  4. Node-Red
  5. [gelöst] Umwandlung von Objekt in String
    6.5k
22 Beiträge 3 Kommentatoren 907 Aufrufe 3 Beobachtet
  • Claus1985 0C Claus1985 0
    mickymM Offline
    mickymM Offline
    mickym
    @claus1985-0 Dann wäre es doch mal das Einfachste, wenn Du in allen Nodes Brightness groß schreibst - dann sollte es gehen.
           "id": "9ab6af5f.30ba",
           "type": "switch",
           "z": "a37484bb.f4a9e8",
           "name": "payload.Brightness gesetzt?",
           "property": "payload.Brightness",
           "propertyType": "msg",
           "rules": [
                   "t": "null"
                   "t": "nnull"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 500,
           "y": 1580,
           "wires": [
                   "8894c9b1.f9e498"
                   "42d4c7a5.ad8cf8"
           "id": "8894c9b1.f9e498",
           "type": "change",
           "name": "payload.On ?",
           "rules": [
                   "t": "change",
                   "p": "payload.On",
                   "pt": "msg",
                   "from": "true",
                   "fromt": "bool",
                   "to": "100",
                   "tot": "num"
                   "t": "change",
                   "p": "payload.On",
                   "pt": "msg",
                   "from": "false",
                   "fromt": "bool",
                   "to": "0",
                   "tot": "num"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 740,
           "y": 1540,
           "wires": [
                   "2d830216.3daeee"
           "id": "2d830216.3daeee",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload.On",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 940,
           "y": 1540,
           "wires": [
                   "a0915145.3a028"
           "id": "42d4c7a5.ad8cf8",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload.Brightness",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 950,
           "y": 1600,
           "wires": [
                   "a0915145.3a028"
           "id": "a0915145.3a028",
           "type": "debug",
           "name": "Ergebnis",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "",
           "statusType": "auto",
           "x": 1160,
           "y": 1560,
           "wires": []
           "id": "1e404736.197149",
           "type": "inject",
           "name": "Helligkeit geändert",
           "props": [
                   "p": "payload.Brightness",
                   "v": "45",
                   "vt": "num"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "x": 250,
           "y": 1540,
           "wires": [
                   "9ab6af5f.30ba"
           "id": "245d320e.f6207e",
           "type": "inject",
           "name": "Ein",
           "props": [
                   "p": "payload.On",
                   "v": "true",
                   "vt": "bool"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "x": 280,
           "y": 1580,
           "wires": [
                   "9ab6af5f.30ba"
           "id": "c75eb9f8.260d38",
           "type": "inject",
           "name": "Aus",
           "props": [
                   "p": "payload.On",
                   "v": "false",
                   "vt": "bool"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "x": 280,
           "y": 1620,
           "wires": [
                   "9ab6af5f.30ba"
    Das wäre dann eigentlich das Minimum der Anpassung gewesen - bevor ich schreibe, dass es nicht funktioniert:
    Bei mir tuts jedenfalls
    und meine Inject Node erzeugt das gleiche Objekt:
    Claus1985 0C 1 Antwort Letzte Antwort
    • mickymM mickym
             "type": "switch",
             "rules": [
                     "t": "null"
                     "t": "nnull"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 500,
             "y": 1580,
             "wires": [
                     "8894c9b1.f9e498"
                     "42d4c7a5.ad8cf8"
             "type": "change",
             "rules": [
                     "t": "change",
                     "p": "payload.On",
                     "pt": "msg",
                     "from": "true",
                     "fromt": "bool",
                     "to": "100",
                     "tot": "num"
                     "t": "change",
                     "p": "payload.On",
                     "pt": "msg",
                     "from": "false",
                     "fromt": "bool",
                     "to": "0",
                     "tot": "num"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 740,
             "y": 1540,
             "wires": [
                     "2d830216.3daeee"
