  4. (gelöst)Zigbee-Adapter bleibt Gelb Error herdsman Start
    5.8k
41 Beiträge 6 Kommentatoren 12.8k Aufrufe 4 Beobachtet
  • T tom_33
    Ein 16-stelliger HexCode wurde eingefügt und ein Update auf 1.6.6 gestartet.
    Leider bleibt die Instanz auf Gelb. Anbei der Log dazu, welcher mit "errors" und "warns" gespickt ist, aber mir leider nichts sagt. Da steh ich da wie der Ochs vorm Berg.
    2021-12-11 04:06:16.897 - info: host.raspberrypi instance system.adapter.broadlink2.0 scheduled normal terminated and will be restarted on schedule.
    2021-12-11 04:06:16.918 - info: host.raspberrypi Restart adapter system.adapter.broadlink2.0 because enabled
    2021-12-11 04:06:17.969 - info: host.raspberrypi instance system.adapter.broadlink2.0 started with pid 19993
    2021-12-11 07:55:58.599 - info: admin.0 (568) Adapter rating updated
    2021-12-11 07:56:39.099 - info: info.0 (998) Reading/updating systemdata.
    2021-12-11 07:56:39.658 - info: info.0 (998) cpu Temp res = {"main":62.809,"cores":[],"max":62.809,"socket":[],"chipset":null}
    2021-12-11 08:49:42.693 - warn: sonoff.0 (876) Old client BA_Markise_E with secret 1639119391107_4251 sends pingreq. Ignore! Actual secret is 1639208981764_4191
    2021-12-11 12:40:07.364 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2021-12-11 13:16:31.207 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2021-12-11 13:16:31.233 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
    2021-12-11 13:16:31.229 - info: zigbee.0 (1958) Got terminate signal TERMINATE_YOURSELF
    2021-12-11 13:16:31.251 - info: zigbee.0 (1958) cleaned everything up...
    2021-12-11 13:16:31.256 - info: zigbee.0 (1958) Zigbee: disabling joining new devices.
    2021-12-11 13:16:31.631 - info: zigbee.0 (1958) terminating
    2021-12-11 13:16:31.632 - info: zigbee.0 (1958) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-12-11 13:16:32.331 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-12-11 13:16:34.306 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 11231
    2021-12-11 13:16:36.839 - info: zigbee.0 (11231) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 3.3.21
    2021-12-11 13:16:36.950 - info: zigbee.0 (11231) Starting Zigbee npm ...
    2021-12-11 13:16:37.206 - info: zigbee.0 (11231) Installed Version: iobroker.zigbee@1.5.6
    2021-12-11 13:16:45.216 - info: zigbee.0 (11231) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":0,"maintrel":0,"revision":""}}
    2021-12-11 13:16:45.222 - info: zigbee.0 (11231) Disable LED
    2021-12-11 13:16:45.228 - info: zigbee.0 (11231) --> transmitPower : high
    2021-12-11 13:16:45.237 - info: zigbee.0 (11231) Currently 23 devices are joined:
    2021-12-11 13:16:45.308 - info: zigbee.0 (11231) 0x00158d0004a07b41 (addr 17157): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
    2021-12-11 13:16:45.312 - info: zigbee.0 (11231) 0x00158d00024e2f3a (addr 47768): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2021-12-11 13:16:45.313 - info: zigbee.0 (11231) 0x00158d000252be01 (addr 40408): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2021-12-11 13:16:45.316 - info: zigbee.0 (11231) 0x000b57fffe915c30 (addr 12211): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
    2021-12-11 13:16:45.317 - info: zigbee.0 (11231) 0x04cf8cdf3c7c87f9 (addr 20559): WXCJKG12LM - Xiaomi Aqara Opple switch 2 bands (EndDevice)
