  4. Zigbee Adapter - Pairing findet keine Geräte
    6.3k
13 Beiträge 3 Kommentatoren 811 Aufrufe 3 Beobachtet
    @deriobroker sagte in Zigbee Adapter - Pairing findet keine Geräte:
    Hat einer eine Idee?
    Ohne ein Log File nicht.
    deriobroker
    schrieb am zuletzt editiert von deriobroker
    021-11-27 18:32:28.173 - info: host.iobroker instance system.adapter.zigbee.0 started with pid 6267
    2021-11-27 18:32:30.878 - debug: zigbee.0 (6267) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2021-11-27 18:32:30.914 - debug: zigbee.0 (6267) Objects client ready ... initialize now
    2021-11-27 18:32:30.916 - debug: zigbee.0 (6267) Objects create System PubSub Client
    2021-11-27 18:32:30.917 - debug: zigbee.0 (6267) Objects create User PubSub Client
    2021-11-27 18:32:30.918 - debug: zigbee.0 (6267) Objects client initialize lua scripts
    2021-11-27 18:32:30.935 - debug: zigbee.0 (6267) Objects connected to redis: 0.0.0.0:9001
    2021-11-27 18:32:30.945 - debug: zigbee.0 (6267) objectDB connected
    2021-11-27 18:32:30.947 - debug: zigbee.0 (6267) Redis States: Use Redis connection: 0.0.0.0:9000
    2021-11-27 18:32:30.958 - debug: zigbee.0 (6267) States create System PubSub Client
    2021-11-27 18:32:30.959 - debug: zigbee.0 (6267) States create User PubSub Client
    2021-11-27 18:32:30.971 - debug: zigbee.0 (6267) States connected to redis: 0.0.0.0:9000
    2021-11-27 18:32:30.972 - debug: zigbee.0 (6267) statesDB connected
    2021-11-27 18:32:31.280 - debug: zigbee.0 (6267) Plugin sentry Do not initialize Plugin (enabled=false)
    2021-11-27 18:32:31.290 - debug: zigbee.0 (6267) Plugin sentry destroyed because not initialized correctly
    2021-11-27 18:32:31.298 - info: zigbee.0 (6267) starting. Version 1.6.7 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.7, js-controller: 3.3.20
    2021-11-27 18:32:31.339 - debug: zigbee.0 (6267) Using zigbee-herdsman with settings: {"network":{"panID":6755,"extendedPanID":[138,253,173,54,202,78,217,155],"channelList":[11],"networkKey":[220,225,164,223,95,203,10,5,174,195,38,179,49,95,198,172]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
    2021-11-27 18:32:31.398 - info: zigbee.0 (6267) Starting Zigbee npm ...
    2021-11-27 18:32:31.400 - debug: zigbee.0 (6267) Starting zigbee-herdsman...
    2021-11-27 18:32:31.943 - info: zigbee.0 (6267) Installed Version: ioBroker/ioBroker.zigbee
    2021-11-27 18:32:31.957 - debug: zigbee.0 (6267) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2021_11_27-18_32_31.tar.gz success
    2021-11-27 18:32:31.969 - debug: zigbee.0 (6267) zigbee-herdsman started
    2021-11-27 18:32:31.974 - info: zigbee.0 (6267) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
    2021-11-27 18:32:31.998 - debug: zigbee.0 (6267) Zigbee network parameters: panID=6755 channel=11 extendedPanID=(ausgeblendet)
    2021-11-27 18:32:31.999 - info: zigbee.0 (6267) Unable to disable LED, unsupported function.
    2021-11-27 18:32:32.000 - info: zigbee.0 (6267) --> transmitPower : normal
    2021-11-27 18:32:32.001 - info: zigbee.0 (6267) Unable to set transmit power, unsupported function.
    2021-11-27 18:32:32.003 - info: zigbee.0 (6267) Currently no devices.
