  4. Ferraris Zähler mit TCRT5000 und esp8266
    6.8k
esp8266ferrarismqtttcrt5000smlsmartmeter
485 Beiträge 49 Kommentatoren 169.5k Aufrufe 46 Beobachtet
  • S so
    @eisbaeeer Hier noch mein log vom buid, vielleicht siehst du nochwas. Ich bin mir unsicher, ob da alles okay verlaufen ist. Ist allerdings ohne vorheriges 'clean'.
    so@soso  ~/workspace/Ferraris_MQTT_Energy_Counter_Meter_TCRT5000/source/Ferraris_MQTT_Energy_Counter_Meter_TCRT5000   master ● ? ⍟1  pio run
    Processing nodemcuv2 (platform: espressif8266@3.0.0; board: nodemcuv2; framework: arduino)
    Verbose mode can be enabled via `-v, --verbose` option
    CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/nodemcuv2.html
    PLATFORM: Espressif 8266 (3.0.0) > NodeMCU 1.0 (ESP-12E Module)
    HARDWARE: ESP8266 160MHz, 80KB RAM, 4MB Flash
    PACKAGES:
     - framework-arduinoespressif8266 3.30000.210519 (3.0.0)
     - tool-esptool 1.413.0 (4.13)
     - tool-esptoolpy 1.30000.201119 (3.0.0)
     - toolchain-xtensa 2.100200.0 (10.2.0)
    LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
    LDF Modes: Finder ~ chain, Compatibility ~ soft
    Running npm ci...
    npm <command>
    Usage:
    npm install        install all the dependencies in your project
    npm install <foo>  add the <foo> dependency to your project
    npm test           run this project's tests
    npm run <foo>      run the script named <foo>
    npm <command> -h   quick help on <command>
    npm -l             display usage info for all commands
    npm help <term>    search for help on <term>
    npm help npm       more involved overview
    All commands:
        access, adduser, audit, bin, bugs, cache, ci, completion,
        config, dedupe, deprecate, diff, dist-tag, docs, doctor,
        edit, exec, explain, explore, find-dupes, fund, get, help,
        hook, init, install, install-ci-test, install-test, link,
        ll, login, logout, ls, org, outdated, owner, pack, ping,
        pkg, prefix, profile, prune, publish, rebuild, repo,
        restart, root, run-script, search, set, set-script,
        shrinkwrap, star, stars, start, stop, team, test, token,
        uninstall, unpublish, unstar, update, version, view, whoami
    Specify configs in the ini-formatted file:
        /home/so/.npmrc
    or on the command line via: npm <command> --key=value
    More configuration info: npm help config
    Configuration fields: npm help 7 config
    npm@8.1.4 /usr/local/lib/node_modules/npm
    Running npx browserslist@latest --update-db...
    Entering npm script environment at location:
    /home/so/workspace/Ferraris_MQTT_Energy_Counter_Meter_TCRT5000/source/Ferraris_MQTT_Energy_Counter_Meter_TCRT5000/.pio/libdeps/nodemcuv2/ESP8266 IoT Framework/scripts
    Type 'exit' or ^D when finished
     Running npm run build...
    npm <command>
    Usage:
    All commands:
        /home/so/.npmrc
    Found 41 compatible libraries
    Scanning dependencies...
    Dependency Graph
    |-- <ArduinoJson> 6.18.5
    |-- <ESP8266 IoT Framework> 1.9.0
    |   |-- <ESP8266WiFi> 1.0
    |   |-- <ESP8266HTTPClient> 1.2
    |   |-- <DNSServer> 1.1.0
    |   |-- <EEPROM> 1.0
    |   |-- <LittleFS(esp8266)> 0.1.0
    |   |-- <ESP Async WebServer> 1.2.3
    |   |   |-- <ESPAsyncTCP> 1.2.2
    |   |   |-- <Hash> 1.0
    |   |-- <Hash> 1.0
    |-- <PubSubClient> 2.8.0
    Building in debug mode
    warning: Calling missing SConscript without error is deprecated.
    Transition by adding must_exist=False to SConscript calls.
    Missing SConscript 'scripts/preBuild.py'
    File "/home/so/.platformio/penv/lib/python3.8/site-packages/platformio/builder/main.py", line 188, in <module>
    Retrieving maximum program size .pio/build/nodemcuv2/firmware.elf
    Checking size .pio/build/nodemcuv2/firmware.elf
    Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
    RAM:   [======    ]  55.3% (used 45320 bytes from 81920 bytes)
    Flash: [========= ]  89.3% (used 932264 bytes from 1044464 bytes)
    =================================================================== [SUCCESS] Took 6.66 seconds ===================================================================
    EisbaeeerE Offline
    EisbaeeerE Offline
    Eisbaeeer
    schrieb am zuletzt editiert von Eisbaeeer
    #345
    @so Dein Log sieht doch erstmal gut aus. Ich sehe keinen Fehler. Was funktioniert nicht?
    Kein support per PM. Bitte im Forum Fragen stellen!
