  4. Crash - no connection to states 0.0.0.0:6370[redis]
59 Beiträge 4 Kommentatoren 6.0k Aufrufe 3 Beobachtet
  • S Sirfauntleroy
    das Fenster bleibt jetzt so, bis alles wiederhergestellt ist?
    einfach mal so laufen lassen. ... kommen da zwischen drin neue Zeilen, dass man sieht, das was passiert?
    @sirfauntleroy sagte in Crash - no connection to states 0.0.0.0:6370[redis]:
    iobroker logs --watch zeigt dir die Aktivitäten
    • S Sirfauntleroy
      @sirfauntleroy
      Konsole auf, per
      den Fortgang beobachten
        @sirfauntleroy
        Konsole auf, per
        Sirfauntleroy
        will nicht ungeduldig sein, aber ist es normal, dass der Start des Backup-Resores nicht im log steht?
        2021-12-20 21:04:34.397  - info: host.raspberrypi iobroker.js-controller version 3.3.21 js-controller starting
        2021-12-20 21:04:34.403  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-12-20 21:04:34.404  - info: host.raspberrypi hostname: raspberrypi, node: v14.18.2
        2021-12-20 21:04:34.404  - info: host.raspberrypi ip addresses: 192.168.10.11 fe80::1c60:4643:360d:88a7
        2021-12-20 21:04:34.601  - info: host.raspberrypi connected to Objects and States
        2021-12-20 21:04:34.667  - info: host.raspberrypi added notifications configuration of host
        2021-12-20 21:04:34.987  - info: host.raspberrypi 3 instances found
        2021-12-20 21:04:34.999  - info: host.raspberrypi starting 3 instances
        2021-12-20 21:04:35.052  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 7454
        2021-12-20 21:04:37.005  - info: admin.0 (7454) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v14.18.2, js-controller: 3.3.21
        2021-12-20 21:04:37.054  - info: admin.0 (7454) requesting all states
        2021-12-20 21:04:37.055  - info: admin.0 (7454) requesting all objects
        2021-12-20 21:04:37.135  - info: admin.0 (7454) received all objects
        2021-12-20 21:04:37.231  - info: admin.0 (7454) http server listening on port 8081
        2021-12-20 21:04:37.231  - info: admin.0 (7454) Use link "http://localhost:8081" to configure.
        2021-12-20 21:04:37.268  - info: admin.0 (7454) State value to set for "admin.0.info.lastUpdateCheck" has to be type "number" but received type "string"
        2021-12-20 21:04:37.274  - warn: admin.0 (7454) Repository cannot be read
        2021-12-20 21:04:39.056  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 7505
        2021-12-20 21:04:40.515  - info: discovery.0 (7505) starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.18.2, js-controller: 3.3.21
        2021-12-20 21:04:43.039  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7520
        2021-12-20 21:04:44.601  - info: backitup.0 (7520) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
        2021-12-20 21:04:44.662  - info: backitup.0 (7520) [iobroker] backup was activated at 02:40 every 1 day(s)
        2021-12-20 21:05:13.492  - info: host.raspberrypi Updating repository "default" under "http://download.iobroker.net/sources-dist.json"
        2021-12-20 21:07:29.728  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
        2021-12-20 21:07:29.743  - info: backitup.0 (7520) Got terminate signal TERMINATE_YOURSELF
        2021-12-20 21:07:29.744  - info: backitup.0 (7520) cleaned everything up...
        2021-12-20 21:07:29.745  - info: backitup.0 (7520) terminating
        2021-12-20 21:07:29.746  - info: backitup.0 (7520) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-12-20 21:07:29.752  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
        2021-12-20 21:07:30.293  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2021-12-20 21:07:32.829  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7933
        2021-12-20 21:07:34.369  - info: backitup.0 (7933) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
        2021-12-20 21:07:34.432  - info: backitup.0 (7933) [iobroker] backup was activated at 02:40 every 1 day(s)
        2021-12-20 21:08:09.386  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
        2021-12-20 21:08:09.398  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
        2021-12-20 21:08:09.398  - info: backitup.0 (7933) Got terminate signal TERMINATE_YOURSELF
        2021-12-20 21:08:09.401  - info: backitup.0 (7933) cleaned everything up...
