021-12-20 21:04:37.231  - info: admin.0 (7454) Use link "http://localhost:8081" to configure.
      2021-12-20 21:04:37.268  - info: admin.0 (7454) State value to set for "admin.0.info.lastUpdateCheck" has to be type "number" but received type "string"
      2021-12-20 21:04:37.274  - warn: admin.0 (7454) Repository cannot be read
      2021-12-20 21:04:39.056  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 7505
      2021-12-20 21:04:40.515  - info: discovery.0 (7505) starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.18.2, js-controller: 3.3.21
      2021-12-20 21:04:43.039  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7520
      2021-12-20 21:04:44.601  - info: backitup.0 (7520) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
      2021-12-20 21:04:44.662  - info: backitup.0 (7520) [iobroker] backup was activated at 02:40 every 1 day(s)
      2021-12-20 21:05:13.492  - info: host.raspberrypi Updating repository "default" under "http://download.iobroker.net/sources-dist.json"
      2021-12-20 21:07:29.728  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
      2021-12-20 21:07:29.743  - info: backitup.0 (7520) Got terminate signal TERMINATE_YOURSELF
      2021-12-20 21:07:29.744  - info: backitup.0 (7520) cleaned everything up...
      2021-12-20 21:07:29.745  - info: backitup.0 (7520) terminating
      2021-12-20 21:07:29.746  - info: backitup.0 (7520) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-12-20 21:07:29.752  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
      2021-12-20 21:07:30.293  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-12-20 21:07:32.829  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7933
      2021-12-20 21:07:34.369  - info: backitup.0 (7933) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
      2021-12-20 21:07:34.432  - info: backitup.0 (7933) [iobroker] backup was activated at 02:40 every 1 day(s)
      2021-12-20 21:08:09.386  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
      2021-12-20 21:08:09.398  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
      2021-12-20 21:08:09.398  - info: backitup.0 (7933) Got terminate signal TERMINATE_YOURSELF
      2021-12-20 21:08:09.401  - info: backitup.0 (7933) cleaned everything up...
      2021-12-20 21:08:09.402  - info: backitup.0 (7933) terminating
      2021-12-20 21:08:09.405  - info: backitup.0 (7933) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-12-20 21:08:09.993  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-12-20 21:08:12.439  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7984
      2021-12-20 21:08:14.006  - info: backitup.0 (7984) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
      2021-12-20 21:08:14.074  - info: backitup.0 (7984) [iobroker] backup was activated at 02:40 every 1 day(s)
      2021-12-20 21:09:05.300  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
      2021-12-20 21:09:05.316  - info: backitup.0 (7984) Got terminate signal TERMINATE_YOURSELF
      2021-12-20 21:09:05.320  - info: backitup.0 (7984) cleaned everything up...
      2021-12-20 21:09:05.322  - info: backitup.0 (7984) terminating
      2021-12-20 21:09:05.325  - info: backitup.0 (7984) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-12-20 21:09:05.358  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
      2021-12-20 21:09:05.861  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-12-20 21:09:08.399  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 8013
      2021-12-20 21:09:09.926  - info: backitup.0 (8013) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
      2021-12-20 21:09:09.989  - info: backitup.0 (8013) [iobroker] backup was activated at 02:40 every 1 day(s)
      • S Sirfauntleroy
        Sirfauntleroy
        Fand die datei nicht.. nochmal ausgewählt: und es tut sich was
        2021-12-20 21:18:40.643  - info: admin.0 (7454) terminating http server on port 8081
        2021-12-20 21:18:40.642  - info: host.raspberrypi received SIGTERM
        2021-12-20 21:18:40.653  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
        2021-12-20 21:18:40.654  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
        2021-12-20 21:18:40.654  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
        2021-12-20 21:18:40.671  - info: admin.0 (7454) Got terminate signal TERMINATE_YOURSELF
        2021-12-20 21:18:40.672  - info: discovery.0 (7505) Got terminate signal TERMINATE_YOURSELF
        2021-12-20 21:18:40.673  - info: backitup.0 (8013) Got terminate signal TERMINATE_YOURSELF
        2021-12-20 21:18:40.677  - info: discovery.0 (7505) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2021-12-20 21:18:40.677  - info: backitup.0 (8013) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2021-12-20 21:18:40.679  - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
        2021-12-20 21:18:40.683  - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
        2021-12-20 21:18:40.683  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
        2021-12-20 21:18:40.689  - info: admin.0 (7454) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2021-12-20 21:18:41.240  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2021-12-20 21:18:41.258  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2021-12-20 21:18:41.261  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2021-12-20 21:18:41.262  - info: host.raspberrypi All instances are stopped.
