  4. Node-red nicht mehr verfügbar
    5.4k
node-red
8 Beiträge 4 Kommentatoren 2.7k Aufrufe 1 Watching
    spielberger32
    ich hoffe ihr wisst eine Lösung, denn node-red ist nicht mehr aufrufbar und produziert bei mir alle paar Sekunden folgende Fehlermeldung
    node-red exited with 1
    warn Error: Cannot find module 'clone'
    Das ist ein Auszug aus dem Log (wiederholt sich alle paar Sekunden):
    node-red.0	2017-03-05 14:55:24.945	info	node-red exited with 1
    node-red.0	2017-03-05 14:55:24.927	warn	at require (internal/module.js:12:17)
    node-red.0	2017-03-05 14:55:24.927	warn	at Module.require (module.js:353:17)
    node-red.0	2017-03-05 14:55:24.927	warn	at Function.Module._load (module.js:300:12)
    node-red.0	2017-03-05 14:55:24.927	warn	at Module.load (module.js:343:32)
    node-red.0	2017-03-05 14:55:24.927	warn	at Object.Module._extensions..js (module.js:416:10)
    node-red.0	2017-03-05 14:55:24.927	warn	at Module._compile (module.js:409:26)
    node-red.0	2017-03-05 14:55:24.927	warn	at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/flows/index.js:17:13)
    node-red.0	2017-03-05 14:55:24.927	warn	at Function.Module._load (module.js:276:25)
    node-red.0	2017-03-05 14:55:24.927	warn	at Function.Module._resolveFilename (module.js:325:15)
    node-red.0	2017-03-05 14:55:24.927	warn	Error: Cannot find module 'clone'
    node-red.0	2017-03-05 14:55:24.927	warn	^
    node-red.0	2017-03-05 14:55:24.927	warn	throw err;
    node-red.0	2017-03-05 14:55:24.927	warn	module.js:327
    node-red.0	2017-03-05 14:55:23.686	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    node-red.0	2017-03-05 14:55:18.683	info	node-red exited with 1
    node-red.0	2017-03-05 14:55:18.677	warn	at require (internal/module.js:12:17)
    node-red.0	2017-03-05 14:55:18.677	warn	at Module.require (module.js:353:17)
    node-red.0	2017-03-05 14:55:18.677	warn	at Function.Module._load (module.js:300:12)
    node-red.0	2017-03-05 14:55:18.677	warn	at Module.load (module.js:343:32)
    node-red.0	2017-03-05 14:55:18.677	warn	at Object.Module._extensions..js (module.js:416:10)
    node-red.0	2017-03-05 14:55:18.677	warn	at Module._compile (module.js:409:26)
    node-red.0	2017-03-05 14:55:18.677	warn	at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/flows/index.js:17:13)
    node-red.0	2017-03-05 14:55:18.677	warn	at Function.Module._load (module.js:276:25)
    node-red.0	2017-03-05 14:55:18.677	warn	at Function.Module._resolveFilename (module.js:325:15)
    node-red.0	2017-03-05 14:55:18.677	warn	Error: Cannot find module 'clone'
    node-red.0	2017-03-05 14:55:18.677	warn	^
    node-red.0	2017-03-05 14:55:18.677	warn	throw err;
    node-red.0	2017-03-05 14:55:18.677	warn	module.js:327
    node-red.0	2017-03-05 14:55:17.387	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    Das Hinzufügen des angegebenen Moduls führt dazu, dass ein weiteres Modul angefragt wird. Selbe Warnmeldung, anderes Modul. Neuinstallation von node-red bringt nichts.
    Ich habe node-red bislang nur für Tests benutzt, also auch nichts großes damit angestellt oder geändert. Mein Eindruck ist, dass es seit einem Upgrade aller Adapter auftritt. Der node-red-Programmiertab gibt aus: 192.168.XXX.XXX hat die Verbindung abgelehnt
    Host: Raspberry Pi
    node-red Version: 1.1.6
    <size size="85">„Alte Knaben haben genauso ihr Spielzeug wie die jungen, der Unterschied liegt lediglich im Preis.“
    Benjamin Franklin</size>
      kann es sein, dass dein RAM zur Neige geht?
      Das Forum freut sich über eine Spende. Benutzt dazu den Spendenbutton im Header. Danke!
        spielberger32
        Das ist durchaus möglich, aber ich verstehe nicht was das damit zu tun hat :?: vorher lief es ja problemlos …
          War nur ein Schuss ins Blaue, nach der Meldung:
          und der Info, dass es immer wieder andere Module sind, die beim Versuch node-red zu starten nicht geladen werden.
          • BluefoxB Offline
            BluefoxB Offline
            Probier mal node-red adapter neu zu installieren:
            http://www.iobroker.net/docu/?page_id=3 … stallieren
              spielberger32
              Hmm das stimmt :| Und was wäre die Lösung? Es laufen jedenfalls keine überflüssigen Instanzen. Alle Instanzen temporär stoppen und dann node-red starten?
