  4. JavaScript
  5. [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten
1.5k Beiträge 53 Kommentatoren 704.4k Aufrufe 52 Beobachtet
  • T ticaki
    @sigi234 sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
    @ticaki
    2:30:14.226	info	javascript.0 (10844) Stop script script.js.Sigi.UWZ_DWD_NINA15
    22:30:14.228	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: Skripts gestoppt: ID:2666.881601051354
    22:30:14.253	info	javascript.0 (10844) Start javascript script.js.Sigi.UWZ_DWD_NINA15
    22:30:14.283	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: Skripts gestartet: ID:5148.472670716522
    22:30:14.286	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: registered 0 subscriptions and 0 schedules
    22:30:16.568	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: Rufe Daten vom Server ab - ZAMG Area
    22:30:16.640	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: testValueDWD2() 5. [object Object]
    22:30:16.641	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: 500
    22:30:16.641	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: {'date':'Sat, 11 Dec 2021 21:30:15 GMT','server':'Apache','content-length':'209','connection':'close','content-type':'application/json; charset=utf-8'}
    22:30:16.920	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: MODE wurde geändert. MODE: 19 firstRun:true
    22:30:16.920	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: Standalone UWZ Datenabruf aktiviert
    22:30:16.920	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: Standalone ZAMG Datenabruf aktiviert
    22:30:16.921	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: Rufe Daten vom Server ab - UWZ
    22:30:17.043	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: Rufe Daten vom Server ab -ZAMG
    22:30:17.154	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: getDataFromServer() 5.
    22:30:17.154	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: {'type':'Error','msg':'ERROR database connection failed.SQLSTATE[XX000]: Internal error: 7 ERROR: parse error - invalid geometry\nHINT: \'SRID=4326;POINT(un\' <-- parse error at position 18 within geometry'}
    22:30:17.154	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: 500
    22:30:17.154	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: {'date':'Sat, 11 Dec 2021 21:30:16 GMT','server':'Apache','content-length':'209','connection':'close','content-type':'application/json; charset=utf-8'}
    22:30:17.160	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: No change or init! id: dwd.0.warning.object headline: Amtliche WARNUNG vor FROST
    22:30:17.160	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: No change or init! id: dwd.0.warning1.object headline: Amtliche WARNUNG vor GLÄTTE
    22:30:17.161	info	javascript.0 (10844) script.js.Sigi.UWZ_DWD_NINA15: Nutze Datenabruf für DWD über States in dwd.0
    Hm, was gehört jetzt im Skript eingetragen und was in den Objekten?
    Ist beides das gleiche. Beim Start werden Daten die im Skript stehen in die Objekte geschrieben. Du kannst halt einzelne Warncellen aktivieren und deaktivieren und siehst zumindest bei DWD und ZAMG ob es richtig ist.
    Oh ich hab noch ne änderung vergessen:
    var zamgCoordinates = [{laengen:13.05501,breiten:47.80949},{breiten:46.6247200, laengen:14.3052800}];
    hab das umbenannt damit ich nicht mehr durcheinander komme :)
    EDIT ein paar versionen weiter will ich die konfiguration für die Warncellen aus dem Skript haben.
    M Online
    M Online
    Megawaldi
    #809
    @ticaki
    Guten Morgen,
    auch nach dem löschen der entsprechenden Datenpunkte habe ich auch immer den typfehler:
    javascript.0
    	2021-12-12 10:44:38.802	info	State value to set for "0_userdata.0.wetterwarnung.config.warnzelle.zamg.refresh#" has to be type "boolean" but received type "string"
    javascript.0
    	2021-12-12 10:44:38.801	warn	at processImmediate (internal/timers.js:466:21)
    javascript.0
    	2021-12-12 10:44:38.801	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1962:33)
    javascript.0
    	2021-12-12 10:44:38.801	warn	You are assigning a string to the state "0_userdata.0.wetterwarnung.config.warnzelle.zamg.refresh#" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
    javascript.0
    	2021-12-12 10:44:38.726	info	State value to set for "0_userdata.0.wetterwarnung.config.warnzelle.uwz.refresh#" has to be type "boolean" but received type "string"
    javascript.0
    	2021-12-12 10:44:38.725	warn	at processImmediate (internal/timers.js:466:21)
    javascript.0
    	2021-12-12 10:44:38.725	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1962:33)
    javascript.0
    	2021-12-12 10:44:38.725	warn	You are assigning a string to the state "0_userdata.0.wetterwarnung.config.warnzelle.uwz.refresh#" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
    javascript.0
    	2021-12-12 10:44:38.360	info	State value to set for "0_userdata.0.wetterwarnung.config.warnzelle.dwd.refresh#" has to be type "boolean" but received type "string"
    javascript.0
    	2021-12-12 10:44:38.358	warn	at processImmediate (internal/timers.js:466:21)
    javascript.0
    	2021-12-12 10:44:38.358	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1962:33)
    javascript.0
    	2021-12-12 10:44:38.357	warn	You are assigning a string to the state "0_userdata.0.wetterwarnung.config.warnzelle.dwd.refresh#" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
    • LatziL Latzi
      @ticaki
      Guten Morgen,
      ich bekomme warn bezüglich der refresh Datenpunkte, was soll ich unternehmen?