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "payload.On",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 940,
             "y": 1540,
             "wires": [
                     "a0915145.3a028"
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 950,
             "y": 1600,
             "wires": [
                     "a0915145.3a028"
             "type": "debug",
             "name": "Ergebnis",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 1160,
             "y": 1560,
             "wires": []
             "type": "inject",
             "props": [
                     "v": "45",
                     "vt": "num"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "x": 250,
             "y": 1540,
             "wires": [
                     "9ab6af5f.30ba"
             "type": "inject",
             "name": "Ein",
             "props": [
                     "p": "payload.On",
                     "v": "true",
                     "vt": "bool"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "x": 280,
             "y": 1580,
             "wires": [
                     "9ab6af5f.30ba"
             "type": "inject",
             "name": "Aus",
             "props": [
                     "p": "payload.On",
                     "v": "false",
                     "vt": "bool"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "x": 280,
             "y": 1620,
             "wires": [
                     "9ab6af5f.30ba"
      Claus1985 0C Offline
      Claus1985 0
      @mickym Hast Recht, funktioniert, danke für den Hinweis! Ein Detail passt so allerdings noch nicht. Und zwar wenn Brightness gesetzt wird und On auch (z.B. Lampe aus und wird per Befehl auf 73 gesetzt). Dann setzt er die Zahl (z.B. 73) und direkt danach die 100. Ich schätze Homekit sendet dann zwei Befehle in sehr kurzer Abfolge das führt dann zu diesem Ergebnis.
        mickymM Offline
        mickymM Offline
        mickym
        @claus1985-0 Wenn Brightness gesetzt ist - wird doch ON im Flow ignoriert oder werden da 2 Nachrichten gesendet? Sprich wenn im Objekt Brightness und On gesetzt ist, wird doch ignoriert. Ich verstehe es nicht - da kommt keine 100 hinter her.
        • mickymM mickym
          Claus1985 0
          Er sendet da direkt nacheinander On und 100 bzw. On und 73 (siehe Anhang).
          Das Ergebnis ist zwar gleichzeitig aber für ihn sind es zwei einzelne Nachrichten.
            mickymM Offline
            mickymM Offline
            mickym
            @claus1985-0 Na ganz habe ich es noch nicht verstanden:
            Also egal ob Du einschaltest oder dimmst - es kommt immer
            eine Nachricht mit
            1. ON
              und
            2. Brightness
            Das heißt die Brightness kommt als 2. und überschreibt immer was davor gesetzt wurde, nur OFF schickt keine Nachricht mehr hinterher?
            Claus1985 0C F 2 Antworten Letzte Antwort
            • mickymM mickym
              eine Nachricht mit
              1. ON
                und
              2. Brightness
              Claus1985 0
              schrieb am zuletzt editiert von Claus1985 0
              @mickym Ist etwas seltsam was Homekit da schickt. Folgendes:
              Wenn ich die Lampe einschalte (also einfach an) kommt ON = true und Brightness = 100.
              Wenn ich die Lampe ausschalte kommt nur ON = False
              Wenn ich die Lampe mit 73% einschalte (vorher aus) dann kommt ON = true und Brightness = 73
              Wenn ich die Lampe von 73% auf 80% ändere kommt nur Brightness = 80
              Rein von der Perspektive aus müsste Deine Logik funktionieren denn Du fängst ja vorher das Brightness ab.
              Es scheint aber so zu sein, dass obwohl der Zeitstempel der Nachrichten gleich ist, sie im Hintergrund leicht
              versetzt kommen. Dadurch greift es dann nicht.
                mickymM Offline
                mickymM Offline
                mickym
                @claus1985-0 Ok das letzte hilft - im Prinzip hat das Teil im Hinterkopf ob die Lampe ein- oder ausgeschaltet ist. Man muss halt nur wissen, dass bei ON halt Brightness folgt, oder nur Brightness - Off wird halt immer 0.
                • mickymM mickym
                  eine Nachricht mit
                  1. ON
                    und
                  2. Brightness
                  frankyboy73
                  @mickym Hi, bei der Abfrage payload.Brithness ist nicht Null (switch), flutscht die msg.payload.On noch mit durch, die muss noch abgefangen werden.
                  Schöne Grüße Frank
                  • mickymM mickym
                    Claus1985 0
                    @mickym Gute Idee, danke Dir! Habs mit einem zusätzlichen Switch gelöst.