              @Bluefox:
              http://www.iobroker.net/docu/?page_id=3 … stallieren `
              Okay … probiere ich aus
                spielberger32
                Die Lösung von Bluefox HAT FUNKTIONIERT! Hatte nicht auf dem Schirm es komplett manuell über die Konsole zu machen :oops:
                Ich musste allerdings den RPi nochmal durchstartet und den node-red.0-Tab entfernen und neu anlegen.
                Kommt jetzt nur einmal beim Start folgende Meldung:
                node-red.0	2017-03-05 16:03:53.171	warn	5 Mar 16:03:53 - [warn] - node-red-node-serialport: serial in, serial out, serial-port
                node-red.0	2017-03-05 16:03:53.160	warn	5 Mar 16:03:53 - [warn] Missing node modules:
                das war's.
                Super! Vielen Dank!
                  schubi82
                  Hallo zusammen! Ich habe das gleiche Problem, kann aber nicht mehr auf die Anleitung zugreifen..
                  Ich bekomme NodeRed einfach nicht installiert, es handelt sich um ein neues Image und Backup einer alten Installation.
                  Folgender Fehler erscheint:
                  $ ./iobroker add node-red  --host raspberrypi
                  NPM version: 6.11.3
                  npm install iobroker.node-red@1.13.0 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
                  npm WARN tar invalid entrynpm WARN tar invalid entry
                  npm WARN tarball cached data for libmime@4.1.1 (sha512-HkOfBSj+l7pBOOucEgiI6PdbgHa8ljv+1rARzW743HQ51UP8gabMlcA2wAF3Dg1aeuMjHZ+LzAPYxM52IZsyGA==) seems to be corrupted. Refreshing cache.
                  npm
                   WARN tar zlib: unexpected end of file
                  In file included from ../node_modules/nan/nan.h:190,                 from ../src/unix_dgram.cc:5:
                  ../node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribute)’:
                  ../node_modules/nan/nan_maybe_43_inl.h:88:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
                     return obj->ForceSet(GetCurrentContext(), key, value, attribs);
                  In file included from ../src/unix_dgram.cc:5:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
                  ../node_modules/nan/nan.h:817:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                           v8::Isolate::GetCurrent(), target, func, argc, argv);
                  In file included from ../node_modules/nan/nan.h:47,                 from ../src/unix_dgram.cc:5:
                  /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:177:50: note: declared here
                                   NODE_EXTERN v8::Local<v8::Value> MakeCallback(
                  /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
                       __attribute__((deprecated(message))) declarator
                  ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
                  ../node_modules/nan/nan.h:831:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                           v8::Isolate::GetCurrent(), target, symbol, argc, argv);
                  /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:170:50: note: declared here
                  ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
                  ../node_modules/nan/nan.h:845:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                           v8::Isolate::GetCurrent(), target, method, argc, argv);
                  /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:163:50: note: declared here
                  In file included from ../src/unix_dgram.cc:5:../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
                  ../node_modules/nan/nan.h:1463:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                  In file included from ../src/unix_dgram.cc:5:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                  ../node_modules/nan/nan.h:1706:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                       , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                  ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     domain      = info[0]->Int32Value();
                  In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:26,                 from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63,
                  /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2478:46: note: declared here
                     V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
                  /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                     declarator __attribute__((deprecated(message)))
                  ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     type        = info[1]->Int32Value();
                  ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]   protocol    = info[2]->Int32Value();
                  ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     fd = info[0]->Int32Value();
                  ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                     String::Utf8Value path(info[1]);
                  /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2892:28: note: declared here
                                     explicit Utf8Value(Local<v8::Value> obj));
                  ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                  ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     buf = info[1]->ToObject();
                  In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63,
                  /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:10046:15: note: declared here
                   Local<Object> Value::ToObject() const {
                  ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     offset = info[2]->Uint32Value();
                  /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:2477:47: note: declared here
                     V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
                  ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                     length = info[3]->Uint32Value();
                  ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
                     String::Utf8Value path(info[4]);
                  ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                  ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                  In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63,                 from ../node_modules/nan/nan.h:47,
                  ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                  ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]   String::Utf8Value path(info[1]);
                  ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                  ../src/unix_dgram.cc: At global scope:
                  /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                         (node::addon_register_func) (regfunc),                          \
                  /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
                     NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                  ../src/unix_dgram.cc:420:1: note: in expansion of macro ‘NODE_MODULE’
                   NODE_MODULE(unix_dgram, Initialize)
                  /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
                  /home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78:   required from here
                  /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                  reinterpret_cast<Callback>(callback), type);
                  /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:../node_modules/nan/nan_object_wrap.h:66:61:   required from here
                  /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                  make: *** [unix_dgram.target.mk:101: Release/obj.target/unix_dgram/src/unix_dgram.o] Error 1
                  gyp
                  ERR! build error
                  gyp ERR! stack Error: `make` failed with exit code: 2gyp
                   ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:193:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                  gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                  gyp ERR! System Linux 4.19.75-v7+
                  gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
                  gyp ERR! node -v v10.17.0
                  gyp ERR! node-gyp -v v5.0.3
                  gyp ERR! not ok
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                  host.raspberrypi install adapter node-red
                  ERROR: host.raspberrypi error: reading io-package.json SyntaxError: Unexpected string in JSON at position 1
                  ERROR: process exited with code 14
                  Ich verstehe nur Bahnhof :(
                  32.7k
                  82.5k