    2021-11-27 18:32:32.004 - info: zigbee.0 (6267) Zigbee started
    2021-11-27 18:32:34.439 - debug: zigbee.0 (6267) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
    2021-11-27 18:32:34.448 - debug: zigbee.0 (6267) getGroups result: {}
    2021-11-27 18:32:34.449 - debug: zigbee.0 (6267) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
    2021-11-27 18:32:34.467 - debug: zigbee.0 (6267) LQI succeeded for 'Coordinator'
    2021-11-27 18:32:34.495 - debug: zigbee.0 (6267) getCoorinatorInfo result: {"installSource":"ioBroker/ioBroker.zigbee","channel":"11","port":"/dev/ttyACM0","type":"ConBee2/RaspBee2","revision":"0x26720700","version":"0-0.38.114.0."}
    2021-11-27 18:32:34.496 - debug: zigbee.0 (6267) sendTo "getCoordinatorInfo" to system.adapter.admin.0 from system.adapter.zigbee.0
    2021-11-27 18:32:34.507 - debug: zigbee.0 (6267) Routing for 'Coordinator': {"table":[]}
    2021-11-27 18:32:34.508 - debug: zigbee.0 (6267) Routing table succeeded for 'Coordinator'
    2021-11-27 18:32:34.508 - debug: zigbee.0 (6267) Get map succeeded []
    2021-11-27 18:32:34.509 - debug: zigbee.0 (6267) getMap result: {"lqis":[],"routing":[]}
    2021-11-27 18:32:34.510 - debug: zigbee.0 (6267) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
    2021-11-27 18:32:34.627 - debug: zigbee.0 (6267) List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyAMA0"}]
    2021-11-27 18:32:34.628 - debug: zigbee.0 (6267) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
    2021-11-27 18:32:34.650 - debug: zigbee.0 (6267) getDevices result: [{"_id":"0x00212effff077c8a","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff077c8a","_networkAddress":0,"_manufacturerID":0,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":3,"profileID":261,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":10,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[1281],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":null},"mapped":null,"endpoint":{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},"endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":3,"profileID":261,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":10,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[1281],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"name":"0x00212effff077c8a"},"common":{},"native":{}}]
    2021-11-27 18:32:34.651 - debug: zigbee.0 (6267) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
    2021-11-27 18:32:34.703 - debug: zigbee.0 (6267) getExclude result: []
    2021-11-27 18:32:34.704 - debug: zigbee.0 (6267) getBinding result: []
    2021-11-27 18:32:34.705 - debug: zigbee.0 (6267) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
    2021-11-27 18:32:34.714 - debug: zigbee.0 (6267) sendTo "getExclude" to system.adapter.admin.0 from system.adapter.zigbee.0
    2021-11-27 18:32:37.185 - info: zigbee.0 (6267) Zigbee: allowing new devices to join.
    2021-11-27 18:32:37.187 - debug: zigbee.0 (6267) sendTo "letsPairing" to system.adapter.admin.0 from system.adapter.zigbee.0: Start pairing!
    2021-11-27 18:33:38.462 - info: zigbee.0 (6267) Zigbee: stop joining
    • D deriobroker
      @deriobroker
      Die PAN-Id prüfen, das sieht komisch aus.
        @deriobroker
        deriobroker
        Ich habe die Pan-ID noch einmal auf 16x D zurückgesetzt als auch eine eigene generiert:
        2021-11-27 20:27:00.959 - info: host.iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2021-11-27 20:27:01.045 - info: zigbee.0 (10137) Got terminate signal TERMINATE_YOURSELF
        2021-11-27 20:27:01.046 - info: host.iobroker stopInstance system.adapter.zigbee.0 send kill signal
        2021-11-27 20:27:01.047 - info: zigbee.0 (10137) cleaned everything up...
        2021-11-27 20:27:01.049 - info: zigbee.0 (10137) Zigbee: disabling joining new devices.