      2021-12-12 07:55:57.862 - info: javascript.0 (23974) Start javascript script.js.common.UWZ_melden_V0_99_Beta1
      2021-12-12 07:55:57.905 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: Skripts gestartet: ID:1533.1505777283394
      2021-12-12 07:55:57.910 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: registered 1 subscription and 0 schedules
      2021-12-12 07:55:57.970 - warn: javascript.0 (23974) You are assigning a string to the state "javascript.0.wetterwarnung.config.warnzelle.dwd.refresh#" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
      2021-12-12 07:55:57.980 - warn: javascript.0 (23974) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1962:33)
      2021-12-12 07:55:57.981 - warn: javascript.0 (23974) at processImmediate (internal/timers.js:466:21)
      2021-12-12 07:55:58.000 - info: javascript.0 (23974) State value to set for "javascript.0.wetterwarnung.config.warnzelle.dwd.refresh#" has to be type "boolean" but received type "string"
      2021-12-12 07:55:58.302 - warn: javascript.0 (23974) You are assigning a string to the state "javascript.0.wetterwarnung.config.warnzelle.uwz.refresh#" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
      2021-12-12 07:55:58.304 - warn: javascript.0 (23974) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1962:33)
      2021-12-12 07:55:58.304 - warn: javascript.0 (23974) at processImmediate (internal/timers.js:466:21)
      2021-12-12 07:55:58.311 - info: javascript.0 (23974) State value to set for "javascript.0.wetterwarnung.config.warnzelle.uwz.refresh#" has to be type "boolean" but received type "string"
      2021-12-12 07:55:58.600 - warn: javascript.0 (23974) You are assigning a string to the state "javascript.0.wetterwarnung.config.warnzelle.zamg.refresh#" which expects a boolean. Please fix your code to use a boolean or change the state type to string. This warning might become an error in future versions.
      2021-12-12 07:55:58.601 - warn: javascript.0 (23974) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1962:33)
      2021-12-12 07:55:58.602 - warn: javascript.0 (23974) at processImmediate (internal/timers.js:466:21)
      2021-12-12 07:55:58.609 - info: javascript.0 (23974) State value to set for "javascript.0.wetterwarnung.config.warnzelle.zamg.refresh#" has to be type "boolean" but received type "string"
      2021-12-12 07:55:58.622 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: Rufe Daten vom Server ab - ZAMG Area
      2021-12-12 07:55:58.696 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: Status: 200
      2021-12-12 07:55:59.012 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: MODE wurde geändert. MODE: 2 firstRun:true
      2021-12-12 07:55:59.013 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: InitDatabase() first: true
      2021-12-12 07:55:59.014 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: Standalone UWZ Datenabruf aktiviert
      2021-12-12 07:55:59.015 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: Rufe Daten vom Server ab - UWZ
      2021-12-12 07:55:59.162 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: AREA: UWZAT00754
      2021-12-12 07:55:59.163 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: Status: 200
      2021-12-12 07:55:59.163 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: Url: http://feed.alertspro.meteogroup.com/AlertsPro/AlertsProPollService.php?method=getWarning&language=de&areaID=UWZAT00754
      2021-12-12 07:55:59.166 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: ZAMG aktivieren, Warncell vorhanden
      2021-12-12 07:55:59.167 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: Rufe Daten vom Server ab -ZAMG
      2021-12-12 07:55:59.183 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: 1. addDatabaseData() ID + JSON:javascript.0.wetterwarnung.data.uwz-id.UWZAT00754.warning.object - {}
      2021-12-12 07:55:59.239 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: 1. addDatabaseData() ID + JSON:javascript.0.wetterwarnung.data.uwz-id.UWZAT00754.warning1.object - {}
      2021-12-12 07:55:59.281 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: 1. addDatabaseData() ID + JSON:javascript.0.wetterwarnung.data.uwz-id.UWZAT00754.warning2.object - {}
      2021-12-12 07:55:59.323 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: 1. addDatabaseData() ID + JSON:javascript.0.wetterwarnung.data.uwz-id.UWZAT00754.warning3.object - {}
      2021-12-12 07:55:59.364 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: Status: 200
      2021-12-12 07:55:59.364 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: Url: https://warnungen.zamg.at/wsapp/api/getWarningsForCoords?lon=14.62274&lat=48.332741&lang=de
      2021-12-12 07:55:59.400 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: 1. addDatabaseData() ID + JSON:javascript.0.wetterwarnung.data.uwz-id.UWZAT00754.warning4.object - {}
      2021-12-12 07:55:59.446 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: []
      2021-12-12 07:55:59.673 - info: javascript.0 (23974) script.js.common.UWZ_melden_V0_99_Beta1: DEBUG: []
      T Nicht stören
      T Nicht stören
      ticaki
      #810
      @latzi
      @Megawaldi
      Update, war ein copy paste Fehler. Frage mich nur wieso ich den nicht hatte. Der Fehler war bei mir schon mehr als 4 Tage drin und ich hab mehr als einmal die States alle gelöscht.
