  4. [Gelöst]Fehler der JS-Instanz nach JS-Controller Update
12 Beiträge 4 Kommentatoren 1.7k Aufrufe 3 Beobachtet
  • R robson
    ich habe heute mein ioBroker System (v5.1.25) auf die aktuellste (mir angezeigte) Version des JS-Controllers (3.3.21) aktualisiert.
    Nach dem Update lässt sich nun die Javascript-Instanz nicht mehr starten und wirft folgende Fehler ins Protokoll:
    host.ioBroker-RasPi4
    2021-12-04 13:55:16.506	info	Restart adapter system.adapter.javascript.0 because enabled
    2021-12-04 13:55:16.506	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2021-12-04 13:55:16.505	error	Caught by controller[0]: }
    2021-12-04 13:55:16.505	error	Caught by controller[0]: ]
    2021-12-04 13:55:16.505	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
    2021-12-04 13:55:16.505	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
    2021-12-04 13:55:16.505	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
    2021-12-04 13:55:16.505	error	Caught by controller[0]: requireStack: [
    2021-12-04 13:55:16.504	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    2021-12-04 13:55:16.504	error	Caught by controller[0]: {
    2021-12-04 13:55:16.504	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
    2021-12-04 13:55:16.504	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
    2021-12-04 13:55:16.504	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    2021-12-04 13:55:16.504	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    2021-12-04 13:55:16.503	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    2021-12-04 13:55:16.503	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    2021-12-04 13:55:16.503	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
    2021-12-04 13:55:16.503	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    2021-12-04 13:55:16.503	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    2021-12-04 13:55:16.503	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    2021-12-04 13:55:16.502	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    2021-12-04 13:55:16.502	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    2021-12-04 13:55:16.502	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    2021-12-04 13:55:16.502	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
    2021-12-04 13:55:16.502	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    2021-12-04 13:55:16.502	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    2021-12-04 13:55:16.502	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    2021-12-04 13:55:16.501	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    2021-12-04 13:55:16.501	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    2021-12-04 13:55:16.501	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    2021-12-04 13:55:16.501	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
    2021-12-04 13:55:16.501	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    2021-12-04 13:55:16.500	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    2021-12-04 13:55:16.500	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    2021-12-04 13:55:16.500	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
    2021-12-04 13:55:16.500	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
    2021-12-04 13:55:16.500	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
    2021-12-04 13:55:16.500	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
    2021-12-04 13:55:16.499	error	Caught by controller[0]: Require stack:
    2021-12-04 13:55:16.499	error	Caught by controller[0]: Error: Cannot find module 'typescript'
    2021-12-04 13:55:16.499	error	Caught by controller[0]: ^
    2021-12-04 13:55:16.499	error	Caught by controller[0]: throw err;
    2021-12-04 13:55:16.498	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
    2021-12-04 13:55:16.032	info	instance system.adapter.javascript.0 started with pid 13431
    Ein Restore hat zwar funktioniert, jedoch ist immer noch die Hostversion 3.3.21 installiert und der Adapter funktioniert weiterhin nicht.
    Vor dem Upgrade hatte ich keine Probleme. Das System lief monatelang problemlos.
    Kann jemand was mit den Fehlermeldungen anfangen? Kann ich die JS-Controller Version wieder downgraden (leider weiß ich nicht mehr, welches die vorherige Version war)?
    Über Ratschläge wäre ich sehr dankbar.
    //edit: Protokoll-Eintrag erweitert
    @robson
    Unten anfangen.
    NodeJS sauber im System?
    iobroker update -i
    iobroker list instances
    which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    R 1 Antwort Letzte Antwort
      @robson
      Unten anfangen.
      iobroker update -i
      robson
      Danke.
      NodeJS finde ich beim Ausführen der Befehle nicht (s. unten). Aber hier werden doch auch nur die installierten Adapter und Instanzen angezeigt, korrekt?
      Den dritten Befehl habe ich ebenfalls ausgeführt und iobroker neugestartet. Leider keine Veränderung. Die Fehlermeldung (s. erster Beitrag) bleibt bestehen.