        2021-11-27 20:27:01.531 - info: zigbee.0 (10137) terminating
        2021-11-27 20:27:01.532 - info: zigbee.0 (10137) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-11-27 20:27:02.053 - info: host.iobroker stopInstance system.adapter.zigbee.0 killing pid 10137
        2021-11-27 20:27:02.203 - info: host.iobroker instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2021-11-27 20:27:04.084 - info: host.iobroker instance system.adapter.zigbee.0 started with pid 10269
        2021-11-27 20:27:06.728 - debug: zigbee.0 (10269) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2021-11-27 20:27:06.774 - debug: zigbee.0 (10269) Objects client ready ... initialize now
        2021-11-27 20:27:06.776 - debug: zigbee.0 (10269) Objects create System PubSub Client
        2021-11-27 20:27:06.777 - debug: zigbee.0 (10269) Objects create User PubSub Client
        2021-11-27 20:27:06.778 - debug: zigbee.0 (10269) Objects client initialize lua scripts
        2021-11-27 20:27:06.795 - debug: zigbee.0 (10269) Objects connected to redis: 0.0.0.0:9001
        2021-11-27 20:27:06.805 - debug: zigbee.0 (10269) objectDB connected
        2021-11-27 20:27:06.807 - debug: zigbee.0 (10269) Redis States: Use Redis connection: 0.0.0.0:9000
        2021-11-27 20:27:06.817 - debug: zigbee.0 (10269) States create System PubSub Client
        2021-11-27 20:27:06.819 - debug: zigbee.0 (10269) States create User PubSub Client
        2021-11-27 20:27:06.831 - debug: zigbee.0 (10269) States connected to redis: 0.0.0.0:9000
        2021-11-27 20:27:06.832 - debug: zigbee.0 (10269) statesDB connected
        2021-11-27 20:27:07.069 - debug: zigbee.0 (10269) Plugin sentry Do not initialize Plugin (enabled=false)
        2021-11-27 20:27:07.078 - debug: zigbee.0 (10269) Plugin sentry destroyed because not initialized correctly
        2021-11-27 20:27:07.086 - info: zigbee.0 (10269) starting. Version 1.6.7 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.7, js-controller: 3.3.20
        2021-11-27 20:27:07.130 - debug: zigbee.0 (10269) Using zigbee-herdsman with settings: {"network":{"panID":6753,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[220,225,164,223,95,203,10,5,174,195,38,179,49,95,198,172]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"deconz"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
        2021-11-27 20:27:07.195 - info: zigbee.0 (10269) Starting Zigbee npm ...
        2021-11-27 20:27:07.196 - debug: zigbee.0 (10269) Starting zigbee-herdsman...
        2021-11-27 20:27:07.690 - info: zigbee.0 (10269) Installed Version: ioBroker/ioBroker.zigbee
        2021-11-27 20:27:07.710 - debug: zigbee.0 (10269) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2021_11_27-20_27_07.tar.gz success
        2021-11-27 20:27:07.723 - debug: zigbee.0 (10269) zigbee-herdsman started
        2021-11-27 20:27:07.728 - info: zigbee.0 (10269) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":114,"maintrel":0,"revision":"0x26720700"}}
        2021-11-27 20:27:07.748 - debug: zigbee.0 (10269) Zigbee network parameters: panID=6753 channel=11 extendedPanID=dddddddddddddddd
        2021-11-27 20:27:07.749 - info: zigbee.0 (10269) Unable to disable LED, unsupported function.
        2021-11-27 20:27:07.750 - info: zigbee.0 (10269) --> transmitPower : normal
        2021-11-27 20:27:07.751 - info: zigbee.0 (10269) Unable to set transmit power, unsupported function.
        2021-11-27 20:27:07.752 - info: zigbee.0 (10269) Currently no devices.
        2021-11-27 20:27:07.753 - info: zigbee.0 (10269) Zigbee started
        2021-11-27 20:27:47.932 - debug: zigbee.0 (10269) sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
        2021-11-27 20:27:47.941 - debug: zigbee.0 (10269) getGroups result: {}
        2021-11-27 20:27:47.942 - debug: zigbee.0 (10269) sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
        2021-11-27 20:27:47.962 - debug: zigbee.0 (10269) LQI succeeded for 'Coordinator'
        2021-11-27 20:27:47.974 - debug: zigbee.0 (10269) getCoorinatorInfo result: {"installSource":"ioBroker/ioBroker.zigbee","channel":"11","port":"/dev/ttyACM0","type":"ConBee2/RaspBee2","revision":"0x26720700","version":"0-0.38.114.0."}
        2021-11-27 20:27:47.975 - debug: zigbee.0 (10269) sendTo "getCoordinatorInfo" to system.adapter.admin.0 from system.adapter.zigbee.0
        2021-11-27 20:27:47.979 - debug: zigbee.0 (10269) Routing for 'Coordinator': {"table":[]}
        2021-11-27 20:27:47.980 - debug: zigbee.0 (10269) Routing table succeeded for 'Coordinator'
        2021-11-27 20:27:47.981 - debug: zigbee.0 (10269) Get map succeeded []
        2021-11-27 20:27:47.982 - debug: zigbee.0 (10269) getMap result: {"lqis":[],"routing":[]}
        2021-11-27 20:27:47.983 - debug: zigbee.0 (10269) sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
        2021-11-27 20:27:48.118 - debug: zigbee.0 (10269) List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyAMA0"}]
        2021-11-27 20:27:48.119 - debug: zigbee.0 (10269) sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
        2021-11-27 20:27:48.222 - debug: zigbee.0 (10269) getDevices result: [{"_id":"0x00212effff077c8a","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff077c8a","_networkAddress":0,"_manufacturerID":0,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":3,"profileID":261,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":10,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[1281],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":null},"mapped":null,"endpoint":{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},"endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":3,"profileID":261,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":10,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[1281],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff077c8a","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"name":"0x00212effff077c8a"},"common":{},"native":{}}]
        2021-11-27 20:27:48.223 - debug: zigbee.0 (10269) sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
        2021-11-27 20:27:48.325 - debug: zigbee.0 (10269) getExclude result: []
        2021-11-27 20:27:48.329 - debug: zigbee.0 (10269) getBinding result: []
        2021-11-27 20:27:48.330 - debug: zigbee.0 (10269) sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
        2021-11-27 20:27:48.376 - debug: zigbee.0 (10269) sendTo "getExclude" to system.adapter.admin.0 from system.adapter.zigbee.0
        2021-11-27 20:27:50.609 - info: zigbee.0 (10269) Zigbee: allowing new devices to join.