    2021-12-11 13:16:45.319 - info: zigbee.0 (11231) 0x086bd7fffe2e72fc (addr 35850): E1603/E1702 - IKEA TRADFRI control outlet (Router)
    2021-12-11 13:16:45.320 - info: zigbee.0 (11231) 0x00158d00025d8c22 (addr 13309): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2021-12-11 13:16:45.321 - info: zigbee.0 (11231) 0x00158d00025ed89f (addr 19230): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2021-12-11 13:16:45.323 - info: zigbee.0 (11231) 0x00158d0002e6b62d (addr 16784): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2021-12-11 13:16:45.324 - info: zigbee.0 (11231) 0x00158d0002e9e490 (addr 51157): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2021-12-11 13:16:45.325 - info: zigbee.0 (11231) 0x00158d000215a945 (addr 22209): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
    2021-12-11 13:16:45.326 - info: zigbee.0 (11231) 0x00158d000205977d (addr 43801): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
    2021-12-11 13:16:45.327 - info: zigbee.0 (11231) 0x086bd7fffecba104 (addr 6243): RH3040 - TuYa PIR sensor (EndDevice)
    2021-12-11 13:16:45.328 - info: zigbee.0 (11231) 0x00158d0002c8f313 (addr 3758): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2021-12-11 13:16:45.330 - info: zigbee.0 (11231) 0x680ae2fffe3fca6c (addr 64757): E1603/E1702 - IKEA TRADFRI control outlet (Router)
    2021-12-11 13:16:45.331 - info: zigbee.0 (11231) 0x84182600000ef4a4 (addr 13408): AB3257001NJ - OSRAM Smart+ plug (Router)
    2021-12-11 13:16:45.332 - info: zigbee.0 (11231) 0x00158d0002041225 (addr 54978): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
    2021-12-11 13:16:45.333 - info: zigbee.0 (11231) 0x00158d0002b56d7c (addr 1273): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    2021-12-11 13:16:45.334 - info: zigbee.0 (11231) 0x00158d0002e20b9f (addr 13014): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2021-12-11 13:16:45.335 - info: zigbee.0 (11231) 0x00158d0002d46629 (addr 61601): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    2021-12-11 13:16:45.337 - info: zigbee.0 (11231) 0x000d6ffffec25343 (addr 9341): E1603/E1702 - IKEA TRADFRI control outlet (Router)
    2021-12-11 13:16:45.338 - info: zigbee.0 (11231) 0x7cb03eaa00ad39d5 (addr 19720): AB3257001NJ - OSRAM Smart+ plug (Router)
    2021-12-11 13:16:45.339 - info: zigbee.0 (11231) 0x00158d000424150c (addr 24225): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
    2021-12-11 13:16:45.340 - info: zigbee.0 (11231) Zigbee started
    2021-12-11 13:17:23.677 - info: host.raspberrypi iobroker upgrade zigbee@1.6.6
    2021-12-11 13:17:25.917 - info: host.raspberrypi iobroker Update zigbee from @1.5.6 to @1.6.6
    2021-12-11 13:17:25.930 - info: host.raspberrypi iobroker host.raspberrypi Adapter "system.adapter.zigbee.0" is stopped.
    2021-12-11 13:17:25.952 - info: host.raspberrypi "system.adapter.zigbee.0" disabled
    2021-12-11 13:17:25.953 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2021-12-11 13:17:25.958 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
    2021-12-11 13:17:25.959 - info: zigbee.0 (11231) Got terminate signal TERMINATE_YOURSELF
    2021-12-11 13:17:25.960 - info: zigbee.0 (11231) cleaned everything up...
    2021-12-11 13:17:25.964 - info: zigbee.0 (11231) Zigbee: disabling joining new devices.