      EDIT: Nur zur Info: Beim Verwenden von ZAMG und dem einfügen von Koordinaten über Objekte. Die Zahl muß einen . als Dezimaltrennzeichen haben.
      EDIT2: Daten die im Skript stehen lassen sich nicht löschen nur deaktivieren.
      Spenden
      LatziL 1 Antwort Letzte Antwort
      • T ticaki
        @latzi
        @Megawaldi
        LatziL Online
        LatziL Online
        Latzi
        #811
        @ticaki
        auf der ZAMG-Seite sehe ich folgende Meldung:
        Im Datenpunkt "Glatteis" taucht aber leider nichts auf.
        Meine Koordinaten:
        var zamgCoordinates = [{breiten:48.332741,laengen:14.62274}];
        • LatziL Latzi
          @ticaki
          Meine Koordinaten:
          T Nicht stören
          T Nicht stören
          ticaki
          #812
          @latzi sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
          Bei mir gehts.
          Ist die Warnung unter data.zamg? Wenn nein, ist die koordinate unter config.warnzelle deaktiviert.
          steht dein minlevel im Skript auf höher als 1?Bildschirmfoto 2021-12-12 um 11.42.05.png
          Spenden
          • T ticaki
            Bei mir gehts.
            LatziL Online
            LatziL Online
            Latzi
            #813
            @ticaki
            Ich bin schlicht und ergreifend ein Idiot ;-)
            Habe die Datenpunkte gelöscht und danach in der Config UWZ udn ZAMG nicht aktiviert!
            Das habe ich erst bemerkt, nachdem ich auf debug gestellt habe - da kam die Warnung!
            ALEES GUT, TOLLE ARBEIT 👏 👏
            • T ticaki
              Deprecated
              Wird zum Adapter weiterentwickelt und es finden keine Verbesserungen oder Fehlerbehebungen mehr statt. Abgesehen von kritischen.
              https://forum.iobroker.net/topic/68595/test-adapter-weather-warnings
              Das Script:
              Script auf Github
              DWD-UWZ-NINA-Pushwarnungen-iobroker
              Vorbemerkung
              Diese Anleitung ist schon seit längerem nicht überarbeitet worden, daher nicht ganz aktuell.
              Das Skript mit dem anhang beta, wird zur dieser Zeit (08/2023) überarbeitet, da gibt es immer wieder unkommentierte Änderungen. Die Konfiguration wird in diesem ebenfalls immer mal wieder angepasst, so das ein einfaches Copy&Paste nicht ausreicht. Könnt ihr gerne testen, aber es ist expliziert eher ALPHA als beta.
              Support
              Supportthread: Iobroker Forum
              Scriptbeschreibung
              Mit diesem Script kannst du Warnungen des Deutschen Wetterdienstes, der Unwetterzentrale, der Zentralanstalt für Meteorologie und Geodynamik(Österreich) oder von Nina (Notfallinformationssystem der BRD) als Text oder Sprachausgabe über verschiedene Wege ausgeben. Dieses geschieht entweder automatisch nach dem Eintreffen oder nach Betätigen eines Schalters.
              Für DWD, Zamg und UWZ gibt es Datenpunkte um bei bestimmten Gefahren selbst gesteuerte Aktionen auszuführen. Letzteres nutze ich z.B. um bei Sturm/Regen und offenen Fenstern auf diese hinzuweisen.