      iobroker update -i
      Used repository: stable
      hash unchanged, use cached sources
      update done
      Adapter    "admin"         : 5.1.25   , installed 5.1.25
      Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
      Adapter    "backitup"      : 2.2.2    , installed 2.2.2
      Adapter    "cloud"         : 4.1.0    , installed 4.1.0
      Adapter    "devices"       : 1.0.9    , installed 1.0.9
      Adapter    "discovery"     : 2.7.3    , installed 2.7.3
      Adapter    "easee"         : 1.0.5    , installed 1.0.5
      Adapter    "fb-checkpresence": 1.1.10  , installed 1.1.10
      Adapter    "flot"          : 1.10.7   , installed 1.10.7
      Adapter    "followthesun"  : 0.3.5    , installed 0.3.5
      Adapter    "fullybrowser"  : 2.0.9    , installed 2.0.9
      Adapter    "harmony"       : 1.2.2    , installed 1.2.2
      Adapter    "heatingcontrol": 2.7.2    , installed 2.7.2
      Adapter    "history"       : 1.9.13   , installed 1.9.13
      Adapter    "hm-rega"       : 3.0.32   , installed 3.0.32
      Adapter    "hm-rpc"        : 1.14.45  , installed 1.14.45
      Adapter    "ical"          : 1.11.4   , installed 1.11.4
      Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
      Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
      Adapter    "info"          : 1.9.8    , installed 1.9.8
      Adapter    "iot"           : 1.8.24   , installed 1.8.24
      Adapter    "javascript"    : 5.2.13   , installed 5.2.13
      Controller "js-controller" : 3.3.21   , installed 3.3.21
      Adapter    "netatmo-crawler": 0.6.0   , installed 0.6.0
      Adapter    "ping"          : 1.5.0    , installed 1.5.0
      Adapter    "schoolfree"    : 1.0.0    , installed 1.0.0
      Adapter    "shelly"        : 4.0.7    , installed 4.0.7
      Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
      Adapter    "socketio"      : 3.1.4    , installed 3.1.4
      Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
      Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
      Adapter    "telegram"      : 1.10.0   , installed 1.10.0
      Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
      Adapter    "trashschedule" : 1.2.0    , installed 1.2.0
      Adapter    "vis"           : 1.4.5    , installed 1.4.5
      Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
      Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
      Adapter    "volvo"         : 0.0.6    , installed 0.0.6
      Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
      Adapter    "web"           : 3.4.9    , installed 3.4.9
      Adapter    "wolf"          : 1.2.1    , installed 1.2.1
      Adapter    "worx"          : 1.5.5    , installed 1.5.5
      Adapter    "yr"            : 3.0.5    , installed 3.0.5
      + system.adapter.admin.0                  : admin                 : ioBroker-RasPi4                          -  enabled, port: 8081, bind: 0.0.0.0        (SSL), run as: admin
      + system.adapter.alexa2.0                 : alexa2                : ioBroker-RasPi4                          -  enabled
      + system.adapter.backitup.0               : backitup              : ioBroker-RasPi4                          -  enabled
      + system.adapter.cloud.0                  : cloud                 : ioBroker-RasPi4                          -  enabled
        system.adapter.devices.0                : devices               : ioBroker-RasPi4                          - disabled
      + system.adapter.discovery.0              : discovery             : ioBroker-RasPi4                          -  enabled
      + system.adapter.easee.0                  : easee                 : ioBroker-RasPi4                          -  enabled
        system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker-RasPi4                          - disabled
        system.adapter.flot.0                   : flot                  : ioBroker-RasPi4                          - disabled
        system.adapter.followthesun.0           : followthesun          : ioBroker-RasPi4                          - disabled
        system.adapter.fullybrowser.0           : fullybrowser          : ioBroker-RasPi4                          - disabled
        system.adapter.harmony.0                : harmony               : ioBroker-RasPi4                          - disabled
        system.adapter.heatingcontrol.0         : heatingcontrol        : ioBroker-RasPi4                          - disabled
        system.adapter.history.0                : history               : ioBroker-RasPi4                          - disabled
      + system.adapter.hm-rega.0                : hm-rega               : ioBroker-RasPi4                          -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-RasPi4                          -  enabled, port: 12001
      + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-RasPi4                          -  enabled, port: 12010
        system.adapter.ical.0                   : ical                  : ioBroker-RasPi4                          -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-RasPi4                          - disabled
      + system.adapter.info.0                   : info                  : ioBroker-RasPi4                          -  enabled
      + system.adapter.iot.0                    : iot                   : ioBroker-RasPi4                          -  enabled
      + system.adapter.iot.1                    : iot                   : ioBroker-RasPi4                          -  enabled
        system.adapter.javascript.0             : javascript            : ioBroker-RasPi4                          -  enabled
        system.adapter.javascript.1             : javascript            : ioBroker-RasPi4                          - disabled
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : ioBroker-RasPi4                          -  enabled
      + system.adapter.ping.0                   : ping                  : ioBroker-RasPi4                          -  enabled
      + system.adapter.schoolfree.0             : schoolfree            : ioBroker-RasPi4                          -  enabled
        system.adapter.shelly.0                 : shelly                : ioBroker-RasPi4                          - disabled, port: 1882, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : ioBroker-RasPi4                          - disabled, port: 8087, bind: 192.168        .178.11, run as: admin
        system.adapter.socketio.0               : socketio              : ioBroker-RasPi4                          - disabled, port: 8084, bind: 0.0.0.0        , run as: admin
      + system.adapter.sonoff.0                 : sonoff                : ioBroker-RasPi4                          -  enabled, port: 1883, bind: 192.168        .178.11
      + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker-RasPi4                          -  enabled
      + system.adapter.telegram.0               : telegram              : ioBroker-RasPi4                          -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : ioBroker-RasPi4                          -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : ioBroker-RasPi4                          -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-RasPi4                          - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-RasPi4                          - disabled
        system.adapter.vis.0                    : vis                   : ioBroker-RasPi4                          -  enabled
        system.adapter.volvo.0                  : volvo                 : ioBroker-RasPi4                          - disabled
        system.adapter.weatherunderground.0     : weatherunderground    : ioBroker-RasPi4                          -  enabled
        system.adapter.web.0                    : web                   : ioBroker-RasPi4                          -  enabled, port: 443, bind: 0.0.0.0        (SSL), run as: admin
        system.adapter.wolf.0                   : wolf                  : ioBroker-RasPi4                          -  enabled, port: 12004, bind: 0.0.0.        0
        system.adapter.worx.0                   : worx                  : ioBroker-RasPi4                          - disabled
      + system.adapter.yr.0                     : yr                    : ioBroker-RasPi4                          -  enabled
      + instance is alive
      R crunchipC 2 Antworten Letzte Antwort
      • R robson
        Danke.