    2021-12-11 13:17:26.369 - info: zigbee.0 (11231) terminating
    2021-12-11 13:17:26.370 - info: zigbee.0 (11231) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-12-11 13:17:26.601 - info: host.raspberrypi iobroker NPM version: 6.14.15
    2021-12-11 13:17:26.603 - info: host.raspberrypi iobroker npm install iobroker.zigbee@1.6.6 --loglevel error --prefix "/opt/iobroker" (System call)
    2021-12-11 13:17:26.950 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-12-11 13:19:17.840 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    2021-12-11 13:19:17.842 - info: host.raspberrypi iobroker ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 78 | uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:17.848 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    2021-12-11 13:19:17.850 - info: host.raspberrypi iobroker ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 135 | uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:17.854 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    2021-12-11 13:19:17.856 - info: host.raspberrypi iobroker ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 175 | uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:17.860 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    2021-12-11 13:19:17.862 - info: host.raspberrypi iobroker ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 215 | uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:17.867 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    2021-12-11 13:19:17.869 - info: host.raspberrypi iobroker ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 271 | uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:17.874 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    2021-12-11 13:19:17.875 - info: host.raspberrypi iobroker ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 316 | uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:17.882 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    2021-12-11 13:19:17.883 - info: host.raspberrypi iobroker ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 366 | uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:17.888 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    2021-12-11 13:19:17.890 - info: host.raspberrypi iobroker ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 412 | uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:17.892 - info: host.raspberrypi iobroker ../src/serialport.cpp: At global scope:../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] 433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local& v8str)) { | ^
    2021-12-11 13:19:17.894 - info: host.raspberrypi iobroker ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] 452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { | ^
    2021-12-11 13:19:17.897 - info: host.raspberrypi iobroker In file included from ../../../nan/nan.h:58,
    2021-12-11 13:19:17.898 - info: host.raspberrypi iobroker from ../src/./serialport.h:13, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:787:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type] 787 | (node::addon_register_func) (regfunc), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’ 821 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) | ^~~~~~~~~~~~~../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’ 486 | NODE_MODULE(serialport, init); | ^~~~~~~~~~~
    2021-12-11 13:19:21.872 - info: host.raspberrypi iobroker ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    2021-12-11 13:19:21.874 - info: host.raspberrypi iobroker ../src/serialport_unix.cpp:179:82: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=] 179 | snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); | ^~../src/serialport_unix.cpp:179:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024 179 | snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); | ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:21.910 - info: host.raspberrypi iobroker ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    2021-12-11 13:19:21.911 - info: host.raspberrypi iobroker ../src/serialport_unix.cpp:89:84: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=] 89 | snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); | ^~../src/serialport_unix.cpp:89:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024 89 | snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); | ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:28.823 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    2021-12-11 13:19:28.824 - info: host.raspberrypi iobroker ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 78 | uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:28.831 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    2021-12-11 13:19:28.832 - info: host.raspberrypi iobroker ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 135 | uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:28.836 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    2021-12-11 13:19:28.837 - info: host.raspberrypi iobroker ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 175 | uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:28.840 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    2021-12-11 13:19:28.842 - info: host.raspberrypi iobroker ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 215 | uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:28.846 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    2021-12-11 13:19:28.848 - info: host.raspberrypi iobroker ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 271 | uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:28.851 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    2021-12-11 13:19:28.853 - info: host.raspberrypi iobroker ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 316 | uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:28.859 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    2021-12-11 13:19:28.861 - info: host.raspberrypi iobroker ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 366 | uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:28.866 - info: host.raspberrypi iobroker ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    2021-12-11 13:19:28.868 - info: host.raspberrypi iobroker ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 412 | uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:28.869 - info: host.raspberrypi iobroker ../src/serialport.cpp: At global scope:../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] 433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local& v8str)) { | ^
    2021-12-11 13:19:28.872 - info: host.raspberrypi iobroker ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