                    OK also irgendwie scheint die Ausgabe von Homekit auch eher zufällig zu sein.
                    Jetzt gibt er mir beim Einschalten auch teilweise nur ON = true ohne Brightness aus..
                    Es gibt also wohl beide Fälle.
                    • F frankyboy73
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @frankyboy73 @Claus1985-0
                      Genau - so wird nun On=true komplett ignoriert und damit müsste es nach der Logik gehen:
                             "id": "78e5c88c.0d9b08",
                             "type": "switch",
                             "name": "",
                             "property": "payload.On",
                             "rules": [
                                     "t": "true"
                                     "t": "false"
                                     "t": "else"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 3,
                             "x": 470,
                             "y": 1780,
                             "wires": [
                                     "648496f9.de89d8"
                                     "39869018.4b8c4"
                             "id": "d85d77b3.309d98",
                             "type": "inject",
                             "props": [
                                     "v": "45",
                                     "vt": "num"
                             "repeat": "",
                             "crontab": "",
                             "once": false,
                             "onceDelay": 0.1,
                             "topic": "",
                             "payloadType": "str",
                             "x": 230,
                             "y": 1700,
                             "wires": [
                                     "78e5c88c.0d9b08"
                             "id": "4a5abaae.3d7494",
                             "type": "inject",
                             "name": "Ein",
                             "props": [
                                     "p": "payload.On",
                                     "v": "true",
                                     "vt": "bool"
                             "repeat": "",
                             "crontab": "",
                             "once": false,
                             "onceDelay": 0.1,
                             "topic": "",
                             "x": 280,
                             "y": 1780,
                             "wires": [
                                     "78e5c88c.0d9b08"
                             "id": "d4e38a8d.f33978",
                             "type": "inject",
                             "name": "Aus",
                             "props": [
                                     "p": "payload.On",
                                     "v": "false",
                                     "vt": "bool"
                             "repeat": "",
                             "crontab": "",
                             "once": false,
                             "onceDelay": 0.1,
                             "topic": "",
                             "x": 280,
                             "y": 1820,
                             "wires": [
                                     "78e5c88c.0d9b08"
                             "id": "3fe1f543.71321a",
                             "type": "inject",
                             "props": [
                                     "v": "100",
                                     "vt": "num"
                             "repeat": "",
                             "crontab": "",
                             "once": false,
                             "onceDelay": 0.1,
                             "topic": "",
                             "x": 230,
                             "y": 1740,
                             "wires": [
                                     "78e5c88c.0d9b08"
                             "id": "648496f9.de89d8",
                             "type": "change",
                             "name": "=0",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "0",
                                     "tot": "num"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 690,
                             "y": 1740,
                             "wires": [
                                     "9a98a415.b95d08"
                             "id": "39869018.4b8c4",
                             "type": "change",
                             "name": "",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "msg"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 650,
                             "y": 1800,
                             "wires": [
                                     "9a98a415.b95d08"
                             "id": "9a98a415.b95d08",
                             "type": "debug",
                             "name": "Ergebnis",
                             "active": true,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 840,
                             "y": 1760,
                             "wires": []
                      Man muss nur den siwtch das true mit abfragen, aber lässt es ins leere laufen. Off wird auf 0 gesetzt. On wird ignoriert, da entweder Brightness folgt - oder ON eh nicht geschickt wird und nur Brightness.
                      F 1 Antwort Letzte Antwort
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @claus1985-0 sagte in Umwandlung von Objekt in String:
                        Ok dann kannst auch die Brightness setzen - dann wird sie mit der nächsten Brightness ggf. auf den richtigen Wert über schrieben. Dann macht man einen Trigger hinten dran. Ich machs mal kurz.