        2021-11-27 20:27:50.611 - debug: zigbee.0 (10269) sendTo "letsPairing" to system.adapter.admin.0 from system.adapter.zigbee.0: Start pairing!
        2021-11-27 20:28:51.931 - info: zigbee.0 (10269) Zigbee: stop joining
        Leider keine Änderung. Die Log deckt den Zeitraum vom Start des Adapters bis zum Ende des Pairingvorgangs ab.
        • D deriobroker
          Das schaut komisch aus. Bei mir steht da die PAN-Id.
          Stell das auf /dev/serial/by-id/GERÄTEDATEI um.
            crunchipC Abwesend
            crunchipC Abwesend
            @thomas-braun muss dazu nicht vorher der Ordner gelöscht werden
            rm -R /opt/iobroker/iobroker-data/zigbee.0/
            und PanID dddddddd.... soll man nicht mehr verwenden
            Thomas BraunT D 2 Antworten Letzte Antwort
              @crunchip sagte in Zigbee Adapter - Pairing findet keine Geräte:
              Keine Ahnung. Musste ich bei mir noch nie löschen.
                crunchipC Abwesend
                crunchipC Abwesend
                @thomas-braun muss/sollte man zumindest bei einem Stickwechsel und dies sei ja schliesslich gegeben, wenn er vorher einen anderen versucht hatte, zu installieren
                Da es mit einem CC2531 schon nicht geklappt hat, habe ich mir einen Conbee 2 gekauft
                  @crunchip
                  Okay.
                  Mein Wechsel von einem raspbee1 auf einen USB-Stick ging ohne.
                    deriobroker
                    @crunchip Ich habe den Ordner vorhin auch mal gelöscht, da der Adapter dort scheinbar auch Backups anlegt. Da das Pairing auf dem Gerät aber noch nie geklappt hat, habe ich den Ordner vorsichtshalber auch mal geleert.
                    DDDDDDDDDDDDDDDD habe ich nur beim 2. Versuch nach der Neuinstallation drin gelassen.
                    Also: Adapter deinstallieren, Stick abstecken, Ordner löschen, Stick einstecken, Adapter installieren, einrichten, Adapter starten, Pairing... das sind die Schritte, die ich jetzt mehrmals probiert habe.
                    Edit: Nach Stick 1 habe ich den Raspberry neu aufgesetzt.
                    Das sind die aktuellen Werte.
                    • D deriobroker
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @deriobroker zu conbee kann ich dir nichts sagen, vllt mal entsprechende Threads im Forum suchen
                        deriobroker
                        @crunchip Ich finde dazu einfach nichts. Ich kann es mir auch nicht erklären, da der Stick an einem anderen iobroker Host ja ohne Probleme funktioniert.
                        Aber danke für deine Hilfe!
                        Edit: Ich habe jetzt auf einem dritten Raspberry erneut den iobroker samt Zigbee Adapter installiert. Das Pairing klappt auf Anhieb. Ich glaube ich setze das System noch einmal komplett zurück...
                        Trotzdem wäre es interessant zu wissen, warum es letztendlich nicht funktioniert.