        iobroker update -i
        update done
        + instance is alive
        robson
        Protokoll-Eintrag im ersten Post erweitert.
        • R Offline
          robson
          Der Befehl
          gibt mir folgende Ausgabe:
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v12.22.1
          v12.22.1
          6.14.12
          OK:1 http://archive.raspberrypi.org/debian buster InRelease
          OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
          OK:3 https://deb.nodesource.com/node_12.x buster InRelease
          Aktualisierung für 159 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
          nodejs:
            Installiert:           12.22.1-1nodesource1
            Installationskandidat: 12.22.7-deb-1nodesource1
            Versionstabelle:
               12.22.7-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
           *** 12.22.1-1nodesource1 100
               10.24.0~dfsg-1~deb10u1 500
          iob fix
          habe ich abschließend ebenfalls noch mal ausgeführt.
          • R robson
            Danke.
            iobroker update -i
            update done
            + instance is alive
            crunchipC Offline
            crunchipC Offline
            @robson sagte in Fehler der JS-Instanz nach JS-Controller Update auf 3.3.21:
            dann sind auch keine Befehle um das System zu reparieren, sondern zeigen den aktuellen Stand
            deine javascript instanz läuft gar nicht
            typescript nachinstallieren
            • R robson
              GlasfaserG Offline
              GlasfaserG Offline
              https://forum.iobroker.net/topic/46983/gelöst-javascript-startet-nicht-mehr-nach-update/5
              • R robson
                Der Befehl
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v12.22.1
                v12.22.1
                6.14.12
                nodejs:
                  Versionstabelle:
                iob fix
                Unabhänig vom aktuellen Problem:
                Halt die Kiste auf Stand...
                Bei nächster Gelegenheit (bald!!!)
                iobroker stop
                sudo apt update
                sudo apt dist-upgrade
                sudo reboot
                  iobroker stop
                  sudo apt update
                  sudo reboot
                  robson
                  schrieb am zuletzt editiert von robson
                  Das wichtigste vorweg: vielen Dank an @Thomas-Braun, @Glasfaser und @crunchip!
                  Aber der Reihe nach.
                  1.
                  Die Befehle:
                  iobroker del javascript
                  iobroker install javascript
                  aus dem von @Glasfaser verlinkten Thread haben geholfen. Ein Rebuild war nicht genug.
                  2.
                  @crunchip sagte in Fehler der JS-Instanz nach JS-Controller Update auf 3.3.21:
                  Warum muss so etwas nach nachinstalliert werden, wenn es doch monatelang funktioniert hat? Nur interessenhalber.
                  3.
                  @thomas-braun sagte in Fehler der JS-Instanz nach JS-Controller Update auf 3.3.21:
                  iobroker stop
                  sudo apt update
                  sudo reboot
                  Danke für den Hinweis. Ich bin leider selten auf der Konsole unterwegs. Kann ich das auch irgendwo im ioBroker selbst einsehen? Da sieht für mich alles grün und aktuell aus.
                  • R robson
                    1.
                    Die Befehle:
                    2.
                    3.
                    iobroker stop
                    sudo apt update
                    sudo reboot
                    Nein, der ioBroker kümmert sich nicht um das zugrunde liegende Betriebssystem.
                    Das musst du schon selber machen.
                    • R robson
                      1.
                      Die Befehle:
                      2.
                      3.
                      iobroker stop
                      sudo apt update
                      sudo reboot
                      @robson
                      Warum sind da eigentlich zwei Instanzen vom javascript anlegt?
                      Ich würde das System immer so simpel wie möglich halten. Für eine zweite Instanz würde ich jetzt beim javascript keinen Grund sehen. Lösch die javascript.1 raus.
                        @robson
                        robson
                        @robson
                        Die nutze ich für Experimentier-Skripte. Die Instanz schalte ich nur an, wenn ich beim Skripten was testen möchte. Danach ist sie wieder deaktiviert.
                        Alle stabilen Skripte laufen auf der .0-Instanz.