              Unterstützt:
              • Telegram, Pushover, Home24-Mediaplayer, SayIt, Alexa, Datenpunkt, eMail oder Whatsapp
              • Standalone Datenabruf für DWD, NINA, UWZ und Zamg
              • Wetterwarnung
              • Wetterentwarnung
              Funktionen:
              • Filter die Warnungen nach doppelt, Gefahr(level) und Höhe
              • Umschalten über iobroker zwischen DWD/UWZ/NINA
              • Automatischer Versand und/oder manueller Nachrichtenversand (in Lang- oder Kurzform)
              • Zeitschaltuhr für Sprachausgabe
              • Datenpunkte mit der Startzeit, Endzeit, Type, Schlagzeile, Beschreibung, Farbe für Level(bgcolor) und höchstem Warnlevel dieses Typs
              • Datenpunkthauptpfade sind konfigurierbar incl. 0_userdata
              • Konfigurationsprüfung soweit möglich
              • Automodus und einzelne Pushdienste über iobroker schaltbar, sowohl für Automodus als auch Manuell
              • Optimierte Sprachausgabe
              Kleinkram:
              • Sprachausgabe: Sturmdetails werden ausgefiltert oder korrekt ausgesprochen (konfigurierbar)
              • Sprachausgabe: Pause zwischen dem Absenden der einzelnen Warnungen an die Wiedergabeeinheit konfigurierbar.
              • Manuelle Sprachnachrichten können die Zeitschaltuhr missachten. (konfigurierbar)
              • Multi-User/Device bei fast allen Pushdiensten verfügbar (außer Datenpunkt & pushover & whatsapp)
              • Autorestart bei Datenpunkterstellung
              • Alexa und SayIt mit Lautstärkeeinstellung. Alexagruppen unterstützen keine Lautstärke trotzdem konfigurieren.
              • Zusätzliche Hervorhebung konfigurierbar über attentionWarningLevel (im Betreff/Ansage)
              • Filter für Nina-sender
              • Namesbezeichner für Nina verfügbar, diese werden benötigt, falls in der Warnung Ort genannt wird, das auszugeben und damit die Bedeutung der Warnung hervorzuheben.
              Dank an:
              • Mic für die createUserStates() Funktionen
              • CruziX der diese eingebaut hat.
              • crunchip, sigi234, Latzi fürs Testen und Ideen
              • die ursprünglichen Authoren s.o. (im Skript)
              Bedeutung der Farben:
              • 0 - Grün
              • 1 - Dunkelgrün (wobei tails entfernt)
              • 2 - Gelb Wetterwarnungen (Stufe 2)
              • 3 - Orange Warnungen vor markantem Wetter (Stufe 3)
              • 4 - Rot Unwetterwarnungen (Stufe 4).
              • 5 - Violett Warnungen vor extremem Unwetter (DWD -> Weltuntergang nach aktueller Erfahrung und Nina -> höchste Stufe
              Vorbemerkung zur Konfigurationen
              Update: Das Skript wird in Zukunft keine externen Adapter mehr benötigen oder unterstützen.
              Das Skript und die Dokumentation wurden zu erst nur für externe Adapter geschrieben, daher beziehen sich vieles auf die Zusammenarbeit mit diesen. Wenn ihr den integrierten Datenabruf verwenden wollt, findet ihr unter Objekten im Unterverzeichnis
              0_userdata.0.wetterwarnung1.config.basiskonfiguration.warnzelle
              Die Warnzellen die verwendet werden. Ihr könnt dort Warnzellen hinzufügen und entfernen. Im Unterschied zu allen anderen Datenpunkten die sich über die Objekte verändern lassen, überschreiben die Änderungen dort jedoch nicht die Einstellungen im Skript. Wenn das Skript gestartet wird, werden alle im Skript definierten Warnzellen dort eingetragen, anschließend werden alle dort eingetragenen Warnzellen vom Skript eingelesen und verwendet. Folglich könnt ihr keine Warnzellen löschen die im Skript definiert sind. Folgenden Variablen werden für die Definition von Warnzellen verwendet.
              Update: Das wird alles über Datenpunkte erledigt
              Konfiguration in ioBroker/Objekte unter mainStatePath.config
              1. DWD/UWZ/NINA auf true stellen um den jeweiligen Modus zu aktiveren.
              2. Mode ist aus Kompatibilitätsgründen drin und kann als Zeichenkette UWZ usw enthalten.
              3. Punkte unter .auto aktiveren oder deaktivieren den automatischen Versand von Warnmeldungen.
              • .on schaltet den kompletten automatischen Versand an/aus.
              • die Restlichen schalten für einen bestimmten Modus eine bestimmte Art an oder aus.
              1. Punkte unter manuell schalten für das manuelle Auslösen in einem bestimmten Modus die Möglichkeit an oder aus. (z.B. UWZ über alexa aber NINA nicht).