    2021-12-11 13:19:28.873 - info: host.raspberrypi iobroker 452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { | ^
    2021-12-11 13:19:28.876 - info: host.raspberrypi iobroker In file included from ../../../nan/nan.h:58,
    2021-12-11 13:19:28.877 - info: host.raspberrypi iobroker from ../src/./serialport.h:13, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:787:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type] 787 | (node::addon_register_func) (regfunc), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’ 821 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) | ^~~~~~~~~~~~~../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’ 486 | NODE_MODULE(serialport, init); | ^~~~~~~~~~~
    2021-12-11 13:19:32.464 - info: host.raspberrypi iobroker ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    2021-12-11 13:19:32.465 - info: host.raspberrypi iobroker ../src/serialport_unix.cpp:179:82: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=] 179 | snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); | ^~../src/serialport_unix.cpp:179:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024 179 | snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); | ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:32.502 - info: host.raspberrypi iobroker ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    2021-12-11 13:19:32.503 - info: host.raspberrypi iobroker ../src/serialport_unix.cpp:89:84: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=] 89 | snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); | ^~../src/serialport_unix.cpp:89:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024 89 | snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); | ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    2021-12-11 13:19:52.739 - info: host.raspberrypi iobroker Update "system.adapter.zigbee.0"
    2021-12-11 13:19:53.082 - info: host.raspberrypi iobroker upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
    2021-12-11 13:19:56.405 - info: host.raspberrypi iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_ht.png img/sensor_ht.png image/png
    2021-12-11 13:19:59.728 - info: host.raspberrypi iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/paulmann_rgbw_globe.png img/paulmann_rgbw_globe.png image/png
    2021-12-11 13:20:03.004 - info: host.raspberrypi iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lamp_01.png img/lamp_01.png image/png
    2021-12-11 13:20:06.170 - info: host.raspberrypi iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/group_6.png img/group_6.png image/png
    2021-12-11 13:20:06.852 - info: host.raspberrypi iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_gu10.png img/gledopto_gu10.png image/png
    2021-12-11 13:20:07.502 - info: host.raspberrypi iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/flair_viyu_e14_candle.png img/flair_viyu_e14_candle.png image/png
    2021-12-11 13:20:08.223 - info: host.raspberrypi iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/diy.png img/diy.png image/png
    2021-12-11 13:20:08.816 - info: host.raspberrypi iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/crts0111.PNG img/crts0111.PNG image/png
    2021-12-11 13:20:09.424 - info: host.raspberrypi iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_v.png img/battery_v.png image/png
    2021-12-11 13:20:10.046 - info: host.raspberrypi iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZHS15.png img/ZHS15.png image/png
    2021-12-11 13:20:10.683 - info: host.raspberrypi iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Paulmann_50067.png img/Paulmann_50067.png image/png
    2021-12-11 13:20:11.333 - info: host.raspberrypi iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06104A.png img/HG06104A.png image/png
    2021-12-11 13:20:11.393 - info: host.raspberrypi iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
    2021-12-11 13:20:11.454 - info: host.raspberrypi iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
    2021-12-11 13:20:11.519 - info: host.raspberrypi iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_R8_8.png img/DIYRuZ_R8_8.png image/png
    2021-12-11 13:20:11.584 - info: host.raspberrypi iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Geiger.png img/DIYRuZ_Geiger.png image/png
    2021-12-11 13:20:11.648 - info: host.raspberrypi iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad_LeTV_8.png img/DIYRuZ_FreePad_LeTV_8.png image/png
    2021-12-11 13:20:11.714 - info: host.raspberrypi iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
    2021-12-11 13:20:11.783 - info: host.raspberrypi iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Flower.png img/DIYRuZ_Flower.png image/png
    2021-12-11 13:20:11.846 - info: host.raspberrypi iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/png
    2021-12-11 13:20:11.915 - info: host.raspberrypi iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
    2021-12-11 13:20:11.984 - info: host.raspberrypi iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
    2021-12-11 13:20:12.051 - info: host.raspberrypi iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
    2021-12-11 13:20:12.114 - info: host.raspberrypi iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
    2021-12-11 13:20:12.179 - info: host.raspberrypi iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
    2021-12-11 13:20:12.244 - info: host.raspberrypi iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
    2021-12-11 13:20:12.308 - info: host.raspberrypi iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
    2021-12-11 13:20:12.375 - info: host.raspberrypi iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
    2021-12-11 13:20:12.473 - info: host.raspberrypi iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
    2021-12-11 13:20:12.532 - info: host.raspberrypi iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/14147206L.png img/14147206L.png image/png
    2021-12-11 13:20:12.591 - info: host.raspberrypi iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
    2021-12-11 13:20:12.650 - info: host.raspberrypi iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
    2021-12-11 13:20:12.708 - info: host.raspberrypi iobroker Adapter "zigbee" updated
    2021-12-11 13:20:12.713 - info: host.raspberrypi iobroker host.raspberrypi Adapter "system.adapter.zigbee.0" is started
    2021-12-11 13:20:12.730 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
    2021-12-11 13:20:12.804 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 17105
    2021-12-11 13:20:13.758 - info: host.raspberrypi iobroker exit 0
    2021-12-11 13:20:15.849 - info: zigbee.0 (17105) starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 3.3.21
    2021-12-11 13:20:15.945 - info: zigbee.0 (17105) Starting Zigbee npm ...