                               "type": "switch",
                               "name": "",
                               "rules": [
                                       "t": "true"
                                       "t": "false"
                                       "t": "else"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 3,
                               "x": 450,
                               "y": 1780,
                               "wires": [
                                       "8b24d14b.fc4a7"
                                       "648496f9.de89d8"
                                       "39869018.4b8c4"
                               "type": "inject",
                               "props": [
                                       "v": "45",
                                       "vt": "num"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "x": 210,
                               "y": 1700,
                               "wires": [
                                       "78e5c88c.0d9b08"
                               "type": "inject",
                               "name": "Ein",
                               "props": [
                                       "p": "payload.On",
                                       "v": "true",
                                       "vt": "bool"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "x": 260,
                               "y": 1780,
                               "wires": [
                                       "78e5c88c.0d9b08"
                               "type": "inject",
                               "name": "Aus",
                               "props": [
                                       "p": "payload.On",
                                       "v": "false",
                                       "vt": "bool"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "x": 260,
                               "y": 1820,
                               "wires": [
                                       "78e5c88c.0d9b08"
                               "type": "inject",
                               "props": [
                                       "v": "100",
                                       "vt": "num"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "x": 210,
                               "y": 1740,
                               "wires": [
                                       "78e5c88c.0d9b08"
                               "type": "change",
                               "name": "=0",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "0",
                                       "tot": "num"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 670,
                               "y": 1760,
                               "wires": [
                                       "5590f91.34c2208"
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 630,
                               "y": 1800,
                               "wires": [
                                       "5590f91.34c2208"
                               "id": "8b24d14b.fc4a7",
                               "type": "change",
                               "name": "=100",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "100",
                                       "tot": "num"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 670,
                               "y": 1720,
                               "wires": [
                                       "5590f91.34c2208"
                               "id": "5590f91.34c2208",
                               "type": "trigger",
                               "name": "",
                               "op1": "",
                               "op2": "",
                               "op1type": "nul",
                               "op2type": "payl",
                               "duration": "100",
                               "extend": true,
                               "overrideDelay": false,
                               "units": "ms",
                               "reset": "",
                               "bytopic": "all",
                               "topic": "topic",
                               "outputs": 1,
                               "x": 850,
                               "y": 1760,
                               "wires": [
                                       "3714948f.7669bc"
                               "id": "3714948f.7669bc",
                               "type": "debug",
                               "name": "Ergebnis",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 1020,
                               "y": 1760,
                               "wires": []
                        Wenn man das mit Inject Nodes testen will muss man es halt auf 1 s hoch setzen. Wenn aber von der Node 2 Nachrichten kommen, sollten 100s vielleicht ausreichen - ansonsten den Wert halt auf 250 ms erhöhen.
                        • mickymM mickym
                                 "type": "switch",
                                 "name": "",
                                 "rules": [
                                         "t": "true"
                                         "t": "false"
                                         "t": "else"
                                 "checkall": "true",
                                 "repair": false,
                                 "outputs": 3,
                                 "x": 470,
                                 "y": 1780,
                                 "wires": [
                                         "648496f9.de89d8"
                                         "39869018.4b8c4"
                                 "type": "inject",
                                 "props": [
                                         "v": "45",
                                         "vt": "num"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "x": 230,
                                 "y": 1700,
                                 "wires": [
                                         "78e5c88c.0d9b08"
                                 "type": "inject",
                                 "name": "Ein",
                                 "props": [
                                         "p": "payload.On",
                                         "v": "true",
                                         "vt": "bool"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "x": 280,
                                 "y": 1780,
                                 "wires": [
                                         "78e5c88c.0d9b08"
                                 "type": "inject",
                                 "name": "Aus",
                                 "props": [
                                         "p": "payload.On",
                                         "v": "false",
                                         "vt": "bool"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "x": 280,
                                 "y": 1820,
                                 "wires": [
                                         "78e5c88c.0d9b08"
                                 "type": "inject",
                                 "props": [
                                         "v": "100",
                                         "vt": "num"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "x": 230,
                                 "y": 1740,
                                 "wires": [
                                         "78e5c88c.0d9b08"
                                 "type": "change",
                                 "name": "=0",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "0",
                                         "tot": "num"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 690,
                                 "y": 1740,
                                 "wires": [
                                         "9a98a415.b95d08"
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 650,
                                 "y": 1800,
                                 "wires": [
                                         "9a98a415.b95d08"
                                 "type": "debug",
                                 "name": "Ergebnis",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 840,
                                 "y": 1760,
                                 "wires": []
                          frankyboy73
                          @mickym Hi, ich hätte eigentlich eher gedacht es reicht die msg.payload.On in der Change node zu löschen, da auf dem Weg ja eh nur die Brithness ausgegeben werden soll.