        2021-12-20 21:08:09.402  - info: backitup.0 (7933) terminating
        2021-12-20 21:08:09.405  - info: backitup.0 (7933) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-12-20 21:08:09.993  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2021-12-20 21:08:12.439  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7984
        2021-12-20 21:08:14.006  - info: backitup.0 (7984) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
        2021-12-20 21:08:14.074  - info: backitup.0 (7984) [iobroker] backup was activated at 02:40 every 1 day(s)
        2021-12-20 21:09:05.300  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
        2021-12-20 21:09:05.316  - info: backitup.0 (7984) Got terminate signal TERMINATE_YOURSELF
        2021-12-20 21:09:05.320  - info: backitup.0 (7984) cleaned everything up...
        2021-12-20 21:09:05.322  - info: backitup.0 (7984) terminating
        2021-12-20 21:09:05.325  - info: backitup.0 (7984) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-12-20 21:09:05.358  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
        2021-12-20 21:09:05.861  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2021-12-20 21:09:08.399  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 8013
        2021-12-20 21:09:09.926  - info: backitup.0 (8013) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.21
        2021-12-20 21:09:09.989  - info: backitup.0 (8013) [iobroker] backup was activated at 02:40 every 1 day(s)
        • S Sirfauntleroy
          Sirfauntleroy
          Fand die datei nicht.. nochmal ausgewählt: und es tut sich was
          2021-12-20 21:18:40.643  - info: admin.0 (7454) terminating http server on port 8081
          2021-12-20 21:18:40.642  - info: host.raspberrypi received SIGTERM
          2021-12-20 21:18:40.653  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
          2021-12-20 21:18:40.654  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
          2021-12-20 21:18:40.654  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
          2021-12-20 21:18:40.671  - info: admin.0 (7454) Got terminate signal TERMINATE_YOURSELF
          2021-12-20 21:18:40.672  - info: discovery.0 (7505) Got terminate signal TERMINATE_YOURSELF
          2021-12-20 21:18:40.673  - info: backitup.0 (8013) Got terminate signal TERMINATE_YOURSELF
          2021-12-20 21:18:40.677  - info: discovery.0 (7505) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2021-12-20 21:18:40.677  - info: backitup.0 (8013) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2021-12-20 21:18:40.679  - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
          2021-12-20 21:18:40.683  - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
          2021-12-20 21:18:40.683  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
          2021-12-20 21:18:40.689  - info: admin.0 (7454) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2021-12-20 21:18:41.240  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2021-12-20 21:18:41.258  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2021-12-20 21:18:41.261  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
          2021-12-20 21:18:41.262  - info: host.raspberrypi All instances are stopped.
          2021-12-20 21:18:41.285  - info: host.raspberrypi terminated
          2021-12-20 21:18:40.641  - info: backitup.0 (8013) cleaned everything up...
          2021-12-20 21:19:43.964  - info: host.ioBroker iobroker.js-controller version 3.3.21 js-controller starting
          2021-12-20 21:19:43.970  - info: host.ioBroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
          2021-12-20 21:19:43.971  - info: host.ioBroker hostname: ioBroker, node: v14.18.2
          2021-12-20 21:19:43.972  - info: host.ioBroker ip addresses: 192.168.10.11 fe80::1c60:4643:360d:88a7
          2021-12-20 21:19:45.163  - info: host.ioBroker connected to Objects and States
          2021-12-20 21:19:45.191  - info: host.ioBroker added notifications configuration of host
          2021-12-20 21:19:45.688  - info: host.ioBroker Delete host system.host.raspberrypi
          2021-12-20 21:19:45.836  - info: host.ioBroker 76 instances found
          2021-12-20 21:19:45.897  - warn: host.ioBroker does not start any instances on this host
          Thomas BraunT F 2 Antworten Letzte Antwort
          • S Sirfauntleroy
            @sirfauntleroy
            Du hast die Lokalisierung / lokale Zeitzone nicht angepasst .