              Vorbereitung bei der Verwendung von NINA bei Verwendung des externen Adapters
              • mindestens v0.0.22
              • in der Adapterkonfiguration diesen Punkt aktivieren: Json der Warnung in den State rawJson speichern (erhöhter Speicherbedarf)
              Konfiguration bei Verwendung des Skript internen Datenabrufs für DWD, ZAMG, UWZ, NINA (keine anderen Adapter nötig)
              • für UWZ konfiguriert regionName. [['UWZ + DE + PLZ','Mein Ort']]
              var regionName          = [['','']];// var regionName = ['UWZDE13245', 'Entenhausen']
              -die Warncelle ist die Zahl in der linken Spalte: https://www.dwd.de/DE/leistungen/opendata/help/warnungen/cap_warncellids_csv.csv?__blob=publicationFile&v=3
              // Standalone Datenquelle
              // entnehme ZAHL aus CSV
              /* nur Gemeinde/Landkreis/Großstädte werden verwendet: https://www.dwd.de/DE/leistungen/opendata/help/warnungen/cap_warncellids_csv.csv?__blob=publicationFile&v=3 */
              var dwdWarncellId = ''; // Deaktivieren mit '' einzel: '2334535354' mehrere: ['23423424','23423423']
              • Bei Zamg einfach die Koordinaten eingeben (müssen in Österreich liegen)
              // Koordinaten [{laengen:13.05501,breiten:47.80949}];.
              var zamgCoordinates = []; // [] ist deaktiviert
              var uZAMGMitMeteoinformationen = true; // gibt die Wetterinformationen mit der Beschreibung aus: z.B Eine Kaltfront und ein Italientief sorgen im Warnzeitraum...
              • Für Nina ebenfalls die Koordinaten eingeben (müssen in Deutschland liegen)
              // für Nina gebt die Koordinaten für euren Ort ein.
              ninaCoordinates = [] //   ninaCoordinates = [{breiten:51.2277, laengen:6.7735, text:'dadrüben'}, {breiten:53.0511000, laengen:8.6309100, text:'Delmenhorst'}];
              Konfigurationsparameter NACH dem ersten Start
              • DWD/UWZ/NINA muß gesetzt werden, ist alles deaktiviert.
              • Anschließend die Einstellungen unter 0_userdata.0.wetterwarnung.config.auto und 0_userdata.0.wetterwarnung.config.manuell kontrollieren. Mit diesen könnt ihr einstellen das z.B DWD über Alexa und Email ausgegeben wird, Nina hingegen nur über Email
              • Nach dem ersten Start werden Datenpunkte erstellt, die in Zukunft zur Konfiguration genutzt werden und die Werte im Skript überschreiben. Diese findet ihr unter config
              Konfigurationsparameter Script
              Konfigurationsparameter vor dem ersten Start
              1. Der Datenpfad zu allen von diesem Script erstellten Datenpunkten.
              var mainStatePath = 'javascript.0.wetterwarnung_test.';
              // oder
              var mainStatePath = '0_userdata.0.wetterwarnung.';
              1. Aktiveren der Ausgabemöglichkeiten. Es muß mindestens 1 Punkt aktiviert sein.
                Zu den jeweiligen Optionen muß der entsprechende Adapter installiert werden und eventuell im folgenden noch weitere Konfigurationen vorgenommen werden.
              //uPushdienst+= TELEGRAM;
              //uPushdienst+= PUSHOVER;
              //uPushdienst+= EMAIL;
              //uPushdienst+= SAYIT;
              //uPushdienst+= HOMETWO;  // kein Adapter nötig
              //uPushdienst+= ALEXA;
              //uPushdienst+= STATE;    // kein Adapter nötig
              //uPushdienst+= IOGO;
              Um einen Punkt zu aktiveren entferne die //
              z.B.
              Konfigurationsparameter Allgemein
              • Stellt uLogAusgabe auf 0 wenn alles so läuft wie ihr euch das vorstellt.
              var uLogAusgabe=        2; // auf 0 gibt es überhaupt keine Ausgabe beim normalen Betrieb.
              • Mit Hilfe dieser Variablen bestimmt ihr ob Email, Textnachrichten oder Sprachnachrichten voreingestellt ohne Beschreibung (false) und/oder Anweisungen (false) versand werden.
              var uSpracheMitBeschreibung         = true; // gilt für alle Sprachnachrichten
              var uSpracheMitAnweisungen          = true; // uSpracheMitBeschreibung muß evenfalls true sein um Anweisungen zu erhalten
              var uHtmlMitBeschreibung            = true; // gilt für Email
              var uHtmlMitAnweisungen             = true; // uHtmlMitBeschreibung muß evenfalls true sein um Anweisungen zu erhalten
              var uTextMitBeschreibung            = true; // gilt nicht für Email, aber für alle anderen Textnachrichten
              var uTextMitAnweisungen             = true; // uTextMitBeschreibung muß evenfalls true sein um Anweisungen zu erhalten
              uTextHtmlMitOhneAlles               = false // diese beiden Optionen überschreiben alle oben getroffenen Einstellungen
              var uSpracheMitOhneAlles            = true;
              • MitOhneAlles folgendes Muster: Warnung vor Typ, für Region, Stufe: Farbe, Tag Tageszeit
              • Beispiel: Warnung vor Sturm für Köln, Stufe: gelb, heute abend
              Sprachausgabe weitere Einstellungen
              • Wenn die Sprachausgabe manuell ausgelöst wird, kann die Sprachausgabewarteschlage gelöscht (true) oder die abgerufenen Nachrichten angehangen werden (false).