                                 "type": "switch",
                                 "z": "c33d5c4d.42855",
                                 "rules": [
                                         "t": "null"
                                         "t": "nnull"
                                 "checkall": "true",
                                 "repair": false,
                                 "outputs": 2,
                                 "x": 380,
                                 "y": 1060,
                                 "wires": [
                                         "8894c9b1.f9e498"
                                         "42d4c7a5.ad8cf8"
                                 "type": "change",
                                 "rules": [
                                         "t": "change",
                                         "p": "payload.On",
                                         "pt": "msg",
                                         "from": "true",
                                         "fromt": "bool",
                                         "to": "100",
                                         "tot": "num"
                                         "t": "change",
                                         "p": "payload.On",
                                         "pt": "msg",
                                         "from": "false",
                                         "fromt": "bool",
                                         "to": "0",
                                         "tot": "num"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 620,
                                 "y": 1020,
                                 "wires": [
                                         "2d830216.3daeee"
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "payload.On",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 820,
                                 "y": 1020,
                                 "wires": [
                                         "a0915145.3a028"
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "delete",
                                         "p": "payload.On",
                                         "pt": "msg"
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 830,
                                 "y": 1080,
                                 "wires": [
                                         "a0915145.3a028"
                                 "type": "debug",
                                 "name": "Ergebnis",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1040,
                                 "y": 1040,
                                 "wires": []
                                 "type": "inject",
                                 "props": [
                                         "v": "45",
                                         "vt": "num"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "x": 130,
                                 "y": 1020,
                                 "wires": [
                                         "9ab6af5f.30ba"
                                 "type": "inject",
                                 "name": "Ein",
                                 "props": [
                                         "p": "payload.On",
                                         "v": "true",
                                         "vt": "bool"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "x": 160,
                                 "y": 1060,
                                 "wires": [
                                         "9ab6af5f.30ba"
                                 "type": "inject",
                                 "name": "Aus",
                                 "props": [
                                         "p": "payload.On",
                                         "v": "false",
                                         "vt": "bool"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "x": 160,
                                 "y": 1100,
                                 "wires": [
                                         "9ab6af5f.30ba"
                          Schöne Grüße Frank
                          • F frankyboy73
                                   "type": "switch",
                                   "rules": [
                                           "t": "null"
                                           "t": "nnull"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 2,
                                   "x": 380,
                                   "y": 1060,
                                   "wires": [
                                           "8894c9b1.f9e498"
                                           "42d4c7a5.ad8cf8"
                                   "type": "change",
                                   "rules": [
                                           "t": "change",
                                           "p": "payload.On",
                                           "pt": "msg",
                                           "from": "true",
                                           "fromt": "bool",
                                           "to": "100",
                                           "tot": "num"
                                           "t": "change",
                                           "p": "payload.On",
                                           "pt": "msg",
                                           "from": "false",
                                           "fromt": "bool",
                                           "to": "0",
                                           "tot": "num"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 620,
                                   "y": 1020,
                                   "wires": [
                                           "2d830216.3daeee"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "payload.On",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 820,
                                   "y": 1020,
                                   "wires": [
                                           "a0915145.3a028"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "delete",
                                           "p": "payload.On",
                                           "pt": "msg"
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 830,
                                   "y": 1080,
                                   "wires": [
                                           "a0915145.3a028"
                                   "type": "debug",
                                   "name": "Ergebnis",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1040,
                                   "y": 1040,
                                   "wires": []
                                   "type": "inject",
                                   "props": [
                                           "v": "45",
                                           "vt": "num"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "x": 130,
                                   "y": 1020,
                                   "wires": [
                                           "9ab6af5f.30ba"
                                   "type": "inject",
                                   "name": "Ein",
                                   "props": [
                                           "p": "payload.On",
                                           "v": "true",
                                           "vt": "bool"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "x": 160,
                                   "y": 1060,
                                   "wires": [
                                           "9ab6af5f.30ba"
                                   "type": "inject",
                                   "name": "Aus",
                                   "props": [
                                           "p": "payload.On",
                                           "v": "false",
                                           "vt": "bool"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "x": 160,
                                   "y": 1100,
                                   "wires": [
                                           "9ab6af5f.30ba"
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @frankyboy73 sagte in Umwandlung von Objekt in String:
                            e eicht die msg.payload.On in der Change node zu löschen
                            Nee das ist unnötig - da ich ja in der Change node - die komplette payload mit Brightness überschreibe - damit ist die payload ja ein skalares Objekt - sprich Zahl - sprich alle Eigenschaften des payload Objektes sind ja sowieso weg.