    2021-12-11 13:20:16.370 - info: zigbee.0 (17105) Installed Version: iobroker.zigbee@1.6.6
    2021-12-11 13:20:28.630 - error: zigbee.0 (17105) Starting zigbee-herdsman problem : "SRSP - SYS - version after 6000ms"
    2021-12-11 13:20:28.632 - error: zigbee.0 (17105) Failed to start Zigbee
    2021-12-11 13:20:28.634 - error: zigbee.0 (17105) Error herdsman start
    2021-12-11 13:20:38.638 - info: zigbee.0 (17105) Try to reconnect. 1 attempts left
    2021-12-11 13:20:38.640 - info: zigbee.0 (17105) Starting Zigbee npm ...
    2021-12-11 13:20:38.692 - info: zigbee.0 (17105) Installed Version: iobroker.zigbee@1.6.6
    2021-12-11 13:20:38.906 - error: zigbee.0 (17105) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    2021-12-11 13:20:38.906 - error: zigbee.0 (17105) Failed to start Zigbee
    2021-12-11 13:20:38.907 - error: zigbee.0 (17105) Error herdsman start
    IOBroker gestoppt und mit einem reboot gestartet.
    zigbee.0
    	2021-12-11 13:29:39.686	error	Error herdsman start
    zigbee.0
    	2021-12-11 13:29:39.686	error	Failed to start Zigbee
    zigbee.0
    	2021-12-11 13:29:39.685	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    @tom_33
    Das richtige Gerät über den dev-link aus /dev/serial/by-id angelegt?
    könnte aber auch ein Firmware-Thema sein. Welche ist da drauf?
      tom_33
      habe ich nie geändert
        @tom_33
        tom_33
        @thomas-braun sagte in Zigbee-Adapter bleibt Gelb Error herdsman start:
        @tom_33
        Ich habe ihn fix und fertig gekauft. Juni 2019
        • T tom_33
          @tom_33 sagte in Zigbee-Adapter bleibt Gelb Error herdsman start:
          Dann prüf mal ob der noch gültig ist:
          ls -l /dev/serial/by-id
          • T tom_33
            @tom_33
            @tom_33
            https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html#error-srsp-sys-ping-after-6000ms
              tom_33
              schrieb am zuletzt editiert von tom_33
              pi@raspberrypi:~ $ ls -l /dev/serial/by-id
              total 0
              lrwxrwxrwx 1 root root 13 Dec 11 13:28 usb-Texas_Instruments_TI_CC2531_USB_CDC__        _0X00124B0018ED22A3-if00 -> ../../ttyACM0
              pi@raspberrypi:~ $ ^C
              nach USB_CDC steht noch
              Keine Ahnung warum das nicht angezeigt wird
              • T tom_33
                total 0
                Weil dein Terminalprogramm (vmtl. puTTY...) das kaputt macht. Mach das Fenster größer, wenn das geht. Oder verwende unter Windows z. B. die PowerShell.
                  tom_33
                  Ja putty im Vollbildmodus
                  ganz weit rechts...🙄
                  Muss ich den COM-Anschluss ändern?
                  • T tom_33
                    Du musst abgleichen, ob der device-Link auch genau so in den Einstellungen drin steht. Also
                    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018ED22A3-if00
                    Wobei ich bei dem Stick einfach auf "zu alt, zu schwach" tippen würde.
                    If you are using a CC2530 or CC2531; it is a common issue for this adapter to crash (due to its outdated hardware). Reflashing the firmware should fix the problem.
                      tom_33
                      Ich hab nicht gleich gecheckt, dass beim Dropdown Feld noch was dahinter steht. Aber die ID ist ident.
                      Was für ein Dongle ist zu empfehlen? CC26X2R1?
                      • T tom_33
                        @tom_33
                        https://www.zigbee2mqtt.io/guide/adapters/#recommended
                        Bei mir läuft ein
                        Slaesh's CC2652RB stick
                        Den kann ich ganz bequem über die Kommandozeile flugs flashen. Gerade gestern erst gemacht.
                          tom_33
                          OK!
                          Zuerst mal herzlichen Dank für deine schnelle Hilfe.
                          Ich werde mir mal einen neuen Dongle besorgen und dann nochmals einen Versuch starten.