              var uManuellClickClearSpeakMessageList = true;
              • Die Sprachausgabe kann die Details zur Windgeschwindigkeit ausblenden (false) oder aussprechen (true)
              var windForceDetailsSpeak   = false;
              • Ab wieviel Uhr darf die Sprachausgabe verwendet werden (Mo-Fr)
              var startTimeSpeak =        '6:45';
              • Ab wieviel Uhr darf die Sprachausgabe am Wochenende verwendet werden (Sa-So)
              var startTimeSpeakWeekend = '9:00';
              • Wann endet die Sprachausgabeabends
              var endTimeSpeak =          '22:30';
              • Das manuelle Auslösen der Sprachausgabe berücksichtigt die Zeitschaltuhr (false) es ignoriert sie (true)
              var forcedSpeak             = true;
              Filtermöglichkeiten für Warnungen
              1. minlevel hiermit bestimmt man ab welchem Level Warnungen von diesem Skript berücksichtigt werden. Dieser Wert sollte nicht höher als 3 eingestellt sein.
              const minlevel                      =    1
              1. attentionWarningLevel Warnungen gleich/über diesem Wert werden extra hervorgehoben. Die Überschriften zeigen auf Gefahr hin. Pushover-Nachrichten werden mit höherer Prioritätversand. Alle internen nicht einstellbaren Filter/ Filter die im 2. Konfigurationsabschnitt stehen übergehen diese Warnung.
              const attentionWarningLevel         =    4
              1. Warnungen von DWD und UWZ kommen gelegentlich mit einer von/bis Höhenangabe.
              • Tragt bitte hier die Höhe des tiefesten Punktes in eurem Gebiet ein, den ihr in eurem täglichen Leben aufsucht. In meiner Region kommen Meldungen eher selten mit dem "bis" Eintrag.
              const minhoehe                      =    0
              • Hier den höchsten Punkt. Dieser wird mit dem "von" Eintrag verglichen. Ich nehme die Höhe meines Ortes 350m +/- 100m
              const maxhoehe                      =    5000
              Konfigurationsparameter für Pushmöglichkeiten
              • optionale Punkte brauchen nicht angepasst zu werden, wenn die Möglichkeit oben aktiviert wurde.
              • nicht optionale Punkte müssen angepasst/überprüft werden, wenn die Möglichkeit oben aktiviert wurde.
              Einstellungen zu Telegram: (optional)
              • Stelle hier Optional bestimmte Nutzer oder ChatID ein. Einzelnutzer ['Hans']; Multinutzer ['Hans', 'Gretel']; Nutzer vom Adapter übernehmen [];
              • Die Instanz nur anpassen, wenn deine davon abweicht. Das gilt für jede Instanzeinstellung
              var telegramUser        = [''];
              var telegramChatId      = [''];
              var telegramInstanz     = 'telegram.0';
              eMail: (optional)
              • Stelle hier Optional 1 Emailadresse ein, von der versendet wird, und mehrere Emailadressen die empfangen sollen.
              var senderEmailID       =   [""];// 1 Eintrag erlaubt [] oder ["email1"]
              var empfaengerEmailID   =   [""];// Mehrere Empfänger möglich. [] oder ["email1"] oder ["email1","email2"]
              var emailInstanz        =   'email.0';
              Pushover: (optional)
              • DeviceName, hier könnt ihr eines der angemeldeten Gerät bestimmen, das die Nachrichten erhalten soll. Ist kein Gerät bestimmt bekommen alle die Nachricht.
              • uPushoverSound bietet euch die Möglichkeit einen eigenen Sound für die Nachricht auszuwählen. Was ihr dort eintragen könnt findet ihr dort: https://pushover.net/api#sounds
              var uPushoverDeviceName     = '';
              var uPushoverSound          = '';
              var pushoverInstanz         = 'pushover.0';
              ioGo (optional)
              • ioGoUser: Tragt keinen, einen, oder mehrere "ID des Gerätes" ein.
              var ioGoUser = [''];
              Home24:
              • Das ist ungetestet, benutzt besser SayIt. Eingabe IP-Adresse incl. Port für Home24-Mediaplayer mehrere möglich
              var idMediaplayer       = ["192.168.178.x:Port"]; // (muß einen sinnvollen Wert beinhalten, wenn aktiviert)
              SayIt
              • idSayIt muß korrekt ausgefüllt sein, mit dem Datenpfad zum .text Datenpunkt, mehrere möglich.
