  4. Adapterupdates nicht möglich
52 Beiträge 6 Kommentatoren 5.5k Aufrufe 4 Beobachtet
    Tjaden
    ich habe gerade ein Update für Nodejs gemacht (da der Alexa2-Adapter dies forderte) und kann nun keinerlei Adapterupdates mehr installieren. Egal ob Admin, Alexa2, Broadlink2 usw.
    Exemplarisch hier die Meldung beim Versuch vom Update des Alexa2-Adapters:
    $ iobroker upgrade alexa2@3.11.2
    Update alexa2 from @3.9.3 to @3.11.2
    NPM version: 8.1.4
    npm install iobroker.alexa2@3.11.2 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    npm ERR! code E404
    npm ERR! 404 Not Found - GET https://codeload.github.com/homeinstalator/syno/legacy.tar.gz/masternpm ERR! 404 npm ERR! 404 'syno@https://github.com/homeinstalator/syno/tarball/master/' is not in this registry.npm ERR! 404 You should bug the author to publish it (or use the name yourself!)npm ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
    npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2021-11-27T15_51_13_330Z-debug.log
    upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
    upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
    upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
    upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
    upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
    upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
    upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
    upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
    upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
    upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
    upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
    upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
    upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
    upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
    upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot.png icons/echo_dot.png image/png
    upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo4.png icons/echo4.png image/png
    upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo2.png icons/echo2.png image/png
    upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo.png icons/echo.png image/png
    upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo-input.png icons/echo-input.png image/png
    upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/apps.png icons/apps.png image/png
    upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
    Adapter "alexa2" updated
    Process exited with code 0
    Auch wenn am Ende "Adapter "alexa2" updated" steht, so bleibt der Adapter doch bei der alten Version – auch nach Neustart des iobrokers.
    Wie kann ich wieder Updates installieren?
    HomoranH Meister MopperM Thomas BraunT 3 Antworten Letzte Antwort
    • T Tjaden
      NPM version: 8.1.4
      npm ERR! code E404
      @tjaden sagte in Adapterupdates nicht möglich:
      npm ERR! code E404
      nicht erreichbar
      • T Tjaden
        NPM version: 8.1.4
        npm ERR! code E404
        Meister MopperM Online
        Meister Mopper
        @tjaden Die 8er npm-Installation muss zurück zur 6. Die funktioniert nicht mit ioBroker.
        Proxmox und HA ...
        • T Tjaden
          NPM version: 8.1.4
          npm ERR! code E404
          NPM version: 8.1.4
          Falsch installiert. Da sollte npm@6 auftauchen.
          Schau in meiner Signatur, wie es richtig geht.
            NPM version: 8.1.4
            Tjaden
            Danke für die schnellen Antworten!
            leider funktioniert das Downgrade via
            npm install -g npm@6.14.13
            nicht.
            npm -v
            liefert immer noch 8.1.4
            • T Tjaden
              nicht.
              npm -v
              @tjaden
              Richtig, man macht das ja auch nicht so.
              Lies mein HowTo (siehe Signatur), da steht alles drin.
                @tjaden
                Tjaden
                @thomas-braun Das hatte ich mir angesehen, leider ergibt die Suche nach "downgrade" kein Ergebnis. Wonach muss ich suchen?
                • T Tjaden
                  @tjaden
                  Erstmal schauen wo du da genau hängst:
                  which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                    @tjaden
                    Tjaden
                    @thomas-braun musste mir erst mal eine Autotype-funktion basteln, Strg+V funktioniert ja nicht in Docker ...
                    /usr/bin/nodejs
                    /usr/local/bin/node
                    /usr/local/bin/npm
                    v16.13.0
                    v16.13.0
                    8.1.4
                    sudo: Hostname iobroker kann nicht aufgelöst werden
                    OK:1 http://security.debian.org/debian-security stretch/updates InRelease
                    Ign:2 http://deb.debian.org/debian stretch InRelease
                    OK:3 http://deb.debian.org/debian stretch-updates InRelease
                    OK:4 http://deb.debian.org/debian stretch Release
                    OK:6 https://deb.nodesource.com/node_16.x stretch InRelease
                    Aktualisierung für 112 Pakete verfügbar. Führen Sie »apt list --upgradable« au
                    s, um sie anzuzeigen.