        2021-12-20 21:18:41.285  - info: host.raspberrypi terminated
        2021-12-20 21:18:40.641  - info: backitup.0 (8013) cleaned everything up...
        2021-12-20 21:19:43.964  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 21:19:43.970  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 21:19:43.971  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
        2021-12-20 21:19:43.972  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::1c60:4643:360d:88a7
        2021-12-20 21:19:45.163  - info: host.ioBroker connected to Objects and States
        2021-12-20 21:19:45.191  - info: host.ioBroker added notifications configuration of host
        2021-12-20 21:19:45.688  - info: host.ioBroker Delete host system.host.raspberrypi
        2021-12-20 21:19:45.836  - info: host.ioBroker 76 instances found
        2021-12-20 21:19:45.897  - warn: host.ioBroker does not start any instances on this host
        Thomas BraunT F 2 Antworten Letzte Antwort
        • S Sirfauntleroy
          @sirfauntleroy
          Du hast die Lokalisierung / lokale Zeitzone nicht angepasst .
          • S Sirfauntleroy
            F Online
            F Online
            fastfoot
            @sirfauntleroy da ist immer noch der hostname falschiob stop, iob host this, iob start. Gestern hiess es noch dass backitup das macht :-)
            S HomoranH 2 Antworten Letzte Antwort
            • F fastfoot
              Sirfauntleroy
              @fastfoot
              jetzt rattert im log so einiges durch..
              geduldig abwarten...
              • S Sirfauntleroy
                @fastfoot
                Sirfauntleroy
                Das Backup ist durchgelaufen.
                nun folgendes Problem ...
                Error: Cannot find module '../encodings'
                Require stack:
                - /opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js
                - /opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js
                - /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/read.js
                - /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/types/json.js
                - /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/index.js
                - /opt/iobroker/node_modules/iobroker.admin/node_modules/express/lib/express.js
                - /opt/iobroker/node_modules/iobroker.admin/node_modules/express/index.js
                - /opt/iobroker/node_modules/iobroker.admin/lib/web.js
                - /opt/iobroker/node_modules/iobroker.admin/main.js
                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                    at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                    at Module.require (internal/modules/cjs/loader.js:974:19)
                    at require (internal/modules/cjs/helpers.js:93:18)
                    at Object.getCodec (/opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js:65:27)
                    at Object.getDecoder (/opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js:127:23)
                    at getDecoder (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:45:18)
                    at readStream (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:180:15)
                    at getRawBody (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:108:12)
                    at read (/opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/read.js:77:3)
                • S Sirfauntleroy
                  Require stack:
                  @sirfauntleroy
                  nodeJS ist sauber, nehme ich an?
                    @sirfauntleroy
                    Sirfauntleroy
                    nach einem Reboot gehts es jetzt soweit..
                    eieiei..
                    Irgendwie wäre die Idee mit dem schnellen wiederherstellen per .iso ja doch verlockend gewesen...
                    Herzlichen Dank bisher an euch alle!!!!!!
                    • S Sirfauntleroy
                      eieiei..
                      Sirfauntleroy
                      Erstmal danke an alle, die am Backup-Adapter beteiligt sind. Ist ja grundsätzlich schon echt ne super Sache!!!!!!
                      Nachdem das System nun wieder weitgehend anständig läuft, hätte ich noch ein paar Fragen:
                      1. Kann ich nun, da das System läuft redis ohne Probleme abstellen? (Wird ja offensichtlich nicht benötigt und macht mehr Probleme als nutzen) und wenn ja, wie, ohne, dass ich wieder einen Crash verursache? :D
                      2. Da ich die komplette Anbindung an KNX über Nodered realisiere bin ich darauf besonders angewiesen.
                        Nach dem Einspielen des Backups waren die Zusatzbausteine wie KNX-Ultimate nicht wieder hergestellt (glaube auch gelesen zu haben, das dies normal ist). Nachdem ich diese installiert hatte, waren alle KNX-Nodes im ersten Flow ?! ohne jegliche Verbindung. Strange....
                        Gut, dass ich nach jedem größeren Programmierschritt separate Backups aller Flows mache.. so konnte ich diese wiederherstellen. Aber geht das nicht auch einfacher?
                      • F fastfoot
                        @fastfoot sagte in Crash - no connection to states 0.0.0.0:6370[redis]:
                        Dann sollte sich @simatec auch mal hier den Thread ansehen :-)
                        • S Sirfauntleroy
                          @sirfauntleroy sagte in Crash - no connection to states 0.0.0.0:6370[redis]:
                          ja. über iobroker setup custom
                          das kann man so wirklich nicht sagen.