              • sayItVolumen muß die gleiche Anzahl an Einträgen haben wie idSayIt 0-100
              var idSayIt             = ["sayit.0.tts.text"]; // (muß einen sinnvollen Wert beinhalten, wenn aktiviert)
              var sayItVolumen        = [30]; // gleiche Anzahl wie idSayIt
              Alexa
              • idAlexaSerial beinhaltet die Seriennummer deines Echos/deiner Echos. var idAlexaSerial =['G090RV32984110Y', 'G090RV32984110Y'];
              • alexaVolumen 0-100 die gleiche Anzahl wie idAlexaSerial z.B. [30,30];
              var idAlexaSerial       = [''];
              var alexaVolumen        = [30];
              var alexaInstanz        = 'alexa2.0';
              Konfigurationsparameter zu den Modi DWD, UWZ, NINA
              1. Einstellungen zur Unwetterzentrale/UWZ:
                Hier gibts du die UWZ RegionID an. Also z.B. UWZDE12345 und den Namen deines Ortes z.B. Entenhausen.
              var regionName          = [['UWZDE12345','Entenhausen']];
              1. Einstellungen zu Nina
              • Hier stellt bitte euren Ort und euren Landkreis ohne (Kreis, Landkreis, etc) ein. Warnungen von Nina kommen mit Aufgelisteten Orten, das Skript sucht dort drin nach euren Bezeichnern und gibt den gefundenen in der Warnung mit aus.
              var uGemeinde = '';
              ## Support
              - Findet ihr: https://forum.iobroker.net/topic/30616/script-dwd-uwz-nina-warnungen-als-push-sprachnachrichten/216
              [s=DWD/UWZ/NINA Script überarbeitet von ticaki]
              [Script auf Github](https://github.com/ticaki/DWD-UWZ-NINA-Pushwarnungen-iobroker)
              [/s]
              sigi234S Online
              sigi234S Online
              #814
              @ticaki
              • kann man bei dem DP 0_userdata.0.wetterwarnung.config.mode einen Bindestrich einfügen?
              • Wo sehe ich die Anzahl der Warnungen, bzw. ob es eine Warnung gibt? Summer aller Warnungen
              • sigi234S sigi234
                @ticaki
                T Nicht stören
                T Nicht stören
                ticaki
                #815
                @sigi234
                //Version 0.99.02 Beta 1
                • / als Trenner zwischen den Modes
                • neuer State totalWarnings
                • kleiner Bug behoben.
                Der totalWarnings State kann rumspringen während der Verarbeitung er wird bei jedem Verändern der Datenbank und nach dem Durchlauf des Benachrichtigungs und Filtercode gesetzt.
                Spenden
                • T Nicht stören
                  T Nicht stören
                  ticaki
                  #816
                  Allgemeine Infos:
                  Diese Erweiterungen sind für den Einbau von Nina gedacht, das mit den Warncellen hauptsächlich damit der Nutzer bei der Eingabe einer dieser nicht nachvollziehbaren ID's sieht ob sie richtig ist. Darüber ist mir folgender Gedanke gekommen.
                  Es gibt Leute die Warnungen für z.B. Hamburg und Berlin bekommen wollen, andererseits auch Leute die wie ich auf dem Berg leben und im Tal arbeiten obwohl zwischen beiden Orten nicht wirklich eine Distanz liegt. Wäre es da nicht sinnvoll wenn ich Warngruppen einrichte. So das es die Möglichkeit gibt das unterschiedliche Warncellen zusammengefasst werden können (also keine doppelten Warnungen) im Zuge dessen könne ich die Warntypen vereinfachen und auch unterschiedliche Datenquellen zusamemnfassen. Damit meine ich das eine UWZ und DWD Warnung vor Schnee nicht mehr 2 Warnungen sondern nur noch eine Warnung ist.
                  Im Warntext würde das z.B. so aussehen
                  Amtliche WARNUNG vor FROST des DWD und des UWZ für Hamburg und Berlin:
                  Benötigt natürlich einiges an Änderungen (1-2 Wochen) und wird wohl auch nicht direkt problemlos funktionieren, da es soviele Kombinationen an Möglichkeiten gibt, die ich unmöglich testen kann. Dazu kommt noch das ich nur Meldungen zusammenfassen könnte die den gleichen Zeitraum umfassen.
                  Desweiteren würde ich immer die Meldung vom DWD bzw. ZAMG als Vorlage verwenden und UWZ als "da auch".
                  Spenden
                  • T ticaki
                    Allgemeine Infos:
                    sigi234S Online
                    sigi234S Online
                    #817
                    @ticaki
                    Ich würde UWZ ganz raus nehmen.