                            Aber egal - ich glaube Du kannst es nur mit der Trigger Node machen - da unser TE ja inzwischen alle Möglichkeiten, ON mit Brightness, nur Brightness, nur ON hatte. Ursprünglich dachte ich ja dann wie Du ich kann auch ON komplett verzichten - aber dem ist ja auch nicht so,.
                            • mickymM mickym
                                     "type": "switch",
                                     "name": "",
                                     "rules": [
                                             "t": "true"
                                             "t": "false"
                                             "t": "else"
                                     "checkall": "true",
                                     "repair": false,
                                     "outputs": 3,
                                     "x": 450,
                                     "y": 1780,
                                     "wires": [
                                             "8b24d14b.fc4a7"
                                             "648496f9.de89d8"
                                             "39869018.4b8c4"
                                     "type": "inject",
                                     "props": [
                                             "v": "45",
                                             "vt": "num"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "x": 210,
                                     "y": 1700,
                                     "wires": [
                                             "78e5c88c.0d9b08"
                                     "type": "inject",
                                     "name": "Ein",
                                     "props": [
                                             "p": "payload.On",
                                             "v": "true",
                                             "vt": "bool"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "x": 260,
                                     "y": 1780,
                                     "wires": [
                                             "78e5c88c.0d9b08"
                                     "type": "inject",
                                     "name": "Aus",
                                     "props": [
                                             "p": "payload.On",
                                             "v": "false",
                                             "vt": "bool"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "x": 260,
                                     "y": 1820,
                                     "wires": [
                                             "78e5c88c.0d9b08"
                                     "type": "inject",
                                     "props": [
                                             "v": "100",
                                             "vt": "num"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "x": 210,
                                     "y": 1740,
                                     "wires": [
                                             "78e5c88c.0d9b08"
                                     "type": "change",
                                     "name": "=0",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "0",
                                             "tot": "num"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 670,
                                     "y": 1760,
                                     "wires": [
                                             "5590f91.34c2208"
                                     "type": "change",
                                     "name": "",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "msg"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 630,
                                     "y": 1800,
                                     "wires": [
                                             "5590f91.34c2208"
                                     "type": "change",
                                     "name": "=100",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "100",
                                             "tot": "num"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 670,
                                     "y": 1720,
                                     "wires": [
                                             "5590f91.34c2208"
                                     "type": "trigger",
                                     "name": "",
                                     "op1": "",
                                     "op2": "",
                                     "op1type": "nul",
                                     "op2type": "payl",
                                     "duration": "100",
                                     "extend": true,
                                     "units": "ms",
                                     "reset": "",
                                     "bytopic": "all",
                                     "topic": "topic",
                                     "outputs": 1,
                                     "x": 850,
                                     "y": 1760,
                                     "wires": [
                                             "3714948f.7669bc"
                                     "type": "debug",
                                     "name": "Ergebnis",
                                     "active": true,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1020,
                                     "y": 1760,
                                     "wires": []
                              Claus1985 0
                              @mickym Funktioniert perfekt, danke Dir!!
                                mickymM Offline
                                mickymM Offline
                                mickym
                                Freut mich! Vielleicht ist NodeRed ohne 20 Programmzeilen doch einfacher. ;)