                          bG tom
                          A Becks0815B 2 Antworten Letzte Antwort
                          • T tom_33
                            OK!
                            bG tom
                            arnold
                            schrieb am zuletzt editiert von arnold
                            @tom_33
                            Bevor du neuen Dongle besorgst gehe auf die Seite
                            https://www.zigbee2mqtt.io/guide/installation/01_linux.html#optional-running-as-a-daemon-with-systemctl
                            oder
                            Diese Anleitung erklärt, wie man Zigbee2MQTT unter Linux betreibt.
                            Thomas BraunT T 2 Antworten Letzte Antwort
                            • A arnold
                              @tom_33
                              oder
                              @arnold zigbee2mqtt ist so nah mit dem iobroker.zigbee verwandt, das dürfte keinen Unterschied machen. Alte Firmware und Hardwarelimits hast du da genauso.
                              • A arnold
                                @tom_33
                                oder
                                tom_33
                                @arnold sagte in Zigbee-Adapter bleibt Gelb Error herdsman start:
                                Danke für den Tipp, aber der Dongle ist schon bestellt. Es war ohnehin Zeit die Hardware zu erneuern. Ich habe zur Zeit 23 Zigbees im Betrieb und noch ein paar in der Schublade, welche ich einsetzten möchte. Das ist mit dem CC2531 eh schon grenzwertig. Auch ist es nach einem Neustart immer ein bisschen nervig, weil ein paar ZigbeeGeräte nicht korrekt eingebunden werden.
                                  arnold
                                  mein Bekannte hat den gleichen CC2531 (von mir geflasht bekommen) und sein iobroker ist zu 95 % identisch mit meinem und bei dem ist zigbee grün
                                  seine Einstellung
                                  ich werde mir auch ein neuen Dongle bestellen zB. LAUNCHXL-CC26X2R1 nur auf der Seite von Texas Instruments sind die ausverkauft, bei anderen (digikey.de) lange Lieferzeiten.
                                  • T tom_33
                                    arnold
                                    @tom_33 welchen Dongel hast du bestellt (vielleicht link).
                                    • A arnold
                                      tom_33
                                      @arnold
                                      Einen Slaesh's CC2652RB. Wie von Thomas Braun empfohlen. Auf eBay von mmsmarthome, welcher in München seinen Standort hat. Dieser wird fix und fertig geliefert und ich hoffe, der Wechsel geht so easy, wie ein paar hier schon beschrieben haben.
                                      • T tom_33
                                        @arnold
                                        Jan1
                                        @tom_33
                                        empfohlen nicht wirklich, er hat den ;)
                                        Ist ein guter Stick, wobei der Sonoff eben fast identisch ist und nur die Hälfte kostet.
                                        Ob das ein großer Vorteil, oder Erleichterung ist, dass man den über die Kommandozeile flashen kann, ich weiß es nicht. Wobei das mit dem Sonoff auch klappen müsste. Mein IOBoker Server seht auf dem PC und wenn ich mein Stick flashen möchte stecke ich den einfach am PC an und flash den. Also vom Aufwand eher bescheiden und das funktioniert auf alle Fälle immer :)
                                        Edit:
                                        wenn der Windows Treiber dafür geladen wurde, falls der nicht eh schon auf dem PC vorhanden ist
                                          tom_33
                                          Nun habe ich den CC2652RB in Betrieb nehmen können. Alten Stick raus und neuen rein hats nicht gespielt.
                                          Ich habe die PAN-ID und die erweiterte PAN-ID ändern müssen. Da ich mir meine 23 stück Zigbees schön dokumentiert habe, war das Einbinden kein großes Problem.
                                          Angefangen mit den Routern (Steckdosen und Lampen), und dann mit den Endgeräten (Temp/Taster/Regensensor/Türkontakten) weiter gemacht.
                                          Das Pairing funktionierte alles tadellos, ohne das ich Geräte dem Router unmittelbarr unter die Nase halten musste. Ich bin total zufrieden mit dem neuen Stick. Manche haben sogar einen Empfang von 150 (was immer das heißt) 😀 .
                                          Danke euch für die Tipps und Empfehlungen.
                                          lg tom