                    • sigi234S sigi234
                      @ticaki
                      NashraN Offline
                      NashraN Offline
                      Nashra
                      Most Active Forum Testing
                      schrieb am zuletzt editiert von Nashra
                      #818
                      @ticaki
                      Warum? UWZ ist hier bei uns genauer als DWD und NINA meldet wenn überhaupt wenn es fast vorbei ist 😂
                      Gruß Ralf
                      • NashraN Nashra
                        @ticaki
                        T Nicht stören
                        T Nicht stören
                        ticaki
                        #819
                        @nashra
                        Danke ich hatte den gleichen Gedanken wie sigi, das hat sich damit erledigt :)
                        Spenden
                        LatziL NashraN 2 Antworten Letzte Antwort
                        • T ticaki
                          @nashra
                          LatziL Online
                          LatziL Online
                          Latzi
                          schrieb am zuletzt editiert von Latzi
                          #820
                          @ticaki sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
                          Bitte nicht UWZ rausnehmen, war im letzten Sommer das präziseste was an Vorhersage für mich möglich war!
                          • T ticaki
                            @nashra
                            NashraN Offline
                            NashraN Offline
                            Nashra
                            #821
                            @nashra
                            Danke. Problem ist wohl bei den verschiedenen Systemen das sie jeh nach Region unterschiedlich gut bzw. aktuell sind.
                            Hier z.B.
                            DWD schickt Sturmmeldung. Was passiert, nix
                            UWZ meldet, dann kommt auch was
                            NINA, naja. Kleines Beispiel, Samstags 12 Uhr Sirenentest, Meldung dazu kommt um 12:10 Uhr oder manchmal auch gar nicht. Beim Wetter ist es genauso.
                            Gruß Ralf
                            • NashraN Nashra
                              @nashra
                              Hier z.B.
                              T Nicht stören
                              T Nicht stören
                              ticaki
                              #822
                              @nashra
                              Das mit der Sturmmeldung sollte aber mit DWD2 (das genauer) nicht mehr vorkommen. Ich hab hier immer Gewitterwarnungen ohne Gewitter. Aber seit DWD2 ist bis jetzt noch nix gewarnt worden das auch nicht da war.
                              Spenden
                              • NashraN Offline
                                NashraN Offline
                                Nashra
                                #823
                                Hm, ist DWD2 eine neue Api von DooferWetterdienstDeutschland 😂
                                wenn Du schreibst das der besser ist, lasse ich mich mal überraschen.
                                Gruß Ralf
                                • NashraN Nashra
                                  T Nicht stören
                                  T Nicht stören
                                  ticaki
                                  #824
                                  @nashra
                                  Ne das ist meine Bezeichung:
                                  Erläuterung:
                                  DWD Adapter ruft Daten für den Kreis ab, also alle Warnungen die innerhalb eines Kreis veröffentlicht werden abgerufen. Irgendwo in deinem Kreis wird also Sturm sein. :)
                                  Ich hab dann letztens etwas mit maps.dwd.de rumgespielt und dort einen möglichkeit gefunden Warnungen für ein Dorf/Stadt/Region abzurufen.
                                  Dazu suche hier: https://www.dwd.de/DE/leistungen/opendata/help/warnungen/cap_warncellids_csv.csv?__blob=publicationFile&v=3
                                  deine Gemeinde und trage diese in
                                  var dwdWarncellId='';
                                  ein.
                                  Danach erhälst du nur noch Warnungen die der DWD für den Bereich deines Ortes vorgesehen hat. Hat dein Ort extreme Höhenunterschiede (oder wie hier in der Gegend eine "Stadt" deren weitester Stadtteil 10 km entfernt ist) kann das aber noch immer ungenau sein.
                                  Spenden
                                  • NashraN Offline
                                    NashraN Offline
                                    Nashra
                                    #825
                                    Danke für die Erklärung, hört sich interessant an. Dann lasse ich mich mal überraschen 👍
                                    Gruß Ralf
                                    • NashraN Nashra
                                      T Nicht stören
                                      T Nicht stören
                                      ticaki
                                      #826
                                      @nashra sagte in [Script] DWD/UWZ/NINA Warnungen als Push/Sprachnachrichten:
                                      Ich glaube wir reden aneinander vorbei.
                                      Das oben ist seit 2 Wochen in dem Script verfügbar.
                                      Spenden
                                      • T ticaki
                                        NashraN Offline
                                        NashraN Offline
                                        Nashra
                                        #827
                                        Ähm, ja. Ist irgendwie untergegangen bzw. nicht mitbekommen da Privat einiges um die Ohren.
                                        Dann muß ich mal das Skript einbauen :-)
                                        von 12345 oder komplett neu?
                                        Gruß Ralf
                                        • NashraN Nashra
                                          T Nicht stören
                                          T Nicht stören
                                          ticaki
                                          #828
                                          @nashra
                                          em besser ganz neu. weiß ja nicht wielange du kein Update gemacht hast :)
                                          Spenden