                    Ign:1 http://deb.debian.org/debian stretch InRelease
                    OK:2 http://security.debian.org/debian-security stretch/updates InRelease
                    OK:5 https://deb.nodesource.com/node_16.x stretch InRelease
                    nodejs:
                      Installiert:           16.13.0-1nodesource1
                      Installationskandidat: 16.13.0-1nodesource1
                      Versionstabelle:
                     *** 16.13.0-1nodesource1 500
                    root@iobroker:/opt/iobroker#         500 https://deb.nodesource.com/node_16.x st
                    retch/main amd64 Packages
                         4.8.2~dfsg-1 500
                            500 http://deb.debian.org/debian stretch/main amd64 Packages
                    • T Tjaden
                      /usr/bin/nodejs
                      /usr/local/bin/node
                      /usr/local/bin/npm
                      v16.13.0
                      v16.13.0
                      8.1.4
                      nodejs:
                        Versionstabelle:
                           4.8.2~dfsg-1 500
                      root@iobroker
                      Murks. Kein root-login! Auch nicht im Docker.
                      Halte das System auf Stand.
                      debian stretch
                      Ist nicht mehr unterstützt. Installier was lebendes, buster oder bullseye.
                      node_16.x
                      und
                      /usr/local/bin/node
                      Installier node14, dann im richtigen Pfad.
                      Rechte Maustaste in einem Terminal funktioniert nicht?
                        root@iobroker
                        debian stretch
                        node_16.x
                        und
                        /usr/local/bin/node
                        Tjaden
                        schrieb am zuletzt editiert von Tjaden
                        @thomas-braun said in Adapterupdates nicht möglich:
                        root@iobroker
                        Meinst du mit der Aussage, ich solle mich nicht als "root" einloggen? Ich logge mich da gar nicht ein, ich öffne lediglich das Terminal in Docker – man ist dort automatisch eingeloggt.
                        Das war mein Plan heute, daher hatte ich die Updates von Node, iobroker und NPM gemacht. Was sind die anderen 109 Pakete? Und wir haben ja festgestellt dass Updates im Zusammenhang mit iobroker eher kontraproduktiv sind, wenn Node 16 und NPM 8 zu neue Versionen sind.
                        debian stretch
                        Keine Ahnung was das ist oder wie ich etwas "lebendes" installiere.
                        node_16.x
                        und
                        /usr/local/bin/node
                        Das Update von Node 10 zu 16 hat mich ca. zwei Stunden gekostet, da trotz erfolgreichem Update am Ende immer Version 10.6 dort stand. Ich musste die 10er-Version deinstallieren und dann habe ich offenbar die Ordner /usr/local/bin/node und /usr/bin/node verknüpft, seitdem zeigt er die Version 16 statt 10 an.
                        Nachtrag: Der Befehl lautete
                        sudo ln -s /usr/bin/nodejs /usr/bin/node
                        Mein einziger Kontakt zu Debian/Linux ist das Terminal in Docker auf meinem Synology NAS, sonst habe ich damit nichts am Hut. Bislang hatten die Updates nie so funktioniert wie in den Anleitungen hier beschrieben.
                        Ich versuche nun noch mal das Downgrade zu Node 14, leider hatte ich Docker neu gestartet und daher sind die Kommandos weg, die ich vorher mühsam ergoogelt habe.
                        Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                        • T Tjaden
                          root@iobroker
                          debian stretch
                          node_16.x
                          und
                          /usr/local/bin/node
                          @tjaden
                          Das sind offenbar veraltete Pakte vom Betriebssystem.