            • S Sirfauntleroy
              F Online
              F Online
              fastfoot
              @sirfauntleroy da ist immer noch der hostname falschiob stop, iob host this, iob start. Gestern hiess es noch dass backitup das macht :-)
              S HomoranH 2 Antworten Letzte Antwort
              • F fastfoot
                Sirfauntleroy
                @fastfoot
                jetzt rattert im log so einiges durch..
                geduldig abwarten...
                • S Sirfauntleroy
                  @fastfoot
                  Sirfauntleroy
                  Das Backup ist durchgelaufen.
                  nun folgendes Problem ...
                  Error: Cannot find module '../encodings'
                  Require stack:
                  - /opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js
                  - /opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js
                  - /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/read.js
                  - /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/types/json.js
                  - /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/index.js
                  - /opt/iobroker/node_modules/iobroker.admin/node_modules/express/lib/express.js
                  - /opt/iobroker/node_modules/iobroker.admin/node_modules/express/index.js
                  - /opt/iobroker/node_modules/iobroker.admin/lib/web.js
                  - /opt/iobroker/node_modules/iobroker.admin/main.js
                      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                      at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                      at Module.require (internal/modules/cjs/loader.js:974:19)
                      at require (internal/modules/cjs/helpers.js:93:18)
                      at Object.getCodec (/opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js:65:27)
                      at Object.getDecoder (/opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js:127:23)
                      at getDecoder (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:45:18)
                      at readStream (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:180:15)
                      at getRawBody (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:108:12)
                      at read (/opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/read.js:77:3)
                  • S Sirfauntleroy
                    Require stack:
                    @sirfauntleroy
                    nodeJS ist sauber, nehme ich an?
                      @sirfauntleroy
                      Sirfauntleroy
                      nach einem Reboot gehts es jetzt soweit..
                      eieiei..
                      Irgendwie wäre die Idee mit dem schnellen wiederherstellen per .iso ja doch verlockend gewesen...
                      Herzlichen Dank bisher an euch alle!!!!!!
                      • S Sirfauntleroy
                        eieiei..
                        Sirfauntleroy
                        Erstmal danke an alle, die am Backup-Adapter beteiligt sind. Ist ja grundsätzlich schon echt ne super Sache!!!!!!
                        Nachdem das System nun wieder weitgehend anständig läuft, hätte ich noch ein paar Fragen:
                        1. Kann ich nun, da das System läuft redis ohne Probleme abstellen? (Wird ja offensichtlich nicht benötigt und macht mehr Probleme als nutzen) und wenn ja, wie, ohne, dass ich wieder einen Crash verursache? :D
                        2. Da ich die komplette Anbindung an KNX über Nodered realisiere bin ich darauf besonders angewiesen.
                          Nach dem Einspielen des Backups waren die Zusatzbausteine wie KNX-Ultimate nicht wieder hergestellt (glaube auch gelesen zu haben, das dies normal ist). Nachdem ich diese installiert hatte, waren alle KNX-Nodes im ersten Flow ?! ohne jegliche Verbindung. Strange....
                          Gut, dass ich nach jedem größeren Programmierschritt separate Backups aller Flows mache.. so konnte ich diese wiederherstellen. Aber geht das nicht auch einfacher?
                        • F fastfoot
                          @fastfoot sagte in Crash - no connection to states 0.0.0.0:6370[redis]:
                          Dann sollte sich @simatec auch mal hier den Thread ansehen :-)
                          • S Sirfauntleroy
                            ja. über iobroker setup custom
                            das kann man so wirklich nicht sagen.