    • EisbaeeerE Eisbaeeer
      so
      #346
      @eisbaeeer
      EisbaeeerE 2 Antworten Letzte Antwort
      • S so
        @eisbaeeer
        EisbaeeerE Offline
        EisbaeeerE Offline
        Eisbaeeer
        #347
        @so ok, da fehlt tatsächlich der Webserver. Da hat das npm ci nicht funktioniert. Ich teste das morgen mal bei mir. Hab bisher nur auf Windows compiliert.
        • S so
          @eisbaeeer
          EisbaeeerE Offline
          EisbaeeerE Offline
          Eisbaeeer
          #348
          @so Also ich habe das gleiche Phänomen. Scheinbar compiliert er die Webseite mit den Configuration und dashboard items nicht. Das "sudo npm ci" läuft bei mir durch. Kannst du diesbezüglich ein issue aufmachen? https://github.com/maakbaas/esp8266-iot-framework/issues
          Gruß Lars
            Gruß Lars
            so
            #349
            @eisbaeeer
            Okay, hab ein Issue aufgesetzt.
            • C Offline
              chr2002
              #350
              ich habe jetzt echt mal eine Frage : Wie zum Geier funktioniert dieses Ding ? :-)
              Ich habe zuerst versucht, das ganze mit der Lichtschranke in Gang zu bekommen. Leider funktioniert das bei meinem Zähler überhaupt nicht und ich werde wohl ohnehin einen Digitalen bekommen.
              Jetzt habe ich noch einen weiteren Zähler, der hat einen Potenzialfreien S0 Kontakt per Optokoppler. Nun hätte ich versucht, statt des Digital Pins der Lichtschranke das Signal des S0 Kontaktes zu verwenden. Ich Schickte 3,3V zum S0 Eingang vom ESP und gehe vom S0 Ausgang auf den D1 Pin. Aber die Impulse werden nicht erkannt. Auch bringt ein Pulldown nix. Der Pulse Graph macht was er will.
              Von der Lichtschranke kommt doch auch nur ein 3,3V Signal oder ein 0V per Pulldown (auf der Lichtschranke)
              Oder liege ich da falsch.
              Lg Chris
              EisbaeeerE 1 Antwort Letzte Antwort
              • C chr2002
                Lg Chris
                EisbaeeerE Offline
                EisbaeeerE Offline
                Eisbaeeer
                #351
                @chr2002 Hallo Chris. Die Eingänge werden auf Ground gezogen. Versuche mal die Eingänge auf GND zu Brücken, dann solltest du einen Impuls bekommen. Den S0 kannst du mit der Schaltung auch verwenden.
                Gruß Lars
                C 1 Antwort Letzte Antwort
                  Gruß Lars
                  chr2002
                  #352
                  @eisbaeeer Das habe ich auch probiert. Also erst per Pullup gegen 3,3V und GND auf D1.
                  Dann auch mal ohne PullUP. Der Impuls geht mal auf Low, mal nicht. Und manchmal bleibt er auch auf Low, obwohl die Brücke zu gnd raus ist und der 10k Ohm Pullup gegen 3,3V drin ist.
                  • C Offline
                    chr2002
                    #353
                    Oder ist da irgendein check drin, der eine Wartezeit zwischen den Impulsen vorraussetzt. Ich wenn ich eine ganze weile Warte, gibts einen Flankenwechsel. Wenn ich zu kurz hintereinander die Brücke gegen GND mache, passiert nichts. Danach geht aber iwie erstmal gar nichts mehr, auch wenn ich viel später wieder die Brücke setze.
                    • C Offline
                      chr2002
                      #354
                      Ich bekomme den Graphen nichtmal zuverlässig auf LOW oder High, wenn ich eine Brücke setze. Da wird irgendwas wohl noch mit einbezogen. Hiermit geht also kein S0.
                      • C chr2002
                        EisbaeeerE Offline
                        EisbaeeerE Offline
                        Eisbaeeer
                        #355
                        @chr2002 Ähm ja, die Entprellzeit. Stell die mal niedriger, dann sollte das klappen.
                          chr2002
                          #356
                          @eisbaeeer Auch schon probiert :-D Leider ohne Erfolg. Der Graph macht immernoch was er will.
                          • C Offline
                            chr2002
                            schrieb am zuletzt editiert von chr2002
                            #357
                            Ich gebs auf. Hier ist was faul. ESPeasy zählt aber vernünftig. Keine Ahnung, am ESP liegt es nicht. Mit der Lichtschranke kommen auch keine anständigen Impulse zustande. Sehr seltsam. Vllt ist die 0.92 verbuggt ? Kann das sein ?
                            Ich lasse das sein. Und werde eine anständige Wandlermessung hinter den Zähler packen :-D Von dort per Modbus weiter.
                            • C chr2002
                              Dan.Master
                              schrieb am zuletzt editiert von Dan.Master
                              #358
                              @Eisbaeeer
                              Hallo Lars,
                              ich bin mal ein bisschen durch deinen Code gegangen.