                          Nein, DU hast aktiv node16 installiert, entgegen der Empfehlung node14 zu verwenden. Das kann man durch entsprechende nodesource-Repos ja ganz wunderbar steuern.
                          Sind die Namen der zur Zeit 'lebendigen' Releases von Debian.
                          Das sind 1:58 zu lang. Man muss lediglich in einer Datei ein Zeichen ersetzen und dann upgraden. Dann passt es sofort. So mache ich das im HowTo aus meiner Signatur.
                          • T Tjaden
                            root@iobroker
                            debian stretch
                            node_16.x
                            und
                            /usr/local/bin/node
                            Chaos... In /usr/local/bin darf node gar nicht liegen.
                            Der genannte ln -s Befehl verknüpft auch nichts aus /usr/local/bin.
                            • T Tjaden
                              root@iobroker
                              debian stretch
                              node_16.x
                              und
                              /usr/local/bin/node
                              dann war bislang schon deine Intsalltion immer krumm.
                              Zieh die hier einmalig wirklich gerade, dann fluppt es auch bei dir.
                              Und lass sie dann auch gerade!
                                Tjaden
                                @homoran Bislang war ich froh, dass es nach viel anfänglichem trial and error irgendwann lief – und dies nun seit 2018. Wie gesagt, jedes Update ist immer ein großer Aufwand da die Anleitungen hier nicht wirklich funktionieren. "iobroker stop" z. B. funktioniert nicht, ich nutze dafür "pkill io", was meiner Annahme nach dem Umstand geschuldet ist dass iobroker bei mir im Docker auf der Synology NAS läuft.
                                Okay, wie ändere ich das?
                                Seit dem "ln -s Befehl" bekomme ich aber sowohl bei "node -v" als auch bei "nodejs -v" die gleiche Version angezeigt.
                                Bislang habe ich mich beim iobroker ausschließlich mit JS und VIS beschäftigt – eben zwecks Automatisierung einiger Vorgänge im Haus. Das klappt auch mehr oder weniger gut (alle paar Monate muss ich einige Skripte neu starten), aktuell beschäftige ich mich wieder damit weil die Speak-Befehle von Alexa2 nicht mehr funktionieren. (Ich habe ein JS geschrieben, welches entsprechende Durchsagen im Haus macht bei gewissen E-Mails. Das lief auch bis vor kurzem noch einwandfrei)
                                Sehr gerne würde ich das System geradeziehen und bin offen für Vorschläge. Leider fehlt mir das Hintergrundwissen, wie ich das mache.
                                HomoranH Thomas BraunT haselchenH 4 Antworten Letzte Antwort
                                • T Tjaden
                                  Ja!
                                  aber warum tust du dir einen Docker an, wenn du mit
                                  Debian/Linux ... damit nichts am Hut.
                                  hast?
                                  Ein Container erfordert immer deutlich mehr Kenntnisse/Aufwand als eine Installation auf reinem Linux.
                                  Und bei Linux brauchst du auch nicht wirklich mehr Kenntnisse als bei einem Windows-Rechner.
                                  Da programmierst du ja auch nicht auf Betriebssystemebene
                                  • T Tjaden
                                    @tjaden Mal in das bereits genannte HowTo zu nodeJS geschaut?
                                    Da steht soweit eigentlich alles drin.
                                    • T Tjaden
                                      Freche Behauptung.
                                      HomoranH T 2 Antworten Letzte Antwort
                                        Freche Behauptung.
                                        @thomas-braun sagte in Adapterupdates nicht möglich:
                                        Freche Behauptung.
                                        Naja,
                                        Wenn @Tjaden sich ungefiltert die Linux-Anleitungen ansieht.
                                        Da muss er schon bei Docker-Anleitungen nachsehen.
                                        Die klappen dann auch
                                        • T Tjaden
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          @tjaden
                                          Nur der Richtigkeithalber:
                                          Seit Node 12 funktioniert pkill io nicht mehr wie erwartet. Stattdessen pkill node oder pkill -u iobroker