                              Ich baue gerade einen Ferraris Zähler mit Analogauswertung via Maxim MAX127 ADC mit 12Bit mit "programmierbarer" Hysterese auf der Basis deines Codes. Ich bin auch bei 80% des Projekts
                              Grund:
                              Ich hatte in der Vergangenheit das Problem das sich zwei ESP Wemos D1 nach 3-4 Monaten nicht mehr gemeldet haben. Nach neu flashen ging es immer so ein paar Wochen und später meldete sich der ganz Kram auch nach Neustart nicht.
                              Wenn ich das ja soweit verstanden habe wir ja quasi in den "EEPROM" geschrieben den der ESP aber nicht hat und das durch den Flash emuliert wird.
                              Die macht der ja über die beiden JSON "Strukturen" dash und configuration .
                              Soweit ich das jetzt Überblicke wird bei jedem Impuls und neuem kW und bei der MQTT übertragen daten in den Flash geschrieben.
                              Somit haben wir ja nach 2-3 Monaten die sicheren Schreibzyklen von (100.000) mal erreicht und haben das Risiko eines Speicherschädigung.
                              Bei einer Schreibzeit alle 30s wären es 720 Zyklen am Tag. 100.000/720 = 138,8 Tage.
                              Oder liege ich mit den häufigen Schreibzyklen auf dem falschem Weg?
                              Ich habe die Quellen bzw die Beschreibung der Libs für des Dashboard.h und configuaration.h leider nicht auf Anhieb gefunden.
                              Aber vielleicht liebe ich da auf dem Holzweg.
                              Ich habe den Sinn der ProcInput1-4() Routinen nicht ganz verstanden mit array und modulo. Wozu hast du die mit im Programm?
                              DerDani
                              EisbaeeerE ? 2 Antworten Letzte Antwort
                              • D Dan.Master
                                @Eisbaeeer
                                Hallo Lars,
                                Grund:
                                DerDani
                                EisbaeeerE Offline
                                EisbaeeerE Offline
                                Eisbaeeer
                                #359
                                @dan-master sagte in Ferraris Zähler mit TCRT5000 und esp8266:
                                @Eisbaeeer
                                Hallo Lars,
                                Ja, das EEPROM wird emuliert und im flash gespeichert. ABER ich speichere nur bei vollen KWh ab. Ich habe dir mal die Stellen markiert:
                                Schau mal im Code nach "saveconfig", nur dann wird gespeichert.
                                Gruß Lars
                                • D Dan.Master
                                  @Eisbaeeer
                                  Hallo Lars,
                                  Grund:
                                  DerDani
                                  #360
                                  Grund:
                                  DerDani
                                  Wie macht man das denn?
                                  btw....Ich nutze aber eine eigens compillierte und abgespeckte ESPeasy Version für den Counter.....mit 160 MHz Tacktung
                                  Von 9 D1 Mini und 2 NodeMCU ist mir bis Dato noch keiner abgeraucht.
                                  Alle mit Tasmota und ESPeasy geflasht....einer ist noch im Testmode mit ESPhome.
                                  Irgendwas muss ich wohl falsch machen......😁
                                    klassisch
                                    schrieb am zuletzt editiert von klassisch
                                    #361
                                    Wemos D1 Mini, Beispiel mit selbstgefrickeltem Programm:
                                    Betriebszeit: 1241 17:01:49 (Tage Std:Min:Sek)
                                    Man bekommt viele Clones mit unterschiedlicher Qualität.
                                    Also erst mal die Lötvebindungen zwischen Modul und Platine inspizieren und oft einfach alle nachlöten.
                                    Dann IMMER noch einen 1000µF Kondensator parallel zu den 3.3V und meist auch einen parallel zu den 5V. Im Notfall noch einen 10µF Cerco dirakt an die 3.3V am Modul zum Gehäuse.
                                    Dann laufen die jahrelang stabil.
                                    Was manchmal vorkommt: Wenn die Funkverbindung schlecht wird, gibt es bei manchen Programmen Neustarts.
                                    Einen ESP32 habe ich tatsächlich verloren. Der war immer nach einigen Stunden weg.
                                    Ansonsten laufen die 8266 D1 Mini recht rund. Mit selbstgefrickelter SW, ESPEasy, ESPHome, Tasmota.
                                    ? D 2 Antworten Letzte Antwort
                                    • K klassisch
                                      #362
                                      @klassisch , ich bestelle auch immer beim Händler des Vertrauens....hier in DE.
                                      ....auch mein China Mann schickt kostenlosen Ersatz. Das hatte ich mal bei einem CC1001....der schickte mir dann gleich drei Stück nach.
                                      Da habe ich bei ihm eine glückliche Hand gehabt.....
                                        #363
                                        Inzwischen habe ich eine -43 dBm Verbindung zum Zählerschrank.....
                                        Da brauche ich mir keine Sorgen machen.....
                                          klassisch
                                          #364
                                          @menne Sauber! Da ist mein Zählerschrank spartanisch. Altes Metallgehäuse ohne Platzreserven.
                                          Und nur noch dee Lesekopf für die "moderne Meßeinrichtung" mit einer Ethernet Flachband-Fensterdurchführung durch den Spalt an der Metalltür und dann via RS485 durchs Haus bis zum RS485 <-> Ethernet-Wandler.
